[GRASS-SVN] r44647 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Dec 21 14:12:46 EST 2010
Author: martinl
Date: 2010-12-21 11:12:46 -0800 (Tue, 21 Dec 2010)
New Revision: 44647
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI: fix tab order (use pyscrolledwindow)
(merge r44646 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-12-21 19:05:23 UTC (rev 44646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-12-21 19:12:46 UTC (rev 44647)
@@ -45,7 +45,7 @@
import gcmd
import utils
from preferences import globalSettings as UserSettings
-from debug import Debug
+from debug import Debug
wxGdalSelect, EVT_GDALSELECT = NewEvent()
@@ -71,7 +71,7 @@
self.tcp = TreeCtrlComboPopup()
self.SetPopupControl(self.tcp)
- self.SetPopupExtents(0,100)
+ self.SetPopupExtents(0, 100)
if type:
self.tcp.SetData(type = type, mapsets = mapsets,
multiple = multiple,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-12-21 19:05:23 UTC (rev 44646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-12-21 19:12:46 UTC (rev 44647)
@@ -75,6 +75,7 @@
import wx.lib.flatnotebook as FN
import wx.lib.colourselect as csel
import wx.lib.filebrowsebutton as filebrowse
+import wx.lib.scrolledpanel as scrolled
from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
from wx.lib.newevent import NewEvent
@@ -662,28 +663,28 @@
wx.Frame.__init__(self, parent=parent, id=ID, title=title,
pos=wx.DefaultPosition, style=wx.DEFAULT_FRAME_STYLE | wx.TAB_TRAVERSAL,
name = "MainFrame")
self.locale = wx.Locale(language = wx.LANGUAGE_DEFAULT)
self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
# statusbar
self.CreateStatusBar()
# icon
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
guisizer = wx.BoxSizer(wx.VERTICAL)
# set apropriate output window
if self.parent:
self.standalone = False
else:
self.standalone = True
- # logo+description
+ # logo + description
topsizer = wx.BoxSizer(wx.HORIZONTAL)
# GRASS logo
self.logo = wx.StaticBitmap(parent=self.panel,
bitmap=wx.Bitmap(name=os.path.join(imagepath,
@@ -691,10 +692,8 @@
type=wx.BITMAP_TYPE_PNG))
topsizer.Add (item=self.logo, proportion=0, border=3,
flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL)
- # put module description
+ # add module description
if self.task.label != '':
module_desc = self.task.label + ' ' + self.task.description
else:
@@ -708,14 +707,14 @@
self.panel.SetSizerAndFit(guisizer)
self.Layout()
# notebooks
self.notebookpanel = cmdPanel(parent = self.panel, task = self.task,
mainFrame = self)
self.goutput = self.notebookpanel.goutput
self.notebookpanel.OnUpdateValues = self.updateValuesHook
guisizer.Add (item=self.notebookpanel, proportion=1, flag=wx.EXPAND)
# status bar
status_text = _("Enter parameters for '") + self.task.name + "'"
try:
@@ -723,7 +722,7 @@
self.updateValuesHook()
except ValueError:
self.SetStatusText( status_text )
# buttons
btnsizer = wx.BoxSizer(orient=wx.HORIZONTAL)
# cancel
@@ -731,24 +730,20 @@
self.btn_cancel.SetToolTipString(_("Close this window without executing the command (Ctrl+Q)"))
btnsizer.Add(item=self.btn_cancel, proportion=0, flag=wx.ALL | wx.ALIGN_CENTER, border=10)
self.btn_cancel.Bind(wx.EVT_BUTTON, self.OnCancel)
- # help
- self.btn_help = wx.Button(parent=self.panel, id=wx.ID_HELP)
- self.btn_help.SetToolTipString(_("Show manual page of the command (Ctrl+H)"))
- self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
if not hasattr(self.notebookpanel, "manual_tab_id"):
self.btn_help.Hide()
if self.get_dcmd is not None: # A callback has been set up
btn_apply = wx.Button(parent=self.panel, id=wx.ID_APPLY)
btn_ok = wx.Button(parent=self.panel, id=wx.ID_OK)
btn_ok.SetDefault()
btnsizer.Add(item=btn_apply, proportion=0,
border=10)
btnsizer.Add(item=btn_ok, proportion=0,
border=10)
btn_apply.Bind(wx.EVT_BUTTON, self.OnApply)
btn_ok.Bind(wx.EVT_BUTTON, self.OnOK)
else: # We're standalone
@@ -756,36 +751,31 @@
self.btn_run = wx.Button(parent=self.panel, id=wx.ID_OK, label= _("&Run"))
self.btn_run.SetToolTipString(_("Run the command (Ctrl+R)"))
self.btn_run.SetDefault()
- # abort
- ### self.btn_abort = wx.Button(parent=self.panel, id=wx.ID_STOP)
- ### self.btn_abort.SetToolTipString(_("Abort the running command"))
- ### self.btn_abort.Enable(False)
# copy
self.btn_clipboard = wx.Button(parent=self.panel, id=wx.ID_COPY)
self.btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard (Ctrl+C)"))
- ### btnsizer.Add(item=self.btn_abort, proportion=0,
- ### flag=wx.ALL | wx.ALIGN_CENTER,
- ### border=10)
btnsizer.Add(item=self.btn_run, proportion=0,
border=10)
btnsizer.Add(item=self.btn_clipboard, proportion=0,
border=10)
self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
- ### self.btn_abort.Bind(wx.EVT_BUTTON, self.OnAbort)
self.btn_clipboard.Bind(wx.EVT_BUTTON, self.OnCopy)
+ # help
+ self.btn_help = wx.Button(parent=self.panel, id=wx.ID_HELP)
+ self.btn_help.SetToolTipString(_("Show manual page of the command (Ctrl+H)"))
+ self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
# add help button
btnsizer.Add(item=self.btn_help, proportion=0, flag=wx.ALL | wx.ALIGN_CENTER, border=10)
guisizer.Add(item=btnsizer, proportion=0, flag=wx.ALIGN_CENTER | wx.LEFT | wx.RIGHT,
border = 30)
if self.parent and not self.modeler:
addLayer = False
for p in self.task.params:
@@ -810,19 +800,16 @@
guisizer.Add(item=self.closebox, proportion=0,
flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
border=5)
self.Bind(wx.EVT_CLOSE, self.OnCancel)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
- #constrained_size = self.notebookpanel.GetSize()
+ # constrained_size = self.notebookpanel.GetSize()
# 80 takes the tabbar into account
- #self.notebookpanel.SetSize( (constrained_size[0] + 25, constrained_size[1]) )
- #self.notebookpanel.Layout()
+ ### self.notebookpanel.SetSize( (constrained_size[0] + 25, constrained_size[1]) )
+ ### self.notebookpanel.Layout()
# do layout
- guisizer.SetSizeHints(self.panel)
# called automatically by SetSizer()
self.panel.SetAutoLayout(True)
@@ -832,20 +819,19 @@
self.SetSize((sizeFrame[0], sizeFrame[1] +
self.notebookpanel.constrained_size[1] -
self.notebookpanel.panelMinHeight))
# thread to update dialog
# create queues
self.requestQ = Queue.Queue()
self.resultQ = Queue.Queue()
self.updateThread = UpdateQThread(self.notebookpanel, self.requestQ, self.resultQ)
self.Layout()
- #keep initial window size limited for small screens
+ # keep initial window size limited for small screens
width, height = self.GetSizeTuple()
- if width > 640: width = 640
- if height > 480: height = 480
- self.SetSize((width, height))
+ self.SetSize(wx.Size(min(width, 640),
+ min(height, 480)))
# fix goutput's pane size
if self.goutput:
@@ -1078,8 +1064,8 @@
tab = {}
tabsizer = {}
for section in sections:
- tab[section] = wx.ScrolledWindow( parent=self.notebook )
- tab[section].SetScrollRate(10,10)
+ tab[section] = scrolled.ScrolledPanel(parent=self.notebook)
+ tab[section].SetScrollRate(10, 10)
tabsizer[section] = wx.BoxSizer(orient=wx.VERTICAL)
self.notebook.AddPage( tab[section], text=section.replace('_', ' '))
@@ -1832,9 +1818,9 @@
pass
def OnCheckBoxMulti(self, event):
+ """!Fill the values as a ','-separated string according to
+ current status of the checkboxes.
- Fill the values as a ','-separated string according to current status of the checkboxes.
me = event.GetId()
theParam = None
