[GRASS-SVN] r44664 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Dec 22 08:32:12 EST 2010
Author: martinl
Date: 2010-12-22 05:32:12 -0800 (Wed, 22 Dec 2010)
New Revision: 44664
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
backport r44662 & r44663 from trunk
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-12-22 13:30:11 UTC (rev 44663)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-12-22 13:32:12 UTC (rev 44664)
@@ -1502,7 +1502,7 @@
return filetype, ltype
class StaticWrapText(wx.StaticText):
- """! A Static Text field that wraps its text to fit its width,
+ """!A Static Text field that wraps its text to fit its width,
enlarging its height if necessary.
def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
@@ -1522,7 +1522,7 @@
def OnResize(self, event):
if not getattr(self, "resizing", False):
self.resizing = True
- newSize = wx.Size(self.parent.GetSize().width,
+ newSize = wx.Size(self.parent.GetSize().width - 50,
self.GetSize().height)
if self.wrappedSize != newSize:
wx.StaticText.SetLabel(self, self.originalLabel)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-12-22 13:30:11 UTC (rev 44663)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-12-22 13:32:12 UTC (rev 44664)
@@ -31,8 +31,8 @@
Or you set an alias or wrap the call up in a nice shell script, GUI
environment ... please contribute your idea.
-Copyright (C) 2000-2010 by the GRASS Development Team
-This program is free software under the GPL (>=v2) Read the file
+Copyright(C) 2000-2010 by the GRASS Development Team
+This program is free software under the GPL(>=v2) Read the file
COPYING coming with GRASS for details.
@author Jan-Oliver Wagner <jan at intevation.de>
@@ -691,21 +691,21 @@
bitmap = wx.Bitmap(name = os.path.join(imagepath,
'grass_form.png'),
type = wx.BITMAP_TYPE_PNG))
- topsizer.Add (item = self.logo, proportion = 0, border = 3,
- flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL)
+ topsizer.Add(item = self.logo, proportion = 0, border = 3,
+ flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL)
# add module description
- if self.task.label != '':
+ if self.task.label:
module_desc = self.task.label + ' ' + self.task.description
else:
module_desc = self.task.description
self.description = gdialogs.StaticWrapText(parent = self.panel,
label = module_desc)
- topsizer.Add (item = self.description, proportion = 1, border = 5,
- flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
- guisizer.Add (item = topsizer, proportion = 0, flag = wx.EXPAND)
+ topsizer.Add(item = self.description, proportion = 1, border = 5,
+ flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+ guisizer.Add(item = topsizer, proportion = 0, flag = wx.EXPAND)
self.panel.SetSizerAndFit(guisizer)
self.Layout()
@@ -714,7 +714,7 @@
mainFrame = self)
self.goutput = self.notebookpanel.goutput
self.notebookpanel.OnUpdateValues = self.updateValuesHook
- guisizer.Add (item = self.notebookpanel, proportion = 1, flag = wx.EXPAND)
+ guisizer.Add(item = self.notebookpanel, proportion = 1, flag = wx.EXPAND)
# status bar
status_text = _("Enter parameters for '") + self.task.name + "'"
@@ -753,7 +753,7 @@
self.btn_run.SetToolTipString(_("Run the command (Ctrl+R)"))
self.btn_run.SetDefault()
# copy
- self.btn_clipboard = wx.Button(parent = self.panel, id = wx.ID_COPY)
+ self.btn_clipboard = wx.Button(parent = self.panel, id = wx.ID_COPY, label = _("C&opy"))
self.btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard (Ctrl+C)"))
btnsizer.Add(item = self.btn_run, proportion = 0,
@@ -805,11 +805,6 @@
self.Bind(wx.EVT_CLOSE, self.OnCancel)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
- # constrained_size = self.notebookpanel.GetSize()
- # 80 takes the tabbar into account
- ### self.notebookpanel.SetSize((constrained_size[0] + 25, constrained_size[1]))
- ### self.notebookpanel.Layout()
# do layout
# called automatically by SetSizer()
self.panel.SetAutoLayout(True)
@@ -817,9 +812,8 @@
sizeFrame = self.GetBestSize()
self.SetMinSize(sizeFrame)
- self.SetSize((sizeFrame[0], sizeFrame[1] +
- self.notebookpanel.constrained_size[1] -
- self.notebookpanel.panelMinHeight))
+ self.SetSize(wx.Size(sizeFrame[0], sizeFrame[1] + 0.33 * max(self.notebookpanel.panelMinHeight,
+ self.notebookpanel.constrained_size[1])))
# thread to update dialog
# create queues
@@ -831,8 +825,8 @@
# keep initial window size limited for small screens
width, height = self.GetSizeTuple()
- self.SetSize(wx.Size(min(width, 640),
- min(height, 480)))
+ self.SetSize(wx.Size(min(width, 650),
+ min(height, 500)))
# fix goutput's pane size
if self.goutput:
@@ -1103,7 +1097,7 @@
# if label is given: description -> tooltip
if f.get('label','') != '':
title = text_beautify(f['label'])
- tooltip = text_beautify (f['description'], width = -1)
+ tooltip = text_beautify(f['description'], width = -1)
else:
title = text_beautify(f['description'])
tooltip = None
@@ -1164,7 +1158,7 @@
# otherwise description -> lavel
if p.get('label','') != '':
title = text_beautify(p['label'])
- tooltip = text_beautify (p['description'], width = -1)
+ tooltip = text_beautify(p['description'], width = -1)
else:
title = text_beautify(p['description'])
tooltip = None
@@ -1181,7 +1175,7 @@
p.get('multiple', False) and \
p.get('gisprompt',False) == False and \
p.get('type', '') == 'string':
- title_txt = wx.StaticBox (parent = which_panel, id = wx.ID_ANY)
+ title_txt = wx.StaticBox(parent = which_panel, id = wx.ID_ANY)
else:
title_sizer = wx.BoxSizer(wx.HORIZONTAL)
title_txt = wx.StaticText(parent = which_panel)
@@ -1213,10 +1207,10 @@
title_txt.SetLabel(" %s: (%s, %s) " % (title, p['name'], p['type']))
- if len(valuelist) > 6:
- hSizer = wx.StaticBoxSizer (box = title_txt, orient = wx.VERTICAL)
+ if valuelist_desc:
+ hSizer = wx.StaticBoxSizer(box = title_txt, orient = wx.VERTICAL)
else:
- hSizer = wx.StaticBoxSizer (box = title_txt, orient = wx.HORIZONTAL)
+ hSizer = wx.StaticBoxSizer(box = title_txt, orient = wx.HORIZONTAL)
isEnabled = {}
# copy default values
if p['value'] == '':
@@ -1243,15 +1237,14 @@
hSizer.Add(item = chkbox, proportion = 0,
flag = wx.ADJUST_MINSIZE | wx.ALL, border = 1)
chkbox.Bind(wx.EVT_CHECKBOX, self.OnCheckBoxMulti)
idx += 1
which_sizer.Add(item = hSizer, proportion = 0,
- flag = wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border = 5)
+ flag = wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border = 5)
elif p.get('gisprompt', False) == False:
if len(valuelist) == 1: # -> textctrl
title_txt.SetLabel("%s (%s %s):" % (title, _('valid range'),
- str(valuelist[0])))
+ str(valuelist[0])))
if p.get('type', '') == 'integer' and \
not p.get('multiple', False):
@@ -1701,13 +1694,13 @@
# determine panel size
- maxsizes = (0,0)
+ maxsizes = (0, 0)
for section in sections:
tab[section].SetSizer(tabsizer[section])
tabsizer[section].Fit(tab[section])
tab[section].Layout()
minsecsizes = tabsizer[section].GetSize()
- maxsizes = map(lambda x: max(maxsizes[x], minsecsizes[x]), (0,1))
+ maxsizes = map(lambda x: max(maxsizes[x], minsecsizes[x]), (0, 1))
# TODO: be less arbitrary with these 600
self.panelMinHeight = 100
