[GRASS-SVN] r44673 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Wed Dec 22 09:09:00 EST 2010
Author: martinl
Date: 2010-12-22 06:09:00 -0800 (Wed, 22 Dec 2010)
New Revision: 44673
grass/branches/releasebranch_6_4/lib/python/core.py
pythonlib: parser(): returncode 1 on failure
(merge r44671 from trunk)
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2010-12-22 14:08:20 UTC (rev 44672)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2010-12-22 14:09:00 UTC (rev 44673)
@@ -418,11 +418,11 @@
if not os.getenv("GISBASE"):
print >> sys.stderr, "You must be in GRASS GIS to run this program."
sys.exit(1)
cmdline = [basename(sys.argv[0])]
cmdline += ['"' + arg + '"' for arg in sys.argv[1:]]
os.environ['CMDLINE'] = ' '.join(cmdline)
argv = sys.argv[:]
name = argv[0]
if not os.path.isabs(name):
@@ -430,14 +430,14 @@
argv[0] = os.path.abspath(name)
else:
argv[0] = os.path.join(sys.path[0], name)
p = Popen(['g.parser', '-s'] + argv, stdout = PIPE)
s = p.communicate()[0]
lines = s.splitlines()
if not lines or lines[0].rstrip('\r\n') != "@ARGS_PARSED@":
sys.stdout.write(s)
- sys.exit()
+ sys.exit(1)
return _parse_opts(lines[1:])
