[GRASS-SVN] r44694 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Dec 23 17:45:10 EST 2010
Author: martinl
Date: 2010-12-23 14:45:10 -0800 (Thu, 23 Dec 2010)
New Revision: 44694
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/globalvar.py
fix GetGRASSCmd() to work properly on Windows
(merge r44691 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/globalvar.py 2010-12-23 22:43:31 UTC (rev 44693)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/globalvar.py 2010-12-23 22:45:10 UTC (rev 44694)
@@ -79,13 +79,6 @@
import wx
import wx.lib.flatnotebook as FN
-try:
- import subprocess
-except:
- compatPath = os.path.join(globalvar.ETCWXDIR, "compat")
- sys.path.append(compatPath)
- import subprocess
Query layer (generated for example by selecting item in the Attribute Table Manager)
Deleted automatically on re-render action
@@ -129,7 +122,7 @@
_("Projection"),]
"""!File name extension binaries/scripts"""
-if subprocess.mswindows:
+if sys.platform == 'win32':
EXT_BIN = '.exe'
EXT_SCT = '.bat'
else:
@@ -137,17 +130,21 @@
EXT_SCT = ''
def GetGRASSCmds(bin = True, scripts = True, gui_scripts = True):
- """!Create list of all available GRASS commands to use when
- parsing string from the command line
+ """!Create list of available GRASS commands to use when parsing
+ string from the command line
+ @param bin True to include executable into list
+ @param scripts True to include scripts into list
+ @param gui_scripts True to include GUI scripts into list
gisbase = os.environ['GISBASE']
cmd = list()
- if bin is True:
- for file in os.listdir(os.path.join(gisbase, 'bin')):
+ if bin:
+ for executable in os.listdir(os.path.join(gisbase, 'bin')):
+ ext = os.path.splitext(executable)[1]
if not EXT_BIN or \
- file[-4:] == EXT_BIN or \
- file[-4:] == EXT_SCT:
- cmd.append(file)
+ ext in (EXT_BIN, EXT_SCT):
+ cmd.append(executable)
# add special call for setting vector colors
cmd.append('vcolors')
@@ -157,18 +154,19 @@
os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'gui', 'scripts')
os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'wxpython', 'scripts')
cmd = cmd + os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts'))
- if subprocess.mswindows:
+ if sys.platform == 'win32':
for idx in range(len(cmd)):
- if cmd[idx][-4:] in (EXT_BIN, EXT_SCT):
- cmd[idx] = cmd[idx][:-4]
+ name, ext = os.path.splitext(cmd[idx])
+ if ext in (EXT_BIN, EXT_SCT):
+ cmd[idx] = name
return cmd
"""@brief Collected GRASS-relared binaries/scripts"""
grassCmd = {}
grassCmd['all'] = GetGRASSCmds()
-grassCmd['script'] = GetGRASSCmds(bin = False)
+grassCmd['script'] = GetGRASSCmds(bin = False, gui_scripts = False)
"""@Toolbar icon size"""
toolbarSize = (24, 24)
