[GRASS-SVN] r44700 - grass-promo/tutorials/grass_modis
Thu Dec 23 19:47:03 EST 2010
Author: ychemin
Date: 2010-12-23 16:47:03 -0800 (Thu, 23 Dec 2010)
New Revision: 44700
   grass-promo/tutorials/grass_modis/article_GIPE.tex
Update
Modified: grass-promo/tutorials/grass_modis/article_GIPE.tex
--- grass-promo/tutorials/grass_modis/article_GIPE.tex	2010-12-24 00:45:43 UTC (rev 44699)
+++ grass-promo/tutorials/grass_modis/article_GIPE.tex	2010-12-24 00:47:03 UTC (rev 44700)
@@ -36,6 +36,11 @@
 \end{smallverbatim}
 Another tool, gdalwarp (\href{http://www.gdal.org/gdalwarp.html}{www.gdal.org/gdalwarp.html}) is dedicated to extract part of images and geolocate them properly. It would reproject the image data, it is useful to note that it also change the file format if you request it to do so. The script below does that with a target projection \textit{EPSG:4326} which actually means the following proj4 crs: \textit{+proj=longlat +ellps=WGS84 +datum=WGS84 +no\_defs}.
 \begin{smallverbatim}
+#This Unix Shell script automatically
+# extracts and reprojects MODIS
+# subdatasets into processed/
+# subdirectory as GeoTiff (*.tif) files
 for file in *.hdf
 do SDS_list=$(gdalinfo $file \
         | grep "SUBDATASET_.*_NAME.*")
@@ -51,9 +56,14 @@
 \end{smallverbatim}
 \section{Renaming}
-Most of the time you will want to reduce the size of the MODIS file names. As an example for MOD13Q1 NDVI layer remaning when converting from HDF to TIF, write the following script at the GRASS Command Line Interface:
+Most of the time you will want to reduce the size of the MODIS file names. As an example for MOD13Q1 NDVI layer renaming when converting from HDF to TIF, write the following script at the GRASS Command Line Interface:
+# extracts MODIS NDVI subdatasets into
+# GeoTiff (*.tif) files with a sed
+# renaming scheme.
 root=~/MOD13Q1/2_PreProcessed
 rootNDVI=$root/NDVI/
 for file in MOD13Q1.A2010*.hdf
@@ -61,7 +71,7 @@
 	SDS_list_NDVI=$(gdalinfo $file \
 		| grep "SUBDATASET_1_NAME")
 	echo $file
-	gdal_translate -of GTiff -quiet "${SDS_list_NDVI#*=}" \
+	gdal_translate -of GTiff "${SDS_list_NDVI#*=}" \
 	   $rootNDVI/$(echo ${SDS_list_NDVI#*=} \
 	   | sed 's/\(.*\):\(.*\):"\(.*\).A\(.*\)\.\h \
 	   \(.*\)\.\(.*\)\.\(.*\).hdf":\(.*\): \
@@ -69,10 +79,15 @@
 done
 \end{smallverbatim}
+If the later part of the code above is confusing, it may be a good idea to read about \href{http://www.gnu.org/software/sed/manual/sed.html}{sed} syntax.
 \section{Importing in GRASS}
 Once your files are prepared, they can be imported in GRASS.
+#Import all NDVI files in a directory
+# into GRASS GIS
 cd $rootNDVI
 for file in $rootNDVI
 do
@@ -82,6 +97,9 @@
 To access blindly an NDVI set of files, create a variable list from g.mlist:
+#Create a list of NDVI files available
+# in the current GRASS GIS Mapset
 listNDVI=$(g.mlist type=rast pattern=*NDVI*)
 echo $listNDVI
 \end{smallverbatim}
