[GRASS-SVN] r44713 - in grass/trunk: include lib/raster
svn_grass at osgeo.org
Fri Dec 24 11:51:38 EST 2010
Author: martinl
Date: 2010-12-24 08:51:38 -0800 (Fri, 24 Dec 2010)
New Revision: 44713
Added:
grass/trunk/lib/raster/close.c
grass/trunk/lib/raster/open.c
Removed:
grass/trunk/lib/raster/closecell.c
grass/trunk/lib/raster/opencell.c
grass/trunk/include/rasterdefs.h
rasterlib: closecell.c renamed to close.c, opencell.c renamed to open.c
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h 2010-12-24 15:13:08 UTC (rev 44712)
+++ grass/trunk/include/rasterdefs.h 2010-12-24 16:51:38 UTC (rev 44713)
@@ -96,7 +96,7 @@
int Rast_cell_stats_histo_eq(struct Cell_stats *, CELL, CELL, CELL, CELL, int,
void (*)(CELL, CELL, CELL));
-/* closecell.c */
+/* close.c */
void Rast_close(int);
void Rast_unopen(int);
void Rast__unopen_all(void);
@@ -429,7 +429,7 @@
void Rast__convert_flags_01(char *, const unsigned char *, int);
void Rast__init_null_bits(unsigned char *, int);
-/* opencell.c */
+/* open.c */
int Rast_open_old(const char *, const char *);
int Rast__open_old(const char *, const char *);
int Rast_open_c_new(const char *);
Copied: grass/trunk/lib/raster/close.c (from rev 44707, grass/trunk/lib/raster/closecell.c)
--- grass/trunk/lib/raster/close.c (rev 0)
+++ grass/trunk/lib/raster/close.c 2010-12-24 16:51:38 UTC (rev 44713)
@@ -0,0 +1,496 @@
+ * \file raster/close.c
+ * \brief Raster Library - Close raster file
+ * (C) 1999-2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author USACERL and many others
+#ifdef __MINGW32__
+# include <windows.h>
+#endif
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <fcntl.h>
+#include <signal.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#include "R.h"
+#define FORMAT_FILE "f_format"
+#define QUANT_FILE "f_quant"
+#define NULL_FILE "null"
+static int close_old(int);
+static int close_new(int, int);
+static void write_fp_format(int fd);
+ * \brief Close a raster map
+ * The raster map opened on file descriptor <i>fd</i> is
+ * closed. Memory allocated for raster processing is freed. If open
+ * for writing, skeletal support files for the new raster map are
+ * created as well.
+ * <b>Note:</b> If a module wants to explicitly write support files
+ * (e.g., a specific color table) for a raster map it creates, it must
+ * do so after the raster map is closed. Otherwise the close will
+ * overwrite the support files. See \ref
+ * Raster_Map_Layer_Support_Routines for routines which write raster
+ * support files.
+ * If the map is a new floating point, move the <tt>.tmp</tt> file
+ * into the <tt>fcell</tt> element, create an empty file in the
+ * <tt>cell</tt> directory; write the floating-point range file; write
+ * a default quantization file quantization file is set here to round
+ * fp numbers (this is a default for now). create an empty category
+ * file, with max cat = max value (for backwards compatibility). Move
+ * the <tt>.tmp</tt> NULL-value bitmap file to the <tt>cell_misc</tt>
+ * directory.
+ * \param fd file descriptor
+ * \return void
+void Rast_close(int fd)
+ struct fileinfo *fcb = &R__.fileinfo[fd];
+ if (fd < 0 || fd >= R__.fileinfo_count || fcb->open_mode <= 0)
+ G_fatal_error(_("Invalid descriptor: %d"), fd);
+ if (fcb->open_mode == OPEN_OLD)
+ close_old(fd);
+ else
+ close_new(fd, 1);
+ * \brief Unopen a raster map
+ * for writing, the raster map is not created and the temporary file
+ * created when the raster map was opened is removed (see \ref
+ * Creating_and_Opening_New_Raster_Files). This routine is useful when
+ * errors are detected and it is desired to not create the new raster
+ * map. While it is true that the raster map will not be created if
+ * the module exits without closing the file, the temporary file will
+ * not be removed at module exit. GRASS database management will
+ * eventually remove the temporary file, but the file can be quite
+ * large and will take up disk space until GRASS does remove it. Use
+ * this routine as a courtesy to the user.
+ * \return void
+void Rast_unopen(int fd)
+ close_old(fd);
+ else
+ close_new(fd, 0);
+ * \brief Unopen all raster maps
+ * Unopen all raster maps opened for write. Memory allocated for
+ * raster processing is freed, and the temporary file created when the
+ * raster map was opened is removed (see \ref
+ * errors are detected and it is desired to remove temporary files.
+ * \return void
+void Rast__unopen_all(void)
+ int i;
+ for (i = 0; i < R__.fileinfo_count; i++) {
+ struct fileinfo *fcb = &R__.fileinfo[i];
+ if (fcb->open_mode == OPEN_NEW_COMPRESSED ||
+ fcb->open_mode == OPEN_NEW_UNCOMPRESSED)
+ close_new(i, 0);
+static int close_old(int fd)
+ /* if R__.auto_mask was only allocated for reading map rows to create
+ non-existant null rows, and not for actuall mask, free R__.mask_row
+ if(R__.auto_mask <=0)
+ G_free (R__.mask_buf);
+ This is obsolete since now the mask_bus is always allocated
+ if (fcb->gdal)
+ Rast_close_gdal_link(fcb->gdal);
+ if (fcb->null_bits)
+ G_free(fcb->null_bits);
+ if (fcb->null_fd >= 0)
+ close(fcb->null_fd);
+ fcb->null_fd = -1;
+ if (fcb->cellhd.compressed)
+ G_free(fcb->row_ptr);
+ G_free(fcb->col_map);
+ G_free(fcb->mapset);
+ G_free(fcb->data);
+ G_free(fcb->name);
+ if (fcb->reclass_flag)
+ Rast_free_reclass(&fcb->reclass);
+ fcb->open_mode = -1;
+ if (fcb->map_type != CELL_TYPE) {
+ Rast_quant_free(&fcb->quant);
+ xdr_destroy(&fcb->xdrstream);
+ close(fd);
+ return 1;
+static void write_support_files(int fd)
+ struct Categories cats;
+ struct History hist;
+ CELL cell_min, cell_max;
+ char path[GPATH_MAX];
+ /* remove color table */
+ Rast_remove_colors(fcb->name, "");
+ /* create a history file */
+ Rast_short_history(fcb->name, "raster", &hist);
+ Rast_write_history(fcb->name, &hist);
+ /* write the range */
+ if (fcb->map_type == CELL_TYPE) {
+ Rast_write_range(fcb->name, &fcb->range);
+ Rast__remove_fp_range(fcb->name);
+ /*NOTE: int range for floating point maps is not written out */
+ else { /* if(fcb->map_type != CELL_TYPE) */
+ Rast_write_fp_range(fcb->name, &fcb->fp_range);
+ Rast_construct_default_range(&fcb->range);
+ /* this range will be used to add default rule to quant structure */
+ fcb->cellhd.format = -1;
+ else /* CELL map */
+ fcb->cellhd.format = fcb->nbytes - 1;
+ /* write header file */
+ Rast_put_cellhd(fcb->name, &fcb->cellhd);
+ /* if map is floating point write the quant rules, otherwise remove f_quant */
+ /* DEFAULT RANGE QUANT
+ Rast_get_fp_range_min_max(&fcb->fp_range, &dcell_min, &dcell_max);
+ if(!Rast_is_d_null_value(&dcell_min) && !Rast_is_d_null_value(&dcell_max))
+ Rast_get_range_min_max(&fcb->range, &cell_min, &cell_max);
+ Rast_quant_add_rule(&fcb->quant, dcell_min, dcell_max,
+ cell_min, cell_max);
+ Rast_quant_round(&fcb->quant);
+ Rast_write_quant(fcb->name, fcb->mapset, &fcb->quant);
+ else {
+ /* remove cell_misc/name/f_quant */
+ G__file_name_misc(path, "cell_misc", QUANT_FILE, fcb->name,
+ fcb->mapset);
+ remove(path);
+ /* create empty cats file */
+ if (Rast_is_c_null_value(&cell_max))
+ cell_max = 0;
+ Rast_init_cats((char *)NULL, &cats);
+ Rast_write_cats(fcb->name, &cats);
+ Rast_free_cats(&cats);
+ /* write the histogram */
+ /* only works for integer maps */
+ if ((fcb->map_type == CELL_TYPE)
+ && (fcb->want_histogram)) {
+ Rast_write_histogram_cs(fcb->name, &fcb->statf);
+ Rast_free_cell_stats(&fcb->statf);
+ else {
+ Rast_remove_histogram(fcb->name);
+static int close_new_gdal(int fd, int ok)
+ int stat = 1;
+ if (ok) {
+ int cell_fd;
+ G_debug(1, "close %s GDAL", fcb->name);
+ if (fcb->cur_row < fcb->cellhd.rows) {
+ int row;
+ Rast_zero_output_buf(fcb->data, fcb->map_type);
+ for (row = fcb->cur_row; row < fcb->cellhd.rows; row++)
+ Rast_put_row(fd, fcb->data, fcb->map_type);
+ fcb->data = NULL;
+ /* create path : full null file name */
+ G__make_mapset_element_misc("cell_misc", fcb->name);
+ G__file_name_misc(path, "cell_misc", NULL_FILE, fcb->name,
+ G_mapset());
+ remove(path);
+ /* write 0-length cell file */
+ G__make_mapset_element("cell");
+ G__file_name(path, "cell", fcb->name, fcb->mapset);
+ cell_fd = creat(path, 0666);
+ close(cell_fd);
+ if (fcb->map_type != CELL_TYPE) { /* floating point map */
+ write_fp_format(fd);
+ /* write 0-length fcell file */
+ G__make_mapset_element("fcell");
+ G__file_name(path, "fcell", fcb->name, fcb->mapset);
+ close(cell_fd);
+ else {
+ /* remove fcell/name file */
+ remove(path);
+ /* remove cell_misc/name/f_format */
+ G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name,
+ fcb->mapset);
+ remove(path);
+ if (Rast_close_gdal_write_link(fcb->gdal) < 0)
+ stat = -1;
+ else {
+ remove(fcb->gdal->filename);
+ /* NOW CLOSE THE FILE DESCRIPTOR */
+ close(fd);
+ if (fcb->data != NULL)
+ if (ok)
+ write_support_files(fd);
+ return stat;
+static int close_new(int fd, int ok)
+ int stat;
+ int row;
+ const char *CELL_DIR;
+ if (fcb->gdal)
+ return close_new_gdal(fd, ok);
+ if (ok) {
+ switch (fcb->open_mode) {
+ case OPEN_NEW_COMPRESSED:
+ G_debug(1, "close %s compressed", fcb->name);
+ break;
+ case OPEN_NEW_UNCOMPRESSED:
+ G_debug(1, "close %s uncompressed", fcb->name);
+ break;
+ fcb->data = NULL;
+ G_mapset());
+ remove(path);
+ if (fcb->null_cur_row > 0) {
+ /* if temporary NULL file exists, write it into cell_misc/name/null */
+ if (rename(fcb->null_temp_name, path)) {
+ G_warning(_("Unable to rename null file '%s'"),
+ fcb->null_temp_name, path);
+ stat = -1;
+ else {
+ remove(fcb->null_temp_name);
+ else {
+ remove(path);
+ } /* null_cur_row > 0 */
+ if (fcb->open_mode == OPEN_NEW_COMPRESSED) { /* auto compression */
+ fcb->row_ptr[fcb->cellhd.rows] = lseek(fd, 0L, SEEK_CUR);
+ Rast__write_row_ptrs(fd);
+ int cell_fd;
+ /* now write 0-length cell file */
+ cell_fd =
+ creat(G__file_name(path, "cell", fcb->name, fcb->mapset),
+ 0666);
+ close(cell_fd);
+ CELL_DIR = "fcell";
+ else {
+ remove(path);
+ fcb->mapset);
+ remove(path);
+ CELL_DIR = "cell";
+ close(fd);
+ } /* ok */
+ close(fd);
+ if (fcb->null_temp_name != NULL) {
+ G_free(fcb->null_temp_name);
+ fcb->null_temp_name = NULL;
+ /* if the cell file was written to a temporary file
+ * move this temporary file into the cell file
+ * if the move fails, tell the user, but go ahead and create
+ * the support files
+ stat = 1;
+ if (ok && (fcb->temp_name != NULL)) {
+ G__file_name(path, CELL_DIR, fcb->name, fcb->mapset);
+ remove(path);
+ if (rename(fcb->temp_name, path)) {
+ G_warning(_("Unable to rename cell file '%s'"),
+ fcb->temp_name, path);
+ stat = -1;
+ else {
+ remove(fcb->temp_name);
+ if (fcb->temp_name != NULL) {
+ G_free(fcb->temp_name);
+ if (ok)
+ return stat;
+/* returns 0 on success, 1 on failure */
+ struct Key_Value *format_kv;
+ G_warning(_("unable to write f_format file for CELL maps"));
+ return;
+ format_kv = G_create_key_value();
+ if (fcb->map_type == FCELL_TYPE)
+ G_set_key_value("type", "float", format_kv);
+ else
+ G_set_key_value("type", "double", format_kv);
+ G_set_key_value("byte_order", "xdr", format_kv);
+ G_set_key_value("lzw_compression_bits", "-1", format_kv);
+ G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name, fcb->mapset);
+ G_write_key_value_file(path, format_kv);
+ G_free_key_value(format_kv);
Deleted: grass/trunk/lib/raster/closecell.c
--- grass/trunk/lib/raster/closecell.c 2010-12-24 15:13:08 UTC (rev 44712)
+++ grass/trunk/lib/raster/closecell.c 2010-12-24 16:51:38 UTC (rev 44713)
@@ -1,496 +0,0 @@
- * \file raster/closecell.c
- * \brief Raster Library - Close raster file
- * (C) 1999-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author USACERL and many others
-#ifdef __MINGW32__
-# include <windows.h>
-#endif
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <unistd.h>
-#include <fcntl.h>
-#include <signal.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include <grass/glocale.h>
-#include "R.h"
-#define FORMAT_FILE "f_format"
-#define QUANT_FILE "f_quant"
-#define NULL_FILE "null"
-static int close_old(int);
-static int close_new(int, int);
-static void write_fp_format(int fd);
- * \brief Close a raster map
- * The raster map opened on file descriptor <i>fd</i> is
- * closed. Memory allocated for raster processing is freed. If open
- * for writing, skeletal support files for the new raster map are
- * created as well.
- * <b>Note:</b> If a module wants to explicitly write support files
- * (e.g., a specific color table) for a raster map it creates, it must
- * do so after the raster map is closed. Otherwise the close will
- * overwrite the support files. See \ref
- * Raster_Map_Layer_Support_Routines for routines which write raster
- * support files.
- * If the map is a new floating point, move the <tt>.tmp</tt> file
- * into the <tt>fcell</tt> element, create an empty file in the
- * <tt>cell</tt> directory; write the floating-point range file; write
- * a default quantization file quantization file is set here to round
- * fp numbers (this is a default for now). create an empty category
- * file, with max cat = max value (for backwards compatibility). Move
- * the <tt>.tmp</tt> NULL-value bitmap file to the <tt>cell_misc</tt>
- * directory.
- * \param fd file descriptor
- * \return void
-void Rast_close(int fd)
- struct fileinfo *fcb = &R__.fileinfo[fd];
- if (fd < 0 || fd >= R__.fileinfo_count || fcb->open_mode <= 0)
- G_fatal_error(_("Invalid descriptor: %d"), fd);
- if (fcb->open_mode == OPEN_OLD)
- close_old(fd);
- else
- close_new(fd, 1);
- * \brief Unopen a raster map
- * for writing, the raster map is not created and the temporary file
- * created when the raster map was opened is removed (see \ref
- * Creating_and_Opening_New_Raster_Files). This routine is useful when
- * errors are detected and it is desired to not create the new raster
- * map. While it is true that the raster map will not be created if
- * the module exits without closing the file, the temporary file will
- * not be removed at module exit. GRASS database management will
- * eventually remove the temporary file, but the file can be quite
- * large and will take up disk space until GRASS does remove it. Use
- * this routine as a courtesy to the user.
- * \return void
-void Rast_unopen(int fd)
- close_old(fd);
- else
- close_new(fd, 0);
- * \brief Unopen all raster maps
- * Unopen all raster maps opened for write. Memory allocated for
- * raster processing is freed, and the temporary file created when the
- * raster map was opened is removed (see \ref
- * errors are detected and it is desired to remove temporary files.
- * \return void
-void Rast__unopen_all(void)
- int i;
- for (i = 0; i < R__.fileinfo_count; i++) {
- struct fileinfo *fcb = &R__.fileinfo[i];
- if (fcb->open_mode == OPEN_NEW_COMPRESSED ||
- fcb->open_mode == OPEN_NEW_UNCOMPRESSED)
- close_new(i, 0);
-static int close_old(int fd)
- /* if R__.auto_mask was only allocated for reading map rows to create
- non-existant null rows, and not for actuall mask, free R__.mask_row
- if(R__.auto_mask <=0)
- G_free (R__.mask_buf);
- This is obsolete since now the mask_bus is always allocated
- if (fcb->gdal)
- Rast_close_gdal_link(fcb->gdal);
- if (fcb->null_bits)
- G_free(fcb->null_bits);
- if (fcb->null_fd >= 0)
- close(fcb->null_fd);
- fcb->null_fd = -1;
- if (fcb->cellhd.compressed)
- G_free(fcb->row_ptr);
- G_free(fcb->col_map);
- G_free(fcb->mapset);
- G_free(fcb->data);
- G_free(fcb->name);
- if (fcb->reclass_flag)
- Rast_free_reclass(&fcb->reclass);
- fcb->open_mode = -1;
- if (fcb->map_type != CELL_TYPE) {
- Rast_quant_free(&fcb->quant);
- xdr_destroy(&fcb->xdrstream);
- close(fd);
- return 1;
-static void write_support_files(int fd)
- struct Categories cats;
- struct History hist;
- CELL cell_min, cell_max;
- char path[GPATH_MAX];
- /* remove color table */
- Rast_remove_colors(fcb->name, "");
- /* create a history file */
- Rast_short_history(fcb->name, "raster", &hist);
- Rast_write_history(fcb->name, &hist);
- /* write the range */
- if (fcb->map_type == CELL_TYPE) {
- Rast_write_range(fcb->name, &fcb->range);
- Rast__remove_fp_range(fcb->name);
- /*NOTE: int range for floating point maps is not written out */
- else { /* if(fcb->map_type != CELL_TYPE) */
- Rast_write_fp_range(fcb->name, &fcb->fp_range);
- Rast_construct_default_range(&fcb->range);
- /* this range will be used to add default rule to quant structure */
- fcb->cellhd.format = -1;
- else /* CELL map */
- fcb->cellhd.format = fcb->nbytes - 1;
- /* write header file */
- Rast_put_cellhd(fcb->name, &fcb->cellhd);
- /* if map is floating point write the quant rules, otherwise remove f_quant */
- /* DEFAULT RANGE QUANT
- Rast_get_fp_range_min_max(&fcb->fp_range, &dcell_min, &dcell_max);
- if(!Rast_is_d_null_value(&dcell_min) && !Rast_is_d_null_value(&dcell_max))
- Rast_get_range_min_max(&fcb->range, &cell_min, &cell_max);
- Rast_quant_add_rule(&fcb->quant, dcell_min, dcell_max,
- cell_min, cell_max);
- Rast_quant_round(&fcb->quant);
- Rast_write_quant(fcb->name, fcb->mapset, &fcb->quant);
- else {
- /* remove cell_misc/name/f_quant */
- G__file_name_misc(path, "cell_misc", QUANT_FILE, fcb->name,
- fcb->mapset);
- remove(path);
- /* create empty cats file */
- if (Rast_is_c_null_value(&cell_max))
- cell_max = 0;
- Rast_init_cats((char *)NULL, &cats);
- Rast_write_cats(fcb->name, &cats);
- Rast_free_cats(&cats);
- /* write the histogram */
- /* only works for integer maps */
- if ((fcb->map_type == CELL_TYPE)
- && (fcb->want_histogram)) {
- Rast_write_histogram_cs(fcb->name, &fcb->statf);
- Rast_free_cell_stats(&fcb->statf);
- else {
- Rast_remove_histogram(fcb->name);
-static int close_new_gdal(int fd, int ok)
- int stat = 1;
- if (ok) {
- int cell_fd;
- G_debug(1, "close %s GDAL", fcb->name);
- if (fcb->cur_row < fcb->cellhd.rows) {
- int row;
- Rast_zero_output_buf(fcb->data, fcb->map_type);
- for (row = fcb->cur_row; row < fcb->cellhd.rows; row++)
- Rast_put_row(fd, fcb->data, fcb->map_type);
- fcb->data = NULL;
- /* create path : full null file name */
- G__make_mapset_element_misc("cell_misc", fcb->name);
- G__file_name_misc(path, "cell_misc", NULL_FILE, fcb->name,
- G_mapset());
- remove(path);
- /* write 0-length cell file */
- G__make_mapset_element("cell");
- G__file_name(path, "cell", fcb->name, fcb->mapset);
- cell_fd = creat(path, 0666);
- close(cell_fd);
- if (fcb->map_type != CELL_TYPE) { /* floating point map */
- write_fp_format(fd);
- /* write 0-length fcell file */
- G__make_mapset_element("fcell");
- G__file_name(path, "fcell", fcb->name, fcb->mapset);
- close(cell_fd);
- else {
- /* remove fcell/name file */
- remove(path);
- /* remove cell_misc/name/f_format */
- G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name,
- fcb->mapset);
- remove(path);
- if (Rast_close_gdal_write_link(fcb->gdal) < 0)
- stat = -1;
- else {
- remove(fcb->gdal->filename);
- /* NOW CLOSE THE FILE DESCRIPTOR */
- close(fd);
- if (fcb->data != NULL)
- if (ok)
- write_support_files(fd);
- return stat;
-static int close_new(int fd, int ok)
- int stat;
- int row;
- const char *CELL_DIR;
- if (fcb->gdal)
- return close_new_gdal(fd, ok);
- if (ok) {
- switch (fcb->open_mode) {
- case OPEN_NEW_COMPRESSED:
- G_debug(1, "close %s compressed", fcb->name);
- break;
- case OPEN_NEW_UNCOMPRESSED:
- G_debug(1, "close %s uncompressed", fcb->name);
- break;
- fcb->data = NULL;
- G_mapset());
- remove(path);
- if (fcb->null_cur_row > 0) {
- /* if temporary NULL file exists, write it into cell_misc/name/null */
- if (rename(fcb->null_temp_name, path)) {
- G_warning(_("Unable to rename null file '%s'"),
- fcb->null_temp_name, path);
- stat = -1;
- else {
- remove(fcb->null_temp_name);
- else {
- remove(path);
- } /* null_cur_row > 0 */
- if (fcb->open_mode == OPEN_NEW_COMPRESSED) { /* auto compression */
- fcb->row_ptr[fcb->cellhd.rows] = lseek(fd, 0L, SEEK_CUR);
- Rast__write_row_ptrs(fd);
- int cell_fd;
- /* now write 0-length cell file */
- cell_fd =
- creat(G__file_name(path, "cell", fcb->name, fcb->mapset),
- 0666);
- close(cell_fd);
- CELL_DIR = "fcell";
- else {
- remove(path);
- fcb->mapset);
- remove(path);
- CELL_DIR = "cell";
- close(fd);
- } /* ok */
- close(fd);
- if (fcb->null_temp_name != NULL) {
- G_free(fcb->null_temp_name);
- fcb->null_temp_name = NULL;
- /* if the cell file was written to a temporary file
- * move this temporary file into the cell file
- * if the move fails, tell the user, but go ahead and create
- * the support files
- stat = 1;
- if (ok && (fcb->temp_name != NULL)) {
- G__file_name(path, CELL_DIR, fcb->name, fcb->mapset);
- remove(path);
- if (rename(fcb->temp_name, path)) {
- G_warning(_("Unable to rename cell file '%s'"),
- fcb->temp_name, path);
- stat = -1;
- else {
- remove(fcb->temp_name);
- if (fcb->temp_name != NULL) {
- G_free(fcb->temp_name);
- if (ok)
- return stat;
-/* returns 0 on success, 1 on failure */
- struct Key_Value *format_kv;
- G_warning(_("unable to write f_format file for CELL maps"));
- return;
- format_kv = G_create_key_value();
- if (fcb->map_type == FCELL_TYPE)
- G_set_key_value("type", "float", format_kv);
- else
- G_set_key_value("type", "double", format_kv);
- G_set_key_value("byte_order", "xdr", format_kv);
- G_set_key_value("lzw_compression_bits", "-1", format_kv);
- G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name, fcb->mapset);
- G_write_key_value_file(path, format_kv);
- G_free_key_value(format_kv);
Copied: grass/trunk/lib/raster/open.c (from rev 44707, grass/trunk/lib/raster/opencell.c)
--- grass/trunk/lib/raster/open.c (rev 0)
+++ grass/trunk/lib/raster/open.c 2010-12-24 16:51:38 UTC (rev 44713)
@@ -0,0 +1,944 @@
+ * \file raster/open.c
+ * \brief Raster Library - Open raster file
+ * for details.
+#include <rpc/types.h>
+#include <rpc/xdr.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <grass/config.h>
+#include "R.h"
+static struct fileinfo *new_fileinfo(int fd)
+ int oldsize = R__.fileinfo_count;
+ int newsize = oldsize;
+ int i;
+ if (fd < oldsize)
+ return &R__.fileinfo[fd];
+ newsize *= 2;
+ if (newsize <= fd)
+ newsize = fd + 20;
+ R__.fileinfo = G_realloc(R__.fileinfo, newsize * sizeof(struct fileinfo));
+ /* Mark all cell files as closed */
+ for (i = oldsize; i < newsize; i++) {
+ memset(&R__.fileinfo[i], 0, sizeof(struct fileinfo));
+ R__.fileinfo[i].open_mode = -1;
+ R__.fileinfo_count = newsize;
+ * \brief Open raster file
+ * Arrange for the NULL-value bitmap to be read as well as the raster
+ * map. If no NULL-value bitmap exists, arrange for the production of
+ * NULL-values based on zeros in the raster map. If the map is
+ * floating-point, arrange for quantization to integer for
+ * Rast_get_c_row(), et. al., by reading the quantization rules
+ * for the map using Rast_read_quant(). If the programmer wants to read
+ * the floating point map using uing quant rules other than the ones
+ * stored in map's quant file, he/she should call Rast_set_quant_rules()
+ * after the call to Rast_open_old().
+ * \param name map name
+ * \param open_mode mode
+ * \param map_type map type (CELL, FCELL, DCELL)
+ * \return open file descriptor ( >= 0) if successful
+static int open_raster_new(const char *name, int open_mode,
+ RASTER_MAP_TYPE map_type);
+ \brief Open an existing integer raster map (cell)
+ Opens the existing cell file <i>name</i> in the <i>mapset</i> for
+ reading by Rast_get_row() with mapping into the current window.
+ This routine opens the raster map <i>name</i> in <i>mapset</i> for
+ reading. A nonnegative file descriptor is returned if the open is
+ successful. Otherwise a diagnostic message is printed and a negative
+ value is returned. This routine does quite a bit of work. Since
+ GRASS users expect that all raster maps will be resampled into the
+ current region, the resampling index for the raster map is prepared
+ by this routine after the file is opened. The resampling is based on
+ the active module region (see also \ref The_Region}. Preparation
+ required for reading the various raster file formats (see \ref
+ Raster_File_Format for an explanation of the various raster file
+ formats) is also done.
+ Diagnostics: warning message printed if open fails.
+ \param name map name
+ \param mapset mapset name where raster map <i>name</i> lives
+ \return nonnegative file descriptor (int)
+int Rast_open_old(const char *name, const char *mapset)
+ int fd = Rast__open_old(name, mapset);
+ /* turn on auto masking, if not already on */
+ Rast__check_for_auto_masking();
+ if(R__.auto_mask <= 0)
+ R__.mask_buf = Rast_allocate_c_buf();
+ now we don't ever free it!, so no need to allocate it (Olga)
+ /* mask_buf is used for reading MASK file when mask is set and
+ for reading map rows when the null file doesn't exist */
+ return fd;
+/*! \brief Lower level function, open cell files, supercell files,
+ and the MASK file.
+ Actions:
+ - opens the named cell file, following reclass reference if
+ named layer is a reclass layer.
+ - creates the required mapping between the data and the window
+ for use by the get_map_row family of routines.
+ Diagnostics: Errors other than actual open failure will cause a
+ diagnostic to be delivered thru G_warning() open failure messages
+ are left to the calling routine since the masking logic will want to
+ issue a different warning.
+ Note: This routine does NOT open the MASK layer. If it did we would
+ get infinite recursion. This routine is called to open the mask by
+ Rast__check_for_auto_masking() which is called by Rast_open_old().
+ \param mapset mapset of cell file to be opened
+ \return open file descriptor
+int Rast__open_old(const char *name, const char *mapset)
+ struct fileinfo *fcb;
+ int fd;
+ char *cell_dir;
+ const char *r_name;
+ const char *r_mapset;
+ struct Cell_head cellhd;
+ int CELL_nbytes = 0; /* bytes per cell in CELL map */
+ int INTERN_SIZE;
+ int reclass_flag;
+ int MAP_NBYTES;
+ RASTER_MAP_TYPE MAP_TYPE;
+ struct Reclass reclass;
+ char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+ struct GDAL_link *gdal;
+ Rast__init();
+ G_unqualified_name(name, mapset, xname, xmapset);
+ name = xname;
+ mapset = xmapset;
+ if (!G_find_raster2(name, mapset))
+ G_fatal_error(_("Raster map <%s> not found"),
+ G_fully_qualified_name(name, mapset));
+ /* Check for reclassification */
+ reclass_flag = Rast_get_reclass(name, mapset, &reclass);
+ switch (reclass_flag) {
+ case 0:
+ r_name = name;
+ r_mapset = mapset;
+ break;
+ case 1:
+ r_name = reclass.name;
+ r_mapset = reclass.mapset;
+ if (!G_find_raster2(r_name, r_mapset))
+ G_fatal_error(_("Unable to open raster map <%s@%s> since it is a reclass "
+ "of raster map <%s@%s> which does not exist"),
+ name, mapset, r_name, r_mapset);
+ break;
+ default: /* Error reading cellhd/reclass file */
+ G_fatal_error(_("Error reading reclass file for raster map <%s>"),
+ break;
+ /* read the cell header */
+ Rast_get_cellhd(r_name, r_mapset, &cellhd);
+ /* now check the type */
+ MAP_TYPE = Rast_map_type(r_name, r_mapset);
+ if (MAP_TYPE < 0)
+ G_fatal_error(_("Error reading map type for raster map <%s>"),
+ if (MAP_TYPE == CELL_TYPE)
+ /* set the number of bytes for CELL map */
+ CELL_nbytes = cellhd.format + 1;
+ if (CELL_nbytes < 1)
+ G_fatal_error(_("Raster map <%s@%s>: format field in header file invalid"),
+ r_name, r_mapset);
+ if (cellhd.proj != R__.rd_window.proj)
+ G_fatal_error(_("Raster map <%s> is in different projection than current region. "
+ "Found <%s>, should be <%s>."),
+ G_fully_qualified_name(name, mapset),
+ G__projection_name(cellhd.proj),
+ G__projection_name(R__.rd_window.proj));
+ if (cellhd.zone != R__.rd_window.zone)
+ G_fatal_error(_("Raster map <%s> is in different zone (%d) than current region (%d)"),
+ G_fully_qualified_name(name, mapset), cellhd.zone, R__.rd_window.zone);
+ /* when map is int warn if too large cell size */
+ if (MAP_TYPE == CELL_TYPE && (unsigned int)CELL_nbytes > sizeof(CELL))
+ G_fatal_error(_("Raster map <%s>: bytes per cell (%d) too large"),
+ G_fully_qualified_name(name, mapset), CELL_nbytes);
+ /* record number of bytes per cell */
+ if (MAP_TYPE == FCELL_TYPE) {
+ cell_dir = "fcell";
+ INTERN_SIZE = sizeof(FCELL);
+ MAP_NBYTES = XDR_FLOAT_NBYTES;
+ else if (MAP_TYPE == DCELL_TYPE) {
+ INTERN_SIZE = sizeof(DCELL);
+ MAP_NBYTES = XDR_DOUBLE_NBYTES;
+ else { /* integer */
+ cell_dir = "cell";
+ INTERN_SIZE = sizeof(CELL);
+ MAP_NBYTES = CELL_nbytes;
+ gdal = Rast_get_gdal_link(r_name, r_mapset);
+ if (gdal) {
+#ifdef HAVE_GDAL
+ /* dummy descriptor to reserve the fileinfo slot */
+ fd = open(G_DEV_NULL, O_RDONLY);
+#else
+ G_fatal_error(_("Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
+#endif
+ else
+ /* now actually open file for reading */
+ fd = G_open_old(cell_dir, r_name, r_mapset);
+ if (fd < 0)
+ G_fatal_error(_("Unable to open %s file for raster map <%s@%s>"),
+ cell_dir, r_name, r_mapset);
+ fcb = new_fileinfo(fd);
+ fcb->map_type = MAP_TYPE;
+ /* Save cell header */
+ fcb->cellhd = cellhd;
+ /* allocate null bitstream buffers for reading null rows */
+ fcb->null_cur_row = -1;
+ fcb->null_bits = Rast__allocate_null_bits(cellhd.cols);
+ /* mark closed */
+ /* save name and mapset */
+ fcb->name = G_store(name);
+ fcb->mapset = G_store(mapset);
+ /* mark no data row in memory */
+ fcb->cur_row = -1;
+ /* if reclass, copy reclass structure */
+ if ((fcb->reclass_flag = reclass_flag))
+ fcb->reclass = reclass;
+ fcb->gdal = gdal;
+ if (!gdal)
+ /* check for compressed data format, making initial reads if necessary */
+ if (Rast__check_format(fd) < 0) {
+ close(fd); /* warning issued by check_format() */
+ G_fatal_error(_("Error reading format for <%s@%s>"),
+ /* create the mapping from cell file to window */
+ Rast__create_window_mapping(fd);
+ * allocate the data buffer
+ * number of bytes per cell is cellhd.format+1
+ /* for reading fcb->data is allocated to be fcb->cellhd.cols * fcb->nbytes
+ (= XDR_FLOAT/DOUBLE_NBYTES) */
+ fcb->data = (unsigned char *)G_calloc(fcb->cellhd.cols, MAP_NBYTES);
+ /* initialize/read in quant rules for float point maps */
+ Rast_read_quant(fcb->reclass.name, fcb->reclass.mapset,
+ &(fcb->quant));
+ else
+ Rast_read_quant(fcb->name, fcb->mapset, &(fcb->quant));
+ /* now mark open for read: this must follow create_window_mapping() */
+ fcb->open_mode = OPEN_OLD;
+ fcb->io_error = 0;
+ fcb->nbytes = MAP_NBYTES;
+ if (!gdal) {
+ if (!G_find_file2_misc("cell_misc", NULL_FILE, r_name, r_mapset)) {
+ /* G_warning("unable to find [%s]",path); */
+ fcb->null_file_exists = 0;
+ else {
+ fcb->null_fd = G_open_old_misc("cell_misc", NULL_FILE, r_name, r_mapset);
+ fcb->null_file_exists = fcb->null_fd >= 0;
+ xdrmem_create(&fcb->xdrstream, (caddr_t) fcb->data,
+ (u_int) (fcb->nbytes * fcb->cellhd.cols), XDR_DECODE);
+ return fd;
+ \brief Opens a new cell file in a database (compressed)
+ Opens a new cell file <i>name</i> in the current mapset for writing
+ by Rast_put_row().
+ The file is created and filled with no data it is assumed that the
+ new cell file is to conform to the current window.
+ The file must be written sequentially. Use Rast_open_new_random()
+ for non sequential writes.
+ Note: the open actually creates a temporary file Rast_close() will
+ move the temporary file to the cell file and write out the necessary
+ support files (cellhd, cats, hist, etc.).
+ Warning: calls to Rast_set_window() made after opening a new cell file
+ may create confusion and should be avoided the new cell file will be
+ created to conform to the window at the time of the open.
+ \return open file descriptor ( >= 0) if successful
+ \return negative integer if error
+int Rast_open_c_new(const char *name)
+ return open_raster_new(name, OPEN_NEW_COMPRESSED, CELL_TYPE);
+ \brief Opens a new cell file in a database (uncompressed)
+ See also Rast_open_new().
+int Rast_open_c_new_uncompressed(const char *name)
+ return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, CELL_TYPE);
+ \brief Save histogram for newly create raster map (cell)
+ If newly created cell files should have histograms, set flag=1
+ otherwise set flag=0. Applies to subsequent opens.
+ \param flag flag indicator
+void Rast_want_histogram(int flag)
+ R__.want_histogram = flag;
+ \brief Sets the format for subsequent opens on new integer cell files
+ (uncompressed and random only).
+ Warning: subsequent put_row calls will only write n+1 bytes per
+ cell. If the data requires more, the cell file will be written
+ incorrectly (but with n+1 bytes per cell)
+ When writing float map: format is -1
+ \param n format
+void Rast_set_cell_format(int n)
+/* sets the format for integer raster map */
+ R__.nbytes = n + 1;
+ if (R__.nbytes <= 0)
+ R__.nbytes = 1;
+ if (R__.nbytes > sizeof(CELL))
+ R__.nbytes = sizeof(CELL);
+ \brief Get cell value format
+ \param v cell
+ \return cell format
+int Rast_get_cell_format(CELL v)
+ unsigned int i;
+ if (v >= 0)
+ for (i = 0; i < sizeof(CELL); i++)
+ if (!(v /= 256))
+ return i;
+ return sizeof(CELL) - 1;
+ \brief Opens new fcell file in a database
+ Opens a new floating-point map <i>name</i> in the current mapset for
+ writing. The type of the file (i.e. either double or float) is
+ determined and fixed at this point. The default is FCELL_TYPE. In
+ order to change this default
+ Use Rast_set_fp_type() where type is one of DCELL_TYPE or FCELL_TYPE.
+ See warnings and notes for Rast_open_new().
+int Rast_open_fp_new(const char *name)
+ return open_raster_new(name, OPEN_NEW_COMPRESSED, R__.fp_type);
+ \brief Opens new fcell file in a database (uncompressed)
+ See Rast_open_fp_new() for details.
+int Rast_open_fp_new_uncompressed(const char *name)
+ return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, R__.fp_type);
+#ifdef HAVE_GDAL
+static int open_raster_new_gdal(char *map, char *mapset,
+ int fd;
+ if (fd < 0)
+ G_fatal_error(_("Unable to open null device"));
+ /* mark closed */
+ fcb->map_type = map_type;
+ fcb->gdal = Rast_create_gdal_link(map, map_type);
+ if (!fcb->gdal)
+ G_fatal_error(_("Unable to create GDAL link"));
+ fcb->cellhd = R__.wr_window;
+ fcb->cellhd.compressed = 0;
+ fcb->nbytes = Rast_cell_size(fcb->map_type);
+ /* for writing fcb->data is allocated to be R__.wr_window.cols *
+ sizeof(CELL or DCELL or FCELL) */
+ fcb->data = G_calloc(R__.wr_window.cols, fcb->nbytes);
+ fcb->name = map;
+ fcb->mapset = mapset;
+ fcb->cur_row = 0;
+ fcb->row_ptr = NULL;
+ fcb->temp_name = NULL;
+ fcb->null_cur_row = 0;
+ fcb->null_bits = NULL;
+ Rast_quant_init(&(fcb->quant));
+ /* init cell stats */
+ /* now works only for int maps */
+ if ((fcb->want_histogram = R__.want_histogram))
+ Rast_init_cell_stats(&fcb->statf);
+ /* init range and if map is double/float init d/f_range */
+ Rast_init_range(&fcb->range);
+ Rast_init_fp_range(&fcb->fp_range);
+ /* mark file as open for write */
+ fcb->open_mode = OPEN_NEW_UNCOMPRESSED;
+ return fd;
+#endif /* HAVE_GDAL */
+ int fd;
+ char *tempname;
+ char *map;
+ char *mapset;
+ const char *cell_dir;
+ int nbytes;
+ Rast__init();
+ switch (map_type) {
+ case CELL_TYPE:
+ nbytes = R__.nbytes;
+ break;
+ case FCELL_TYPE:
+ nbytes = XDR_FLOAT_NBYTES;
+ break;
+ case DCELL_TYPE:
+ nbytes = XDR_DOUBLE_NBYTES;
+ break;
+ default:
+ G_fatal_error(_("Invalid map type <%d>"), map_type);
+ break;
+ if (G_unqualified_name(name, G_mapset(), xname, xmapset) < 0)
+ G_fatal_error(_("Raster map <%s> is not in the current mapset (%s)"),
+ name, G_mapset());
+ map = G_store(xname);
+ mapset = G_store(xmapset);
+ /* check for legal grass name */
+ if (G_legal_filename(map) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), map);
+#ifdef HAVE_GDAL
+ if (G_find_file2("", "GDAL", G_mapset()))
+ return open_raster_new_gdal(map, mapset, map_type);
+#endif
+ /* open a tempfile name */
+ tempname = G_tempfile();
+ fd = creat(tempname, 0666);
+ if (fd < 0) {
+ G_free(mapset);
+ G_free(tempname);
+ G_free(map);
+ G_fatal_error(_("No temp files available"));
+ * since we are bypassing the normal open logic
+ * must create the cell element
+ G__make_mapset_element(cell_dir);
+ /* mark closed */
+ fcb->gdal = NULL;
+ fcb->data = (unsigned char *)G_calloc(R__.wr_window.cols,
+ Rast_cell_size(fcb->map_type));
+ * copy current window into cell header
+ * set format to cell/supercell
+ * for compressed writing
+ * allocate space to hold the row address array
+ if (open_mode == OPEN_NEW_COMPRESSED && fcb->map_type == CELL_TYPE) {
+ fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
+ G_zero(fcb->row_ptr, (fcb->cellhd.rows + 1) * sizeof(off_t));
+ fcb->cellhd.compressed = R__.compression_type;
+ fcb->nbytes = 1; /* to the minimum */
+ else {
+ fcb->nbytes = nbytes;
+ if (open_mode == OPEN_NEW_COMPRESSED) {
+ else
+ /* save name and mapset, and tempfile name */
+ fcb->name = map;
+ fcb->temp_name = tempname;
+ /* next row to be written (in order) is zero */
+ fcb->cur_row = 0;
+ /* open a null tempfile name */
+ fcb->null_fd = creat(tempname, 0666);
+ if (fcb->null_fd < 0) {
+ G_free(tempname);
+ close(fd);
+ G_fatal_error(_("no temp files available"));
+ fcb->null_temp_name = tempname;
+ /* allocate null bitstream buffer for writing */
+ fcb->null_bits = Rast__allocate_null_bits(fcb->cellhd.cols);
+ fcb->open_mode = open_mode;
+ return fd;
+ \brief Set raster map floating-point data format.
+ This controls the storage type for floating-point maps. It affects
+ subsequent calls to G_open_fp_map_new(). The <i>type</i> must be
+ one of FCELL_TYPE (float) or DCELL_TYPE (double). The use of this
+ routine by applications is discouraged since its use would override
+ user preferences.
+ \param type raster data type
+ \return void
+void Rast_set_fp_type(RASTER_MAP_TYPE map_type)
+ Rast__init();
+ case FCELL_TYPE:
+ case DCELL_TYPE:
+ R__.fp_type = map_type;
+ break;
+ default:
+ G_fatal_error(_("Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"));
+ break;
+ \brief Check if raster map is floating-point
+ Returns true (1) if raster map <i>name</i> in <i>mapset</i>
+ is a floating-point dataset; false(0) otherwise.
+ \return 1 floating-point
+ \return 0 int
+int Rast_map_is_fp(const char *name, const char *mapset)
+ const char *xmapset;
+ xmapset = G_find_raster2(name, mapset);
+ if (!xmapset)
+ G__file_name(path, "fcell", name, xmapset);
+ if (access(path, 0) == 0)
+ return 1;
+ G__file_name(path, "g3dcell", name, xmapset);
+ return 1;
+ return 0;
+ \brief Determine raster data type
+ Determines if the raster map is floating point or integer. Returns
+ DCELL_TYPE for double maps, FCELL_TYPE for float maps, CELL_TYPE for
+ integer maps, -1 if error has occured
+ \param mapset mapset where map <i>name</i> lives
+ \return raster data type
+RASTER_MAP_TYPE Rast_map_type(const char *name, const char *mapset)
+ if (!xmapset) {
+ if (mapset && *mapset)
+ G_fatal_error(_("Raster map <%s> not found in mapset <%s>"),
+ name, mapset);
+ else
+ G_fatal_error(_("Raster map <%s> not found"), name);
+ return Rast__check_fp_type(name, xmapset);
+ return DCELL_TYPE;
+ return CELL_TYPE;
+ \brief Determine raster type from descriptor
+ \param fd file descriptor
+RASTER_MAP_TYPE Rast_get_map_type(int fd)
+ return fcb->map_type;
+ \brief Determines whether the floating points cell file has double or float type
+ \return raster type (fcell, dcell)
+RASTER_MAP_TYPE Rast__check_fp_type(const char *name, const char *mapset)
+ struct Key_Value *format_keys;
+ const char *str, *str1;
+ RASTER_MAP_TYPE map_type;
+ if (!xmapset)
+ G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, xmapset);
+ if (access(path, 0) != 0)
+ G_fatal_error(_("Unable to find '%s'"), path);
+ format_keys = G_read_key_value_file(path);
+ if ((str = G_find_key_value("type", format_keys)) != NULL) {
+ if (strcmp(str, "double") == 0)
+ map_type = DCELL_TYPE;
+ else if (strcmp(str, "float") == 0)
+ map_type = FCELL_TYPE;
+ else {
+ G_free_key_value(format_keys);
+ G_fatal_error(_("Invalid type: field '%s' in file '%s'"), str, path);
+ else {
+ G_fatal_error(_("Missing type: field in file '%s'"), path);
+ if ((str1 = G_find_key_value("byte_order", format_keys)) != NULL) {
+ if (strcmp(str1, "xdr") != 0)
+ G_warning(_("Raster map <%s> is not xdr: byte_order: %s"),
+ name, str);
+ /* here read and translate byte order if not using xdr */
+ return map_type;
+ \brief Opens a new raster map
+ Opens a new raster map of type <i>wr_type</i>
+ Supported data types:
+ - CELL_TYPE
+ - FCELL_TYPE
+ - DCELL_TYPE
+ On CELL_TYPE calls Rast_open_new() otherwise Rast_open_fp_new().
+ \param wr_type raster data type
+int Rast_open_new(const char *name, RASTER_MAP_TYPE wr_type)
+ return open_raster_new(name, OPEN_NEW_COMPRESSED, wr_type);
+ \brief Opens a new raster map (uncompressed)
+ See Rast_open_new().
+int Rast_open_new_uncompressed(const char *name, RASTER_MAP_TYPE wr_type)
+ return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, wr_type);
+ \brief Sets quant translation rules for raster map opened for
+ reading.
+ Returned by Rast_open_old(). After calling this function,
+ Rast_get_c_row() and Rast_get_c_row() will use rules defined by q
+ (instead of using rules defined in map's quant file) to convert floats to
+ ints.
+ \param fd file descriptor (cell file)
+ \param q pointer to Quant structure
+ \return void
+void Rast_set_quant_rules(int fd, struct Quant *q)
+ CELL cell;
+ DCELL dcell;
+ struct Quant_table *p;
+ if (fcb->open_mode != OPEN_OLD)
+ G_fatal_error(_("Rast_set_quant_rules() can be called only for "
+ "raster maps opened for reading"));
+ /* copy all info from q to fcb->quant) */
+ Rast_quant_init(&fcb->quant);
+ if (q->truncate_only) {
+ Rast_quant_truncate(&fcb->quant);
+ return;
+ for (p = &(q->table[q->nofRules - 1]); p >= q->table; p--)
+ Rast_quant_add_rule(&fcb->quant, p->dLow, p->dHigh, p->cLow,
+ p->cHigh);
+ if (Rast_quant_get_neg_infinite_rule(q, &dcell, &cell) > 0)
+ Rast_quant_set_neg_infinite_rule(&fcb->quant, dcell, cell);
+ if (Rast_quant_get_pos_infinite_rule(q, &dcell, &cell) > 0)
+ Rast_quant_set_pos_infinite_rule(&fcb->quant, dcell, cell);
Deleted: grass/trunk/lib/raster/opencell.c
--- grass/trunk/lib/raster/opencell.c 2010-12-24 15:13:08 UTC (rev 44712)
+++ grass/trunk/lib/raster/opencell.c 2010-12-24 16:51:38 UTC (rev 44713)
@@ -1,944 +0,0 @@
- * \file raster/opencell.c
- * \brief Raster Library - Open raster file
- * for details.
-#include <rpc/types.h>
-#include <rpc/xdr.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-#include <fcntl.h>
-#include <grass/config.h>
-#include "R.h"
-static struct fileinfo *new_fileinfo(int fd)
- int oldsize = R__.fileinfo_count;
- int newsize = oldsize;
- int i;
- if (fd < oldsize)
- return &R__.fileinfo[fd];
- newsize *= 2;
- if (newsize <= fd)
- newsize = fd + 20;
- R__.fileinfo = G_realloc(R__.fileinfo, newsize * sizeof(struct fileinfo));
- /* Mark all cell files as closed */
- for (i = oldsize; i < newsize; i++) {
- memset(&R__.fileinfo[i], 0, sizeof(struct fileinfo));
- R__.fileinfo[i].open_mode = -1;
- R__.fileinfo_count = newsize;
- * \brief Open raster file
- * Arrange for the NULL-value bitmap to be read as well as the raster
- * map. If no NULL-value bitmap exists, arrange for the production of
- * NULL-values based on zeros in the raster map. If the map is
- * floating-point, arrange for quantization to integer for
- * Rast_get_c_row(), et. al., by reading the quantization rules
- * for the map using Rast_read_quant(). If the programmer wants to read
- * the floating point map using uing quant rules other than the ones
- * stored in map's quant file, he/she should call Rast_set_quant_rules()
- * after the call to Rast_open_old().
- * \param name map name
- * \param open_mode mode
- * \param map_type map type (CELL, FCELL, DCELL)
- * \return open file descriptor ( >= 0) if successful
-static int open_raster_new(const char *name, int open_mode,
- RASTER_MAP_TYPE map_type);
- \brief Open an existing integer raster map (cell)
- Opens the existing cell file <i>name</i> in the <i>mapset</i> for
- reading by Rast_get_row() with mapping into the current window.
- This routine opens the raster map <i>name</i> in <i>mapset</i> for
- reading. A nonnegative file descriptor is returned if the open is
- successful. Otherwise a diagnostic message is printed and a negative
- value is returned. This routine does quite a bit of work. Since
- GRASS users expect that all raster maps will be resampled into the
- current region, the resampling index for the raster map is prepared
- by this routine after the file is opened. The resampling is based on
- the active module region (see also \ref The_Region}. Preparation
- required for reading the various raster file formats (see \ref
- Raster_File_Format for an explanation of the various raster file
- formats) is also done.
- Diagnostics: warning message printed if open fails.
- \param name map name
- \param mapset mapset name where raster map <i>name</i> lives
- \return nonnegative file descriptor (int)
-int Rast_open_old(const char *name, const char *mapset)
- int fd = Rast__open_old(name, mapset);
- /* turn on auto masking, if not already on */
- Rast__check_for_auto_masking();
- if(R__.auto_mask <= 0)
- R__.mask_buf = Rast_allocate_c_buf();
- now we don't ever free it!, so no need to allocate it (Olga)
- /* mask_buf is used for reading MASK file when mask is set and
- for reading map rows when the null file doesn't exist */
- return fd;
-/*! \brief Lower level function, open cell files, supercell files,
- and the MASK file.
- Actions:
- - opens the named cell file, following reclass reference if
- named layer is a reclass layer.
- - creates the required mapping between the data and the window
- for use by the get_map_row family of routines.
- Diagnostics: Errors other than actual open failure will cause a
- diagnostic to be delivered thru G_warning() open failure messages
- are left to the calling routine since the masking logic will want to
- issue a different warning.
- Note: This routine does NOT open the MASK layer. If it did we would
- get infinite recursion. This routine is called to open the mask by
- Rast__check_for_auto_masking() which is called by Rast_open_old().
- \param mapset mapset of cell file to be opened
- \return open file descriptor
-int Rast__open_old(const char *name, const char *mapset)
- struct fileinfo *fcb;
- int fd;
- char *cell_dir;
- const char *r_name;
- const char *r_mapset;
- struct Cell_head cellhd;
- int CELL_nbytes = 0; /* bytes per cell in CELL map */
- int INTERN_SIZE;
- int reclass_flag;
- int MAP_NBYTES;
- RASTER_MAP_TYPE MAP_TYPE;
- struct Reclass reclass;
- char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- struct GDAL_link *gdal;
- Rast__init();
- G_unqualified_name(name, mapset, xname, xmapset);
- name = xname;
- mapset = xmapset;
- if (!G_find_raster2(name, mapset))
- G_fatal_error(_("Raster map <%s> not found"),
- G_fully_qualified_name(name, mapset));
- /* Check for reclassification */
- reclass_flag = Rast_get_reclass(name, mapset, &reclass);
- switch (reclass_flag) {
- case 0:
- r_name = name;
- r_mapset = mapset;
- break;
- case 1:
- r_name = reclass.name;
- r_mapset = reclass.mapset;
- if (!G_find_raster2(r_name, r_mapset))
- G_fatal_error(_("Unable to open raster map <%s@%s> since it is a reclass "
- "of raster map <%s@%s> which does not exist"),
- name, mapset, r_name, r_mapset);
- break;
- default: /* Error reading cellhd/reclass file */
- G_fatal_error(_("Error reading reclass file for raster map <%s>"),
- break;
- /* read the cell header */
- Rast_get_cellhd(r_name, r_mapset, &cellhd);
- /* now check the type */
- MAP_TYPE = Rast_map_type(r_name, r_mapset);
- if (MAP_TYPE < 0)
- G_fatal_error(_("Error reading map type for raster map <%s>"),
- if (MAP_TYPE == CELL_TYPE)
- /* set the number of bytes for CELL map */
- CELL_nbytes = cellhd.format + 1;
- if (CELL_nbytes < 1)
- G_fatal_error(_("Raster map <%s@%s>: format field in header file invalid"),
- r_name, r_mapset);
- if (cellhd.proj != R__.rd_window.proj)
- G_fatal_error(_("Raster map <%s> is in different projection than current region. "
- "Found <%s>, should be <%s>."),
- G_fully_qualified_name(name, mapset),
- G__projection_name(cellhd.proj),
- G__projection_name(R__.rd_window.proj));
- if (cellhd.zone != R__.rd_window.zone)
- G_fatal_error(_("Raster map <%s> is in different zone (%d) than current region (%d)"),
- G_fully_qualified_name(name, mapset), cellhd.zone, R__.rd_window.zone);
- /* when map is int warn if too large cell size */
- if (MAP_TYPE == CELL_TYPE && (unsigned int)CELL_nbytes > sizeof(CELL))
- G_fatal_error(_("Raster map <%s>: bytes per cell (%d) too large"),
- G_fully_qualified_name(name, mapset), CELL_nbytes);
- /* record number of bytes per cell */
- if (MAP_TYPE == FCELL_TYPE) {
- cell_dir = "fcell";
- INTERN_SIZE = sizeof(FCELL);
- MAP_NBYTES = XDR_FLOAT_NBYTES;
- else if (MAP_TYPE == DCELL_TYPE) {
- INTERN_SIZE = sizeof(DCELL);
- MAP_NBYTES = XDR_DOUBLE_NBYTES;
- else { /* integer */
- cell_dir = "cell";
- INTERN_SIZE = sizeof(CELL);
- MAP_NBYTES = CELL_nbytes;
- gdal = Rast_get_gdal_link(r_name, r_mapset);
- if (gdal) {
-#ifdef HAVE_GDAL
- /* dummy descriptor to reserve the fileinfo slot */
- fd = open(G_DEV_NULL, O_RDONLY);
-#else
- G_fatal_error(_("Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
-#endif
- else
- /* now actually open file for reading */
- fd = G_open_old(cell_dir, r_name, r_mapset);
- if (fd < 0)
- G_fatal_error(_("Unable to open %s file for raster map <%s@%s>"),
- cell_dir, r_name, r_mapset);
- fcb = new_fileinfo(fd);
- fcb->map_type = MAP_TYPE;
- /* Save cell header */
- fcb->cellhd = cellhd;
- /* allocate null bitstream buffers for reading null rows */
- fcb->null_cur_row = -1;
- fcb->null_bits = Rast__allocate_null_bits(cellhd.cols);
- /* mark closed */
- /* save name and mapset */
- fcb->name = G_store(name);
- fcb->mapset = G_store(mapset);
- /* mark no data row in memory */
- fcb->cur_row = -1;
- /* if reclass, copy reclass structure */
- if ((fcb->reclass_flag = reclass_flag))
- fcb->reclass = reclass;
- fcb->gdal = gdal;
- if (!gdal)
- /* check for compressed data format, making initial reads if necessary */
- if (Rast__check_format(fd) < 0) {
- close(fd); /* warning issued by check_format() */
- G_fatal_error(_("Error reading format for <%s@%s>"),
- /* create the mapping from cell file to window */
- Rast__create_window_mapping(fd);
- * allocate the data buffer
- * number of bytes per cell is cellhd.format+1
- /* for reading fcb->data is allocated to be fcb->cellhd.cols * fcb->nbytes
- (= XDR_FLOAT/DOUBLE_NBYTES) */
- fcb->data = (unsigned char *)G_calloc(fcb->cellhd.cols, MAP_NBYTES);
- /* initialize/read in quant rules for float point maps */
- Rast_read_quant(fcb->reclass.name, fcb->reclass.mapset,
- &(fcb->quant));
- else
- Rast_read_quant(fcb->name, fcb->mapset, &(fcb->quant));
- /* now mark open for read: this must follow create_window_mapping() */
- fcb->open_mode = OPEN_OLD;
- fcb->io_error = 0;
- fcb->nbytes = MAP_NBYTES;
- if (!gdal) {
- if (!G_find_file2_misc("cell_misc", NULL_FILE, r_name, r_mapset)) {
- /* G_warning("unable to find [%s]",path); */
- fcb->null_file_exists = 0;
- else {
- fcb->null_fd = G_open_old_misc("cell_misc", NULL_FILE, r_name, r_mapset);
- fcb->null_file_exists = fcb->null_fd >= 0;
- xdrmem_create(&fcb->xdrstream, (caddr_t) fcb->data,
- (u_int) (fcb->nbytes * fcb->cellhd.cols), XDR_DECODE);
- return fd;
- \brief Opens a new cell file in a database (compressed)
- Opens a new cell file <i>name</i> in the current mapset for writing
- by Rast_put_row().
- The file is created and filled with no data it is assumed that the
- new cell file is to conform to the current window.
- The file must be written sequentially. Use Rast_open_new_random()
- for non sequential writes.
- Note: the open actually creates a temporary file Rast_close() will
- move the temporary file to the cell file and write out the necessary
- support files (cellhd, cats, hist, etc.).
- Warning: calls to Rast_set_window() made after opening a new cell file
- may create confusion and should be avoided the new cell file will be
- created to conform to the window at the time of the open.
- \return open file descriptor ( >= 0) if successful
- \return negative integer if error
-int Rast_open_c_new(const char *name)
- return open_raster_new(name, OPEN_NEW_COMPRESSED, CELL_TYPE);
- \brief Opens a new cell file in a database (uncompressed)
- See also Rast_open_new().
-int Rast_open_c_new_uncompressed(const char *name)
- return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, CELL_TYPE);
- \brief Save histogram for newly create raster map (cell)
- If newly created cell files should have histograms, set flag=1
- otherwise set flag=0. Applies to subsequent opens.
- \param flag flag indicator
-void Rast_want_histogram(int flag)
- R__.want_histogram = flag;
- \brief Sets the format for subsequent opens on new integer cell files
- (uncompressed and random only).
- Warning: subsequent put_row calls will only write n+1 bytes per
- cell. If the data requires more, the cell file will be written
- incorrectly (but with n+1 bytes per cell)
- When writing float map: format is -1
- \param n format
-void Rast_set_cell_format(int n)
-/* sets the format for integer raster map */
- R__.nbytes = n + 1;
- if (R__.nbytes <= 0)
- R__.nbytes = 1;
- if (R__.nbytes > sizeof(CELL))
- R__.nbytes = sizeof(CELL);
- \brief Get cell value format
- \param v cell
- \return cell format
-int Rast_get_cell_format(CELL v)
- unsigned int i;
- if (v >= 0)
- for (i = 0; i < sizeof(CELL); i++)
- if (!(v /= 256))
- return i;
- return sizeof(CELL) - 1;
- \brief Opens new fcell file in a database
- Opens a new floating-point map <i>name</i> in the current mapset for
- writing. The type of the file (i.e. either double or float) is
- determined and fixed at this point. The default is FCELL_TYPE. In
- order to change this default
- Use Rast_set_fp_type() where type is one of DCELL_TYPE or FCELL_TYPE.
- See warnings and notes for Rast_open_new().
-int Rast_open_fp_new(const char *name)
- return open_raster_new(name, OPEN_NEW_COMPRESSED, R__.fp_type);
- \brief Opens new fcell file in a database (uncompressed)
- See Rast_open_fp_new() for details.
-int Rast_open_fp_new_uncompressed(const char *name)
- return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, R__.fp_type);
-#ifdef HAVE_GDAL
-static int open_raster_new_gdal(char *map, char *mapset,
- int fd;
- if (fd < 0)
- G_fatal_error(_("Unable to open null device"));
- /* mark closed */
- fcb->map_type = map_type;
- fcb->gdal = Rast_create_gdal_link(map, map_type);
- if (!fcb->gdal)
- G_fatal_error(_("Unable to create GDAL link"));
- fcb->cellhd = R__.wr_window;
- fcb->cellhd.compressed = 0;
- fcb->nbytes = Rast_cell_size(fcb->map_type);
- /* for writing fcb->data is allocated to be R__.wr_window.cols *
- sizeof(CELL or DCELL or FCELL) */
- fcb->data = G_calloc(R__.wr_window.cols, fcb->nbytes);
- fcb->name = map;
- fcb->mapset = mapset;
- fcb->cur_row = 0;
- fcb->row_ptr = NULL;
- fcb->temp_name = NULL;
- fcb->null_cur_row = 0;
- fcb->null_bits = NULL;
- Rast_quant_init(&(fcb->quant));
- /* init cell stats */
- /* now works only for int maps */
- if ((fcb->want_histogram = R__.want_histogram))
- Rast_init_cell_stats(&fcb->statf);
- /* init range and if map is double/float init d/f_range */
- Rast_init_range(&fcb->range);
- Rast_init_fp_range(&fcb->fp_range);
- /* mark file as open for write */
- fcb->open_mode = OPEN_NEW_UNCOMPRESSED;
- return fd;
-#endif /* HAVE_GDAL */
- int fd;
- char *tempname;
- char *map;
- char *mapset;
- const char *cell_dir;
- int nbytes;
- Rast__init();
- switch (map_type) {
- case CELL_TYPE:
- nbytes = R__.nbytes;
- break;
- case FCELL_TYPE:
- nbytes = XDR_FLOAT_NBYTES;
- break;
- case DCELL_TYPE:
- nbytes = XDR_DOUBLE_NBYTES;
- break;
- default:
- G_fatal_error(_("Invalid map type <%d>"), map_type);
- break;
- if (G_unqualified_name(name, G_mapset(), xname, xmapset) < 0)
- G_fatal_error(_("Raster map <%s> is not in the current mapset (%s)"),
- name, G_mapset());
- map = G_store(xname);
- mapset = G_store(xmapset);
- /* check for legal grass name */
- if (G_legal_filename(map) < 0)
- G_fatal_error(_("<%s> is an illegal file name"), map);
-#ifdef HAVE_GDAL
- if (G_find_file2("", "GDAL", G_mapset()))
- return open_raster_new_gdal(map, mapset, map_type);
-#endif
- /* open a tempfile name */
- tempname = G_tempfile();
- fd = creat(tempname, 0666);
- if (fd < 0) {
- G_free(mapset);
- G_free(tempname);
- G_free(map);
- G_fatal_error(_("No temp files available"));
- * since we are bypassing the normal open logic
- * must create the cell element
- G__make_mapset_element(cell_dir);
- /* mark closed */
- fcb->gdal = NULL;
- fcb->data = (unsigned char *)G_calloc(R__.wr_window.cols,
- Rast_cell_size(fcb->map_type));
- * copy current window into cell header
- * set format to cell/supercell
- * for compressed writing
- * allocate space to hold the row address array
- if (open_mode == OPEN_NEW_COMPRESSED && fcb->map_type == CELL_TYPE) {
- fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
- G_zero(fcb->row_ptr, (fcb->cellhd.rows + 1) * sizeof(off_t));
- fcb->cellhd.compressed = R__.compression_type;
- fcb->nbytes = 1; /* to the minimum */
- else {
- fcb->nbytes = nbytes;
- if (open_mode == OPEN_NEW_COMPRESSED) {
- else
- /* save name and mapset, and tempfile name */
- fcb->name = map;
- fcb->temp_name = tempname;
- /* next row to be written (in order) is zero */
- fcb->cur_row = 0;
- /* open a null tempfile name */
- fcb->null_fd = creat(tempname, 0666);
- if (fcb->null_fd < 0) {
- G_free(tempname);
- close(fd);
- G_fatal_error(_("no temp files available"));
- fcb->null_temp_name = tempname;
- /* allocate null bitstream buffer for writing */
- fcb->null_bits = Rast__allocate_null_bits(fcb->cellhd.cols);
- fcb->open_mode = open_mode;
- return fd;
- \brief Set raster map floating-point data format.
- This controls the storage type for floating-point maps. It affects
- subsequent calls to G_open_fp_map_new(). The <i>type</i> must be
- one of FCELL_TYPE (float) or DCELL_TYPE (double). The use of this
- routine by applications is discouraged since its use would override
- user preferences.
- \param type raster data type
- \return void
-void Rast_set_fp_type(RASTER_MAP_TYPE map_type)
- Rast__init();
- case FCELL_TYPE:
- case DCELL_TYPE:
- R__.fp_type = map_type;
- break;
- default:
- G_fatal_error(_("Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"));
- break;
- \brief Check if raster map is floating-point
- Returns true (1) if raster map <i>name</i> in <i>mapset</i>
- is a floating-point dataset; false(0) otherwise.
- \return 1 floating-point
- \return 0 int
-int Rast_map_is_fp(const char *name, const char *mapset)
- const char *xmapset;
- xmapset = G_find_raster2(name, mapset);
- if (!xmapset)
- G__file_name(path, "fcell", name, xmapset);
- if (access(path, 0) == 0)
- return 1;
- G__file_name(path, "g3dcell", name, xmapset);
- return 1;
- return 0;
- \brief Determine raster data type
- Determines if the raster map is floating point or integer. Returns
- DCELL_TYPE for double maps, FCELL_TYPE for float maps, CELL_TYPE for
- integer maps, -1 if error has occured
- \param mapset mapset where map <i>name</i> lives
- \return raster data type
-RASTER_MAP_TYPE Rast_map_type(const char *name, const char *mapset)
- if (!xmapset) {
- if (mapset && *mapset)
- G_fatal_error(_("Raster map <%s> not found in mapset <%s>"),
- name, mapset);
- else
- G_fatal_error(_("Raster map <%s> not found"), name);
- return Rast__check_fp_type(name, xmapset);
- return DCELL_TYPE;
- return CELL_TYPE;
- \brief Determine raster type from descriptor
- \param fd file descriptor
-RASTER_MAP_TYPE Rast_get_map_type(int fd)
- return fcb->map_type;
- \brief Determines whether the floating points cell file has double or float type
- \return raster type (fcell, dcell)
-RASTER_MAP_TYPE Rast__check_fp_type(const char *name, const char *mapset)
- struct Key_Value *format_keys;
- const char *str, *str1;
- RASTER_MAP_TYPE map_type;
- if (!xmapset)
- G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, xmapset);
- if (access(path, 0) != 0)
- G_fatal_error(_("Unable to find '%s'"), path);
- format_keys = G_read_key_value_file(path);
- if ((str = G_find_key_value("type", format_keys)) != NULL) {
- if (strcmp(str, "double") == 0)
- map_type = DCELL_TYPE;
- else if (strcmp(str, "float") == 0)
- map_type = FCELL_TYPE;
- else {
- G_free_key_value(format_keys);
- G_fatal_error(_("Invalid type: field '%s' in file '%s'"), str, path);
- else {
- G_fatal_error(_("Missing type: field in file '%s'"), path);
- if ((str1 = G_find_key_value("byte_order", format_keys)) != NULL) {
- if (strcmp(str1, "xdr") != 0)
- G_warning(_("Raster map <%s> is not xdr: byte_order: %s"),
- name, str);
- /* here read and translate byte order if not using xdr */
- return map_type;
- \brief Opens a new raster map
- Opens a new raster map of type <i>wr_type</i>
- Supported data types:
- - CELL_TYPE
- - FCELL_TYPE
- - DCELL_TYPE
- On CELL_TYPE calls Rast_open_new() otherwise Rast_open_fp_new().
- \param wr_type raster data type
-int Rast_open_new(const char *name, RASTER_MAP_TYPE wr_type)
- return open_raster_new(name, OPEN_NEW_COMPRESSED, wr_type);
- \brief Opens a new raster map (uncompressed)
- See Rast_open_new().
-int Rast_open_new_uncompressed(const char *name, RASTER_MAP_TYPE wr_type)
- return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, wr_type);
- \brief Sets quant translation rules for raster map opened for
- reading.
- Returned by Rast_open_old(). After calling this function,
- Rast_get_c_row() and Rast_get_c_row() will use rules defined by q
- (instead of using rules defined in map's quant file) to convert floats to
- ints.
- \param fd file descriptor (cell file)
- \param q pointer to Quant structure
- \return void
-void Rast_set_quant_rules(int fd, struct Quant *q)
- CELL cell;
- DCELL dcell;
- struct Quant_table *p;
- if (fcb->open_mode != OPEN_OLD)
- G_fatal_error(_("Rast_set_quant_rules() can be called only for "
- "raster maps opened for reading"));
- /* copy all info from q to fcb->quant) */
- Rast_quant_init(&fcb->quant);
- if (q->truncate_only) {
- Rast_quant_truncate(&fcb->quant);
- return;
- for (p = &(q->table[q->nofRules - 1]); p >= q->table; p--)
- Rast_quant_add_rule(&fcb->quant, p->dLow, p->dHigh, p->cLow,
- p->cHigh);
- if (Rast_quant_get_neg_infinite_rule(q, &dcell, &cell) > 0)
- Rast_quant_set_neg_infinite_rule(&fcb->quant, dcell, cell);
- if (Rast_quant_get_pos_infinite_rule(q, &dcell, &cell) > 0)
- Rast_quant_set_pos_infinite_rule(&fcb->quant, dcell, cell);
