[GRASS-SVN] r44718 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Dec 25 10:54:16 EST 2010
Author: martinl
Date: 2010-12-25 07:54:16 -0800 (Sat, 25 Dec 2010)
New Revision: 44718
grass/trunk/lib/vector/Vlib/open_ogr.c
vlib/ogr: don't use OGR_DS_GetLayerByName()
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-25 13:51:58 UTC (rev 44717)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-25 15:54:16 UTC (rev 44718)
@@ -212,11 +212,12 @@
int V1_open_new_ogr(struct Map_info *Map, const char *name, int with_z)
- OGRSFDriverH Ogr_driver;
- OGRDataSourceH Ogr_ds;
- OGRLayerH Ogr_layer;
+ OGRSFDriverH Ogr_driver;
+ OGRDataSourceH Ogr_ds;
+ OGRLayerH Ogr_layer;
+ OGRFeatureDefnH Ogr_featuredefn;
- int i;
+ int i, nlayers;
char **Ogr_layer_options;
Ogr_layer_options = NULL;
@@ -239,26 +240,26 @@
Map->fInfo.ogr.ds = Ogr_ds;
- Ogr_layer = OGR_DS_GetLayerByName(Ogr_ds, Map->fInfo.ogr.layer_name);
- if (Ogr_layer) {
- for (i = 0; i < OGR_DS_GetLayerCount(Ogr_ds); i++) {
- if (OGR_DS_GetLayer(Ogr_ds, i) == Ogr_layer) {
- if (G_get_overwrite()) {
- G_warning(_("OGR layer <%s> already exists and will be overwritten"),
- Map->fInfo.ogr.layer_name);
- if (OGR_DS_DeleteLayer(Ogr_ds, i) != OGRERR_NONE) {
- G_warning(_("Unable to delete OGR layer <%s>"),
- return -1;
+ nlayers = OGR_DS_GetLayerCount(Ogr_ds);
+ for (i = 0; i < nlayers; i++) {
+ Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
+ Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
+ if (strcmp(OGR_FD_GetName(Ogr_featuredefn), Map->fInfo.ogr.layer_name) == 0) {
+ if (G_get_overwrite()) {
+ G_warning(_("OGR layer <%s> already exists and will be overwritten"),
+ Map->fInfo.ogr.layer_name);
+ if (OGR_DS_DeleteLayer(Ogr_ds, i) != OGRERR_NONE) {
+ G_warning(_("Unable to delete OGR layer <%s>"),
+ return -1;
- else {
- G_fatal_error(_("OGR layer <%s> already exists in datasource '%s'"),
- Map->fInfo.ogr.layer_name, Map->fInfo.ogr.dsn);
- break;
+ else {
+ G_fatal_error(_("OGR layer <%s> already exists in datasource '%s'"),
+ Map->fInfo.ogr.layer_name, Map->fInfo.ogr.dsn);
+ break;
