[GRASS-SVN] r44720 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Dec 25 11:21:28 EST 2010
Author: martinl
Date: 2010-12-25 08:21:28 -0800 (Sat, 25 Dec 2010)
New Revision: 44720
grass/trunk/lib/vector/Vlib/area.c
grass/trunk/lib/vector/Vlib/array.c
grass/trunk/lib/vector/Vlib/ascii.c
grass/trunk/lib/vector/Vlib/box.c
grass/trunk/lib/vector/Vlib/break_lines.c
grass/trunk/lib/vector/Vlib/break_polygons.c
grass/trunk/lib/vector/Vlib/bridges.c
grass/trunk/lib/vector/Vlib/buffer.c
grass/trunk/lib/vector/Vlib/buffer2.c
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/lib/vector/Vlib/cats.c
grass/trunk/lib/vector/Vlib/cindex.c
grass/trunk/lib/vector/Vlib/clean_nodes.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/close_nat.c
grass/trunk/lib/vector/Vlib/close_ogr.c
grass/trunk/lib/vector/Vlib/constraint.c
grass/trunk/lib/vector/Vlib/dangles.c
grass/trunk/lib/vector/Vlib/dbcolumns.c
grass/trunk/lib/vector/Vlib/dgraph.c
grass/trunk/lib/vector/Vlib/e_intersect.c
grass/trunk/lib/vector/Vlib/error.c
grass/trunk/lib/vector/Vlib/field.c
grass/trunk/lib/vector/Vlib/find.c
grass/trunk/lib/vector/Vlib/graph.c
grass/trunk/lib/vector/Vlib/hist.c
grass/trunk/lib/vector/Vlib/init_head.c
grass/trunk/lib/vector/Vlib/intersect.c
grass/trunk/lib/vector/Vlib/legal_vname.c
grass/trunk/lib/vector/Vlib/level.c
grass/trunk/lib/vector/Vlib/level_two.c
grass/trunk/lib/vector/Vlib/line.c
grass/trunk/lib/vector/Vlib/list.c
grass/trunk/lib/vector/Vlib/map.c
grass/trunk/lib/vector/Vlib/merge_lines.c
grass/trunk/lib/vector/Vlib/net.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/open_nat.c
grass/trunk/lib/vector/Vlib/open_ogr.c
grass/trunk/lib/vector/Vlib/overlap.c
grass/trunk/lib/vector/Vlib/overlay.c
grass/trunk/lib/vector/Vlib/poly.c
grass/trunk/lib/vector/Vlib/read.c
grass/trunk/lib/vector/Vlib/read_nat.c
grass/trunk/lib/vector/Vlib/read_ogr.c
grass/trunk/lib/vector/Vlib/remove_areas.c
grass/trunk/lib/vector/Vlib/remove_duplicates.c
grass/trunk/lib/vector/Vlib/rewind.c
grass/trunk/lib/vector/Vlib/rewind_nat.c
grass/trunk/lib/vector/Vlib/rewind_ogr.c
grass/trunk/lib/vector/Vlib/select.c
grass/trunk/lib/vector/Vlib/simple_features.c
grass/trunk/lib/vector/Vlib/sindex.c
grass/trunk/lib/vector/Vlib/snap.c
grass/trunk/lib/vector/Vlib/tin.c
grass/trunk/lib/vector/Vlib/type.c
grass/trunk/lib/vector/Vlib/window.c
grass/trunk/lib/vector/Vlib/write_ogr.c
vlib: unify \file doxygen instruction (cosmetics)
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/area.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file area.c
+ \file lib/vector/Vlib/area.c
\brief Vector library - area-related functions
Modified: grass/trunk/lib/vector/Vlib/array.c
--- grass/trunk/lib/vector/Vlib/array.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/array.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file array.c
+ \file lib/vector/Vlib/array.c
\brief Vector library - category array
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/ascii.c
+ \file lib/vector/Vlib/ascii.c
\brief Vector library - GRASS ASCII vector format
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/box.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file box.c
+ \file lib/vector/Vlib/box.c
\brief Vector library - bounding box
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file break_lines.c
+ * \file lib/vector/Vlib/break_lines.c
* \brief Vector library - Clean vector map (break lines)
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file break_polygons.c
+ \file lib/vector/Vlib/break_polygons.c
\brief Vector library - clean geometry (break polygons)
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/bridges.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file bridges.c
+ \file lib/vector/Vlib/bridges.c
\brief Vector library - clean geometry (bridges)
Modified: grass/trunk/lib/vector/Vlib/buffer.c
--- grass/trunk/lib/vector/Vlib/buffer.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/buffer.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file buffer.c
+ \file lib/vector/Vlib/buffer.c
\brief Vector library - nearest, adjust, parallel lines
Modified: grass/trunk/lib/vector/Vlib/buffer2.c
--- grass/trunk/lib/vector/Vlib/buffer2.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/buffer2.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file buffer2.c
+ \file lib/vector/Vlib/buffer2.c
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file build_nat.c
+ \file lib/vector/Vlib/build_nat.c
\brief Vector library - Building topology for native format
Modified: grass/trunk/lib/vector/Vlib/cats.c
--- grass/trunk/lib/vector/Vlib/cats.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/cats.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file cats.c
+ * \file lib/vector/Vlib/cats.c
* \brief Vector library - Category management
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/cindex.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file Vlib/cindex.c
+ * \file lib/vector/Vlib/cindex.c
* \brief Vector library - category index.
Modified: grass/trunk/lib/vector/Vlib/clean_nodes.c
--- grass/trunk/lib/vector/Vlib/clean_nodes.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/clean_nodes.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file clean_nodes.c
+ \file lib/vector/Vlib/clean_nodes.c
\brief Vector library - Clean boundaries at nodes
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/close.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file close.c
+ \file lib/vector/Vlib/close.c
\brief Vector library - Close map
Modified: grass/trunk/lib/vector/Vlib/close_nat.c
--- grass/trunk/lib/vector/Vlib/close_nat.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/close_nat.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file close_nat.c
+ \file lib/vector/Vlib/close_nat.c
\brief Vector library - Close map (native format)
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file close_ogr.c
+ \file lib/vector/Vlib/close_ogr.c
\brief Vector library - Close map (OGR)
Modified: grass/trunk/lib/vector/Vlib/constraint.c
--- grass/trunk/lib/vector/Vlib/constraint.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/constraint.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file constraint.c
+ \file lib/vector/Vlib/constraint.c
\brief Vector library - constraints
Modified: grass/trunk/lib/vector/Vlib/dangles.c
--- grass/trunk/lib/vector/Vlib/dangles.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/dangles.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file dangles.c
+ \file lib/vector/Vlib/dangles.c
\brief Vector library - clean geometry (dangles)
Modified: grass/trunk/lib/vector/Vlib/dbcolumns.c
--- grass/trunk/lib/vector/Vlib/dbcolumns.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/dbcolumns.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file dbcolumns.c
+ \file lib/vector/Vlib/dbcolumns.c
\brief Vector library - DB info on vectors maps
Modified: grass/trunk/lib/vector/Vlib/dgraph.c
--- grass/trunk/lib/vector/Vlib/dgraph.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/dgraph.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file dgraph.c
+ \file lib/vector/Vlib/dgraph.c
\brief Vector library - intersection (lower level functions)
Modified: grass/trunk/lib/vector/Vlib/e_intersect.c
--- grass/trunk/lib/vector/Vlib/e_intersect.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/e_intersect.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file e_intersect.c
+ \file lib/vector/Vlib/e_intersect.c
Modified: grass/trunk/lib/vector/Vlib/error.c
--- grass/trunk/lib/vector/Vlib/error.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/error.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file error.c
+ \file lib/vector/Vlib/error.c
\brief Vector library - error management
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/field.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/field.c
+ \file lib/vector/Vlib/field.c
\brief Vector library - field (layer) related fns.
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/find.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file find.c
+ * \file lib/vector/Vlib/find.c
* \brief Vector library - Find nearest vector feature.
Modified: grass/trunk/lib/vector/Vlib/graph.c
--- grass/trunk/lib/vector/Vlib/graph.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/graph.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file graph.c
+ \file lib/vector/Vlib/graph.c
\brief Vector library - graph manipulation
Modified: grass/trunk/lib/vector/Vlib/hist.c
--- grass/trunk/lib/vector/Vlib/hist.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/hist.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file hist.c
+ \file lib/vector/Vlib/hist.c
\brief Vector library - history manipulation
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/init_head.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/init_head.c
+ \file lib/vector/Vlib/init_head.c
\brief Vector library - init header of vector maps
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file intersect.c
+ \file lib/vector/Vlib/intersect.c
Modified: grass/trunk/lib/vector/Vlib/legal_vname.c
--- grass/trunk/lib/vector/Vlib/legal_vname.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/legal_vname.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file legal_vname.c
+ \file lib/vector/Vlib/legal_vname.c
\brief Vector library - Check if map name is legal vector map name
Modified: grass/trunk/lib/vector/Vlib/level.c
--- grass/trunk/lib/vector/Vlib/level.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/level.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file level.c
+ \file lib/vector/Vlib/level.c
\brief Vector library - level info
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/level_two.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file level_two.c
+ \file lib/vector/Vlib/level_two.c
\brief Vector library - topology level functions
Modified: grass/trunk/lib/vector/Vlib/line.c
--- grass/trunk/lib/vector/Vlib/line.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/line.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/line.c
+ \file lib/vector/Vlib/line.c
\brief Vector library - vector feature geometry
Modified: grass/trunk/lib/vector/Vlib/list.c
--- grass/trunk/lib/vector/Vlib/list.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/list.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,6 +1,6 @@
- * \file list.c
+ * \file lib/vector/Vlib/list.c
* \brief Vector library - list definition
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/map.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file map.c
+ * \file lib/vector/Vlib/map.c
* \brief Vector library - Manipulate with vector map
Modified: grass/trunk/lib/vector/Vlib/merge_lines.c
--- grass/trunk/lib/vector/Vlib/merge_lines.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/merge_lines.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file merge_lines.c
+ \file lib/vector/Vlib/merge_lines.c
\brief Vector library - clean geometry (merge lines/boundaries)
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/net.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file net.c
+ * \file lib/vector/Vlib/net.c
* \brief Vector library - net releated fns
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/open.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file vector/Vlib/open.c
+ * \file lib/vector/Vlib/open.c
* \brief Vector library - Open vector map (native or OGR format)
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/open_nat.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/open_nat.c
+ \file lib/vector/Vlib/open_nat.c
\brief Vector library - open vector map (native format) - level 1
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/open_ogr.c
+ \file lib/vector/Vlib/open_ogr.c
\brief Vector library - Open OGR layer as vector map layer
Modified: grass/trunk/lib/vector/Vlib/overlap.c
--- grass/trunk/lib/vector/Vlib/overlap.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/overlap.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file overlap.c
+ \file lib/vector/Vlib/overlap.c
\brief Vector library - region/window overlap
Modified: grass/trunk/lib/vector/Vlib/overlay.c
--- grass/trunk/lib/vector/Vlib/overlay.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/overlay.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file overlay.c
+ \file lib/vector/Vlib/overlay.c
\brief Vector library - overlays
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/poly.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file poly.c
+ \file lib/vector/Vlib/poly.c
\brief Vector library - polygon related fns
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/read.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file read.c
+ \file lib/vector/Vlib/read.c
\brief Vector library - read vector features
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/read_nat.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file read_nat.c
+ \file lib/vector/Vlib/read_nat.c
\brief Vector library - reading data (native format)
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file lib/vector/Vlib/read_ogr.c
+ \file lib/vector/Vlib/lib/vector/Vlib/read_ogr.c
\brief Vector library - reading data (OGR format)
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file remove_areas.c
+ \file lib/vector/Vlib/remove_areas.c
\brief Vector library - clean geometry (remove small areas)
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file remove_duplicates.c
+ \file lib/vector/Vlib/remove_duplicates.c
\brief Vector library - clean geometry (remove duplicates)
Modified: grass/trunk/lib/vector/Vlib/rewind.c
--- grass/trunk/lib/vector/Vlib/rewind.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/rewind.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file rewind.c
+ \file lib/vector/Vlib/rewind.c
\brief Vector library - rewind data
Modified: grass/trunk/lib/vector/Vlib/rewind_nat.c
--- grass/trunk/lib/vector/Vlib/rewind_nat.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/rewind_nat.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file rewind.c
\brief Vector library - rewind data (native format)
Modified: grass/trunk/lib/vector/Vlib/rewind_ogr.c
--- grass/trunk/lib/vector/Vlib/rewind_ogr.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/rewind_ogr.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file rewind.c
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/select.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file Vlib/select.c
+ \file lib/vector/Vlib/select.c
\brief Vector library - spatial index
Modified: grass/trunk/lib/vector/Vlib/simple_features.c
--- grass/trunk/lib/vector/Vlib/simple_features.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/simple_features.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/simple_features.c
+ \file lib/vector/Vlib/simple_features.c
\brief Vector library - OGC Simple Features Access
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/sindex.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file Vlib/sindex.c
+ \file lib/vector/Vlib/sindex.c
\brief Vector library - select vector features
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/snap.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- * \file snap.c
+ * \file lib/vector/Vlib/snap.c
* \brief Vector library - Clean vector map (snap lines)
Modified: grass/trunk/lib/vector/Vlib/tin.c
--- grass/trunk/lib/vector/Vlib/tin.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/tin.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file tin.c
+ \file lib/vector/Vlib/tin.c
\brief Vector library - TIN
Modified: grass/trunk/lib/vector/Vlib/type.c
--- grass/trunk/lib/vector/Vlib/type.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/type.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file type.c
+ \file lib/vector/Vlib/type.c
\brief Vector library - feature type
Modified: grass/trunk/lib/vector/Vlib/window.c
--- grass/trunk/lib/vector/Vlib/window.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/window.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file window.c
+ \file lib/vector/Vlib/window.c
\brief Vector library - window/region
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2010-12-25 16:11:50 UTC (rev 44719)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2010-12-25 16:21:28 UTC (rev 44720)
@@ -1,5 +1,5 @@
- \file vector/Vlib/write_ogr.c
+ \file lib/vector/Vlib/write_ogr.c
\brief Vector library - write vector feature (OGR format)
