[GRASS-SVN] r44722 - in grass/trunk: include include/vect
lib/vector/Vlib
svn_grass at osgeo.org
Sat Dec 25 15:43:32 EST 2010
Author: martinl
Date: 2010-12-25 12:43:32 -0800 (Sat, 25 Dec 2010)
New Revision: 44722
grass/trunk/include/vect/dig_structs.h
grass/trunk/include/vector.h
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/build_ogr.c
grass/trunk/lib/vector/Vlib/header.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/open_ogr.c
grass/trunk/lib/vector/Vlib/write_ogr.c
vlib: introduce Vect_get_ogr_geometry_type() and V2_open_new_ogr()
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/include/vect/dig_structs.h 2010-12-25 20:43:32 UTC (rev 44722)
@@ -179,7 +179,10 @@
void *ds;
void *layer;
#endif
+ char **dsn_options;
+ char **layer_options;
/* Level 1 (used by V*_read_next_line_ogr) */
struct line_pnts **lines; /* points cache */
int *lines_types; /* list of line types */
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/include/vector.h 2010-12-25 20:43:32 UTC (rev 44722)
@@ -164,6 +164,7 @@
const char *Vect_get_ogr_dsn_name(const struct Map_info *);
const char *Vect_get_ogr_layer_name(const struct Map_info *);
const char *Vect_get_ogr_format_info(const struct Map_info *);
+const char *Vect_get_ogr_geometry_type(const struct Map_info *);
int Vect_is_3d(const struct Map_info *);
int Vect_set_organization(struct Map_info *, const char *);
const char *Vect_get_organization(const struct Map_info *);
@@ -456,6 +457,7 @@
int V2_open_old_ogr(struct Map_info *);
int V1_open_new_nat(struct Map_info *, const char *, int);
int V1_open_new_ogr(struct Map_info *, const char *, int);
+int V2_open_new_ogr(struct Map_info *, int);
int V1_rewind_nat(struct Map_info *);
int V1_rewind_ogr(struct Map_info *);
int V2_rewind_nat(struct Map_info *);
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/lib/vector/Vlib/build.c 2010-12-25 20:43:32 UTC (rev 44722)
@@ -124,10 +124,6 @@
plus = &(Map->plus);
if (build > GV_BUILD_NONE) {
- if (Vect_maptype(Map) != GV_FORMAT_NATIVE)
- G_message(_("Using external data format '%s'"),
- Vect_get_ogr_format_info(Map));
G_message(_("Building topology for vector map <%s>..."),
Vect_get_full_name(Map));
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c 2010-12-25 20:43:32 UTC (rev 44722)
@@ -15,7 +15,7 @@
(C) 2001-2010 by the GRASS Development Team
This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
+ (>=v2). Read the file COPYING that comes with GRASS for details.
\author Radim Blazek, Piero Cavalieri
\author Various updates for GRASS 7 by Martin Landa <landa.martin gmail.com>
@@ -371,6 +371,10 @@
return 0;
+ G_message(_("Using external data format '%s' (feature type '%s')"),
+ Vect_get_ogr_format_info(Map),
+ Vect_get_ogr_geometry_type(Map));
/* initialize data structures */
init_parts(&parts);
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/lib/vector/Vlib/header.c 2010-12-25 20:43:32 UTC (rev 44722)
@@ -5,13 +5,14 @@
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009 by the GRASS Development Team
+ (C) 2001-2010 by the GRASS Development Team
\author Original author CERL, probably Dave Gerdes or Mike Higgins.
\author Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ \author Update to GRASS 7 (OGR support) by Martin Landa <landa.martin gmail.com>
#include <grass/config.h>
@@ -24,12 +25,12 @@
static int lookup(const char *file, const char *key, char *value, size_t len);
- \brief Print vector map header
+ \brief Print vector map header to stdout
- \param Map vector map
+ \param Map pointer to Map_info structure
\return 0 on success
int Vect_print_header(const struct Map_info *Map)
fprintf(stdout, "\nSelected information from dig header\n");
@@ -41,28 +42,26 @@
return 0;
\brief Read vector map header from map head file
+ \param Map pointrt to Map_info structure
\return 0
int Vect_read_header(struct Map_info *Map)
Vect__read_head(Map);
return 0;
\brief Write vector map header to map head file
\return 0
int Vect_write_header(const struct Map_info *Map)
/* do some sanity checking here */
@@ -70,11 +69,10 @@
return 0;
- \brief Writes head information to text file.
+ \brief Writes head information to text file (GV_HEAD_ELEMENT)
\return -1 on error
@@ -90,7 +88,7 @@
if (head_fp == NULL) {
G_warning(_("Unable to open header file of vector <%s>"),
- return (-1);
+ return -1;
fprintf(head_fp, "ORGANIZATION: %s\n", Vect_get_organization(Map));
@@ -108,7 +106,7 @@
- \brief Reads head information from text file (GV_HEAD_ELEMENT).
+ \brief Reads head information from text file (GV_HEAD_ELEMENT) - for internal use only
@@ -138,7 +136,7 @@
- return (-1);
+ return -1;
while (G_getl2(buff, 2000, head_fp)) {
@@ -180,39 +178,40 @@
else if (strncmp(buff, "MAP THRESH:", sizeof(char) * 11) == 0)
Vect_set_thresh(Map, atof(ptr));
else
- G_warning(_("Unknown keyword %s in vector head"), buff);
+ G_warning(_("Unknown keyword '%s' in vector head"), buff);
fclose(head_fp);
- return (0);
+ return 0;
- \brief Get map name
+ \brief Get name of vector map
- \return poiter to map name
+ \return string containing name
const char *Vect_get_name(const struct Map_info *Map)
- return (Map->name);
+ return Map->name;
- \brief Get mapset name
+ \brief Get name of mapset where vector map lives
- \return poiter to mapset name
+ \return string containing mapset name
const char *Vect_get_mapset(const struct Map_info *Map)
- return (Map->mapset);
+ return Map->mapset;
- \brief Get full vector map name
+ \brief Get fully qualified name of vector map
- for GV_FORMAT_NATIVE and GV_FORMAT_OGR returns "map at mapset"
- for GV_FORMAT_OGR_DIRECT returns "layer at datasourse"
@@ -221,7 +220,7 @@
- \return pointer to map name (name at mapset)
+ \return allocated string "name at mapset"
const char *Vect_get_full_name(const struct Map_info *Map)
@@ -254,11 +253,11 @@
- \return poiter to string with OGR datasource name
+ \return string containing OGR datasource name
const char *Vect_get_ogr_dsn_name(const struct Map_info *Map)
- return (Map->fInfo.ogr.dsn);
+ return Map->fInfo.ogr.dsn;
@@ -266,20 +265,22 @@
- \return poiter to string with OGR layer name
+ \return string containing OGR layer name
const char *Vect_get_ogr_layer_name(const struct Map_info *Map)
- return (Map->fInfo.ogr.layer_name);
+ return Map->fInfo.ogr.layer_name;
\brief Get OGR format info (relevant only for OGR format)
+ Allocated space should be freed by G_free().
- \return poiter to string with OGR format info (allocated by G_store())
- \return NULL on error
+ \return string containing name of OGR format (allocated by G_store())
+ \return NULL on error (or on missing OGR support)
const char *Vect_get_ogr_format_info(const struct Map_info *Map)
@@ -291,28 +292,61 @@
#endif
return NULL;
- \brief Check if vector map is 3D (with z)
+ \brief Get OGR geometry type (relevant only for OGR format)
- \return 1 map is 3D
- \return 0 map is not 3D
+ \return allocated string containing geometry type info
+const char *Vect_get_ogr_geometry_type(const struct Map_info *Map)
+#ifdef HAVE_OGR
+ OGRwkbGeometryType Ogr_geom_type;
+ OGRFeatureDefnH Ogr_feature_defn;
+ if (!Map->fInfo.ogr.layer)
+ return NULL;
+ Ogr_feature_defn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
+ Ogr_geom_type = OGR_FD_GetGeomType(Ogr_feature_defn);
+ switch(Ogr_geom_type) {
+ case wkbPoint:
+ return G_store(_("point"));
+ case wkbLineString:
+ return G_store(_("linestring"));
+ case wkbPolygon:
+ return G_store(_("polygon"));
+ default:
+ return G_store(_("unknown"));
+#endif
+ return NULL;
+ \brief Check if vector map is 3D
+ \return TRUE vector map is 3D
+ \return FALSE vector map is not 3D
int Vect_is_3d(const struct Map_info *Map)
- return (Map->head.with_z);
+ return Map->head.with_z;
\brief Set organization string in map header
\param str organization name
\return 0
int Vect_set_organization(struct Map_info *Map, const char *str)
G_free(Map->head.organization);
@@ -324,26 +358,26 @@
\brief Get organization string from map header
- \return organization string
+ \return string containing organization name
const char *Vect_get_organization(const struct Map_info *Map)
- return (Map->head.organization);
+ return Map->head.organization;
- \brief Set date of digitization string in map header
+ \brief Set date of digitization in map header
- SUGGESTION: this should be coupled to DateTime functions to support
+ \todo This should be coupled to DateTime functions to support
time series
- \param str data string
+ \param str date given as string
\return 0
int Vect_set_date(struct Map_info *Map, const char *str)
G_free(Map->head.date);
@@ -353,13 +387,10 @@
- \brief Get date of digitization string from map header
+ \brief Get date of digitization from map header
- time series
\return date of digitization string
const char *Vect_get_date(const struct Map_info *Map)
@@ -368,13 +399,13 @@
- \brief Set user name string who digitized the map in map header
+ \brief Set name of user who digitized the map in map header
- \param str user name string
+ \param str user name
- \return 0 on success
+ \return 0
int Vect_set_person(struct Map_info *Map, const char *str)
G_free(Map->head.your_name);
@@ -386,22 +417,22 @@
\brief Get user name string who digitized the map from map header
- \return user name string
+ \return string containing user name
const char *Vect_get_person(const struct Map_info *Map)
- return (Map->head.your_name);
+ return Map->head.your_name;
- \brief Set map name string in map header
+ \brief Set map name in map header
- \param str map name string
+ \param str map name to be set
+ \return 0
int Vect_set_map_name(struct Map_info *Map, const char *str)
@@ -412,24 +443,24 @@
- \brief Get map name string in map header
+ \brief Get map name from map header
- \return map name string
+ \return string containing map name
const char *Vect_get_map_name(const struct Map_info *Map)
- return (Map->head.map_name);
+ return Map->head.map_name;
- \brief Set date string when the source map was originally produced in map header
+ \brief Set date when the source map was originally produced in map header
- \param str date when the source map was originally produced string
+ \param str date given as a string
+ \return 0
int Vect_set_map_date(struct Map_info *Map, const char *str)
@@ -440,24 +471,24 @@
- \brief Get date string when the source map was originally produced in map header
+ \brief Get date when the source map was originally produced from map header
- \return date when the source map was originally produced string
+ \return string containg a date
const char *Vect_get_map_date(const struct Map_info *Map)
- return (Map->head.source_date);
+ return Map->head.source_date;
\brief Set map scale in map header
- \param map scale
+ \param scale map scale
+ \return 0
int Vect_set_scale(struct Map_info *Map, int scale)
@@ -469,22 +500,22 @@
\brief Get map scale from map header
\return map scale
int Vect_get_scale(const struct Map_info *Map)
- return ((int) Map->head.orig_scale);
+ return (int) Map->head.orig_scale;
\brief Set comment or other info string in map header
\param str comment or other info string
+ \return 0
int Vect_set_comment(struct Map_info *Map, const char *str)
@@ -497,22 +528,22 @@
\brief Get comment or other info string from map header
\return comment or other info string
const char *Vect_get_comment(const struct Map_info *Map)
- return (Map->head.line_3);
+ return Map->head.line_3;
\brief Set projection zone in map header
\param zone projection zone
+ \return 0
int Vect_set_zone(struct Map_info *Map, int zone)
@@ -524,26 +555,28 @@
\brief Get projection zone from map header
\return projection zone
int Vect_get_zone(const struct Map_info *Map)
- return (Map->head.plani_zone);
+ return Map->head.plani_zone;
\brief Set projection in map header
+ Supported projections:
+ - PROJECTION_XY 0 - x,y (Raw imagery),
+ - PROJECTION_UTM 1 - UTM Universal Transverse Mercator,
+ - PROJECTION_SP 2 - State Plane (in feet),
+ - PROJECTION_LL 3 - Latitude-Longitude
+ \param proj projection code
+ \return 0
int Vect_set_proj(struct Map_info *Map, int proj)
@@ -555,28 +588,27 @@
\brief Get projection from map header
\return PROJECTION_XY 0 - x,y (Raw imagery),
\return PROJECTION_UTM 1 - UTM Universal Transverse Mercator,
\return PROJECTION_SP 2 - State Plane (in feet),
\return PROJECTION_LL 3 - Latitude-Longitude
int Vect_get_proj(const struct Map_info *Map)
- return (Map->proj);
+ return Map->proj;
- \brief Query cartographic projection name of vector map
+ \brief Query cartographic projection name of pointer to Map_info structure
Returns a pointer to a string which is a printable name for
- projection code <em>proj</em> (as returned by
- Vect_get_proj()).
+ projection code <em>proj</em> (as returned by Vect_get_proj()).
- \return poiter to projection name
+ \return allocated string containing projection name
\return NULL if <em>proj</em> is not a valid projection
@@ -601,29 +633,29 @@
\brief Set threshold used for digitization in map header
\param thresh threshold used for digitization
+ \return 0
int Vect_set_thresh(struct Map_info *Map, double thresh)
G_debug(1, "Vect_set_thresh(): thresh = %f", thresh);
Map->head.digit_thresh = thresh;
- return (0);
+ return 0;
\brief Get threshold used for digitization from map header
\return threshold used for digitization
double Vect_get_thresh(const struct Map_info *Map)
G_debug(1, "Vect_get_thresh(): thresh = %f", Map->head.digit_thresh);
- return (Map->head.digit_thresh);
+ return Map->head.digit_thresh;
@@ -633,5 +665,5 @@
char path[GPATH_MAX];
G__file_name(path, "", file, "PERMANENT");
- return G_lookup_key_value_from_file(path, key, value, (int)len) == 1;
+ return G_lookup_key_value_from_file(path, key, value, (int) len) == 1;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/lib/vector/Vlib/open.c 2010-12-25 20:43:32 UTC (rev 44722)
@@ -723,6 +723,7 @@
struct Key_Value *key_val;
const char *p;
+ G_debug(2, " using OGR format");
Map->format = GV_FORMAT_OGR_DIRECT;
fp = G_fopen_old("", "OGR", G_mapset());
if (!fp) {
@@ -742,6 +743,7 @@
else {
/* native */
+ G_debug(2, " using native format");
Map->format = GV_FORMAT_NATIVE;
/* check if map already exists */
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-25 20:43:32 UTC (rev 44722)
@@ -202,11 +202,13 @@
- \brief Create new OGR layer in given OGR datasource (level 1)
+ \brief Prepare OGR datasource for creating new OGR layer (level 1)
+ New OGR layer can be created by V2_open_new_ogr().
\param[out] Map pointer to Map_info structure
\param name name of OGR layer to create
- \param with_z 2D or 3D (unused?)
+ \param with_z WITH_Z for 3D vector data otherwise WITHOUT_Z
\return 0 success
\return -1 error
@@ -217,11 +219,7 @@
OGRDataSourceH Ogr_ds;
OGRLayerH Ogr_layer;
OGRFeatureDefnH Ogr_featuredefn;
- OGRSpatialReferenceH Ogr_spatial_ref;
- struct Key_Value *projinfo, *projunits;
int i, nlayers;
char **Ogr_layer_options;
@@ -249,7 +247,7 @@
for (i = 0; i < nlayers; i++) {
Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
- if (strcmp(OGR_FD_GetName(Ogr_featuredefn), Map->fInfo.ogr.layer_name) == 0) {
+ if (strcmp(OGR_FD_GetName(Ogr_featuredefn), name) == 0) {
if (G_get_overwrite()) {
G_warning(_("OGR layer <%s> already exists and will be overwritten"),
@@ -264,17 +262,73 @@
G_fatal_error(_("OGR layer <%s> already exists in datasource '%s'"),
Map->fInfo.ogr.layer_name, Map->fInfo.ogr.dsn);
+ Map->fInfo.ogr.layer = NULL;
break;
- /* create new OGR layer */
- projinfo = G_get_projinfo();
+ return 0;
+ \brief Create new OGR layer in given OGR datasource (level 2)
+ V1_open_new_ogr() is required to be called before this function.
+ \param[in,out] Map pointer to Map_info structure
+ \param type feature type (GV_POINT, GV_LINE, ...)
+ \return 0 success
+ \return -1 error
+int V2_open_new_ogr(struct Map_info *Map, int type)
+ OGRLayerH Ogr_layer;
+ OGRSpatialReferenceH Ogr_spatial_ref;
+ struct Key_Value *projinfo, *projunits;
+ char **Ogr_layer_options;
+ if (!Map->fInfo.ogr.driver_name ||
+ !Map->fInfo.ogr.layer_name ||
+ !Map->fInfo.ogr.ds)
+ return -1;
+ /* get spatial reference */
+ projinfo = G_get_projinfo();
projunits = G_get_projunits();
Ogr_spatial_ref = GPJ_grass_to_osr(projinfo, projunits);
- /* Ogr_layer_options = CSLSetNameValue(Ogr_layer_options, "OVERWRITE", "YES"); */
- Ogr_layer = OGR_DS_CreateLayer(Ogr_ds, Map->fInfo.ogr.layer_name,
- Ogr_spatial_ref, wkbPoint, Ogr_layer_options);
+ switch(type) {
+ case GV_POINT:
+ Ogr_geom_type = wkbPoint;
+ break;
+ case GV_LINE:
+ Ogr_geom_type = wkbLineString;
+ break;
+ case GV_AREA:
+ Ogr_geom_type = wkbPolygon;
+ break;
+ default:
+ G_warning(_("Unsupported geometry type (%d)"), type);
+ return -1;
+ Ogr_layer_options = Map->fInfo.ogr.layer_options;
+ if (Vect_is_3d(Map)) {
+ if (strcmp(Map->fInfo.ogr.driver_name, "PostgreSQL") == 0) {
+ Ogr_layer_options = CSLSetNameValue(Ogr_layer_options, "DIM", "3");
+ else {
+ Ogr_layer_options = CSLSetNameValue(Ogr_layer_options, "DIM", "2");
+ Ogr_layer = OGR_DS_CreateLayer(Map->fInfo.ogr.ds, Map->fInfo.ogr.layer_name,
+ Ogr_spatial_ref, Ogr_geom_type, Ogr_layer_options);
CSLDestroy(Ogr_layer_options);
if (!Ogr_layer) {
G_warning(_("Unable to create OGR layer <%s> in '%s'"),
@@ -282,7 +336,7 @@
return -1;
Map->fInfo.ogr.layer = Ogr_layer;
return 0;
#endif
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2010-12-25 16:25:52 UTC (rev 44721)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2010-12-25 20:43:32 UTC (rev 44722)
@@ -66,8 +66,8 @@
if (!Map->fInfo.ogr.layer) {
- G_warning(_("OGR layer not defined"));
- return -1;
+ if (V2_open_new_ogr(Map, type) < 0)
+ return -1;
Ogr_featuredefn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
