[GRASS-SVN] r44727 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Dec 26 07:22:26 EST 2010
Author: martinl
Date: 2010-12-26 04:22:26 -0800 (Sun, 26 Dec 2010)
New Revision: 44727
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
wxGUI/GSelect: filtering items in progress, see #1251
patch by Anna Kratochvilova
(merge r44725 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-12-26 12:16:45 UTC (rev 44726)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-12-26 12:22:26 UTC (rev 44727)
@@ -186,6 +186,7 @@
self.filterElements = filter
def _startsWith(self, text):
+ """!Filter items - currently unused"""
return True if text.startswith(self.GetCombo().GetValue()) else False
def OnPopup(self, force = False):
@@ -197,14 +198,22 @@
else:
selected = None
exclude = False
- text = self.GetCombo().GetValue().strip()
- if grass.find_file(name = text, element = self.type)['fullname']:
- self.SetFilter(None)
- else:
- self.SetFilter(self._startsWith)
self.GetElementList(selected, exclude)
+ # selects map starting according to written text
+ inputText = self.GetCombo().GetValue().strip()
+ if inputText:
+ root = self.seltree.GetRootItem()
+ match = self.FindItem(root, inputText, startLetters = True)
+ if wx.TreeItemId.IsOk(self.seltree.GetPrevSibling(match)):
+ match = self.seltree.GetPrevSibling(match)
+ else:
+ match = self.seltree.GetItemParent(match)
+ self.seltree.EnsureVisible(match)
+ self.seltree.SelectItem(match)
def GetElementList(self, elements = None, exclude = False):
"""!Get filtered list of GIS elements in accessible mapsets
and display as tree with all relevant elements displayed
@@ -371,17 +380,22 @@
self.seltree.SelectItem(first_dir)
# helpers
- def FindItem(self, parentItem, text):
+ def FindItem(self, parentItem, text, startLetters = False):
+ """!Finds item with given name or starting with given text"""
+ startletters = startLetters
item, cookie = self.seltree.GetFirstChild(parentItem)
- while item:
+ while wx.TreeItemId.IsOk(item):
if self.seltree.GetItemText(item) == text:
return item
if self.seltree.ItemHasChildren(item):
- item = self.FindItem(item, text)
+ item = self.FindItem(item, text, startLetters = startletters)
+ if wx.TreeItemId.IsOk(item):
+ return item
+ elif startletters and self.seltree.GetItemText(item).startswith(text.split('@')[0]):
+ return item
item, cookie = self.seltree.GetNextChild(parentItem, cookie)
return wx.TreeItemId()
def AddItem(self, value, parent=None):
if not parent:
@@ -411,6 +425,21 @@
if item == self.seltree.GetFirstChild(self.seltree.GetRootItem())[0]:
itemPrev = item
self.seltree.SelectItem(itemPrev)
+ # selects first item starting with the written text in next mapset
+ elif event.GetKeyCode() == wx.WXK_TAB:
+ selected = self.seltree.GetSelection()
+ if self.seltree.ItemHasChildren(selected):
+ parent = selected
+ else:
+ parent = self.seltree.GetItemParent(selected)
+ nextSibling = self.seltree.GetNextSibling(parent)
+ if wx.TreeItemId.IsOk(nextSibling):
+ match = self.FindItem(nextSibling, self.GetCombo().GetValue().strip(), True)
+ else:
+ match = self.FindItem(self.seltree.GetFirstChild(self.seltree.GetItemParent(parent))[0],
+ self.GetCombo().GetValue().strip(), True)
elif event.GetKeyCode() == wx.WXK_RIGHT:
