[GRASS-SVN] r44730 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Dec 26 08:52:15 EST 2010
Author: martinl
Date: 2010-12-26 05:52:15 -0800 (Sun, 26 Dec 2010)
New Revision: 44730
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
wxGUI: print warning when map is not found
(merge r44728 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-12-26 13:50:45 UTC (rev 44729)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-12-26 13:52:15 UTC (rev 44730)
@@ -47,7 +47,7 @@
from icon import Icons as Icons
from preferences import globalSettings as UserSettings
from vdigit import haveVDigit
-from gcmd import GError
+from gcmd import GWarning
try:
import subprocess
except:
@@ -1329,13 +1329,19 @@
# set layer text to map name
if dcmd:
self.GetPyData(layer)[0]['cmd'] = dcmd
- mapname = self._getLayerName(layer)
- if not mapname:
- GError(parent = self,
- message = _("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd))
+ mapText = self._getLayerName(layer)
+ mapName = utils.GetLayerNameFromCmd(dcmd)
+ mapLayer = self.GetPyData(layer)[0]['maplayer']
+ self.SetItemText(layer, mapName)
+ if not mapText or \
+ (mapLayer and \
+ not grass.find_file(name = mapName, element = mapLayer.GetType())['fullname']):
+ propwin.Hide()
+ GWarning(parent = self,
+ message = _("Map <%s> not found.") % mapName)
return
- self.SetItemText(layer, mapname)
# update layer data
if params:
self.SetPyData(layer, (self.GetPyData(layer)[0], params))
@@ -1351,9 +1357,9 @@
render = UserSettings.Get(group = 'display', key = 'autoRendering', subkey = 'enabled')
self.mapdisplay.MapWindow.ZoomToMap(layers = [mapLayer,],
render = render)
+ # update nviz session
if self.mapdisplay.toolbars['nviz'] and dcmd:
- # update nviz session
mapWin = self.mapdisplay.MapWindow
if len(mapLayer.GetCmd()) > 0:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-12-26 13:50:45 UTC (rev 44729)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-12-26 13:52:15 UTC (rev 44730)
@@ -75,7 +75,7 @@
def GetLayerNameFromCmd(dcmd, fullyQualified = False, param = None,
layerType = None):
"""!Get map name from GRASS command
@param dcmd GRASS command (given as list)
@param fullyQualified change map name to be fully qualified
@param force parameter otherwise 'input'/'map'
@@ -131,12 +131,10 @@
findType = 'cell'
else:
findType = layerType
- result = grass.find_file(mapname, element=findType)
+ mapset = grass.find_file(mapname, element=findType)['mapset']
except AttributeError, e: # not found
return ''
- if result:
- mapset = result['mapset']
- else:
+ if not mapset:
mapset = grass.gisenv()['MAPSET']
else:
