[GRASS-SVN] r44746 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Tue Dec 28 17:08:38 EST 2010
Author: martinl
Date: 2010-12-28 14:08:38 -0800 (Tue, 28 Dec 2010)
New Revision: 44746
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: popup-menu clean up
(merge r44744 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-12-28 22:07:17 UTC (rev 44745)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-12-28 22:08:38 UTC (rev 44746)
@@ -1777,7 +1777,6 @@
self.workspaceOpen = wx.NewId()
self.workspaceSave = wx.NewId()
self.addrast = wx.NewId()
- self.addrast3d = wx.NewId()
self.addshaded = wx.NewId()
self.addvect = wx.NewId()
self.addthematic = wx.NewId()
@@ -1807,9 +1806,6 @@
(self.addrast, 'addrast', Icons["addrast"].GetBitmap(),
wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
self.parent.OnAddRaster),
- (self.addrast3d, 'addrast3d', Icons["addrast3d"].GetBitmap(),
- wx.ITEM_NORMAL, Icons["addrast3d"].GetLabel(), Icons["addrast3d"].GetDesc(),
- self.parent.OnAddRaster3D),
(self.addshaded, 'addshaded', Icons["addshaded"].GetBitmap(),
wx.ITEM_NORMAL, _("Add various raster-based map layers"), "",
self.parent.OnAddRasterMisc),
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-12-28 22:07:17 UTC (rev 44745)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-12-28 22:08:38 UTC (rev 44746)
@@ -36,7 +36,7 @@
### i18N
import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
import gui_modules
sys.path.append(gui_modules.__path__[0])
@@ -150,8 +150,8 @@
wx.CallAfter(self.notebook.SetSelection, 0)
# use default window layout ?
- if UserSettings.Get(group='general', key='defWindowPos', subkey='enabled'):
- dim = UserSettings.Get(group='general', key='defWindowPos', subkey='dim')
+ if UserSettings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled'):
+ dim = UserSettings.Get(group = 'general', key = 'defWindowPos', subkey = 'dim')
try:
x, y = map(int, dim.split(',')[0:2])
w, h = map(int, dim.split(',')[2:4])
@@ -174,7 +174,7 @@
self.workspaceFile = None
else:
# start default initial display
- self.NewDisplay(show=False)
+ self.NewDisplay(show = False)
# show map display widnow
# -> OnSize() -> UpdateMap()
@@ -196,22 +196,22 @@
def __createNoteBook(self):
"""!Creates notebook widgets"""
if globalvar.hasAgw:
- self.notebook = FN.FlatNotebook(parent=self, id=wx.ID_ANY, agwStyle = globalvar.FNPageDStyle)
+ self.notebook = FN.FlatNotebook(parent = self, id = wx.ID_ANY, agwStyle = globalvar.FNPageDStyle)
else:
- self.notebook = FN.FlatNotebook(parent=self, id=wx.ID_ANY, style = globalvar.FNPageDStyle)
+ self.notebook = FN.FlatNotebook(parent = self, id = wx.ID_ANY, style = globalvar.FNPageDStyle)
# create displays notebook widget and add it to main notebook page
cbStyle = globalvar.FNPageStyle
- self.gm_cb = FN.FlatNotebook(self, id=wx.ID_ANY, agwStyle = cbStyle)
+ self.gm_cb = FN.FlatNotebook(self, id = wx.ID_ANY, agwStyle = cbStyle)
else:
- self.gm_cb = FN.FlatNotebook(self, id=wx.ID_ANY, style = cbStyle)
+ self.gm_cb = FN.FlatNotebook(self, id = wx.ID_ANY, style = cbStyle)
self.gm_cb.SetTabAreaColour(globalvar.FNPageColor)
- self.notebook.AddPage(self.gm_cb, text=_("Map layers"))
+ self.notebook.AddPage(self.gm_cb, text = _("Map layers"))
# create command output text area and add it to main notebook page
- self.goutput = goutput.GMConsole(self, pageid=1)
- self.notebook.AddPage(self.goutput, text=_("Command console"))
+ self.goutput = goutput.GMConsole(self, pageid = 1)
+ self.notebook.AddPage(self.goutput, text = _("Command console"))
# create 'search module' notebook page
self.search = MenuTreeWindow(parent = self)
@@ -339,7 +339,7 @@
"""!Page of notebook closed
Also close associated map display
- if UserSettings.Get(group='manager', key='askOnQuit', subkey='enabled'):
+ if UserSettings.Get(group = 'manager', key = 'askOnQuit', subkey = 'enabled'):
maptree = self.curr_page.maptree
if self.workspaceFile:
@@ -351,9 +351,9 @@
# ask user to save current settings
if maptree.GetCount() > 0:
dlg = wx.MessageDialog(self,
- message=message,
- caption=_("Close Map Display %d") % (self.curr_pagenum + 1),
- style=wx.YES_NO | wx.YES_DEFAULT |
+ message = message,
+ caption = _("Close Map Display %d") % (self.curr_pagenum + 1),
+ style = wx.YES_NO | wx.YES_DEFAULT |
wx.CANCEL | wx.ICON_QUESTION | wx.CENTRE)
ret = dlg.ShowModal()
if ret == wx.ID_YES:
@@ -421,7 +421,7 @@
"""!Run command selected from menu"""
if event:
cmd = self.GetMenuCmd(event)
- self.goutput.RunCmd(cmd, switchPage=False)
+ self.goutput.RunCmd(cmd, switchPage = False)
def OnMenuCmd(self, event, cmd = ''):
"""!Parse command selected from menu"""
@@ -502,11 +502,11 @@
if name and add:
# add layer to map layer tree
- self.curr_page.maptree.AddLayer(ltype='vector',
- lname=name,
- lchecked=True,
- lopacity=1.0,
- lcmd=['d.vect', 'map=%s' % name])
+ self.curr_page.maptree.AddLayer(ltype = 'vector',
+ lname = name,
+ lchecked = True,
+ lopacity = 1.0,
+ lcmd = ['d.vect', 'map=%s' % name])
def OnAboutGRASS(self, event):
"""!Display 'About GRASS' dialog"""
@@ -551,11 +551,11 @@
if self.workspaceFile and self.workspaceChanged:
self.OnWorkspaceSave()
elif self.workspaceFile is None and maptree.GetCount() > 0:
- dlg = wx.MessageDialog(self, message=_("Current workspace is not empty. "
+ dlg = wx.MessageDialog(self, message = _("Current workspace is not empty. "
"Do you want to store current settings "
"to workspace file?"),
- caption=_("Create new workspace?"),
- style=wx.YES_NO | wx.YES_DEFAULT | \
+ caption = _("Create new workspace?"),
+ style = wx.YES_NO | wx.YES_DEFAULT | \
wx.CANCEL | wx.ICON_QUESTION)
@@ -578,10 +578,10 @@
self.workspaceChanged = False
self.SetTitle(self.baseTitle)
- def OnWorkspaceOpen(self, event=None):
+ def OnWorkspaceOpen(self, event = None):
"""!Open file with workspace definition"""
- dlg = wx.FileDialog(parent=self, message=_("Choose workspace file"),
- defaultDir=os.getcwd(), wildcard=_("GRASS Workspace File (*.gxw)|*.gxw"))
+ dlg = wx.FileDialog(parent = self, message = _("Choose workspace file"),
+ defaultDir = os.getcwd(), wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"))
filename = ''
if dlg.ShowModal() == wx.ID_OK:
@@ -620,14 +620,14 @@
"Invalid file, unable to parse XML document.") % filename)
return
- busy = wx.BusyInfo(message=_("Please wait, loading workspace..."),
- parent=self)
+ busy = wx.BusyInfo(message = _("Please wait, loading workspace..."),
+ parent = self)
wx.Yield()
# load layer manager window properties
- if UserSettings.Get(group='workspace', key='posManager', subkey='enabled') is False:
+ if UserSettings.Get(group = 'workspace', key = 'posManager', subkey = 'enabled') is False:
if gxwXml.layerManager['pos']:
self.SetPosition(gxwXml.layerManager['pos'])
if gxwXml.layerManager['size']:
@@ -639,16 +639,16 @@
displayId = 0
mapdisplay = list()
for display in gxwXml.displays:
- mapdisp = self.NewDisplay(show=False)
+ mapdisp = self.NewDisplay(show = False)
mapdisplay.append(mapdisp)
maptree = self.gm_cb.GetPage(displayId).maptree
# set windows properties
- mapdisp.SetProperties(render=display['render'],
- mode=display['mode'],
- showCompExtent=display['showCompExtent'],
- constrainRes=display['constrainRes'],
- projection=display['projection']['enabled'])
+ mapdisp.SetProperties(render = display['render'],
+ mode = display['mode'],
+ showCompExtent = display['showCompExtent'],
+ constrainRes = display['constrainRes'],
+ projection = display['projection']['enabled'])
if display['projection']['enabled']:
if display['projection']['epsg']:
@@ -659,7 +659,7 @@
value = display['projection']['proj'])
# set position and size of map display
- if UserSettings.Get(group='workspace', key='posDisplay', subkey='enabled') is False:
+ if UserSettings.Get(group = 'workspace', key = 'posDisplay', subkey = 'enabled') is False:
if display['pos']:
mapdisp.SetPosition(display['pos'])
if display['size']:
@@ -668,7 +668,7 @@
# set extent if defined
if display['extent']:
w, s, e, n = display['extent']
- region = maptree.Map.region = maptree.Map.GetRegion(w=w, s=s, e=e, n=n)
+ region = maptree.Map.region = maptree.Map.GetRegion(w = w, s = s, e = e, n = n)
mapdisp.GetWindow().ResetZoomHistory()
mapdisp.GetWindow().ZoomHistory(region['n'],
region['s'],
@@ -688,24 +688,24 @@
display = layer['display']
maptree = self.gm_cb.GetPage(display).maptree
- newItem = maptree.AddLayer(ltype=layer['type'],
- lname=layer['name'],
- lchecked=layer['checked'],
- lopacity=layer['opacity'],
- lcmd=layer['cmd'],
- lgroup=layer['group'],
- lnviz=layer['nviz'],
- lvdigit=layer['vdigit'])
+ newItem = maptree.AddLayer(ltype = layer['type'],
+ lname = layer['name'],
+ lchecked = layer['checked'],
+ lopacity = layer['opacity'],
+ lcmd = layer['cmd'],
+ lgroup = layer['group'],
+ lnviz = layer['nviz'],
+ lvdigit = layer['vdigit'])
if layer.has_key('selected'):
if layer['selected']:
selected.append((maptree, newItem))
else:
- maptree.SelectItem(newItem, select=False)
+ maptree.SelectItem(newItem, select = False)
for maptree, layer in selected:
if not maptree.IsSelected(layer):
- maptree.SelectItem(layer, select=True)
+ maptree.SelectItem(layer, select = True)
maptree.layer_selected = layer
busy.Destroy()
@@ -719,9 +719,9 @@
return True
- def OnWorkspaceLoad(self, event=None):
+ def OnWorkspaceLoad(self, event = None):
"""!Load given map layers into layer tree"""
- dialog = gdialogs.LoadMapLayersDialog(parent=self, title=_("Load map layers into layer tree"))
+ dialog = gdialogs.LoadMapLayersDialog(parent = self, title = _("Load map layers into layer tree"))
if dialog.ShowModal() == wx.ID_OK:
# start new map display if no display is available
@@ -729,8 +729,8 @@
self.NewDisplay()
- parent=self)
+ parent = self)
wx.Yield()
for layerName in dialog.GetMapLayers():
@@ -738,19 +738,19 @@
cmd = ['d.rast', 'map=%s' % layerName]
elif dialog.GetLayerType() == 'vector':
cmd = ['d.vect', 'map=%s' % layerName]
- newItem = maptree.AddLayer(ltype=dialog.GetLayerType(),
- lname=layerName,
- lchecked=False,
- lopacity=1.0,
- lcmd=cmd,
- lgroup=None)
+ newItem = maptree.AddLayer(ltype = dialog.GetLayerType(),
+ lname = layerName,
+ lchecked = False,
+ lopacity = 1.0,
+ lcmd = cmd,
+ lgroup = None)
busy.Destroy()
def OnWorkspaceLoadGrcFile(self, event):
"""!Load map layers from GRC file (Tcl/Tk GUI) into map layer tree"""
- dlg = wx.FileDialog(parent=self, message=_("Choose GRC file to load"),
- defaultDir=os.getcwd(), wildcard=_("Old GRASS Workspace File (*.grc)|*.grc"))
+ dlg = wx.FileDialog(parent = self, message = _("Choose GRC file to load"),
+ defaultDir = os.getcwd(), wildcard = _("Old GRASS Workspace File (*.grc)|*.grc"))
filename = ''
@@ -765,19 +765,19 @@
if not self.curr_page:
self.NewDisplay()
- parent=self)
+ parent = self)
wx.Yield()
maptree = None
for layer in workspace.ProcessGrcFile(filename).read(self):
maptree = self.gm_cb.GetPage(layer['display']).maptree
- lgroup=layer['group'])
+ lgroup = layer['group'])
busy.Destroy()
@@ -785,10 +785,10 @@
# reverse list of map layers
maptree.Map.ReverseListOfLayers()
- def OnWorkspaceSaveAs(self, event=None):
+ def OnWorkspaceSaveAs(self, event = None):
"""!Save workspace definition to selected file"""
- dlg = wx.FileDialog(parent=self, message=_("Choose file to save current workspace"),
- defaultDir=os.getcwd(), wildcard=_("GRASS Workspace File (*.gxw)|*.gxw"), style=wx.FD_SAVE)
+ dlg = wx.FileDialog(parent = self, message = _("Choose file to save current workspace"),
+ defaultDir = os.getcwd(), wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"), style = wx.FD_SAVE)
filename = ''
@@ -802,9 +802,9 @@
filename += ".gxw"
if os.path.exists(filename):
- dlg = wx.MessageDialog(self, message=_("Workspace file <%s> already exists. "
+ dlg = wx.MessageDialog(self, message = _("Workspace file <%s> already exists. "
"Do you want to overwrite this file?") % filename,
- caption=_("Save workspace"), style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ caption = _("Save workspace"), style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlg.ShowModal() != wx.ID_YES:
dlg.Destroy()
return False
@@ -815,13 +815,13 @@
self.workspaceFile = filename
self.SetTitle(self.baseTitle + " - " + os.path.basename(self.workspaceFile))
- def OnWorkspaceSave(self, event=None):
+ def OnWorkspaceSave(self, event = None):
"""!Save file with workspace definition"""
"Do you want to overwrite this file?") % \
self.workspaceFile,
if dlg.ShowModal() == wx.ID_NO:
dlg.Destroy()
else:
@@ -837,7 +837,7 @@
Return True on success, False on error
- tmpfile = tempfile.TemporaryFile(mode='w+b')
+ tmpfile = tempfile.TemporaryFile(mode = 'w+b')
try:
workspace.WriteWorkspaceFile(lmgr = self, file = tmpfile)
except StandardError, e:
@@ -955,7 +955,7 @@
def OnPreferences(self, event):
"""!General GUI preferences/settings"""
if not self.dialogs['preferences']:
- dlg = preferences.PreferencesDialog(parent=self)
+ dlg = preferences.PreferencesDialog(parent = self)
self.dialogs['preferences'] = dlg
self.dialogs['preferences'].CenterOnScreen()
@@ -966,8 +966,8 @@
Init histogram display canvas and tools
self.histogram = histogram.HistFrame(self,
- id=wx.ID_ANY, pos=wx.DefaultPosition, size=(400,300),
- style=wx.DEFAULT_FRAME_STYLE)
+ id = wx.ID_ANY, pos = wx.DefaultPosition, size = (400,300),
+ style = wx.DEFAULT_FRAME_STYLE)
#show new display
self.histogram.Show()
@@ -979,8 +979,8 @@
Init profile canvas and tools
self.profile = profile.ProfileFrame(self,
self.profile.Show()
self.profile.Refresh()
self.profile.Update()
@@ -992,7 +992,7 @@
win = mapcalculator.MapCalcFrame(parent = self,
- cmd=cmd[0])
+ cmd = cmd[0])
win.CentreOnScreen()
win.Show()
@@ -1009,31 +1009,31 @@
def OnImportDxfFile(self, event):
"""!Convert multiple DXF layers to GRASS vector map layers"""
- dlg = gdialogs.DxfImportDialog(parent=self)
+ dlg = gdialogs.DxfImportDialog(parent = self)
dlg.CentreOnScreen()
dlg.ShowModal()
def OnImportGdalLayers(self, event):
"""!Convert multiple GDAL layers to GRASS raster map layers"""
- dlg = gdialogs.GdalImportDialog(parent=self)
+ dlg = gdialogs.GdalImportDialog(parent = self)
dlg.ShowModal()
def OnLinkGdalLayers(self, event):
"""!Link multiple GDAL layers to GRASS raster map layers"""
- dlg = gdialogs.GdalImportDialog(parent=self, link = True)
+ dlg = gdialogs.GdalImportDialog(parent = self, link = True)
dlg.ShowModal()
def OnImportOgrLayers(self, event):
"""!Convert multiple OGR layers to GRASS vector map layers"""
- dlg = gdialogs.GdalImportDialog(parent=self, ogr = True)
+ dlg = gdialogs.GdalImportDialog(parent = self, ogr = True)
dlg.ShowModal()
def OnLinkOgrLayers(self, event):
"""!Links multiple OGR layers to GRASS vector map layers"""
- dlg = gdialogs.GdalImportDialog(parent=self, ogr = True, link = True)
+ dlg = gdialogs.GdalImportDialog(parent = self, ogr = True, link = True)
dlg.ShowModal()
@@ -1088,11 +1088,11 @@
maptype = None
if not maptype or maptype != 'vector':
- wx.MessageBox(parent=self,
- message=_("Attribute management is available only "
+ wx.MessageBox(parent = self,
+ message = _("Attribute management is available only "
"for vector maps."),
- caption=_("Message"),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ caption = _("Message"),
+ style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
return
if not self.curr_page.maptree.GetPyData(layer)[0]:
@@ -1101,13 +1101,13 @@
if not dcmd:
return
- busy = wx.BusyInfo(message=_("Please wait, loading attribute data..."),
- parent=self)
+ busy = wx.BusyInfo(message = _("Please wait, loading attribute data..."),
+ parent = self)
wx.Yield()
- dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
- size=wx.Size(500, 300),
- item=layer, log=self.goutput)
+ dbmanager = dbm.AttributeManager(parent = self, id = wx.ID_ANY,
+ size = wx.Size(500, 300),
+ item = layer, log = self.goutput)
busy.Destroy()
@@ -1117,11 +1117,11 @@
# show ATM window
dbmanager.Show()
- def OnNewDisplay(self, event=None):
+ def OnNewDisplay(self, event = None):
"""!Create new layer tree and map display instance"""
self.NewDisplay()
- def NewDisplay(self, show=True):
+ def NewDisplay(self, show = True):
"""!Create new layer tree, which will
create an associated map display frame
@@ -1132,29 +1132,29 @@
Debug.msg(1, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
# make a new page in the bookcontrol for the layer tree (on page 0 of the notebook)
- self.pg_panel = wx.Panel(self.gm_cb, id=wx.ID_ANY, style= wx.EXPAND)
- self.gm_cb.AddPage(self.pg_panel, text="Display "+ str(self.disp_idx + 1), select = True)
+ self.pg_panel = wx.Panel(self.gm_cb, id = wx.ID_ANY, style = wx.EXPAND)
+ self.gm_cb.AddPage(self.pg_panel, text = "Display "+ str(self.disp_idx + 1), select = True)
self.curr_page = self.gm_cb.GetCurrentPage()
# create layer tree (tree control for managing GIS layers) and put on new notebook page
- self.curr_page.maptree = layertree.LayerTree(self.curr_page, id=wx.ID_ANY, pos=wx.DefaultPosition,
- size=wx.DefaultSize, style=wx.TR_HAS_BUTTONS |
+ self.curr_page.maptree = layertree.LayerTree(self.curr_page, id = wx.ID_ANY, pos = wx.DefaultPosition,
+ size = wx.DefaultSize, style = wx.TR_HAS_BUTTONS |
wx.TR_LINES_AT_ROOT| wx.TR_HIDE_ROOT |
wx.TR_DEFAULT_STYLE| wx.NO_BORDER | wx.FULL_REPAINT_ON_RESIZE,
- idx=self.disp_idx, lmgr=self, notebook=self.gm_cb,
- auimgr=self._auimgr, showMapDisplay=show)
+ idx = self.disp_idx, lmgr = self, notebook = self.gm_cb,
+ auimgr = self._auimgr, showMapDisplay = show)
# layout for controls
cb_boxsizer = wx.BoxSizer(wx.VERTICAL)
- cb_boxsizer.Add(self.curr_page.maptree, proportion=1, flag=wx.EXPAND, border=1)
+ cb_boxsizer.Add(self.curr_page.maptree, proportion = 1, flag = wx.EXPAND, border = 1)
self.curr_page.SetSizer(cb_boxsizer)
cb_boxsizer.Fit(self.curr_page.maptree)
self.curr_page.Layout()
self.curr_page.maptree.Layout()
idx = 4 + self.disp_idx * 4
try:
x, y = map(int, dim.split(',')[idx:idx + 2])
@@ -1174,8 +1174,9 @@
self.NewDisplay(show = True)
- self.AddRaster(event)
+ self.notebook.SetSelection(0)
+ self.curr_page.maptree.AddLayer('raster')
def OnAddRaster3D(self, event):
"""!Add 3D raster map layer"""
@@ -1185,7 +1186,7 @@
self.AddRaster3D(event)
def OnAddRasterMisc(self, event):
- """!Add raster menu"""
+ """!Create misc raster popup-menu"""
@@ -1193,49 +1194,43 @@
point = wx.GetMousePosition()
rastmenu = wx.Menu()
- addshaded = wx.MenuItem(rastmenu, -1, Icons ["addshaded"].GetLabel())
- addshaded.SetBitmap(Icons["addshaded"].GetBitmap (self.iconsize))
- rastmenu.AppendItem(addshaded)
- self.Bind(wx.EVT_MENU, self.AddShaded, addshaded)
- addrgb = wx.MenuItem(rastmenu, -1, Icons["addrgb"].GetLabel())
- addrgb.SetBitmap(Icons["addrgb"].GetBitmap(self.iconsize))
- rastmenu.AppendItem(addrgb)
- self.Bind(wx.EVT_MENU, self.AddRGB, addrgb)
- addhis = wx.MenuItem(rastmenu, -1, Icons ["addhis"].GetLabel())
- addhis.SetBitmap(Icons["addhis"].GetBitmap (self.iconsize))
- rastmenu.AppendItem(addhis)
- self.Bind(wx.EVT_MENU, self.AddHIS, addhis)
- addrastarrow = wx.MenuItem(rastmenu, -1, Icons ["addrarrow"].GetLabel())
- addrastarrow.SetBitmap(Icons["addrarrow"].GetBitmap (self.iconsize))
- rastmenu.AppendItem(addrastarrow)
- self.Bind(wx.EVT_MENU, self.AddRastarrow, addrastarrow)
- addrastnums = wx.MenuItem(rastmenu, -1, Icons ["addrnum"].GetLabel())
- addrastnums.SetBitmap(Icons["addrnum"].GetBitmap (self.iconsize))
- rastmenu.AppendItem(addrastnums)
- self.Bind(wx.EVT_MENU, self.AddRastnum, addrastnums)
- # Popup the menu. If an item is selected then its handler
+ for key, handler in (('addrast3d', self.OnAddRaster3D),
+ (None, None),
+ ('addrgb', self.OnAddRasterRGB),
+ ('addhis', self.OnAddRasterHIS),
+ (None, None),
+ ('addshaded', self.OnAddRasterShaded),
+ (None, None),
+ ('addrarrow', self.OnAddRasterArrow),
+ ('addrnum', self.OnAddRasterNum)):
+ if key is None:
+ rastmenu.AppendSeparator()
+ continue
+ item = wx.MenuItem(rastmenu, wx.ID_ANY, Icons[key].GetLabel())
+ item.SetBitmap(Icons[key].GetBitmap(self.iconsize))
+ rastmenu.AppendItem(item)
+ self.Bind(wx.EVT_MENU, handler, item)
+ # Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.PopupMenu(rastmenu)
rastmenu.Destroy()
# show map display
self.curr_page.maptree.mapdisplay.Show()
def OnAddVector(self, event):
- """!Add vector map layer"""
+ """!Add vector map to the current layer tree"""
- self.AddVector(event)
+ self.curr_page.maptree.AddLayer('vector')
def OnAddVectorMisc(self, event):
- """!Add vector menu"""
+ """!Create misc vector popup-menu"""
@@ -1243,16 +1238,17 @@
vectmenu = wx.Menu()
- addtheme = wx.MenuItem(vectmenu, -1, Icons["addthematic"].GetLabel())
- addtheme.SetBitmap(Icons["addthematic"].GetBitmap(self.iconsize))
- vectmenu.AppendItem(addtheme)
- self.Bind(wx.EVT_MENU, self.AddThemeMap, addtheme)
- addchart = wx.MenuItem(vectmenu, -1, Icons["addchart"].GetLabel())
- addchart.SetBitmap(Icons["addchart"].GetBitmap(self.iconsize))
- vectmenu.AppendItem(addchart)
- self.Bind(wx.EVT_MENU, self.AddThemeChart, addchart)
+ for key, handler in (('addthematic', self.OnAddVectorTheme),
+ ('addchart', self.OnAddVectorChart)):
+ if key is None:
+ continue
+ item = wx.MenuItem(vectmenu, wx.ID_ANY, Icons[key].GetLabel())
+ vectmenu.AppendItem(item)
self.PopupMenu(vectmenu)
@@ -1261,8 +1257,18 @@
# show map display
+ def OnAddVectorTheme(self, event):
+ """!Add thematic vector map to the current layer tree"""
+ self.curr_page.maptree.AddLayer('thememap')
+ def OnAddVectorChart(self, event):
+ """!Add chart vector map to the current layer tree"""
+ self.curr_page.maptree.AddLayer('themechart')
def OnAddOverlay(self, event):
- """!Add decoration overlay menu"""
+ """!Create decoration overlay menu"""
@@ -1270,31 +1276,21 @@
ovlmenu = wx.Menu()
- addgrid = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addgrid"].GetLabel())
- addgrid.SetBitmap(Icons["addgrid"].GetBitmap(self.iconsize))
- ovlmenu.AppendItem(addgrid)
- self.Bind(wx.EVT_MENU, self.AddGrid, addgrid)
+ for key, handler in (('addgrid', self.OnAddGrid),
+ ('addlabels', self.OnAddLabels),
+ ('addgeodesic', self.OnAddGeodesic),
+ ('addrhumb', self.OnAddRhumb),
+ (None, None),
+ ('addcmd', self.OnAddCommand)):
+ if key is None:
+ ovlmenu.AppendSeparator()
+ continue
+ item = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons[key].GetLabel())
+ ovlmenu.AppendItem(item)
- addlabels = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addlabels"].GetLabel())
- addlabels.SetBitmap(Icons["addlabels"].GetBitmap(self.iconsize))
- ovlmenu.AppendItem(addlabels)
- self.Bind(wx.EVT_MENU, self.OnAddLabels, addlabels)
- addgeodesic = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addgeodesic"].GetLabel())
- addgeodesic.SetBitmap(Icons["addgeodesic"].GetBitmap(self.iconsize))
- ovlmenu.AppendItem(addgeodesic)
- self.Bind(wx.EVT_MENU, self.AddGeodesic, addgeodesic)
- addrhumb = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addrhumb"].GetLabel())
- addrhumb.SetBitmap(Icons["addrhumb"].GetBitmap(self.iconsize))
- ovlmenu.AppendItem(addrhumb)
- self.Bind(wx.EVT_MENU, self.AddRhumb, addrhumb)
- addcmd = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addcmd"].GetLabel())
- addcmd.SetBitmap(Icons["addcmd"].GetBitmap(self.iconsize))
- ovlmenu.AppendItem(addcmd)
- self.Bind(wx.EVT_MENU, self.OnAddCommand, addcmd)
self.PopupMenu(ovlmenu)
@@ -1302,58 +1298,39 @@
# show map display
- def AddRaster(self, event):
- """!Add raster to the layer tree"""
+ def OnAddRaster3D(self, event):
+ """!Add 3D raster map to the current layer tree"""
- self.curr_page.maptree.AddLayer('raster')
- def AddRaster3D(self, event):
- self.notebook.SetSelection(0)
self.curr_page.maptree.AddLayer('3d-raster')
- def AddRGB(self, event):
- """!Add RGB layer"""
+ def OnAddRasterRGB(self, event):
+ """!Add RGB raster map to the current layer tree"""
self.curr_page.maptree.AddLayer('rgb')
- def AddHIS(self, event):
- """!Add HIS layer"""
+ def OnAddRasterHIS(self, event):
+ """!Add HIS raster map to the current layer tree"""
self.curr_page.maptree.AddLayer('his')
- def AddShaded(self, event):
- """!Add shaded relief map layer"""
+ def OnAddRasterShaded(self, event):
+ """!Add shaded relief raster map to the current layer tree"""
self.curr_page.maptree.AddLayer('shaded')
- def AddRastarrow(self, event):
- """!Add raster flow arrows map"""
+ def OnAddRasterArrow(self, event):
+ """!Add flow arrows raster map to the current layer tree"""
self.curr_page.maptree.AddLayer('rastarrow')
- def AddRastnum(self, event):
- """!Add raster map with cell numbers"""
+ def OnAddRasterNum(self, event):
+ """!Add cell number raster map to the current layer tree"""
self.curr_page.maptree.AddLayer('rastnum')
- def AddVector(self, event):
- """!Add vector layer"""
- self.curr_page.maptree.AddLayer('vector')
- def AddThemeMap(self, event):
- """!Add thematic map layer"""
- self.curr_page.maptree.AddLayer('thememap')
- def AddThemeChart(self, event):
- """!Add thematic chart layer"""
- self.curr_page.maptree.AddLayer('themechart')
def OnAddCommand(self, event):
- """!Add command line layer"""
+ """!Add command line map layer to the current layer tree"""
@@ -1376,23 +1353,23 @@
# show map display
- def AddGrid(self, event):
- """!Add layer grid"""
+ def OnAddGrid(self, event):
+ """!Add grid map layer to the current layer tree"""
self.curr_page.maptree.AddLayer('grid')
- def AddGeodesic(self, event):
- """!Add layer geodesic"""
+ def OnAddGeodesic(self, event):
+ """!Add geodesic line map layer to the current layer tree"""
self.curr_page.maptree.AddLayer('geodesic')
- def AddRhumb(self, event):
- """!Add layer rhumb"""
+ def OnAddRhumb(self, event):
+ """!Add rhumb map layer to the current layer tree"""
self.curr_page.maptree.AddLayer('rhumb')
def OnAddLabels(self, event):
- """!Add layer vector labels"""
+ """!Add vector labels map layer to the current layer tree"""
@@ -1404,14 +1381,13 @@
def OnDeleteLayer(self, event):
+ """!Remove selected map layer from the current layer Tree
- Delete selected map display layer in GIS Manager tree widget
if not self.curr_page or not self.curr_page.maptree.layer_selected:
self.MsgNoLayerSelected()
return
- if UserSettings.Get(group='manager', key='askOnRemoveLayer', subkey='enabled'):
+ if UserSettings.Get(group = 'manager', key = 'askOnRemoveLayer', subkey = 'enabled'):
layerName = ''
for item in self.curr_page.maptree.GetSelections():
name = str(self.curr_page.maptree.GetItemText(item))
@@ -1429,14 +1405,14 @@
message = _("Do you want to remove selected map layer(s) "
"from layer tree?")
- dlg = wx.MessageDialog (parent=self, message=message,
- caption=_("Remove map layer"),
- style=wx.YES_NO | wx.YES_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
+ dlg = wx.MessageDialog (parent = self, message = message,
+ caption = _("Remove map layer"),
+ style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
- if dlg.ShowModal() in [wx.ID_NO, wx.ID_CANCEL]:
+ if dlg.ShowModal() != wx.ID_YES:
dlg.Destroy()
return
dlg.Destroy()
for layer in self.curr_page.maptree.GetSelections():
@@ -1479,7 +1455,7 @@
if self.workspaceChanged and \
- UserSettings.Get(group='manager', key='askOnQuit', subkey='enabled'):
+ UserSettings.Get(group = 'manager', key = 'askOnQuit', subkey = 'enabled'):
message = _("Do you want to save changes in the workspace?")
else:
@@ -1489,9 +1465,9 @@
- message=message,
- caption=_("Quit GRASS GUI"),
+ caption = _("Quit GRASS GUI"),
@@ -1519,10 +1495,10 @@
def MsgNoLayerSelected(self):
"""!Show dialog message 'No layer selected'"""
- message=_("No map layer selected. Operation cancelled."),
+ message = _("No map layer selected. Operation cancelled."),
class GMApp(wx.App):
def __init__(self, workspace = None):
@@ -1548,8 +1524,8 @@
introImagePath = os.path.join(globalvar.ETCWXDIR, "images", "grass_splash.png")
introImage = wx.Image(introImagePath, wx.BITMAP_TYPE_PNG)
introBmp = introImage.ConvertToBitmap()
- wx.SplashScreen (bitmap=introBmp, splashStyle=wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
- milliseconds=2000, parent=None, id=wx.ID_ANY)
+ wx.SplashScreen (bitmap = introBmp, splashStyle = wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
+ milliseconds = 2000, parent = None, id = wx.ID_ANY)
wx.Yield()
w, h = wx.GetDisplaySize()
@@ -1565,7 +1541,7 @@
subkey = 'dim', value = dim)
# create and show main frame
- mainframe = GMFrame(parent=None, id=wx.ID_ANY,
+ mainframe = GMFrame(parent = None, id = wx.ID_ANY,
workspace = self.workspaceFile)
mainframe.Show()
@@ -1600,7 +1576,7 @@
return (workspaceFile,)
-def main(argv=None):
+def main(argv = None):
# process command-line arguments
