[GRASS-SVN] r44753 - grass-addons/raster/mcda/r.mcda.electre
svn_grass at osgeo.org
Tue Dec 28 17:59:08 EST 2010
Author: gianluca
Date: 2010-12-28 14:59:08 -0800 (Tue, 28 Dec 2010)
New Revision: 44753
grass-addons/raster/mcda/r.mcda.electre/local_proto.h
grass-addons/raster/mcda/r.mcda.electre/main.c
removed some strange string in code
Modified: grass-addons/raster/mcda/r.mcda.electre/local_proto.h
--- grass-addons/raster/mcda/r.mcda.electre/local_proto.h 2010-12-28 22:36:14 UTC (rev 44752)
+++ grass-addons/raster/mcda/r.mcda.electre/local_proto.h 2010-12-28 22:59:08 UTC (rev 44753)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
-#include <time.h>
+#include <math.h>
#include <grass/gis.h>
#include <grass/glocale.h>
#include <grass/config.h>
Modified: grass-addons/raster/mcda/r.mcda.electre/main.c
--- grass-addons/raster/mcda/r.mcda.electre/main.c 2010-12-28 22:36:14 UTC (rev 44752)
+++ grass-addons/raster/mcda/r.mcda.electre/main.c 2010-12-28 22:59:08 UTC (rev 44753)
@@ -1,4 +1,3 @@
-<<<<<<< .mine
* MODULE: r.mcda.electre
@@ -231,243 +230,3 @@
exit(EXIT_SUCCESS);
- * MODULE: r.mcda.electre
- * AUTHORS: Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
- * PURPOSE: Make a multicriterio decision analysis based on ELECTRE algorthm
- * COPYRIGHT: (C) GRASS Development Team (2008)
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
-#include "local_proto.h"
- * main function
-int main(int argc, char *argv[])
- struct Cell_head cellhd; /* it stores region information, and header information of rasters */
- char *result_concordance, *result_discordance; /* outputs raster name */
- char *mapset; /* mapset name */
- unsigned char *outrast_concordance, *outrast_discordance; /* output buffer */
- char *message;
- int i, j, ncriteria = 0; /* index and files number */
- int nrows, ncols;
- int row1, row2, col1, col2;
- int outfd_concordance, outfd_discordance; /* output file descriptor */
- double *weight_vect, ***decision_vol; /* vector and matrix */
- struct History history; /* holds meta-data (title, comments,..) */
- struct GModule *module; /* GRASS module for parsing arguments */
- struct Option *criteria, *weight, *discordance, *concordance; /* options */
- struct input *attributes; /*storage alla input criteria GRID files and output concordance and discordance GRID files */
- /* initialize GIS environment */
- G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
- /* initialize module */
- module = G_define_module();
- module->keywords = _("raster,MCDA");
- module->description =
- _("Multicirtieria decision analysis based on ELECTRE method");
- /* Define the different options as defined in gis.h */
- criteria = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
- criteria->key = "criteria";
- criteria->type = TYPE_STRING;
- criteria->required = YES;
- criteria->multiple = YES;
- criteria->gisprompt = "old,cell,raster";
- criteria->description =
- "Input geographics criteria in information system";
- weight = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
- weight->key = "weight";
- weight->type = TYPE_DOUBLE;
- weight->required = YES;
- weight->multiple = YES;
- weight->description = _("Criteria weight(s) (w1,w2,..)");
- concordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
- concordance->key = "concordance";
- concordance->type = TYPE_STRING;
- concordance->required = YES;
- concordance->gisprompt = "new,cell,raster";
- concordance->answer = "concordance";
- concordance->description = "concordance output map";
- discordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
- discordance->key = "discordance";
- discordance->type = TYPE_STRING;
- discordance->required = YES;
- discordance->gisprompt = "new,cell,raster";
- discordance->answer = "discordance";
- discordance->description = "discordance output map";
- /* options and flags parser */
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- G_message("Start: %s", G_date()); /*write calculation start time */
- /* number of file (=criteria) */
- while (criteria->answers[ncriteria] != NULL) {
- ncriteria++;
- /* process the input maps: stores options and flags to variables */
- /* CRITERIA grid */
- attributes = G_malloc(ncriteria * sizeof(struct input)); /*attributes is input struct defined in top file and store alla criteria files */
- weight_vect = G_malloc(ncriteria * sizeof(double)); /*allocate memory fron vector weight */
- build_weight_vect(nrows, ncols, ncriteria, weight, weight_vect); /*calcolate weight vector */
- for (i = 0; i < ncriteria; i++) {
- struct input *p = &attributes[i];
- p->name = criteria->answers[i];
- p->mapset = G_find_cell2(p->name, ""); /* G_find_cell: Looks for the raster map "name" in the database. */
- if (p->mapset == NULL) /* returns NULL if the map was not found in any mapset, mapset name otherwise */
- G_fatal_error(_("Raster file <%s> not found"), p->name);
- if ((p->infd = G_open_cell_old(p->name, p->mapset)) < 0) /* G_open_cell_old - returns file destriptor (>0) */
- G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),
- p->name, p->mapset);
- if (G_get_cellhd(p->name, p->mapset, &cellhd) < 0) /* controlling, if we can open input raster */
- G_fatal_error(_("Unable to read file header of <%s>"), p->name);
- p->inrast = G_allocate_d_raster_buf(); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL */
- result_concordance = concordance->answer; /* store outputn name in variables */
- result_discordance = discordance->answer;
- if (G_legal_filename(result_concordance) < 0) /* check for legal database file names */
- G_fatal_error(_("<%s> is an illegal file name"), result_concordance);
- if (G_legal_filename(result_discordance) < 0) /* check for legal database file names */
- G_fatal_error(_("<%s> is an illegal file name"), result_discordance);
- /*values = G_malloc(ncriteria * sizeof(DCELL)); */
- nrows = G_window_rows();
- ncols = G_window_cols();
- /*memory allocation for-three dimensional matrix */
- decision_vol = G_malloc(nrows * sizeof(double *));
- for (i = 0; i < nrows; ++i) {
- decision_vol[i] = G_malloc(ncols * sizeof(double *));
- for (j = 0; j < ncols; ++j) {
- decision_vol[i][j] = G_malloc((ncriteria + 2) * sizeof(double)); /****NOTE: it's storage enven concordance and discordance index map****/
- /* Allocate output buffer, use DCELL_TYPE */
- outrast_concordance = G_allocate_raster_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
- outrast_discordance = G_allocate_raster_buf(DCELL_TYPE);
- /* controlling, if we can write the raster */
- if ((outfd_concordance =
- G_open_raster_new(result_concordance, DCELL_TYPE)) < 0)
- G_fatal_error(_("Unable to create raster map <%s>"),
- result_concordance);
- if ((outfd_discordance =
- G_open_raster_new(result_discordance, DCELL_TYPE)) < 0)
- result_discordance);
- /*build a three dimensional matrix for storage all critera maps */
- for (row1 = 0; row1 < nrows; row1++) {
- G_get_raster_row(attributes[i].infd, attributes[i].inrast, row1, DCELL_TYPE); /* Reads appropriate information into the buffer buf associated with the requested row */
- /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row); */
- for (col1 = 0; col1 < ncols; col1++) {
- /* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array */
- DCELL v1 = ((DCELL *) attributes[i].inrast)[col1];
- decision_vol[row1][col1][i] = (double)(v1);
- build_dominance_matrix(nrows, ncols, ncriteria, weight_vect, decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index */
- ((DCELL *) outrast_concordance)[col1] = (DCELL) decision_vol[row1][col1][ncriteria]; /*write concordance map */
- ((DCELL *) outrast_discordance)[col1] = (DCELL) decision_vol[row1][col1][ncriteria + 1]; /*write discordance map */
- if (G_put_raster_row
- (outfd_concordance, outrast_concordance, DCELL_TYPE) < 0)
- G_fatal_error(_("Failed writing raster map <%s>"),
- (outfd_discordance, outrast_discordance, DCELL_TYPE) < 0)
- G_message("End: %s", G_date());
- /* memory cleanup */
- G_free(attributes[i].inrast);
- G_free(outrast_concordance);
- G_free(outrast_discordance);
- G_free(decision_vol);
- /* closing raster maps */
- G_close_cell(attributes[i].infd);
- G_close_cell(outfd_concordance);
- G_close_cell(outfd_discordance);
- /* add command line incantation to history concordance file */
- G_short_history(result_concordance, "raster", &history);
- G_command_history(&history);
- G_write_history(result_concordance, &history);
- /* add command line incantation to history discordance file */
- G_short_history(result_discordance, "raster", &history);
- G_write_history(result_discordance, &history);
- exit(EXIT_SUCCESS);
->>>>>>> .r42697
