[GRASS-SVN] r44759 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Dec 29 09:48:14 EST 2010
Author: martinl
Date: 2010-12-29 06:48:14 -0800 (Wed, 29 Dec 2010)
New Revision: 44759
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
wxGUI/mapdisp: coding style clean up
(merge r44757 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py 2010-12-29 14:47:42 UTC (rev 44758)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py 2010-12-29 14:48:14 UTC (rev 44759)
@@ -85,10 +85,10 @@
"""!Main frame for map display window. Drawing takes place in
child double buffered drawing window.
- def __init__(self, parent=None, id=wx.ID_ANY, title=_("GRASS GIS - Map display"),
- style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
- tree=None, notebook=None, lmgr=None, page=None,
- Map=None, auimgr=None, **kwargs):
+ def __init__(self, parent = None, id = wx.ID_ANY, title = _("GRASS GIS - Map display"),
+ style = wx.DEFAULT_FRAME_STYLE, toolbars = ["map"],
+ tree = None, notebook = None, lmgr = None, page = None,
+ Map = None, auimgr = None, **kwargs):
"""!Main map display window with toolbars, statusbar and
DrawWindow
@@ -151,26 +151,26 @@
# Add statusbar
- self.statusbar = self.CreateStatusBar(number=4, style=0)
+ self.statusbar = self.CreateStatusBar(number = 4, style = 0)
self.statusbar.SetStatusWidths([-5, -2, -1, -1])
self.statusbarWin = dict()
self.statusbarWin['toggle'] = wx.Choice(self.statusbar, wx.ID_ANY,
choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
- self.statusbarWin['toggle'].SetSelection(UserSettings.Get(group='display',
- key='statusbarMode',
- subkey='selection'))
+ self.statusbarWin['toggle'].SetSelection(UserSettings.Get(group = 'display',
+ key = 'statusbarMode',
+ subkey = 'selection'))
self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
# auto-rendering checkbox
- self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Render"))
+ self.statusbarWin['render'] = wx.CheckBox(parent = self.statusbar, id = wx.ID_ANY,
+ label = _("Render"))
self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
- self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
- key='autoRendering',
- subkey='enabled'))
+ self.statusbarWin['render'].SetValue(UserSettings.Get(group = 'display',
+ key = 'autoRendering',
+ subkey = 'enabled'))
self.statusbarWin['render'].SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
# show region
- self.statusbarWin['region'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Show computational extent"))
+ self.statusbarWin['region'] = wx.CheckBox(parent = self.statusbar, id = wx.ID_ANY,
+ label = _("Show computational extent"))
self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.statusbarWin['region'])
self.statusbarWin['region'].SetValue(False)
@@ -182,10 +182,10 @@
"computational region inside a display region "
"as a red box).")))
# set resolution
- self.statusbarWin['resolution'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Constrain display resolution to computational settings"))
+ self.statusbarWin['resolution'] = wx.CheckBox(parent = self.statusbar, id = wx.ID_ANY,
+ label = _("Constrain display resolution to computational settings"))
self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.statusbarWin['resolution'])
- self.statusbarWin['resolution'].SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+ self.statusbarWin['resolution'].SetValue(UserSettings.Get(group = 'display', key = 'compResolution', subkey = 'enabled'))
self.statusbarWin['resolution'].Hide()
self.statusbarWin['resolution'].SetToolTip(wx.ToolTip (_("Constrain display resolution "
"to computational region settings. "
@@ -194,7 +194,7 @@
# map scale
self.statusbarWin['mapscale'] = wx.ComboBox(parent = self.statusbar, id = wx.ID_ANY,
style = wx.TE_PROCESS_ENTER,
- size=(150, -1))
+ size = (150, -1))
self.statusbarWin['mapscale'].SetItems(['1:1000',
'1:5000',
'1:10000',
@@ -207,15 +207,15 @@
self.statusbar.Bind(wx.EVT_COMBOBOX, self.OnChangeMapScale, self.statusbarWin['mapscale'])
# go to
- self.statusbarWin['goto'] = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
- value="", style=wx.TE_PROCESS_ENTER,
- size=(300, -1))
+ self.statusbarWin['goto'] = wx.TextCtrl(parent = self.statusbar, id = wx.ID_ANY,
+ value = "", style = wx.TE_PROCESS_ENTER,
+ size = (300, -1))
self.statusbarWin['goto'].Hide()
self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
# projection
- self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Use defined projection"))
+ self.statusbarWin['projection'] = wx.CheckBox(parent = self.statusbar, id = wx.ID_ANY,
+ label = _("Use defined projection"))
self.statusbarWin['projection'].SetValue(False)
size = self.statusbarWin['projection'].GetSize()
self.statusbarWin['projection'].SetMinSize((size[0] + 150, size[1]))
@@ -231,8 +231,8 @@
self.statusbarWin['mask'].SetForegroundColour(wx.Colour(255, 0, 0))
# on-render gauge
- self.statusbarWin['progress'] = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
- range=0, style=wx.GA_HORIZONTAL)
+ self.statusbarWin['progress'] = wx.Gauge(parent = self.statusbar, id = wx.ID_ANY,
+ range = 0, style = wx.GA_HORIZONTAL)
self.statusbarWin['progress'].Hide()
self.StatusbarReposition() # reposition statusbar
@@ -240,8 +240,8 @@
# Init map display (buffered DC & set default cursor)
- self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,
- Map=self.Map, tree=self.tree, lmgr=self._layerManager)
+ self.MapWindow2D = BufferedWindow(self, id = wx.ID_ANY,
+ Map = self.Map, tree = self.tree, lmgr = self._layerManager)
# default is 2D display mode
self.MapWindow = self.MapWindow2D
self.MapWindow.SetCursor(self.cursors["default"])
@@ -347,9 +347,9 @@
log = self._layerManager.goutput
else:
log = None
- self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, mapcontent=self.Map,
- layerTree=self.tree,
- log=log)
+ self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent = self, mapcontent = self.Map,
+ layerTree = self.tree,
+ log = log)
self._mgr.AddPane(self.toolbars['vdigit'],
wx.aui.AuiPaneInfo().
@@ -363,8 +363,8 @@
# change mouse to draw digitized line
self.MapWindow.mouse['box'] = "point"
self.MapWindow.zoomtype = 0
- self.MapWindow.pen = wx.Pen(colour='red', width=2, style=wx.SOLID)
- self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SOLID)
+ self.MapWindow.pen = wx.Pen(colour = 'red', width = 2, style = wx.SOLID)
+ self.MapWindow.polypen = wx.Pen(colour = 'green', width = 2, style = wx.SOLID)
# georectifier
elif name == "georect":
self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
@@ -406,8 +406,8 @@
# create GL window & NVIZ toolbar
if not self.MapWindow3D:
- self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY,
+ self.MapWindow3D = nviz.GLWindow(self, id = wx.ID_ANY,
self.MapWindow = self.MapWindow3D
@@ -530,7 +530,7 @@
"""!Re-render map composition (each map layer)
# delete tmp map layers (queries)
- qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
+ qlayer = self.Map.GetListOfLayers(l_name = globalvar.QUERYLAYER)
for layer in qlayer:
self.Map.DeleteLayer(layer)
@@ -543,9 +543,9 @@
# deselect features in vdigit
if self.toolbars['vdigit'] and self.digit:
self.digit.driver.SetSelected([])
- self.MapWindow.UpdateMap(render=True, renderVector=True)
+ self.MapWindow.UpdateMap(render = True, renderVector = True)
else:
- self.MapWindow.UpdateMap(render=True)
+ self.MapWindow.UpdateMap(render = True)
# update statusbar
self.StatusbarUpdate()
@@ -597,7 +597,7 @@
self.MapWindow.mouse['use'] = "zoom"
self.MapWindow.mouse['box'] = "box"
self.MapWindow.zoomtype = 1
- self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+ self.MapWindow.pen = wx.Pen(colour = 'Red', width = 2, style = wx.SHORT_DASH)
# change the cursor
self.MapWindow.SetCursor(self.cursors["cross"])
@@ -614,7 +614,7 @@
self.MapWindow.zoomtype = -1
# change the cursor
@@ -738,13 +738,13 @@
try:
if self.statusbarWin['projection'].IsChecked():
- if not UserSettings.Get(group='projection', key='statusbar', subkey='proj4'):
+ if not UserSettings.Get(group = 'projection', key = 'statusbar', subkey = 'proj4'):
self.statusbar.SetStatusText(_("Projection not defined (check the settings)"), 0)
else:
# reproject values
- projIn = UserSettings.Get(group='projection',
- key='statusbar',
- subkey='proj4')
+ projIn = UserSettings.Get(group = 'projection',
+ key = 'statusbar',
+ subkey = 'proj4')
projOut = gcmd.RunCommand('g.proj',
flags = 'jf',
read = True)
@@ -770,7 +770,7 @@
region = self.Map.GetCurrentRegion()
else:
region['center_easting'], region['center_northing'] = e, n
@@ -841,12 +841,12 @@
subkey = 'll')
else:
- projOut = UserSettings.Get(group='projection',
- key='statusbar',
- subkey='proj4')
+ projOut = UserSettings.Get(group = 'projection',
+ subkey = 'proj4')
proj, coord1 = utils.ReprojectCoordinates(coord = (region["w"], region["s"]),
projOut = projOut, flags = 'd')
proj, coord2 = utils.ReprojectCoordinates(coord = (region["e"], region["n"]),
@@ -999,9 +999,9 @@
else:
proj, coord = utils.ReprojectCoordinates(coord = (region['center_easting'],
region['center_northing']),
- key='statusbar',
- subkey='proj4'),
+ subkey = 'proj4'),
flags = 'd')
if coord:
if proj in ('ll', 'latlong', 'longlat') and format == 'DMS':
@@ -1028,7 +1028,7 @@
elif self.statusbarWin['toggle'].GetSelection() == 8: # projection
self.statusbar.SetStatusText("")
- epsg = UserSettings.Get(group='projection', key='statusbar', subkey='epsg')
+ epsg = UserSettings.Get(group = 'projection', key = 'statusbar', subkey = 'epsg')
if epsg:
label = '%s (EPSG: %s)' % (_("Use defined projection"), epsg)
self.statusbarWin['projection'].SetLabel(label)
@@ -1042,7 +1042,7 @@
else:
self.statusbar.SetStatusText("", 1)
- def StatusbarEnableLongHelp(self, enable=True):
+ def StatusbarEnableLongHelp(self, enable = True):
"""!Enable/disable toolbars long help"""
for toolbar in self.toolbars.itervalues():
if toolbar:
@@ -1113,7 +1113,7 @@
message = _("Choose a file name to save the image "
"(no need to add extension)"),
wildcard = filetype,
- style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
+ style = wx.SAVE | wx.FD_OVERWRITE_PROMPT)
if dlg.ShowModal() == wx.ID_OK:
path = dlg.GetPath()
@@ -1223,7 +1223,7 @@
self.toolbars['map'].action['desc'] = 'modifyAttrb'
self.MapWindow.mouse['use'] = "queryVector"
self._OnQuery()
def OnNvizQuerySurface(self, event):
@@ -1293,7 +1293,7 @@
# use display region settings instead of computation region settings
self.tmpreg = os.getenv("GRASS_REGION")
- os.environ["GRASS_REGION"] = self.Map.SetRegion(windres=False)
+ os.environ["GRASS_REGION"] = self.Map.SetRegion(windres = False)
# build query commands for any selected rasters and vectors
if raststr != '':
@@ -1328,8 +1328,8 @@
if self._layerManager:
if raststr:
self._layerManager.goutput.RunCmd(rcmd,
- compReg=False,
- onDone = self._QueryMapDone)
+ compReg = False,
+ onDone = self._QueryMapDone)
if vectstr:
self._layerManager.goutput.RunCmd(vcmd,
@@ -1363,18 +1363,18 @@
if not self.tree.layer_selected or \
self.tree.GetPyData(self.tree.layer_selected)[0]['type'] != 'vector':
- wx.MessageBox(parent=self,
- message=_("No vector map selected for querying."),
- caption=_("Vector querying"),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ wx.MessageBox(parent = self,
+ message = _("No vector map selected for querying."),
+ caption = _("Vector querying"),
+ style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
return
if self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetMapset() != \
grass.gisenv()['MAPSET']:
- message=_("Only vector map from the current mapset can be modified."),
+ message = _("Only vector map from the current mapset can be modified."),
return
posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
@@ -1389,23 +1389,23 @@
if self.dialogs['attributes'] is None:
self.dialogs['attributes'] = \
- dbm_dialogs.DisplayAttributesDialog(parent=self.MapWindow,
- map=mapName,
- query=((east, north), qdist),
- pos=posWindow,
- action="update")
+ dbm_dialogs.DisplayAttributesDialog(parent = self.MapWindow,
+ map = mapName,
+ query = ((east, north), qdist),
+ pos = posWindow,
+ action = "update")
else:
# selection changed?
if not self.dialogs['attributes'].mapDBInfo or \
self.dialogs['attributes'].mapDBInfo.map != mapName:
- self.dialogs['attributes'].UpdateDialog(map=mapName, query=((east, north), qdist))
+ self.dialogs['attributes'].UpdateDialog(map = mapName, query = ((east, north), qdist))
else:
- self.dialogs['attributes'].UpdateDialog(query=((east, north), qdist))
+ self.dialogs['attributes'].UpdateDialog(query = ((east, north), qdist))
cats = self.dialogs['attributes'].GetCats()
try:
- qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)[0]
+ qlayer = self.Map.GetListOfLayers(l_name = globalvar.QUERYLAYER)[0]
except IndexError:
qlayer = None
@@ -1413,22 +1413,22 @@
# highlight feature & re-draw map
if qlayer:
qlayer.SetCmd(self.AddTmpVectorMapLayer(mapName, cats,
- useId=False,
- addLayer=False))
+ useId = False,
+ addLayer = False))
else:
- qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId=False)
+ qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId = False)
# set opacity based on queried layer
- opacity = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetOpacity(float=True)
+ opacity = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetOpacity(float = True)
qlayer.SetOpacity(opacity)
- self.MapWindow.UpdateMap(render=False, renderVector=False)
+ self.MapWindow.UpdateMap(render = False, renderVector = False)
if not self.dialogs['attributes'].IsShown():
self.dialogs['attributes'].Show()
else:
if qlayer:
self.Map.DeleteLayer(qlayer)
if self.dialogs['attributes'].IsShown():
self.dialogs['attributes'].Hide()
@@ -1458,9 +1458,9 @@
if action == "nvizQueryVector":
vector.Check(True)
else:
- display = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
- text=_("Query raster/vector map(s) (display mode)"),
- kind=wx.ITEM_CHECK)
+ display = wx.MenuItem(parentMenu = toolsmenu, id = wx.ID_ANY,
+ text = _("Query raster/vector map(s) (display mode)"),
+ kind = wx.ITEM_CHECK)
toolsmenu.AppendItem(display)
self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
numLayers = 0
@@ -1475,13 +1475,13 @@
if action == "displayAttrb":
display.Check(True)
- modify = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
- text=_("Query vector map (edit mode)"),
+ modify = wx.MenuItem(parentMenu = toolsmenu, id = wx.ID_ANY,
+ text = _("Query vector map (edit mode)"),
toolsmenu.AppendItem(modify)
self.Bind(wx.EVT_MENU, self.OnQueryModify, modify)
modify.Enable(False)
digitToolbar = self.toolbars['vdigit']
if self.tree.layer_selected:
layer_selected = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer']
@@ -1503,7 +1503,7 @@
@param useId use feature id instead of category
# color settings from ATM
- color = UserSettings.Get(group='atm', key='highlight', subkey='color')
+ color = UserSettings.Get(group = 'atm', key = 'highlight', subkey = 'color')
colorStr = str(color[0]) + ":" + \
str(color[1]) + ":" + \
str(color[2])
@@ -1522,7 +1522,7 @@
"map=%s" % name,
"color=%s" % colorStr,
"fcolor=%s" % colorStr,
- "width=%d" % UserSettings.Get(group='atm', key='highlight', subkey='width')]
+ "width=%d" % UserSettings.Get(group = 'atm', key = 'highlight', subkey = 'width')]
if icon != '':
pattern.append('icon=%s' % icon)
if size > 0:
@@ -1540,18 +1540,13 @@
cmd[-1].append("layer=%d" % layer)
cmd[-1].append("cats=%s" % utils.ListOfCatsToRange(lcats))
- # if self.icon:
- # cmd.append("icon=%s" % (self.icon))
- # if self.pointsize:
- # cmd.append("size=%s" % (self.pointsize))
if addLayer:
if useId:
- return self.Map.AddLayer(type='vector', name=globalvar.QUERYLAYER, command=cmd,
- l_active=True, l_hidden=True, l_opacity=1.0)
+ return self.Map.AddLayer(type = 'vector', name = globalvar.QUERYLAYER, command = cmd,
+ l_active = True, l_hidden = True, l_opacity = 1.0)
else:
- return self.Map.AddLayer(type='command', name=globalvar.QUERYLAYER, command=cmd,
+ return self.Map.AddLayer(type = 'command', name = globalvar.QUERYLAYER, command = cmd,
else:
return cmd
@@ -1594,8 +1589,8 @@
self.MapWindow.mouse['use'] = "measure"
self.MapWindow.mouse['box'] = "line"
- self.MapWindow.pen = wx.Pen(colour='red', width=2, style=wx.SHORT_DASH)
- self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SHORT_DASH)
+ self.MapWindow.pen = wx.Pen(colour = 'red', width = 2, style = wx.SHORT_DASH)
+ self.MapWindow.polypen = wx.Pen(colour = 'green', width = 2, style = wx.SHORT_DASH)
# change the cursor
self.MapWindow.SetCursor(self.cursors["pencil"])
@@ -1659,8 +1654,8 @@
raster.append(self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
self.profile = profile.ProfileFrame(self,
- id=wx.ID_ANY, pos=wx.DefaultPosition, size=(700,300),
- style=wx.DEFAULT_FRAME_STYLE, rasterList=raster)
+ id = wx.ID_ANY, pos = wx.DefaultPosition, size = (700,300),
+ style = wx.DEFAULT_FRAME_STYLE, rasterList = raster)
self.profile.Show()
# Open raster select dialog to make sure that a raster (and the desired raster)
# is selected to be profiled
@@ -1717,8 +1712,8 @@
"""!Init histogram display canvas and tools
self.histogram = histogram.HistFrame(self,
- id=wx.ID_ANY, size=globalvar.HIST_WINDOW_SIZE,
- style=wx.DEFAULT_FRAME_STYLE)
+ id = wx.ID_ANY, size = globalvar.HIST_WINDOW_SIZE,
+ style = wx.DEFAULT_FRAME_STYLE)
#show new display
self.histogram.Show()
@@ -1769,12 +1764,12 @@
# decoration overlay control dialog
self.dialogs['barscale'] = \
- gdialogs.DecorationDialog(parent=self, title=_('Scale and North arrow'),
- size=(350, 200),
- style=wx.DEFAULT_DIALOG_STYLE | wx.CENTRE,
- cmd=['d.barscale', 'at=0,5'],
- ovlId=id,
- name='barscale',
+ gdialogs.DecorationDialog(parent = self, title = _('Scale and North arrow'),
+ size = (350, 200),
+ style = wx.DEFAULT_DIALOG_STYLE | wx.CENTRE,
+ cmd = ['d.barscale', 'at = 0,5'],
+ ovlId = id,
+ name = 'barscale',
checktxt = _("Show/hide scale and North arrow"),
ctrltxt = _("scale object"))
@@ -1799,12 +1794,12 @@
# Decoration overlay control dialog
self.dialogs['legend'] = \
- gdialogs.DecorationDialog(parent=self, title=('Legend'),
- size=(350, 200),
- cmd=cmd,
- ovlId=id,
- name='legend',
+ gdialogs.DecorationDialog(parent = self, title = ('Legend'),
+ cmd = cmd,
+ ovlId = id,
+ name = 'legend',
checktxt = _("Show/hide legend"),
ctrltxt = _("legend object"))
@@ -1826,9 +1821,9 @@
else:
id = 101
- self.dialogs['text'] = gdialogs.TextLayerDialog(parent=self, ovlId=id,
- title=_('Add text layer'),
- size=(400, 200))
+ self.dialogs['text'] = gdialogs.TextLayerDialog(parent = self, ovlId = id,
+ title = _('Add text layer'),
+ size = (400, 200))
self.dialogs['text'].CenterOnParent()
# If OK button pressed in decoration control dialog
@@ -1851,10 +1846,10 @@
self.MapWindow.pdc.SetId(id)
self.MapWindow.textdict[id] = self.dialogs['text'].GetValues()
- self.MapWindow.Draw(self.MapWindow.pdcDec, img=self.MapWindow.textdict[id],
- drawid=id, pdctype='text', coords=coords)
+ self.MapWindow.Draw(self.MapWindow.pdcDec, img = self.MapWindow.textdict[id],
+ drawid = id, pdctype = 'text', coords = coords)
self.MapWindow.mouse['use'] = 'pointer'
@@ -1864,8 +1859,8 @@
# Reset comand and rendering options in render.Map. Always render decoration.
# Showing/hiding handled by PseudoDC
- self.Map.ChangeOverlay(ovltype=type, type='overlay', name='', command=dcmd,
- l_active=True, l_render=False)
+ self.Map.ChangeOverlay(ovltype = type, type = 'overlay', name = '', command = dcmd,
+ l_active = True, l_render = False)
self.params[type] = params
self.propwin[type] = propwin
@@ -1940,8 +1935,8 @@
self.PopupMenu(zoommenu)
zoommenu.Destroy()
- def SetProperties(self, render=False, mode=0, showCompExtent=False,
- constrainRes=False, projection=False):
+ def SetProperties(self, render = False, mode = 0, showCompExtent = False,
+ constrainRes = False, projection = False):
"""!Set properies of map display window"""
self.statusbarWin['render'].SetValue(render)
self.statusbarWin['toggle'].SetSelection(mode)
@@ -1977,8 +1972,8 @@
else:
Map = None
- self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map,
- size=globalvar.MAP_WINDOW_SIZE)
+ self.mapFrm = MapFrame(parent = None, id = wx.ID_ANY, Map = Map,
+ size = globalvar.MAP_WINDOW_SIZE)
#self.SetTopWindow(Map)
self.mapFrm.Show()
@@ -2019,7 +2014,7 @@
cmdfilename = sys.argv[2]
import gettext
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
print >> sys.stderr, "\nStarting monitor <%s>...\n" % (title)
