[GRASS-SVN] r44767 - grass/trunk/lib/python
svn_grass at osgeo.org
Wed Dec 29 13:07:14 EST 2010
Author: martinl
Date: 2010-12-29 10:07:14 -0800 (Wed, 29 Dec 2010)
New Revision: 44767
grass/trunk/lib/python/vector.py
pythonlib: vector_what() implemented
Modified: grass/trunk/lib/python/vector.py
--- grass/trunk/lib/python/vector.py 2010-12-29 16:56:08 UTC (rev 44766)
+++ grass/trunk/lib/python/vector.py 2010-12-29 18:07:14 UTC (rev 44767)
@@ -13,7 +13,7 @@
@endcode
-(C) 2008-2009 by the GRASS Development Team
+(C) 2008-2010 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -23,6 +23,7 @@
import os
+import types
from core import *
@@ -216,3 +217,106 @@
return { 'columns' : columns,
'values' : values }
+# interface to v.what
+def vector_what(name, coord, distance = 0.0):
+ """!Query vector map at given locations
+ To query one vector map at one location
+ @code
+ print grass.vector_what(name = 'archsites', coord = (595743, 4925281), distance = 250)
+ [{'Category': 8, 'Map': 'archsites', 'Layer': 1, 'Key_column': 'cat',
+ 'Database': '/home/martin/grassdata/spearfish60/PERMANENT/dbf/',
+ 'Mapset': 'PERMANENT', 'Driver': 'dbf',
+ 'Attributes': {'str1': 'No_Name', 'cat': '8'},
+ 'Table': 'archsites', 'Type': 'Point', 'Id': 8}]
+ @endcode
+ To query one vector map at more locations
+ @code
+ for q in grass.vector_what(name = ('archsites', 'roads'), coord = (595743, 4925281),
+ distance = 250):
+ print q['Map'], q['Attributes']
+ archsites {'str1': 'No_Name', 'cat': '8'}
+ roads {'label': 'interstate', 'cat': '1'}
+ @endcode
+ To query more vector maps at one location
+ @code
+ for q in grass.vector_what(name = 'archsites', coord = [(595743, 4925281), (597950, 4918898)],
+ distance = 250):
+ archsites {'str1': 'Bob_Miller', 'cat': '22'}
+ @endcode
+ @param name vector map(s) to query given as string or list/tuple
+ @param coord coordinates of query given as tuple (easting, northing) or list of tuples
+ @param distance query threshold distance (in map units)
+ @return parsed list
+ if os.environ.has_key("LC_ALL"):
+ locale = os.environ["LC_ALL"]
+ os.environ["LC_ALL"] = "C"
+ if type(name) is types.StringType:
+ name_list = [name]
+ else:
+ name_list = name
+ layer_list = ['-1'] * len(name_list)
+ coord_list = list()
+ if type(coord) is types.TupleType:
+ coord_list.append('%f,%f' % (coord[0], coord[1]))
+ else:
+ for e, n in coord:
+ coord_list.append('%f,%f' % (e, n))
+ ret = read_command('v.what',
+ quiet = True,
+ flags = 'ag',
+ map = ','.join(name_list),
+ layer = ','.join(layer_list),
+ east_north = ','.join(coord_list),
+ distance = float(distance))
+ os.environ["LC_ALL"] = locale
+ data = list()
+ if not ret:
+ return data
+ dict_attrb = None
+ for item in ret.splitlines():
+ try:
+ key, value = map(lambda x: x.strip(), item.split('=', 1))
+ except ValueError:
+ continue
+ if key in ('East', 'North'):
+ continue
+ if key == 'Map':
+ dict_main = { 'Map' : value }
+ dict_attrb = None
+ data.append(dict_main)
+ continue
+ else:
+ if dict_attrb is not None:
+ dict_attrb[key] = value
+ else:
+ if key in ('Category', 'Layer', 'Id'):
+ dict_main[key] = int(value)
+ else:
+ dict_main[key] = value
+ if key == 'Key_column':
+ # skip attributes
+ dict_attrb = dict()
+ dict_main['Attributes'] = dict_attrb
+ return data
