[GRASS-SVN] r44771 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Dec 29 13:30:37 EST 2010
Author: martinl
Date: 2010-12-29 10:30:37 -0800 (Wed, 29 Dec 2010)
New Revision: 44771
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py
wxGUI: use grass.vector_what()
(merge r44769 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py 2010-12-29 18:29:11 UTC (rev 44770)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py 2010-12-29 18:30:37 UTC (rev 44771)
@@ -6,7 +6,7 @@
List of classes:
- VectorDBInfo
-(C) 2007-2009 by the GRASS Development Team
+(C) 2007-2010 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -16,6 +16,7 @@
import os
+import types
import wx
@@ -23,9 +24,11 @@
import gcmd
from preferences import globalSettings as UserSettings
+import grass.script as grass
def unicodeValue(value):
"""!Encode value"""
- enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
+ enc = UserSettings.Get(group = 'atm', key = 'encoding', subkey = 'value')
if enc:
value = unicode(value, enc)
elif os.environ.has_key('GRASS_DB_ENCODING'):
@@ -40,25 +43,25 @@
def createDbInfoDesc(panel, mapDBInfo, layer):
"""!Create database connection information content"""
- infoFlexSizer = wx.FlexGridSizer (cols=2, hgap=1, vgap=1)
+ infoFlexSizer = wx.FlexGridSizer (cols = 2, hgap = 1, vgap = 1)
infoFlexSizer.AddGrowableCol(1)
- infoFlexSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label="Driver:"))
- label=mapDBInfo.layers[layer]['driver']))
- label="Database:"))
- label=mapDBInfo.layers[layer]['database']))
- label="Table:"))
- label=mapDBInfo.layers[layer]['table']))
- label="Key:"))
- label=mapDBInfo.layers[layer]['key']))
+ infoFlexSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = "Driver:"))
+ label = mapDBInfo.layers[layer]['driver']))
+ label = "Database:"))
+ label = mapDBInfo.layers[layer]['database']))
+ label = "Table:"))
+ label = mapDBInfo.layers[layer]['table']))
+ label = "Key:"))
+ label = mapDBInfo.layers[layer]['key']))
return infoFlexSizer
@@ -86,63 +89,36 @@
Return line id or None if no line is found"""
line = None
nselected = 0
+ data = grass.vector_what(name = self.map,
+ coord = (float(queryCoords[0]), float(queryCoords[1])),
+ distance = float(qdist))
+ if len(data) < 1:
+ return None
- if os.environ.has_key("LC_ALL"):
- locale = os.environ["LC_ALL"]
- os.environ["LC_ALL"] = "C"
+ # process attributes
+ table = data[0]['Table']
+ for key, value in data[0]['Attributes'].iteritems():
+ if len(value) < 1:
+ value = None
+ else:
+ if self.tables[table][key]['ctype'] != types.StringType:
+ value = self.tables[table][key]['ctype'] (value)
+ else:
+ value = unicodeValue(value)
+ self.tables[table][key]['values'].append(value)
- ### FIXME (implement script-style output)
- ret = gcmd.RunCommand('v.what',
- quiet = True,
- read = True,
- flags = 'a',
- map = self.map,
- east_north = '%f,%f' % \
- (float(queryCoords[0]), float(queryCoords[1])),
- distance = float(qdist))
+ ret = dict()
+ for key, value in data[0].iteritems():
+ if key == 'Attributes':
+ continue
+ ret[key] = list()
+ ret[key].append(value)
- os.environ["LC_ALL"] = locale
- data = {}
- if ret:
- readAttrb = False
- for item in ret.splitlines():
- try:
- key, value = item.split(':', 1)
- except ValueError:
- continue
- if key == 'Layer' and readAttrb:
- readAttrb = False
- if readAttrb:
- name, value = item.split(':', 1)
- name = name.strip()
- value = value.strip()
- # append value to the column
- if len(value) < 1:
- value = None
- else:
- if self.tables[table][name]['ctype'] != type(''):
- value = self.tables[table][name]['ctype'] (value.strip())
- else:
- value = unicodeValue(value.strip())
- self.tables[table][name]['values'].append(value)
- else:
- if not data.has_key(key):
- data[key] = []
- data[key].append(value.strip())
- if key == 'Table':
- table = value.strip()
- if key == 'Key column': # skip attributes
- readAttrb = True
- return data
+ return ret
- def SelectFromTable(self, layer, cols='*', where=None):
+ def SelectFromTable(self, layer, cols = '*', where = None):
"""!Select records from the table
Return number of selected records, -1 on error
@@ -155,9 +131,9 @@
table = self.layers[layer]["table"] # get table desc
# select values (only one record)
if where is None or where is '':
- sql="SELECT %s FROM %s" % (cols, table)
+ sql = "SELECT %s FROM %s" % (cols, table)
else:
- sql="SELECT %s FROM %s WHERE %s" % (cols, table, where)
+ sql = "SELECT %s FROM %s WHERE %s" % (cols, table, where)
ret = gcmd.RunCommand('db.select',
parent = self,
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py 2010-12-29 18:29:11 UTC (rev 44770)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py 2010-12-29 18:30:37 UTC (rev 44771)
@@ -7,7 +7,7 @@
- DisplayAttributesDialog
- ModifyTableRecord
