[GRASS-SVN] r44780 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules xml
svn_grass at osgeo.org
Wed Dec 29 15:22:38 EST 2010
Author: martinl
Date: 2010-12-29 12:22:38 -0800 (Wed, 29 Dec 2010)
New Revision: 44780
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: define first parameter for grassTask
(merge r44778 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-12-29 20:19:38 UTC (rev 44779)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-12-29 20:22:38 UTC (rev 44780)
@@ -356,14 +356,22 @@
self.flags = list()
self.keywords = list()
self.errorMsg = ''
+ self.firstParam = None
if grassModule is not None:
try:
processTask(tree = etree.fromstring(getInterfaceDescription(grassModule)),
task = self)
except gcmd.GException, e:
self.errorMsg = str(e)
+ self.define_first()
+ def define_first(self):
+ """!Define first parameter"""
+ if len(self.params) > 0:
+ self.firstParam = self.params[0]['name']
def get_error_msg(self):
"""!Get error message ('' for no error)"""
return self.errorMsg
@@ -535,7 +543,8 @@
self.__processModule()
self.__processParams()
self.__processFlags()
+ self.task.define_first()
def __processModule(self):
"""!Process module description"""
self.task.name = self.root.get('name', default = 'unknown')
@@ -2058,11 +2067,11 @@
try:
key, value = option.split('=', 1)
except:
- if i == 0: # add key name of first parameter if not given
+ if i == 0: # add key name of first parameter if not given
key = self.grass_task.get_options()['params'][0]['name']
value = option
else:
- raise gcmd.GException, _("Unable to parse command %s") % ' '.join(cmd)
+ raise gcmd.GException, _("Unable to parse command '%s'") % ' '.join(cmd)
element = self.grass_task.get_param(key, raiseError = False)
if not element:
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-12-29 20:19:38 UTC (rev 44779)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-12-29 20:22:38 UTC (rev 44780)
@@ -2933,7 +2933,7 @@
<help>Display the HTML man pages of GRASS</help>
<keywords>general,manual,help</keywords>
<handler>RunMenuCmd</handler>
- <command>g.manual wxGUI</command>
+ <command>g.manual entry=wxGUI</command>
</menuitem>
<separator />
<menuitem>
