[GRASS-SVN] r44805 - in grass/branches/releasebranch_6_4/gui/wxpython: gui_modules xml
Thu Dec 30 06:58:35 EST 2010
Author: martinl
Date: 2010-12-30 03:58:35 -0800 (Thu, 30 Dec 2010)
New Revision: 44805
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
   grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
wxGUI: load/save settings for GdalSelect
     menuitem 'link external formats' added to the menu
(merge r44800 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2010-12-30 11:51:42 UTC (rev 44804)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2010-12-30 11:58:35 UTC (rev 44805)
@@ -1020,6 +1020,9 @@
         self.parent = parent
         self.ogr    = ogr
         wx.Panel.__init__(self, parent = panel, id = wx.ID_ANY)
+        self.settingsBox = wx.StaticBox(parent = self, id=wx.ID_ANY,
+                                        label=" %s " % _("Settings"))
         self.inputBox = wx.StaticBox(parent = self, id=wx.ID_ANY,
                                      label=" %s " % _("Source name"))
@@ -1047,6 +1050,18 @@
             sources.append(_("Protocol"))
             self.sourceMap['pro'] = idx
+        if self.ogr:
+            self.settingsFile = os.path.join(os.path.expanduser("~"), '.grass7', 'wxOGR')
+        else:
+            self.settingsFile = os.path.join(os.path.expanduser("~"), '.grass7', 'wxGDAL')
+        self._settings = self._loadSettings()
+        self.settingsChoice = wx.Choice(parent = self, id = wx.ID_ANY)
+        self.settingsChoice.Bind(wx.EVT_CHOICE, self.OnSettingsLoad)
+        self.settingsChoice.SetItems(self._settings.keys())
+        self.btnSettings = wx.Button(parent = self, id = wx.ID_SAVE)
+        self.btnSettings.Bind(wx.EVT_BUTTON, self.OnSettingsSave)
         self.source = wx.RadioBox(parent = self, id = wx.ID_ANY,
                                   label = _('Source type'),
                                   style = wx.RA_SPECIFY_COLS,
@@ -1147,6 +1162,20 @@
     def _layout(self):
         """!Layout"""
         mainSizer = wx.BoxSizer(wx.VERTICAL)
+        settingsSizer = wx.StaticBoxSizer(self.settingsBox, wx.HORIZONTAL)
+        settingsSizer.Add(item = wx.StaticText(parent = self,
+                                               id = wx.ID_ANY,
+                                               label = _("Load settings:")),
+                          flag = wx.ALIGN_CENTER_VERTICAL | wx.RIGHT,
+                          border  = 5)
+        settingsSizer.Add(item = self.settingsChoice,
+                          proportion = 1,
+                          flag = wx.EXPAND)
+        settingsSizer.Add(item = self.btnSettings,
+                          flag = wx.LEFT,
+                          border = 5)
         inputSizer = wx.StaticBoxSizer(self.inputBox, wx.HORIZONTAL)
         self.dsnSizer = wx.GridBagSizer(vgap=3, hgap=3)
@@ -1169,9 +1198,11 @@
         inputSizer.Add(item=self.dsnSizer, proportion=1,
                        flag=wx.EXPAND | wx.ALL)
+        mainSizer.Add(item=settingsSizer, proportion=0,
+                      flag=wx.ALL | wx.EXPAND, border=5)
         mainSizer.Add(item=self.source, proportion=0,
-                      flag=wx.ALL | wx.EXPAND, border=5)
+                      flag=wx.LEFT | wx.RIGHT | wx.EXPAND, border=5)
         mainSizer.Add(item=inputSizer, proportion=0,
@@ -1186,9 +1217,79 @@
         return pattern
-    def OnSetType(self, event):
+    def OnSettingsLoad(self, event):
+        """!Load named settings"""
+        name = event.GetString()
+        if not self._settings.has_key(name):
+            gcmd.GError(parent = self,
+                        message = _("Settings named '%s' not found") % name)
+            return
+        data = self._settings[name]
+        self.OnSetType(event = None, sel = self.sourceMap[data[0]])
+        self.OnSetFormat(event = None, format = data[2])
+        self.OnSetDsn(event = None, path = data[1])
+    def OnSettingsSave(self, event):
+        """!Save settings"""
+        dlg = wx.TextEntryDialog(parent = self,
+                                 message = _("Name:"),
+                                 caption = _("Save settings"))
+        if dlg.ShowModal() != wx.ID_OK:
+            return
+        if not dlg.GetValue():
+            gcmd.GMessage(parent = self,
+                          message = _("Name not given, settings is not saved."))
+            return
+        data = self._loadSettings()
+        try:
+            fd = open(self.settingsFile, 'w')
+            fd.write(dlg.GetValue() + ';' + self.dsnType + ';' +
+                     self._getDsn() + ';' +
+                     self.format.GetStringSelection())
+            fd.write('\n')
+        except IOError:
+                        message = _("Unable to save settings."))
+            return
+        fd.close()
+        dlg.Destroy()
+    def _loadSettings(self):
+        """!Load settings from the file
+        The file is defined by self.SettingsFile.
+        @return parsed dict
+        @return empty dict on error
+        data = dict()
+        if not os.path.exists(self.settingsFile):
+            return data
+        try:
+            fd = open(self.settingsFile, 'r')
+            for line in fd.readlines():
+                try:
+                    name, ftype, dsn, format = line.rstrip('\n').split(';')
+                    data[name] = (ftype, dsn, format)
+                except ValueError:
+                    pass
+        except IOError:
+            return data
+        fd.close()
+        return data
+    def OnSetType(self, event, sel = None):
         """!Datasource type changed"""
-        sel = event.GetSelection()
+        if event:
+            sel = event.GetSelection()
+        else:
+            self.source.SetSelection(sel)
         win = self.input[self.dsnType][1]
         self.dsnSizer.Remove(win)
         win.Hide()
@@ -1222,7 +1323,7 @@
         if self.parent.GetName() == 'MultiImportDialog':
             self.parent.list.DeleteAllItems()
         self.format.SetItems(self.input[self.dsnType][2])
         if sel in (self.sourceMap['file'],
                    self.sourceMap['dir']):
@@ -1246,19 +1347,35 @@
         self.dsnSizer.Layout()
-    def OnSetDsn(self, event):
+    def _getDsn(self):
+        """!Get datasource name"""
+        if self.format.GetStringSelection() == 'PostgreSQL':
+            return 'PG:dbname=%s' % self.input[self.dsnType][1].GetStringSelection()
+        return self.input[self.dsnType][1].GetValue()
+    def OnSetDsn(self, event, path = None):
         """!Input DXF file/OGR dsn defined, update list of layer widget"""
-        path = event.GetString()
+        if event:
+            path = event.GetString()
+        else:
+                for item in path.split(':', 1)[1].split(','):
+                    key, value = item.split('=', 1)
+                    if key == 'dbname':
+                        self.input[self.dsnType][1].SetStringSelection(value)
+                        break
+            else:
+                self.input[self.dsnType][1].SetValue(path)
         if not path:
             return
         data = list()
         layerId = 1
-        if self.format.GetStringSelection() == 'PostgreSQL':
-            dsn = 'PG:dbname=%s' % self.input[self.dsnType][1].GetValue()
-        else:
-            dsn = self.input[self.dsnType][1].GetValue()
+        dsn = self._getDsn()
         if self.dsnType == 'file':
             baseName = os.path.basename(dsn)
             grassName = utils.GetValidLayerName(baseName.split('.', -1)[0])
@@ -1302,9 +1419,10 @@
             else:
                 self.parent.btn_run.Enable(False)
-        event.Skip()
+        if event:
+            event.Skip()
-    def OnSetFormat(self, event):
+    def OnSetFormat(self, event, format = None):
         """!Format changed"""
         if self.dsnType not in ['file', 'db']:
             return
@@ -1317,7 +1435,10 @@
         else: # database
             win.Hide()
-        format = event.GetString()
+        if event:
+            format = event.GetString()
+        else:
+            self.format.SetStringSelection(format)
             try:
@@ -1374,7 +1495,7 @@
     def GetDsn(self):
         """!Get DSN"""
-            return 'PG:dbname=%s' % self.input[self.dsnType][1].GetValue()
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2010-12-30 11:51:42 UTC (rev 44804)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2010-12-30 11:58:35 UTC (rev 44805)
@@ -54,19 +54,12 @@
 	  <label>Import raster data</label>
 	  <items>
 	    <menuitem>
-	      <label>Import raster data</label>
+	      <label>Common import formats</label>
 	      <help>Import raster data into a GRASS map layer using GDAL.</help>
 	      <keywords>raster,import</keywords>
 	      <handler>OnImportGdalLayers</handler>
 	      <command>r.in.gdal</command>
 	    </menuitem>
-	    <menuitem>
-	      <label>Link external raster data</label>
-	      <help>Link GDAL supported raster data as a pseudo GRASS raster map layer.</help>
-	      <keywords>raster,import</keywords>
-              <handler>OnLinkGdalLayers</handler>
-	      <command>r.external</command>
-	    </menuitem>
 	    <separator />
 	    <menuitem>
 	      <label>Aggregate ASCII xyz import</label>
@@ -151,19 +144,12 @@
 	  <label>Import vector data</label>
 	  <items>
 	    <menuitem>
-	      <label>Import vector data</label>
 	      <help>Converts vector layers into a GRASS vector map using OGR.</help>
 	      <keywords>vector,import</keywords>
 	      <handler>OnImportOgrLayers</handler>
 	      <command>v.in.ogr</command>
 	    </menuitem>
-	    <menuitem>
-	      <label>Link external vector data</label>
-	      <help>Creates a new pseudo-vector map as a link to an OGR-supported layer.</help>
-	      <keywords>vector</keywords>
-              <handler>OnLinkOgrLayers</handler>
-	      <command>v.external</command>
-	    </menuitem>
 	    <separator />
 	    <menuitem>
 	      <label>ASCII points/GRASS ASCII vector import</label>
@@ -495,6 +481,26 @@
 	</menu>
 	<separator />
 	<menu>
+	  <label>Link external formats</label>
+	  <items>
+	    <menuitem>
+	      <label>Link external raster data</label>
+	      <help>Link GDAL supported raster data as a pseudo GRASS raster map layer.</help>
+	      <keywords>raster,import</keywords>
+              <handler>OnLinkGdalLayers</handler>
+	      <command>r.external</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Link external vector data</label>
+	      <help>Creates a new pseudo-vector map as a link to an OGR-supported layer.</help>
+	      <keywords>vector</keywords>
+              <handler>OnLinkOgrLayers</handler>
+	      <command>v.external</command>
+	    </menuitem>
+	  </items>
+	</menu>
+	<separator />
+	<menu>
 	  <label>Manage maps and volumes</label>
 	  <items>
 	    <menuitem>
@@ -1775,7 +1781,7 @@
 	    </menuitem>
 	    <menuitem>
 	      <label>Linear regression</label>
-	      <help>Calculates linear regression from two raster maps: y = a + b*x</help>
+	      <help>Calculates linear regression from two raster maps: y = a + b*x.</help>
 	      <keywords>raster,statistics</keywords>
 	      <handler>OnMenuCmd</handler>
 	      <command>r.regression.line</command>
@@ -2595,7 +2601,7 @@
 	    </menuitem>
 	    <menuitem>
 	      <label>Principal components</label>
-	      <help>Principal components analysis (pca) program for image processing.</help>
+	      <help>Principal components analysis (PCA) for image processing.</help>
 	      <keywords>imagery,image transformation,PCA</keywords>
 	      <command>i.pca</command>
