[GRASS-SVN] r44811 - in grass/trunk: lib/vector/Vlib
raster/r.external vector/v.external
svn_grass at osgeo.org
Thu Dec 30 11:52:24 EST 2010
Author: martinl
Date: 2010-12-30 08:52:24 -0800 (Thu, 30 Dec 2010)
New Revision: 44811
grass/trunk/lib/vector/Vlib/header.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/open_ogr.c
grass/trunk/raster/r.external/main.c
grass/trunk/vector/v.external/list.c
grass/trunk/vector/v.external/local_proto.h
grass/trunk/vector/v.external/main.c
vlib: initial suppor for 3D vector data linked via OGR
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c 2010-12-30 13:08:24 UTC (rev 44810)
+++ grass/trunk/lib/vector/Vlib/header.c 2010-12-30 16:52:24 UTC (rev 44811)
@@ -314,13 +314,39 @@
Ogr_geom_type = OGR_FD_GetGeomType(Ogr_feature_defn);
switch(Ogr_geom_type) {
case wkbPoint:
- return G_store(_("point"));
+ return G_store(_("Point"));
+ case wkbMultiPoint:
+ return G_store(_("MultiPoint"));
case wkbLineString:
- return G_store(_("linestring"));
+ return G_store(_("LineString"));
+ case wkbMultiLineString:
+ return G_store(_("MultiLineString"));
case wkbPolygon:
- return G_store(_("polygon"));
+ return G_store(_("Polygon"));
+ case wkbMultiPolygon:
+ return G_store(_("MultiPolygon"));
+ case wkbGeometryCollection:
+ return G_store(_("GeometryCollection"));
+ case wkbNone:
+ return G_store(_("None"));
+ case wkbLinearRing:
+ return G_store(_("LinearRing"));
+ case wkbPoint25D:
+ return G_store(_("3D Point"));
+ case wkbMultiPoint25D:
+ return G_store(_("3D MultiPoint"));
+ case wkbLineString25D:
+ return G_store(_("3D LineString"));
+ case wkbMultiLineString25D:
+ return G_store(_("3D MultiLineString"));
+ case wkbPolygon25D:
+ return G_store(_("3D Polygon"));
+ case wkbMultiPolygon25D:
+ return G_store(_("3D MultiPolygon"));
+ case wkbGeometryCollection25D:
+ return G_store(_("3D GeometryCollection"));
default:
- return G_store(_("unknown"));
+ return G_store(_("Unknown"));
#endif
return NULL;
@@ -329,6 +355,8 @@
\brief Check if vector map is 3D
+ Check vector map header.
\param Map pointer to Map_info structure
\return TRUE vector map is 3D
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2010-12-30 13:08:24 UTC (rev 44810)
+++ grass/trunk/lib/vector/Vlib/open.c 2010-12-30 16:52:24 UTC (rev 44811)
@@ -177,17 +177,17 @@
/* initialize Map->head */
Vect__init_head(Map);
/* initialize support structures for 2D, update to 3D when reading support files */
- Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = 0;
+ Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = WITHOUT_Z;
/* initialize Map->plus */
dig_init_plus(&(Map->plus));
/* check OGR mapset */
- ogr_mapset = 0;
+ ogr_mapset = FALSE;
if (G_name_is_fully_qualified(name, xname, xmapset)) {
if (strcasecmp(xmapset, "ogr") == 0) {
/* unique OGR mapset detected */
G_debug(1, "OGR mapset detected");
- ogr_mapset = 1;
+ ogr_mapset = TRUE;
Map->fInfo.ogr.dsn = G_store(xname);
if (layer) {
Map->fInfo.ogr.layer_name = G_store(layer); /* no layer to be open */
@@ -491,7 +491,7 @@
unlink(file_path);
- return (level);
+ return level;
@@ -920,7 +920,7 @@
* \brief Open topology file ('topo')
* \param[in,out] Map pointer to Map_info structure
- * \param head_only open only head
+ * \param head_only TRUE to read only header
* \return 0 on success
* \return 1 file does not exist
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-30 13:08:24 UTC (rev 44810)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2010-12-30 16:52:24 UTC (rev 44811)
@@ -37,8 +37,7 @@
Map->fInfo.ogr.layer_name must be set before.
- \param update non-zero for write mode, otherwise read-only
- (write mode is currently not supported)
+ \param update TRUE for write mode, otherwise read-only
\return 0 success
\return -1 error
@@ -49,15 +48,10 @@
OGRDataSourceH Ogr_ds;
OGRLayerH Ogr_layer;
OGRFeatureDefnH Ogr_featuredefn;
+ OGRwkbGeometryType Ogr_geom_type;
Ogr_layer = NULL;
- if (update) {
- G_warning(_("Write mode is not supported for OGR format"));
- return -1;
+ Ogr_geom_type = wkbUnknown;
if (!Map->fInfo.ogr.dsn) {
G_fatal_error(_("OGR datasource not defined"));
@@ -90,6 +84,7 @@
Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
if (strcmp(OGR_FD_GetName(Ogr_featuredefn), Map->fInfo.ogr.layer_name) == 0) {
+ Ogr_geom_type = OGR_FD_GetGeomType(Ogr_featuredefn);
layer = i;
break;
@@ -109,12 +104,21 @@
Map->fInfo.ogr.lines_num = 0;
Map->fInfo.ogr.lines_next = 0;
- Map->head.with_z = WITHOUT_Z; /* TODO: 3D */
+ switch(Ogr_geom_type) {
+ case wkbPoint25D: case wkbLineString25D: case wkbPolygon25D:
+ case wkbMultiPoint25D: case wkbMultiLineString25D: case wkbMultiPolygon25D:
+ Map->head.with_z = WITH_Z;
+ break;
+ default:
+ Map->head.with_z = WITHOUT_Z;
+ break;
Map->fInfo.ogr.feature_cache = NULL;
Map->fInfo.ogr.feature_cache_id = -1; /* FID >= 0 */
- return (0);
+ return 0;
@@ -219,7 +223,7 @@
int i, nlayers;
char **Ogr_layer_options;
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c 2010-12-30 13:08:24 UTC (rev 44810)
+++ grass/trunk/raster/r.external/main.c 2010-12-30 16:52:24 UTC (rev 44811)
@@ -57,7 +57,7 @@
int iDr;
- fprintf(stdout, _("Supported Formats:\n"));
+ G_message(_("Supported formats:"));
for (iDr = 0; iDr < GDALGetDriverCount(); iDr++) {
GDALDriverH hDriver = GDALGetDriver(iDr);
const char *pszRWFlag;
@@ -69,7 +69,7 @@
else
pszRWFlag = "ro";
- fprintf(stdout, " %s (%s): %s\n",
+ fprintf(stdout, " %s (%s): %s\n",
GDALGetDriverShortName(hDriver),
pszRWFlag, GDALGetDriverLongName(hDriver));
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c 2010-12-30 13:08:24 UTC (rev 44810)
+++ grass/trunk/vector/v.external/list.c 2010-12-30 16:52:24 UTC (rev 44811)
@@ -1,4 +1,5 @@
#include <grass/gis.h>
+#include <grass/vector.h>
#include <grass/glocale.h>
#include "ogr_api.h"
@@ -9,14 +10,14 @@
OGRSFDriverH Ogr_driver;
- G_message(_("Available drivers:\n"));
for (i = 0; i < OGRGetDriverCount(); i++) {
Ogr_driver = OGRGetDriver(i);
fprintf(fd, " %s\n", OGR_Dr_GetName(Ogr_driver));
-int list_layers(FILE *fd, const char *dsn, const char *layer)
+int list_layers(FILE *fd, const char *dsn, const char *layer, int *is3D)
int i, ret;
int nlayers;
@@ -25,6 +26,7 @@
ret = -1;
@@ -50,6 +52,19 @@
if (layer)
if (strcmp(layer_name, layer) == 0) {
+ if (is3D) {
+ *is3D = WITH_Z;
+ break;
+ default:
+ *is3D = WITHOUT_Z;
+ break;
ret = i;
Modified: grass/trunk/vector/v.external/local_proto.h
--- grass/trunk/vector/v.external/local_proto.h 2010-12-30 13:08:24 UTC (rev 44810)
+++ grass/trunk/vector/v.external/local_proto.h 2010-12-30 16:52:24 UTC (rev 44811)
@@ -18,6 +18,6 @@
/* list.c */
void list_formats(FILE *);
-int list_layers(FILE *, const char *, const char *);
+int list_layers(FILE *, const char *, const char *, int *);
#endif
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2010-12-30 13:08:24 UTC (rev 44810)
+++ grass/trunk/vector/v.external/main.c 2010-12-30 16:52:24 UTC (rev 44811)
@@ -8,7 +8,7 @@
* PURPOSE: Create a new vector as a link to OGR layer (read-only)
- * COPYRIGHT: (C) 2003-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2010 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -39,7 +39,7 @@
FILE *fd;
- int ilayer;
+ int ilayer, is3D;
char buf[GPATH_MAX];
G_gisinit(argv[0]);
@@ -64,7 +64,7 @@
if (flags.layer->answer) {
if (!options.dsn->answer)
G_fatal_error(_("Required parameter <%s> not set"), options.dsn->key);
- list_layers(stdout, options.dsn->answer, NULL);
+ list_layers(stdout, options.dsn->answer, NULL, NULL);
exit(EXIT_SUCCESS);
@@ -75,15 +75,14 @@
G_fatal_error(_("Required parameter <%s> not set"), options.layer->key);
- ilayer = list_layers(NULL, options.dsn->answer, options.layer->answer);
+ ilayer = list_layers(NULL, options.dsn->answer, options.layer->answer, &is3D);
if (ilayer == -1) {
G_fatal_error(_("Layer <%s> not available"), options.layer->answer);
G_debug(2, "layer '%s' was found", options.layer->answer);
- /* TODO: support 3d vector data */
- Vect_open_new(&Map, options.output->answer, WITHOUT_Z);
+ Vect_open_new(&Map, options.output->answer, is3D);
Vect_hist_command(&Map);
Vect_close(&Map);
@@ -116,7 +115,7 @@
Vect_close(&Map);
- G_done_msg(_("<%s> created."), options.output->answer);
+ G_done_msg(_("Link to vector map <%s> created."), options.output->answer);
exit(EXIT_SUCCESS);
