[GRASS-SVN] r44813 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Dec 30 13:16:27 EST 2010
Author: martinl
Date: 2010-12-30 10:16:27 -0800 (Thu, 30 Dec 2010)
New Revision: 44813
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
wxGUI: cosmetics - coding style
(merge r44812 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2010-12-30 18:11:45 UTC (rev 44812)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2010-12-30 18:16:27 UTC (rev 44813)
@@ -7,7 +7,7 @@
- MapWindow
- BufferedWindow
-(C) 2006-2009 by the GRASS Development Team
+(C) 2006-2010 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -107,25 +107,25 @@
len(self.polycoords) > 0:
# for linear feature show segment and total length
distance_seg = self.Distance(self.polycoords[-1],
- (e, n), screen=False)[0]
+ (e, n), screen = False)[0]
distance_tot = distance_seg
for idx in range(1, len(self.polycoords)):
distance_tot += self.Distance(self.polycoords[idx-1],
self.polycoords[idx],
- screen=False )[0]
+ screen = False)[0]
self.parent.statusbar.SetStatusText("%.*f, %.*f (seg: %.*f; tot: %.*f)" % \
(precision, e, precision, n,
precision, distance_seg,
precision, distance_tot), 0)
else:
if self.parent.statusbarWin['projection'].IsChecked():
- if not UserSettings.Get(group='projection', key='statusbar', subkey='proj4'):
+ if not UserSettings.Get(group = 'projection', key = 'statusbar', subkey = 'proj4'):
self.parent.statusbar.SetStatusText(_("Projection not defined (check the settings)"), 0)
else:
proj, coord = utils.ReprojectCoordinates(coord = (e, n),
- projOut = UserSettings.Get(group='projection',
- key='statusbar',
- subkey='proj4'),
+ projOut = UserSettings.Get(group = 'projection',
+ key = 'statusbar',
+ subkey = 'proj4'),
flags = 'd')
if coord:
@@ -279,10 +279,10 @@
# zoom objects
self.zoomhistory = [] # list of past zoom extents
- self.currzoom = 0 # current set of extents in zoom history being used
- self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
+ self.currzoom = 0 # current set of extents in zoom history being used
+ self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
self.hitradius = 10 # distance for selecting map decorations
- self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
+ self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
# OnSize called to make sure the buffer is initialized.
# This might result in OnSize getting called twice on some
@@ -342,9 +342,8 @@
return True
- def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
- Draws map and overlay decorations
+ def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0, 0, 0, 0]):
+ """!Draws map and overlay decorations
if drawid == None:
if pdctype == 'image' and img:
@@ -369,7 +368,7 @@
### pdc.Clear()
- Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
+ Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype = %s, coord=%s" % \
(drawid, pdctype, coords))
# set PseudoDC id
@@ -436,10 +435,10 @@
x,y = point
xlist.append(x)
ylist.append(y)
- x1=min(xlist)
- x2=max(xlist)
- y1=min(ylist)
- y2=max(ylist)
+ x1 = min(xlist)
+ x2 = max(xlist)
+ y1 = min(ylist)
+ y2 = max(ylist)
pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
# self.ovlcoords[drawid] = [x1,y1,x2,y2]
@@ -478,8 +477,7 @@
return drawid
def TextBounds(self, textinfo):
- Return text boundary data
+ """!Return text boundary data
@param textinfo text metadata (text, font, color, rotation)
@param coords reference point
@@ -653,7 +651,7 @@
idle time instead of multiple times during resizing.
if self.resize:
- self.UpdateMap(render=True)
+ self.UpdateMap(render = True)
event.Skip()
@@ -666,13 +664,13 @@
@param width image width
@param height image height
- busy = wx.BusyInfo(message=_("Please wait, exporting image..."),
- parent=self)
+ busy = wx.BusyInfo(message = _("Please wait, exporting image..."),
+ parent = self)
wx.Yield()
self.Map.ChangeMapSize((width, height))
ibuffer = wx.EmptyBitmap(max(1, width), max(1, height))
- self.Map.Render(force=True, windres = True)
+ self.Map.Render(force = True, windres = True)
img = self.GetImage()
self.Draw(self.pdc, img, drawid = 99)
dc = wx.BufferedPaintDC(self, ibuffer)
@@ -697,7 +695,7 @@
@return list of images
imgs = []
- for overlay in self.Map.GetListOfLayers(l_type="overlay", l_active=True):
+ for overlay in self.Map.GetListOfLayers(l_type = "overlay", l_active = True):
if os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
img = wx.Image(overlay.mapfile, wx.BITMAP_TYPE_ANY)
self.imagedict[img] = { 'id' : overlay.id,
@@ -724,7 +722,7 @@
return img
- def UpdateMap(self, render=True, renderVector=True):
+ def UpdateMap(self, render = True, renderVector = True):
Updates the canvas anytime there is a change to the
underlaying images or to the geometry of the canvas.
@@ -794,14 +792,14 @@
# draw background map image to PseudoDC
if not self.img:
- self.Draw(self.pdc, pdctype='clear')
+ self.Draw(self.pdc, pdctype = 'clear')
else:
try:
id = self.imagedict[self.img]['id']
except:
return False
- self.Draw(self.pdc, self.img, drawid=id)
+ self.Draw(self.pdc, self.img, drawid = id)
# render vector map layer
@@ -843,12 +841,12 @@
# draw any active and defined overlays
if self.imagedict[img]['layer'].IsActive():
id = self.imagedict[img]['id']
- self.Draw(self.pdc, img=img, drawid=id,
- pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
+ self.Draw(self.pdc, img = img, drawid = id,
+ pdctype = self.overlays[id]['pdcType'], coords = self.overlays[id]['coords'])
for id in self.textdict.keys():
- self.Draw(self.pdc, img=self.textdict[id], drawid=id,
- pdctype='text', coords=[10, 10, 10, 10])
+ self.Draw(self.pdc, img = self.textdict[id], drawid = id,
+ pdctype = 'text', coords = [10, 10, 10, 10])
# optionally draw computational extent box
self.DrawCompRegionExtent()
@@ -883,7 +881,7 @@
# clear measurement
if self.mouse["use"] == "measure":
- self.ClearLines(pdc=self.pdcTmp)
+ self.ClearLines(pdc = self.pdcTmp)
self.polycoords = []
self.mouse['use'] = 'pointer'
self.mouse['box'] = 'point'
@@ -924,11 +922,11 @@
dispReg = self.Map.GetCurrentRegion()
reg = None
if self.IsInRegion(dispReg, compReg):
- self.polypen = wx.Pen(colour=wx.Colour(0, 0, 255, 128), width=3, style=wx.SOLID)
+ self.polypen = wx.Pen(colour = wx.Colour(0, 0, 255, 128), width = 3, style = wx.SOLID)
reg = dispReg
else:
- self.polypen = wx.Pen(colour=wx.Colour(255, 0, 0, 128),
- width=3, style=wx.SOLID)
+ self.polypen = wx.Pen(colour = wx.Colour(255, 0, 0, 128),
+ width = 3, style = wx.SOLID)
reg = compReg
self.regionCoords = []
@@ -938,7 +936,7 @@
self.regionCoords.append((reg['w'], reg['s']))
self.regionCoords.append((reg['w'], reg['n']))
# draw region extent
- self.DrawLines(pdc=self.pdcDec, polycoords=self.regionCoords)
+ self.DrawLines(pdc = self.pdcDec, polycoords = self.regionCoords)
def IsInRegion(self, region, refRegion):
@@ -962,13 +960,13 @@
Erase the canvas
if self.pdcVector:
- self.Draw(self.pdcVector, pdctype='clear')
+ self.Draw(self.pdcVector, pdctype = 'clear')
- self.Draw(self.pdcDec, pdctype='clear')
- self.Draw(self.pdcTmp, pdctype='clear')
+ self.Draw(self.pdcDec, pdctype = 'clear')
+ self.Draw(self.pdcTmp, pdctype = 'clear')
def DragMap(self, moveto):
@@ -1019,7 +1017,7 @@
self.RefreshRect(r, False)
self.lastpos = (event.GetX(), event.GetY())
- def MouseDraw(self, pdc=None, begin=None, end=None):
+ def MouseDraw(self, pdc = None, begin = None, end = None):
Mouse box or line from 'begin' to 'end'
@@ -1054,15 +1052,15 @@
pass
pdc.SetId(boxid)
- self.Draw(pdc, drawid=boxid, pdctype='box', coords=mousecoords)
+ self.Draw(pdc, drawid = boxid, pdctype = 'box', coords = mousecoords)
elif self.mouse['box'] == "line" or self.mouse['box'] == 'point':
self.lineid = wx.ID_NEW
mousecoords = [begin[0], begin[1], \
end[0], end[1]]
- x1=min(begin[0],end[0])
- x2=max(begin[0],end[0])
- y1=min(begin[1],end[1])
- y2=max(begin[1],end[1])
+ x1 = min(begin[0],end[0])
+ x2 = max(begin[0],end[0])
+ y1 = min(begin[1],end[1])
+ y2 = max(begin[1],end[1])
r = wx.Rect(x1,y1,x2-x1,y2-y1)
r.Inflate(4,4)
try:
@@ -1071,9 +1069,9 @@
pass
pdc.SetId(self.lineid)
- self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
+ self.Draw(pdc, drawid = self.lineid, pdctype = 'line', coords = mousecoords)
- def DrawLines(self, pdc=None, polycoords=None):
+ def DrawLines(self, pdc = None, polycoords = None):
Draw polyline in PseudoDC
@@ -1096,7 +1094,7 @@
for p in polycoords:
coords.append(self.Cell2Pixel(p))
- self.Draw(pdc, drawid=self.plineid, pdctype='polyline', coords=coords)
+ self.Draw(pdc, drawid = self.plineid, pdctype = 'polyline', coords = coords)
Debug.msg (4, "BufferedWindow.DrawLines(): coords=%s, id=%s" % \
(coords, self.plineid))
@@ -1105,8 +1103,8 @@
return -1
- def DrawCross(self, pdc, coords, size, rotation=0,
- text=None, textAlign='lr', textOffset=(5, 5)):
+ def DrawCross(self, pdc, coords, size, rotation = 0,
+ text = None, textAlign = 'lr', textOffset = (5, 5)):
"""!Draw cross in PseudoDC
@todo implement rotation
@@ -1125,7 +1123,7 @@
self.lineid = wx.NewId()
for lineCoords in coordsCross:
- self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=lineCoords)
+ self.Draw(pdc, drawid = self.lineid, pdctype = 'line', coords = lineCoords)
if not text:
return self.lineid
@@ -1139,8 +1137,8 @@
else:
coord = [coords[0] - textOffset[0], coords[1] + textOffset[1], 0, 0]
- self.Draw(pdc, img=text,
- pdctype='text', coords=coord)
+ self.Draw(pdc, img = text,
+ pdctype = 'text', coords = coord)
return self.lineid
@@ -1266,13 +1264,12 @@
digitToolbar.GetAction() in ("moveLine",) and
digitClass.driver.GetSelected() > 0)):
# draw box only when left mouse button is pressed
- self.MouseDraw(pdc=self.pdcTmp)
+ self.MouseDraw(pdc = self.pdcTmp)
# event.Skip()
def OnLeftDownVDigitAddLine(self, event):
- Left mouse button down - vector digitizer add new line
+ """!Left mouse button down - vector digitizer add new line
action
digitToolbar = self.parent.toolbars['vdigit']
@@ -1295,23 +1292,23 @@
if fid < 0:
return
- self.UpdateMap(render=False) # redraw map
+ self.UpdateMap(render = False) # redraw map
# add new record into atribute table
- if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
+ if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled') is True:
# select attributes based on layer and category
cats = { fid : {
- UserSettings.Get(group='vdigit', key="layer", subkey='value') :
- (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
+ UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value') :
+ (UserSettings.Get(group = 'vdigit', key = "category", subkey = 'value'), )
posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
self.mouse['end'][1] + self.dialogOffset))
- addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
- cats=cats,
- pos=posWindow,
- action="add")
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapLayer,
+ cats = cats,
+ pos = posWindow,
+ action = "add")
if not point:
self.__geomAttrb(fid, addRecordDlg, 'area', digitClass,
@@ -1321,7 +1318,7 @@
if addRecordDlg.mapDBInfo and \
addRecordDlg.ShowModal() == wx.ID_OK:
- sqlfile = tempfile.NamedTemporaryFile(mode="w")
+ sqlfile = tempfile.NamedTemporaryFile(mode = "w")
for sql in addRecordDlg.GetSQLString():
sqlfile.file.write(sql + ";\n")
sqlfile.file.flush()
@@ -1337,7 +1334,7 @@
elif digitToolbar.GetAction('type') in ["line", "boundary"]:
# add new point to the line
self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
- self.DrawLines(pdc=self.pdcTmp)
+ self.DrawLines(pdc = self.pdcTmp)
def __geomAttrb(self, fid, dialog, attrb, digit, mapLayer):
"""!Trac geometry attributes?"""
@@ -1358,7 +1355,7 @@
type = 'length'
if val > 0:
- layer = int(UserSettings.Get(group='vdigit', key="layer", subkey='value'))
+ layer = int(UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value'))
column = vdigit['geomAttr'][attrb]['column']
val = UnitsConvertValue(val, type, vdigit['geomAttr'][attrb]['units'])
dialog.SetColumnValue(layer, column, val)
@@ -1379,7 +1376,7 @@
return
dbInfo = gselect.VectorDBInfo(vectorName)
for fid in fids:
for layer, cats in digit.GetLineCats(fid).iteritems():
table = dbInfo.GetTable(layer)
@@ -1421,7 +1418,7 @@
for atm in self.lmgr.dialogs['atm']:
atmVector = atm.GetVectorName()
if atmVector == digitVector:
- layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
+ layer = UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value')
# TODO: use AddDataRow instead
atm.LoadData(layer)
@@ -1435,7 +1432,7 @@
self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
self.vdigitMove['id'].append(wx.NewId())
def OnLeftDownVDigitMoveLine(self, event):
@@ -1455,10 +1452,10 @@
if digitToolbar.GetAction() in ["moveVertex", "editLine"]:
# set pen
- pcolor = UserSettings.Get(group='vdigit', key="symbol",
- subkey=["highlight", "color"])
- self.pen = self.polypen = wx.Pen(colour=pcolor,
- width=2, style=wx.SHORT_DASH)
+ pcolor = UserSettings.Get(group = 'vdigit', key = "symbol",
+ subkey = ["highlight", "color"])
+ self.pen = self.polypen = wx.Pen(colour = pcolor,
+ width = 2, style = wx.SHORT_DASH)
self.pdcTmp.SetPen(self.polypen)
def OnLeftDownVDigitDisplayCA(self, event):
@@ -1485,8 +1482,8 @@
digitClass.GetSelectType()) is None:
return
- if UserSettings.Get(group='vdigit', key='checkForDupl',
- subkey='enabled'):
+ if UserSettings.Get(group = 'vdigit', key = 'checkForDupl',
+ subkey = 'enabled'):
lines = digitClass.driver.GetSelected()
else:
lines = (digitClass.driver.GetSelected()[0],) # only first found
@@ -1501,12 +1498,12 @@
# select attributes based on coordinates (all layers)
if self.parent.dialogs['attributes'] is None:
self.parent.dialogs['attributes'] = \
- dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
- cats=cats,
- action="update")
+ dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapLayer,
+ cats = cats,
+ action = "update")
else:
# upgrade dialog
- self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
+ self.parent.dialogs['attributes'].UpdateDialog(cats = cats)
if self.parent.dialogs['attributes']:
if len(cats.keys()) > 0:
@@ -1521,15 +1518,15 @@
else: # displayCats
if self.parent.dialogs['category'] is None:
# open new dialog
- dlg = VDigitCategoryDialog(parent=self,
- map=mapLayer,
- cats=cats,
- pos=posWindow,
- title=_("Update categories"))
+ dlg = VDigitCategoryDialog(parent = self,
+ map = mapLayer,
+ cats = cats,
+ pos = posWindow,
+ title = _("Update categories"))
self.parent.dialogs['category'] = dlg
else:
# update currently open dialog
- self.parent.dialogs['category'].UpdateDialog(cats=cats)
+ self.parent.dialogs['category'].UpdateDialog(cats = cats)
if self.parent.dialogs['category']:
@@ -1540,7 +1537,7 @@
if self.parent.dialogs['category'].IsShown():
self.parent.dialogs['category'].Hide()
def OnLeftDownVDigitCopyCA(self, event):
@@ -1568,8 +1565,7 @@
self.layerTmp = None
def OnLeftDownVDigitBulkLine(self, event):
- Left mouse button down - vector digitizer label 3d vector
+ """!Left mouse button down - vector digitizer label 3d vector
lines
@@ -1577,7 +1573,7 @@
if len(self.polycoords) > 1: # start new line
if len(self.polycoords) == 1:
begin = self.Pixel2Cell(self.polycoords[-1])
@@ -1619,10 +1615,10 @@
try:
mapLayer = digitToolbar.GetLayer().GetName()
except:
- wx.MessageBox(parent=self,
- message=_("No vector map selected for editing."),
- caption=_("Vector digitizer"),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ wx.MessageBox(parent = self,
+ message = _("No vector map selected for editing."),
+ caption = _("Vector digitizer"),
+ style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
event.Skip()
return
@@ -1631,8 +1627,8 @@
"removeVertex",
"editLine"):
# set pen
- self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
- self.polypen = wx.Pen(colour='dark green', width=2, style=wx.SOLID)
+ self.pen = wx.Pen(colour = 'Red', width = 2, style = wx.SHORT_DASH)
+ self.polypen = wx.Pen(colour = 'dark green', width = 2, style = wx.SOLID)
if digitToolbar.GetAction() in ("addVertex",
"removeVertex",
@@ -1698,7 +1694,7 @@
if digitToolbar.GetAction() in ("moveVertex",
"editLine"):
if len(digitClass.driver.GetSelected()) == 0:
- nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
+ nselected = digitClass.driver.SelectLineByPoint(pos1, type = VDigit_Lines_Type)
if digitToolbar.GetAction() == "editLine":
try:
@@ -1708,7 +1704,7 @@
if selVertex:
# self.UpdateMap(render=False)
- ids = digitClass.driver.GetSelected(grassId=False)
+ ids = digitClass.driver.GetSelected(grassId = False)
# move this line to tmp layer
for id in ids:
@@ -1726,7 +1722,7 @@
digitClass.driver.SetSelected([])
del self.vdigitMove
elif digitToolbar.GetAction() in ("copyCats",
"copyAttrs"):
@@ -1781,7 +1777,7 @@
# get pseudoDC id of objects which should be redrawn
if digitToolbar.GetAction() == "moveLine":
# -> move line
- self.vdigitMove['id'] = digitClass.driver.GetSelected(grassId=False)
+ self.vdigitMove['id'] = digitClass.driver.GetSelected(grassId = False)
self.vdigitMove['coord'] = digitClass.driver.GetSelectedCoord()
else: # moveVertex
self.vdigitMove['id'] = digitClass.driver.GetSelectedVertex(pos1)
@@ -1791,31 +1787,31 @@
# check for duplicates
- if UserSettings.Get(group='vdigit', key='checkForDupl', subkey='enabled') is True:
+ if UserSettings.Get(group = 'vdigit', key = 'checkForDupl', subkey = 'enabled') is True:
dupl = digitClass.driver.GetDuplicates()
if dupl:
- dlg = VDigitDuplicatesDialog(parent=self, data=dupl, pos=posWindow)
+ dlg = VDigitDuplicatesDialog(parent = self, data = dupl, pos = posWindow)
if dlg.ShowModal() == wx.ID_OK:
digitClass.driver.UnSelect(dlg.GetUnSelected())
# update selected
if digitToolbar.GetAction() != "editLine":
# -> move line || move vertex
else: # no vector object found
if not (digitToolbar.GetAction() in ("moveLine",
"moveVertex") and \
len(self.vdigitMove['id']) > 0):
# avoid left-click when features are already selected
- self.UpdateMap(render=False, renderVector=False)
+ self.UpdateMap(render = False, renderVector = False)
def OnLeftUpVDigitModifyLine(self, event):
@@ -1828,15 +1824,15 @@
pos1 = self.Pixel2Cell(self.mouse['begin'])
pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
- type=VDigit_Lines_Type)
+ type = VDigit_Lines_Type)
if not pointOnLine:
return
if digitToolbar.GetAction() in ["splitLine", "addVertex"]:
- self.UpdateMap(render=False) # highlight object
- self.DrawCross(pdc=self.pdcTmp, coords=self.Cell2Pixel(pointOnLine),
- size=5)
+ self.UpdateMap(render = False) # highlight object
+ self.DrawCross(pdc = self.pdcTmp, coords = self.Cell2Pixel(pointOnLine),
+ size = 5)
else: # removeVertex
# get only id of vertex
try:
@@ -1847,13 +1843,13 @@
if id:
x, y = self.pdcVector.GetIdBounds(id)[0:2]
self.pdcVector.RemoveId(id)
- self.DrawCross(pdc=self.pdcTmp, coords=(x, y),
- size=5)
+ self.DrawCross(pdc = self.pdcTmp, coords = (x, y),
+ size = 5)
else:
# unselect
def OnLeftUpVDigitCopyLine(self, event):
@@ -1865,29 +1861,29 @@
pos2 = self.Pixel2Cell(self.mouse['end'])
- if UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True) == '':
+ if UserSettings.Get(group = 'vdigit', key = 'bgmap',
+ subkey = 'value', internal = True) == '':
# no background map -> copy from current vector map layer
nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
if nselected > 0:
# highlight selected features
else:
else:
# copy features from background map
self.copyIds += digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
if len(self.copyIds) > 0:
- color = UserSettings.Get(group='vdigit', key='symbol',
- subkey=['highlight', 'color'])
+ color = UserSettings.Get(group = 'vdigit', key = 'symbol',
+ subkey = ['highlight', 'color'])
colorStr = str(color[0]) + ":" + \
str(color[1]) + ":" + \
str(color[2])
dVectTmp = ['d.vect',
- 'map=%s' % UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True),
+ 'map=%s' % UserSettings.Get(group = 'vdigit', key = 'bgmap',
+ subkey = 'value', internal = True),
'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
'-i',
'color=%s' % colorStr,
@@ -1896,15 +1892,15 @@
'width=2']
if not self.layerTmp:
- self.layerTmp = self.Map.AddLayer(type='vector',
- name=globalvar.QUERYLAYER,
- command=dVectTmp)
+ self.layerTmp = self.Map.AddLayer(type = 'vector',
+ name = globalvar.QUERYLAYER,
+ command = dVectTmp)
else:
self.layerTmp.SetCmd(dVectTmp)
- self.UpdateMap(render=True, renderVector=False)
+ self.UpdateMap(render = True, renderVector = False)
else:
self.redrawAll = None
@@ -1923,10 +1919,10 @@
if nselected > 0:
- self.DrawLines(pdc=self.pdcTmp) # redraw temp line
+ self.DrawLines(pdc = self.pdcTmp) # redraw temp line
else:
def OnLeftUpVDigitConnectLine(self, event):
@@ -1936,7 +1932,7 @@
digitClass = self.parent.digit
if len(digitClass.driver.GetSelected()) > 0:
def OnLeftUp(self, event):
"""!Left mouse button released
@@ -1964,7 +1960,7 @@
self.Zoom(begin, end, self.zoomtype)
# redraw map
# update statusbar
self.parent.StatusbarUpdate()
@@ -1978,7 +1974,7 @@
self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
# clear temp canvas
elif self.mouse["use"] in ["measure", "profile"]:
# measure or profile
@@ -1986,8 +1982,8 @@
self.parent.MeasureDist(self.mouse['begin'], self.mouse['end'])
self.polycoords.append(self.Pixel2Cell(self.mouse['end']))
elif self.mouse["use"] == "pointer" and \
self.parent.GetLayerManager().gcpmanagement:
@@ -1999,8 +1995,8 @@
else:
coordtype = 'target'
- self.parent.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm=True)
+ self.parent.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm = True)
self.parent.GetLayerManager().georectifying:
@@ -2012,7 +2008,7 @@
coordtype = 'mapcoord'
self.parent.GetLayerManager().georectifying.SetGCPData(coordtype, coord, self)
elif self.mouse["use"] == "pointer" and self.parent.toolbars['vdigit']:
# digitization tool active
@@ -2169,9 +2165,9 @@
map = digitToolbar.GetLayer().GetName()
except:
map = None
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
if map:
# mapcoords = []
@@ -2192,12 +2188,12 @@
position = self.Cell2Pixel(self.polycoords[-1])
self.redrawAll = True
self.Refresh()
- if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') and \
+ if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled') and \
(line is True or \
(not line and fid > 0)):
posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
@@ -2205,14 +2201,14 @@
cats = { fid : {
- addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=map,
- cats=cats,
- pos=posWindow,
- action="add")
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = map,
+ cats = cats,
+ pos = posWindow,
+ action = "add")
self.__geomAttrb(fid, addRecordDlg, 'length', digitClass,
digitToolbar.GetLayer())
@@ -2224,7 +2220,7 @@
@@ -2260,11 +2256,11 @@
try:
if digitToolbar.GetAction() == 'copyCats':
if digitClass.CopyCats(self.copyCatsList,
- self.copyCatsIds, copyAttrb=False) < 0:
+ self.copyCatsIds, copyAttrb = False) < 0:
return
else:
- self.copyCatsIds, copyAttrb=True) < 0:
+ self.copyCatsIds, copyAttrb = True) < 0:
return
del self.copyCatsList
@@ -2304,7 +2300,7 @@
del self.copyIds
if self.layerTmp:
self.Map.DeleteLayer(self.layerTmp)
del self.layerTmp
elif digitToolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
@@ -2312,13 +2308,13 @@
pos2 = self.polycoords[1]
selected = digitClass.driver.GetSelected()
- dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
- nselected=len(selected))
+ dlg = VDigitZBulkDialog(parent = self, title = _("Z bulk-labeling dialog"),
+ nselected = len(selected))
if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
dlg.step.GetValue()) < 0:
return
- self.UpdateMap(render=False, renderVector=True)
+ self.UpdateMap(render = False, renderVector = True)
elif digitToolbar.GetAction() == "typeConv":
# -> feature type conversion
# - point <-> centroid
@@ -2330,7 +2326,7 @@
# unselect and re-render
self.Refresh()
@@ -2365,7 +2361,7 @@
if len(self.vdigitMove['id']) > 1:
self.vdigitMove['id'].pop()
elif digitToolbar.GetAction() in ["deleteLine", "moveLine", "splitLine",
"addVertex", "removeVertex", "moveVertex",
@@ -2390,17 +2386,17 @@
del self.copyIds
if self.layerTmp:
del self.layerTmp
- self.UpdateMap(render=False) # render vector
+ self.UpdateMap(render = False) # render vector
elif digitToolbar.GetAction() == "zbulkLine":
# reset polyline
@@ -2417,7 +2413,7 @@
self.Zoom(begin, end, 0) # no zoom
# redraw map
# update statusbar
@@ -2449,7 +2445,7 @@
(self.mouse['end'][0], self.mouse['end'][1]))
if digitToolbar.GetAction() == "addLine" and digitToolbar.GetAction('type') in ["line", "boundary"]:
if len(self.polycoords) > 0:
- self.MouseDraw(pdc=self.pdcTmp, begin=self.Cell2Pixel(self.polycoords[-1]))
+ self.MouseDraw(pdc = self.pdcTmp, begin = self.Cell2Pixel(self.polycoords[-1]))
elif digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] \
and hasattr(self, "vdigitMove"):
dx = self.mouse['end'][0] - self.mouse['begin'][0]
@@ -2482,14 +2478,14 @@
self.pdcTmp.RemoveId(self.vdigitMove['id'][2]-1)
self.polycoords.append((x, y))
else: # edit line
try:
if self.vdigitMove['id'][-1] > 0: # previous vertex
- begin=self.Cell2Pixel(self.polycoords[-1]))
+ begin = self.Cell2Pixel(self.polycoords[-1]))
except: # no line
self.vdigitMove['id'] = []
@@ -2504,12 +2500,11 @@
event.Skip()
- def ClearLines(self, pdc=None):
- Clears temporary drawn lines from PseudoDC
+ def ClearLines(self, pdc = None):
+ """!Clears temporary drawn lines from PseudoDC
if not pdc:
- pdc=self.pdcTmp
+ pdc = self.pdcTmp
try:
pdc.ClearId(self.lineid)
pdc.RemoveId(self.lineid)
@@ -2757,8 +2752,8 @@
if digitToolbar and digitToolbar.GetLayer() == l:
w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
- self.Map.GetRegion(n=n, s=s, w=w, e=e,
- update=True)
+ self.Map.GetRegion(n = n, s = s, w = w, e = e,
+ update = True)
updated = True
else:
vect.append(l.name)
@@ -2796,7 +2791,7 @@
def ZoomToDefault(self):
"""!Set display geometry to match default region settings
- self.Map.region = self.Map.GetRegion(default=True)
+ self.Map.region = self.Map.GetRegion(default = True)
self.Map.AdjustRegion() # aling region extent to the display
self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-12-30 18:11:45 UTC (rev 44812)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-12-30 18:16:27 UTC (rev 44813)
@@ -76,7 +76,7 @@
@return id of tool
- bmpDisabled=wx.NullBitmap
+ bmpDisabled = wx.NullBitmap
if label:
Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
@@ -90,7 +90,7 @@
return tool
- def EnableLongHelp(self, enable=True):
+ def EnableLongHelp(self, enable = True):
"""!Enable/disable long help
@param enable True for enable otherwise disable
@@ -111,7 +111,7 @@
if self.parent.toolbars['vdigit']:
# update vdigit toolbar (unselect currently selected tool)
- id = self.parent.toolbars['vdigit'].GetAction(type='id')
+ id = self.parent.toolbars['vdigit'].GetAction(type = 'id')
self.parent.toolbars['vdigit'].ToggleTool(id, False)
if event:
@@ -129,7 +129,7 @@
# initialize toolbar
self.ToggleTool(self.action['id'], True)
- def GetAction(self, type='desc'):
+ def GetAction(self, type = 'desc'):
"""!Get current action info"""
return self.action.get(type, '')
@@ -347,8 +347,7 @@
self.EnableTool(tool, enabled)
class GCPManToolbar(AbstractToolbar):
- Toolbar for managing ground control points
+ """!Toolbar for managing ground control points
@param parent reference to GCP widget
@@ -409,9 +408,9 @@
# add tool to toggle active map window
self.togglemapid = wx.NewId()
- self.togglemap = wx.Choice(parent=self, id=self.togglemapid,
+ self.togglemap = wx.Choice(parent = self, id = self.togglemapid,
choices = [_('source'), _('target')],
- style=wx.CB_READONLY)
+ style = wx.CB_READONLY)
self.InsertControl(10, self.togglemap)
@@ -632,7 +631,7 @@
Toolbar for digitization
- def __init__(self, parent, mapcontent, layerTree=None, log=None):
+ def __init__(self, parent, mapcontent, layerTree = None, log = None):
self.mapcontent = mapcontent # Map class instance
self.layerTree = layerTree # reference to layer tree associated to map display
self.log = log # log area
@@ -658,7 +657,7 @@
'id' : self.addPoint }
# list of available vector maps
- self.UpdateListOfLayers(updateTool=True)
+ self.UpdateListOfLayers(updateTool = True)
# realize toolbar
self.Realize()
@@ -764,7 +763,7 @@
def OnTool(self, event):
"""!Tool selected -> disable selected tool in map toolbar"""
- id = self.parent.toolbars['map'].GetAction(type='id')
+ id = self.parent.toolbars['map'].GetAction(type = 'id')
self.parent.toolbars['map'].ToggleTool(id, False)
# set cursor
@@ -790,7 +789,7 @@
# clear tmp canvas
if self.action['id'] != id:
- self.parent.MapWindow.ClearLines(pdc=self.parent.MapWindow.pdcTmp)
+ self.parent.MapWindow.ClearLines(pdc = self.parent.MapWindow.pdcTmp)
if self.parent.digit and \
len(self.parent.digit.driver.GetSelected()) > 0:
# cancel action
@@ -921,17 +920,17 @@
point = wx.GetMousePosition()
toolMenu = wx.Menu()
# Add items to the menu
- cats = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Copy categories'),
- kind=wx.ITEM_CHECK)
+ cats = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Copy categories'),
+ kind = wx.ITEM_CHECK)
toolMenu.AppendItem(cats)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyCats, cats)
if self.action['desc'] == "copyCats":
cats.Check(True)
- attrb = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Duplicate attributes'),
+ attrb = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Duplicate attributes'),
toolMenu.AppendItem(attrb)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyAttrb, attrb)
if self.action['desc'] == "copyAttrs":
@@ -999,8 +998,8 @@
self.parent.digit = None
if not self.settingsDialog:
- self.settingsDialog = VDigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
- style=wx.DEFAULT_DIALOG_STYLE)
+ self.settingsDialog = VDigitSettingsDialog(parent = self.parent, title = _("Digitization settings"),
+ style = wx.DEFAULT_DIALOG_STYLE)
self.settingsDialog.Show()
def OnAdditionalToolMenu(self, event):
@@ -1008,73 +1007,73 @@
- copy = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Copy features from (background) vector map'),
+ copy = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Copy features from (background) vector map'),
toolMenu.AppendItem(copy)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
if self.action['desc'] == "copyLine":
copy.Check(True)
- flip = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Flip selected lines/boundaries'),
+ flip = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Flip selected lines/boundaries'),
toolMenu.AppendItem(flip)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
if self.action['desc'] == "flipLine":
flip.Check(True)
- merge = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Merge selected lines/boundaries'),
+ merge = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Merge selected lines/boundaries'),
toolMenu.AppendItem(merge)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnMerge, merge)
if self.action['desc'] == "mergeLine":
merge.Check(True)
- breakL = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Break selected lines/boundaries at intersection'),
+ breakL = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Break selected lines/boundaries at intersection'),
toolMenu.AppendItem(breakL)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnBreak, breakL)
if self.action['desc'] == "breakLine":
breakL.Check(True)
- snap = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Snap selected lines/boundaries (only to nodes)'),
+ snap = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Snap selected lines/boundaries (only to nodes)'),
toolMenu.AppendItem(snap)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnSnap, snap)
if self.action['desc'] == "snapLine":
snap.Check(True)
- connect = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Connect selected lines/boundaries'),
+ connect = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Connect selected lines/boundaries'),
toolMenu.AppendItem(connect)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnConnect, connect)
if self.action['desc'] == "connectLine":
connect.Check(True)
- query = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Query features'),
+ query = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Query features'),
toolMenu.AppendItem(query)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnQuery, query)
if self.action['desc'] == "queryLine":
query.Check(True)
- zbulk = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Z bulk-labeling of 3D lines'),
+ zbulk = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Z bulk-labeling of 3D lines'),
toolMenu.AppendItem(zbulk)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
if self.action['desc'] == "zbulkLine":
zbulk.Check(True)
- typeconv = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
- text=_('Feature type conversion'),
+ typeconv = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
+ text = _('Feature type conversion'),
toolMenu.AppendItem(typeconv)
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
if self.action['desc'] == "typeConv":
@@ -1175,7 +1174,7 @@
return
Debug.msg(2, "Digittoolbar.OnQuery(): %s" % \
- UserSettings.Get(group='vdigit', key='query', subkey='selection'))
+ UserSettings.Get(group = 'vdigit', key = 'query', subkey = 'selection'))
self.action = { 'desc' : "queryLine",
'id' : self.additionalTools }
self.parent.MapWindow.mouse['box'] = 'box'
@@ -1183,9 +1182,9 @@
def OnZBulk(self, event):
"""!Z bulk-labeling selected lines/boundaries"""
if not self.parent.digit.driver.Is3D():
- wx.MessageBox(parent=self.parent,
- message=_("Vector map is not 3D. Operation canceled."),
+ wx.MessageBox(parent = self.parent,
+ message = _("Vector map is not 3D. Operation canceled."),
return
if self.action['desc'] == 'zbulkLine': # select previous action
@@ -1227,7 +1226,7 @@
if event.GetSelection() == 0: # create new vector map layer
if self.mapLayer:
- openVectorMap = self.mapLayer.GetName(fullyQualified=False)['name']
+ openVectorMap = self.mapLayer.GetName(fullyQualified = False)['name']
else:
openVectorMap = None
mapName = gdialogs.CreateNewVector(self.parent,
@@ -1235,17 +1234,17 @@
cmd = (('v.edit',
{ 'tool' : 'create' },
'map')),
- disableAdd=True)[0]
+ disableAdd = True)[0]
if mapName:
# add layer to map layer tree
if self.layerTree:
- self.layerTree.AddLayer(ltype='vector',
- lname=mapName,
- lchecked=True,
- lopacity=1.0,
- lcmd=['d.vect', 'map=%s' % mapName])
+ self.layerTree.AddLayer(ltype = 'vector',
+ lname = mapName,
+ lchecked = True,
+ lopacity = 1.0,
+ lcmd = ['d.vect', 'map=%s' % mapName])
- vectLayers = self.UpdateListOfLayers(updateTool=True)
+ vectLayers = self.UpdateListOfLayers(updateTool = True)
selection = vectLayers.index(mapName)
else:
pass # TODO (no Layer Manager)
@@ -1280,10 +1279,10 @@
# unset background map if needed
if mapLayer:
- subkey='value', internal=True) == mapLayer.GetName():
- UserSettings.Set(group='vdigit', key='bgmap',
- subkey='value', value='', internal=True)
+ subkey = 'value', internal = True) == mapLayer.GetName():
+ UserSettings.Set(group = 'vdigit', key = 'bgmap',
+ subkey = 'value', value = '', internal = True)
self.parent.statusbar.SetStatusText(_("Please wait, "
"opening vector map <%s> for editing...") % \
@@ -1295,7 +1294,7 @@
from vdigit import VDigit as VDigit
# use vdigit's PseudoDC
self.parent.MapWindow.DefinePseudoDC(vdigit = True)
- self.parent.digit = VDigit(mapwindow=self.parent.MapWindow)
+ self.parent.digit = VDigit(mapwindow = self.parent.MapWindow)
self.mapLayer = mapLayer
@@ -1327,9 +1326,9 @@
self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
if not self.parent.MapWindow.resize:
- self.parent.MapWindow.UpdateMap(render=True)
+ self.parent.MapWindow.UpdateMap(render = True)
- opacity = mapLayer.GetOpacity(float=True)
+ opacity = mapLayer.GetOpacity(float = True)
if opacity < 1.0:
alpha = int(opacity * 255)
self.parent.digit.driver.UpdateSettings(alpha)
@@ -1350,13 +1349,13 @@
# save changes
if self.mapLayer:
Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
- if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
+ if UserSettings.Get(group = 'vdigit', key = 'saveOnExit', subkey = 'enabled') is False:
if self.parent.digit.GetUndoLevel() > -1:
- dlg = wx.MessageDialog(parent=self.parent,
- message=_("Do you want to save changes "
+ dlg = wx.MessageDialog(parent = self.parent,
+ message = _("Do you want to save changes "
"in vector map <%s>?") % self.mapLayer.GetName(),
- caption=_("Save changes?"),
- style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ caption = _("Save changes?"),
+ style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlg.ShowModal() == wx.ID_NO:
# revert changes
self.parent.digit.Undo(0)
@@ -1396,7 +1395,7 @@
return True
- def UpdateListOfLayers (self, updateTool=False):
+ def UpdateListOfLayers (self, updateTool = False):
Update list of available vector map layers.
This list consists only editable layers (in the current mapset)
@@ -1413,8 +1412,8 @@
# select vector map layer in the current mapset
layerNameList = []
- self.layers = self.mapcontent.GetListOfLayers(l_type="vector",
- l_mapset=grass.gisenv()['MAPSET'])
+ self.layers = self.mapcontent.GetListOfLayers(l_type = "vector",
+ l_mapset = grass.gisenv()['MAPSET'])
for layer in self.layers:
if not layer.name in layerNameList: # do not duplicate layer
layerNameList.append (layer.GetName())
@@ -1426,9 +1425,9 @@
value = layerNameSelected
if not self.comboid:
- self.combo = wx.ComboBox(self, id=wx.ID_ANY, value=value,
- choices=[_('New vector map'), ] + layerNameList, size=(115, -1),
+ self.combo = wx.ComboBox(self, id = wx.ID_ANY, value = value,
+ choices = [_('New vector map'), ] + layerNameList, size = (115, -1),
self.comboid = self.InsertControl(0, self.combo)
self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectMap, self.comboid)
else:
@@ -1616,7 +1615,7 @@
self.settingsDialog = NvizPreferencesDialog(parent = self.parent)
- def OnExit (self, event=None):
+ def OnExit (self, event = None):
"""!Quit nviz tool (swith to 2D mode)"""
# set default mouse settings
self.parent.MapWindow.mouse['use'] = "pointer"
