[GRASS-SVN] r44820 - grass/branches/releasebranch_6_4
svn_grass at osgeo.org
Fri Dec 31 08:43:21 EST 2010
Author: neteler
Date: 2010-12-31 05:43:21 -0800 (Fri, 31 Dec 2010)
New Revision: 44820
grass/branches/releasebranch_6_4/configure
grass/branches/releasebranch_6_4/configure.in
added $DLLIB for sqlite
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure 2010-12-30 21:13:55 UTC (rev 44819)
+++ grass/branches/releasebranch_6_4/configure 2010-12-31 13:43:21 UTC (rev 44820)
@@ -10108,14 +10108,16 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10113: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10115: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsqlite3 $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 10119 "configure"
+#line 10121 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -10126,7 +10128,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -10145,13 +10147,49 @@
echo "$ac_t""no" 1>&6
-echo "configure:10149: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10151: checking for sqlite3_open in -lsqlite3" >&5
+LIBS="-lsqlite3 $DLLIB $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 10157 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char sqlite3_open();
+int main() {
+sqlite3_open()
+; return 0; }
+EOF
+if { (eval echo configure:10168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=yes"
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ SQLITELIB="$SQLITELIB -lsqlite3 $DLLIB"
+else
+ echo "$ac_t""no" 1>&6
+echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
+echo "configure:10187: checking for sqlite3_open in -lsqlite3" >&5
+ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10155 "configure"
+#line 10193 "configure"
@@ -10162,7 +10200,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10180,6 +10218,42 @@
else
+echo "configure:10223: checking for sqlite3_open in -lsqlite3" >&5
+LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
+#line 10229 "configure"
+int main() {
+sqlite3_open()
+; return 0; }
+EOF
+if { (eval echo configure:10240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+else
+ rm -rf conftest*
+fi
+rm -f conftest*
+ SQLITELIB="$SQLITELIB -lsqlite3 $MATHLIB $DLLIB"
+else
LDFLAGS=${ac_save_ldflags}
{ echo "configure: error: *** Unable to locate SQLite library." 1>&2; exit 1; }
@@ -10197,6 +10271,22 @@
+fi
+fi
@@ -10215,7 +10305,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10219: checking whether to use FFMPEG" >&5
+echo "configure:10309: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10235,7 +10325,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10239: checking for location of FFMPEG includes" >&5
+echo "configure:10329: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10261,15 +10351,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:10265: checking for $ac_hdr" >&5
+echo "configure:10355: checking for $ac_hdr" >&5
-#line 10268 "configure"
+#line 10358 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:10273: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -10305,15 +10395,15 @@
do
-echo "configure:10309: checking for $ac_hdr" >&5
+echo "configure:10399: checking for $ac_hdr" >&5
-#line 10312 "configure"
+#line 10402 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10407: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10349,15 +10439,15 @@
do
-echo "configure:10353: checking for $ac_hdr" >&5
+echo "configure:10443: checking for $ac_hdr" >&5
-#line 10356 "configure"
+#line 10446 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10361: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10451: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10400,7 +10490,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10404: checking for location of FFMPEG library" >&5
+echo "configure:10494: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10427,13 +10517,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10431: checking for av_free in -lavutil" >&5
+echo "configure:10521: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10437 "configure"
+#line 10527 "configure"
@@ -10444,7 +10534,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10463,13 +10553,13 @@
-echo "configure:10467: checking for av_free in -lavutil" >&5
+echo "configure:10557: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10473 "configure"
+#line 10563 "configure"
@@ -10480,7 +10570,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10525,13 +10615,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10529: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10619: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10535 "configure"
+#line 10625 "configure"
@@ -10542,7 +10632,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10561,13 +10651,13 @@
-echo "configure:10565: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10655: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10571 "configure"
+#line 10661 "configure"
@@ -10578,7 +10668,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10623,13 +10713,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10627: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10717: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10633 "configure"
+#line 10723 "configure"
@@ -10640,7 +10730,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10659,13 +10749,13 @@
-echo "configure:10663: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10753: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10669 "configure"
+#line 10759 "configure"
@@ -10676,7 +10766,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10735,7 +10825,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10739: checking whether to use OpenGL" >&5
+echo "configure:10829: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10769,7 +10859,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10773: checking for location of OpenGL includes" >&5
+echo "configure:10863: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10795,15 +10885,15 @@
do
-echo "configure:10799: checking for $ac_hdr" >&5
+echo "configure:10889: checking for $ac_hdr" >&5
-#line 10802 "configure"
+#line 10892 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10807: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10897: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10837,7 +10927,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10841: checking for location of OpenGL library" >&5
+echo "configure:10931: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10866,13 +10956,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10870: checking for glBegin in -lGL" >&5
+echo "configure:10960: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10876 "configure"
+#line 10966 "configure"
@@ -10883,7 +10973,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10902,13 +10992,13 @@
-echo "configure:10906: checking for glBegin in -lGL" >&5
+echo "configure:10996: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10912 "configure"
+#line 11002 "configure"
@@ -10919,7 +11009,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10938,13 +11028,13 @@
-echo "configure:10942: checking for glBegin in -lGL" >&5
+echo "configure:11032: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10948 "configure"
+#line 11038 "configure"
@@ -10955,7 +11045,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10974,13 +11064,13 @@
-echo "configure:10978: checking for glBegin in -lGL" >&5
+echo "configure:11068: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10984 "configure"
+#line 11074 "configure"
@@ -10991,7 +11081,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11053,13 +11143,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11057: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11147: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11063 "configure"
+#line 11153 "configure"
@@ -11070,7 +11160,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11089,13 +11179,13 @@
-echo "configure:11093: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11183: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11099 "configure"
+#line 11189 "configure"
@@ -11106,7 +11196,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11150,10 +11240,10 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11154: checking for glXCreatePbuffer" >&5
+echo "configure:11244: checking for glXCreatePbuffer" >&5
-#line 11157 "configure"
+#line 11247 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -11176,7 +11266,7 @@
; return 0; }
EOF
-if { (eval echo configure:11180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11198,10 +11288,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11202: checking for glXCreateGLXPixmap" >&5
+echo "configure:11292: checking for glXCreateGLXPixmap" >&5
-#line 11205 "configure"
+#line 11295 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11224,7 +11314,7 @@
; return 0; }
EOF
-if { (eval echo configure:11228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11263,7 +11353,7 @@
-echo "configure:11267: checking for location of OpenGL includes" >&5
+echo "configure:11357: checking for location of OpenGL includes" >&5
@@ -11289,15 +11379,15 @@
do
-echo "configure:11293: checking for $ac_hdr" >&5
+echo "configure:11383: checking for $ac_hdr" >&5
-#line 11296 "configure"
+#line 11386 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11332,10 +11422,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11336: checking for glBegin" >&5
+echo "configure:11426: checking for glBegin" >&5
-#line 11339 "configure"
+#line 11429 "configure"
which can conflict with char glBegin(); below. */
@@ -11358,7 +11448,7 @@
; return 0; }
EOF
-if { (eval echo configure:11362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11373,10 +11463,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11377: checking for gluBeginCurve" >&5
+echo "configure:11467: checking for gluBeginCurve" >&5
-#line 11380 "configure"
+#line 11470 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11399,7 +11489,7 @@
; return 0; }
EOF
-if { (eval echo configure:11403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11443,7 +11533,7 @@
-echo "configure:11447: checking for location of OpenGL includes" >&5
+echo "configure:11537: checking for location of OpenGL includes" >&5
@@ -11469,15 +11559,15 @@
do
-echo "configure:11473: checking for $ac_hdr" >&5
+echo "configure:11563: checking for $ac_hdr" >&5
-#line 11476 "configure"
+#line 11566 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11571: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11511,7 +11601,7 @@
-echo "configure:11515: checking for location of OpenGL library" >&5
+echo "configure:11605: checking for location of OpenGL library" >&5
@@ -11536,18 +11626,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11540: checking for OpenGL library" >&5
+echo "configure:11630: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11544 "configure"
+#line 11634 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11571,18 +11661,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11575: checking for GLU library" >&5
+echo "configure:11665: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11579 "configure"
+#line 11669 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11631,7 +11721,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11635: checking whether to use Tcl/Tk" >&5
+echo "configure:11725: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11651,7 +11741,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11655: checking for location of Tcl/Tk includes" >&5
+echo "configure:11745: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11677,15 +11767,15 @@
do
-echo "configure:11681: checking for $ac_hdr" >&5
+echo "configure:11771: checking for $ac_hdr" >&5
-#line 11684 "configure"
+#line 11774 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11722,15 +11812,15 @@
do
-echo "configure:11726: checking for $ac_hdr" >&5
+echo "configure:11816: checking for $ac_hdr" >&5
-#line 11729 "configure"
+#line 11819 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11763,7 +11853,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11767: checking Tcl version" >&5
+echo "configure:11857: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11771,7 +11861,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 11775 "configure"
+#line 11865 "configure"
#include <stdio.h>
@@ -11783,7 +11873,7 @@
EOF
-if { (eval echo configure:11787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11801,7 +11891,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11805: checking Tk version" >&5
+echo "configure:11895: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11809,7 +11899,7 @@
else
-#line 11813 "configure"
+#line 11903 "configure"
#include <stdio.h>
@@ -11821,7 +11911,7 @@
EOF
-if { (eval echo configure:11825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11852,7 +11942,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11856: checking for location of Tcl/Tk library" >&5
+echo "configure:11946: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11892,13 +11982,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11896: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11986: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11902 "configure"
+#line 11992 "configure"
@@ -11909,7 +11999,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11928,13 +12018,13 @@
-echo "configure:11932: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12022: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11938 "configure"
+#line 12028 "configure"
@@ -11945,7 +12035,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11972,13 +12062,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11976: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12066: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11982 "configure"
+#line 12072 "configure"
@@ -11989,7 +12079,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12008,13 +12098,13 @@
-echo "configure:12012: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12102: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12018 "configure"
+#line 12108 "configure"
@@ -12025,7 +12115,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12052,13 +12142,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12056: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12146: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12062 "configure"
+#line 12152 "configure"
@@ -12069,7 +12159,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12088,13 +12178,13 @@
-echo "configure:12092: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12182: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12098 "configure"
+#line 12188 "configure"
@@ -12105,7 +12195,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12183,13 +12273,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12187: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12277: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12193 "configure"
+#line 12283 "configure"
@@ -12200,7 +12290,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12219,13 +12309,13 @@
-echo "configure:12223: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12313: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12229 "configure"
+#line 12319 "configure"
@@ -12236,7 +12326,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12263,13 +12353,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12267: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12357: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12273 "configure"
+#line 12363 "configure"
@@ -12280,7 +12370,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12299,13 +12389,13 @@
-echo "configure:12303: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12393: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12309 "configure"
+#line 12399 "configure"
@@ -12316,7 +12406,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12343,13 +12433,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12347: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12437: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12353 "configure"
+#line 12443 "configure"
@@ -12360,7 +12450,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12379,13 +12469,13 @@
-echo "configure:12383: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12473: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12389 "configure"
+#line 12479 "configure"
@@ -12396,7 +12486,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12486,13 +12576,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12490: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12580: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12496 "configure"
+#line 12586 "configure"
@@ -12503,7 +12593,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12552,7 +12642,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12556: checking whether to use ODBC" >&5
+echo "configure:12646: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12571,7 +12661,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12575: checking for location of ODBC includes" >&5
+echo "configure:12665: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12597,15 +12687,15 @@
do
-echo "configure:12601: checking for $ac_hdr" >&5
+echo "configure:12691: checking for $ac_hdr" >&5
-#line 12604 "configure"
+#line 12694 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12609: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12639,7 +12729,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12643: checking for location of ODBC library" >&5
+echo "configure:12733: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12664,13 +12754,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12668: checking for SQLConnect in -lodbc" >&5
+echo "configure:12758: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12674 "configure"
+#line 12764 "configure"
@@ -12681,7 +12771,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12706,13 +12796,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12710: checking for SQLConnect in -liodbc" >&5
+echo "configure:12800: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12716 "configure"
+#line 12806 "configure"
@@ -12723,7 +12813,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12748,11 +12838,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12752: checking for ODBC library" >&5
+echo "configure:12842: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12756 "configure"
+#line 12846 "configure"
#include <windows.h>
#include <sql.h>
@@ -12760,7 +12850,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12809,7 +12899,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12813: checking whether to use FFTW" >&5
+echo "configure:12903: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12828,7 +12918,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12832: checking for location of FFTW includes" >&5
+echo "configure:12922: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12854,15 +12944,15 @@
do
-echo "configure:12858: checking for $ac_hdr" >&5
+echo "configure:12948: checking for $ac_hdr" >&5
-#line 12861 "configure"
+#line 12951 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12866: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12956: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12890,15 +12980,15 @@
do
-echo "configure:12894: checking for $ac_hdr" >&5
+echo "configure:12984: checking for $ac_hdr" >&5
-#line 12897 "configure"
+#line 12987 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12902: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12992: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12926,15 +13016,15 @@
do
-echo "configure:12930: checking for $ac_hdr" >&5
+echo "configure:13020: checking for $ac_hdr" >&5
-#line 12933 "configure"
+#line 13023 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12938: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12980,7 +13070,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12984: checking for location of FFTW library" >&5
+echo "configure:13074: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13005,13 +13095,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13009: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13099: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13015 "configure"
+#line 13105 "configure"
@@ -13022,7 +13112,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:13026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13047,13 +13137,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13051: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13141: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13057 "configure"
+#line 13147 "configure"
@@ -13064,7 +13154,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13089,13 +13179,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13093: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13183: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13099 "configure"
+#line 13189 "configure"
@@ -13106,7 +13196,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13163,7 +13253,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13167: checking whether to use BLAS" >&5
+echo "configure:13257: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13184,7 +13274,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13188: checking for location of BLAS includes" >&5
+echo "configure:13278: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13204,7 +13294,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13208: checking for location of BLAS library" >&5
+echo "configure:13298: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13230,15 +13320,15 @@
do
-echo "configure:13234: checking for $ac_hdr" >&5
+echo "configure:13324: checking for $ac_hdr" >&5
-#line 13237 "configure"
+#line 13327 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13332: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13273,13 +13363,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13277: checking for dnrm2_ in -lblas" >&5
+echo "configure:13367: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 13283 "configure"
+#line 13373 "configure"
@@ -13290,7 +13380,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13309,13 +13399,13 @@
-echo "configure:13313: checking for dnrm2_ in -lblas" >&5
+echo "configure:13403: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13319 "configure"
+#line 13409 "configure"
@@ -13326,7 +13416,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13370,13 +13460,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13374: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13464: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13380 "configure"
+#line 13470 "configure"
@@ -13387,7 +13477,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13402,13 +13492,13 @@
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13406: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13496: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13412 "configure"
+#line 13502 "configure"
@@ -13419,7 +13509,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13434,13 +13524,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13438: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13528: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13444 "configure"
+#line 13534 "configure"
@@ -13451,7 +13541,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13497,16 +13587,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13501: checking for sgemm in $vlib_flags" >&5
+echo "configure:13591: checking for sgemm in $vlib_flags" >&5
-#line 13503 "configure"
+#line 13593 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13524,13 +13614,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13528: checking for sgemm_ in -lblas" >&5
+echo "configure:13618: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13534 "configure"
+#line 13624 "configure"
@@ -13541,7 +13631,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13556,13 +13646,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13560: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13650: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13566 "configure"
+#line 13656 "configure"
@@ -13573,7 +13663,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13588,13 +13678,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13592: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13682: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13598 "configure"
+#line 13688 "configure"
@@ -13605,7 +13695,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13639,13 +13729,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13643: checking for acosp in -lsunmath" >&5
+echo "configure:13733: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13649 "configure"
+#line 13739 "configure"
@@ -13656,7 +13746,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13671,13 +13761,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13675: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13765: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13681 "configure"
+#line 13771 "configure"
@@ -13688,7 +13778,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13718,13 +13808,13 @@
# Generic BLAS library
-echo "configure:13722: checking for sgemm_ in -lblas" >&5
+echo "configure:13812: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13728 "configure"
+#line 13818 "configure"
@@ -13735,7 +13825,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13774,7 +13864,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13778: checking whether to use LAPACK" >&5
+echo "configure:13868: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13799,7 +13889,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13803: checking for location of LAPACK includes" >&5
+echo "configure:13893: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13819,7 +13909,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13823: checking for location of LAPACK library" >&5
+echo "configure:13913: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13845,15 +13935,15 @@
do
-echo "configure:13849: checking for $ac_hdr" >&5
+echo "configure:13939: checking for $ac_hdr" >&5
-#line 13852 "configure"
+#line 13942 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13857: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13885,10 +13975,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13889: checking for dsegv_" >&5
+echo "configure:13979: checking for dsegv_" >&5
-#line 13892 "configure"
+#line 13982 "configure"
which can conflict with char dsegv_(); below. */
@@ -13911,7 +14001,7 @@
; return 0; }
EOF
-if { (eval echo configure:13915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13938,13 +14028,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13942: checking for desgv_ in -llapack" >&5
+echo "configure:14032: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13948 "configure"
+#line 14038 "configure"
@@ -13955,7 +14045,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13987,13 +14077,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13991: checking for dgesv_ in -llapack" >&5
+echo "configure:14081: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13997 "configure"
+#line 14087 "configure"
@@ -14004,7 +14094,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14023,13 +14113,13 @@
-echo "configure:14027: checking for dgesv_ in -llapack" >&5
+echo "configure:14117: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14033 "configure"
+#line 14123 "configure"
@@ -14040,7 +14130,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14096,7 +14186,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14100: checking whether to use Motif" >&5
+echo "configure:14190: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14115,7 +14205,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14119: checking for location of Motif includes" >&5
+echo "configure:14209: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14141,15 +14231,15 @@
do
-echo "configure:14145: checking for $ac_hdr" >&5
+echo "configure:14235: checking for $ac_hdr" >&5
-#line 14148 "configure"
+#line 14238 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14153: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14183,7 +14273,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14187: checking for location of Motif library" >&5
+echo "configure:14277: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14208,13 +14298,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14212: checking for XmStringCreate in -lXm" >&5
+echo "configure:14302: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14218 "configure"
+#line 14308 "configure"
@@ -14225,7 +14315,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14266,7 +14356,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14270: checking whether to use Cairo" >&5
+echo "configure:14360: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14292,7 +14382,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14296: checking for location of cairo includes" >&5
+echo "configure:14386: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14318,15 +14408,15 @@
do
-echo "configure:14322: checking for $ac_hdr" >&5
+echo "configure:14412: checking for $ac_hdr" >&5
-#line 14325 "configure"
+#line 14415 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14362,7 +14452,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14366: checking for location of cairo library" >&5
+echo "configure:14456: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14382,7 +14472,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14386: checking for cairo linking flags" >&5
+echo "configure:14476: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14398,10 +14488,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14402: checking for cairo_create" >&5
+echo "configure:14492: checking for cairo_create" >&5
-#line 14405 "configure"
+#line 14495 "configure"
which can conflict with char cairo_create(); below. */
@@ -14424,7 +14514,7 @@
; return 0; }
EOF
-if { (eval echo configure:14428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14458,10 +14548,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14462: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14552: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14465 "configure"
+#line 14555 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14484,7 +14574,7 @@
; return 0; }
EOF
-if { (eval echo configure:14488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14526,7 +14616,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14530: checking whether to use GLw" >&5
+echo "configure:14620: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14545,7 +14635,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14549: checking for location of GLw includes" >&5
+echo "configure:14639: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14571,15 +14661,15 @@
do
-echo "configure:14575: checking for $ac_hdr" >&5
+echo "configure:14665: checking for $ac_hdr" >&5
-#line 14578 "configure"
+#line 14668 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14673: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14607,15 +14697,15 @@
do
-echo "configure:14611: checking for $ac_hdr" >&5
+echo "configure:14701: checking for $ac_hdr" >&5
-#line 14614 "configure"
+#line 14704 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14709: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14655,7 +14745,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14659: checking for location of GLw library" >&5
+echo "configure:14749: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14680,13 +14770,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14684: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14774: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14690 "configure"
+#line 14780 "configure"
@@ -14697,7 +14787,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14722,13 +14812,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14726: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14816: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14732 "configure"
+#line 14822 "configure"
@@ -14739,7 +14829,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14764,13 +14854,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14768: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14858: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14774 "configure"
+#line 14864 "configure"
@@ -14781,7 +14871,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14806,13 +14896,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14810: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14900: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14816 "configure"
+#line 14906 "configure"
@@ -14823,7 +14913,7 @@
; return 0; }
EOF
-if { (eval echo configure:14827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14848,13 +14938,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14852: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14942: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
cat > conftest.$ac_ext <<EOF
-#line 14858 "configure"
+#line 14948 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -14865,7 +14955,7 @@
; return 0; }
EOF
-if { (eval echo configure:14869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -14890,13 +14980,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14894: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14984: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
-#line 14900 "configure"
+#line 14990 "configure"
@@ -14907,7 +14997,7 @@
; return 0; }
EOF
-if { (eval echo configure:14911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14934,13 +15024,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14938: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15028: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14944 "configure"
+#line 15034 "configure"
@@ -14951,7 +15041,7 @@
; return 0; }
EOF
-if { (eval echo configure:14955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14970,13 +15060,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:14974: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15064: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14980 "configure"
+#line 15070 "configure"
@@ -14987,7 +15077,7 @@
; return 0; }
EOF
-if { (eval echo configure:14991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15014,13 +15104,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15018: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15108: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15024 "configure"
+#line 15114 "configure"
@@ -15031,7 +15121,7 @@
; return 0; }
EOF
-if { (eval echo configure:15035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15050,13 +15140,13 @@
-echo "configure:15054: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15144: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15060 "configure"
+#line 15150 "configure"
@@ -15067,7 +15157,7 @@
; return 0; }
EOF
-if { (eval echo configure:15071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15180,7 +15270,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15184: checking whether to use FreeType" >&5
+echo "configure:15274: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15199,7 +15289,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15203: checking for location of FreeType includes" >&5
+echo "configure:15293: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15225,15 +15315,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:15229: checking for $ac_hdr" >&5
+echo "configure:15319: checking for $ac_hdr" >&5
-#line 15232 "configure"
+#line 15322 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:15237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -15267,7 +15357,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15271: checking for location of FreeType library" >&5
+echo "configure:15361: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15292,13 +15382,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15296: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15386: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15302 "configure"
+#line 15392 "configure"
@@ -15309,7 +15399,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15350,7 +15440,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15354: checking whether to use NLS" >&5
+echo "configure:15444: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15370,10 +15460,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15374: checking for gettext" >&5
+echo "configure:15464: checking for gettext" >&5
-#line 15377 "configure"
+#line 15467 "configure"
which can conflict with char gettext(); below. */
@@ -15396,7 +15486,7 @@
; return 0; }
EOF
-if { (eval echo configure:15400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15414,13 +15504,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15418: checking for gettext in -lintl" >&5
+echo "configure:15508: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15424 "configure"
+#line 15514 "configure"
@@ -15431,7 +15521,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15466,7 +15556,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15470: checking whether to use C++" >&5
+echo "configure:15560: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15482,7 +15572,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15486: checking for $ac_word" >&5
+echo "configure:15576: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15511,7 +15601,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15515: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15605: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15522,12 +15612,12 @@
cat > conftest.$ac_ext << EOF
-#line 15526 "configure"
+#line 15616 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15553,19 +15643,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15557: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15647: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15562: checking whether we are using GNU C++" >&5
+echo "configure:15652: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15659: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15583,7 +15673,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15587: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15677: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15624,7 +15714,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15628: checking whether to use openDWG" >&5
+echo "configure:15718: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15644,7 +15734,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15648: checking for location of openDGW includes" >&5
+echo "configure:15738: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15670,15 +15760,15 @@
do
-echo "configure:15674: checking for $ac_hdr" >&5
+echo "configure:15764: checking for $ac_hdr" >&5
-#line 15677 "configure"
+#line 15767 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15772: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15712,7 +15802,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15716: checking for location of openDWG library" >&5
+echo "configure:15806: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15759,7 +15849,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15763: checking for special C compiler options needed for large files" >&5
+echo "configure:15853: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15767,7 +15857,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15771 "configure"
+#line 15861 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15783,7 +15873,7 @@
; return 0; }
EOF
-if { (eval echo configure:15787: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15877: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15792,7 +15882,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15796 "configure"
+#line 15886 "configure"
@@ -15808,7 +15898,7 @@
; return 0; }
EOF
-if { (eval echo configure:15812: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15902: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15828,11 +15918,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15832: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15922: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15836 "configure"
+#line 15926 "configure"
@@ -15848,14 +15938,14 @@
; return 0; }
EOF
-if { (eval echo configure:15852: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15942: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15859 "configure"
+#line 15949 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15873,7 +15963,7 @@
; return 0; }
EOF
-if { (eval echo configure:15877: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15967: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15892,11 +15982,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15896: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15986: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15900 "configure"
+#line 15990 "configure"
@@ -15912,14 +16002,14 @@
; return 0; }
EOF
-if { (eval echo configure:15916: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16006: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15923 "configure"
+#line 16013 "configure"
#define _LARGE_FILES 1
@@ -15937,7 +16027,7 @@
; return 0; }
EOF
-if { (eval echo configure:15941: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16031: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15956,25 +16046,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15960: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16050: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15964 "configure"
+#line 16054 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15971: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16061: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15978 "configure"
+#line 16068 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15983,7 +16073,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16077: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16004,10 +16094,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16008: checking if system supports Large Files at all" >&5
+echo "configure:16098: checking if system supports Large Files at all" >&5
-#line 16011 "configure"
+#line 16101 "configure"
#include <stdio.h>
@@ -16039,7 +16129,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16043: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16133: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16068,7 +16158,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16072: checking whether to use Python" >&5
+echo "configure:16162: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16088,7 +16178,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16092: checking for $ac_word" >&5
+echo "configure:16182: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16130,15 +16220,15 @@
do
-echo "configure:16134: checking for $ac_hdr" >&5
+echo "configure:16224: checking for $ac_hdr" >&5
-#line 16137 "configure"
+#line 16227 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16232: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16208,7 +16298,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16212: checking whether to use wxWidgets" >&5
+echo "configure:16302: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16229,7 +16319,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16233: checking for $ac_word" >&5
+echo "configure:16323: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16277,7 +16367,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16281: checking wxWidgets version" >&5
+echo "configure:16371: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16300,15 +16390,15 @@
do
-echo "configure:16304: checking for $ac_hdr" >&5
+echo "configure:16394: checking for $ac_hdr" >&5
-#line 16307 "configure"
+#line 16397 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16312: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16402: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in 2010-12-30 21:13:55 UTC (rev 44819)
+++ grass/branches/releasebranch_6_4/configure.in 2010-12-31 13:43:21 UTC (rev 44820)
@@ -1068,7 +1068,7 @@
LOC_CHECK_LIB_PATH(sqlite,SQLite,SQLITELIBPATH)
-LOC_CHECK_LIBS(sqlite3,sqlite3_open,SQLite,$SQLITELIBPATH,SQLITELIB,,,,$MATHLIB)
+LOC_CHECK_LIBS(sqlite3,sqlite3_open,SQLite,$SQLITELIBPATH,SQLITELIB,,,,$MATHLIB,$DLLIB)
fi # $USE_SQLITE
