[GRASS-SVN] r44822 - grass/trunk
svn_grass at osgeo.org
Fri Dec 31 08:44:07 EST 2010
Author: neteler
Date: 2010-12-31 05:44:07 -0800 (Fri, 31 Dec 2010)
New Revision: 44822
grass/trunk/configure
grass/trunk/configure.in
added $DLLIB for sqlite
Modified: grass/trunk/configure
--- grass/trunk/configure 2010-12-31 13:43:46 UTC (rev 44821)
+++ grass/trunk/configure 2010-12-31 13:44:07 UTC (rev 44822)
@@ -8498,14 +8498,16 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8503: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8505: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsqlite3 $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 8509 "configure"
+#line 8511 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -8516,7 +8518,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -8535,13 +8537,49 @@
echo "$ac_t""no" 1>&6
-echo "configure:8539: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8541: checking for sqlite3_open in -lsqlite3" >&5
+LIBS="-lsqlite3 $DLLIB $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 8547 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char sqlite3_open();
+int main() {
+sqlite3_open()
+; return 0; }
+EOF
+if { (eval echo configure:8558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=yes"
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ SQLITELIB="$SQLITELIB -lsqlite3 $DLLIB"
+else
+ echo "$ac_t""no" 1>&6
+echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
+echo "configure:8577: checking for sqlite3_open in -lsqlite3" >&5
+ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8545 "configure"
+#line 8583 "configure"
@@ -8552,7 +8590,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8570,6 +8608,42 @@
else
+echo "configure:8613: checking for sqlite3_open in -lsqlite3" >&5
+LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
+#line 8619 "configure"
+int main() {
+sqlite3_open()
+; return 0; }
+EOF
+if { (eval echo configure:8630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+else
+ rm -rf conftest*
+fi
+rm -f conftest*
+ SQLITELIB="$SQLITELIB -lsqlite3 $MATHLIB $DLLIB"
+else
LDFLAGS=${ac_save_ldflags}
{ echo "configure: error: *** Unable to locate SQLite library." 1>&2; exit 1; }
@@ -8587,6 +8661,22 @@
+fi
+fi
@@ -8605,7 +8695,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8609: checking whether to use FFMPEG" >&5
+echo "configure:8699: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8625,7 +8715,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8629: checking for location of FFMPEG includes" >&5
+echo "configure:8719: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8651,15 +8741,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8655: checking for $ac_hdr" >&5
+echo "configure:8745: checking for $ac_hdr" >&5
-#line 8658 "configure"
+#line 8748 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8663: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8753: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8695,15 +8785,15 @@
do
-echo "configure:8699: checking for $ac_hdr" >&5
+echo "configure:8789: checking for $ac_hdr" >&5
-#line 8702 "configure"
+#line 8792 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8739,15 +8829,15 @@
do
-echo "configure:8743: checking for $ac_hdr" >&5
+echo "configure:8833: checking for $ac_hdr" >&5
-#line 8746 "configure"
+#line 8836 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8751: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8841: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8790,7 +8880,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8794: checking for location of FFMPEG library" >&5
+echo "configure:8884: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8817,13 +8907,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8821: checking for av_free in -lavutil" >&5
+echo "configure:8911: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8827 "configure"
+#line 8917 "configure"
@@ -8834,7 +8924,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8853,13 +8943,13 @@
-echo "configure:8857: checking for av_free in -lavutil" >&5
+echo "configure:8947: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8863 "configure"
+#line 8953 "configure"
@@ -8870,7 +8960,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8915,13 +9005,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:8919: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9009: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8925 "configure"
+#line 9015 "configure"
@@ -8932,7 +9022,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:8936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8951,13 +9041,13 @@
-echo "configure:8955: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9045: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8961 "configure"
+#line 9051 "configure"
@@ -8968,7 +9058,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:8972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9013,13 +9103,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9017: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9107: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9023 "configure"
+#line 9113 "configure"
@@ -9030,7 +9120,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9049,13 +9139,13 @@
-echo "configure:9053: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9143: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9059 "configure"
+#line 9149 "configure"
@@ -9066,7 +9156,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9125,7 +9215,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9129: checking whether to use OpenGL" >&5
+echo "configure:9219: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9159,7 +9249,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9163: checking for location of OpenGL includes" >&5
+echo "configure:9253: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9185,15 +9275,15 @@
do
-echo "configure:9189: checking for $ac_hdr" >&5
+echo "configure:9279: checking for $ac_hdr" >&5
-#line 9192 "configure"
+#line 9282 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9227,7 +9317,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9231: checking for location of OpenGL library" >&5
+echo "configure:9321: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9256,13 +9346,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9260: checking for glBegin in -lGL" >&5
+echo "configure:9350: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9266 "configure"
+#line 9356 "configure"
@@ -9273,7 +9363,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9292,13 +9382,13 @@
-echo "configure:9296: checking for glBegin in -lGL" >&5
+echo "configure:9386: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9302 "configure"
+#line 9392 "configure"
@@ -9309,7 +9399,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9328,13 +9418,13 @@
-echo "configure:9332: checking for glBegin in -lGL" >&5
+echo "configure:9422: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9338 "configure"
+#line 9428 "configure"
@@ -9345,7 +9435,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9364,13 +9454,13 @@
-echo "configure:9368: checking for glBegin in -lGL" >&5
+echo "configure:9458: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9374 "configure"
+#line 9464 "configure"
@@ -9381,7 +9471,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9443,13 +9533,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9447: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9537: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9453 "configure"
+#line 9543 "configure"
@@ -9460,7 +9550,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9479,13 +9569,13 @@
-echo "configure:9483: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9573: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9489 "configure"
+#line 9579 "configure"
@@ -9496,7 +9586,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9543,10 +9633,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9547: checking for glXCreatePbuffer" >&5
+echo "configure:9637: checking for glXCreatePbuffer" >&5
-#line 9550 "configure"
+#line 9640 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9569,7 +9659,7 @@
; return 0; }
EOF
-if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9606,10 +9696,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9610: checking for glXCreateGLXPixmap" >&5
+echo "configure:9700: checking for glXCreateGLXPixmap" >&5
-#line 9613 "configure"
+#line 9703 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9632,7 +9722,7 @@
; return 0; }
EOF
-if { (eval echo configure:9636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9675,7 +9765,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9679: checking for location of OpenGL framework" >&5
+echo "configure:9769: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9699,15 +9789,15 @@
do
-echo "configure:9703: checking for $ac_hdr" >&5
+echo "configure:9793: checking for $ac_hdr" >&5
-#line 9706 "configure"
+#line 9796 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9711: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9743,10 +9833,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9747: checking for glBegin" >&5
+echo "configure:9837: checking for glBegin" >&5
-#line 9750 "configure"
+#line 9840 "configure"
which can conflict with char glBegin(); below. */
@@ -9769,7 +9859,7 @@
; return 0; }
EOF
-if { (eval echo configure:9773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9806,10 +9896,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9810: checking for gluBeginCurve" >&5
+echo "configure:9900: checking for gluBeginCurve" >&5
-#line 9813 "configure"
+#line 9903 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9832,7 +9922,7 @@
; return 0; }
EOF
-if { (eval echo configure:9836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9880,7 +9970,7 @@
-echo "configure:9884: checking for location of OpenGL includes" >&5
+echo "configure:9974: checking for location of OpenGL includes" >&5
@@ -9906,15 +9996,15 @@
do
-echo "configure:9910: checking for $ac_hdr" >&5
+echo "configure:10000: checking for $ac_hdr" >&5
-#line 9913 "configure"
+#line 10003 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9948,7 +10038,7 @@
-echo "configure:9952: checking for location of OpenGL library" >&5
+echo "configure:10042: checking for location of OpenGL library" >&5
@@ -9973,18 +10063,18 @@
ac_save_ldflags="$LDFLAGS"
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9977: checking for OpenGL library" >&5
+echo "configure:10067: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9981 "configure"
+#line 10071 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -10008,18 +10098,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10012: checking for GLU library" >&5
+echo "configure:10102: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10016 "configure"
+#line 10106 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10068,7 +10158,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10072: checking whether to use Tcl/Tk" >&5
+echo "configure:10162: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -10088,7 +10178,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10092: checking for location of Tcl/Tk includes" >&5
+echo "configure:10182: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10114,15 +10204,15 @@
do
-echo "configure:10118: checking for $ac_hdr" >&5
+echo "configure:10208: checking for $ac_hdr" >&5
-#line 10121 "configure"
+#line 10211 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10159,15 +10249,15 @@
do
-echo "configure:10163: checking for $ac_hdr" >&5
+echo "configure:10253: checking for $ac_hdr" >&5
-#line 10166 "configure"
+#line 10256 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10261: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10201,7 +10291,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10205: checking Tcl version" >&5
+echo "configure:10295: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -10209,7 +10299,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 10213 "configure"
+#line 10303 "configure"
#include <stdio.h>
@@ -10221,7 +10311,7 @@
EOF
-if { (eval echo configure:10225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -10239,7 +10329,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10243: checking Tk version" >&5
+echo "configure:10333: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10247,7 +10337,7 @@
else
-#line 10251 "configure"
+#line 10341 "configure"
#include <stdio.h>
@@ -10259,7 +10349,7 @@
EOF
-if { (eval echo configure:10263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -10288,7 +10378,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10292: checking for location of Tcl/Tk library" >&5
+echo "configure:10382: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10328,13 +10418,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10332: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10422: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 10338 "configure"
+#line 10428 "configure"
@@ -10345,7 +10435,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10364,13 +10454,13 @@
-echo "configure:10368: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10458: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10374 "configure"
+#line 10464 "configure"
@@ -10381,7 +10471,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10408,13 +10498,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10412: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10502: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10418 "configure"
+#line 10508 "configure"
@@ -10425,7 +10515,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10444,13 +10534,13 @@
-echo "configure:10448: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10538: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10454 "configure"
+#line 10544 "configure"
@@ -10461,7 +10551,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10488,13 +10578,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10492: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10582: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10498 "configure"
+#line 10588 "configure"
@@ -10505,7 +10595,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10524,13 +10614,13 @@
-echo "configure:10528: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10618: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10534 "configure"
+#line 10624 "configure"
@@ -10541,7 +10631,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10619,13 +10709,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10623: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10713: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10629 "configure"
+#line 10719 "configure"
@@ -10636,7 +10726,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10655,13 +10745,13 @@
-echo "configure:10659: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10749: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10665 "configure"
+#line 10755 "configure"
@@ -10672,7 +10762,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10699,13 +10789,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10703: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10793: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10709 "configure"
+#line 10799 "configure"
@@ -10716,7 +10806,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10735,13 +10825,13 @@
-echo "configure:10739: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10829: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10745 "configure"
+#line 10835 "configure"
@@ -10752,7 +10842,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10779,13 +10869,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10783: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10873: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 10789 "configure"
+#line 10879 "configure"
@@ -10796,7 +10886,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10815,13 +10905,13 @@
-echo "configure:10819: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10909: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10825 "configure"
+#line 10915 "configure"
@@ -10832,7 +10922,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10922,13 +11012,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:10926: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:11016: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 10932 "configure"
+#line 11022 "configure"
@@ -10939,7 +11029,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10989,7 +11079,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10993: checking whether to use ODBC" >&5
+echo "configure:11083: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11008,7 +11098,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11012: checking for location of ODBC includes" >&5
+echo "configure:11102: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11034,15 +11124,15 @@
do
-echo "configure:11038: checking for $ac_hdr" >&5
+echo "configure:11128: checking for $ac_hdr" >&5
-#line 11041 "configure"
+#line 11131 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11136: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11076,7 +11166,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11080: checking for location of ODBC library" >&5
+echo "configure:11170: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11101,13 +11191,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11105: checking for SQLConnect in -lodbc" >&5
+echo "configure:11195: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11111 "configure"
+#line 11201 "configure"
@@ -11118,7 +11208,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11143,13 +11233,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11147: checking for SQLConnect in -liodbc" >&5
+echo "configure:11237: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11153 "configure"
+#line 11243 "configure"
@@ -11160,7 +11250,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11185,11 +11275,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11189: checking for ODBC library" >&5
+echo "configure:11279: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11193 "configure"
+#line 11283 "configure"
#include <windows.h>
#include <sql.h>
@@ -11197,7 +11287,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11246,7 +11336,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11250: checking whether to use FFTW" >&5
+echo "configure:11340: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11265,7 +11355,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11269: checking for location of FFTW includes" >&5
+echo "configure:11359: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11291,15 +11381,15 @@
do
-echo "configure:11295: checking for $ac_hdr" >&5
+echo "configure:11385: checking for $ac_hdr" >&5
-#line 11298 "configure"
+#line 11388 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11393: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11327,15 +11417,15 @@
do
-echo "configure:11331: checking for $ac_hdr" >&5
+echo "configure:11421: checking for $ac_hdr" >&5
-#line 11334 "configure"
+#line 11424 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11363,15 +11453,15 @@
do
-echo "configure:11367: checking for $ac_hdr" >&5
+echo "configure:11457: checking for $ac_hdr" >&5
-#line 11370 "configure"
+#line 11460 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11375: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11465: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11417,7 +11507,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11421: checking for location of FFTW library" >&5
+echo "configure:11511: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11442,13 +11532,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11446: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11536: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11452 "configure"
+#line 11542 "configure"
@@ -11459,7 +11549,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:11463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11484,13 +11574,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11488: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11578: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 11494 "configure"
+#line 11584 "configure"
@@ -11501,7 +11591,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11526,13 +11616,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11530: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11620: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11536 "configure"
+#line 11626 "configure"
@@ -11543,7 +11633,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11600,7 +11690,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11604: checking whether to use BLAS" >&5
+echo "configure:11694: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -11621,7 +11711,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11625: checking for location of BLAS includes" >&5
+echo "configure:11715: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11641,7 +11731,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11645: checking for location of BLAS library" >&5
+echo "configure:11735: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11667,15 +11757,15 @@
do
-echo "configure:11671: checking for $ac_hdr" >&5
+echo "configure:11761: checking for $ac_hdr" >&5
-#line 11674 "configure"
+#line 11764 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11679: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11710,13 +11800,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11714: checking for dnrm2_ in -lblas" >&5
+echo "configure:11804: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 11720 "configure"
+#line 11810 "configure"
@@ -11727,7 +11817,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11746,13 +11836,13 @@
-echo "configure:11750: checking for dnrm2_ in -lblas" >&5
+echo "configure:11840: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11756 "configure"
+#line 11846 "configure"
@@ -11763,7 +11853,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11807,13 +11897,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11811: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11901: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 11817 "configure"
+#line 11907 "configure"
@@ -11824,7 +11914,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:11828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11839,13 +11929,13 @@
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11843: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11933: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 11849 "configure"
+#line 11939 "configure"
@@ -11856,7 +11946,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11871,13 +11961,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11875: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11965: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11881 "configure"
+#line 11971 "configure"
@@ -11888,7 +11978,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:11892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11934,16 +12024,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11938: checking for sgemm in $vlib_flags" >&5
+echo "configure:12028: checking for sgemm in $vlib_flags" >&5
-#line 11940 "configure"
+#line 12030 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:11947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -11961,13 +12051,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11965: checking for sgemm_ in -lblas" >&5
+echo "configure:12055: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11971 "configure"
+#line 12061 "configure"
@@ -11978,7 +12068,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11993,13 +12083,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11997: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12087: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12003 "configure"
+#line 12093 "configure"
@@ -12010,7 +12100,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12025,13 +12115,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12029: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12119: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12035 "configure"
+#line 12125 "configure"
@@ -12042,7 +12132,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12076,13 +12166,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12080: checking for acosp in -lsunmath" >&5
+echo "configure:12170: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12086 "configure"
+#line 12176 "configure"
@@ -12093,7 +12183,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12108,13 +12198,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12112: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12202: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12118 "configure"
+#line 12208 "configure"
@@ -12125,7 +12215,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12155,13 +12245,13 @@
# Generic BLAS library
-echo "configure:12159: checking for sgemm_ in -lblas" >&5
+echo "configure:12249: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12165 "configure"
+#line 12255 "configure"
@@ -12172,7 +12262,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12211,7 +12301,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12215: checking whether to use LAPACK" >&5
+echo "configure:12305: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12236,7 +12326,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12240: checking for location of LAPACK includes" >&5
+echo "configure:12330: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12256,7 +12346,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12260: checking for location of LAPACK library" >&5
+echo "configure:12350: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12282,15 +12372,15 @@
do
-echo "configure:12286: checking for $ac_hdr" >&5
+echo "configure:12376: checking for $ac_hdr" >&5
-#line 12289 "configure"
+#line 12379 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12384: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12322,10 +12412,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12326: checking for dsegv_" >&5
+echo "configure:12416: checking for dsegv_" >&5
-#line 12329 "configure"
+#line 12419 "configure"
which can conflict with char dsegv_(); below. */
@@ -12348,7 +12438,7 @@
; return 0; }
EOF
-if { (eval echo configure:12352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12375,13 +12465,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12379: checking for desgv_ in -llapack" >&5
+echo "configure:12469: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12385 "configure"
+#line 12475 "configure"
@@ -12392,7 +12482,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12424,13 +12514,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12428: checking for dgesv_ in -llapack" >&5
+echo "configure:12518: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 12434 "configure"
+#line 12524 "configure"
@@ -12441,7 +12531,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12460,13 +12550,13 @@
-echo "configure:12464: checking for dgesv_ in -llapack" >&5
+echo "configure:12554: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12470 "configure"
+#line 12560 "configure"
@@ -12477,7 +12567,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12533,7 +12623,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12537: checking whether to use Cairo" >&5
+echo "configure:12627: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -12559,7 +12649,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12563: checking for location of cairo includes" >&5
+echo "configure:12653: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12585,15 +12675,15 @@
do
-echo "configure:12589: checking for $ac_hdr" >&5
+echo "configure:12679: checking for $ac_hdr" >&5
-#line 12592 "configure"
+#line 12682 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12597: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12629,7 +12719,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12633: checking for location of cairo library" >&5
+echo "configure:12723: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12649,7 +12739,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12653: checking for cairo linking flags" >&5
+echo "configure:12743: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12665,10 +12755,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12669: checking for cairo_create" >&5
+echo "configure:12759: checking for cairo_create" >&5
-#line 12672 "configure"
+#line 12762 "configure"
which can conflict with char cairo_create(); below. */
@@ -12691,7 +12781,7 @@
; return 0; }
EOF
-if { (eval echo configure:12695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -12725,10 +12815,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12729: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12819: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12732 "configure"
+#line 12822 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -12751,7 +12841,7 @@
; return 0; }
EOF
-if { (eval echo configure:12755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -12784,10 +12874,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12788: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12878: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12791 "configure"
+#line 12881 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -12810,7 +12900,7 @@
; return 0; }
EOF
-if { (eval echo configure:12814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -12852,7 +12942,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12856: checking whether to use FreeType" >&5
+echo "configure:12946: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -12871,7 +12961,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12875: checking for location of FreeType includes" >&5
+echo "configure:12965: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12897,15 +12987,15 @@
do
-echo "configure:12901: checking for $ac_hdr" >&5
+echo "configure:12991: checking for $ac_hdr" >&5
-#line 12904 "configure"
+#line 12994 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12999: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12939,7 +13029,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12943: checking for location of FreeType library" >&5
+echo "configure:13033: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12964,13 +13054,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12968: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13058: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12974 "configure"
+#line 13064 "configure"
@@ -12981,7 +13071,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13022,7 +13112,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13026: checking whether to use NLS" >&5
+echo "configure:13116: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13042,10 +13132,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13046: checking for gettext" >&5
+echo "configure:13136: checking for gettext" >&5
-#line 13049 "configure"
+#line 13139 "configure"
which can conflict with char gettext(); below. */
@@ -13068,7 +13158,7 @@
; return 0; }
EOF
-if { (eval echo configure:13072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13086,13 +13176,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13090: checking for gettext in -lintl" >&5
+echo "configure:13180: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13096 "configure"
+#line 13186 "configure"
@@ -13103,7 +13193,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13138,7 +13228,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13142: checking whether to use C++" >&5
+echo "configure:13232: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13154,7 +13244,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13158: checking for $ac_word" >&5
+echo "configure:13248: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13183,7 +13273,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13187: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13277: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13194,12 +13284,12 @@
cat > conftest.$ac_ext << EOF
-#line 13198 "configure"
+#line 13288 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13225,19 +13315,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13229: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13319: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13234: checking whether we are using GNU C++" >&5
+echo "configure:13324: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13255,7 +13345,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13259: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13349: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13296,7 +13386,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13300: checking whether to use openDWG" >&5
+echo "configure:13390: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13316,7 +13406,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13320: checking for location of openDGW includes" >&5
+echo "configure:13410: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13342,15 +13432,15 @@
do
-echo "configure:13346: checking for $ac_hdr" >&5
+echo "configure:13436: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 13349 "configure"
+#line 13439 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13354: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13384,7 +13474,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13388: checking for location of openDWG library" >&5
+echo "configure:13478: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13425,7 +13515,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13429: checking whether to use POSIX threads" >&5
+echo "configure:13519: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -13445,7 +13535,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13449: checking for location of POSIX threads includes" >&5
+echo "configure:13539: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13471,15 +13561,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13475: checking for $ac_hdr" >&5
+echo "configure:13565: checking for $ac_hdr" >&5
-#line 13478 "configure"
+#line 13568 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13483: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13513,7 +13603,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13517: checking for location of POSIX threads library" >&5
+echo "configure:13607: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13538,10 +13628,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13542: checking for pthread_create" >&5
+echo "configure:13632: checking for pthread_create" >&5
-#line 13545 "configure"
+#line 13635 "configure"
which can conflict with char pthread_create(); below. */
@@ -13564,7 +13654,7 @@
; return 0; }
EOF
-if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -13591,13 +13681,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13595: checking for pthread_create in -lpthread" >&5
+echo "configure:13685: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 13601 "configure"
+#line 13691 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13608,7 +13698,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:13612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13664,7 +13754,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13668: checking for special C compiler options needed for large files" >&5
+echo "configure:13758: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13672,7 +13762,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13676 "configure"
+#line 13766 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13688,7 +13778,7 @@
; return 0; }
EOF
-if { (eval echo configure:13692: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13782: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -13697,7 +13787,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13701 "configure"
+#line 13791 "configure"
@@ -13713,7 +13803,7 @@
; return 0; }
EOF
-if { (eval echo configure:13717: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13807: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13733,11 +13823,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13737: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13827: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13741 "configure"
+#line 13831 "configure"
@@ -13753,14 +13843,14 @@
; return 0; }
EOF
-if { (eval echo configure:13757: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13847: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13764 "configure"
+#line 13854 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13778,7 +13868,7 @@
; return 0; }
EOF
-if { (eval echo configure:13782: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13872: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13797,11 +13887,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13801: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13891: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13805 "configure"
+#line 13895 "configure"
@@ -13817,14 +13907,14 @@
; return 0; }
EOF
-if { (eval echo configure:13821: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13911: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13828 "configure"
+#line 13918 "configure"
#define _LARGE_FILES 1
@@ -13842,7 +13932,7 @@
; return 0; }
EOF
-if { (eval echo configure:13846: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13936: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13861,25 +13951,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13865: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13955: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13869 "configure"
+#line 13959 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13876: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13966: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13883 "configure"
+#line 13973 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13888,7 +13978,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13892: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13982: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13909,25 +13999,25 @@
fi
-echo "configure:13913: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14003: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13917 "configure"
+#line 14007 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13924: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14014: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13931 "configure"
+#line 14021 "configure"
#include <stdio.h>
@@ -13936,7 +14026,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13940: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14030: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13959,18 +14049,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13963: checking for fseeko" >&5
+echo "configure:14053: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13967 "configure"
+#line 14057 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13987,10 +14077,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13991: checking if system supports Large Files at all" >&5
+echo "configure:14081: checking if system supports Large Files at all" >&5
-#line 13994 "configure"
+#line 14084 "configure"
#include <stdio.h>
@@ -14022,7 +14112,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14026: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14116: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14051,7 +14141,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14055: checking whether to use Python" >&5
+echo "configure:14145: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -14072,7 +14162,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:14076: checking for $ac_word" >&5
+echo "configure:14166: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -14114,15 +14204,15 @@
do
-echo "configure:14118: checking for $ac_hdr" >&5
+echo "configure:14208: checking for $ac_hdr" >&5
-#line 14121 "configure"
+#line 14211 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14170,7 +14260,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:14174: checking for $ac_word" >&5
+echo "configure:14264: checking for $ac_word" >&5
case "$SWIG" in
@@ -14232,7 +14322,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14236: checking whether to use wxWidgets" >&5
+echo "configure:14326: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14253,7 +14343,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14257: checking for $ac_word" >&5
+echo "configure:14347: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14301,7 +14391,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14305: checking wxWidgets version" >&5
+echo "configure:14395: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14324,15 +14414,15 @@
do
-echo "configure:14328: checking for $ac_hdr" >&5
+echo "configure:14418: checking for $ac_hdr" >&5
-#line 14331 "configure"
+#line 14421 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14336: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2010-12-31 13:43:46 UTC (rev 44821)
+++ grass/trunk/configure.in 2010-12-31 13:44:07 UTC (rev 44822)
@@ -1032,7 +1032,7 @@
LOC_CHECK_LIB_PATH(sqlite,SQLite,SQLITELIBPATH)
-LOC_CHECK_LIBS(sqlite3,sqlite3_open,SQLite,$SQLITELIBPATH,SQLITELIB,,,,$MATHLIB)
+LOC_CHECK_LIBS(sqlite3,sqlite3_open,SQLite,$SQLITELIBPATH,SQLITELIB,,,,$MATHLIB,$DLLIB)
fi # $USE_SQLITE
