[GRASS-SVN] r40771 - in grass/trunk: display/d.profile
display/d.rast doc/raster/r.example general/g.region
imagery/i.albedo imagery/i.atcorr imagery/i.biomass
imagery/i.cca imagery/i.class imagery/i.cluster
imagery/i.eb.eta imagery/i.eb.evapfr imagery/i.eb.h_SEBAL01
imagery/i.eb.soilheatflux imagery/i.emissivity
imagery/i.evapo.time_integration imagery/i.fft
imagery/i.gensig imagery/i.gensigset imagery/i.his.rgb
imagery/i.ifft imagery/i.latlong imagery/i.maxlik
imagery/i.modis.qc imagery/i.pca imagery/i.points
imagery/i.rectify imagery/i.rgb.his imagery/i.smap
imagery/i.sunhours imagery/i.vi imagery/i.vpoints
imagery/i.zc include lib/gis lib/raster lib/rst/interp_float
ps/ps.map raster/r.basins.fill raster/r.bitpattern
raster/r.carve raster/r.category raster/r.circle
raster/r.clump raster/r.coin raster/r.colors
raster/r.compress raster/r.cost raster/r.covar raster/r.cross
raster/r.describe raster/r.distance raster/r.drain
raster/r.fill.dir raster/r.flow raster/r.grow
raster/r.grow.distance raster/r.horizon raster/r.in.arc
raster/r.in.ascii raster/r.in.bin raster/r.in.gridatb
raster/r.lake raster/r.le/r.le.patch raster/r.le/r.le.pixel
raster/r.le/r.le.setup raster/r.le/r.le.trace
raster/r.li/r.li.daemon raster/r.los raster/r.mapcalc
raster/r.mfilter raster/r.neighbors raster/r.out.arc
raster/r.out.ascii raster/r.out.bin raster/r.out.gridatb
raster/r.out.mat raster/r.out.mpeg raster/r.out.pov
raster/r.out.vrml raster/r.param.scale raster/r.patch
raster/r.proj raster/r.quantile raster/r.random
raster/r.random.cells raster/r.random.surface raster/r.recode
raster/r.region raster/r.resamp.interp raster/r.resamp.stats
raster/r.resample raster/r.rescale raster/r.rescale.eq
raster/r.ros raster/r.series raster/r.slope.aspect
raster/r.spread raster/r.spreadpath raster/r.statistics2
raster/r.statistics3 raster/r.stats raster/r.sun
raster/r.sunmask raster/r.support raster/r.support.stats
raster/r.surf.contour raster/r.surf.fractal
raster/r.surf.gauss raster/r.surf.idw raster/r.surf.idw2
raster/r.surf.random raster/r.terraflow raster/r.texture
raster/r.thin raster/r.to.rast3 raster/r.to.rast3elev
raster/r.to.vect raster/r.univar raster/r.uslek
raster/r.usler raster/r.volume raster/r.walk
raster/r.water.outlet raster/r.watershed/ram
raster/r.watershed/seg raster/r.watershed/shed raster/r.what
raster/simwe/simlib raster3d/r3.cross.rast
raster3d/r3.out.vtk raster3d/r3.to.rast
swig/perl/R_slope_aspect/r_slope_aspect vector/lidar/lidarlib
vector/lidar/v.lidar.correction vector/lidar/v.lidar.growing
vector/lidar/v.surf.bspline vector/v.kernel
vector/v.neighbors vector/v.to.rast vector/v.what.rast
visualization/xganim
svn_grass at osgeo.org
Mon Feb 1 12:53:17 EST 2010
Author: glynn
Date: 2010-02-01 12:53:15 -0500 (Mon, 01 Feb 2010)
New Revision: 40771
Added:
grass/trunk/lib/raster/align_window.c
grass/trunk/lib/raster/window.c
Removed:
grass/trunk/lib/gis/align_window.c
grass/trunk/display/d.profile/main.c
grass/trunk/display/d.rast/display.c
grass/trunk/doc/raster/r.example/main.c
grass/trunk/general/g.region/main.c
grass/trunk/imagery/i.albedo/main.c
grass/trunk/imagery/i.atcorr/main.cpp
grass/trunk/imagery/i.biomass/main.c
grass/trunk/imagery/i.cca/main.c
grass/trunk/imagery/i.class/cellhd.c
grass/trunk/imagery/i.class/draw_cell.c
grass/trunk/imagery/i.class/outline.c
grass/trunk/imagery/i.class/signature.c
grass/trunk/imagery/i.cluster/main.c
grass/trunk/imagery/i.eb.eta/main.c
grass/trunk/imagery/i.eb.evapfr/main.c
grass/trunk/imagery/i.eb.h_SEBAL01/main.c
grass/trunk/imagery/i.eb.soilheatflux/main.c
grass/trunk/imagery/i.emissivity/main.c
grass/trunk/imagery/i.evapo.time_integration/main.c
grass/trunk/imagery/i.fft/main.c
grass/trunk/imagery/i.gensig/covariance.c
grass/trunk/imagery/i.gensig/get_train.c
grass/trunk/imagery/i.gensig/means.c
grass/trunk/imagery/i.gensigset/get_train.c
grass/trunk/imagery/i.gensigset/read_data.c
grass/trunk/imagery/i.his.rgb/main.c
grass/trunk/imagery/i.ifft/main.c
grass/trunk/imagery/i.latlong/main.c
grass/trunk/imagery/i.maxlik/main.c
grass/trunk/imagery/i.modis.qc/main.c
grass/trunk/imagery/i.pca/main.c
grass/trunk/imagery/i.points/drawcell.c
grass/trunk/imagery/i.rectify/rectify.c
grass/trunk/imagery/i.rgb.his/main.c
grass/trunk/imagery/i.smap/openfiles.c
grass/trunk/imagery/i.smap/segment.c
grass/trunk/imagery/i.sunhours/main.c
grass/trunk/imagery/i.vi/main.c
grass/trunk/imagery/i.vpoints/drawcell.c
grass/trunk/imagery/i.zc/main.c
grass/trunk/include/gisdefs.h
grass/trunk/include/rasterdefs.h
grass/trunk/lib/gis/get_window.c
grass/trunk/lib/gis/window_map.c
grass/trunk/lib/raster/alloc_cell.c
grass/trunk/lib/raster/get_row_colr.c
grass/trunk/lib/raster/sample.c
grass/trunk/lib/raster/zero_cell.c
grass/trunk/lib/rst/interp_float/output2d.c
grass/trunk/ps/ps.map/do_masking.c
grass/trunk/ps/ps.map/ps_outline.c
grass/trunk/raster/r.basins.fill/main.c
grass/trunk/raster/r.bitpattern/main.c
grass/trunk/raster/r.carve/enforce_ds.c
grass/trunk/raster/r.carve/raster.c
grass/trunk/raster/r.category/cats.c
grass/trunk/raster/r.circle/main.c
grass/trunk/raster/r.clump/clump.c
grass/trunk/raster/r.coin/main.c
grass/trunk/raster/r.colors/stats.c
grass/trunk/raster/r.compress/main.c
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.covar/main.c
grass/trunk/raster/r.cross/main.c
grass/trunk/raster/r.describe/describe.c
grass/trunk/raster/r.distance/distance.c
grass/trunk/raster/r.distance/edges.c
grass/trunk/raster/r.drain/main.c
grass/trunk/raster/r.fill.dir/main.c
grass/trunk/raster/r.flow/precomp.c
grass/trunk/raster/r.grow.distance/main.c
grass/trunk/raster/r.grow/main.c
grass/trunk/raster/r.horizon/main.c
grass/trunk/raster/r.in.arc/main.c
grass/trunk/raster/r.in.ascii/main.c
grass/trunk/raster/r.in.bin/main.c
grass/trunk/raster/r.in.gridatb/adjcellhd.c
grass/trunk/raster/r.lake/main.c
grass/trunk/raster/r.le/r.le.patch/driver.c
grass/trunk/raster/r.le/r.le.patch/input.c
grass/trunk/raster/r.le/r.le.pixel/driver.c
grass/trunk/raster/r.le/r.le.setup/main.c
grass/trunk/raster/r.le/r.le.trace/main.c
grass/trunk/raster/r.li/r.li.daemon/daemon.c
grass/trunk/raster/r.los/main.c
grass/trunk/raster/r.mapcalc/map.c
grass/trunk/raster/r.mapcalc/xcoor.c
grass/trunk/raster/r.mfilter/main.c
grass/trunk/raster/r.neighbors/bufs.c
grass/trunk/raster/r.neighbors/main.c
grass/trunk/raster/r.out.arc/main.c
grass/trunk/raster/r.out.ascii/main.c
grass/trunk/raster/r.out.bin/main.c
grass/trunk/raster/r.out.gridatb/adjcellhd.c
grass/trunk/raster/r.out.mat/main.c
grass/trunk/raster/r.out.mpeg/main.c
grass/trunk/raster/r.out.pov/main.c
grass/trunk/raster/r.out.vrml/main.c
grass/trunk/raster/r.out.vrml/put_grid.c
grass/trunk/raster/r.param.scale/process.c
grass/trunk/raster/r.patch/main.c
grass/trunk/raster/r.proj/bordwalk.c
grass/trunk/raster/r.proj/main.c
grass/trunk/raster/r.proj/readcell.c
grass/trunk/raster/r.quantile/main.c
grass/trunk/raster/r.random.cells/init.c
grass/trunk/raster/r.random.surface/init.c
grass/trunk/raster/r.random/count.c
grass/trunk/raster/r.random/random.c
grass/trunk/raster/r.recode/recode.c
grass/trunk/raster/r.region/main.c
grass/trunk/raster/r.resamp.interp/main.c
grass/trunk/raster/r.resamp.stats/main.c
grass/trunk/raster/r.resample/main.c
grass/trunk/raster/r.rescale.eq/get_stats.c
grass/trunk/raster/r.rescale/get_range.c
grass/trunk/raster/r.ros/main.c
grass/trunk/raster/r.series/main.c
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.spread/main.c
grass/trunk/raster/r.spread/ram2out.c
grass/trunk/raster/r.spreadpath/main.c
grass/trunk/raster/r.statistics2/main.c
grass/trunk/raster/r.statistics3/main.c
grass/trunk/raster/r.stats/main.c
grass/trunk/raster/r.stats/raw_stats.c
grass/trunk/raster/r.sun/main.c
grass/trunk/raster/r.sunmask/main.c
grass/trunk/raster/r.support.stats/histo.c
grass/trunk/raster/r.support/histo.c
grass/trunk/raster/r.surf.contour/main.c
grass/trunk/raster/r.surf.contour/read_cell.c
grass/trunk/raster/r.surf.fractal/process.c
grass/trunk/raster/r.surf.fractal/write_rast.c
grass/trunk/raster/r.surf.gauss/gaussurf.c
grass/trunk/raster/r.surf.idw/main.c
grass/trunk/raster/r.surf.idw2/read_cell.c
grass/trunk/raster/r.surf.random/randsurf.c
grass/trunk/raster/r.terraflow/main.cc
grass/trunk/raster/r.texture/main.c
grass/trunk/raster/r.thin/io.c
grass/trunk/raster/r.to.rast3/main.c
grass/trunk/raster/r.to.rast3elev/main.c
grass/trunk/raster/r.to.vect/points.c
grass/trunk/raster/r.univar/r.univar_main.c
grass/trunk/raster/r.uslek/main.c
grass/trunk/raster/r.usler/main.c
grass/trunk/raster/r.volume/centroids.c
grass/trunk/raster/r.walk/main.c
grass/trunk/raster/r.water.outlet/main.c
grass/trunk/raster/r.watershed/ram/init_vars.c
grass/trunk/raster/r.watershed/seg/bseg_open.c
grass/trunk/raster/r.watershed/seg/bseg_read.c
grass/trunk/raster/r.watershed/seg/bseg_write.c
grass/trunk/raster/r.watershed/seg/cseg_open.c
grass/trunk/raster/r.watershed/seg/cseg_read.c
grass/trunk/raster/r.watershed/seg/cseg_write.c
grass/trunk/raster/r.watershed/seg/dseg_open.c
grass/trunk/raster/r.watershed/seg/dseg_read.c
grass/trunk/raster/r.watershed/seg/dseg_write.c
grass/trunk/raster/r.watershed/seg/init_vars.c
grass/trunk/raster/r.watershed/shed/read.c
grass/trunk/raster/r.watershed/shed/valid.c
grass/trunk/raster/r.what/main.c
grass/trunk/raster/simwe/simlib/output.c
grass/trunk/raster3d/r3.cross.rast/main.c
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/raster3d/r3.to.rast/main.c
grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
grass/trunk/vector/lidar/lidarlib/raster.c
grass/trunk/vector/lidar/lidarlib/zones.c
grass/trunk/vector/lidar/v.lidar.correction/main.c
grass/trunk/vector/lidar/v.lidar.growing/main.c
grass/trunk/vector/lidar/v.surf.bspline/main.c
grass/trunk/vector/v.kernel/main.c
grass/trunk/vector/v.neighbors/main.c
grass/trunk/vector/v.to.rast/support.c
grass/trunk/vector/v.what.rast/main.c
grass/trunk/visualization/xganim/main.cc
Move raster-specific functions from lib/gis to lib/raster:
G_align_window -> Rast_align_window
G_window_rows -> Rast_window_rows
G_window_cols -> Rast_window_cols
G_northing_to_row -> Rast_northing_to_row
G_easting_to_col -> Rast_easting_to_col
G_row_to_northing -> Rast_row_to_northing
G_col_to_easting -> Rast_col_to_easting
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/display/d.profile/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -40,8 +40,8 @@
DCELL *buf = Rast_allocate_d_buf();
- int nrows = G_window_rows();
- int ncols = G_window_cols();
+ int nrows = Rast_window_rows();
+ int ncols = Rast_window_cols();
int row, col;
min = 1e300;
@@ -133,8 +133,8 @@
x -= col + 0.5;
y -= row + 0.5;
- if (row < 0 || row + 1 >= G_window_rows() ||
- col < 0 || col + 1 >= G_window_cols()) {
+ if (row < 0 || row + 1 >= Rast_window_rows() ||
+ col < 0 || col + 1 >= Rast_window_cols()) {
Rast_set_d_null_value(result, 1);
return 0;
@@ -237,8 +237,8 @@
G_scan_easting( profile->answers[i+0], &x, G_projection());
G_scan_northing(profile->answers[i+1], &y, G_projection());
- p->x = G_easting_to_col (x, &window);
- p->y = G_northing_to_row(y, &window);
+ p->x = Rast_easting_to_col (x, &window);
+ p->y = Rast_northing_to_row(y, &window);
if (num_points > 0) {
const struct point *prev = &points[num_points-1];
Modified: grass/trunk/display/d.rast/display.c
--- grass/trunk/display/d.rast/display.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/display/d.rast/display.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -50,8 +50,8 @@
int cur_A_row;
int ncols, nrows;
- ncols = G_window_cols();
- nrows = G_window_rows();
+ ncols = Rast_window_cols();
+ nrows = Rast_window_rows();
/* Set up the screen, conversions, and graphics */
D_setup(0);
Modified: grass/trunk/doc/raster/r.example/main.c
--- grass/trunk/doc/raster/r.example/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/doc/raster/r.example/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -119,8 +119,8 @@
inrast = Rast_allocate_buf(data_type);
/* Allocate output buffer, use input map data_type */
outrast = Rast_allocate_buf(data_type);
/* controlling, if we can write the raster */
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/general/g.region/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -549,7 +549,7 @@
if (flag.res_set->answer)
- G_align_window(&window, &temp_window);
+ Rast_align_window(&window, &temp_window);
Vect_close(&Map);
@@ -783,7 +783,7 @@
if (!mapset)
G_fatal_error(_("Raster map <%s> not found"), name);
Rast_get_cellhd(name, mapset, &temp_window);
/* save= */
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.albedo/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -164,8 +164,8 @@
G_fatal_error(_("At least two raster maps are required"));
outrast = Rast_allocate_buf(out_data_type);
/* Create New raster files */
Modified: grass/trunk/imagery/i.atcorr/main.cpp
--- grass/trunk/imagery/i.atcorr/main.cpp 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.atcorr/main.cpp 2010-02-01 17:53:15 UTC (rev 40771)
@@ -120,7 +120,7 @@
cbuf = (CELL*)Rast_allocate_buf(CELL_TYPE);
- for(col = 0; col < G_window_cols(); col++) cbuf[col] = round_c(buf[col]);
+ for(col = 0; col < Rast_window_cols(); col++) cbuf[col] = round_c(buf[col]);
Rast_put_row(ofd, cbuf, CELL_TYPE);
@@ -295,8 +295,8 @@
if(ivis_fd >= 0) vis = (FCELL*)Rast_allocate_buf(FCELL_TYPE);
G_verbose_message(_("Percent complete..."));
for(row = 0; row < nrows; row++)
Modified: grass/trunk/imagery/i.biomass/main.c
--- grass/trunk/imagery/i.biomass/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.biomass/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -117,8 +117,8 @@
infd_wa = Rast_open_old(wa, "");
inrast_wa = Rast_allocate_d_buf();
outrast1 = Rast_allocate_d_buf();
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.cca/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -207,7 +207,7 @@
/* do the transform */
- transform(datafds, outfds, G_window_rows(), G_window_cols(), q, bands,
+ transform(datafds, outfds, Rast_window_rows(), Rast_window_cols(), q, bands,
outbandmin, outbandmax);
/* make grey scale color table */
Modified: grass/trunk/imagery/i.class/cellhd.c
--- grass/trunk/imagery/i.class/cellhd.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.class/cellhd.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -7,13 +7,13 @@
int row, col;
int top, bottom, left, right;
- row = G_northing_to_row(cellhd->north, &view->cell.head) + .5;
+ row = Rast_northing_to_row(cellhd->north, &view->cell.head) + .5;
top = row_to_view(view, row);
- col = G_easting_to_col(cellhd->west, &view->cell.head) + .5;
+ col = Rast_easting_to_col(cellhd->west, &view->cell.head) + .5;
left = col_to_view(view, col);
- row = G_northing_to_row(cellhd->south, &view->cell.head) + .5;
+ row = Rast_northing_to_row(cellhd->south, &view->cell.head) + .5;
bottom = row_to_view(view, row);
- col = G_easting_to_col(cellhd->east, &view->cell.head) + .5;
+ col = Rast_easting_to_col(cellhd->east, &view->cell.head) + .5;
right = col_to_view(view, col);
Outline_box(top, bottom, left, right);
Modified: grass/trunk/imagery/i.class/draw_cell.c
--- grass/trunk/imagery/i.class/draw_cell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.class/draw_cell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -24,8 +24,8 @@
display_title(view);
Rast_set_window(&view->cell.head);
left = view->cell.left;
top = view->cell.top;
Modified: grass/trunk/imagery/i.class/outline.c
--- grass/trunk/imagery/i.class/outline.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.class/outline.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -40,8 +40,8 @@
temp.x = view_to_col(Region.view, A[cur].x);
tmp_n = row_to_northing(&(Region.view->cell.head), temp.y, 0.5);
tmp_e = col_to_easting(&(Region.view->cell.head), temp.x, 0.5);
- tmp[cur].y = G_northing_to_row(tmp_n, &Band_cellhd);
- tmp[cur].x = G_easting_to_col(tmp_e, &Band_cellhd);
+ tmp[cur].y = Rast_northing_to_row(tmp_n, &Band_cellhd);
+ tmp[cur].x = Rast_easting_to_col(tmp_e, &Band_cellhd);
/* find first edge which is not horizontal */
Modified: grass/trunk/imagery/i.class/signature.c
--- grass/trunk/imagery/i.class/signature.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.class/signature.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -274,8 +274,8 @@
fd = Rast_open_c_new(MASK);
buffer = Rast_allocate_c_buf();
for (row = 0; row < nrows; row++) {
readbands(nbands, row);
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.cluster/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -160,8 +160,8 @@
G_get_window(&window);
I_cluster_clear(&C);
Modified: grass/trunk/imagery/i.eb.eta/main.c
--- grass/trunk/imagery/i.eb.eta/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.eb.eta/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -85,8 +85,8 @@
infd_tempk = Rast_open_old(tempk, "");
inrast_tempk = Rast_allocate_d_buf();
outfd1 = Rast_open_new(result1, DCELL_TYPE);
Modified: grass/trunk/imagery/i.eb.evapfr/main.c
--- grass/trunk/imagery/i.eb.evapfr/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.eb.evapfr/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -107,8 +107,8 @@
inrast_h0 = Rast_allocate_d_buf();
if (makin)
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/main.c
--- grass/trunk/imagery/i.eb.h_SEBAL01/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -231,8 +231,8 @@
ymin = cellhd.south;
ymax = cellhd.north;
/* Allocate output buffer */
Modified: grass/trunk/imagery/i.eb.soilheatflux/main.c
--- grass/trunk/imagery/i.eb.soilheatflux/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.eb.soilheatflux/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -109,8 +109,8 @@
infd_time = Rast_open_old(time, "");
inrast_time = Rast_allocate_d_buf();
outrast = Rast_allocate_d_buf();
Modified: grass/trunk/imagery/i.emissivity/main.c
--- grass/trunk/imagery/i.emissivity/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.emissivity/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -66,8 +66,8 @@
inr = Rast_allocate_d_buf();
outr = Rast_allocate_d_buf();
Modified: grass/trunk/imagery/i.evapo.time_integration/main.c
--- grass/trunk/imagery/i.evapo.time_integration/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.evapo.time_integration/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -235,8 +235,8 @@
G_fatal_error(_("The min specified input map is two"));
Modified: grass/trunk/imagery/i.fft/main.c
--- grass/trunk/imagery/i.fft/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.fft/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -109,8 +109,8 @@
G_get_set_window(&window); /* get the current window for later */
/* get the rows and columns in the current window */
- rows = G_window_rows();
- cols = G_window_cols();
+ rows = Rast_window_rows();
+ cols = Rast_window_cols();
totsize = rows * cols;
/* Allocate appropriate memory for the structure containing
Modified: grass/trunk/imagery/i.gensig/covariance.c
--- grass/trunk/imagery/i.gensig/covariance.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.gensig/covariance.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -23,8 +23,8 @@
for (b2 = 0; b2 < S->nbands; b2++)
S->sig[n].var[b1][b2] = 0.0;
class = (CELL *) G_calloc(ncols, sizeof(CELL));
G_message(_("Calculating class covariance matrices..."));
Modified: grass/trunk/imagery/i.gensig/get_train.c
--- grass/trunk/imagery/i.gensig/get_train.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.gensig/get_train.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -23,8 +23,8 @@
fd = files->train_fd;
cell = files->train_cell;
/* determine the categories in the map */
I_init_signatures(S, files->nbands);
Modified: grass/trunk/imagery/i.gensig/means.c
--- grass/trunk/imagery/i.gensig/means.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.gensig/means.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -19,8 +19,8 @@
for (b = 0; b < S->nbands; b++) /* for each band file */
S->sig[n].mean[b] = 0.0;
G_message(_("Calculating class means..."));
Modified: grass/trunk/imagery/i.gensigset/get_train.c
--- grass/trunk/imagery/i.gensigset/get_train.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.gensigset/get_train.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -23,8 +23,8 @@
/* determine the non-zero categories in the map */
I_InitSigSet(S);
Modified: grass/trunk/imagery/i.gensigset/read_data.c
--- grass/trunk/imagery/i.gensigset/read_data.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.gensigset/read_data.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -15,8 +15,8 @@
CELL *class;
struct ClassData *Data;
G_message(_("Reading raster maps..."));
Modified: grass/trunk/imagery/i.his.rgb/main.c
--- grass/trunk/imagery/i.his.rgb/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.his.rgb/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -80,8 +80,8 @@
exit(EXIT_FAILURE);
/* get dimension of the image */
openfiles(opt_hue->answer, opt_int->answer, opt_sat->answer,
opt_red->answer, opt_green->answer, opt_blue->answer,
Modified: grass/trunk/imagery/i.ifft/main.c
--- grass/trunk/imagery/i.ifft/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.ifft/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -121,8 +121,8 @@
Rast_set_window(&realhead); /* set the window to the whole cell map */
Modified: grass/trunk/imagery/i.latlong/main.c
--- grass/trunk/imagery/i.latlong/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.latlong/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -89,8 +89,8 @@
xmax = cellhd.east;
/*Stolen from r.sun */
/* Set up parameters for projection to lat/long if necessary */
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.maxlik/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -102,8 +102,8 @@
open_files();
G_percent(row, nrows, 2);
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.modis.qc/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -204,8 +204,8 @@
inrast = Rast_allocate_c_buf();
G_debug(3, "number of rows %d", cellhd.rows);
outrast = Rast_allocate_c_buf();
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.pca/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -129,7 +129,7 @@
for (j = 0; j < bands; j++) {
covar[i][j] =
covar[i][j] /
- ((double)((G_window_rows() * G_window_cols()) - 1));
+ ((double)((Rast_window_rows() * Rast_window_cols()) - 1));
G_debug(3, "covar[%d][%d] = %f", i, j, covar[i][j]);
@@ -226,8 +226,8 @@
static int calc_mu(int *fds, double *mu, int bands)
int i;
- int rows = G_window_rows();
- int cols = G_window_cols();
+ int rows = Rast_window_rows();
+ int cols = Rast_window_cols();
void *rowbuf = NULL;
for (i = 0; i < bands; i++) {
@@ -276,8 +276,8 @@
static int calc_covariance(int *fds, double **covar, double *mu, int bands)
int j, k;
int row, col;
@@ -351,8 +351,8 @@
double max = 0.;
double old_range = 0.;
double new_range = 0.;
int cell_mapsiz = Rast_cell_size(CELL_TYPE);
int dcell_mapsiz = Rast_cell_size(DCELL_TYPE);
DCELL *d_buf;
Modified: grass/trunk/imagery/i.points/drawcell.c
--- grass/trunk/imagery/i.points/drawcell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.points/drawcell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -37,8 +37,8 @@
set_colors(colors);
Modified: grass/trunk/imagery/i.rectify/rectify.c
--- grass/trunk/imagery/i.rectify/rectify.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.rectify/rectify.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -42,8 +42,8 @@
Rast_set_window(&cellhd);
infd = Rast_open_old(name, mapset);
map_type = Rast_get_map_type(infd);
- rast = (void *)G_calloc(G_window_cols() + 1, Rast_cell_size(map_type));
- Rast_set_null_value(rast, G_window_cols() + 1, map_type);
+ rast = (void *)G_calloc(Rast_window_cols() + 1, Rast_cell_size(map_type));
+ Rast_set_null_value(rast, Rast_window_cols() + 1, map_type);
G_copy(&win, &target_window, sizeof(win));
Modified: grass/trunk/imagery/i.rgb.his/main.c
--- grass/trunk/imagery/i.rgb.his/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.rgb.his/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -81,8 +81,8 @@
openfiles(opt_red->answer, opt_green->answer, opt_blue->answer,
opt_hue->answer, opt_inten->answer, opt_sat->answer,
Modified: grass/trunk/imagery/i.smap/openfiles.c
--- grass/trunk/imagery/i.smap/openfiles.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.smap/openfiles.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -26,7 +26,7 @@
files->cellbuf = Rast_allocate_d_buf();
files->outbuf = Rast_allocate_c_buf();
- files->isdata = G_malloc(G_window_cols());
+ files->isdata = G_malloc(Rast_window_cols());
files->nbands = Ref.nfiles;
files->band_fd = (int *)G_calloc(Ref.nfiles, sizeof(int));
Modified: grass/trunk/imagery/i.smap/segment.c
--- grass/trunk/imagery/i.smap/segment.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.smap/segment.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -47,8 +47,8 @@
ml = parms->ml; /* use maxl? */
block_size = parms->blocksize;
- wd = G_window_cols(); /* get width from GRASS */
- ht = G_window_rows(); /* get height from GRASS */
+ wd = Rast_window_cols(); /* get width from GRASS */
+ ht = Rast_window_rows(); /* get height from GRASS */
/* make blocksize a power of 2 */
if (block_size < 8)
Modified: grass/trunk/imagery/i.sunhours/main.c
--- grass/trunk/imagery/i.sunhours/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.sunhours/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -77,8 +77,8 @@
inrast_lat = Rast_allocate_d_buf();
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.vi/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -238,8 +238,8 @@
inrast_chan7chan = Rast_allocate_d_buf();
Modified: grass/trunk/imagery/i.vpoints/drawcell.c
--- grass/trunk/imagery/i.vpoints/drawcell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.vpoints/drawcell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -47,8 +47,8 @@
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/imagery/i.zc/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -121,8 +121,8 @@
- or = G_window_rows();
- oc = G_window_cols();
+ or = Rast_window_rows();
+ oc = Rast_window_cols();
rows = G_math_max_pow2((long)or);
cols = G_math_max_pow2((long)oc);
size = (rows > cols) ? rows : cols;
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/include/gisdefs.h 2010-02-01 17:53:15 UTC (rev 40771)
@@ -50,9 +50,6 @@
void G_adjust_Cell_head(struct Cell_head *, int, int);
void G_adjust_Cell_head3(struct Cell_head *, int, int, int);
-/* align_window.c */
-void G_align_window(struct Cell_head *, const struct Cell_head *);
/* alloc.c */
#define G_incr_void_ptr(ptr, size) \
((void *)((const unsigned char *)(ptr) + (size)))
@@ -675,14 +672,8 @@
int G_scan_resolution(const char *, double *, int);
/* window_map.c */
-double G_northing_to_row(double, const struct Cell_head *);
double G_adjust_east_longitude(double, double);
double G_adjust_easting(double, const struct Cell_head *);
-double G_easting_to_col(double, const struct Cell_head *);
-double G_row_to_northing(double, const struct Cell_head *);
-double G_col_to_easting(double, const struct Cell_head *);
-int G_window_rows(void);
-int G_window_cols(void);
void G__init_window(void);
/* worker.c */
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/include/rasterdefs.h 2010-02-01 17:53:15 UTC (rev 40771)
@@ -5,6 +5,9 @@
/* --- ANSI prototypes for the lib/raster functions --- */
+/* align_window.c */
+void Rast_align_window(struct Cell_head *, const struct Cell_head *);
/* alloc_cell.c */
size_t Rast_cell_size(RASTER_MAP_TYPE);
void *Rast_allocate_buf(RASTER_MAP_TYPE);
@@ -517,6 +520,14 @@
/* set_window.c */
void Rast_set_window(struct Cell_head *);
+/* window.c */
+double Rast_northing_to_row(double, const struct Cell_head *);
+double Rast_easting_to_col(double, const struct Cell_head *);
+double Rast_row_to_northing(double, const struct Cell_head *);
+double Rast_col_to_easting(double, const struct Cell_head *);
+int Rast_window_rows(void);
+int Rast_window_cols(void);
/* window_map.c */
void Rast__create_window_mapping(int);
int Rast_row_repeat_nomask(int, int);
Deleted: grass/trunk/lib/gis/align_window.c
--- grass/trunk/lib/gis/align_window.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/gis/align_window.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -1,74 +0,0 @@
- * \file gis/align_window.c
- * \brief GIS Library - Window alignment functions.
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
-#include <stdio.h>
-#include <math.h>
-#include <grass/gis.h>
- * \brief Align two regions.
- * Modifies the input <i>window</i> to align to <i>ref</i> region. The
- * resolutions in <i>window</i> are set to match those in <i>ref</i>
- * and the <i>window</i> edges (north, south, east, west) are modified
- * to align with the grid of the <i>ref</i> region.
- * The <i>window</i> may be enlarged if necessary to achieve the
- * alignment. The north is rounded northward, the south southward,
- * the east eastward and the west westward. Lon-lon constraints are
- * taken into consideration to make sure that the north doesn't go
- * above 90 degrees (for lat/lon) or that the east does "wrap" past
- * the west, etc.
- * \param[in,out] window pointer to Cell_head to be modified
- * \param ref pointer to Cell_head
- * \return NULL on success
-void G_align_window(struct Cell_head *window, const struct Cell_head *ref)
- int preserve;
- window->ns_res = ref->ns_res;
- window->ew_res = ref->ew_res;
- window->zone = ref->zone;
- window->proj = ref->proj;
- preserve = window->proj == PROJECTION_LL &&
- window->east == (window->west + 360);
- window->south =
- G_row_to_northing(ceil(G_northing_to_row(window->south, ref)), ref);
- window->north =
- G_row_to_northing(floor(G_northing_to_row(window->north, ref)), ref);
- window->east =
- G_col_to_easting(ceil(G_easting_to_col(window->east, ref)), ref);
- window->west =
- G_col_to_easting(floor(G_easting_to_col(window->west, ref)), ref);
- if (window->proj == PROJECTION_LL) {
- while (window->north > 90.0)
- window->north -= window->ns_res;
- while (window->south < -90.0)
- window->south += window->ns_res;
- if (preserve)
- window->east = window->west + 360;
- else
- while (window->east - window->west > 360.0)
- window->east -= window->ew_res;
- G_adjust_Cell_head(window, 0, 0);
Modified: grass/trunk/lib/gis/get_window.c
--- grass/trunk/lib/gis/get_window.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/gis/get_window.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -39,7 +39,7 @@
* should not use this routine since its use implies that the active
* module region will not be used. Programs that read or write raster
* map data (or vector data) can query the active module region using
- * G_window_rows() and G_window_cols().
+ * Rast_window_rows() and Rast_window_cols().
* \param window pointer to Cell_head
Modified: grass/trunk/lib/gis/window_map.c
--- grass/trunk/lib/gis/window_map.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/gis/window_map.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -11,34 +11,12 @@
-#include <stdlib.h>
#include "G.h"
- * \brief Northing to row.
- * Converts a <i>north</i>ing relative to a <i>window</i> to a row.
- * <b>Note:</b> The result is a double. Casting it to an integer will
- * give the row number.
- * \param north northing value
- * \param window pointer to Cell_head
- * \return row number
-double G_northing_to_row(double north, const struct Cell_head *window)
- return (window->north - north) / window->ns_res;
* \brief Adjust east longitude.
* This routine returns an equivalent <i>east</i> that is
@@ -91,131 +69,6 @@
- * \brief Easting to column.
- * Converts <i>east</i> relative to a <i>window</i> to a column.
- * <b>Note:</b> The result is a <i>double</i>. Casting it to an
- * <i>int</i> will give the column number.
- * \param east east coordinate
- * \return column number
-double G_easting_to_col(double east, const struct Cell_head *window)
- east = G_adjust_easting(east, window);
- return (east - window->west) / window->ew_res;
- * \brief Row to northing.
- * Converts a <i>row</i> relative to a <i>window</i> to a
- * northing.
- * <b>Note:</b> row is a double:
- * - row+0.0 will return the northing for the northern edge of the row.
- * - row+0.5 will return the northing for the center of the row.
- * - row+1.0 will return the northing for the southern edge of the row.
- * \param row row number
- * \param[in] window pointer to Cell_head
- * \return north coordinate
-double G_row_to_northing(double row, const struct Cell_head *window)
- return window->north - row * window->ns_res;
- * \brief Column to easting.
- * Converts a <i>col</i> relative to a <i>window</i> to an easting.
- * <b>Note:</b> <i>col</i> is a <i>double</i>:
- * - col+0.0 will return the easting for the western edge of the column.
- * - col+0.5 will return the easting for the center of the column.
- * - col+1.0 will return the easting for the eastern edge of the column.
- * \param col column number
- * \return east coordinate
-double G_col_to_easting(double col, const struct Cell_head *window)
- return window->west + col * window->ew_res;
- * \brief Number of rows in active window.
- * This routine returns the number of rows in the active module window.
- * Before raster files can be read or written, it is necessary to
- * known how many rows are in the active window. For example:
- \code
-int nrows, cols;
-int row, col;
-nrows = G_window_rows();
-ncols = G_window_cols();
-for (row = 0; row < nrows; row++) {
- // read row ...
- for (col = 0; col < ncols; col++) {
- // process col ...
- \endcode
- * \return number of rows
- G__init_window();
- return G__.window.rows;
- * \brief Number of columns in active window.
- * These routines return the number of rows and columns (respectively)
- * in the active module region. Before raster maps can be read or
- * written, it is necessary to known how many rows and columns are in
- * the active region. For example:
- \code
-int nrows, cols;
-int row, col;
- // read row ...
- \endcode
- * \return number of columns
- G__init_window();
- return G__.window.cols;
* \brief Initialize window.
Copied: grass/trunk/lib/raster/align_window.c (from rev 40768, grass/trunk/lib/gis/align_window.c)
--- grass/trunk/lib/raster/align_window.c (rev 0)
+++ grass/trunk/lib/raster/align_window.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -0,0 +1,75 @@
+ * \file gis/align_window.c
+ * \brief GIS Library - Window alignment functions.
+ * (C) 2001-2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Original author CERL
+#include <stdio.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+ * \brief Align two regions.
+ * Modifies the input <i>window</i> to align to <i>ref</i> region. The
+ * resolutions in <i>window</i> are set to match those in <i>ref</i>
+ * and the <i>window</i> edges (north, south, east, west) are modified
+ * to align with the grid of the <i>ref</i> region.
+ * The <i>window</i> may be enlarged if necessary to achieve the
+ * alignment. The north is rounded northward, the south southward,
+ * the east eastward and the west westward. Lon-lon constraints are
+ * taken into consideration to make sure that the north doesn't go
+ * above 90 degrees (for lat/lon) or that the east does "wrap" past
+ * the west, etc.
+ * \param[in,out] window pointer to Cell_head to be modified
+ * \param ref pointer to Cell_head
+ * \return NULL on success
+void Rast_align_window(struct Cell_head *window, const struct Cell_head *ref)
+ int preserve;
+ window->ns_res = ref->ns_res;
+ window->ew_res = ref->ew_res;
+ window->zone = ref->zone;
+ window->proj = ref->proj;
+ preserve = window->proj == PROJECTION_LL &&
+ window->east == (window->west + 360);
+ window->south =
+ Rast_row_to_northing(ceil(Rast_northing_to_row(window->south, ref)), ref);
+ window->north =
+ Rast_row_to_northing(floor(Rast_northing_to_row(window->north, ref)), ref);
+ window->east =
+ Rast_col_to_easting(ceil(Rast_easting_to_col(window->east, ref)), ref);
+ window->west =
+ Rast_col_to_easting(floor(Rast_easting_to_col(window->west, ref)), ref);
+ if (window->proj == PROJECTION_LL) {
+ while (window->north > 90.0)
+ window->north -= window->ns_res;
+ while (window->south < -90.0)
+ window->south += window->ns_res;
+ if (preserve)
+ window->east = window->west + 360;
+ else
+ while (window->east - window->west > 360.0)
+ window->east -= window->ew_res;
+ G_adjust_Cell_head(window, 0, 0);
Modified: grass/trunk/lib/raster/alloc_cell.c
--- grass/trunk/lib/raster/alloc_cell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/raster/alloc_cell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -54,7 +54,7 @@
void *Rast_allocate_buf(RASTER_MAP_TYPE data_type)
- return (void *)G_calloc(G_window_cols() + 1, Rast_cell_size(data_type));
+ return (void *)G_calloc(Rast_window_cols() + 1, Rast_cell_size(data_type));
@@ -81,7 +81,7 @@
CELL *Rast_allocate_c_buf(void)
- return (CELL *) G_calloc(G_window_cols() + 1, sizeof(CELL));
+ return (CELL *) G_calloc(Rast_window_cols() + 1, sizeof(CELL));
@@ -94,7 +94,7 @@
FCELL *Rast_allocate_f_buf(void)
- return (FCELL *) G_calloc(G_window_cols() + 1, sizeof(FCELL));
+ return (FCELL *) G_calloc(Rast_window_cols() + 1, sizeof(FCELL));
@@ -107,7 +107,7 @@
DCELL *Rast_allocate_d_buf(void)
- return (DCELL *) G_calloc(G_window_cols() + 1, sizeof(DCELL));
+ return (DCELL *) G_calloc(Rast_window_cols() + 1, sizeof(DCELL));
@@ -120,7 +120,7 @@
char *Rast_allocate_null_buf(void)
- return (char *)G_calloc(G_window_cols() + 1, sizeof(char));
+ return (char *)G_calloc(Rast_window_cols() + 1, sizeof(char));
Modified: grass/trunk/lib/raster/get_row_colr.c
--- grass/trunk/lib/raster/get_row_colr.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/raster/get_row_colr.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -40,7 +40,7 @@
unsigned char *red, unsigned char *grn,
unsigned char *blu, unsigned char *nul)
int type = Rast_get_map_type(fd);
int size = Rast_cell_size(type);
void *array;
Modified: grass/trunk/lib/raster/sample.c
--- grass/trunk/lib/raster/sample.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/raster/sample.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -98,11 +98,11 @@
DCELL *maprow = Rast_allocate_d_buf();
/* convert northing and easting to row and col, resp */
- row = (int)floor(G_northing_to_row(north, window));
- col = (int)floor(G_easting_to_col(east, window));
+ row = (int)floor(Rast_northing_to_row(north, window));
+ col = (int)floor(Rast_easting_to_col(east, window));
- if (row < 0 || row >= G_window_rows() ||
- col < 0 || col >= G_window_cols()) {
+ if (row < 0 || row >= Rast_window_rows() ||
+ col < 0 || col >= Rast_window_cols()) {
Rast_set_d_null_value(&result, 1);
goto done;
@@ -157,8 +157,8 @@
double frow, fcol, trow, tcol;
DCELL result;
- frow = G_northing_to_row(north, window);
- fcol = G_easting_to_col(east, window);
+ frow = Rast_northing_to_row(north, window);
+ fcol = Rast_easting_to_col(east, window);
row = (int)floor(frow - 0.5);
@@ -167,8 +167,8 @@
trow = frow - row - 0.5;
tcol = fcol - col - 0.5;
goto done;
@@ -249,8 +249,8 @@
for (i = 0; i < 4; i++)
rows[i] = Rast_allocate_d_buf();
row = (int)floor(frow - 1.5);
@@ -259,8 +259,8 @@
trow = frow - row - 1.5;
tcol = fcol - col - 1.5;
- if (row < 0 || row + 3 >= G_window_rows() ||
- col < 0 || col + 3 >= G_window_cols()) {
+ if (row < 0 || row + 3 >= Rast_window_rows() ||
+ col < 0 || col + 3 >= Rast_window_cols()) {
goto done;
Added: grass/trunk/lib/raster/window.c
--- grass/trunk/lib/raster/window.c (rev 0)
+++ grass/trunk/lib/raster/window.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -0,0 +1,151 @@
+#include "../gis/G.h"
+#include "R.h"
+ * \brief Number of rows in active window.
+ * This routine returns the number of rows in the active module window.
+ * Before raster files can be read or written, it is necessary to
+ * known how many rows are in the active window. For example:
+ \code
+int nrows, cols;
+int row, col;
+nrows = Rast_window_rows();
+ncols = Rast_window_cols();
+for (row = 0; row < nrows; row++) {
+ // read row ...
+ for (col = 0; col < ncols; col++) {
+ // process col ...
+ \endcode
+ * \return number of rows
+ G__init_window();
+ return G__.window.rows;
+ * \brief Number of columns in active window.
+ * These routines return the number of rows and columns (respectively)
+ * in the active module region. Before raster maps can be read or
+ * written, it is necessary to known how many rows and columns are in
+ * the active region. For example:
+ \code
+int nrows, cols;
+int row, col;
+ // read row ...
+ \endcode
+ * \return number of columns
+ G__init_window();
+ return G__.window.cols;
+ * \brief Northing to row.
+ * Converts a <i>north</i>ing relative to a <i>window</i> to a row.
+ * <b>Note:</b> The result is a double. Casting it to an integer will
+ * give the row number.
+ * \param north northing value
+ * \param window pointer to Cell_head
+ * \return row number
+double Rast_northing_to_row(double north, const struct Cell_head *window)
+ return (window->north - north) / window->ns_res;
+ * \brief Easting to column.
+ * Converts <i>east</i> relative to a <i>window</i> to a column.
+ * <b>Note:</b> The result is a <i>double</i>. Casting it to an
+ * <i>int</i> will give the column number.
+ * \param east east coordinate
+ * \return column number
+double Rast_easting_to_col(double east, const struct Cell_head *window)
+ east = G_adjust_easting(east, window);
+ return (east - window->west) / window->ew_res;
+ * \brief Row to northing.
+ * Converts a <i>row</i> relative to a <i>window</i> to a
+ * northing.
+ * <b>Note:</b> row is a double:
+ * - row+0.0 will return the northing for the northern edge of the row.
+ * - row+0.5 will return the northing for the center of the row.
+ * - row+1.0 will return the northing for the southern edge of the row.
+ * \param row row number
+ * \param[in] window pointer to Cell_head
+ * \return north coordinate
+double Rast_row_to_northing(double row, const struct Cell_head *window)
+ return window->north - row * window->ns_res;
+ * \brief Column to easting.
+ * Converts a <i>col</i> relative to a <i>window</i> to an easting.
+ * <b>Note:</b> <i>col</i> is a <i>double</i>:
+ * - col+0.0 will return the easting for the western edge of the column.
+ * - col+0.5 will return the easting for the center of the column.
+ * - col+1.0 will return the easting for the eastern edge of the column.
+ * \param col column number
+ * \return east coordinate
+double Rast_col_to_easting(double col, const struct Cell_head *window)
+ return window->west + col * window->ew_res;
Modified: grass/trunk/lib/raster/zero_cell.c
--- grass/trunk/lib/raster/zero_cell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/raster/zero_cell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -27,7 +27,7 @@
void Rast_zero_c_buf(CELL * buf)
- int i = G_window_cols();
+ int i = Rast_window_cols();
while (i--)
*buf++ = 0;
@@ -45,5 +45,5 @@
void Rast_zero_buf(void *rast, RASTER_MAP_TYPE data_type)
- memset(rast, 0, G_window_cols() * Rast_cell_size(data_type));
+ memset(rast, 0, Rast_window_cols() * Rast_cell_size(data_type));
Modified: grass/trunk/lib/rst/interp_float/output2d.c
--- grass/trunk/lib/rst/interp_float/output2d.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/lib/rst/interp_float/output2d.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -95,15 +95,15 @@
Rast_set_window(cellhd);
- if (nrows != G_window_rows()) {
+ if (nrows != Rast_window_rows()) {
G_warning(_("Rows changed from %d to %d"), nrows,
- G_window_rows());
+ Rast_window_rows());
return -1;
- if (ncols != G_window_cols()) {
+ if (ncols != Rast_window_cols()) {
G_warning(_("Cols changed from %d to %d"), ncols,
- G_window_cols());
+ Rast_window_cols());
return -1;
Modified: grass/trunk/ps/ps.map/do_masking.c
--- grass/trunk/ps/ps.map/do_masking.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/ps/ps.map/do_masking.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -24,11 +24,11 @@
/* adjust columns to multiple of 8 */
while (cols % 8)
cols++;
- factor = (double)cols / (double)G_window_cols();
+ factor = (double)cols / (double)Rast_window_cols();
width = factor * PS.map_pix_wide;
/* write mask to PostScript file, using "no data" color */
Modified: grass/trunk/ps/ps.map/ps_outline.c
--- grass/trunk/ps/ps.map/ps_outline.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/ps/ps.map/ps_outline.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -116,14 +116,14 @@
k = 0;
raster_size = Rast_cell_size(map_type);
while (read_next()) { /* read rest of file, one row at *//* a time */
- n1 = G_row_to_northing((double)row - 1., &(PS.w));
- n2 = G_row_to_northing((double)row, &(PS.w));
- n3 = G_row_to_northing((double)row + 1., &(PS.w));
+ n1 = Rast_row_to_northing((double)row - 1., &(PS.w));
+ n2 = Rast_row_to_northing((double)row, &(PS.w));
+ n3 = Rast_row_to_northing((double)row + 1., &(PS.w));
for (col = 0; col < scan_length - 1; col++) {
- e1 = G_col_to_easting((double)col - 1., &(PS.w));
- e2 = G_col_to_easting((double)col, &(PS.w));
- e3 = G_col_to_easting((double)col + 1., &(PS.w));
+ e1 = Rast_col_to_easting((double)col - 1., &(PS.w));
+ e2 = Rast_col_to_easting((double)col, &(PS.w));
+ e3 = Rast_col_to_easting((double)col + 1., &(PS.w));
tl = G_incr_void_ptr(buffer[top], col * raster_size);
/* top left in window */
tr = G_incr_void_ptr(buffer[top], (col + 1) * raster_size);
Modified: grass/trunk/raster/r.basins.fill/main.c
--- grass/trunk/raster/r.basins.fill/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.basins.fill/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -94,8 +94,8 @@
Rast_get_cellhd(drain_name, "", &window);
Rast_set_window(&window);
ridge_name = ridge_opt->answer;
Modified: grass/trunk/raster/r.bitpattern/main.c
--- grass/trunk/raster/r.bitpattern/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.bitpattern/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -107,8 +107,8 @@
outfd = Rast_open_new(result, data_type);
Modified: grass/trunk/raster/r.carve/enforce_ds.c
--- grass/trunk/raster/r.carve/enforce_ds.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.carve/enforce_ds.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -73,7 +73,7 @@
/* allocate and clear memory for entire raster */
rbuf =
- G_calloc(G_window_rows() * G_window_cols(),
+ G_calloc(Rast_window_rows() * Rast_window_cols(),
Rast_cell_size(parm->raster_type));
/* first read whole elevation file into buf */
@@ -122,7 +122,7 @@
return 0;
if (!bm)
- bm = BM_create(G_window_cols(), G_window_rows());
+ bm = BM_create(Rast_window_cols(), Rast_window_rows());
clear_bitmap(bm);
pg_init(&pg);
@@ -133,12 +133,12 @@
for (i = 0; i < points->n_points; i++) {
Point2 pt, ptxy;
double elev;
- int row = G_northing_to_row(points->y[i], &wind);
- int col = G_easting_to_col(points->x[i], &wind);
+ int row = Rast_northing_to_row(points->y[i], &wind);
+ int col = Rast_easting_to_col(points->x[i], &wind);
/* rough clipping */
- if (row < 0 || row > G_window_rows() - 1 ||
- col < 0 || col > G_window_cols() - 1) {
+ if (row < 0 || row > Rast_window_rows() - 1 ||
+ col < 0 || col > Rast_window_cols() - 1) {
if (first_in != -1)
in_out = 1;
@@ -210,8 +210,8 @@
int i, j;
- for (i = 0; i < G_window_rows(); i++)
- for (j = 0; j < G_window_cols(); j++)
+ for (i = 0; i < Rast_window_rows(); i++)
+ for (j = 0; j < Rast_window_cols(); j++)
BM_set(bm, i, j, 0);
@@ -278,24 +278,24 @@
CELL *cbuf = data;
- cbuf[row * G_window_cols() + col] =
- MIN(cbuf[row * G_window_cols() + col], elev) - (int)depth;
+ cbuf[row * Rast_window_cols() + col] =
+ MIN(cbuf[row * Rast_window_cols() + col], elev) - (int)depth;
break;
case FCELL_TYPE:
FCELL *fbuf = data;
- fbuf[row * G_window_cols() + col] =
- MIN(fbuf[row * G_window_cols() + col], elev) - depth;
+ fbuf[row * Rast_window_cols() + col] =
+ MIN(fbuf[row * Rast_window_cols() + col], elev) - depth;
break;
case DCELL_TYPE:
DCELL *dbuf = data;
- dbuf[row * G_window_cols() + col] =
- MIN(dbuf[row * G_window_cols() + col], elev) - depth;
+ dbuf[row * Rast_window_cols() + col] =
+ MIN(dbuf[row * Rast_window_cols() + col], elev) - depth;
break;
@@ -313,8 +313,8 @@
struct Cell_head wind;
G_get_window(&wind);
- rastrows = G_window_rows();
- rastcols = G_window_cols();
+ rastrows = Rast_window_rows();
+ rastcols = Rast_window_cols();
Rast_set_d_null_value(&min, 1);
@@ -322,8 +322,8 @@
rowoff = rad / wind.ns_res;
coloff = rad / wind.ew_res;
- row = G_northing_to_row(py, &wind);
- col = G_easting_to_col(px, &wind);
+ row = Rast_northing_to_row(py, &wind);
+ col = Rast_easting_to_col(px, &wind);
/* get bounding box of line segment */
row1 = MAX(0, row - rowoff);
@@ -359,11 +359,11 @@
for (r = row1; r < row2; r++) {
- double cy = G_row_to_northing(r + 0.5, &wind);
+ double cy = Rast_row_to_northing(r + 0.5, &wind);
int c;
for (c = col1; c < col2; c++) {
- double cx = G_col_to_easting(c + 0.5, &wind);
+ double cx = Rast_col_to_easting(c + 0.5, &wind);
if (G_distance(px, py, cx, cy) <= SQR(rad)) {
switch (rtype) {
@@ -450,26 +450,26 @@
coloff = parm->swidth / wind.ew_res;
/* get prevrow and prevcol for iteration 0 of following loop */
- prevrow = G_northing_to_row(pgxypts[0][1], &wind);
- prevcol = G_easting_to_col(pgxypts[0][0], &wind);
+ prevrow = Rast_northing_to_row(pgxypts[0][1], &wind);
+ prevcol = Rast_easting_to_col(pgxypts[0][0], &wind);
for (i = 1; i < (npts - 1); i++) {
int c, r;
- int row = G_northing_to_row(pgxypts[i][1], &wind);
- int col = G_easting_to_col(pgxypts[i][0], &wind);
+ int row = Rast_northing_to_row(pgxypts[i][1], &wind);
+ int col = Rast_easting_to_col(pgxypts[i][0], &wind);
row1 = MAX(0, MIN(row, prevrow) - rowoff);
- row2 = MIN(G_window_rows() - 1, MAX(row, prevrow) + rowoff);
+ row2 = MIN(Rast_window_rows() - 1, MAX(row, prevrow) + rowoff);
col1 = MAX(0, MIN(col, prevcol) - coloff);
- col2 = MIN(G_window_cols() - 1, MAX(col, prevcol) + coloff);
+ col2 = MIN(Rast_window_cols() - 1, MAX(col, prevcol) + coloff);
- cy = G_row_to_northing(r + 0.5, &wind);
+ cy = Rast_row_to_northing(r + 0.5, &wind);
- cellx = G_col_to_easting(c + 0.5, &wind);
+ cellx = Rast_col_to_easting(c + 0.5, &wind);
celly = cy; /* gets written over in distance2... */
/* Thought about not going past endpoints (use
Modified: grass/trunk/raster/r.carve/raster.c
--- grass/trunk/raster/r.carve/raster.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.carve/raster.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -7,7 +7,7 @@
void *read_raster(void *buf, const int fd, const RASTER_MAP_TYPE rtype)
void *tmpbuf = buf;
int i;
G_message(_("Reading raster map..."));
@@ -17,7 +17,7 @@
Rast_get_row(fd, tmpbuf, i, rtype);
tmpbuf =
- G_incr_void_ptr(tmpbuf, Rast_cell_size(rtype) * G_window_cols());
+ G_incr_void_ptr(tmpbuf, Rast_cell_size(rtype) * Rast_window_cols());
return tmpbuf;
@@ -27,7 +27,7 @@
void *write_raster(void *buf, const int fd, const RASTER_MAP_TYPE rtype)
void *tmpbuf = buf;
int i;
G_message(_("Writing raster map..."));
@@ -37,7 +37,7 @@
Rast_put_row(fd, tmpbuf, rtype);
tmpbuf =
return tmpbuf;
Modified: grass/trunk/raster/r.category/cats.c
--- grass/trunk/raster/r.category/cats.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.category/cats.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -38,8 +38,8 @@
/* open the raster map */
cell = Rast_allocate_c_buf();
Rast_init_cell_stats(&statf);
Modified: grass/trunk/raster/r.circle/main.c
--- grass/trunk/raster/r.circle/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.circle/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -131,10 +131,10 @@
for (row = 0; row < w.rows; row++) {
G_percent(row, w.rows, 2);
- cur[1] = G_row_to_northing(row + 0.5, &w);
+ cur[1] = Rast_row_to_northing(row + 0.5, &w);
for (col = 0; col < w.cols; col++) {
c = col;
- cur[0] = G_col_to_easting(col + 0.5, &w);
+ cur[0] = Rast_col_to_easting(col + 0.5, &w);
int_buf[c] =
(int)(distance(pt, cur, fmin, fmax, binary) * fmult);
if (int_buf[c] == 0)
Modified: grass/trunk/raster/r.clump/clump.c
--- grass/trunk/raster/r.clump/clump.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.clump/clump.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -44,8 +44,8 @@
int column;
/* allocate reclump index */
nalloc = INCR;
Modified: grass/trunk/raster/r.coin/main.c
--- grass/trunk/raster/r.coin/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.coin/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -117,7 +117,7 @@
dumpname = G_tempfile();
statname = G_tempfile();
- window_cells = G_window_rows() * G_window_cols();
+ window_cells = Rast_window_rows() * Rast_window_cols();
map1name = parm.map1->answer;
map2name = parm.map2->answer;
Modified: grass/trunk/raster/r.colors/stats.c
--- grass/trunk/raster/r.colors/stats.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.colors/stats.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -33,8 +33,8 @@
Rast_init_cell_stats(statf);
G_verbose_message(_("Reading raster map <%s>..."),
@@ -62,8 +62,8 @@
dcell = Rast_allocate_d_buf();
statf->geometric = geometric;
statf->geom_abs = geom_abs;
Modified: grass/trunk/raster/r.compress/main.c
--- grass/trunk/raster/r.compress/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.compress/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -202,7 +202,7 @@
else
new = Rast_open_new(name, map_type);
rast = Rast_allocate_buf(map_type);
oldsize = lseek(old, (off_t) 0, SEEK_END);
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.cost/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -340,8 +340,8 @@
move_dir_layer = opt11->answer;
/* Find number of rows and columns in window */
/* Open cost cell layer for reading */
cost_mapset = G_find_raster2(cost_layer, "");
@@ -540,8 +540,8 @@
continue;
got_one = 1;
- col = (int)G_easting_to_col(site->east, &window);
- row = (int)G_northing_to_row(site->north, &window);
+ col = (int)Rast_easting_to_col(site->east, &window);
+ row = (int)Rast_northing_to_row(site->north, &window);
new_start_pt =
(struct start_pt *)(G_malloc(sizeof(struct start_pt)));
@@ -589,8 +589,8 @@
continue;
have_stop_points = 1;
new_start_pt =
Modified: grass/trunk/raster/r.covar/main.c
--- grass/trunk/raster/r.covar/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.covar/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -79,8 +79,8 @@
fd[i] = Rast_open_old(name, "");
G_message(_("%s: complete ... "), G_program_name());
count = 0;
Modified: grass/trunk/raster/r.cross/main.c
--- grass/trunk/raster/r.cross/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.cross/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -95,8 +95,8 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
nfiles = 0;
non_zero = flag.z->answer;
Modified: grass/trunk/raster/r.describe/describe.c
--- grass/trunk/raster/r.describe/describe.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.describe/describe.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -88,8 +88,8 @@
Rast_set_quant_rules(fd, &q);
G_verbose_message(_("Reading <%s> ..."), name);
Modified: grass/trunk/raster/r.distance/distance.c
--- grass/trunk/raster/r.distance/distance.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.distance/distance.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -37,8 +37,8 @@
double dist;
double e1, n1, e2, n2;
extern double G_distance();
- extern double G_row_to_northing();
- extern double G_col_to_easting();
+ extern double Rast_row_to_northing();
+ extern double Rast_col_to_easting();
int zerro_row, zerro_col;
int nulldistance = 0;
@@ -48,18 +48,18 @@
nulldistance = null_distance(name1, name2, &zerro_row, &zerro_col);
for (i1 = 0; i1 < list1->ncells; i1++) {
- e1 = G_col_to_easting(list1->col[i1] + 0.5, region);
- n1 = G_row_to_northing(list1->row[i1] + 0.5, region);
+ e1 = Rast_col_to_easting(list1->col[i1] + 0.5, region);
+ n1 = Rast_row_to_northing(list1->row[i1] + 0.5, region);
for (i2 = 0; i2 < list2->ncells; i2++) {
if (!nulldistance) {
- e2 = G_col_to_easting(list2->col[i2] + 0.5, region);
- n2 = G_row_to_northing(list2->row[i2] + 0.5, region);
+ e2 = Rast_col_to_easting(list2->col[i2] + 0.5, region);
+ n2 = Rast_row_to_northing(list2->row[i2] + 0.5, region);
dist = G_distance(e1, n1, e2, n2);
else {
- e2 = e1 = G_col_to_easting(zerro_col + 0.5, region);
- n2 = n1 = G_row_to_northing(zerro_row + 0.5, region);
+ e2 = e1 = Rast_col_to_easting(zerro_col + 0.5, region);
+ n2 = n1 = Rast_row_to_northing(zerro_row + 0.5, region);
dist = 0.;
@@ -101,8 +101,8 @@
G_message(_("Reading maps <%s,%s> while finding 0 distance ..."), name1,
name2);
Modified: grass/trunk/raster/r.distance/edges.c
--- grass/trunk/raster/r.distance/edges.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.distance/edges.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -45,8 +45,8 @@
G_message(_("Reading map %s ..."), map->fullname);
buf0 = (CELL *) G_calloc(ncols + 2, sizeof(CELL));
buf1 = (CELL *) G_calloc(ncols + 2, sizeof(CELL));
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.drain/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -223,8 +223,8 @@
/* get the window information */
if (opt4->answer) {
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -240,8 +240,8 @@
for (i = 0; coordopt->answers[i] != NULL; i += 2) {
G_scan_easting(coordopt->answers[i], &east, G_projection());
G_scan_northing(coordopt->answers[i + 1], &north, G_projection());
- start_col = (int)G_easting_to_col(east, &window);
- start_row = (int)G_northing_to_row(north, &window);
+ start_col = (int)Rast_easting_to_col(east, &window);
+ start_row = (int)Rast_northing_to_row(north, &window);
if (start_row < 0 || start_row > nrows ||
start_col < 0 || start_col > ncols) {
@@ -277,8 +277,8 @@
if (!G_site_in_region(site, &window))
continue;
- start_col = (int)G_easting_to_col(site->east, &window);
- start_row = (int)G_northing_to_row(site->north, &window);
+ start_col = (int)Rast_easting_to_col(site->east, &window);
+ start_row = (int)Rast_northing_to_row(site->north, &window);
/* effectively just a duplicate check to G_site_in_region() ??? */
if (start_row < 0 || start_row > nrows || start_col < 0 ||
Modified: grass/trunk/raster/r.fill.dir/main.c
--- grass/trunk/raster/r.fill.dir/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.fill.dir/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -184,8 +184,8 @@
/* buffers for internal use */
bndC.ns = ncols;
Modified: grass/trunk/raster/r.flow/precomp.c
--- grass/trunk/raster/r.flow/precomp.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.flow/precomp.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -80,9 +80,9 @@
if (G_projection() == PROJECTION_LL) {
for (row = 0; row < region.rows; row++) {
- northing = G_row_to_northing(row + 0.5, ®ion);
- ew_dist[row] = G_distance(G_col_to_easting(0., ®ion), northing,
- G_col_to_easting(1., ®ion),
+ northing = Rast_row_to_northing(row + 0.5, ®ion);
+ ew_dist[row] = G_distance(Rast_col_to_easting(0., ®ion), northing,
+ Rast_col_to_easting(1., ®ion),
northing);
Modified: grass/trunk/raster/r.grow/main.c
--- grass/trunk/raster/r.grow/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.grow/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -170,8 +170,8 @@
if (opt.new->answer)
newval = atoi(opt.new->answer);
if (strcmp(opt.met->answer, "euclidean") == 0)
setup_neighbors_euclidean(radius);
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.grow.distance/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -56,10 +56,10 @@
static double geodesic_distance(int x1, int y1, int x2, int y2)
- double lat1 = G_row_to_northing(y1 + 0.5, &window);
- double lat2 = G_row_to_northing(y2 + 0.5, &window);
- double lon1 = G_col_to_easting(x1 + 0.5, &window);
- double lon2 = G_col_to_easting(x2 + 0.5, &window);
+ double lat1 = Rast_row_to_northing(y1 + 0.5, &window);
+ double lat2 = Rast_row_to_northing(y2 + 0.5, &window);
+ double lon1 = Rast_col_to_easting(x1 + 0.5, &window);
+ double lon2 = Rast_col_to_easting(x2 + 0.5, &window);
return G_geodesic_distance(lon1, lat1, lon2, lat2);
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.horizon/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -594,13 +594,13 @@
fd1 = Rast_open_fp_new(shad_filename);
- if (numrows != G_window_rows())
+ if (numrows != Rast_window_rows())
G_fatal_error(_("OOPS: rows changed from %d to %d"), numrows,
- G_window_rows());
- if (numcols != G_window_cols())
+ if (numcols != Rast_window_cols())
G_fatal_error(_("OOPS: cols changed from %d to %d"), numcols,
- G_window_cols());
for (iarc = 0; iarc < numrows; iarc++) {
i = numrows - iarc - 1;
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.in.arc/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -131,12 +131,12 @@
ncols = cellhd.cols;
G_fatal_error(_("OOPS: rows changed from %d to %d"), nrows,
- G_window_rows());
G_fatal_error(_("OOPS: cols changed from %d to %d"), ncols,
- G_window_cols());
switch (rtype) {
case CELL_TYPE:
Modified: grass/trunk/raster/r.in.ascii/main.c
--- grass/trunk/raster/r.in.ascii/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.in.ascii/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -191,12 +191,12 @@
- G_window_rows());
- G_window_cols());
rast_ptr = Rast_allocate_buf(data_type);
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.in.bin/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -473,13 +473,13 @@
- if (grass_nrows != G_window_rows())
+ if (grass_nrows != Rast_window_rows())
G_fatal_error("rows changed from %d to %d",
- grass_nrows, G_window_rows());
+ grass_nrows, Rast_window_rows());
- if (grass_ncols != G_window_cols())
+ if (grass_ncols != Rast_window_cols())
G_fatal_error("cols changed from %d to %d",
- grass_ncols, G_window_cols());
+ grass_ncols, Rast_window_cols());
expected = (off_t) ncols * nrows * bytes;
if (flag.gmt_hd->answer)
Modified: grass/trunk/raster/r.in.gridatb/adjcellhd.c
--- grass/trunk/raster/r.in.gridatb/adjcellhd.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.in.gridatb/adjcellhd.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -12,11 +12,11 @@
- if (cellhd->rows != G_window_rows()) {
+ if (cellhd->rows != Rast_window_rows()) {
retval = 2;
- if (cellhd->cols != G_window_cols()) {
+ if (cellhd->cols != Rast_window_cols()) {
retval = 3;
Modified: grass/trunk/raster/r.lake/main.c
--- grass/trunk/raster/r.lake/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.lake/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -214,8 +214,8 @@
if (lakemap)
lake_fd = Rast_open_new(lakemap, 1);
/* If we use x,y as seed... */
if (sdxy_opt->answer) {
@@ -225,8 +225,8 @@
G_scan_easting(sdxy_opt->answers[0], &east, G_projection());
G_scan_northing(sdxy_opt->answers[1], &north, G_projection());
if (start_row < 0 || start_row > rows ||
start_col < 0 || start_col > cols)
Modified: grass/trunk/raster/r.le/r.le.patch/driver.c
--- grass/trunk/raster/r.le/r.le.patch/driver.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.le/r.le.patch/driver.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -2807,8 +2807,8 @@
REGLIST *ptrfirst, *ptrthis, *ptrnew;
CELL *row_buf;
n_scale = 1;
Modified: grass/trunk/raster/r.le/r.le.patch/input.c
--- grass/trunk/raster/r.le/r.le.patch/input.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.le/r.le.patch/input.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -383,8 +383,8 @@
if (edge->answer) {
choice->edge = atoi(edge->answer);
if (choice->edge < 0 ||
- choice->edge >= G_window_rows() ||
- choice->edge >= G_window_cols()) {
+ choice->edge >= Rast_window_rows() ||
+ choice->edge >= Rast_window_cols()) {
fprintf(stderr, "\n");
fprintf(stderr,
" ***********************************************\n");
Modified: grass/trunk/raster/r.le/r.le.pixel/driver.c
--- grass/trunk/raster/r.le/r.le.pixel/driver.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.le/r.le.pixel/driver.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -1640,8 +1640,8 @@
data_type = Rast_map_type(choice->fn, G_mapset());
g_scale = 1;
Modified: grass/trunk/raster/r.le/r.le.setup/main.c
--- grass/trunk/raster/r.le/r.le.setup/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.le/r.le.setup/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -91,7 +91,7 @@
/* setup the current window for display & clear screen */
D_setup(1);
- Rw_l = (double)G_window_cols() / G_window_rows();
+ Rw_l = (double)Rast_window_cols() / Rast_window_rows();
/*R_open_driver(); */
/* R_font("romant"); */
Modified: grass/trunk/raster/r.le/r.le.trace/main.c
--- grass/trunk/raster/r.le/r.le.trace/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.le/r.le.trace/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -64,7 +64,7 @@
/* setup the current window for display */
G_system(" d.colormode float");
G_system(" d.frame -e");
R_open_driver();
R_font("romant");
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -593,7 +593,7 @@
lseek(random_access, 0, SEEK_SET);
cell_buf = Rast_allocate_d_buf();
- Rast_set_d_null_value(cell_buf, G_window_cols() + 1);
+ Rast_set_d_null_value(cell_buf, Rast_window_cols() + 1);
for (i = 0; i < g->sf_y + ((int)g->rl / 2); i++) {
Rast_put_row(mv_fd, cell_buf, DCELL_TYPE);
@@ -613,9 +613,9 @@
- for (i = 0; i < G_window_rows() - g->sf_y - g->rows; i++)
+ for (i = 0; i < Rast_window_rows() - g->sf_y - g->rows; i++)
return 1;
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.los/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -194,8 +194,8 @@
fcell = Rast_allocate_buf(FCELL_TYPE);
/* find number of rows and columns in elevation map */
/* open elevation overlay file for reading */
old = Rast_open_old(elev_layer, old_mapset);
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.mapcalc/map.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -27,8 +27,8 @@
G_get_window(¤t_region2);
- columns = G_window_cols();
+ columns = Rast_window_cols();
depths = 1;
Modified: grass/trunk/raster/r.mapcalc/xcoor.c
--- grass/trunk/raster/r.mapcalc/xcoor.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.mapcalc/xcoor.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -24,7 +24,7 @@
if (argt[0] != DCELL_TYPE)
return E_RES_TYPE;
- x = G_col_to_easting(0.5, ¤t_region2);
+ x = Rast_col_to_easting(0.5, ¤t_region2);
for (i = 0; i < columns; i++) {
res[i] = x;
@@ -46,7 +46,7 @@
return E_RES_TYPE;
- y = G_row_to_northing(current_row + 0.5, ¤t_region2);
+ y = Rast_row_to_northing(current_row + 0.5, ¤t_region2);
res[i] = y;
Modified: grass/trunk/raster/r.mfilter/main.c
--- grass/trunk/raster/r.mfilter/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.mfilter/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -108,8 +108,8 @@
in_name = opt1->answer;
buflen = ncols * sizeof(DCELL);
/* get the filter */
Modified: grass/trunk/raster/r.neighbors/bufs.c
--- grass/trunk/raster/r.neighbors/bufs.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.neighbors/bufs.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -15,12 +15,12 @@
int i;
int bufsize;
- bufsize = (G_window_cols() + 2 * ncb.nsize) * sizeof(DCELL);
+ bufsize = (Rast_window_cols() + 2 * ncb.nsize) * sizeof(DCELL);
ncb.buf = (DCELL **) G_malloc(ncb.nsize * sizeof(DCELL *));
for (i = 0; i < ncb.nsize; i++) {
ncb.buf[i] = (DCELL *) G_malloc(bufsize);
- Rast_set_d_null_value(ncb.buf[i], G_window_cols() + 2 * ncb.nsize);
+ Rast_set_d_null_value(ncb.buf[i], Rast_window_cols() + 2 * ncb.nsize);
return 0;
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.neighbors/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -211,12 +211,12 @@
if (!flag.align->answer) {
Rast_get_cellhd(ncb.oldcell, "", &cellhd);
- G_align_window(&window, &cellhd);
+ Rast_align_window(&window, &cellhd);
/* open raster maps */
in_fd = Rast_open_old(ncb.oldcell, "");
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.arc/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -126,8 +126,8 @@
raster = Rast_allocate_buf(out_type);
/* open arc file for writing */
if (do_stdout)
Modified: grass/trunk/raster/r.out.ascii/main.c
--- grass/trunk/raster/r.out.ascii/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.ascii/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -158,8 +158,8 @@
dp = 16;
/* open ascii file for writing or use stdout */
if (parm.output->answer && strcmp("-", parm.output->answer) != 0) {
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.bin/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -425,8 +425,8 @@
write_gmt_header(&header, swap_flag, fp);
in_buf = Rast_allocate_d_buf();
out_buf = G_malloc(ncols * bytes);
Modified: grass/trunk/raster/r.out.gridatb/adjcellhd.c
--- grass/trunk/raster/r.out.gridatb/adjcellhd.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.gridatb/adjcellhd.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -7,10 +7,10 @@
G_set_window(cellhd);
retval = 2;
retval = 3;
return (retval);
Modified: grass/trunk/raster/r.out.mat/main.c
--- grass/trunk/raster/r.out.mat/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.mat/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -293,12 +293,12 @@
/* data array, by increasing column */
raster =
- G_calloc((G_window_rows() + 1) * (G_window_cols() + 1),
+ G_calloc((Rast_window_rows() + 1) * (Rast_window_cols() + 1),
G_debug(1, "mem alloc is %d bytes\n", /* I think _cols()+1 is unneeded? */
- Rast_cell_size(map_type) * (G_window_rows() +
- 1) * (G_window_cols() + 1));
+ Rast_cell_size(map_type) * (Rast_window_rows() +
+ 1) * (Rast_window_cols() + 1));
G_verbose_message(_("Reading in map ... "));
@@ -306,7 +306,7 @@
for (row = 0, ptr = raster; row < mrows; row++,
ptr =
- (G_window_cols() + 1) * Rast_cell_size(map_type))) {
+ (Rast_window_cols() + 1) * Rast_cell_size(map_type))) {
Rast_get_row(fd, ptr, row, map_type);
G_percent(row, mrows, 2);
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.mpeg/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -175,8 +175,8 @@
G_debug(1, "encoder = [%s]", encoder);
- vrows = G_window_rows();
- vcols = G_window_cols();
+ vrows = Rast_window_rows();
+ vcols = Rast_window_cols();
nrows = vrows;
ncols = vcols;
@@ -259,7 +259,7 @@
pg = G_malloc(size);
pb = G_malloc(size);
- tsiz = G_window_cols();
+ tsiz = Rast_window_cols();
tr = (unsigned char *)G_malloc(tsiz);
tg = (unsigned char *)G_malloc(tsiz);
Modified: grass/trunk/raster/r.out.pov/main.c
--- grass/trunk/raster/r.out.pov/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.pov/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -173,8 +173,8 @@
- nrows = G_window_rows();
- ncols = G_window_cols();
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
if (nrows > YMAX || ncols > XMAX)
G_fatal_error(_("Raster map is too big! Exceeds %d columns or %d rows"),
XMAX, YMAX);
Modified: grass/trunk/raster/r.out.vrml/main.c
--- grass/trunk/raster/r.out.vrml/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.vrml/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -196,8 +196,8 @@
Zrange = (w->rows - 1) * w->ns_res;
Xrange = (w->cols - 1) * w->ew_res;
- transX = -(G_col_to_easting(0.5, w));
- transZ = -(G_row_to_northing(0.5, w));
+ transX = -(Rast_col_to_easting(0.5, w));
+ transZ = -(Rast_row_to_northing(0.5, w));
transY = -min;
if (Zrange >= Xrange && Zrange >= Yrange) { /* northing biggest */
Modified: grass/trunk/raster/r.out.vrml/put_grid.c
--- grass/trunk/raster/r.out.vrml/put_grid.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.out.vrml/put_grid.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -49,12 +49,12 @@
G_percent(row, rows - 1, 10);
Rast_get_f_row(elevfd, tf, row);
- coordz = G_row_to_northing((double)row, w);
+ coordz = Rast_row_to_northing((double)row, w);
do_coordcnv(&coordz, 'z');
/* write a row */
for (col = 0; col < cols; col++) {
- coordx = G_col_to_easting((double)col, w);
+ coordx = Rast_col_to_easting((double)col, w);
do_coordcnv(&coordx, 'x');
/* HACK: no nulls in vrml grid */
Modified: grass/trunk/raster/r.param.scale/process.c
--- grass/trunk/raster/r.param.scale/process.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.param.scale/process.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -65,8 +65,8 @@
G_get_window(®ion); /* Fill out the region structure (the */
/* geographical limits etc.) */
- nrows = G_window_rows(); /* Find out the number of rows and */
- ncols = G_window_cols(); /* columns of the raster. */
+ nrows = Rast_window_rows(); /* Find out the number of rows and */
+ ncols = Rast_window_cols(); /* columns of the raster. */
if ((region.ew_res / region.ns_res >= 1.01) || /* If EW and NS resolns are */
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.patch/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -112,8 +112,8 @@
presult = Rast_allocate_buf(out_type);
patch = Rast_allocate_buf(out_type);
G_verbose_message(_("Percent complete..."));
Modified: grass/trunk/raster/r.proj/bordwalk.c
--- grass/trunk/raster/r.proj/bordwalk.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.proj/bordwalk.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -192,14 +192,14 @@
/* adjust to edges */
- idx = (int)floor(G_easting_to_col(xmin, to_hd));
- xmin = G_col_to_easting(idx + 0.0, to_hd);
- idx = (int)floor(G_easting_to_col(xmax, to_hd));
- xmax = G_col_to_easting(idx + 1.0, to_hd);
- idx = (int)floor(G_northing_to_row(ymin, to_hd));
- ymin = G_row_to_northing(idx + 1.0, to_hd);
- idx = (int)floor(G_northing_to_row(ymax, to_hd));
- ymax = G_row_to_northing(idx + 0.0, to_hd);
+ idx = (int)floor(Rast_easting_to_col(xmin, to_hd));
+ xmin = Rast_col_to_easting(idx + 0.0, to_hd);
+ idx = (int)floor(Rast_easting_to_col(xmax, to_hd));
+ xmax = Rast_col_to_easting(idx + 1.0, to_hd);
+ idx = (int)floor(Rast_northing_to_row(ymin, to_hd));
+ ymin = Rast_row_to_northing(idx + 1.0, to_hd);
+ idx = (int)floor(Rast_northing_to_row(ymax, to_hd));
+ ymax = Rast_row_to_northing(idx + 0.0, to_hd);
to_hd->west = (xmin < to_hd->west) ? to_hd->west : xmin;
to_hd->east = (xmax > to_hd->east) ? to_hd->east : xmax;
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.proj/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -395,9 +395,9 @@
outcellhd.west = outcellhd.south = HUGE_VAL;
outcellhd.east = outcellhd.north = -HUGE_VAL;
for (row = 0; row < incellhd.rows; row++) {
- ycoord1 = G_row_to_northing((double)(row + 0.5), &incellhd);
+ ycoord1 = Rast_row_to_northing((double)(row + 0.5), &incellhd);
for (col = 0; col < incellhd.cols; col++) {
- xcoord1 = G_col_to_easting((double)(col + 0.5), &incellhd);
+ xcoord1 = Rast_col_to_easting((double)(col + 0.5), &incellhd);
pj_do_proj(&xcoord1, &ycoord1, &iproj, &oproj);
if (xcoord1 > outcellhd.east)
outcellhd.east = xcoord1;
Modified: grass/trunk/raster/r.proj/readcell.c
--- grass/trunk/raster/r.proj/readcell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.proj/readcell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -27,8 +27,8 @@
int nblocks;
int i;
ny = (nrows + BDIM - 1) / BDIM;
nx = (ncols + BDIM - 1) / BDIM;
Modified: grass/trunk/raster/r.quantile/main.c
--- grass/trunk/raster/r.quantile/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.quantile/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -318,8 +318,8 @@
slot_size = (max - min) / num_slots;
get_slot_counts(infile);
Modified: grass/trunk/raster/r.random/count.c
--- grass/trunk/raster/r.random/count.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.random/count.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -52,8 +52,8 @@
theState->cmax.data.v =
(void *)G_malloc(Rast_cell_size(theState->cmax.type));
theState->nCells = nrows * ncols;
theState->nNulls = 0;
Modified: grass/trunk/raster/r.random/random.c
--- grass/trunk/raster/r.random/random.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.random/random.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -34,8 +34,8 @@
G_get_window(&window);
/* open the data files, input raster should be set-up already */
if ((infd = theState->fd_old) < 0)
Modified: grass/trunk/raster/r.random.cells/init.c
--- grass/trunk/raster/r.random.cells/init.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.random.cells/init.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -21,8 +21,8 @@
G_debug(2, "Init()");
- Rs = G_window_rows();
- Cs = G_window_cols();
+ Rs = Rast_window_rows();
+ Cs = Rast_window_cols();
G_get_set_window(&Region);
EW = Region.ew_res;
NS = Region.ns_res;
Modified: grass/trunk/raster/r.random.surface/init.c
--- grass/trunk/raster/r.random.surface/init.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.random.surface/init.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -22,8 +22,8 @@
G_debug(2, "Init");
Surface = (double **)G_malloc(Rs * sizeof(double *));
for (row = 0; row < Rs; row++)
Surface[row] = (double *)G_malloc(Cs * sizeof(double));
Modified: grass/trunk/raster/r.recode/recode.c
--- grass/trunk/raster/r.recode/recode.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.recode/recode.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -30,14 +30,14 @@
if (align_wind) {
Rast_get_cellhd(name, "", &cellhd);
G_get_set_window(&window);
/* open the input file for reading */
in_fd = Rast_open_old(name, "");
Modified: grass/trunk/raster/r.region/main.c
--- grass/trunk/raster/r.region/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.region/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -210,7 +210,7 @@
window.west = box.W;
window.east = box.E;
Vect_close(&Map);
@@ -308,7 +308,7 @@
Rast_get_cellhd(name, "", &temp_window);
- G_align_window(&window, &temp_window);
+ Rast_align_window(&window, &temp_window);
window.rows = cellhd.rows;
Modified: grass/trunk/raster/r.resamp.interp/main.c
--- grass/trunk/raster/r.resamp.interp/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.resamp.interp/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -104,14 +104,14 @@
/* enlarge source window */
- double north = G_row_to_northing(0.5, &dst_w);
- double south = G_row_to_northing(dst_w.rows - 0.5, &dst_w);
- int r0 = (int)floor(G_northing_to_row(north, &src_w) - 0.5) - 1;
- int r1 = (int)floor(G_northing_to_row(south, &src_w) - 0.5) + 3;
- double west = G_col_to_easting(0.5, &dst_w);
- double east = G_col_to_easting(dst_w.cols - 0.5, &dst_w);
- int c0 = (int)floor(G_easting_to_col(west, &src_w) - 0.5) - 1;
- int c1 = (int)floor(G_easting_to_col(east, &src_w) - 0.5) + 3;
+ double north = Rast_row_to_northing(0.5, &dst_w);
+ double south = Rast_row_to_northing(dst_w.rows - 0.5, &dst_w);
+ int r0 = (int)floor(Rast_northing_to_row(north, &src_w) - 0.5) - 1;
+ int r1 = (int)floor(Rast_northing_to_row(south, &src_w) - 0.5) + 3;
+ double west = Rast_col_to_easting(0.5, &dst_w);
+ double east = Rast_col_to_easting(dst_w.cols - 0.5, &dst_w);
+ int c0 = (int)floor(Rast_easting_to_col(west, &src_w) - 0.5) - 1;
+ int c1 = (int)floor(Rast_easting_to_col(east, &src_w) - 0.5) + 3;
src_w.south -= src_w.ns_res * (r1 - src_w.rows);
src_w.north += src_w.ns_res * (-r0);
@@ -146,8 +146,8 @@
switch (neighbors) {
case 1: /* nearest */
for (row = 0; row < dst_w.rows; row++) {
- double north = G_row_to_northing(row + 0.5, &dst_w);
- double maprow_f = G_northing_to_row(north, &src_w) - 0.5;
+ double north = Rast_row_to_northing(row + 0.5, &dst_w);
+ double maprow_f = Rast_northing_to_row(north, &src_w) - 0.5;
int maprow0 = (int)floor(maprow_f + 0.5);
G_percent(row, dst_w.rows, 2);
@@ -156,8 +156,8 @@
read_rows(infile, maprow0);
for (col = 0; col < dst_w.cols; col++) {
- double east = G_col_to_easting(col + 0.5, &dst_w);
- double mapcol_f = G_easting_to_col(east, &src_w) - 0.5;
+ double east = Rast_col_to_easting(col + 0.5, &dst_w);
+ double mapcol_f = Rast_easting_to_col(east, &src_w) - 0.5;
int mapcol0 = (int)floor(mapcol_f + 0.5);
double c = bufs[0][mapcol0];
@@ -177,8 +177,8 @@
case 2: /* bilinear */
int maprow0 = (int)floor(maprow_f);
double v = maprow_f - maprow0;
@@ -188,8 +188,8 @@
int mapcol0 = (int)floor(mapcol_f);
int mapcol1 = mapcol0 + 1;
double u = mapcol_f - mapcol0;
@@ -216,8 +216,8 @@
case 4: /* bicubic */
int maprow1 = (int)floor(maprow_f);
int maprow0 = maprow1 - 1;
double v = maprow_f - maprow1;
@@ -228,8 +228,8 @@
int mapcol1 = (int)floor(mapcol_f);
int mapcol0 = mapcol1 - 1;
int mapcol2 = mapcol1 + 1;
Modified: grass/trunk/raster/r.resamp.stats/main.c
--- grass/trunk/raster/r.resamp.stats/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.resamp.stats/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -98,15 +98,15 @@
row_map = G_malloc((dst_w.rows + 1) * sizeof(int));
for (col = 0; col <= dst_w.cols; col++) {
- double x = G_col_to_easting(col, &dst_w);
+ double x = Rast_col_to_easting(col, &dst_w);
- col_map[col] = (int)floor(G_easting_to_col(x, &src_w) + 0.5);
+ col_map[col] = (int)floor(Rast_easting_to_col(x, &src_w) + 0.5);
for (row = 0; row <= dst_w.rows; row++) {
- double y = G_row_to_northing(row, &dst_w);
+ double y = Rast_row_to_northing(row, &dst_w);
- row_map[row] = (int)floor(G_northing_to_row(y, &src_w) + 0.5);
+ row_map[row] = (int)floor(Rast_northing_to_row(y, &src_w) + 0.5);
@@ -169,15 +169,15 @@
row_map = G_malloc((dst_w.rows + 1) * sizeof(double));
- col_map[col] = G_easting_to_col(x, &src_w);
+ col_map[col] = Rast_easting_to_col(x, &src_w);
- row_map[row] = G_northing_to_row(y, &src_w);
+ row_map[row] = Rast_northing_to_row(y, &src_w);
@@ -313,10 +313,10 @@
- int r0 = (int)floor(G_northing_to_row(dst_w.north, &src_w));
- int r1 = (int)ceil(G_northing_to_row(dst_w.south, &src_w));
- int c0 = (int)floor(G_easting_to_col(dst_w.west, &src_w));
- int c1 = (int)ceil(G_easting_to_col(dst_w.east, &src_w));
+ int r0 = (int)floor(Rast_northing_to_row(dst_w.north, &src_w));
+ int r1 = (int)ceil(Rast_northing_to_row(dst_w.south, &src_w));
+ int c0 = (int)floor(Rast_easting_to_col(dst_w.west, &src_w));
+ int c1 = (int)ceil(Rast_easting_to_col(dst_w.east, &src_w));
Modified: grass/trunk/raster/r.resample/main.c
--- grass/trunk/raster/r.resample/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.resample/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -99,8 +99,8 @@
/* raster buffer is big enough to hold data */
rast = Rast_allocate_buf(data_type);
if (ncols <= 1)
rast = G_realloc(rast, 2 * Rast_cell_size(data_type));
/* we need the buffer at least 2 cells large */
Modified: grass/trunk/raster/r.rescale/get_range.c
--- grass/trunk/raster/r.rescale/get_range.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.rescale/get_range.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -19,8 +19,8 @@
Rast_set_window(&cellhd);
G_message(_("Reading %s ..."), name);
G_percent(row, nrows, 2);
Modified: grass/trunk/raster/r.rescale.eq/get_stats.c
--- grass/trunk/raster/r.rescale.eq/get_stats.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.rescale.eq/get_stats.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -11,8 +11,8 @@
int row, nrows, ncols;
Modified: grass/trunk/raster/r.ros/main.c
--- grass/trunk/raster/r.ros/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.ros/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -399,8 +399,8 @@
/* find number of rows and columns in window */
fuel = Rast_allocate_c_buf();
mois_1h = Rast_allocate_c_buf();
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.series/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -224,8 +224,8 @@
values = G_malloc(num_inputs * sizeof(DCELL));
values_tmp = G_malloc(num_inputs * sizeof(DCELL));
/* process the data */
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.slope.aspect/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -368,7 +368,7 @@
if (!flag.a->answer) {
Rast_get_cellhd(elev_name, "", &cellhd);
@@ -391,8 +391,8 @@
if (((window.west == (window.east - 360.))
|| (window.east == (window.west - 360.))) &&
@@ -414,11 +414,11 @@
G_warning(_("Converting units to meters, factor=%.6f"), factor);
G_begin_distance_calculations();
- north = G_row_to_northing(0.5, &window);
- ns_med = G_row_to_northing(1.5, &window);
- south = G_row_to_northing(2.5, &window);
- east = G_col_to_easting(2.5, &window);
- west = G_col_to_easting(0.5, &window);
+ north = Rast_row_to_northing(0.5, &window);
+ ns_med = Rast_row_to_northing(1.5, &window);
+ south = Rast_row_to_northing(2.5, &window);
+ east = Rast_col_to_easting(2.5, &window);
+ west = Rast_col_to_easting(0.5, &window);
V = G_distance(east, north, east, south) * 4 / zfactor;
H = G_distance(east, ns_med, west, ns_med) * 4 / zfactor;
/* ____________________________
@@ -451,7 +451,7 @@
if (slope_name != NULL) {
slope_fd = opennew(slope_name, out_type);
slp_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(slp_raster, G_window_cols(), data_type);
+ Rast_set_null_value(slp_raster, Rast_window_cols(), data_type);
Rast_put_row(slope_fd, slp_raster, data_type);
else {
@@ -462,7 +462,7 @@
if (aspect_name != NULL) {
aspect_fd = opennew(aspect_name, out_type);
asp_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(asp_raster, G_window_cols(), data_type);
+ Rast_set_null_value(asp_raster, Rast_window_cols(), data_type);
Rast_put_row(aspect_fd, asp_raster, data_type);
else {
@@ -473,7 +473,7 @@
if (pcurv_name != NULL) {
pcurv_fd = opennew(pcurv_name, out_type);
pcurv_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(pcurv_raster, G_window_cols(), data_type);
+ Rast_set_null_value(pcurv_raster, Rast_window_cols(), data_type);
Rast_put_row(pcurv_fd, pcurv_raster, data_type);
else {
@@ -484,7 +484,7 @@
if (tcurv_name != NULL) {
tcurv_fd = opennew(tcurv_name, out_type);
tcurv_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(tcurv_raster, G_window_cols(), data_type);
+ Rast_set_null_value(tcurv_raster, Rast_window_cols(), data_type);
Rast_put_row(tcurv_fd, tcurv_raster, data_type);
else {
@@ -495,7 +495,7 @@
if (dx_name != NULL) {
dx_fd = opennew(dx_name, out_type);
dx_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(dx_raster, G_window_cols(), data_type);
+ Rast_set_null_value(dx_raster, Rast_window_cols(), data_type);
Rast_put_row(dx_fd, dx_raster, data_type);
else {
@@ -506,7 +506,7 @@
if (dy_name != NULL) {
dy_fd = opennew(dy_name, out_type);
dy_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(dy_raster, G_window_cols(), data_type);
+ Rast_set_null_value(dy_raster, Rast_window_cols(), data_type);
Rast_put_row(dy_fd, dy_raster, data_type);
else {
@@ -517,7 +517,7 @@
if (dxx_name != NULL) {
dxx_fd = opennew(dxx_name, out_type);
dxx_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(dxx_raster, G_window_cols(), data_type);
+ Rast_set_null_value(dxx_raster, Rast_window_cols(), data_type);
Rast_put_row(dxx_fd, dxx_raster, data_type);
else {
@@ -528,7 +528,7 @@
if (dyy_name != NULL) {
dyy_fd = opennew(dyy_name, out_type);
dyy_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(dyy_raster, G_window_cols(), data_type);
+ Rast_set_null_value(dyy_raster, Rast_window_cols(), data_type);
Rast_put_row(dyy_fd, dyy_raster, data_type);
else {
@@ -539,7 +539,7 @@
if (dxy_name != NULL) {
dxy_fd = opennew(dxy_name, out_type);
dxy_raster = Rast_allocate_buf(data_type);
- Rast_set_null_value(dxy_raster, G_window_cols(), data_type);
+ Rast_set_null_value(dxy_raster, Rast_window_cols(), data_type);
Rast_put_row(dxy_fd, dxy_raster, data_type);
else {
@@ -553,16 +553,16 @@
if (Wrap) {
Rast_get_d_row_nomask(elevation_fd, elev_cell[1] + 1, 0);
- elev_cell[1][0] = elev_cell[1][G_window_cols() - 1];
- elev_cell[1][G_window_cols() + 1] = elev_cell[1][2];
+ elev_cell[1][0] = elev_cell[1][Rast_window_cols() - 1];
+ elev_cell[1][Rast_window_cols() + 1] = elev_cell[1][2];
else
Rast_get_d_row_nomask(elevation_fd, elev_cell[1], 0);
if (Wrap) {
Rast_get_d_row_nomask(elevation_fd, elev_cell[2] + 1, 1);
- elev_cell[2][0] = elev_cell[2][G_window_cols() - 1];
- elev_cell[2][G_window_cols() + 1] = elev_cell[2][2];
+ elev_cell[2][0] = elev_cell[2][Rast_window_cols() - 1];
+ elev_cell[2][Rast_window_cols() + 1] = elev_cell[2][2];
else
Rast_get_d_row_nomask(elevation_fd, elev_cell[2], 1);
@@ -572,11 +572,11 @@
for (row = 2; row < nrows; row++) {
/* if projection is Lat/Lon, recalculate V and H */
- north = G_row_to_northing((row - 2 + 0.5), &window);
- ns_med = G_row_to_northing((row - 1 + 0.5), &window);
- south = G_row_to_northing((row + 0.5), &window);
+ north = Rast_row_to_northing((row - 2 + 0.5), &window);
+ ns_med = Rast_row_to_northing((row - 1 + 0.5), &window);
+ south = Rast_row_to_northing((row + 0.5), &window);
@@ -606,8 +606,8 @@
if (Wrap) {
Rast_get_d_row_nomask(elevation_fd, elev_cell[2] + 1, row);
else
Rast_get_d_row_nomask(elevation_fd, elev_cell[2], row);
@@ -998,7 +998,7 @@
DCELL min, max;
struct FPRange range;
Rast_close(aspect_fd);
@@ -1103,7 +1103,7 @@
val2 = 90;
Rast_add_c_color_rule(&val1, 255, 0, 0, &val2, 0, 0, 0, &colors);
Rast_close(slope_fd);
@@ -1233,7 +1233,7 @@
if (pcurv_fd >= 0) {
Rast_close(pcurv_fd);
@@ -1260,7 +1260,7 @@
if (tcurv_fd >= 0) {
Rast_close(tcurv_fd);
@@ -1287,7 +1287,7 @@
if (dx_fd >= 0) {
Rast_close(dx_fd);
@@ -1312,7 +1312,7 @@
if (dy_fd >= 0) {
Rast_close(dy_fd);
@@ -1337,7 +1337,7 @@
if (dxx_fd >= 0) {
Rast_close(dxx_fd);
@@ -1362,7 +1362,7 @@
if (dyy_fd >= 0) {
Rast_close(dyy_fd);
@@ -1387,7 +1387,7 @@
if (dxy_fd >= 0) {
Rast_close(dxy_fd);
Modified: grass/trunk/raster/r.spread/main.c
--- grass/trunk/raster/r.spread/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.spread/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -334,8 +334,8 @@
/*transfor measurement unit from meters to centimeters due to ROS unit
*if the input ROSs are in m/min units, cancell the following*/
Modified: grass/trunk/raster/r.spread/ram2out.c
--- grass/trunk/raster/r.spread/ram2out.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.spread/ram2out.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -16,11 +16,11 @@
extern int nrows, ncols;
extern struct Cell_head window;
double north, west;
- double G_row_to_northing(), G_col_to_easting();
+ double Rast_row_to_northing(), G_col_to_easting();
int row, col;
/* Copy maps in ram to output maps, casting into integers */
G_message("Writing output: %s, x_output: %s, y_output: %s ... ",
out_layer, x_out_layer, y_out_layer);
Modified: grass/trunk/raster/r.spreadpath/main.c
--- grass/trunk/raster/r.spreadpath/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.spreadpath/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -162,8 +162,8 @@
path_mapset = G_find_raster(path_layer, search_mapset);
/* find number of rows and cols in window */
Modified: grass/trunk/raster/r.statistics2/main.c
--- grass/trunk/raster/r.statistics2/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.statistics2/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -185,8 +185,8 @@
mincat = range.min;
ncats = range.max - range.min + 1;
- rows = G_window_rows();
- cols = G_window_cols();
+ rows = Rast_window_rows();
+ cols = Rast_window_cols();
switch (method) {
case COUNT:
Modified: grass/trunk/raster/r.statistics3/main.c
--- grass/trunk/raster/r.statistics3/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.statistics3/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -495,8 +495,8 @@
for (i = 0; i < num_cats; i++)
basecats[i].slots = G_calloc(num_slots, sizeof(unsigned int));
get_slot_counts(base_fd, cover_fd);
Modified: grass/trunk/raster/r.stats/main.c
--- grass/trunk/raster/r.stats/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.stats/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -220,8 +220,8 @@
averaged = flag.A->answer;
raw_output = flag.r->answer;
as_int = flag.i->answer;
fd = NULL;
nfiles = 0;
Modified: grass/trunk/raster/r.stats/raw_stats.c
--- grass/trunk/raster/r.stats/raw_stats.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.stats/raw_stats.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -10,7 +10,7 @@
char str1[50];
register int i;
int row, col, nulls_found;
char nbuf[100], ebuf[100];
RASTER_MAP_TYPE *map_type;
@@ -44,7 +44,7 @@
if (with_coordinates)
- G_format_northing(G_row_to_northing(row + .5, &window), nbuf,
+ G_format_northing(Rast_row_to_northing(row + .5, &window), nbuf,
G_projection() == PROJECTION_LL ? -1 : 0);
@@ -69,7 +69,7 @@
if (with_coordinates) {
- G_format_easting(G_col_to_easting(col + .5, &window), ebuf,
+ G_format_easting(Rast_col_to_easting(col + .5, &window), ebuf,
fprintf(stdout, "%s%s%s%s", ebuf, fs, nbuf, fs);
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.sun/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -1159,10 +1159,10 @@
- if (m != G_window_rows())
- G_fatal_error("OOPS: rows changed from %d to %d", m, G_window_rows());
- if (n != G_window_cols())
- G_fatal_error("OOPS: cols changed from %d to %d", n, G_window_cols());
+ if (m != Rast_window_rows())
+ G_fatal_error("OOPS: rows changed from %d to %d", m, Rast_window_rows());
+ if (n != Rast_window_cols())
+ G_fatal_error("OOPS: cols changed from %d to %d", n, Rast_window_cols());
for (iarc = 0; iarc < m; iarc++) {
i = m - iarc - 1;
Modified: grass/trunk/raster/r.sunmask/main.c
--- grass/trunk/raster/r.sunmask/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.sunmask/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -490,8 +490,8 @@
/* outbuf.c[col1]=1; */
Rast_set_null_value(&outbuf.c[col1], 1, CELL_TYPE);
OK = 1;
- east = G_col_to_easting(col1 + 0.5, &window);
- north = G_row_to_northing(row1 + 0.5, &window);
+ east = Rast_col_to_easting(col1 + 0.5, &window);
+ north = Rast_row_to_northing(row1 + 0.5, &window);
east1 = east;
north1 = north;
if (dvalue == 0.0 && !zeros)
@@ -510,9 +510,9 @@
if ((maxh) > (dmax - dvalue))
OK = 0;
else {
- dcol = G_easting_to_col(east, &window);
- if (drow != G_northing_to_row(north, &window)) {
- drow = G_northing_to_row(north, &window);
+ dcol = Rast_easting_to_col(east, &window);
+ if (drow != Rast_northing_to_row(north, &window)) {
+ drow = Rast_northing_to_row(north, &window);
Rast_get_row(elev_fd, tmpbuf.v, (int)drow,
data_type);
Modified: grass/trunk/raster/r.support/histo.c
--- grass/trunk/raster/r.support/histo.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.support/histo.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -23,8 +23,8 @@
Modified: grass/trunk/raster/r.support.stats/histo.c
--- grass/trunk/raster/r.support.stats/histo.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.support.stats/histo.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -39,8 +39,8 @@
Modified: grass/trunk/raster/r.surf.contour/main.c
--- grass/trunk/raster/r.surf.contour/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.contour/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -87,8 +87,8 @@
if (!con_mapset)
G_fatal_error("Contour raster map [%s] not found", con_name);
i_val_l_f = nrows + ncols;
con = read_cell(con_name, con_mapset);
alt_row = (CELL *) G_malloc(ncols * sizeof(CELL));
Modified: grass/trunk/raster/r.surf.contour/read_cell.c
--- grass/trunk/raster/r.surf.contour/read_cell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.contour/read_cell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -4,8 +4,8 @@
CELL **read_cell(const char *name, const char *mapset)
- int nrows = G_window_rows();
- int ncols = G_window_cols();
+ int nrows = Rast_window_rows();
+ int ncols = Rast_window_cols();
CELL *buf, **idx;
int fd;
int row;
Modified: grass/trunk/raster/r.surf.fractal/process.c
--- grass/trunk/raster/r.surf.fractal/process.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.fractal/process.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -38,8 +38,8 @@
- ncols = G_window_cols(); /* columns of the raster view. */
+ ncols = Rast_window_cols(); /* columns of the raster view. */
nn = G_math_max_pow2(MAX(nrows, ncols)); /* Find smallest power of 2 that */
/* largest side of raster will fit. */
Modified: grass/trunk/raster/r.surf.fractal/write_rast.c
--- grass/trunk/raster/r.surf.fractal/write_rast.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.fractal/write_rast.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -40,8 +40,8 @@
/* of the input raster. */
row_out = Rast_allocate_d_buf();
Modified: grass/trunk/raster/r.surf.gauss/gaussurf.c
--- grass/trunk/raster/r.surf.gauss/gaussurf.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.gauss/gaussurf.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -38,8 +38,8 @@
fd_out = Rast_open_new(out, DCELL_TYPE);
Modified: grass/trunk/raster/r.surf.idw/main.c
--- grass/trunk/raster/r.surf.idw/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.idw/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -136,8 +136,8 @@
/* create distance squared or latitude lookup tables */
/* initialize function pointers */
Modified: grass/trunk/raster/r.surf.idw2/read_cell.c
--- grass/trunk/raster/r.surf.idw2/read_cell.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.idw2/read_cell.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -17,7 +17,7 @@
/* Set window to align with input raster map */
Modified: grass/trunk/raster/r.surf.random/randsurf.c
--- grass/trunk/raster/r.surf.random/randsurf.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.surf.random/randsurf.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -26,8 +26,8 @@
/****** OPEN CELL FILES AND GET CELL DETAILS ******/
fd_out = Rast_open_new(out, int_map ? CELL_TYPE : DCELL_TYPE);
if (int_map)
row_out_C = Rast_allocate_c_buf();
Modified: grass/trunk/raster/r.terraflow/main.cc
--- grass/trunk/raster/r.terraflow/main.cc 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.terraflow/main.cc 2010-02-01 17:53:15 UTC (rev 40771)
@@ -467,8 +467,8 @@
check_args();
- int nr = G_window_rows();
- int nc = G_window_cols();
+ int nr = Rast_window_rows();
+ int nc = Rast_window_cols();
if ((nr > dimension_type_max) || (nc > dimension_type_max)) {
G_fatal_error(_("[nrows=%d, ncols=%d] dimension_type overflow -- "
"change dimension_type and recompile"), nr, nc);
Modified: grass/trunk/raster/r.texture/main.c
--- grass/trunk/raster/r.texture/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.texture/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -222,8 +222,8 @@
/* Allocate output buffer, use FCELL data_type */
outrast = Rast_allocate_buf(out_data_type);
/* Load raster map. */
Modified: grass/trunk/raster/r.thin/io.c
--- grass/trunk/raster/r.thin/io.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.thin/io.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -93,8 +93,8 @@
strcpy(cell, name);
cell_file = Rast_open_old(cell, "");
- n_rows = G_window_rows();
- n_cols = G_window_cols();
+ n_rows = Rast_window_rows();
+ n_cols = Rast_window_cols();
G_message(_("File %s -- %d rows X %d columns"), name, n_rows, n_cols);
n_cols += (PAD << 1);
@@ -157,8 +157,8 @@
row_count = n_rows - (PAD << 1);
col_count = n_cols - (PAD << 1);
G_message(_("Output file %d rows X %d columns"), row_count, col_count);
- G_message(_("Window %d rows X %d columns"), G_window_rows(),
- G_window_cols());
+ G_message(_("Window %d rows X %d columns"), Rast_window_rows(),
for (row = 0, k = PAD; row < row_count; row++, k++) {
buf = get_a_row(k);
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.to.rast3/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -213,8 +213,8 @@
G3d_getWindow(®ion);
/*Check if the g3d-region is equal to the 2d rows and cols */
G_debug(2, "Check the 2d and 3d region settings");
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.to.rast3elev/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -402,8 +402,8 @@
G_debug(2, "Checking 2d and 3d region");
Modified: grass/trunk/raster/r.to.vect/points.c
--- grass/trunk/raster/r.to.vect/points.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.to.vect/points.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -39,7 +39,7 @@
for (row = 0; row < cell_head.rows; row++) {
G_percent(row, n_rows, 2);
- y = G_row_to_northing((double)(row + .5), &cell_head);
+ y = Rast_row_to_northing((double)(row + .5), &cell_head);
switch (data_type) {
case CELL_TYPE:
@@ -57,7 +57,7 @@
int cat, val;
double dval;
- x = G_col_to_easting((double)(col + .5), &cell_head);
+ x = Rast_col_to_easting((double)(col + .5), &cell_head);
case CELL_TYPE:
Modified: grass/trunk/raster/r.univar/r.univar_main.c
--- grass/trunk/raster/r.univar/r.univar_main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.univar/r.univar_main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -162,7 +162,7 @@
static void
process_raster(univar_stat * stats, int fd, const struct Cell_head *region)
- /* use G_window_rows(), G_window_cols() here? */
+ /* use Rast_window_rows(), Rast_window_cols() here? */
const int rows = region->rows;
const int cols = region->cols;
int first = (stats->n < 1);
Modified: grass/trunk/raster/r.uslek/main.c
--- grass/trunk/raster/r.uslek/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.uslek/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -100,8 +100,8 @@
infd_pomat = Rast_open_old(pomat, "");
inrast_pomat = Rast_allocate_d_buf();
outrast = Rast_allocate_d_buf();
/* Create New raster files */
Modified: grass/trunk/raster/r.usler/main.c
--- grass/trunk/raster/r.usler/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.usler/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -86,8 +86,8 @@
inrast_annual_pmm = Rast_allocate_d_buf();
Modified: grass/trunk/raster/r.volume/centroids.c
--- grass/trunk/raster/r.volume/centroids.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.volume/centroids.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -46,8 +46,8 @@
/* do rows and columns through window and mask */
/* to do counting */
for (row = 0; row < rows; row++) {
Rast_get_c_row(fd, cell_buf, row); /* get a row */
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.walk/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -437,8 +437,8 @@
dtm_mapset = G_find_raster2(dtm_layer, "");
@@ -730,8 +730,8 @@
continue;
got_one = 1;
new_start_pt =
@@ -777,8 +777,8 @@
continue;
new_start_pt =
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.water.outlet/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -122,8 +122,8 @@
dr_f = ba_f = N_f = E_f = errr = 0;
total = nrows * ncols;
nrows_less_one = nrows - 1;
ncols_less_one = ncols - 1;
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -116,8 +116,8 @@
total_cells = nrows * ncols;
if (max_length <= d_zero)
max_length = 10 * nrows * window.ns_res + 10 * ncols * window.ew_res;
Modified: grass/trunk/raster/r.watershed/seg/bseg_open.c
--- grass/trunk/raster/r.watershed/seg/bseg_open.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/bseg_open.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -21,8 +21,8 @@
G_warning("bseg_open(): unable to create segment file");
return -2;
- if (0 > (errflag = segment_format(fd, G_window_rows(),
- G_window_cols(), srows, scols,
+ if (0 > (errflag = segment_format(fd, Rast_window_rows(),
+ Rast_window_cols(), srows, scols,
sizeof(char)))) {
close(fd);
unlink(filename);
Modified: grass/trunk/raster/r.watershed/seg/bseg_read.c
--- grass/trunk/raster/r.watershed/seg/bseg_read.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/bseg_read.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -15,8 +15,8 @@
bseg->mapset = NULL;
map_fd = Rast_open_old(map_name, mapset);
buffer = Rast_allocate_c_buf();
for (row = 0; row < nrows; row++) {
Rast_get_c_row(map_fd, buffer, row);
Modified: grass/trunk/raster/r.watershed/seg/bseg_write.c
--- grass/trunk/raster/r.watershed/seg/bseg_write.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/bseg_write.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -11,8 +11,8 @@
char value;
map_fd = Rast_open_c_new(map_name);
G_percent(row, nrows, 1);
Modified: grass/trunk/raster/r.watershed/seg/cseg_open.c
--- grass/trunk/raster/r.watershed/seg/cseg_open.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/cseg_open.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -22,7 +22,7 @@
if (0 >
(errflag =
- segment_format(fd, G_window_rows(), G_window_cols(), srows, scols,
+ segment_format(fd, Rast_window_rows(), Rast_window_cols(), srows, scols,
sizeof(CELL)))) {
close(fd);
unlink(filename);
Modified: grass/trunk/raster/r.watershed/seg/cseg_read.c
--- grass/trunk/raster/r.watershed/seg/cseg_read.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/cseg_read.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -15,7 +15,7 @@
cseg->mapset = NULL;
Modified: grass/trunk/raster/r.watershed/seg/cseg_write.c
--- grass/trunk/raster/r.watershed/seg/cseg_write.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/cseg_write.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -10,7 +10,7 @@
CELL *buffer;
segment_flush(&(cseg->seg));
Modified: grass/trunk/raster/r.watershed/seg/dseg_open.c
--- grass/trunk/raster/r.watershed/seg/dseg_open.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/dseg_open.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -23,7 +23,7 @@
if (0 >
(errflag =
sizeof(double)))) {
close(fd);
unlink(filename);
Modified: grass/trunk/raster/r.watershed/seg/dseg_read.c
--- grass/trunk/raster/r.watershed/seg/dseg_read.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/dseg_read.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -15,8 +15,8 @@
dseg->mapset = NULL;
dbuffer = Rast_allocate_d_buf();
Rast_get_d_row(map_fd, dbuffer, row);
Modified: grass/trunk/raster/r.watershed/seg/dseg_write.c
--- grass/trunk/raster/r.watershed/seg/dseg_write.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/dseg_write.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -10,8 +10,8 @@
double *dbuffer;
map_fd = Rast_open_new(map_name, DCELL_TYPE);
segment_flush(&(dseg->seg));
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -132,8 +132,8 @@
if (window.ew_res < window.ns_res)
Modified: grass/trunk/raster/r.watershed/shed/read.c
--- grass/trunk/raster/r.watershed/shed/read.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/shed/read.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -14,8 +14,8 @@
char *mapset;
B_FACTS *facts;
buf = Rast_allocate_c_buf();
bas_buf = Rast_allocate_c_buf();
mapset = G_find_raster(haf_name, "");
Modified: grass/trunk/raster/r.watershed/shed/valid.c
--- grass/trunk/raster/r.watershed/shed/valid.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.watershed/shed/valid.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -16,8 +16,8 @@
window = &(output->window);
- nrows = G_window_rows ();
- ncols = G_window_cols ();
+ nrows = Rast_window_rows ();
+ ncols = Rast_window_cols ();
if (NULL == (mapset = G_find_raster(accum_name, ""))) {
free_output(output);
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/r.what/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -304,8 +304,8 @@
/* convert north, east to row and col */
/* a special case.
* if north falls at southern edge, or east falls on eastern edge,
Modified: grass/trunk/raster/simwe/simlib/output.c
--- grass/trunk/raster/simwe/simlib/output.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster/simwe/simlib/output.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -156,12 +156,12 @@
- if (my != G_window_rows())
+ if (my != Rast_window_rows())
G_fatal_error("OOPS: rows changed from %d to %d\n", mx,
- G_window_rows());
- if (mx != G_window_cols())
+ Rast_window_rows());
+ if (mx != Rast_window_cols())
G_fatal_error("OOPS: cols changed from %d to %d\n", my,
- G_window_cols());
+ Rast_window_cols());
for (iarc = 0; iarc < my; iarc++) {
i = my - iarc - 1;
@@ -615,12 +615,12 @@
- G_window_rows());
- G_window_cols());
i = my - iarc - 1;
Modified: grass/trunk/raster3d/r3.cross.rast/main.c
--- grass/trunk/raster3d/r3.cross.rast/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster3d/r3.cross.rast/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -279,8 +279,8 @@
/*If not equal, set the 2D windows correct */
if (rows != region.rows || cols != region.cols) {
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -440,8 +440,8 @@
if (param.structgrid->answer) {
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/raster3d/r3.to.rast/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -246,8 +246,8 @@
/*If not equal, set the 3D window correct */
Modified: grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
--- grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -419,8 +419,8 @@
@@ -442,11 +442,11 @@
G_warning("Converting units to meters, factor=%.6f", factor);
@@ -481,7 +481,7 @@
else {
@@ -492,7 +492,7 @@
else {
@@ -503,7 +503,7 @@
else {
@@ -514,7 +514,7 @@
else {
@@ -525,7 +525,7 @@
else {
@@ -536,7 +536,7 @@
else {
@@ -547,7 +547,7 @@
else {
@@ -558,7 +558,7 @@
else {
@@ -569,7 +569,7 @@
else {
@@ -583,16 +583,16 @@
if (Wrap) {
else
if (Wrap) {
else
@@ -601,11 +601,11 @@
@@ -635,8 +635,8 @@
if (Wrap) {
else
@@ -1027,7 +1027,7 @@
DCELL min, max;
@@ -1130,7 +1130,7 @@
val2 = 90;
@@ -1258,7 +1258,7 @@
@@ -1284,7 +1284,7 @@
@@ -1310,7 +1310,7 @@
if (dx_fd >= 0) {
Rast_close(dx_fd);
@@ -1334,7 +1334,7 @@
if (dy_fd >= 0) {
Rast_close(dy_fd);
@@ -1358,7 +1358,7 @@
if (dxx_fd >= 0) {
Rast_close(dxx_fd);
@@ -1382,7 +1382,7 @@
if (dyy_fd >= 0) {
Rast_close(dyy_fd);
@@ -1406,7 +1406,7 @@
if (dxy_fd >= 0) {
Rast_close(dxy_fd);
Modified: grass/trunk/vector/lidar/lidarlib/raster.c
--- grass/trunk/vector/lidar/lidarlib/raster.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/lidar/lidarlib/raster.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -214,8 +214,8 @@
G_get_window(&Original);
for (col = 0; col < ncols; col++) {
- X = G_col_to_easting((double)(col) + 0.5, &Original);
- Y = G_row_to_northing((double)(row) + 0.5, &Original);
+ X = Rast_col_to_easting((double)(col) + 0.5, &Original);
+ Y = Rast_row_to_northing((double)(row) + 0.5, &Original);
if (Vect_point_in_box(X, Y, mean, &General)) { /* Here, mean is just for asking if obs point is in box */
Modified: grass/trunk/vector/lidar/lidarlib/zones.c
--- grass/trunk/vector/lidar/lidarlib/zones.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/lidar/lidarlib/zones.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -271,8 +271,8 @@
Rast_set_window(&Original);
raster = Rast_allocate_buf(DCELL_TYPE);
@@ -374,8 +374,8 @@
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -190,8 +190,8 @@
* subregion will be overlaped by its neibourgh subregions. This overlapping
* is calculated as OVERLAP_PASS times the east-west resolution. */
ew_resol = original_reg.ew_res;
ns_resol = original_reg.ns_res;
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -236,8 +236,8 @@
/*Setting the active region */
Rast_set_window(&elaboration_reg);
G_debug(1, _("Rows = %d"), nrows);
G_debug(1, _("Columns = %d"), ncols);
@@ -276,10 +276,10 @@
(points->y[0] == original_reg.north))) {
row =
- (int)(G_northing_to_row
+ (int)(Rast_northing_to_row
(points->y[0], &elaboration_reg));
col =
- (int)(G_easting_to_col
+ (int)(Rast_easting_to_col
(points->x[0], &elaboration_reg));
while (1) {
@@ -365,10 +365,10 @@
north))) {
row =
(points_first->y[0], &elaboration_reg));
col =
(points_first->x[0], &elaboration_reg));
if (fabs
@@ -473,10 +473,10 @@
row =
col =
if (raster_matrix[row][col].clas == PRE_TERRAIN) {
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -358,8 +358,8 @@
G_debug(1, "Interpolation()");
if (map) {
if (!G_alloc_matrix(nrows, ncols))
G_fatal_error(_("Interpolation: The region resolution is too high: "
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/v.kernel/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -405,8 +405,8 @@
continue;
- N = G_row_to_northing(row + 0.5, &window);
- E = G_col_to_easting(col + 0.5, &window);
+ N = Rast_row_to_northing(row + 0.5, &window);
+ E = Rast_col_to_easting(col + 0.5, &window);
compute_distance(N, E, &In, sigma, term, &gaussian, dmax);
output_cell[col] = multip * gaussian;
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/v.neighbors/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -85,8 +85,8 @@
field = Vect_get_field_number(&In, field_opt->answer);
G_get_set_window(®ion);
result = Rast_allocate_buf(CELL_TYPE);
@@ -105,7 +105,7 @@
- y = G_row_to_northing(row + 0.5, ®ion);
+ y = Rast_row_to_northing(row + 0.5, ®ion);
box.N = y + radius;
box.S = y - radius;
@@ -116,7 +116,7 @@
int i, count;
CELL value;
- x = G_col_to_easting(col + 0.5, ®ion);
+ x = Rast_col_to_easting(col + 0.5, ®ion);
box.E = x + radius;
box.W = x - radius;
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/v.to.rast/support.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -427,11 +427,11 @@
Rast_init_cell_stats(&stats);
Rast_set_cats_title("Categories", &rast_cats);
Rast_get_row(fd, rowbuf, row, map_type);
- Rast_update_cell_stats(rowbuf, G_window_cols(), &stats);
+ Rast_update_cell_stats(rowbuf, Rast_window_cols(), &stats);
Rast_rewind_cell_stats(&stats);
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/vector/v.what.rast/main.c 2010-02-01 17:53:15 UTC (rev 40771)
@@ -193,8 +193,8 @@
G_debug(4, " cat = %d", cat);
/* Add point to cache */
- drow = G_northing_to_row(Points->y[0], &window);
- dcol = G_easting_to_col(Points->x[0], &window);
+ drow = Rast_northing_to_row(Points->y[0], &window);
+ dcol = Rast_easting_to_col(Points->x[0], &window);
/* a special case.
Modified: grass/trunk/visualization/xganim/main.cc
--- grass/trunk/visualization/xganim/main.cc 2010-02-01 15:36:31 UTC (rev 40770)
+++ grass/trunk/visualization/xganim/main.cc 2010-02-01 17:53:15 UTC (rev 40771)
@@ -109,8 +109,8 @@
nrows = vrows;
ncols = vcols;
@@ -190,7 +190,7 @@
dcell = Rast_allocate_d_buf();
/* allocate memory */
tr = (unsigned char *) G_malloc(tsiz * sizeof(char));
