[GRASS-SVN] r40789 - grass/branches/develbranch_6/visualization/nviz/src
Wed Feb 3 03:12:55 EST 2010
Author: neteler
Date: 2010-02-03 03:12:55 -0500 (Wed, 03 Feb 2010)
New Revision: 40789
   grass/branches/develbranch_6/visualization/nviz/src/interface.h
   grass/branches/develbranch_6/visualization/nviz/src/nviz_init.c
glynn: Fix handling of command line (backport from trunk, r40784)
Modified: grass/branches/develbranch_6/visualization/nviz/src/interface.h
--- grass/branches/develbranch_6/visualization/nviz/src/interface.h	2010-02-03 08:12:34 UTC (rev 40788)
+++ grass/branches/develbranch_6/visualization/nviz/src/interface.h	2010-02-03 08:12:55 UTC (rev 40789)
@@ -243,7 +243,6 @@
 /* nviz_init.c */
 int Ninit(Tcl_Interp *, Tk_Window);
 int Ninitdata(Tcl_Interp *, Nv_data *);
-int Ngetargs(Tcl_Interp *, const char ***);
 /* position.c */
 int Ninit_view_cmd(Nv_data *, Tcl_Interp *, int, char **);
Modified: grass/branches/develbranch_6/visualization/nviz/src/nviz_init.c
--- grass/branches/develbranch_6/visualization/nviz/src/nviz_init.c	2010-02-03 08:12:34 UTC (rev 40788)
+++ grass/branches/develbranch_6/visualization/nviz/src/nviz_init.c	2010-02-03 08:12:55 UTC (rev 40789)
@@ -21,7 +21,7 @@
 int script_mode = 0;
 static int parse_command(Nv_data * data, Tcl_Interp * interp,	/* Current interpreter. */
-			 int argc, const char **argv)
+			 int argc, const char *argv0, const char **argv)
     struct Option *elev, *colr, *vct, *pnt, *vol;
     struct Option *panel_path, *script, *state;
@@ -29,7 +29,7 @@
     struct GModule *module;
     char *arglist[3], *autoload;
     int i, aload = 1;
-    char *argv2[argc - 1];
+    char **argv2;
     int argc2, ii, jj;
@@ -136,15 +136,13 @@
      * Routine to strip out script name passed to through argv
      * If left in it treats it as a elev arg and tries to open
-    for (ii = 0; ii < argc; ii++) {
-	if (ii == 1)
-	    continue;
-	argv2[jj] = (char *)argv[ii];
-	jj++;
-    argc2 = argc - 1;
+    argv2 = G_malloc((argc + 2) * sizeof(char *));
+    argv2[0] = (char *)argv0;
+    for (ii = 0; ii < argc; ii++)
+	argv2[ii + 1] = (char *)argv[ii];
+    argv2[argc + 1] = NULL;
+    argc2 = argc + 1;
     /* BUG?: warning: passing arg 2 of `G_parser' from incompatible pointer type */
     if (G_parser(argc2, argv2))
 	exit(EXIT_FAILURE);
@@ -378,55 +376,44 @@
  * so that G_parser can deal with them without getting sick.
-int Ngetargs(Tcl_Interp * interp,	/* Current interpreter. */
-	     const char ***args)
+static int Ngetargs(Tcl_Interp * interp,	/* Current interpreter. */
+		    const char **p_argv0,
+		    const char ***p_argv)
-    const char *argv0, *tmp;
-    char *tmp2;
-    const char *cmd;
+    const char *argv0, *argv, *cmd;
+    char *tmp;
     int argc;
     G_debug(2, "nviz_init:Ngetargs()");
     argv0 = Tcl_GetVar(interp, "argv0", TCL_LEAVE_ERR_MSG);
-    tmp = Tcl_GetVar(interp, "argv", TCL_LEAVE_ERR_MSG);
+    argv = Tcl_GetVar(interp, "argv", TCL_LEAVE_ERR_MSG);
     cmd = Tcl_GetNameOfExecutable();
-#ifdef __MINGW32__
-    /* argv0: C:\path\to\nviz.exe
-     *   cmd: C:/path/to/nviz.exe
-     * modify argv0 to compare with cmd.
-    for (tmp2 = argv0; *tmp2; tmp2++)
-	if (*tmp2 == '\\')
-	    *tmp2 = '/';
-#endif
+    G_debug(2, "nviz_init:argv0=%s", argv0);
+    G_debug(2, "nviz_init:argv=%s", argv);
+    G_debug(2, "nviz_init:cmd=%s", cmd);
+    tmp = G_store(argv0);
+    G_convert_dirseps_from_host(tmp);
+    argv0 = tmp;
+    *p_argv0 = argv0;
     if (strstr(argv0, "script_tools") != NULL ||
 	strstr(argv0, "script_play") != NULL ||
 	strstr(argv0, "script_get_line") != NULL ||
 	strstr(argv0, "script_file_tools") != NULL) {
 	G_message(_("Entering script mode ..."));
-	tmp2 = (char *)G_malloc((strlen(cmd) + 2) * (sizeof(char)));
-	sprintf(tmp2, "%s", cmd);
 	script_mode = 1;
+	argv = "";
-    else if (strstr(cmd, argv0) == NULL) {
-	tmp2 =
-	    (char *)G_malloc((strlen(cmd) + strlen(argv0) + strlen(tmp) + 4) *
-			     (sizeof(char)));
-	sprintf(tmp2, "%s %s %s", cmd, argv0, tmp);
-    else {
-	tmp2 =
-	    (char *)G_malloc((strlen(argv0) + strlen(tmp) + 2) *
-			     (sizeof(char)));
-	sprintf(tmp2, "%s %s", argv0, tmp);
-    if (TCL_ERROR == Tcl_SplitList(interp, tmp2, &argc, args))
+    if (TCL_ERROR == Tcl_SplitList(interp, argv, &argc, p_argv))
 	exit(EXIT_FAILURE);
+    G_debug(2, "nviz_init:argc=%d", argc);
     return (argc);
@@ -552,12 +539,13 @@
 int Ninitdata(Tcl_Interp *interp,	/* Current interpreter. */
 	      Nv_data *data)
+    const char *argv0;
     const char **argv;
     int argc;
-    argc = Ngetargs(interp, &argv);
+    argc = Ngetargs(interp, &argv0, &argv);
-    G_gisinit(argv[0]);
+    G_gisinit(argv0);
     GS_libinit();
@@ -567,7 +555,7 @@
     data->NumCplanes = 0;
     data->CurCplane = 0;
     if (!script_mode)
-	parse_command(data, interp, argc, argv);
+	parse_command(data, interp, argc, argv0, argv);
     return (TCL_OK);
