[GRASS-SVN] r40807 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Wed Feb 3 23:58:02 EST 2010
Author: rashadkm
Date: 2010-02-03 23:58:00 -0500 (Wed, 03 Feb 2010)
New Revision: 40807
Added:
grass-addons/gui/wxpython/data_catalog/mapframe.py
Removed:
grass-addons/gui/wxpython/data_catalog/mapdisp_1.py
fixed error on updateMap
Deleted: grass-addons/gui/wxpython/data_catalog/mapdisp_1.py
--- grass-addons/gui/wxpython/data_catalog/mapdisp_1.py 2010-02-04 04:23:35 UTC (rev 40806)
+++ grass-addons/gui/wxpython/data_catalog/mapdisp_1.py 2010-02-04 04:58:00 UTC (rev 40807)
@@ -1,4227 +0,0 @@
- at package mapdisp.py
- at brief GIS map display canvas, with toolbar for various display
-management functions, and second toolbar for vector
-digitizing.
-Can be used either from GIS Manager or as p.mon backend.
-Classes:
- - Command
- - MapWindow
- - BufferedWindow
- - MapFrame
- - MapApp
-Usage:
- python mapdisp.py monitor-identifier /path/to/command/file
-(C) 2006-2008 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Michael Barton
- at author Jachym Cepicky
- at author Martin Landa <landa.martin gmail.com>
-import os
-import sys
-import time
-import glob
-import math
-import tempfile
-import copy
-import globalvar
-if not os.getenv("GRASS_WXBUNDLED"):
- globalvar.CheckForWx()
-import wx
-import wx.aui
-from threading import Thread
-try:
- import subprocess
-except:
- CompatPath = os.path.join(globalvar.ETCWXDIR)
- sys.path.append(CompatPath)
- from compat import subprocess
-gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
-sys.path.append(gmpath)
-import render
-import toolbars
-import track
-import menuform
-import gselect
-import disp_print
-import gcmd
-import dbm
-import histogram
-import profile
-import globalvar
-import utils
-import gdialogs
-from grass.script import core as grass
-from vdigit import VDigitCategoryDialog as VDigitCategoryDialog
-from vdigit import VDigitZBulkDialog as VDigitZBulkDialog
-from vdigit import VDigitDuplicatesDialog as VDigitDuplicatesDialog
-from vdigit import GV_LINES as VDigit_Lines_Type
-from debug import Debug as Debug
-from icon import Icons as Icons
-from preferences import globalSettings as UserSettings
-import images
-imagepath = images.__path__[0]
-sys.path.append(imagepath)
-### global variables
-# for standalone app
-cmdfilename = None
-class Command(Thread):
- Creates thread which will observe the command file and see, if
- there is new command to be executed
- def __init__ (self, parent, Map):
- Thread.__init__(self)
- global cmdfilename
- self.parent = parent
- self.map = Map
- self.cmdfile = open(cmdfilename, "r")
- def run(self):
- Run this in thread
- dispcmd = []
- while 1:
- self.parent.redraw = False
- line = self.cmdfile.readline().strip()
- if line == "quit":
- break
- if line:
- try:
- Debug.msg (3, "Command.run(): cmd=%s" % (line))
- self.map.AddLayer(item=None, type="raster",
- name='',
- command=line,
- l_opacity=1)
- self.parent.redraw =True
- except Exception, e:
- print "Command Thread: ",e
- time.sleep(0.1)
- sys.exit()
-class MapWindow(object):
- Abstract map window class
- Parent for BufferedWindow class (2D display mode) and
- GLWindow (3D display mode)
- def __init__(self, parent, id=wx.ID_ANY,
- pos=wx.DefaultPosition,
- size=wx.DefaultSize,
- style=wx.NO_FULL_REPAINT_ON_RESIZE,
- Map=None, tree=None, gismgr=None):
- self.parent = parent # MapFrame
- # mouse attributes like currently pressed buttons, position on
- # the screen, begin and end of dragging, and type of drawing
- self.mouse = {
- 'l' : False,
- 'r' : False,
- 'm' : False,
- 'begin': [0, 0], # screen coordinates
- 'end' : [0, 0],
- 'use' : "pointer",
- 'box' : "point"
- def EraseMap(self):
- Erase the canvas (virtual method)
- pass
- def UpdateMap(self):
- Updates the canvas anytime there is a change to the
- underlaying images or to the geometry of the canvas.
- pass
- def OnLeftDown(self, event):
- pass
- def OnLeftUp(self, event):
- pass
- def OnMouseMotion(self, event):
- pass
- def OnZoomToMap(self, event):
- pass
- def OnZoomToRaster(self, event):
- pass
- def GetSelectedLayer(self, type = 'layer', multi = False):
- Get selected layer from layer tree
- @param type 'item' / 'layer' / 'nviz'
- @param multi return first selected layer or all
- @return layer / map layer properties / nviz properties
- @return None / [] on failure
- ret = []
- if not self.tree or \
- not self.tree.GetSelection():
- if multi:
- return []
- else:
- return None
- if multi and \
- type == 'item':
- return self.tree.GetSelections()
- for item in self.tree.GetSelections():
- if not item.IsChecked():
- if multi:
- continue
- else:
- return None
- if type == 'item': # -> multi = False
- return item
- try:
- if type == 'nviz':
- layer = self.tree.GetPyData(item)[0]['nviz']
- else:
- layer = self.tree.GetPyData(item)[0]['maplayer']
- except:
- layer = None
- if multi:
- ret.append(layer)
- else:
- return layer
- return ret
-class BufferedWindow(MapWindow, wx.Window):
- A Buffered window class.
- When the drawing needs to change, you app needs to call the
- UpdateMap() method. Since the drawing is stored in a bitmap, you
- can also save the drawing to file by calling the
- SaveToFile(self,file_name,file_type) method.
- def __init__(self, parent, id,
- pos = wx.DefaultPosition,
- size = wx.DefaultSize,
- MapWindow.__init__(self, parent, id, pos, size, style,
- Map, tree, gismgr)
- wx.Window.__init__(self, parent, id, pos, size, style)
- self.Map = Map
- self.tree = tree
- self.gismanager = gismgr
- # Flags
- self.resize = False # indicates whether or not a resize event has taken place
- self.dragimg = None # initialize variable for map panning
- # Variable for drawing on DC
- self.pen = None # pen for drawing zoom boxes, etc.
- self.polypen = None # pen for drawing polylines (measurements, profiles, etc)
- # List of wx.Point tuples defining a polyline (geographical coordinates)
- self.polycoords = []
- # ID of rubber band line
- self.lineid = None
- # ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
- self.plineid = None
- # Event bindings
- self.Bind(wx.EVT_PAINT, self.OnPaint)
- self.Bind(wx.EVT_SIZE, self.OnSize)
- self.Bind(wx.EVT_IDLE, self.OnIdle)
- self.Bind(wx.EVT_MOTION, self.MouseActions)
- self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
- self.processMouse = True
- # Render output objects
- self.mapfile = None # image file to be rendered
- self.img = "" # wx.Image object (self.mapfile)
- # used in digitization tool (do not redraw vector map)
- self.imgVectorMap = None
- # decoration overlays
- self.overlays = {}
- # images and their PseudoDC ID's for painting and dragging
- self.imagedict = {}
- self.select = {} # selecting/unselecting decorations for dragging
- self.textdict = {} # text, font, and color indexed by id
- self.currtxtid = None # PseudoDC id for currently selected text
- # Zoom objects
- self.zoomhistory = [] # list of past zoom extents
- self.currzoom = 0 # current set of extents in zoom history being used
- self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
- self.hitradius = 10 # distance for selecting map decorations
- self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
- # OnSize called to make sure the buffer is initialized.
- # This might result in OnSize getting called twice on some
- # platforms at initialization, but little harm done.
- ### self.OnSize(None)
- # create PseudoDC used for background map, map decorations like scales and legends
- self.pdc = wx.PseudoDC()
- # used for digitization tool
- self.pdcVector = None
- # decorations (region box, etc.)
- self.pdcDec = wx.PseudoDC()
- # pseudoDC for temporal objects (select box, measurement tool, etc.)
- self.pdcTmp = wx.PseudoDC()
- # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
- self.redrawAll = True
- # will store an off screen empty bitmap for saving to file
- self._buffer = ''
- self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
- # vars for handling mouse clicks
- self.dragid = -1
- self.lastpos = (0, 0)
- def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
- Draws map and overlay decorations
- if drawid == None:
- if pdctype == 'image' and img:
- drawid = self.imagedict[img]
- elif pdctype == 'clear':
- drawid == None
- else:
- drawid = wx.NewId()
- if img and pdctype == 'image':
- # self.imagedict[img]['coords'] = coords
- self.select[self.imagedict[img]['id']] = False # ?
- pdc.BeginDrawing()
- if drawid != 99:
- bg = wx.TRANSPARENT_BRUSH
- else:
- bg = wx.Brush(self.GetBackgroundColour())
- pdc.SetBackground(bg)
- ### pdc.Clear()
- Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
- (drawid, pdctype, coords))
- # set PseudoDC id
- if drawid is not None:
- pdc.SetId(drawid)
- if pdctype == 'clear': # erase the display
- bg = wx.WHITE_BRUSH
- # bg = wx.Brush(self.GetBackgroundColour())
- pdc.RemoveAll()
- pdc.Clear()
- pdc.EndDrawing()
- self.Refresh()
- return
- if pdctype == 'image': # draw selected image
- bitmap = wx.BitmapFromImage(img)
- w,h = bitmap.GetSize()
- pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
- pdc.SetIdBounds(drawid, (coords[0],coords[1], w, h))
- elif pdctype == 'box': # draw a box on top of the map
- if self.pen:
- pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
- pdc.SetPen(self.pen)
- x2 = max(coords[0],coords[2])
- x1 = min(coords[0],coords[2])
- y2 = max(coords[1],coords[3])
- y1 = min(coords[1],coords[3])
- rwidth = x2-x1
- rheight = y2-y1
- rect = wx.Rect(x1,y1,rwidth,rheight)
- pdc.DrawRectangleRect(rect)
- pdc.SetIdBounds(drawid,rect)
- # self.ovlcoords[drawid] = coords
- elif pdctype == 'line': # draw a line on top of the map
- if self.pen:
- pdc.DrawLine(coords[0], coords[1], coords[2], coords[3])
- pdc.SetIdBounds(drawid,(coords[0], coords[1], coords[2], coords[3]))
- elif pdctype == 'polyline': # draw a polyline on top of the map
- if self.polypen:
- pdc.SetPen(self.polypen)
- pdc.DrawLines(coords)
- # get bounding rectangle for polyline
- xlist = []
- ylist = []
- if len(coords) > 0:
- for point in coords:
- x,y = point
- xlist.append(x)
- ylist.append(y)
- x1=min(xlist)
- x2=max(xlist)
- y1=min(ylist)
- y2=max(ylist)
- pdc.SetIdBounds(drawid,(x1,y1,x2,y2))
- # self.ovlcoords[drawid] = [x1,y1,x2,y2]
- elif pdctype == 'point': # draw point
- if self.pen:
- pdc.DrawPoint(coords[0], coords[1])
- coordsBound = (coords[0] - 5,
- coords[1] - 5,
- coords[0] + 5,
- coords[1] + 5)
- pdc.SetIdBounds(drawid, coordsBound)
- elif pdctype == 'text': # draw text on top of map
- if not img['active']:
- return #only draw active text
- if img.has_key('rotation'):
- rotation = float(img['rotation'])
- else:
- rotation = 0.0
- w, h = self.GetFullTextExtent(img['text'])[0:2]
- pdc.SetFont(img['font'])
- pdc.SetTextForeground(img['color'])
- coords, w, h = self.TextBounds(img)
- if rotation == 0:
- pdc.DrawText(img['text'], coords[0], coords[1])
- else:
- pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
- pdc.SetIdBounds(drawid, (coords[0], coords[1], w, h))
- pdc.EndDrawing()
- self.Refresh()
- return drawid
- def TextBounds(self, textinfo):
- Return text boundary data
- @param textinfo text metadata (text, font, color, rotation)
- @param coords reference point
- if textinfo.has_key('rotation'):
- rotation = float(textinfo['rotation'])
- else:
- rotation = 0.0
- coords = textinfo['coords']
- Debug.msg (4, "BufferedWindow.TextBounds(): text=%s, rotation=%f" % \
- (textinfo['text'], rotation))
- self.Update()
- ### self.Refresh()
- self.SetFont(textinfo['font'])
- w, h = self.GetTextExtent(textinfo['text'])
- if rotation == 0:
- coords[2], coords[3] = coords[0] + w, coords[1] + h
- return coords, w, h
- boxh = math.fabs(math.sin(math.radians(rotation)) * w) + h
- boxw = math.fabs(math.cos(math.radians(rotation)) * w) + h
- coords[2] = coords[0] + boxw
- coords[3] = coords[1] + boxh
- return coords, boxw, boxh
- def OnPaint(self, event):
- Draw PseudoDC's to buffered paint DC
- self.pdc for background and decorations
- self.pdcVector for vector map which is edited
- self.pdcTmp for temporaly drawn objects (self.polycoords)
- If self.redrawAll is False on self.pdcTmp content is re-drawn
- Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
- dc = wx.BufferedPaintDC(self, self.buffer)
- ### dc.SetBackground(wx.Brush("White"))
- dc.Clear()
- # use PrepareDC to set position correctly
- self.PrepareDC(dc)
- # create a clipping rect from our position and size
- # and update region
- rgn = self.GetUpdateRegion().GetBox()
- dc.SetClippingRect(rgn)
- switchDraw = False
- if self.redrawAll is None:
- switchDraw = True
- if self.redrawAll: # redraw pdc and pdcVector
- # draw to the dc using the calculated clipping rect
- self.pdc.DrawToDCClipped(dc, rgn)
- # draw vector map layer
- if self.pdcVector:
- # decorate with GDDC (transparency)
- try:
- gcdc = wx.GCDC(dc)
- self.pdcVector.DrawToDCClipped(gcdc, rgn)
- except NotImplementedError, e:
- print >> sys.stderr, e
- self.pdcVector.DrawToDCClipped(dc, rgn)
- self.bufferLast = None
- else: # do not redraw pdc and pdcVector
- if self.bufferLast is None:
- # draw to the dc
- self.pdc.DrawToDC(dc)
- try:
- self.pdcVector.DrawToDC(gcdc)
- self.pdcVector.DrawToDC(dc)
- # store buffered image
- # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
- self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
- pdcLast = wx.PseudoDC()
- pdcLast.DrawBitmap(bmp=self.bufferLast, x=0, y=0)
- pdcLast.DrawToDC(dc)
- # draw decorations (e.g. region box)
- try:
- self.pdcDec.DrawToDC(gcdc)
- self.pdcDec.DrawToDC(dc)
- # draw temporary object on the foreground
- ### self.pdcTmp.DrawToDCClipped(dc, rgn)
- self.pdcTmp.DrawToDC(dc)
- if switchDraw:
- self.redrawAll = False
- def OnSize(self, event):
- Scale map image so that it is
- the same size as the Window
- Debug.msg(3, "BufferedWindow.OnSize():")
- # set size of the input image
- self.Map.ChangeMapSize(self.GetClientSize())
- # align extent based on center point and display resolution
- # this causes that image is not resized when display windows is resized
- # self.Map.AlignExtentFromDisplay()
- # Make new off screen bitmap: this bitmap will always have the
- # current drawing in it, so it can be used to save the image to
- # a file, or whatever.
- self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
- # get the image to be rendered
- self.img = self.GetImage()
- # update map display
- if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
- self.img = self.img.Scale(self.Map.width, self.Map.height)
- if len(self.Map.GetListOfLayers()) > 0:
- self.UpdateMap()
- # re-render image on idle
- self.resize = True
- # reposition checkbox in statusbar
- self.parent.StatusbarReposition()
- # update statusbar
- self.parent.StatusbarUpdate()
- def OnIdle(self, event):
- Only re-render a composite map image from GRASS during
- idle time instead of multiple times during resizing.
- if self.resize:
- self.UpdateMap(render=True)
- event.Skip()
- def SaveToFile(self, FileName, FileType):
- This draws the psuedo DC to a buffer that
- can be saved to a file.
- self.buffer.SaveFile(FileName, FileType)
- def GetOverlay(self):
- Converts rendered overlay files to wx.Image
- Updates self.imagedict
- @return list of images
- imgs = []
- for overlay in self.Map.GetListOfLayers(l_type="overlay", l_active=True):
- if os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
- img = wx.Image(overlay.mapfile, wx.BITMAP_TYPE_ANY)
- self.imagedict[img] = { 'id' : overlay.id,
- 'layer' : overlay }
- imgs.append(img)
- return imgs
- def GetImage(self):
- Converts redered map files to wx.Image
- Updates self.imagedict (id=99)
- @return wx.Image instance (map composition)
- imgId = 99
- if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
- os.path.getsize(self.Map.mapfile):
- img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
- else:
- img = None
- self.imagedict[img] = { 'id': imgId }
- return img
- def UpdateMap(self, render=True, renderVector=True):
- @param render re-render map composition
- @param renderVector re-render vector map layer enabled for editing (used for digitizer)
- start = time.clock()
- # if len(self.Map.GetListOfLayers()) == 0:
- # return False
- if self.img is None:
- render = True
- # initialize process bar (only on 'render')
- if render is True or renderVector is True:
- self.parent.onRenderGauge.Show()
- if self.parent.onRenderGauge.GetRange() > 0:
- self.parent.onRenderGauge.SetValue(1)
- # render background image if needed
- # update layer dictionary if there has been a change in layers
- if self.tree and self.tree.reorder == True:
- self.tree.ReorderLayers()
- # reset flag for auto-rendering
- if self.tree:
- self.tree.rerender = False
- if render:
- # update display size
- if self.parent.compResolution.IsChecked():
- # use computation region resolution for rendering
- windres = True
- else:
- windres = False
- self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
- windres=windres)
- else:
- self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
- self.img = self.GetImage() # id=99
- # clear pseudoDcs
- for pdc in (self.pdc,
- self.pdcDec,
- self.pdcTmp):
- pdc.Clear()
- pdc.RemoveAll()
- # draw background map image to PseudoDC
- if not self.img:
- self.Draw(self.pdc, pdctype='clear')
- else:
- try:
- id = self.imagedict[self.img]['id']
- except:
- return False
- self.Draw(self.pdc, self.img, drawid=id)
- # render vector map layer
- digitToolbar = self.parent.toolbars['vdigit']
- if renderVector and digitToolbar and \
- digitToolbar.GetLayer():
- # set region
- self.parent.digit.driver.UpdateRegion()
- # re-calculate threshold for digitization tool
- self.parent.digit.driver.GetThreshold()
- # draw map
- self.pdcVector.Clear()
- self.pdcVector.RemoveAll()
- try:
- item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
- except TypeError:
- item = None
- if item and self.tree.IsItemChecked(item):
- self.parent.digit.driver.DrawMap()
- # translate tmp objects (pointer position)
- if digitToolbar.GetAction() == 'moveLine':
- if hasattr(self, "vdigitMove") and \
- self.vdigitMove.has_key('beginDiff'):
- # move line
- for id in self.vdigitMove['id']:
- # print self.pdcTmp.GetIdBounds(id)
- self.pdcTmp.TranslateId(id,
- self.vdigitMove['beginDiff'][0],
- self.vdigitMove['beginDiff'][1])
- del self.vdigitMove['beginDiff']
- # render overlays
- for img in self.GetOverlay():
- # draw any active and defined overlays
- if self.imagedict[img]['layer'].IsActive():
- id = self.imagedict[img]['id']
- self.Draw(self.pdc, img=img, drawid=id,
- pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
- for id in self.textdict.keys():
- self.Draw(self.pdc, img=self.textdict[id], drawid=id,
- pdctype='text', coords=[10, 10, 10, 10])
- # optionally draw computational extent box
- self.DrawCompRegionExtent()
- # redraw pdcTmp if needed
- if len(self.polycoords) > 0:
- self.DrawLines(self.pdcTmp)
- if self.gismanager.georectifying:
- # -> georectifier (redraw GCPs)
- if self.parent.toolbars['georect']:
- coordtype = 'gcpcoord'
- else:
- coordtype = 'mapcoord'
- self.parent.gismanager.georectifying.DrawGCP(coordtype)
- # clear measurement
- if self.mouse["use"] == "measure":
- self.ClearLines(pdc=self.pdcTmp)
- self.mouse['use'] = 'pointer'
- self.mouse['box'] = 'point'
- self.mouse['end'] = [0, 0]
- self.SetCursor(self.parent.cursors["default"])
- stop = time.clock()
- # hide process bar
- self.parent.onRenderGauge.Hide()
- ### self.Map.SetRegion()
- if grass.find_file(name = 'MASK', element = 'cell')['name']:
- # mask found
- self.parent.maskInfo.SetLabel(_('MASK'))
- else:
- self.parent.maskInfo.SetLabel('')
- Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
- (render, renderVector, (stop-start)))
- return True
- def DrawCompRegionExtent(self):
- Draw computational region extent in the display
- Display region is drawn as a blue box inside the computational region,
- computational region inside a display region as a red box).
- if hasattr(self, "regionCoords"):
- compReg = self.Map.GetRegion()
- dispReg = self.Map.GetCurrentRegion()
- reg = None
- if self.IsInRegion(dispReg, compReg):
- self.polypen = wx.Pen(colour=wx.Colour(0, 0, 255, 128), width=3, style=wx.SOLID)
- reg = dispReg
- else:
- self.polypen = wx.Pen(colour=wx.Colour(255, 0, 0, 128),
- width=3, style=wx.SOLID)
- reg = compReg
- self.regionCoords = []
- self.regionCoords.append((reg['w'], reg['n']))
- self.regionCoords.append((reg['e'], reg['n']))
- self.regionCoords.append((reg['e'], reg['s']))
- self.regionCoords.append((reg['w'], reg['s']))
- # draw region extent
- self.DrawLines(pdc=self.pdcDec, polycoords=self.regionCoords)
- def IsInRegion(self, region, refRegion):
- Test if 'region' is inside of 'refRegion'
- @param region input region
- @param refRegion reference region (e.g. computational region)
- @return True if region is inside of refRegion
- @return False
- if region['s'] >= refRegion['s'] and \
- region['n'] <= refRegion['n'] and \
- region['w'] >= refRegion['w'] and \
- region['e'] <= refRegion['e']:
- return True
- return False
- Erase the canvas
- self.Draw(self.pdcVector, pdctype='clear')
- self.Draw(self.pdcDec, pdctype='clear')
- self.Draw(self.pdcTmp, pdctype='clear')
- def DragMap(self, moveto):
- Drag the entire map image for panning.
- dc = wx.BufferedDC(wx.ClientDC(self))
- dc.SetBackground(wx.Brush("White"))
- dc.Clear()
- self.dragimg = wx.DragImage(self.buffer)
- self.dragimg.BeginDrag((0, 0), self)
- self.dragimg.GetImageRect(moveto)
- self.dragimg.Move(moveto)
- self.dragimg.DoDrawImage(dc, moveto)
- self.dragimg.EndDrag()
- return True
- def DragItem(self, id, event):
- Drag an overlay decoration item
- if id == 99 or id == '' or id == None: return
- Debug.msg (5, "BufferedWindow.DragItem(): id=%d" % id)
- x, y = self.lastpos
- dx = event.GetX() - x
- dy = event.GetY() - y
- self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
- r = self.pdc.GetIdBounds(id)
- if id > 100: # text dragging
- rtop = (r[0],r[1]-r[3],r[2],r[3])
- r = r.Union(rtop)
- rleft = (r[0]-r[2],r[1],r[2],r[3])
- r = r.Union(rleft)
- self.pdc.TranslateId(id, dx, dy)
- r2 = self.pdc.GetIdBounds(id)
- self.textdict[id]['coords'] = r2
- r = r.Union(r2)
- r.Inflate(4,4)
- self.RefreshRect(r, False)
- self.lastpos = (event.GetX(), event.GetY())
- def MouseDraw(self, pdc=None, begin=None, end=None):
- Mouse box or line from 'begin' to 'end'
- If not given from self.mouse['begin'] to self.mouse['end'].
- if not pdc:
- return
- if begin is None:
- begin = self.mouse['begin']
- if end is None:
- end = self.mouse['end']
- Debug.msg (5, "BufferedWindow.MouseDraw(): use=%s, box=%s, begin=%f,%f, end=%f,%f" % \
- (self.mouse['use'], self.mouse['box'],
- begin[0], begin[1], end[0], end[1]))
- if self.mouse['box'] == "box":
- boxid = wx.ID_NEW
- mousecoords = [begin[0], begin[1],
- end[0], end[1]]
- r = pdc.GetIdBounds(boxid)
- r.Inflate(4,4)
- pdc.ClearId(boxid)
- pdc.SetId(boxid)
- self.Draw(pdc, drawid=boxid, pdctype='box', coords=mousecoords)
- elif self.mouse['box'] == "line" or self.mouse['box'] == 'point':
- self.lineid = wx.ID_NEW
- mousecoords = [begin[0], begin[1], \
- end[0], end[1]]
- x1=min(begin[0],end[0])
- x2=max(begin[0],end[0])
- y1=min(begin[1],end[1])
- y2=max(begin[1],end[1])
- r = wx.Rect(x1,y1,x2-x1,y2-y1)
- r.Inflate(4,4)
- try:
- pdc.ClearId(self.lineid)
- except:
- pass
- pdc.SetId(self.lineid)
- self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
- def DrawLines(self, pdc=None, polycoords=None):
- Draw polyline in PseudoDC
- Set self.pline to wx.NEW_ID + 1
- polycoords - list of polyline vertices, geographical coordinates
- (if not given, self.polycoords is used)
- if not pdc:
- pdc = self.pdcTmp
- if not polycoords:
- polycoords = self.polycoords
- if len(polycoords) > 0:
- self.plineid = wx.ID_NEW + 1
- # convert from EN to XY
- coords = []
- for p in polycoords:
- coords.append(self.Cell2Pixel(p))
- self.Draw(pdc, drawid=self.plineid, pdctype='polyline', coords=coords)
- Debug.msg (4, "BufferedWindow.DrawLines(): coords=%s, id=%s" % \
- (coords, self.plineid))
- return self.plineid
- return -1
- def DrawCross(self, pdc, coords, size, rotation=0,
- text=None, textAlign='lr', textOffset=(5, 5)):
- """Draw cross in PseudoDC
- @todo implement rotation
- @param pdc PseudoDC
- @param coord center coordinates
- @param rotation rotate symbol
- @param text draw also text (text, font, color, rotation)
- @param textAlign alignment (default 'lower-right')
- @textOffset offset for text (from center point)
- Debug.msg(4, "BufferedWindow.DrawCross(): pdc=%s, coords=%s, size=%d" % \
- (pdc, coords, size))
- coordsCross = ((coords[0] - size, coords[1], coords[0] + size, coords[1]),
- (coords[0], coords[1] - size, coords[0], coords[1] + size))
- self.lineid = wx.NewId()
- for lineCoords in coordsCross:
- self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=lineCoords)
- if not text:
- return self.lineid
- if textAlign == 'ul':
- coord = [coords[0] - textOffset[0], coords[1] - textOffset[1], 0, 0]
- elif textAlign == 'ur':
- coord = [coords[0] + textOffset[0], coords[1] - textOffset[1], 0, 0]
- elif textAlign == 'lr':
- coord = [coords[0] + textOffset[0], coords[1] + textOffset[1], 0, 0]
- else:
- coord = [coords[0] - textOffset[0], coords[1] + textOffset[1], 0, 0]
- self.Draw(pdc, img=text,
- pdctype='text', coords=coord)
- def MouseActions(self, event):
- Mouse motion and button click notifier
- if not self.processMouse:
- return
- ### if self.redrawAll is False:
- ### self.redrawAll = True
- # zoom with mouse wheel
- if event.GetWheelRotation() != 0:
- self.OnMouseWheel(event)
- # left mouse button pressed
- elif event.LeftDown():
- self.OnLeftDown(event)
- # left mouse button released
- elif event.LeftUp():
- self.OnLeftUp(event)
- # dragging
- elif event.Dragging():
- self.OnDragging(event)
- # double click
- elif event.ButtonDClick():
- self.OnButtonDClick(event)
- # middle mouse button pressed
- elif event.MiddleDown():
- self.OnMiddleDown(event)
- # right mouse button pressed
- elif event.RightDown():
- self.OnRightDown(event)
- # right mouse button released
- elif event.RightUp():
- self.OnRightUp(event)
- elif event.Moving():
- self.OnMouseMoving(event)
-# event.Skip()
- def OnMouseWheel(self, event):
- Mouse wheel moved
- self.processMouse = False
- current = event.GetPositionTuple()[:]
- wheel = event.GetWheelRotation()
- Debug.msg (5, "BufferedWindow.MouseAction(): wheel=%d" % wheel)
- # zoom 1/2 of the screen, centered to current mouse position (TODO: settings)
- begin = (current[0] - self.Map.width / 4,
- current[1] - self.Map.height / 4)
- end = (current[0] + self.Map.width / 4,
- current[1] + self.Map.height / 4)
- if wheel > 0:
- zoomtype = 1
- else:
- zoomtype = -1
- # zoom
- self.Zoom(begin, end, zoomtype)
- # redraw map
- self.UpdateMap()
- ### self.OnPaint(None)
- self.Refresh()
-# event.Skip()
- def OnDragging(self, event):
- Mouse dragging with left button down
- Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
- previous = self.mouse['begin']
- move = (current[0] - previous[0],
- current[1] - previous[1])
- # dragging or drawing box with left button
- if self.mouse['use'] == 'pan':
- self.DragMap(move)
- # dragging decoration overlay item
- elif (self.mouse['use'] == 'pointer' and
- not digitToolbar and
- self.dragid != None):
- self.DragItem(self.dragid, event)
- # dragging anything else - rubber band box or line
- else:
- if (self.mouse['use'] == 'pointer' and
- not digitToolbar): return
- self.mouse['end'] = event.GetPositionTuple()[:]
- digitClass = self.parent.digit
- if (event.LeftIsDown() and
- not (digitToolbar and
- digitToolbar.GetAction() in ("moveLine",) and
- digitClass.driver.GetSelected() > 0)):
- # draw box only when left mouse button is pressed
- self.MouseDraw(pdc=self.pdcTmp)
-# event.Skip()
- Left mouse button pressed
- Debug.msg (5, "BufferedWindow.OnLeftDown(): use=%s" % \
- self.mouse["use"])
- self.mouse['begin'] = event.GetPositionTuple()[:]
- if self.mouse["use"] in ["measure", "profile"]:
- # measure or profile
- if len(self.polycoords) == 0:
- self.mouse['end'] = self.mouse['begin']
- self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
- else:
- self.mouse['begin'] = self.mouse['end']
- elif self.mouse['use'] == 'zoom':
- pass
- elif self.mouse["use"] == "pointer" and self.parent.toolbars['vdigit']:
- # digitization
- east, north = self.Pixel2Cell(self.mouse['begin'])
- try:
- map = digitToolbar.GetLayer().GetName()
- except:
- map = None
- wx.MessageBox(parent=self,
- message=_("No vector map selected for editing."),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- event.Skip()
- return
- # calculate position of 'update record' dialog
- position = self.mouse['begin']
- posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
- position[1] + self.dialogOffset))
- if digitToolbar.GetAction() not in ("moveVertex", "addVertex",
- "removeVertex", "editLine"):
- # set pen
- self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
- self.polypen = wx.Pen(colour='dark green', width=2, style=wx.SOLID)
- if digitToolbar.GetAction() in ("addVertex", "removeVertex"):
- # unselect
- digitClass.driver.SetSelected([])
- if digitToolbar.GetAction() == "addLine":
- if digitToolbar.GetAction('type') in ["point", "centroid"]:
- # add new point
- if digitToolbar.GetAction('type') == 'point':
- point = True
- else:
- point = False
- fid = digitClass.AddPoint(map, point, east, north)
- if fid < 0:
- return
- self.UpdateMap(render=False) # redraw map
- # add new record into atribute table
- if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
- # select attributes based on layer and category
- cats = { fid : {
- UserSettings.Get(group='vdigit', key="layer", subkey='value') :
- (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
- addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=map,
- cats=cats,
- pos=posWindow,
- action="add")
- if addRecordDlg.mapDBInfo and \
- addRecordDlg.ShowModal() == wx.ID_OK:
- sqlfile = tempfile.NamedTemporaryFile(mode="w")
- for sql in addRecordDlg.GetSQLString():
- sqlfile.file.write(sql + ";\n")
- sqlfile.file.flush()
- executeCommand = gcmd.Command(cmd=["db.execute",
- "--q",
- "input=%s" % sqlfile.name])
- elif digitToolbar.GetAction('type') in ["line", "boundary"]:
- # add new point to the line
- self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
- self.DrawLines(pdc=self.pdcTmp)
- elif digitToolbar.GetAction() == "editLine" and hasattr(self, "vdigitMove"):
- self.vdigitMove['id'].append(wx.NewId())
- elif digitToolbar.GetAction() == "deleteLine":
- pass
- elif digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
- not hasattr(self, "vdigitMove"):
- self.vdigitMove = {}
- # geographic coordinates of initial position (left-down)
- self.vdigitMove['begin'] = None
- # list of ids to modify
- self.vdigitMove['id'] = []
- # ids geographic coordinates
- self.vdigitMove['coord'] = {}
- if digitToolbar.GetAction() in ["moveVertex", "editLine"]:
- # set pen
- pcolor = UserSettings.Get(group='vdigit', key="symbol",
- subkey=["highlight", "color"])
- self.pen = self.polypen = wx.Pen(colour=pcolor,
- width=2, style=wx.SHORT_DASH)
- self.pdcTmp.SetPen(self.polypen)
- elif digitToolbar.GetAction() == "splitLine":
- # unselect
- elif digitToolbar.GetAction() in ["displayAttrs", "displayCats"]:
- qdist = digitClass.driver.GetThreshold(type='selectThresh')
- coords = (east, north)
- if digitClass.type == 'vdigit':
- # unselect
- # select feature by point
- cats = {}
- if digitClass.driver.SelectLineByPoint(coords,
- digitClass.GetSelectType()) is not None:
- if UserSettings.Get(group='vdigit', key='checkForDupl',
- subkey='enabled'):
- lines = digitClass.driver.GetSelected()
- else:
- lines = (digitClass.driver.GetSelected()[0],) # only first found
- for line in lines:
- cats[line] = digitClass.GetLineCats(line)
- if digitToolbar.GetAction() == "displayAttrs":
- # select attributes based on coordinates (all layers)
- if self.parent.dialogs['attributes'] is None:
- if digitClass.type == 'vedit':
- self.parent.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self, map=map,
- query=(coords, qdist),
- pos=posWindow,
- action="update")
- else:
- cats=cats,
- action="update")
- else:
- # update currently open dialog
- self.parent.dialogs['attributes'].UpdateDialog(query=(coords, qdist))
- else:
- # upgrade dialog
- self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
- if self.parent.dialogs['attributes']:
- if len(cats.keys()) > 0:
- # highlight feature & re-draw map
- if not self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Show()
- else:
- if self.parent.dialogs['attributes'] and \
- self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Hide()
- else: # displayCats
- if self.parent.dialogs['category'] is None:
- # open new dialog
- dlg = VDigitCategoryDialog(parent=self,
- map=map,
- pos=posWindow,
- title=_("Update categories"))
- self.parent.dialogs['category'] = dlg
- else:
- map=map,
- cats=cats,
- pos=posWindow,
- else:
- self.parent.dialogs['category'].UpdateDialog(query=(coords, qdist))
- else:
- # upgrade dialog
- self.parent.dialogs['category'].UpdateDialog(cats=cats)
- if self.parent.dialogs['category']:
- ### digitClass.driver.SetSelected(line)
- if not self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Show()
- else:
- if self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Hide()
- elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
- if not hasattr(self, "copyCatsList"):
- self.copyCatsList = []
- else:
- self.copyCatsIds = []
- self.mouse['box'] = 'box'
- elif digitToolbar.GetAction() == "copyLine":
- self.copyIds = []
- self.layerTmp = None
- elif digitToolbar.GetAction() == "zbulkLine":
- if len(self.polycoords) > 1: # start new line
- if len(self.polycoords) == 1:
- begin = self.Pixel2Cell(self.polycoords[-1])
- end = self.Pixel2Cell(self.mouse['end'])
- else:
- end = self.Pixel2Cell(self.polycoords[-1])
- begin = self.Pixel2Cell(self.mouse['begin'])
- self.DrawLines(self.pdcTmp, polycoords = [begin, end])
- elif self.mouse['use'] == 'pointer':
- # get decoration or text id
- self.idlist = []
- self.dragid = ''
- self.lastpos = self.mouse['begin']
- idlist = self.pdc.FindObjects(x=self.lastpos[0], y=self.lastpos[1],
- radius=self.hitradius)
- if 99 in idlist: idlist.remove(99)
- if idlist != [] :
- self.dragid = idlist[0] #drag whatever is on top
- else:
- pass
- event.Skip()
- Left mouse button released
- Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
- if self.mouse['use'] in ["zoom", "pan"]:
- # set region in zoom or pan
- if self.mouse['use'] == 'zoom':
- # set region for click (zero-width box)
- if begin[0] - end[0] == 0 or \
- begin[1] - end[1] == 0:
- # zoom 1/2 of the screen (TODO: settings)
- begin = (end[0] - self.Map.width / 4,
- end[1] - self.Map.height / 4)
- end = (end[0] + self.Map.width / 4,
- end[1] + self.Map.height / 4)
- self.Zoom(begin, end, self.zoomtype)
- # redraw map
- elif self.mouse["use"] == "query":
- # querying
- self.parent.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
- elif self.mouse["use"] == "queryVector":
- # editable mode for vector map layers
- self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
- # clear temp canvas
- self.UpdateMap(render=False, renderVector=False)
- elif self.mouse["use"] in ["measure", "profile"]:
- self.parent.MeasureDist(self.mouse['begin'], self.mouse['end'])
- self.polycoords.append(self.Pixel2Cell(self.mouse['end']))
- elif self.mouse["use"] == "pointer" and self.parent.gismanager.georectifying:
- # -> georectifying
- coord = self.Pixel2Cell(self.mouse['end'])
- else:
- self.parent.gismanager.georectifying.SetGCPData(coordtype, coord, self)
- # digitization tool active
- pos1 = self.Pixel2Cell(self.mouse['begin'])
- pos2 = self.Pixel2Cell(self.mouse['end'])
- if hasattr(self, "vdigitMove"):
- if len(digitClass.driver.GetSelected()) == 0:
- self.vdigitMove['begin'] = pos1 # left down
- ### else:
- ### dx = pos2[0] - pos1[0] ### ???
- ### dy = pos2[1] - pos1[1]
- ### self.vdigitMove = (self.vdigitMove['begin'][0] + dx,
- ### self.vdigitMove['begin'][1] + dy)
- # eliminate initial mouse moving efect
- if digitToolbar.GetAction() in ["deleteLine", "moveLine", "moveVertex",
- "copyCats", "copyAttrs", "editLine", "flipLine",
- "mergeLine", "snapLine",
- "queryLine", "breakLine", "typeConv", "connectLine"]:
- nselected = 0
- # -> delete line || move line || move vertex
- nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
- if digitToolbar.GetAction() == "editLine":
- try:
- selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
- except IndexError:
- selVertex = None
- if selVertex:
- # self.UpdateMap(render=False)
- ids = digitClass.driver.GetSelected(grassId=False)
- # move this line to tmp layer
- for id in ids:
- if id % 2: # register only vertices
- e, n = self.Pixel2Cell(self.pdcVector.GetIdBounds(id)[0:2])
- self.polycoords.append((e, n))
- # self.pdcVector.RemoveId(id)
- digitClass.driver.DrawSelected(False)
- if selVertex < ids[-1] / 2:
- # choose first or last node of line
- self.vdigitMove['id'].reverse()
- self.polycoords.reverse()
- else:
- # unselect
- if not hasattr(self, "copyCatsIds"):
- # 'from' -> select by point
- nselected = digitClass.driver.SelectLineByPoint(pos1, digitClass.GetSelectType())
- if nselected:
- self.copyCatsList = digitClass.driver.GetSelected()
- else:
- # -> 'to' -> select by bbox
- # return number of selected features (by box/point)
- nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
- if nselected == 0:
- if digitClass.driver.SelectLineByPoint(pos1,
- nselected = 1
- if nselected > 0:
- self.copyCatsIds = digitClass.driver.GetSelected()
- elif digitToolbar.GetAction() == "queryLine":
- selected = digitClass.SelectLinesByQuery(pos1, pos2)
- nselected = len(selected)
- if nselected > 0:
- digitClass.driver.SetSelected(selected)
- else:
- # -> moveLine || deleteLine, etc. (select by point/box)
- if digitToolbar.GetAction() == 'moveLine' and \
- len(digitClass.driver.GetSelected()) > 0:
- nselected = 0
- else:
- drawSeg = True
- else:
- drawSeg = False
- digitClass.GetSelectType(),
- drawSeg)
- nselected = 1
- if nselected > 0:
- if digitToolbar.GetAction() in ["moveLine", "moveVertex"]:
- # get pseudoDC id of objects which should be redrawn
- if digitToolbar.GetAction() == "moveLine":
- # -> move line
- self.vdigitMove['id'] = digitClass.driver.GetSelected(grassId=False)
- self.vdigitMove['coord'] = digitClass.driver.GetSelectedCoord()
- elif digitToolbar.GetAction() == "moveVertex":
- # -> move vertex
- self.vdigitMove['id'] = digitClass.driver.GetSelectedVertex(pos1)
- if len(self.vdigitMove['id']) == 0: # no vertex found
- # check for duplicates
- if UserSettings.Get(group='vdigit', key='checkForDupl', subkey='enabled') is True:
- dupl = digitClass.driver.GetDuplicates()
- if dupl:
- posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
- self.mouse['end'][1] + self.dialogOffset))
- dlg = VDigitDuplicatesDialog(parent=self, data=dupl, pos=posWindow)
- if dlg.ShowModal() == wx.ID_OK:
- digitClass.driver.UnSelect(dlg.GetUnSelected())
- # update selected
- if digitToolbar.GetAction() != "editLine":
- # -> move line || move vertex
- else: # no vector object found
- if not (digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
- len(self.vdigitMove['id']) > 0):
- # avoid left-click when features are already selected
- elif digitToolbar.GetAction() in ["splitLine", "addVertex", "removeVertex"]:
- pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
- type=VDigit_Lines_Type)
- if pointOnLine:
- if digitToolbar.GetAction() in ["splitLine", "addVertex"]:
- self.UpdateMap(render=False) # highlight object
- self.DrawCross(pdc=self.pdcTmp, coords=self.Cell2Pixel(pointOnLine),
- size=5)
- elif digitToolbar.GetAction() == "removeVertex":
- # get only id of vertex
- try:
- id = digitClass.driver.GetSelectedVertex(pos1)[0]
- id = None
- if id:
- x, y = self.pdcVector.GetIdBounds(id)[0:2]
- self.pdcVector.RemoveId(id)
- self.DrawCross(pdc=self.pdcTmp, coords=(x, y),
- size=5)
- else:
- # unselect
- if UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True) == '':
- # no background map -> copy from current vector map layer
- if nselected > 0:
- # highlight selected features
- else:
- else:
- # copy features from background map
- self.copyIds = digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
- if len(self.copyIds) > 0:
- color = UserSettings.Get(group='vdigit', key='symbol',
- subkey=['highlight', 'color'])
- colorStr = str(color[0]) + ":" + \
- str(color[1]) + ":" + \
- str(color[2])
- dVectTmp = ['d.vect',
- 'map=%s' % UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True),
- 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
- '-i',
- 'color=%s' % colorStr,
- 'fcolor=%s' % colorStr,
- 'type=point,line,boundary,centroid',
- 'width=2']
- self.layerTmp = self.Map.AddLayer(type='vector',
- name=globalvar.QUERYLAYER,
- command=dVectTmp)
- self.UpdateMap(render=True, renderVector=False)
- else:
- self.redrawAll = None
- elif digitToolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
- # select lines to be labeled
- pos1 = self.polycoords[0]
- pos2 = self.polycoords[1]
- if nselected > 0:
- self.DrawLines(pdc=self.pdcTmp) # redraw temp line
- else:
- elif digitToolbar.GetAction() == "connectLine":
- if len(digitClass.driver.GetSelected()) > 0:
- self.dragid >= 0):
- # end drag of overlay decoration
- if self.dragid < 99 and self.overlays.has_key(self.dragid):
- self.overlays[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
- elif self.dragid > 100 and self.textdict.has_key(self.dragid):
- self.textdict[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
- else:
- pass
- self.dragid = None
-# self.UpdateMap(render=True)
- else:
- pass
-# event.Skip()
- def OnButtonDClick(self, event):
- Mouse button double click
- Debug.msg (5, "BufferedWindow.OnButtonDClick(): use=%s" % \
- # measure
- self.Refresh()
- elif self.mouse["use"] == "profile":
- # profile
- pass
- # self.pdc.ClearId(self.lineid)
- # self.pdc.ClearId(self.plineid)
- # print 'coordinates: ',self.polycoords
- # self.polycoords = []
- # self.mouse['begin'] = self.mouse['end'] = [0, 0]
- # self.Refresh()
- elif self.mouse['use'] == 'pointer' and self.parent.toolbars['vdigit']:
- pass
- else:
- # select overlay decoration options dialog
- clickposition = event.GetPositionTuple()[:]
- idlist = self.pdc.FindObjects(clickposition[0], clickposition[1], self.hitradius)
- if idlist == []:
- return
- # self.ovlcoords[self.dragid] = self.pdc.GetIdBounds(self.dragid)
- if self.dragid > 100:
- self.currtxtid = self.dragid
- self.parent.OnAddText(None)
- elif self.dragid == 0:
- self.parent.OnAddBarscale(None)
- elif self.dragid == 1:
- self.parent.OnAddLegend(None)
-# event.Skip()
- def OnRightDown(self, event):
- Right mouse button pressed
- Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
- if digitToolbar:
- # digitization tool (confirm action)
- if digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
- hasattr(self, "vdigitMove"):
- pFrom = self.vdigitMove['begin']
- pTo = self.Pixel2Cell(event.GetPositionTuple())
- move = (pTo[0] - pFrom[0],
- pTo[1] - pFrom[1])
- # move line
- if digitClass.MoveSelectedLines(move) < 0:
- return
- # move vertex
- if digitClass.MoveSelectedVertex(pFrom, move) < 0:
- return
- event.Skip()
- def OnRightUp(self, event):
- Right mouse button released
- Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
- if digitToolbar:
- if digitToolbar.GetAction() == "addLine" and \
- digitToolbar.GetAction('type') in ["line", "boundary"]:
- # -> add new line / boundary
- try:
- except:
- map = None
- if map:
- # mapcoords = []
- # xy -> EN
- # for coord in self.polycoords:
- # mapcoords.append(self.Pixel2Cell(coord))
- if digitToolbar.GetAction('type') == 'line':
- line = True
- else:
- line = False
- if len(self.polycoords) < 2: # ignore 'one-point' lines
- return
- fid = digitClass.AddLine(map, line, self.polycoords)
- if fid < 0:
- return
- position = self.Cell2Pixel(self.polycoords[-1])
- self.Refresh()
- cats = { fid : {
- cats=cats,
- pos=posWindow,
- action="add")
- "--q",
- # -> delete selected vector features
- if digitClass.DeleteSelectedLines() < 0:
- return
- # split line
- if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
- return
- elif digitToolbar.GetAction() == "addVertex":
- # add vertex
- if digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
- return
- # remove vertex
- if digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
- return
- try:
- if digitToolbar.GetAction() == 'copyCats':
- if digitClass.CopyCats(self.copyCatsList,
- self.copyCatsIds, copyAttrb=False) < 0:
- return
- else:
- self.copyCatsIds, copyAttrb=True) < 0:
- return
- del self.copyCatsList
- del self.copyCatsIds
- except AttributeError:
- pass
- elif digitToolbar.GetAction() == "editLine" and \
- line = digitClass.driver.GetSelected()
- if digitClass.EditLine(line, self.polycoords) < 0:
- return
- elif digitToolbar.GetAction() == "flipLine":
- if digitClass.FlipLine() < 0:
- return
- elif digitToolbar.GetAction() == "mergeLine":
- if digitClass.MergeLine() < 0:
- return
- elif digitToolbar.GetAction() == "breakLine":
- if digitClass.BreakLine() < 0:
- return
- elif digitToolbar.GetAction() == "snapLine":
- if digitClass.SnapLine() < 0:
- return
- if len(digitClass.driver.GetSelected()) > 1:
- if digitClass.ConnectLine() < 0:
- return
- if digitClass.CopyLine(self.copyIds) < 0:
- return
- del self.copyIds
- if self.layerTmp:
- self.Map.DeleteLayer(self.layerTmp)
- del self.layerTmp
- selected = digitClass.driver.GetSelected()
- dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
- nselected=len(selected))
- if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
- dlg.step.GetValue()) < 0:
- return
- self.UpdateMap(render=False, renderVector=True)
- elif digitToolbar.GetAction() == "typeConv":
- # -> feature type conversion
- # - point <-> centroid
- # - line <-> boundary
- if digitClass.TypeConvForSelectedLines() < 0:
- return
- if digitToolbar.GetAction() != "addLine":
- # unselect and re-render
- self.Refresh()
- event.Skip()
- def OnMiddleDown(self, event):
- Middle mouse button pressed
- if self.mouse["use"] == "pointer" and digitToolbar:
- if (digitToolbar.GetAction() == "addLine" and \
- digitToolbar.GetAction('type') in ["line", "boundary"]) or \
- digitToolbar.GetAction() == "editLine":
- # add line or boundary -> remove last point from the line
- try:
- removed = self.polycoords.pop()
- Debug.msg(4, "BufferedWindow.OnMiddleDown(): polycoords_poped=%s" % \
- [removed,])
- self.mouse['begin'] = self.Cell2Pixel(self.polycoords[-1])
- except:
- pass
- # remove last vertex & line
- if len(self.vdigitMove['id']) > 1:
- self.vdigitMove['id'].pop()
- elif digitToolbar.GetAction() in ["deleteLine", "moveLine", "splitLine",
- "addVertex", "removeVertex", "moveVertex",
- "copyCats", "flipLine", "mergeLine",
- "snapLine", "connectLine", "copyLine",
- "queryLine", "breakLine", "typeConv"]:
- # varios tools -> unselected selected features
- if digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
- elif digitToolbar.GetAction() == "copyCats":
- try:
- pass
- del self.copyIds
- if self.layerTmp:
- del self.layerTmp
- self.UpdateMap(render=False) # render vector
- # reset polyline
- def OnMouseMoving(self, event):
- Motion event and no mouse buttons were pressed
- Debug.msg (5, "BufferedWindow.OnMouseMoving(): coords=%f,%f" % \
- (self.mouse['end'][0], self.mouse['end'][1]))
- if digitToolbar.GetAction() == "addLine" and digitToolbar.GetAction('type') in ["line", "boundary"]:
- self.MouseDraw(pdc=self.pdcTmp, begin=self.Cell2Pixel(self.polycoords[-1]))
- elif digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] \
- and hasattr(self, "vdigitMove"):
- dx = self.mouse['end'][0] - self.mouse['begin'][0]
- dy = self.mouse['end'][1] - self.mouse['begin'][1]
- if len(self.vdigitMove['id']) > 0:
- # draw lines on new position
- # move line
- self.pdcTmp.TranslateId(id, dx, dy)
- elif digitToolbar.GetAction() in ["moveVertex", "editLine"]:
- # move vertex ->
- # (vertex, left vertex, left line,
- # right vertex, right line)
- # do not draw static lines
- if digitToolbar.GetAction() == "moveVertex":
- ### self.pdcTmp.TranslateId(self.vdigitMove['id'][0], dx, dy)
- self.pdcTmp.RemoveId(self.vdigitMove['id'][0])
- if self.vdigitMove['id'][1] > 0: # previous vertex
- x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][1])[0:2])
- self.pdcTmp.RemoveId(self.vdigitMove['id'][1]+1)
- self.polycoords.append((x, y))
- ### x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][0])[0:2])
- if self.vdigitMove['id'][2] > 0: # next vertex
- x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][2])[0:2])
- self.pdcTmp.RemoveId(self.vdigitMove['id'][2]-1)
- else: # edit line
- try:
- if self.vdigitMove['id'][-1] > 0: # previous vertex
- begin=self.Cell2Pixel(self.polycoords[-1]))
- except: # no line
- self.Refresh() # TODO: use RefreshRect()
- # draw mouse moving
- self.MouseDraw(self.pdcTmp)
- event.Skip()
- def ClearLines(self, pdc=None):
- Clears temporary drawn lines from PseudoDC
- if not pdc:
- pdc=self.pdcTmp
- try:
- pdc.RemoveId(self.lineid)
- except:
- pass
- try:
- pdc.ClearId(self.plineid)
- pdc.RemoveId(self.plineid)
- except:
- pass
- Debug.msg(4, "BufferedWindow.ClearLines(): lineid=%s, plineid=%s" %
- (self.lineid, self.plineid))
- return True
- def Pixel2Cell(self, (x, y)):
- Convert image coordinates to real word coordinates
- Input : int x, int y
- Output: float x, float y
- try:
- x = int(x)
- y = int(y)
- except:
- return None
- if self.Map.region["ewres"] > self.Map.region["nsres"]:
- res = self.Map.region["ewres"]
- else:
- res = self.Map.region["nsres"]
- w = self.Map.region["center_easting"] - (self.Map.width / 2) * res
- n = self.Map.region["center_northing"] + (self.Map.height / 2) * res
- east = w + x * res
- north = n - y * res
- # extent does not correspond with whole map canvas area...
- # east = self.Map.region['w'] + x * self.Map.region["ewres"]
- # north = self.Map.region['n'] - y * self.Map.region["nsres"]
- return (east, north)
- def Cell2Pixel(self, (east, north)):
- Convert real word coordinates to image coordinates
- try:
- east = float(east)
- north = float(north)
- except:
- return None
- else:
- # x = int((east - w) / res)
- # y = int((n - north) / res)
- x = (east - w) / res
- y = (n - north) / res
- return (x, y)
- def Zoom(self, begin, end, zoomtype):
- Calculates new region while (un)zoom/pan-ing
- x1, y1 = begin
- x2, y2 = end
- newreg = {}
- # threshold - too small squares do not make sense
- # can only zoom to windows of > 5x5 screen pixels
- if abs(x2-x1) > 5 and abs(y2-y1) > 5 and zoomtype != 0:
- if x1 > x2:
- x1, x2 = x2, x1
- if y1 > y2:
- y1, y2 = y2, y1
- # zoom in
- if zoomtype > 0:
- newreg['w'], newreg['n'] = self.Pixel2Cell((x1, y1))
- newreg['e'], newreg['s'] = self.Pixel2Cell((x2, y2))
- # zoom out
- elif zoomtype < 0:
- newreg['w'], newreg['n'] = self.Pixel2Cell((-x1 * 2, -y1 * 2))
- newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + 2 * \
- (self.Map.width - x2),
- self.Map.height + 2 * \
- (self.Map.height - y2)))
- # pan
- elif zoomtype == 0:
- dx = x1 - x2
- dy = y1 - y2
- newreg['w'], newreg['n'] = self.Pixel2Cell((dx, dy))
- newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + dx,
- self.Map.height + dy))
- # if new region has been calculated, set the values
- if newreg != {}:
- # LL locations
- if self.parent.Map.projinfo['proj'] == 'll':
- if newreg['n'] > 90.0:
- newreg['n'] = 90.0
- if newreg['s'] < -90.0:
- newreg['s'] = -90.0
- ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
- cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
- # xo = self.Cell2Pixel((self.Map.region['center_easting'], self.Map.region['center_northing']))
- # xn = self.Cell2Pixel(ce, cn))
- tmp = self.Pixel2Cell(self.mouse['end'])
- # calculate new center point and display resolution
- self.Map.region['center_easting'] = ce
- self.Map.region['center_northing'] = cn
- self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
- self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
- self.Map.AlignExtentFromDisplay()
- tmp1 = self.mouse['end']
- tmp2 = self.Cell2Pixel(self.vdigitMove['begin'])
- dx = tmp1[0] - tmp2[0]
- dy = tmp1[1] - tmp2[1]
- self.vdigitMove['beginDiff'] = (dx, dy)
- self.pdcTmp.RemoveId(id)
- self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
- self.Map.region['e'], self.Map.region['w'])
- if self.redrawAll is False:
- def ZoomBack(self):
- Zoom to previous extents in zoomhistory list
- zoom = []
- if len(self.zoomhistory) > 1:
- self.zoomhistory.pop()
- zoom = self.zoomhistory[len(self.zoomhistory)-1]
- # (n, s, e, w)
- if zoom:
- # zoom to selected region
- self.Map.region['center_easting'] = zoom[3] + \
- (zoom[2] - zoom[3]) / 2
- self.Map.region['center_northing'] = zoom[1] + \
- (zoom[0] - zoom[1]) / 2
- self.Map.region["ewres"] = (zoom[2] - zoom[3]) / self.Map.width
- self.Map.region["nsres"] = (zoom[0] - zoom[1]) / self.Map.height
- # update map
- self.UpdateMap()
- def ZoomHistory(self, n, s, e, w):
- Manages a list of last 10 zoom extents
- Return removed history item if exists
- removed = None
- self.zoomhistory.append((n,s,e,w))
- if len(self.zoomhistory) > 10:
- removed = self.zoomhistory.pop(0)
- if removed:
- Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s, removed=%s" %
- (self.zoomhistory, removed))
- else:
- Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s" %
- (self.zoomhistory))
- return removed
- Set display extents to match selected raster (including NULLs)
- or vector map.
- self.ZoomToMap()
- Set display extents to match selected raster map (ignore NULLs)
- self.ZoomToMap(zoom=True)
- def ZoomToMap(self, layer = None, zoom = False):
- or vector map.
- zoomreg = {}
- if not layer:
- layer = self.GetSelectedLayer(multi = True)
- if not layer:
- return
- rast = []
- vect = []
- updated = False
- for l in layer:
- # only raster/vector layers are currently supported
- if l.type == 'raster':
- rast.append(l.name)
- elif l.type == 'vector':
- if self.parent.digit and l.name == self.parent.digit.map and \
- self.parent.digit.type == 'vdigit':
- w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
- self.Map.GetRegion(n=n, s=s, w=w, e=e,
- update=True)
- updated = True
- else:
- vect.append(l.name)
- if not updated:
- self.Map.GetRegion(rast = rast,
- vect = vect,
- update = True)
- self.UpdateMap()
- def ZoomToWind(self, event):
- Set display geometry to match computational
- region settings (set with g.region)
- self.Map.region = self.Map.GetRegion()
- ### self.Map.SetRegion(windres=True)
- self.UpdateMap()
- def ZoomToDefault(self, event):
- Set display geometry to match default region settings
- self.Map.region = self.Map.GetRegion(default=True)
- self.Map.AdjustRegion() # aling region extent to the display
- self.UpdateMap()
- def DisplayToWind(self, event):
- Set computational region (WIND file) to
- match display extents
- tmpreg = os.getenv("GRASS_REGION")
- if tmpreg:
- del os.environ["GRASS_REGION"]
- # We ONLY want to set extents here. Don't mess with resolution. Leave that
- # for user to set explicitly with g.region
- new = self.Map.AlignResolution()
- cmdRegion = ["g.region", "--o",
- "n=%f" % new['n'],
- "s=%f" % new['s'],
- "e=%f" % new['e'],
- "w=%f" % new['w'],
- "rows=%d" % int(new['rows']),
- "cols=%d" % int(new['cols'])]
- p = gcmd.Command(cmdRegion)
- if tmpreg:
- os.environ["GRASS_REGION"] = tmpreg
- def ZoomToSaved(self, event):
- """!Set display geometry to match extents in
- saved region file
- dlg = gdialogs.SavedRegion(parent = self, id = wx.ID_ANY,
- title = _("Zoom to saved region extents"),
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_DIALOG_STYLE,
- loadsave='load')
- if dlg.ShowModal() == wx.ID_CANCEL:
- dlg.Destroy()
- return
- wind = dlg.wind
- self.Map.GetRegion(regionName = wind,
- update = True)
- dlg.Destroy()
- self.Map.region['s'],
- self.Map.region['w'])
- self.UpdateMap()
- def SaveDisplayRegion(self, event):
- Save display extents to named region file.
- title = _("Save display extents to region file"),
- loadsave='save')
- dlg.Destroy()
- return
- wind = dlg.wind
- # test to see if it already exists and ask permission to overwrite
- windpath = os.path.join(self.Map.env["GISDBASE"], self.Map.env["LOCATION_NAME"],
- self.Map.env["MAPSET"], "windows", wind)
- if windpath and not os.path.exists(windpath):
- self.SaveRegion(wind)
- elif windpath and os.path.exists(windpath):
- overwrite = wx.MessageBox(_("Region file <%s> already exists. "
- "Do you want to overwrite it?") % (wind),
- _("Warning"), wx.YES_NO | wx.CENTRE)
- if (overwrite == wx.YES):
- else:
- pass
- dlg.Destroy()
- def SaveRegion(self, wind):
- Save region settings
- ### new = self.Map.AlignResolution()
- new = self.Map.GetCurrentRegion()
- "-u",
- "rows=%d" % new['rows'],
- "cols=%d" % new['cols'],
- "save=%s" % wind,
- "--o"]
- if tmpreg:
- if tmpreg:
- def Distance(self, beginpt, endpt, screen=True):
- """Calculete distance
- LL-locations not supported
- @todo Use m.distance
- @param beginpt first point
- @param endpt second point
- @param screen True for screen coordinates otherwise EN
- x1, y1 = beginpt
- x2, y2 = endpt
- if screen:
- dEast = (x2 - x1) * self.Map.region["ewres"]
- dNorth = (y2 - y1) * self.Map.region["nsres"]
- else:
- dEast = (x2 - x1)
- return (math.sqrt(math.pow((dEast),2) + math.pow((dNorth),2)), (dEast, dNorth))
-class MapFrame(wx.Frame):
- Main frame for map display window. Drawing takes place in child double buffered
- drawing window.
- def __init__(self, parent=None, id=wx.ID_ANY, title=_("GRASS GIS - Map display"),
- style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
- tree=None, notebook=None, gismgr=None, page=None,
- Map=None, auimgr=None):
- Main map display window with toolbars, statusbar and
- DrawWindow
- @param toolbars array of activated toolbars, e.g. ['map', 'digit']
- @param tree reference to layer tree
- @param notebook control book ID in Layer Manager
- @param gismgr Layer Manager panel
- @param page notebook page with layer tree
- @param Map instance of render.Map
- self.gismanager = gismgr # GIS Manager object
- self.Map = Map # instance of render.Map
- self.tree = tree # GIS Manager layer tree object
- self.page = page # Notebook page holding the layer tree
- self.layerbook = notebook # GIS Manager layer tree notebook
- # available cursors
- self.cursors = {
- # default: cross
- # "default" : wx.StockCursor(wx.CURSOR_DEFAULT),
- "default" : wx.StockCursor(wx.CURSOR_ARROW),
- "cross" : wx.StockCursor(wx.CURSOR_CROSS),
- "hand" : wx.StockCursor(wx.CURSOR_HAND),
- "pencil" : wx.StockCursor(wx.CURSOR_PENCIL),
- "sizenwse": wx.StockCursor(wx.CURSOR_SIZENWSE)
- wx.Frame.__init__(self, parent, id, title, pos, size, style)
- self.SetName("MapWindow")
- # set the size & system icon
- self.SetClientSize(size)
- self.iconsize = (16, 16)
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
- # Fancy gui
- # self._mgr = auimgr
- self._mgr = wx.aui.AuiManager(self)
- # Add toolbars
- self.toolbars = { 'map' : None,
- 'vdigit' : None,
- 'georect' : None,
- 'nviz' : None }
- for toolb in toolbars:
- self.AddToolbar(toolb)
- # Add statusbar
- self.statusbar = self.CreateStatusBar(number=4, style=0)
- self.statusbar.SetStatusWidths([-5, -2, -1, -1])
- self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
- choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
- self.toggleStatus.SetSelection(UserSettings.Get(group='display', key='statusbarMode', subkey='selection'))
- self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.toggleStatus)
- # auto-rendering checkbox
- self.autoRender = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Render"))
- self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.autoRender)
- self.autoRender.SetValue(UserSettings.Get(group='display', key='autoRendering', subkey='enabled'))
- self.autoRender.SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
- # show region
- self.showRegion = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Show computational extent"))
- self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.showRegion)
- self.showRegion.SetValue(False)
- self.showRegion.Hide()
- self.showRegion.SetToolTip(wx.ToolTip (_("Show/hide computational "
- "region extent (set with g.region). "
- "Display region drawn as a blue box inside the "
- "computational region, "
- "computational region inside a display region "
- "as a red box).")))
- # set resolution
- self.compResolution = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Constrain display resolution to computational settings"))
- self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.compResolution)
- self.compResolution.SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
- self.compResolution.Hide()
- self.compResolution.SetToolTip(wx.ToolTip (_("Constrain display resolution "
- "to computational region settings. "
- "Default value for new map displays can "
- "be set up in 'User GUI settings' dialog.")))
- # map scale
- self.mapScale = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
- value="", style=wx.TE_PROCESS_ENTER,
- size=(150, -1))
- self.mapScale.Hide()
- self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.mapScale)
- # mask
- self.maskInfo = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
- label = '')
- self.maskInfo.SetForegroundColour(wx.Colour(255, 0, 0))
- # on-render gauge
- self.onRenderGauge = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
- range=0, style=wx.GA_HORIZONTAL)
- self.onRenderGauge.Hide()
- self.StatusbarReposition() # reposition statusbar
- # Init map display (buffered DC & set default cursor)
- self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,
- Map=self.Map, tree=self.tree, gismgr=self.gismanager)
- # default is 2D display mode
- self.MapWindow = self.MapWindow2D
- self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
- self.MapWindow.SetCursor(self.cursors["default"])
- # used by Nviz (3D display mode)
- self.MapWindow3D = None
- # initialize region values
- self.__InitDisplay()
- # Bind various events
- self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
- self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
- self.Bind(render.EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
- # Update fancy gui style
- self._mgr.AddPane(self.MapWindow, wx.aui.AuiPaneInfo().CentrePane().
- Dockable(False).BestSize((-1,-1)).
- CloseButton(False).DestroyOnClose(True).
- Layer(0))
- self._mgr.Update()
- # Init print module and classes
- self.printopt = disp_print.PrintOptions(self, self.MapWindow)
- # Initialization of digitization tool
- self.digit = None
- # Init zoom history
- self.MapWindow.ZoomHistory(self.Map.region['n'],
- # Re-use dialogs
- self.dialogs = {}
- self.dialogs['attributes'] = None
- self.dialogs['category'] = None
- self.dialogs['barscale'] = None
- self.dialogs['legend'] = None
- self.decorationDialog = None # decoration/overlays
- def AddToolbar(self, name):
- Add defined toolbar to the window
- Currently known toolbars are:
- - map basic map toolbar
- - digit vector digitizer
- - georect georectifier
- # default toolbar
- if name == "map":
- self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
- self._mgr.AddPane(self.toolbars['map'].toolbar,
- wx.aui.AuiPaneInfo().
- Name("maptoolbar").Caption(_("Map Toolbar")).
- ToolbarPane().Top().
- LeftDockable(False).RightDockable(False).
- BottomDockable(False).TopDockable(True).
- CloseButton(False).Layer(2).
- BestSize((self.toolbars['map'].GetToolbar().GetSize())))
- # vector digitizer
- elif name == "vdigit":
- from vdigit import haveVDigit
- if not haveVDigit:
- from vdigit import errorMsg
- msg = _("Unable to start vector digitizer.\nThe VDigit python extension "
- "was not found or loaded properly.\n"
- "Switching back to 2D display mode.\n\nDetails: %s" % errorMsg)
- self.toolbars['map'].combo.SetValue (_("2D view"))
- message=msg,
- style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- return
- self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, map=self.Map,
- layerTree=self.tree,
- log=self.gismanager.goutput)
- for toolRow in range(0, self.toolbars['vdigit'].numOfRows):
- self._mgr.AddPane(self.toolbars['vdigit'].toolbar[toolRow],
- Name("vdigittoolbar" + str(toolRow)).Caption(_("Vector digitizer toolbar")).
- ToolbarPane().Top().Row(toolRow + 1).
- BestSize((self.toolbars['vdigit'].GetToolbar().GetSize())))
- # change mouse to draw digitized line
- self.MapWindow.mouse['box'] = "point"
- self.MapWindow.zoomtype = 0
- self.MapWindow.pen = wx.Pen(colour='red', width=2, style=wx.SOLID)
- self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SOLID)
- # georectifier
- elif name == "georect":
- self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
- self._mgr.AddPane(self.toolbars['georect'].toolbar,
- Name("georecttoolbar").Caption(_("Georectification toolbar")).
- CloseButton(False).Layer(2))
- # nviz
- elif name == "nviz":
- import nviz
- # check for GLCanvas and OpenGL
- msg = None
- if not nviz.haveGLCanvas:
- msg = _("Unable to switch to 3D display mode.\nThe GLCanvas class has not been "
- "included with this build "
- "of wxPython!\nSwitching back to "
- "2D display mode.\n\nDetails: %s" % nviz.errorMsg)
- if not nviz.haveNviz:
- msg = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
- "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg)
- if msg:
- message=msg,
- return
- # add Nviz toolbar and disable 2D display mode tools
- self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
- self.toolbars['map'].Enable2D(False)
- # update layer tree (-> enable 3d-rasters)
- self.tree.EnableItemType(type='3d-raster', enable=True)
- # update status bar
- self.toggleStatus.Enable(False)
- # erase map window
- self.MapWindow.EraseMap()
- busy = wx.BusyInfo(message=_("Please wait, loading data..."),
- parent=self)
- wx.Yield()
- # create GL window & NVIZ toolbar
- if not self.MapWindow3D:
- self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY,
- self.nvizToolWin = nviz.NvizToolWindow(self, id=wx.ID_ANY,
- mapWindow=self.MapWindow3D)
- self.MapWindow3D.OnPaint(None) # -> LoadData
- self.MapWindow3D.Show()
- self.MapWindow3D.UpdateView(None)
- busy.Destroy()
- self.nvizToolWin.Show()
- # switch from MapWindow to MapWindowGL
- # add nviz toolbar
- self._mgr.DetachPane(self.MapWindow2D)
- self.MapWindow2D.Hide()
- self._mgr.AddPane(self.MapWindow3D, wx.aui.AuiPaneInfo().CentrePane().
- Layer(0))
- self._mgr.AddPane(self.toolbars['nviz'].toolbar,
- Name("nviztoolbar").Caption(_("Nviz toolbar")).
- ToolbarPane().Top().Row(1).
- self.MapWindow = self.MapWindow3D
- self.SetStatusText("", 0)
- def RemoveToolbar (self, name):
- Removes toolbar from the window
- TODO: Only hide, activate by calling AddToolbar()
- # cannot hide main toolbar
- if name == "map":
- return
- # TODO: not destroy only hide
- self._mgr.DetachPane (self.toolbars['vdigit'].toolbar[toolRow])
- self.toolbars['vdigit'].toolbar[toolRow].Destroy()
- else:
- self._mgr.DetachPane (self.toolbars[name].toolbar)
- self.toolbars[name].toolbar.Destroy()
- self.toolbars[name] = None
- if name == 'nviz':
- # hide nviz tools
- self.nvizToolWin.Hide()
- # unload data
-# self.MapWindow3D.Reset()
- # switch from MapWindowGL to MapWindow
- self._mgr.DetachPane(self.MapWindow3D)
- self.MapWindow3D.Hide()
- self.MapWindow2D.Show()
- self._mgr.AddPane(self.MapWindow2D, wx.aui.AuiPaneInfo().CentrePane().
- Layer(0))
- # update layer tree (-> disable 3d-rasters)
- self.tree.EnableItemType(type='3d-raster', enable=False)
- self.MapWindow.UpdateMap()
- self.toolbars['map'].Enable2D(True)
- self.toggleStatus.Enable(True)
- def __InitDisplay(self):
- Initialize map display, set dimensions and map region
- self.width, self.height = self.GetClientSize()
- Debug.msg(2, "MapFrame.__InitDisplay():")
- self.Map.region = self.Map.GetRegion() # g.region -upgc
- # self.Map.SetRegion() # adjust region to match display window
- def OnUpdateProgress(self, event):
- Update progress bar info
- self.onRenderGauge.SetValue(event.value)
- event.Skip()
- def OnFocus(self, event):
- Change choicebook page to match display.
- Or set display for georectifying
- # in georectifying session; display used to get get geographic
- # coordinates for GCPs
- self.OnPointer(event)
- else:
- # change bookcontrol page to page associated with display
- if self.page:
- pgnum = self.layerbook.GetPageIndex(self.page)
- if pgnum > -1:
- self.layerbook.SetSelection(pgnum)
- event.Skip()
- def OnMotion(self, event):
- Mouse moved
- Track mouse motion and update status bar
- # update statusbar if required
- if self.toggleStatus.GetSelection() == 0: # Coordinates
- e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
- if self.toolbars['vdigit'] and \
- self.toolbars['vdigit'].GetAction() == 'addLine' and \
- self.toolbars['vdigit'].GetAction('type') in ('line', 'boundary') and \
- len(self.MapWindow.polycoords) > 0:
- # for linear feature show segment and total length
- distance_seg = self.MapWindow.Distance(self.MapWindow.polycoords[-1],
- (e, n), screen=False)[0]
- distance_tot = distance_seg
- for idx in range(1, len(self.MapWindow.polycoords)):
- distance_tot += self.MapWindow.Distance(self.MapWindow.polycoords[idx-1],
- self.MapWindow.polycoords[idx],
- screen=False )[0]
- self.statusbar.SetStatusText("%.2f, %.2f (seg: %.2f; tot: %.2f)" % \
- (e, n, distance_seg, distance_tot), 0)
- else:
- if self.Map.projinfo['proj'] == 'll':
- self.statusbar.SetStatusText("%s" % utils.Deg2DMS(e, n), 0)
- else:
- self.statusbar.SetStatusText("%.2f, %.2f" % (e, n), 0)
- event.Skip()
- def OnDraw(self, event):
- Re-display current map composition
- self.MapWindow.UpdateMap(render=False)
- def OnRender(self, event):
- Re-render map composition (each map layer)
- # delete tmp map layers (queries)
- qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
- for layer in qlayer:
- self.Map.DeleteLayer(layer)
- # delete tmp lines
- if self.MapWindow.mouse["use"] in ["measure", "profile"]:
- self.MapWindow.polycoords = []
- self.MapWindow.ClearLines()
- # deselect features in vdigit
- if self.toolbars['vdigit'] and self.digit:
- self.digit.driver.SetSelected([])
- self.MapWindow.UpdateMap(render=True, renderVector=True)
- else:
- self.MapWindow.UpdateMap(render=True)
- self.StatusbarUpdate()
- def OnPointer(self, event):
- Pointer button clicked
- if self.toolbars['map']:
- if event:
- self.toolbars['map'].OnTool(event)
- self.toolbars['map'].action['desc'] = ''
- self.MapWindow.mouse['use'] = "pointer"
- # change the cursor
- if self.toolbars['vdigit']:
- # digitization tool activated
- self.MapWindow.SetCursor(self.cursors["cross"])
- # reset mouse['box'] if needed
- if self.toolbars['vdigit'].GetAction() in ['addLine']:
- if self.toolbars['vdigit'].GetAction('type') in ['point', 'centroid']:
- self.MapWindow.mouse['box'] = 'point'
- else: # line, boundary
- self.MapWindow.mouse['box'] = 'line'
- elif self.toolbars['vdigit'].GetAction() in ['addVertex', 'removeVertex', 'splitLine',
- 'editLine', 'displayCats', 'displayAttrs',
- 'copyCats']:
- else: # moveLine, deleteLine
- self.MapWindow.mouse['box'] = 'box'
- elif self.gismanager.georectifying:
- else:
- def OnZoomIn(self, event):
- Zoom in the map.
- Set mouse cursor, zoombox attributes, and zoom direction
- self.MapWindow.mouse['use'] = "zoom"
- self.MapWindow.mouse['box'] = "box"
- self.MapWindow.zoomtype = 1
- self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
- def OnZoomOut(self, event):
- Zoom out the map.
- self.MapWindow.zoomtype = -1
- def OnZoomBack(self, event):
- Zoom last (previously stored position)
- self.MapWindow.ZoomBack()
- def OnPan(self, event):
- Panning, set mouse to drag
- self.MapWindow.mouse['use'] = "pan"
- self.MapWindow.mouse['box'] = "pan"
- self.MapWindow.SetCursor(self.cursors["hand"])
- def OnErase(self, event):
- Erase the canvas
- def OnZoomRegion(self, event):
- Zoom to region
- self.Map.getRegion()
- self.Map.getResolution()
- self.UpdateMap()
- # event.Skip()
- def OnAlignRegion(self, event):
- Align region
- if not self.Map.alignRegion:
- self.Map.alignRegion = True
- else:
- self.Map.alignRegion = False
- # event.Skip()
- def OnToggleRender(self, event):
- Enable/disable auto-rendering
- if self.autoRender.GetValue():
- self.OnRender(None)
- def OnToggleShowRegion(self, event):
- Show/Hide extent in map canvas
- if self.showRegion.GetValue():
- # show extent
- self.MapWindow.regionCoords = []
- else:
- del self.MapWindow.regionCoords
- # redraw map if auto-rendering is enabled
- def OnToggleResolution(self, event):
- Use resolution of computation region settings
- for redering image instead of display resolution
- def OnToggleStatus(self, event):
- Toggle status text
- def OnChangeMapScale(self, event):
- Map scale changed by user
- scale = event.GetString()
- try:
- if scale[:2] != '1:':
- raise ValueError
- value = int(scale[2:])
- except ValueError:
- self.mapScale.SetValue('1:%ld' % int(self.mapScaleValue))
- return
- dEW = value * (self.Map.region['cols'] / self.ppm[0])
- dNS = value * (self.Map.region['rows'] / self.ppm[1])
- self.Map.region['n'] = self.Map.region['center_northing'] + dNS / 2.
- self.Map.region['s'] = self.Map.region['center_northing'] - dNS / 2.
- self.Map.region['w'] = self.Map.region['center_easting'] - dEW / 2.
- self.Map.region['e'] = self.Map.region['center_easting'] + dEW / 2.
- # add to zoom history
- self.MapWindow.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
- # redraw a map
- self.mapScale.SetFocus()
- def StatusbarUpdate(self):
- """Update statusbar content"""
- self.mapScaleValue = self.ppm = None
- self.statusbar.SetStatusText("", 0)
- # enable long help
- self.StatusbarEnableLongHelp()
- elif self.toggleStatus.GetSelection() == 1: # Extent
- self.statusbar.SetStatusText("%.2f - %.2f, %.2f - %.2f" %
- (self.Map.region["w"], self.Map.region["e"],
- self.Map.region["s"], self.Map.region["n"]), 0)
- elif self.toggleStatus.GetSelection() == 2: # Comp. region
- compregion = self.Map.GetRegion()
- self.statusbar.SetStatusText("%.2f - %.2f, %.2f - %.2f (%.2f, %.2f)" %
- (compregion["w"], compregion["e"],
- compregion["s"], compregion["n"],
- compregion["ewres"], compregion["nsres"]), 0)
- elif self.toggleStatus.GetSelection() == 3: # Show comp. extent
- self.showRegion.Show()
- # disable long help
- self.StatusbarEnableLongHelp(False)
- elif self.toggleStatus.GetSelection() == 4: # Display mode
- self.compResolution.Show()
- elif self.toggleStatus.GetSelection() == 5: # Display geometry
- self.statusbar.SetStatusText("rows=%d; cols=%d; nsres=%.2f; ewres=%.2f" %
- (self.Map.region["rows"], self.Map.region["cols"],
- self.Map.region["nsres"], self.Map.region["ewres"]), 0)
- elif self.toggleStatus.GetSelection() == 6: # Map scale
- # TODO: need to be fixed...
- ### screen X region problem
- ### user should specify ppm
- dc = wx.ScreenDC()
- dpSizePx = wx.DisplaySize() # display size in pixels
- dpSizeMM = wx.DisplaySizeMM() # display size in mm (system)
- dpSizeIn = (dpSizeMM[0] / 25.4, dpSizeMM[1] / 25.4) # inches
- sysPpi = dc.GetPPI()
- comPpi = (dpSizePx[0] / dpSizeIn[0],
- dpSizePx[1] / dpSizeIn[1])
- ppi = comPpi # pixel per inch
- self.ppm = ((ppi[0] / 2.54) * 100, # pixel per meter
- (ppi[1] / 2.54) * 100)
- Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): size: px=%d,%d mm=%f,%f "
- "in=%f,%f ppi: sys=%d,%d com=%d,%d; ppm=%f,%f" % \
- (dpSizePx[0], dpSizePx[1], dpSizeMM[0], dpSizeMM[1],
- dpSizeIn[0], dpSizeIn[1],
- sysPpi[0], sysPpi[1], comPpi[0], comPpi[1],
- self.ppm[0], self.ppm[1]))
- region = self.Map.region
- heightCm = region['rows'] / self.ppm[1] * 100
- widthCm = region['cols'] / self.ppm[0] * 100
- Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): width_cm=%f, height_cm=%f" %
- (widthCm, heightCm))
- xscale = (region['e'] - region['w']) / (region['cols'] / self.ppm[0])
- yscale = (region['n'] - region['s']) / (region['rows'] / self.ppm[1])
- scale = (xscale + yscale) / 2.
- Debug.msg(3, "MapFrame.StatusbarUpdate(mapscale): xscale=%f, yscale=%f -> scale=%f" % \
- (xscale, yscale, scale))
- self.statusbar.SetStatusText("")
- try:
- self.mapScale.SetValue("1:%ld" % (scale + 0.5))
- except TypeError:
- pass
- self.mapScaleValue = scale
- self.mapScale.Show()
- else:
- self.statusbar.SetStatusText("", 1)
- def StatusbarEnableLongHelp(self, enable=True):
- """Enable/disable toolbars long help"""
- for toolbar in self.toolbars.itervalues():
- if toolbar:
- toolbar.EnableLongHelp(enable)
- def StatusbarReposition(self):
- """Reposition checkbox in statusbar"""
- # reposition checkbox
- widgets = [(0, self.showRegion),
- (0, self.compResolution),
- (0, self.mapScale),
- (0, self.onRenderGauge),
- (1, self.toggleStatus),
- (2, self.maskInfo),
- (3, self.autoRender)]
- for idx, win in widgets:
- rect = self.statusbar.GetFieldRect(idx)
- if idx == 0: # show region / mapscale / process bar
- # -> size
- wWin, hWin = win.GetBestSize()
- if win == self.onRenderGauge:
- wWin = rect.width - 6
- # -> position
- # if win == self.showRegion:
- # x, y = rect.x + rect.width - wWin, rect.y - 1
- # align left
- # else:
- x, y = rect.x + 3, rect.y - 1
- w, h = wWin, rect.height + 2
- else: # choice || auto-rendering
- x, y = rect.x, rect.y - 1
- w, h = rect.width, rect.height + 2
- if idx == 2: # mask
- x += 5
- y += 4
- elif idx == 3: # render
- x += 5
- win.SetPosition((x, y))
- win.SetSize((w, h))
- def SaveToFile(self, event):
- Save image to file
- filetype = "PNG file (*.png)|*.png|"\
- "TIF file (*.tif)|*.tif|"\
- "GIF file (*.gif)|*.gif"
- dlg = wx.FileDialog(self, "Choose a file name to save the image as a PNG to",
- defaultDir = "",
- defaultFile = "",
- wildcard = filetype,
- style=wx.SAVE|wx.FD_OVERWRITE_PROMPT)
- base = os.path.splitext(dlg.GetPath())[0]
- ext = os.path.splitext(dlg.GetPath())[1]
- if dlg.GetFilterIndex() == 0:
- type = wx.BITMAP_TYPE_PNG
- path = dlg.GetPath()
- if ext != '.png': path = base+'.png'
- elif dlg.GetFilterIndex() == 1:
- type = wx.BITMAP_TYPE_TIF
- if ext != '.tif': path = base+'.tif'
- elif dlg.GetFilterIndex() == 2:
- if ext != '.gif': path = base+'.gif'
- self.MapWindow.SaveToFile(path, type)
- dlg.Destroy()
- def PrintMenu(self, event):
- Print options and output menu for map display
- point = wx.GetMousePosition()
- printmenu = wx.Menu()
- # Add items to the menu
- setup = wx.MenuItem(printmenu, wx.ID_ANY, _('Page setup'))
- printmenu.AppendItem(setup)
- self.Bind(wx.EVT_MENU, self.printopt.OnPageSetup, setup)
- preview = wx.MenuItem(printmenu, wx.ID_ANY, _('Print preview'))
- printmenu.AppendItem(preview)
- self.Bind(wx.EVT_MENU, self.printopt.OnPrintPreview, preview)
- doprint = wx.MenuItem(printmenu, wx.ID_ANY, _('Print display'))
- printmenu.AppendItem(doprint)
- self.Bind(wx.EVT_MENU, self.printopt.OnDoPrint, doprint)
- # Popup the menu. If an item is selected then its handler
- # will be called before PopupMenu returns.
- self.PopupMenu(printmenu)
- printmenu.Destroy()
- def OnCloseWindow(self, event):
- Window closed.
- Also close associated layer tree page
- pgnum = None
- self.Map.Clean()
- # close edited map and 3D tools properly
- maplayer = self.toolbars['vdigit'].GetLayer()
- if maplayer:
- self.toolbars['vdigit'].OnExit()
- self.imgVectorMap = None
- if self.toolbars['nviz']:
- self.toolbars['nviz'].OnExit()
- if self.page:
- if pgnum > -1:
- self.layerbook.DeletePage(pgnum)
- ### self.Destroy()
- # if event:
- # event.Skip() <- causes application crash
- def GetRender(self):
- Returns the current instance of render.Map()
- return self.Map
- def OnQueryDisplay(self, event):
- Query currrent raster/vector map layers (display mode)
- if self.toolbars['map'].GetAction() == 'displayAttrb': # select previous action
- self.toolbars['map'].SelectDefault(event)
- return
- self.toolbars['map'].action['desc'] = 'displayAttrb'
- # switch GIS Manager to output console to show query results
- self.gismanager.notebook.SetSelection(1)
- self.MapWindow.mouse['use'] = "query"
- def OnQueryModify(self, event):
- Query vector map layer (edit mode)
- if self.toolbars['map'].GetAction() == 'modifyAttrb': # select previous action
- return
- self.toolbars['map'].action['desc'] = 'modifyAttrb'
- self.MapWindow.mouse['use'] = "queryVector"
- def QueryMap(self, x, y):
- """!Query map layer features
- Currently only raster and vector map layers are supported.
- @param x,y coordinates
- #set query snap distance for v.what at mapunit equivalent of 10 pixels
- qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
- east, north = self.MapWindow.Pixel2Cell((x, y))
- num = 0
- for layer in self.tree.GetSelections():
- type = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
- if type in ('raster', 'rgb', 'his',
- 'vector', 'thememap', 'themechart'):
- num += 1
- if num < 1:
- dlg = wx.MessageDialog(parent=self,
- message=_('No raster or vector map layer selected for querying.'),
- caption=_('No map layer selected'),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
- dlg.ShowModal()
- dlg.Destroy()
- return
- mapname = None
- raststr = ''
- vectstr = ''
- rcmd = []
- vcmd = []
- dcmd = self.tree.GetPyData(layer)[0]['cmd']
- name = utils.GetLayerNameFromCmd(dcmd)
- if name == '':
- continue
- if type in ('raster', 'rgb', 'his'):
- raststr += "%s," % name
- elif type in ('vector', 'thememap', 'themechart'):
- vectstr += "%s," % name
- # use display region settings instead of computation region settings
- self.tmpreg = os.getenv("GRASS_REGION")
- os.environ["GRASS_REGION"] = self.Map.SetRegion(windres=False)
- # build query commands for any selected rasters and vectors
- if raststr != '':
- rcmd = ['r.what', '--q',
- '-f',
- 'input=%s' % raststr.rstrip(','),
- 'east_north=%f,%f' % (float(east), float(north))]
- if vectstr != '':
- # check for vector maps open to be edited
- digitToolbar = self.toolbars['vdigit']
- if digitToolbar:
- vect = []
- for vector in vectstr.split(','):
- if map == vector:
- self.gismanager.goutput.WriteWarning("Vector map <%s> "
- "opened for editing - skipped." % map)
- continue
- vect.append(vector)
- vectstr = ','.join(vect)
- if len(vectstr) <= 1:
- self.gismanager.goutput.WriteCmdLog("Nothing to query.")
- return
- vcmd = ['v.what', '--q',
- '-a',
- 'map=%s' % vectstr.rstrip(','),
- 'east_north=%f,%f' % (float(east), float(north)),
- 'distance=%f' % qdist]
- # parse query command(s)
- if self.gismanager:
- if rcmd:
- self.gismanager.goutput.RunCmd(rcmd, compReg=False,
- onDone = self._QueryMapDone)
- if vcmd:
- self.gismanager.goutput.RunCmd(vcmd,
- else:
- if rcmd:
- gcmd.Command(rcmd)
- if vcmd:
- gcmd.Command(vcmd)
- def _QueryMapDone(self, returncode):
- """!Restore settings after querying (restore GRASS_REGION)
- @param returncode command return code
- if hasattr(self, "tmpreg"):
- if self.tmpreg:
- os.environ["GRASS_REGION"] = self.tmpreg
- elif os.environ.has_key('GRASS_REGION'):
- del self.tmpreg
- def QueryVector(self, x, y):
- Query vector map layer features
- Attribute data of selected vector object are displayed in GUI dialog.
- Data can be modified (On Submit)
- if not self.tree.layer_selected or \
- self.tree.GetPyData(self.tree.layer_selected)[0]['type'] != 'vector':
- message=_("No vector map selected for querying."),
- caption=_("Vector querying"),
- return
- if self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetMapset() != \
- grass.gisenv()['MAPSET']:
- message=_("Only vector map from the current mapset can be modified."),
- return
- posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
- y + self.MapWindow.dialogOffset))
- qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / \
- self.Map.width)
- mapName = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name
- if self.dialogs['attributes'] is None:
- self.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self.MapWindow,
- map=mapName,
- query=((east, north), qdist),
- pos=posWindow,
- action="update")
- else:
- # selection changed?
- if not self.dialogs['attributes'].mapDBInfo or \
- self.dialogs['attributes'].mapDBInfo.map != mapName:
- self.dialogs['attributes'].UpdateDialog(map=mapName, query=((east, north), qdist))
- else:
- self.dialogs['attributes'].UpdateDialog(query=((east, north), qdist))
- cats = self.dialogs['attributes'].GetCats()
- try:
- qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)[0]
- qlayer = None
- if self.dialogs['attributes'].mapDBInfo and cats:
- if qlayer:
- qlayer.SetCmd(self.AddTmpVectorMapLayer(mapName, cats,
- useId=False,
- addLayer=False))
- else:
- qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId=False)
- # set opacity based on queried layer
- opacity = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetOpacity(float=True)
- qlayer.SetOpacity(opacity)
- self.MapWindow.UpdateMap(render=False, renderVector=False)
- if not self.dialogs['attributes'].IsShown():
- self.dialogs['attributes'].Show()
- else:
- if qlayer:
- self.Map.DeleteLayer(qlayer)
- if self.dialogs['attributes'].IsShown():
- self.dialogs['attributes'].Hide()
- def OnQuery(self, event):
- """Query tools menu"""
- action = self.toolbars['map'].GetAction()
- toolsmenu = wx.Menu()
- display = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
- text=_("Query raster/vector map(s) (display mode)"),
- kind=wx.ITEM_CHECK)
- toolsmenu.AppendItem(display)
- self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
- numLayers = 0
- numLayers += 1
- if numLayers < 1:
- display.Enable(False)
- if action == "displayAttrb":
- display.Check(True)
- modify = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
- text=_("Query vector map (edit mode)"),
- toolsmenu.AppendItem(modify)
- self.Bind(wx.EVT_MENU, self.OnQueryModify, modify)
- if self.tree.layer_selected:
- layer_selected = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer']
- if layer_selected.GetType() != 'vector' or \
- (digitToolbar and \
- digitToolbar.GetLayer() == layer_selected):
- modify.Enable(False)
- else:
- if action == "modifyAttrb":
- modify.Check(True)
- self.PopupMenu(toolsmenu)
- toolsmenu.Destroy()
- def AddTmpVectorMapLayer(self, name, cats, useId=False, addLayer=True):
- Add temporal vector map layer to map composition
- @param name name of map layer
- @param useId use feature id instead of category
- # color settings from ATM
- color = UserSettings.Get(group='atm', key='highlight', subkey='color')
- str(color[2])
- pattern = ["d.vect",
- "map=%s" % name,
- "color=%s" % colorStr,
- "fcolor=%s" % colorStr,
- "width=%d" % UserSettings.Get(group='atm', key='highlight', subkey='width')]
- if useId:
- cmd = pattern
- cmd.append('-i')
- cmd.append('cats=%s' % str(cats))
- else:
- cmd = []
- for layer in cats.keys():
- cmd.append(copy.copy(pattern))
- lcats = cats[layer]
- cmd[-1].append("layer=%d" % layer)
- cmd[-1].append("cats=%s" % utils.ListOfCatsToRange(lcats))
- # if self.icon:
- # cmd.append("icon=%s" % (self.icon))
- # if self.pointsize:
- # cmd.append("size=%s" % (self.pointsize))
- if addLayer:
- if useId:
- return self.Map.AddLayer(type='vector', name=globalvar.QUERYLAYER, command=cmd,
- l_active=True, l_hidden=True, l_opacity=1.0)
- else:
- return self.Map.AddLayer(type='command', name=globalvar.QUERYLAYER, command=cmd,
- else:
- return cmd
- def OnAnalyze(self, event):
- Analysis tools menu
- measure = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["measure"].GetLabel())
- measure.SetBitmap(Icons["measure"].GetBitmap(self.iconsize))
- toolsmenu.AppendItem(measure)
- self.Bind(wx.EVT_MENU, self.OnMeasure, measure)
- profile = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["profile"].GetLabel())
- profile.SetBitmap(Icons["profile"].GetBitmap(self.iconsize))
- toolsmenu.AppendItem(profile)
- self.Bind(wx.EVT_MENU, self.Profile, profile)
- histogram = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["histogram"].GetLabel())
- histogram.SetBitmap(Icons["histogram"].GetBitmap(self.iconsize))
- toolsmenu.AppendItem(histogram)
- self.Bind(wx.EVT_MENU, self.Histogram, histogram)
- def OnMeasure(self, event):
- Init measurement routine that calculates
- map distance along transect drawn on
- map display
- self.totaldist = 0.0 # total measured distance
- # switch GIS Manager to output console to show measure results
- # change mouse to draw line for measurement
- self.MapWindow.mouse['use'] = "measure"
- self.MapWindow.mouse['box'] = "line"
- self.MapWindow.pen = wx.Pen(colour='red', width=2, style=wx.SHORT_DASH)
- self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SHORT_DASH)
- self.MapWindow.SetCursor(self.cursors["pencil"])
- # initiating output
- style = self.gismanager.goutput.cmd_output.StyleWarning
- self.gismanager.goutput.WriteLog(_('Click and drag with left mouse button '
- 'to measure.%s'
- 'Double click with left button to clear.') % \
- (os.linesep), style)
- if self.Map.projinfo['proj'] != 'xy':
- units = self.Map.projinfo['units']
- style = self.gismanager.goutput.cmd_output.StyleCommand
- self.gismanager.goutput.WriteLog(_('Measuring distance') + ' ('
- + units + '):',
- style)
- else:
- self.gismanager.goutput.WriteLog(_('Measuring distance:'),
- style)
- def MeasureDist(self, beginpt, endpt):
- Calculate map distance from screen distance
- and print to output window
- if self.gismanager.notebook.GetSelection() != 1:
- dist, (north, east) = self.MapWindow.Distance(beginpt, endpt)
- dist = round(dist, 3)
- d, dunits = self.FormatDist(dist)
- self.totaldist += dist
- td, tdunits = self.FormatDist(self.totaldist)
- strdist = str(d)
- strtotdist = str(td)
- if self.Map.projinfo['proj'] == 'xy' or 'degree' not in self.Map.projinfo['unit']:
- angle = int(math.degrees(math.atan2(north,east)) + 0.5)
- angle = 180 - angle
- if angle < 0:
- angle = 360+angle
- mstring = 'segment = %s %s\ttotal distance = %s %s\tbearing = %d deg' \
- % (strdist,dunits,strtotdist,tdunits,angle)
- else:
- mstring = 'segment = %s %s\ttotal distance = %s %s' \
- % (strdist,dunits,strtotdist,tdunits)
- self.gismanager.goutput.WriteLog(mstring)
- return dist
- def Profile(self, event):
- Init profile canvas and tools
- raster = []
- if self.tree.layer_selected and \
- self.tree.GetPyData(self.tree.layer_selected)[0]['type'] == 'raster':
- raster.append(self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
- self.profile = profile.ProfileFrame(self,
- id=wx.ID_ANY, pos=wx.DefaultPosition, size=(700,300),
- style=wx.DEFAULT_FRAME_STYLE, rasterList=raster)
- self.profile.Show()
- # Open raster select dialog to make sure that a raster (and the desired raster)
- # is selected to be profiled
- self.profile.OnSelectRaster(None)
- def FormatDist(self, dist):
- """Format length numbers and units in a nice way,
- as a function of length. From code by Hamish Bowman
- Grass Development Team 2006"""
- mapunits = self.Map.projinfo['units']
- if mapunits == 'metres': mapunits = 'meters'
- outunits = mapunits
- dist = float(dist)
- divisor = 1.0
- # figure out which units to use
- if mapunits == 'meters':
- if dist > 2500.0:
- outunits = 'km'
- divisor = 1000.0
- else: outunits = 'm'
- elif mapunits == 'feet':
- # nano-bug: we match any "feet", but US Survey feet is really
- # 5279.9894 per statute mile, or 10.6' per 1000 miles. As >1000
- # miles the tick markers are rounded to the nearest 10th of a
- # mile (528'), the difference in foot flavours is ignored.
- if dist > 5280.0:
- outunits = 'miles'
- divisor = 5280.0
- else:
- outunits = 'ft'
- elif 'degree' in mapunits:
- if dist < 1:
- outunits = 'min'
- divisor = (1/60.0)
- else:
- outunits = 'deg'
- # format numbers in a nice way
- if (dist/divisor) >= 2500.0:
- outdist = round(dist/divisor)
- elif (dist/divisor) >= 1000.0:
- outdist = round(dist/divisor,1)
- elif (dist/divisor) > 0.0:
- outdist = round(dist/divisor,int(math.ceil(3-math.log10(dist/divisor))))
- else:
- outdist = float(dist/divisor)
- return (outdist, outunits)
- def Histogram(self, event):
- Init histogram display canvas and tools
- self.histogram = histogram.HistFrame(self,
- id=wx.ID_ANY, size=globalvar.HIST_WINDOW_SIZE,
- style=wx.DEFAULT_FRAME_STYLE)
- #show new display
- self.histogram.Show()
- self.histogram.Refresh()
- self.histogram.Update()
- def OnDecoration(self, event):
- Decorations overlay menu
- decmenu = wx.Menu()
- AddScale = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addbarscale"].GetLabel())
- AddScale.SetBitmap(Icons["addbarscale"].GetBitmap(self.iconsize))
- decmenu.AppendItem(AddScale)
- self.Bind(wx.EVT_MENU, self.OnAddBarscale, AddScale)
- AddLegend = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addlegend"].GetLabel())
- AddLegend.SetBitmap(Icons["addlegend"].GetBitmap(self.iconsize))
- decmenu.AppendItem(AddLegend)
- self.Bind(wx.EVT_MENU, self.OnAddLegend, AddLegend)
- AddText = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addtext"].GetLabel())
- AddText.SetBitmap(Icons["addtext"].GetBitmap(self.iconsize))
- decmenu.AppendItem(AddText)
- self.Bind(wx.EVT_MENU, self.OnAddText, AddText)
- self.PopupMenu(decmenu)
- decmenu.Destroy()
- def OnAddBarscale(self, event):
- Handler for scale/arrow map decoration menu selection.
- if self.dialogs['barscale']:
- return
- id = 0 # unique index for overlay layer
- # If location is latlon, only display north arrow (scale won't work)
- # proj = self.Map.projinfo['proj']
- # if proj == 'll':
- # barcmd = 'd.barscale -n'
- # else:
- # barcmd = 'd.barscale'
- # decoration overlay control dialog
- self.dialogs['barscale'] = \
- gdialogs.DecorationDialog(parent=self, title=_('Scale and North arrow'),
- size=(350, 200),
- style=wx.DEFAULT_DIALOG_STYLE | wx.CENTRE,
- cmd=['d.barscale', 'at=0,5'],
- ovlId=id,
- name='barscale',
- checktxt = _("Show/hide scale and North arrow"),
- ctrltxt = _("scale object"))
- self.dialogs['barscale'].CentreOnParent()
- ### dialog cannot be show as modal - in the result d.barscale is not selectable
- ### self.dialogs['barscale'].ShowModal()
- self.dialogs['barscale'].Show()
- self.MapWindow.mouse['use'] = 'pointer'
- def OnAddLegend(self, event):
- Handler for legend map decoration menu selection.
- if self.dialogs['legend']:
- return
- id = 1 # index for overlay layer in render
- cmd = ['d.legend', 'at=5,50,2,5']
- cmd.append('map=%s' % self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
- # Decoration overlay control dialog
- self.dialogs['legend'] = \
- gdialogs.DecorationDialog(parent=self, title=('Legend'),
- size=(350, 200),
- cmd=cmd,
- ovlId=id,
- name='legend',
- checktxt = _("Show/hide legend"),
- ctrltxt = _("legend object"))
- self.dialogs['legend'].CentreOnParent()
- ### dialog cannot be show as modal - in the result d.legend is not selectable
- ### self.dialogs['legend'].ShowModal()
- self.dialogs['legend'].Show()
- def OnAddText(self, event):
- Handler for text decoration menu selection.
- if self.MapWindow.dragid > -1:
- id = self.MapWindow.dragid
- else:
- # index for overlay layer in render
- if len(self.MapWindow.textdict.keys()) > 0:
- id = self.MapWindow.textdict.keys()[-1] + 1
- else:
- id = 101
- self.dialogs['text'] = gdialogs.TextLayerDialog(parent=self, ovlId=id,
- title=_('Add text layer'),
- size=(400, 200))
- self.dialogs['text'].CenterOnParent()
- # If OK button pressed in decoration control dialog
- if self.dialogs['text'].ShowModal() == wx.ID_OK:
- text = self.dialogs['text'].GetValues()['text']
- active = self.dialogs['text'].GetValues()['active']
- coords, w, h = self.MapWindow.TextBounds(self.dialogs['text'].GetValues())
- # delete object if it has no text or is not active
- if text == '' or active == False:
- try:
- self.MapWindow.pdc.ClearId(id)
- self.MapWindow.pdc.RemoveId(id)
- del self.MapWindow.textdict[id]
- except:
- pass
- return
- self.MapWindow.pdc.SetId(id)
- self.MapWindow.textdict[id] = self.dialogs['text'].GetValues()
- self.MapWindow.Draw(self.MapWindow.pdcDec, img=self.MapWindow.textdict[id],
- drawid=id, pdctype='text', coords=coords)
- def GetOptData(self, dcmd, type, params, propwin):
- Callback method for decoration overlay command generated by
- dialog created in menuform.py
- # Reset comand and rendering options in render.Map. Always render decoration.
- # Showing/hiding handled by PseudoDC
- self.Map.ChangeOverlay(ovltype=type, type='overlay', name='', command=dcmd,
- l_active=True, l_render=False)
- self.params[type] = params
- self.propwin[type] = propwin
- def OnZoomMenu(self, event):
- Zoom menu
- zoommenu = wx.Menu()
- zoommap = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to selected map(s)'))
- zoommenu.AppendItem(zoommap)
- self.Bind(wx.EVT_MENU, self.MapWindow.OnZoomToMap, zoommap)
- zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
- zoommenu.AppendItem(zoomwind)
- self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToWind, zoomwind)
- zoomdefault = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to default region'))
- zoommenu.AppendItem(zoomdefault)
- self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToDefault, zoomdefault)
- zoomsaved = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to saved region'))
- zoommenu.AppendItem(zoomsaved)
- self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToSaved, zoomsaved)
- savewind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Set computational region from display'))
- zoommenu.AppendItem(savewind)
- self.Bind(wx.EVT_MENU, self.MapWindow.DisplayToWind, savewind)
- savezoom = wx.MenuItem(zoommenu, wx.ID_ANY, _('Save display geometry to named region'))
- zoommenu.AppendItem(savezoom)
- self.Bind(wx.EVT_MENU, self.MapWindow.SaveDisplayRegion, savezoom)
- self.PopupMenu(zoommenu)
- zoommenu.Destroy()
- def SetProperties(self, render=False, mode=0, showCompExtent=False,
- constrainRes=False):
- """Set properies of map display window"""
- self.autoRender.SetValue(render)
- self.toggleStatus.SetSelection(mode)
- self.showRegion.SetValue(showCompExtent)
- self.compResolution.SetValue(constrainRes)
- if showCompExtent:
- def IsStandalone(self):
- """!Check if Map display is standalone"""
- return False
- return True
- def GetLayerManager(self):
- """!Get reference to Layer Manager
- @return window reference
- @return None (if standalone)
- return self.gismanager
-# end of class MapFrame
-class MapApp(wx.App):
- MapApp class
- def OnInit(self):
- wx.InitAllImageHandlers()
- if __name__ == "__main__":
- Map = render.Map() # instance of Map class to render GRASS display output to PPM file
- else:
- Map = None
- self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map, size=(640,480))
- #self.SetTopWindow(Map)
- self.mapFrm.Show()
- # redraw map, if new command appears
- self.redraw = False
- status = Command(self, Map)
- status.start()
- self.timer = wx.PyTimer(self.watcher)
- # check each 0.1s
- self.timer.Start(100)
- return 1
- def OnExit(self):
- # stop the timer
- self.timer.Stop()
- # terminate thread (a bit ugly)
- os.system("""echo "quit" >> %s""" % (cmdfilename))
- def watcher(self):
- """Redraw, if new layer appears"""
- if self.redraw:
- self.mapFrm.OnDraw(None)
- return
-# end of class MapApp
-if __name__ == "__main__":
- ###### SET command variable
- if len(sys.argv) != 3:
- print __doc__
- sys.exit()
- title = sys.argv[1]
- cmdfilename = sys.argv[2]
- import gettext
- gettext.install("gm_map") # replace with the appropriate catalog name
- print "Starting monitor <%s>" % (title)
- gm_map = MapApp(0)
- # set title
- gm_map.mapFrm.SetTitle ("GRASS GIS - Map Display: " + title + " - Location: " + \
- grass.gisenv()['LOCATION_NAME'])
- gm_map.MainLoop()
- if grass.gisenv().has_key("MONITOR"):
- os.system("d.mon sel=%s" % grass.gisenv()["MONITOR"])
- os.remove(cmdfilename)
- os.system("""g.gisenv set="GRASS_PYCMDFILE" """)
- print "Stoping monitor <%s>" % (title)
- sys.exit()
Added: grass-addons/gui/wxpython/data_catalog/mapframe.py
--- grass-addons/gui/wxpython/data_catalog/mapframe.py (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/mapframe.py 2010-02-04 04:58:00 UTC (rev 40807)
@@ -0,0 +1,4235 @@
+ at package mapdisp.py
+ at brief GIS map display canvas, with toolbar for various display
+management functions, and second toolbar for vector
+digitizing.
+Can be used either from GIS Manager or as p.mon backend.
+Classes:
+ - Command
+ - MapWindow
+ - BufferedWindow
+ - MapFrame
+ - MapApp
+Usage:
+ python mapdisp.py monitor-identifier /path/to/command/file
+(C) 2006-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import sys
+import time
+import glob
+import math
+import tempfile
+import copy
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+ globalvar.CheckForWx()
+import wx
+import wx.aui
+from threading import Thread
+try:
+ import subprocess
+except:
+ CompatPath = os.path.join(globalvar.ETCWXDIR)
+ sys.path.append(CompatPath)
+ from compat import subprocess
+gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
+sys.path.append(gmpath)
+import render
+import toolbars
+import track
+import menuform
+import gselect
+import disp_print
+import gcmd
+import dbm
+import histogram
+import profile
+import globalvar
+import utils
+import gdialogs
+from grass.script import core as grass
+from vdigit import VDigitCategoryDialog as VDigitCategoryDialog
+from vdigit import VDigitZBulkDialog as VDigitZBulkDialog
+from vdigit import VDigitDuplicatesDialog as VDigitDuplicatesDialog
+from vdigit import GV_LINES as VDigit_Lines_Type
+from debug import Debug as Debug
+from icon import Icons as Icons
+from preferences import globalSettings as UserSettings
+import images
+imagepath = images.__path__[0]
+sys.path.append(imagepath)
+### global variables
+# for standalone app
+cmdfilename = None
+class Command(Thread):
+ Creates thread which will observe the command file and see, if
+ there is new command to be executed
+ def __init__ (self, parent, Map):
+ Thread.__init__(self)
+ global cmdfilename
+ self.parent = parent
+ self.map = Map
+ self.cmdfile = open(cmdfilename, "r")
+ def run(self):
+ Run this in thread
+ dispcmd = []
+ while 1:
+ self.parent.redraw = False
+ line = self.cmdfile.readline().strip()
+ if line == "quit":
+ break
+ if line:
+ try:
+ Debug.msg (3, "Command.run(): cmd=%s" % (line))
+ self.map.AddLayer(item=None, type="raster",
+ name='',
+ command=line,
+ l_opacity=1)
+ self.parent.redraw =True
+ except Exception, e:
+ print "Command Thread: ",e
+ time.sleep(0.1)
+ sys.exit()
+class MapWindow(object):
+ Abstract map window class
+ Parent for BufferedWindow class (2D display mode) and
+ GLWindow (3D display mode)
+ def __init__(self, parent, id=wx.ID_ANY,
+ pos=wx.DefaultPosition,
+ size=wx.DefaultSize,
+ style=wx.NO_FULL_REPAINT_ON_RESIZE,
+ Map=None, tree=None, gismgr=None):
+ self.parent = parent # MapFrame
+ # mouse attributes like currently pressed buttons, position on
+ # the screen, begin and end of dragging, and type of drawing
+ self.mouse = {
+ 'l' : False,
+ 'r' : False,
+ 'm' : False,
+ 'begin': [0, 0], # screen coordinates
+ 'end' : [0, 0],
+ 'use' : "pointer",
+ 'box' : "point"
+ def EraseMap(self):
+ Erase the canvas (virtual method)
+ pass
+ def UpdateMap(self):
+ Updates the canvas anytime there is a change to the
+ underlaying images or to the geometry of the canvas.
+ pass
+ def OnLeftDown(self, event):
+ pass
+ def OnLeftUp(self, event):
+ pass
+ def OnMouseMotion(self, event):
+ pass
+ def OnZoomToMap(self, event):
+ pass
+ def OnZoomToRaster(self, event):
+ pass
+ def GetSelectedLayer(self, type = 'layer', multi = False):
+ Get selected layer from layer tree
+ @param type 'item' / 'layer' / 'nviz'
+ @param multi return first selected layer or all
+ @return layer / map layer properties / nviz properties
+ @return None / [] on failure
+ ret = []
+ if not self.tree or \
+ not self.tree.GetSelection():
+ if multi:
+ return []
+ else:
+ return None
+ if multi and \
+ type == 'item':
+ return self.tree.GetSelections()
+ for item in self.tree.GetSelections():
+ if not item.IsChecked():
+ if multi:
+ continue
+ else:
+ return None
+ if type == 'item': # -> multi = False
+ return item
+ try:
+ if type == 'nviz':
+ layer = self.tree.GetPyData(item)[0]['nviz']
+ else:
+ layer = self.tree.GetPyData(item)[0]['maplayer']
+ except:
+ layer = None
+ if multi:
+ ret.append(layer)
+ else:
+ return layer
+ return ret
+class BufferedWindow(MapWindow, wx.Window):
+ A Buffered window class.
+ When the drawing needs to change, you app needs to call the
+ UpdateMap() method. Since the drawing is stored in a bitmap, you
+ can also save the drawing to file by calling the
+ SaveToFile(self,file_name,file_type) method.
+ def __init__(self, parent, id,
+ pos = wx.DefaultPosition,
+ size = wx.DefaultSize,
+ MapWindow.__init__(self, parent, id, pos, size, style,
+ Map, tree, gismgr)
+ wx.Window.__init__(self, parent, id, pos, size, style)
+ self.Map = Map
+ self.tree = tree
+ self.gismanager = gismgr
+ book= self.GetParent()
+ q=book.GetParent()
+ r=q.GetParent()
+ splitter=r.GetParent()
+ self.gframe=splitter.GetParent()
+ # Flags
+ self.resize = False # indicates whether or not a resize event has taken place
+ self.dragimg = None # initialize variable for map panning
+ # Variable for drawing on DC
+ self.pen = None # pen for drawing zoom boxes, etc.
+ self.polypen = None # pen for drawing polylines (measurements, profiles, etc)
+ # List of wx.Point tuples defining a polyline (geographical coordinates)
+ self.polycoords = []
+ # ID of rubber band line
+ self.lineid = None
+ # ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
+ self.plineid = None
+ # Event bindings
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ self.Bind(wx.EVT_IDLE, self.OnIdle)
+ self.Bind(wx.EVT_MOTION, self.MouseActions)
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
+ self.processMouse = True
+ # Render output objects
+ self.mapfile = None # image file to be rendered
+ self.img = "" # wx.Image object (self.mapfile)
+ # used in digitization tool (do not redraw vector map)
+ self.imgVectorMap = None
+ # decoration overlays
+ self.overlays = {}
+ # images and their PseudoDC ID's for painting and dragging
+ self.imagedict = {}
+ self.select = {} # selecting/unselecting decorations for dragging
+ self.textdict = {} # text, font, and color indexed by id
+ self.currtxtid = None # PseudoDC id for currently selected text
+ # Zoom objects
+ self.zoomhistory = [] # list of past zoom extents
+ self.currzoom = 0 # current set of extents in zoom history being used
+ self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
+ self.hitradius = 10 # distance for selecting map decorations
+ self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
+ # OnSize called to make sure the buffer is initialized.
+ # This might result in OnSize getting called twice on some
+ # platforms at initialization, but little harm done.
+ ### self.OnSize(None)
+ # create PseudoDC used for background map, map decorations like scales and legends
+ self.pdc = wx.PseudoDC()
+ # used for digitization tool
+ self.pdcVector = None
+ # decorations (region box, etc.)
+ self.pdcDec = wx.PseudoDC()
+ # pseudoDC for temporal objects (select box, measurement tool, etc.)
+ self.pdcTmp = wx.PseudoDC()
+ # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
+ self.redrawAll = True
+ # will store an off screen empty bitmap for saving to file
+ self._buffer = ''
+ self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
+ # vars for handling mouse clicks
+ self.dragid = -1
+ self.lastpos = (0, 0)
+ def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
+ Draws map and overlay decorations
+ if drawid == None:
+ if pdctype == 'image' and img:
+ drawid = self.imagedict[img]
+ elif pdctype == 'clear':
+ drawid == None
+ else:
+ drawid = wx.NewId()
+ if img and pdctype == 'image':
+ # self.imagedict[img]['coords'] = coords
+ self.select[self.imagedict[img]['id']] = False # ?
+ pdc.BeginDrawing()
+ if drawid != 99:
+ bg = wx.TRANSPARENT_BRUSH
+ else:
+ bg = wx.Brush(self.GetBackgroundColour())
+ pdc.SetBackground(bg)
+ ### pdc.Clear()
+ Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
+ (drawid, pdctype, coords))
+ # set PseudoDC id
+ if drawid is not None:
+ pdc.SetId(drawid)
+ if pdctype == 'clear': # erase the display
+ bg = wx.WHITE_BRUSH
+ # bg = wx.Brush(self.GetBackgroundColour())
+ pdc.RemoveAll()
+ pdc.Clear()
+ pdc.EndDrawing()
+ self.Refresh()
+ return
+ if pdctype == 'image': # draw selected image
+ bitmap = wx.BitmapFromImage(img)
+ w,h = bitmap.GetSize()
+ pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
+ pdc.SetIdBounds(drawid, (coords[0],coords[1], w, h))
+ elif pdctype == 'box': # draw a box on top of the map
+ if self.pen:
+ pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
+ pdc.SetPen(self.pen)
+ x2 = max(coords[0],coords[2])
+ x1 = min(coords[0],coords[2])
+ y2 = max(coords[1],coords[3])
+ y1 = min(coords[1],coords[3])
+ rwidth = x2-x1
+ rheight = y2-y1
+ rect = wx.Rect(x1,y1,rwidth,rheight)
+ pdc.DrawRectangleRect(rect)
+ pdc.SetIdBounds(drawid,rect)
+ # self.ovlcoords[drawid] = coords
+ elif pdctype == 'line': # draw a line on top of the map
+ if self.pen:
+ pdc.DrawLine(coords[0], coords[1], coords[2], coords[3])
+ pdc.SetIdBounds(drawid,(coords[0], coords[1], coords[2], coords[3]))
+ elif pdctype == 'polyline': # draw a polyline on top of the map
+ if self.polypen:
+ pdc.SetPen(self.polypen)
+ pdc.DrawLines(coords)
+ # get bounding rectangle for polyline
+ xlist = []
+ ylist = []
+ if len(coords) > 0:
+ for point in coords:
+ x,y = point
+ xlist.append(x)
+ ylist.append(y)
+ x1=min(xlist)
+ x2=max(xlist)
+ y1=min(ylist)
+ y2=max(ylist)
+ pdc.SetIdBounds(drawid,(x1,y1,x2,y2))
+ # self.ovlcoords[drawid] = [x1,y1,x2,y2]
+ elif pdctype == 'point': # draw point
+ if self.pen:
+ pdc.DrawPoint(coords[0], coords[1])
+ coordsBound = (coords[0] - 5,
+ coords[1] - 5,
+ coords[0] + 5,
+ coords[1] + 5)
+ pdc.SetIdBounds(drawid, coordsBound)
+ elif pdctype == 'text': # draw text on top of map
+ if not img['active']:
+ return #only draw active text
+ if img.has_key('rotation'):
+ rotation = float(img['rotation'])
+ else:
+ rotation = 0.0
+ w, h = self.GetFullTextExtent(img['text'])[0:2]
+ pdc.SetFont(img['font'])
+ pdc.SetTextForeground(img['color'])
+ coords, w, h = self.TextBounds(img)
+ if rotation == 0:
+ pdc.DrawText(img['text'], coords[0], coords[1])
+ else:
+ pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
+ pdc.SetIdBounds(drawid, (coords[0], coords[1], w, h))
+ pdc.EndDrawing()
+ self.Refresh()
+ return drawid
+ def TextBounds(self, textinfo):
+ Return text boundary data
+ @param textinfo text metadata (text, font, color, rotation)
+ @param coords reference point
+ if textinfo.has_key('rotation'):
+ rotation = float(textinfo['rotation'])
+ else:
+ rotation = 0.0
+ coords = textinfo['coords']
+ Debug.msg (4, "BufferedWindow.TextBounds(): text=%s, rotation=%f" % \
+ (textinfo['text'], rotation))
+ self.Update()
+ ### self.Refresh()
+ self.SetFont(textinfo['font'])
+ w, h = self.GetTextExtent(textinfo['text'])
+ if rotation == 0:
+ coords[2], coords[3] = coords[0] + w, coords[1] + h
+ return coords, w, h
+ boxh = math.fabs(math.sin(math.radians(rotation)) * w) + h
+ boxw = math.fabs(math.cos(math.radians(rotation)) * w) + h
+ coords[2] = coords[0] + boxw
+ coords[3] = coords[1] + boxh
+ return coords, boxw, boxh
+ def OnPaint(self, event):
+ Draw PseudoDC's to buffered paint DC
+ self.pdc for background and decorations
+ self.pdcVector for vector map which is edited
+ self.pdcTmp for temporaly drawn objects (self.polycoords)
+ If self.redrawAll is False on self.pdcTmp content is re-drawn
+ Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
+ dc = wx.BufferedPaintDC(self, self.buffer)
+ ### dc.SetBackground(wx.Brush("White"))
+ dc.Clear()
+ # use PrepareDC to set position correctly
+ self.PrepareDC(dc)
+ # create a clipping rect from our position and size
+ # and update region
+ rgn = self.GetUpdateRegion().GetBox()
+ dc.SetClippingRect(rgn)
+ switchDraw = False
+ if self.redrawAll is None:
+ switchDraw = True
+ if self.redrawAll: # redraw pdc and pdcVector
+ # draw to the dc using the calculated clipping rect
+ self.pdc.DrawToDCClipped(dc, rgn)
+ # draw vector map layer
+ if self.pdcVector:
+ # decorate with GDDC (transparency)
+ try:
+ gcdc = wx.GCDC(dc)
+ self.pdcVector.DrawToDCClipped(gcdc, rgn)
+ except NotImplementedError, e:
+ print >> sys.stderr, e
+ self.pdcVector.DrawToDCClipped(dc, rgn)
+ self.bufferLast = None
+ else: # do not redraw pdc and pdcVector
+ if self.bufferLast is None:
+ # draw to the dc
+ self.pdc.DrawToDC(dc)
+ try:
+ self.pdcVector.DrawToDC(gcdc)
+ self.pdcVector.DrawToDC(dc)
+ # store buffered image
+ # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
+ self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
+ pdcLast = wx.PseudoDC()
+ pdcLast.DrawBitmap(bmp=self.bufferLast, x=0, y=0)
+ pdcLast.DrawToDC(dc)
+ # draw decorations (e.g. region box)
+ try:
+ self.pdcDec.DrawToDC(gcdc)
+ self.pdcDec.DrawToDC(dc)
+ # draw temporary object on the foreground
+ ### self.pdcTmp.DrawToDCClipped(dc, rgn)
+ self.pdcTmp.DrawToDC(dc)
+ if switchDraw:
+ self.redrawAll = False
+ def OnSize(self, event):
+ Scale map image so that it is
+ the same size as the Window
+ Debug.msg(3, "BufferedWindow.OnSize():")
+ # set size of the input image
+ self.Map.ChangeMapSize(self.GetClientSize())
+ # align extent based on center point and display resolution
+ # this causes that image is not resized when display windows is resized
+ # self.Map.AlignExtentFromDisplay()
+ # Make new off screen bitmap: this bitmap will always have the
+ # current drawing in it, so it can be used to save the image to
+ # a file, or whatever.
+ self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
+ # get the image to be rendered
+ self.img = self.GetImage()
+ # update map display
+ if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
+ self.img = self.img.Scale(self.Map.width, self.Map.height)
+ if len(self.Map.GetListOfLayers()) > 0:
+ self.UpdateMap()
+ # re-render image on idle
+ self.resize = True
+ # reposition checkbox in statusbar
+ self.parent.StatusbarReposition()
+ # update statusbar
+ self.parent.StatusbarUpdate()
+ def OnIdle(self, event):
+ Only re-render a composite map image from GRASS during
+ idle time instead of multiple times during resizing.
+ if self.resize:
+ self.UpdateMap(render=True)
+ event.Skip()
+ def SaveToFile(self, FileName, FileType):
+ This draws the psuedo DC to a buffer that
+ can be saved to a file.
+ self.buffer.SaveFile(FileName, FileType)
+ def GetOverlay(self):
+ Converts rendered overlay files to wx.Image
+ Updates self.imagedict
+ @return list of images
+ imgs = []
+ for overlay in self.Map.GetListOfLayers(l_type="overlay", l_active=True):
+ if os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
+ img = wx.Image(overlay.mapfile, wx.BITMAP_TYPE_ANY)
+ self.imagedict[img] = { 'id' : overlay.id,
+ 'layer' : overlay }
+ imgs.append(img)
+ return imgs
+ def GetImage(self):
+ Converts redered map files to wx.Image
+ Updates self.imagedict (id=99)
+ @return wx.Image instance (map composition)
+ imgId = 99
+ if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
+ os.path.getsize(self.Map.mapfile):
+ img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
+ else:
+ img = None
+ self.imagedict[img] = { 'id': imgId }
+ return img
+ def UpdateMap(self, render=True, renderVector=True):
+ @param render re-render map composition
+ @param renderVector re-render vector map layer enabled for editing (used for digitizer)
+ start = time.clock()
+ # if len(self.Map.GetListOfLayers()) == 0:
+ # return False
+ if self.img is None:
+ render = True
+ # initialize process bar (only on 'render')
+ if render is True or renderVector is True:
+ self.parent.onRenderGauge.Show()
+ if self.parent.onRenderGauge.GetRange() > 0:
+ self.parent.onRenderGauge.SetValue(1)
+ # render background image if needed
+ # update layer dictionary if there has been a change in layers
+ if self.tree and self.tree.reorder == True:
+ self.tree.ReorderLayers()
+ # reset flag for auto-rendering
+ if self.tree:
+ self.tree.rerender = False
+ if render:
+ # update display size
+ if self.parent.compResolution.IsChecked():
+ # use computation region resolution for rendering
+ windres = True
+ else:
+ windres = False
+ self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
+ windres=windres)
+ else:
+ self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+ self.img = self.GetImage() # id=99
+ # clear pseudoDcs
+ for pdc in (self.pdc,
+ self.pdcDec,
+ self.pdcTmp):
+ pdc.Clear()
+ pdc.RemoveAll()
+ # draw background map image to PseudoDC
+ if not self.img:
+ self.Draw(self.pdc, pdctype='clear')
+ else:
+ try:
+ id = self.imagedict[self.img]['id']
+ except:
+ return False
+ self.Draw(self.pdc, self.img, drawid=id)
+ # render vector map layer
+ digitToolbar = self.parent.toolbars['vdigit']
+ if renderVector and digitToolbar and \
+ digitToolbar.GetLayer():
+ # set region
+ self.parent.digit.driver.UpdateRegion()
+ # re-calculate threshold for digitization tool
+ self.parent.digit.driver.GetThreshold()
+ # draw map
+ self.pdcVector.Clear()
+ self.pdcVector.RemoveAll()
+ try:
+ item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
+ except TypeError:
+ item = None
+ if item and self.tree.IsItemChecked(item):
+ self.parent.digit.driver.DrawMap()
+ # translate tmp objects (pointer position)
+ if digitToolbar.GetAction() == 'moveLine':
+ if hasattr(self, "vdigitMove") and \
+ self.vdigitMove.has_key('beginDiff'):
+ # move line
+ for id in self.vdigitMove['id']:
+ # print self.pdcTmp.GetIdBounds(id)
+ self.pdcTmp.TranslateId(id,
+ self.vdigitMove['beginDiff'][0],
+ self.vdigitMove['beginDiff'][1])
+ del self.vdigitMove['beginDiff']
+ # render overlays
+ for img in self.GetOverlay():
+ # draw any active and defined overlays
+ if self.imagedict[img]['layer'].IsActive():
+ id = self.imagedict[img]['id']
+ self.Draw(self.pdc, img=img, drawid=id,
+ pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
+ for id in self.textdict.keys():
+ self.Draw(self.pdc, img=self.textdict[id], drawid=id,
+ pdctype='text', coords=[10, 10, 10, 10])
+ # optionally draw computational extent box
+ self.DrawCompRegionExtent()
+ # redraw pdcTmp if needed
+ if len(self.polycoords) > 0:
+ self.DrawLines(self.pdcTmp)
+ if self.gframe.georectifying:
+ # -> georectifier (redraw GCPs)
+ if self.parent.toolbars['georect']:
+ coordtype = 'gcpcoord'
+ else:
+ coordtype = 'mapcoord'
+ self.gframe.georectifying.DrawGCP(coordtype)
+ # clear measurement
+ if self.mouse["use"] == "measure":
+ self.ClearLines(pdc=self.pdcTmp)
+ self.mouse['use'] = 'pointer'
+ self.mouse['box'] = 'point'
+ self.mouse['end'] = [0, 0]
+ self.SetCursor(self.parent.cursors["default"])
+ stop = time.clock()
+ # hide process bar
+ self.parent.onRenderGauge.Hide()
+ ### self.Map.SetRegion()
+ if grass.find_file(name = 'MASK', element = 'cell')['name']:
+ # mask found
+ self.parent.maskInfo.SetLabel(_('MASK'))
+ else:
+ self.parent.maskInfo.SetLabel('')
+ Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+ (render, renderVector, (stop-start)))
+ return True
+ def DrawCompRegionExtent(self):
+ Draw computational region extent in the display
+ Display region is drawn as a blue box inside the computational region,
+ computational region inside a display region as a red box).
+ if hasattr(self, "regionCoords"):
+ compReg = self.Map.GetRegion()
+ dispReg = self.Map.GetCurrentRegion()
+ reg = None
+ if self.IsInRegion(dispReg, compReg):
+ self.polypen = wx.Pen(colour=wx.Colour(0, 0, 255, 128), width=3, style=wx.SOLID)
+ reg = dispReg
+ else:
+ self.polypen = wx.Pen(colour=wx.Colour(255, 0, 0, 128),
+ width=3, style=wx.SOLID)
+ reg = compReg
+ self.regionCoords = []
+ self.regionCoords.append((reg['w'], reg['n']))
+ self.regionCoords.append((reg['e'], reg['n']))
+ self.regionCoords.append((reg['e'], reg['s']))
+ self.regionCoords.append((reg['w'], reg['s']))
+ # draw region extent
+ self.DrawLines(pdc=self.pdcDec, polycoords=self.regionCoords)
+ def IsInRegion(self, region, refRegion):
+ Test if 'region' is inside of 'refRegion'
+ @param region input region
+ @param refRegion reference region (e.g. computational region)
+ @return True if region is inside of refRegion
+ @return False
+ if region['s'] >= refRegion['s'] and \
+ region['n'] <= refRegion['n'] and \
+ region['w'] >= refRegion['w'] and \
+ region['e'] <= refRegion['e']:
+ return True
+ return False
+ Erase the canvas
+ self.Draw(self.pdcVector, pdctype='clear')
+ self.Draw(self.pdcDec, pdctype='clear')
+ self.Draw(self.pdcTmp, pdctype='clear')
+ def DragMap(self, moveto):
+ Drag the entire map image for panning.
+ dc = wx.BufferedDC(wx.ClientDC(self))
+ dc.SetBackground(wx.Brush("White"))
+ dc.Clear()
+ self.dragimg = wx.DragImage(self.buffer)
+ self.dragimg.BeginDrag((0, 0), self)
+ self.dragimg.GetImageRect(moveto)
+ self.dragimg.Move(moveto)
+ self.dragimg.DoDrawImage(dc, moveto)
+ self.dragimg.EndDrag()
+ return True
+ def DragItem(self, id, event):
+ Drag an overlay decoration item
+ if id == 99 or id == '' or id == None: return
+ Debug.msg (5, "BufferedWindow.DragItem(): id=%d" % id)
+ x, y = self.lastpos
+ dx = event.GetX() - x
+ dy = event.GetY() - y
+ self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
+ r = self.pdc.GetIdBounds(id)
+ if id > 100: # text dragging
+ rtop = (r[0],r[1]-r[3],r[2],r[3])
+ r = r.Union(rtop)
+ rleft = (r[0]-r[2],r[1],r[2],r[3])
+ r = r.Union(rleft)
+ self.pdc.TranslateId(id, dx, dy)
+ r2 = self.pdc.GetIdBounds(id)
+ self.textdict[id]['coords'] = r2
+ r = r.Union(r2)
+ r.Inflate(4,4)
+ self.RefreshRect(r, False)
+ self.lastpos = (event.GetX(), event.GetY())
+ def MouseDraw(self, pdc=None, begin=None, end=None):
+ Mouse box or line from 'begin' to 'end'
+ If not given from self.mouse['begin'] to self.mouse['end'].
+ if not pdc:
+ return
+ if begin is None:
+ begin = self.mouse['begin']
+ if end is None:
+ end = self.mouse['end']
+ Debug.msg (5, "BufferedWindow.MouseDraw(): use=%s, box=%s, begin=%f,%f, end=%f,%f" % \
+ (self.mouse['use'], self.mouse['box'],
+ begin[0], begin[1], end[0], end[1]))
+ if self.mouse['box'] == "box":
+ boxid = wx.ID_NEW
+ mousecoords = [begin[0], begin[1],
+ end[0], end[1]]
+ r = pdc.GetIdBounds(boxid)
+ r.Inflate(4,4)
+ pdc.ClearId(boxid)
+ pdc.SetId(boxid)
+ self.Draw(pdc, drawid=boxid, pdctype='box', coords=mousecoords)
+ elif self.mouse['box'] == "line" or self.mouse['box'] == 'point':
+ self.lineid = wx.ID_NEW
+ mousecoords = [begin[0], begin[1], \
+ end[0], end[1]]
+ x1=min(begin[0],end[0])
+ x2=max(begin[0],end[0])
+ y1=min(begin[1],end[1])
+ y2=max(begin[1],end[1])
+ r = wx.Rect(x1,y1,x2-x1,y2-y1)
+ r.Inflate(4,4)
+ try:
+ pdc.ClearId(self.lineid)
+ except:
+ pass
+ pdc.SetId(self.lineid)
+ self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
+ def DrawLines(self, pdc=None, polycoords=None):
+ Draw polyline in PseudoDC
+ Set self.pline to wx.NEW_ID + 1
+ polycoords - list of polyline vertices, geographical coordinates
+ (if not given, self.polycoords is used)
+ if not pdc:
+ pdc = self.pdcTmp
+ if not polycoords:
+ polycoords = self.polycoords
+ if len(polycoords) > 0:
+ self.plineid = wx.ID_NEW + 1
+ # convert from EN to XY
+ coords = []
+ for p in polycoords:
+ coords.append(self.Cell2Pixel(p))
+ self.Draw(pdc, drawid=self.plineid, pdctype='polyline', coords=coords)
+ Debug.msg (4, "BufferedWindow.DrawLines(): coords=%s, id=%s" % \
+ (coords, self.plineid))
+ return self.plineid
+ return -1
+ def DrawCross(self, pdc, coords, size, rotation=0,
+ text=None, textAlign='lr', textOffset=(5, 5)):
+ """Draw cross in PseudoDC
+ @todo implement rotation
+ @param pdc PseudoDC
+ @param coord center coordinates
+ @param rotation rotate symbol
+ @param text draw also text (text, font, color, rotation)
+ @param textAlign alignment (default 'lower-right')
+ @textOffset offset for text (from center point)
+ Debug.msg(4, "BufferedWindow.DrawCross(): pdc=%s, coords=%s, size=%d" % \
+ (pdc, coords, size))
+ coordsCross = ((coords[0] - size, coords[1], coords[0] + size, coords[1]),
+ (coords[0], coords[1] - size, coords[0], coords[1] + size))
+ self.lineid = wx.NewId()
+ for lineCoords in coordsCross:
+ self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=lineCoords)
+ if not text:
+ return self.lineid
+ if textAlign == 'ul':
+ coord = [coords[0] - textOffset[0], coords[1] - textOffset[1], 0, 0]
+ elif textAlign == 'ur':
+ coord = [coords[0] + textOffset[0], coords[1] - textOffset[1], 0, 0]
+ elif textAlign == 'lr':
+ coord = [coords[0] + textOffset[0], coords[1] + textOffset[1], 0, 0]
+ else:
+ coord = [coords[0] - textOffset[0], coords[1] + textOffset[1], 0, 0]
+ self.Draw(pdc, img=text,
+ pdctype='text', coords=coord)
+ def MouseActions(self, event):
+ Mouse motion and button click notifier
+ if not self.processMouse:
+ return
+ ### if self.redrawAll is False:
+ ### self.redrawAll = True
+ # zoom with mouse wheel
+ if event.GetWheelRotation() != 0:
+ self.OnMouseWheel(event)
+ # left mouse button pressed
+ elif event.LeftDown():
+ self.OnLeftDown(event)
+ # left mouse button released
+ elif event.LeftUp():
+ self.OnLeftUp(event)
+ # dragging
+ elif event.Dragging():
+ self.OnDragging(event)
+ # double click
+ elif event.ButtonDClick():
+ self.OnButtonDClick(event)
+ # middle mouse button pressed
+ elif event.MiddleDown():
+ self.OnMiddleDown(event)
+ # right mouse button pressed
+ elif event.RightDown():
+ self.OnRightDown(event)
+ # right mouse button released
+ elif event.RightUp():
+ self.OnRightUp(event)
+ elif event.Moving():
+ self.OnMouseMoving(event)
+# event.Skip()
+ def OnMouseWheel(self, event):
+ Mouse wheel moved
+ self.processMouse = False
+ current = event.GetPositionTuple()[:]
+ wheel = event.GetWheelRotation()
+ Debug.msg (5, "BufferedWindow.MouseAction(): wheel=%d" % wheel)
+ # zoom 1/2 of the screen, centered to current mouse position (TODO: settings)
+ begin = (current[0] - self.Map.width / 4,
+ current[1] - self.Map.height / 4)
+ end = (current[0] + self.Map.width / 4,
+ current[1] + self.Map.height / 4)
+ if wheel > 0:
+ zoomtype = 1
+ else:
+ zoomtype = -1
+ # zoom
+ self.Zoom(begin, end, zoomtype)
+ # redraw map
+ self.UpdateMap()
+ ### self.OnPaint(None)
+ self.Refresh()
+# event.Skip()
+ def OnDragging(self, event):
+ Mouse dragging with left button down
+ Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
+ previous = self.mouse['begin']
+ move = (current[0] - previous[0],
+ current[1] - previous[1])
+ # dragging or drawing box with left button
+ if self.mouse['use'] == 'pan':
+ self.DragMap(move)
+ # dragging decoration overlay item
+ elif (self.mouse['use'] == 'pointer' and
+ not digitToolbar and
+ self.dragid != None):
+ self.DragItem(self.dragid, event)
+ # dragging anything else - rubber band box or line
+ else:
+ if (self.mouse['use'] == 'pointer' and
+ not digitToolbar): return
+ self.mouse['end'] = event.GetPositionTuple()[:]
+ digitClass = self.parent.digit
+ if (event.LeftIsDown() and
+ not (digitToolbar and
+ digitToolbar.GetAction() in ("moveLine",) and
+ digitClass.driver.GetSelected() > 0)):
+ # draw box only when left mouse button is pressed
+ self.MouseDraw(pdc=self.pdcTmp)
+# event.Skip()
+ Left mouse button pressed
+ Debug.msg (5, "BufferedWindow.OnLeftDown(): use=%s" % \
+ self.mouse["use"])
+ self.mouse['begin'] = event.GetPositionTuple()[:]
+ if self.mouse["use"] in ["measure", "profile"]:
+ # measure or profile
+ if len(self.polycoords) == 0:
+ self.mouse['end'] = self.mouse['begin']
+ self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
+ else:
+ self.mouse['begin'] = self.mouse['end']
+ elif self.mouse['use'] == 'zoom':
+ pass
+ elif self.mouse["use"] == "pointer" and self.parent.toolbars['vdigit']:
+ # digitization
+ east, north = self.Pixel2Cell(self.mouse['begin'])
+ try:
+ map = digitToolbar.GetLayer().GetName()
+ except:
+ map = None
+ wx.MessageBox(parent=self,
+ message=_("No vector map selected for editing."),
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ event.Skip()
+ return
+ # calculate position of 'update record' dialog
+ position = self.mouse['begin']
+ posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
+ position[1] + self.dialogOffset))
+ if digitToolbar.GetAction() not in ("moveVertex", "addVertex",
+ "removeVertex", "editLine"):
+ # set pen
+ self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+ self.polypen = wx.Pen(colour='dark green', width=2, style=wx.SOLID)
+ if digitToolbar.GetAction() in ("addVertex", "removeVertex"):
+ # unselect
+ digitClass.driver.SetSelected([])
+ if digitToolbar.GetAction() == "addLine":
+ if digitToolbar.GetAction('type') in ["point", "centroid"]:
+ # add new point
+ if digitToolbar.GetAction('type') == 'point':
+ point = True
+ else:
+ point = False
+ fid = digitClass.AddPoint(map, point, east, north)
+ if fid < 0:
+ return
+ self.UpdateMap(render=False) # redraw map
+ # add new record into atribute table
+ if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
+ # select attributes based on layer and category
+ cats = { fid : {
+ UserSettings.Get(group='vdigit', key="layer", subkey='value') :
+ (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
+ addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=map,
+ cats=cats,
+ pos=posWindow,
+ action="add")
+ if addRecordDlg.mapDBInfo and \
+ addRecordDlg.ShowModal() == wx.ID_OK:
+ sqlfile = tempfile.NamedTemporaryFile(mode="w")
+ for sql in addRecordDlg.GetSQLString():
+ sqlfile.file.write(sql + ";\n")
+ sqlfile.file.flush()
+ executeCommand = gcmd.Command(cmd=["db.execute",
+ "--q",
+ "input=%s" % sqlfile.name])
+ elif digitToolbar.GetAction('type') in ["line", "boundary"]:
+ # add new point to the line
+ self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
+ self.DrawLines(pdc=self.pdcTmp)
+ elif digitToolbar.GetAction() == "editLine" and hasattr(self, "vdigitMove"):
+ self.vdigitMove['id'].append(wx.NewId())
+ elif digitToolbar.GetAction() == "deleteLine":
+ pass
+ elif digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
+ not hasattr(self, "vdigitMove"):
+ self.vdigitMove = {}
+ # geographic coordinates of initial position (left-down)
+ self.vdigitMove['begin'] = None
+ # list of ids to modify
+ self.vdigitMove['id'] = []
+ # ids geographic coordinates
+ self.vdigitMove['coord'] = {}
+ if digitToolbar.GetAction() in ["moveVertex", "editLine"]:
+ # set pen
+ pcolor = UserSettings.Get(group='vdigit', key="symbol",
+ subkey=["highlight", "color"])
+ self.pen = self.polypen = wx.Pen(colour=pcolor,
+ width=2, style=wx.SHORT_DASH)
+ self.pdcTmp.SetPen(self.polypen)
+ elif digitToolbar.GetAction() == "splitLine":
+ # unselect
+ elif digitToolbar.GetAction() in ["displayAttrs", "displayCats"]:
+ qdist = digitClass.driver.GetThreshold(type='selectThresh')
+ coords = (east, north)
+ if digitClass.type == 'vdigit':
+ # unselect
+ # select feature by point
+ cats = {}
+ if digitClass.driver.SelectLineByPoint(coords,
+ digitClass.GetSelectType()) is not None:
+ if UserSettings.Get(group='vdigit', key='checkForDupl',
+ subkey='enabled'):
+ lines = digitClass.driver.GetSelected()
+ else:
+ lines = (digitClass.driver.GetSelected()[0],) # only first found
+ for line in lines:
+ cats[line] = digitClass.GetLineCats(line)
+ if digitToolbar.GetAction() == "displayAttrs":
+ # select attributes based on coordinates (all layers)
+ if self.parent.dialogs['attributes'] is None:
+ if digitClass.type == 'vedit':
+ self.parent.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self, map=map,
+ query=(coords, qdist),
+ pos=posWindow,
+ action="update")
+ else:
+ cats=cats,
+ action="update")
+ else:
+ # update currently open dialog
+ self.parent.dialogs['attributes'].UpdateDialog(query=(coords, qdist))
+ else:
+ # upgrade dialog
+ self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
+ if self.parent.dialogs['attributes']:
+ if len(cats.keys()) > 0:
+ # highlight feature & re-draw map
+ if not self.parent.dialogs['attributes'].IsShown():
+ self.parent.dialogs['attributes'].Show()
+ else:
+ if self.parent.dialogs['attributes'] and \
+ self.parent.dialogs['attributes'].IsShown():
+ self.parent.dialogs['attributes'].Hide()
+ else: # displayCats
+ if self.parent.dialogs['category'] is None:
+ # open new dialog
+ dlg = VDigitCategoryDialog(parent=self,
+ map=map,
+ pos=posWindow,
+ title=_("Update categories"))
+ self.parent.dialogs['category'] = dlg
+ else:
+ map=map,
+ cats=cats,
+ pos=posWindow,
+ else:
+ self.parent.dialogs['category'].UpdateDialog(query=(coords, qdist))
+ else:
+ # upgrade dialog
+ self.parent.dialogs['category'].UpdateDialog(cats=cats)
+ if self.parent.dialogs['category']:
+ ### digitClass.driver.SetSelected(line)
+ if not self.parent.dialogs['category'].IsShown():
+ self.parent.dialogs['category'].Show()
+ else:
+ if self.parent.dialogs['category'].IsShown():
+ self.parent.dialogs['category'].Hide()
+ elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
+ if not hasattr(self, "copyCatsList"):
+ self.copyCatsList = []
+ else:
+ self.copyCatsIds = []
+ self.mouse['box'] = 'box'
+ elif digitToolbar.GetAction() == "copyLine":
+ self.copyIds = []
+ self.layerTmp = None
+ elif digitToolbar.GetAction() == "zbulkLine":
+ if len(self.polycoords) > 1: # start new line
+ if len(self.polycoords) == 1:
+ begin = self.Pixel2Cell(self.polycoords[-1])
+ end = self.Pixel2Cell(self.mouse['end'])
+ else:
+ end = self.Pixel2Cell(self.polycoords[-1])
+ begin = self.Pixel2Cell(self.mouse['begin'])
+ self.DrawLines(self.pdcTmp, polycoords = [begin, end])
+ elif self.mouse['use'] == 'pointer':
+ # get decoration or text id
+ self.idlist = []
+ self.dragid = ''
+ self.lastpos = self.mouse['begin']
+ idlist = self.pdc.FindObjects(x=self.lastpos[0], y=self.lastpos[1],
+ radius=self.hitradius)
+ if 99 in idlist: idlist.remove(99)
+ if idlist != [] :
+ self.dragid = idlist[0] #drag whatever is on top
+ else:
+ pass
+ event.Skip()
+ Left mouse button released
+ Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
+ if self.mouse['use'] in ["zoom", "pan"]:
+ # set region in zoom or pan
+ if self.mouse['use'] == 'zoom':
+ # set region for click (zero-width box)
+ if begin[0] - end[0] == 0 or \
+ begin[1] - end[1] == 0:
+ # zoom 1/2 of the screen (TODO: settings)
+ begin = (end[0] - self.Map.width / 4,
+ end[1] - self.Map.height / 4)
+ end = (end[0] + self.Map.width / 4,
+ end[1] + self.Map.height / 4)
+ self.Zoom(begin, end, self.zoomtype)
+ # redraw map
+ elif self.mouse["use"] == "query":
+ # querying
+ self.parent.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
+ elif self.mouse["use"] == "queryVector":
+ # editable mode for vector map layers
+ self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
+ # clear temp canvas
+ self.UpdateMap(render=False, renderVector=False)
+ elif self.mouse["use"] in ["measure", "profile"]:
+ self.parent.MeasureDist(self.mouse['begin'], self.mouse['end'])
+ self.polycoords.append(self.Pixel2Cell(self.mouse['end']))
+ elif self.mouse["use"] == "pointer" and self.parent.gismanager.georectifying:
+ # -> georectifying
+ coord = self.Pixel2Cell(self.mouse['end'])
+ else:
+ self.parent.gismanager.georectifying.SetGCPData(coordtype, coord, self)
+ # digitization tool active
+ pos1 = self.Pixel2Cell(self.mouse['begin'])
+ pos2 = self.Pixel2Cell(self.mouse['end'])
+ if hasattr(self, "vdigitMove"):
+ if len(digitClass.driver.GetSelected()) == 0:
+ self.vdigitMove['begin'] = pos1 # left down
+ ### else:
+ ### dx = pos2[0] - pos1[0] ### ???
+ ### dy = pos2[1] - pos1[1]
+ ### self.vdigitMove = (self.vdigitMove['begin'][0] + dx,
+ ### self.vdigitMove['begin'][1] + dy)
+ # eliminate initial mouse moving efect
+ if digitToolbar.GetAction() in ["deleteLine", "moveLine", "moveVertex",
+ "copyCats", "copyAttrs", "editLine", "flipLine",
+ "mergeLine", "snapLine",
+ "queryLine", "breakLine", "typeConv", "connectLine"]:
+ nselected = 0
+ # -> delete line || move line || move vertex
+ nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
+ if digitToolbar.GetAction() == "editLine":
+ try:
+ selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
+ except IndexError:
+ selVertex = None
+ if selVertex:
+ # self.UpdateMap(render=False)
+ ids = digitClass.driver.GetSelected(grassId=False)
+ # move this line to tmp layer
+ for id in ids:
+ if id % 2: # register only vertices
+ e, n = self.Pixel2Cell(self.pdcVector.GetIdBounds(id)[0:2])
+ self.polycoords.append((e, n))
+ # self.pdcVector.RemoveId(id)
+ digitClass.driver.DrawSelected(False)
+ if selVertex < ids[-1] / 2:
+ # choose first or last node of line
+ self.vdigitMove['id'].reverse()
+ self.polycoords.reverse()
+ else:
+ # unselect
+ if not hasattr(self, "copyCatsIds"):
+ # 'from' -> select by point
+ nselected = digitClass.driver.SelectLineByPoint(pos1, digitClass.GetSelectType())
+ if nselected:
+ self.copyCatsList = digitClass.driver.GetSelected()
+ else:
+ # -> 'to' -> select by bbox
+ # return number of selected features (by box/point)
+ nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
+ if nselected == 0:
+ if digitClass.driver.SelectLineByPoint(pos1,
+ nselected = 1
+ if nselected > 0:
+ self.copyCatsIds = digitClass.driver.GetSelected()
+ elif digitToolbar.GetAction() == "queryLine":
+ selected = digitClass.SelectLinesByQuery(pos1, pos2)
+ nselected = len(selected)
+ if nselected > 0:
+ digitClass.driver.SetSelected(selected)
+ else:
+ # -> moveLine || deleteLine, etc. (select by point/box)
+ if digitToolbar.GetAction() == 'moveLine' and \
+ len(digitClass.driver.GetSelected()) > 0:
+ nselected = 0
+ else:
+ drawSeg = True
+ else:
+ drawSeg = False
+ digitClass.GetSelectType(),
+ drawSeg)
+ nselected = 1
+ if nselected > 0:
+ if digitToolbar.GetAction() in ["moveLine", "moveVertex"]:
+ # get pseudoDC id of objects which should be redrawn
+ if digitToolbar.GetAction() == "moveLine":
+ # -> move line
+ self.vdigitMove['id'] = digitClass.driver.GetSelected(grassId=False)
+ self.vdigitMove['coord'] = digitClass.driver.GetSelectedCoord()
+ elif digitToolbar.GetAction() == "moveVertex":
+ # -> move vertex
+ self.vdigitMove['id'] = digitClass.driver.GetSelectedVertex(pos1)
+ if len(self.vdigitMove['id']) == 0: # no vertex found
+ # check for duplicates
+ if UserSettings.Get(group='vdigit', key='checkForDupl', subkey='enabled') is True:
+ dupl = digitClass.driver.GetDuplicates()
+ if dupl:
+ posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
+ self.mouse['end'][1] + self.dialogOffset))
+ dlg = VDigitDuplicatesDialog(parent=self, data=dupl, pos=posWindow)
+ if dlg.ShowModal() == wx.ID_OK:
+ digitClass.driver.UnSelect(dlg.GetUnSelected())
+ # update selected
+ if digitToolbar.GetAction() != "editLine":
+ # -> move line || move vertex
+ else: # no vector object found
+ if not (digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
+ len(self.vdigitMove['id']) > 0):
+ # avoid left-click when features are already selected
+ elif digitToolbar.GetAction() in ["splitLine", "addVertex", "removeVertex"]:
+ pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
+ type=VDigit_Lines_Type)
+ if pointOnLine:
+ if digitToolbar.GetAction() in ["splitLine", "addVertex"]:
+ self.UpdateMap(render=False) # highlight object
+ self.DrawCross(pdc=self.pdcTmp, coords=self.Cell2Pixel(pointOnLine),
+ size=5)
+ elif digitToolbar.GetAction() == "removeVertex":
+ # get only id of vertex
+ try:
+ id = digitClass.driver.GetSelectedVertex(pos1)[0]
+ id = None
+ if id:
+ x, y = self.pdcVector.GetIdBounds(id)[0:2]
+ self.pdcVector.RemoveId(id)
+ self.DrawCross(pdc=self.pdcTmp, coords=(x, y),
+ size=5)
+ else:
+ # unselect
+ if UserSettings.Get(group='vdigit', key='bgmap',
+ subkey='value', internal=True) == '':
+ # no background map -> copy from current vector map layer
+ if nselected > 0:
+ # highlight selected features
+ else:
+ else:
+ # copy features from background map
+ self.copyIds = digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
+ if len(self.copyIds) > 0:
+ color = UserSettings.Get(group='vdigit', key='symbol',
+ subkey=['highlight', 'color'])
+ colorStr = str(color[0]) + ":" + \
+ str(color[1]) + ":" + \
+ str(color[2])
+ dVectTmp = ['d.vect',
+ 'map=%s' % UserSettings.Get(group='vdigit', key='bgmap',
+ subkey='value', internal=True),
+ 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
+ '-i',
+ 'color=%s' % colorStr,
+ 'fcolor=%s' % colorStr,
+ 'type=point,line,boundary,centroid',
+ 'width=2']
+ self.layerTmp = self.Map.AddLayer(type='vector',
+ name=globalvar.QUERYLAYER,
+ command=dVectTmp)
+ self.UpdateMap(render=True, renderVector=False)
+ else:
+ self.redrawAll = None
+ elif digitToolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
+ # select lines to be labeled
+ pos1 = self.polycoords[0]
+ pos2 = self.polycoords[1]
+ if nselected > 0:
+ self.DrawLines(pdc=self.pdcTmp) # redraw temp line
+ else:
+ elif digitToolbar.GetAction() == "connectLine":
+ if len(digitClass.driver.GetSelected()) > 0:
+ self.dragid >= 0):
+ # end drag of overlay decoration
+ if self.dragid < 99 and self.overlays.has_key(self.dragid):
+ self.overlays[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
+ elif self.dragid > 100 and self.textdict.has_key(self.dragid):
+ self.textdict[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
+ else:
+ pass
+ self.dragid = None
+# self.UpdateMap(render=True)
+ else:
+ pass
+# event.Skip()
+ def OnButtonDClick(self, event):
+ Mouse button double click
+ Debug.msg (5, "BufferedWindow.OnButtonDClick(): use=%s" % \
+ # measure
+ self.Refresh()
+ elif self.mouse["use"] == "profile":
+ # profile
+ pass
+ # self.pdc.ClearId(self.lineid)
+ # self.pdc.ClearId(self.plineid)
+ # print 'coordinates: ',self.polycoords
+ # self.polycoords = []
+ # self.mouse['begin'] = self.mouse['end'] = [0, 0]
+ # self.Refresh()
+ elif self.mouse['use'] == 'pointer' and self.parent.toolbars['vdigit']:
+ pass
+ else:
+ # select overlay decoration options dialog
+ clickposition = event.GetPositionTuple()[:]
+ idlist = self.pdc.FindObjects(clickposition[0], clickposition[1], self.hitradius)
+ if idlist == []:
+ return
+ # self.ovlcoords[self.dragid] = self.pdc.GetIdBounds(self.dragid)
+ if self.dragid > 100:
+ self.currtxtid = self.dragid
+ self.parent.OnAddText(None)
+ elif self.dragid == 0:
+ self.parent.OnAddBarscale(None)
+ elif self.dragid == 1:
+ self.parent.OnAddLegend(None)
+# event.Skip()
+ def OnRightDown(self, event):
+ Right mouse button pressed
+ Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
+ if digitToolbar:
+ # digitization tool (confirm action)
+ if digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
+ hasattr(self, "vdigitMove"):
+ pFrom = self.vdigitMove['begin']
+ pTo = self.Pixel2Cell(event.GetPositionTuple())
+ move = (pTo[0] - pFrom[0],
+ pTo[1] - pFrom[1])
+ # move line
+ if digitClass.MoveSelectedLines(move) < 0:
+ return
+ # move vertex
+ if digitClass.MoveSelectedVertex(pFrom, move) < 0:
+ return
+ event.Skip()
+ def OnRightUp(self, event):
+ Right mouse button released
+ Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
+ if digitToolbar:
+ if digitToolbar.GetAction() == "addLine" and \
+ digitToolbar.GetAction('type') in ["line", "boundary"]:
+ # -> add new line / boundary
+ try:
+ except:
+ map = None
+ if map:
+ # mapcoords = []
+ # xy -> EN
+ # for coord in self.polycoords:
+ # mapcoords.append(self.Pixel2Cell(coord))
+ if digitToolbar.GetAction('type') == 'line':
+ line = True
+ else:
+ line = False
+ if len(self.polycoords) < 2: # ignore 'one-point' lines
+ return
+ fid = digitClass.AddLine(map, line, self.polycoords)
+ if fid < 0:
+ return
+ position = self.Cell2Pixel(self.polycoords[-1])
+ self.Refresh()
+ cats = { fid : {
+ cats=cats,
+ pos=posWindow,
+ action="add")
+ "--q",
+ # -> delete selected vector features
+ if digitClass.DeleteSelectedLines() < 0:
+ return
+ # split line
+ if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ return
+ elif digitToolbar.GetAction() == "addVertex":
+ # add vertex
+ if digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ return
+ # remove vertex
+ if digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ return
+ try:
+ if digitToolbar.GetAction() == 'copyCats':
+ if digitClass.CopyCats(self.copyCatsList,
+ self.copyCatsIds, copyAttrb=False) < 0:
+ return
+ else:
+ self.copyCatsIds, copyAttrb=True) < 0:
+ return
+ del self.copyCatsList
+ del self.copyCatsIds
+ except AttributeError:
+ pass
+ elif digitToolbar.GetAction() == "editLine" and \
+ line = digitClass.driver.GetSelected()
+ if digitClass.EditLine(line, self.polycoords) < 0:
+ return
+ elif digitToolbar.GetAction() == "flipLine":
+ if digitClass.FlipLine() < 0:
+ return
+ elif digitToolbar.GetAction() == "mergeLine":
+ if digitClass.MergeLine() < 0:
+ return
+ elif digitToolbar.GetAction() == "breakLine":
+ if digitClass.BreakLine() < 0:
+ return
+ elif digitToolbar.GetAction() == "snapLine":
+ if digitClass.SnapLine() < 0:
+ return
+ if len(digitClass.driver.GetSelected()) > 1:
+ if digitClass.ConnectLine() < 0:
+ return
+ if digitClass.CopyLine(self.copyIds) < 0:
+ return
+ del self.copyIds
+ if self.layerTmp:
+ self.Map.DeleteLayer(self.layerTmp)
+ del self.layerTmp
+ selected = digitClass.driver.GetSelected()
+ dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
+ nselected=len(selected))
+ if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
+ dlg.step.GetValue()) < 0:
+ return
+ self.UpdateMap(render=False, renderVector=True)
+ elif digitToolbar.GetAction() == "typeConv":
+ # -> feature type conversion
+ # - point <-> centroid
+ # - line <-> boundary
+ if digitClass.TypeConvForSelectedLines() < 0:
+ return
+ if digitToolbar.GetAction() != "addLine":
+ # unselect and re-render
+ self.Refresh()
+ event.Skip()
+ def OnMiddleDown(self, event):
+ Middle mouse button pressed
+ if self.mouse["use"] == "pointer" and digitToolbar:
+ if (digitToolbar.GetAction() == "addLine" and \
+ digitToolbar.GetAction('type') in ["line", "boundary"]) or \
+ digitToolbar.GetAction() == "editLine":
+ # add line or boundary -> remove last point from the line
+ try:
+ removed = self.polycoords.pop()
+ Debug.msg(4, "BufferedWindow.OnMiddleDown(): polycoords_poped=%s" % \
+ [removed,])
+ self.mouse['begin'] = self.Cell2Pixel(self.polycoords[-1])
+ except:
+ pass
+ # remove last vertex & line
+ if len(self.vdigitMove['id']) > 1:
+ self.vdigitMove['id'].pop()
+ elif digitToolbar.GetAction() in ["deleteLine", "moveLine", "splitLine",
+ "addVertex", "removeVertex", "moveVertex",
+ "copyCats", "flipLine", "mergeLine",
+ "snapLine", "connectLine", "copyLine",
+ "queryLine", "breakLine", "typeConv"]:
+ # varios tools -> unselected selected features
+ if digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
+ elif digitToolbar.GetAction() == "copyCats":
+ try:
+ pass
+ del self.copyIds
+ if self.layerTmp:
+ del self.layerTmp
+ self.UpdateMap(render=False) # render vector
+ # reset polyline
+ def OnMouseMoving(self, event):
+ Motion event and no mouse buttons were pressed
+ Debug.msg (5, "BufferedWindow.OnMouseMoving(): coords=%f,%f" % \
+ (self.mouse['end'][0], self.mouse['end'][1]))
+ if digitToolbar.GetAction() == "addLine" and digitToolbar.GetAction('type') in ["line", "boundary"]:
+ self.MouseDraw(pdc=self.pdcTmp, begin=self.Cell2Pixel(self.polycoords[-1]))
+ elif digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] \
+ and hasattr(self, "vdigitMove"):
+ dx = self.mouse['end'][0] - self.mouse['begin'][0]
+ dy = self.mouse['end'][1] - self.mouse['begin'][1]
+ if len(self.vdigitMove['id']) > 0:
+ # draw lines on new position
+ # move line
+ self.pdcTmp.TranslateId(id, dx, dy)
+ elif digitToolbar.GetAction() in ["moveVertex", "editLine"]:
+ # move vertex ->
+ # (vertex, left vertex, left line,
+ # right vertex, right line)
+ # do not draw static lines
+ if digitToolbar.GetAction() == "moveVertex":
+ ### self.pdcTmp.TranslateId(self.vdigitMove['id'][0], dx, dy)
+ self.pdcTmp.RemoveId(self.vdigitMove['id'][0])
+ if self.vdigitMove['id'][1] > 0: # previous vertex
+ x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][1])[0:2])
+ self.pdcTmp.RemoveId(self.vdigitMove['id'][1]+1)
+ self.polycoords.append((x, y))
+ ### x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][0])[0:2])
+ if self.vdigitMove['id'][2] > 0: # next vertex
+ x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][2])[0:2])
+ self.pdcTmp.RemoveId(self.vdigitMove['id'][2]-1)
+ else: # edit line
+ try:
+ if self.vdigitMove['id'][-1] > 0: # previous vertex
+ begin=self.Cell2Pixel(self.polycoords[-1]))
+ except: # no line
+ self.Refresh() # TODO: use RefreshRect()
+ # draw mouse moving
+ self.MouseDraw(self.pdcTmp)
+ event.Skip()
+ def ClearLines(self, pdc=None):
+ Clears temporary drawn lines from PseudoDC
+ if not pdc:
+ pdc=self.pdcTmp
+ try:
+ pdc.RemoveId(self.lineid)
+ except:
+ pass
+ try:
+ pdc.ClearId(self.plineid)
+ pdc.RemoveId(self.plineid)
+ except:
+ pass
+ Debug.msg(4, "BufferedWindow.ClearLines(): lineid=%s, plineid=%s" %
+ (self.lineid, self.plineid))
+ return True
+ def Pixel2Cell(self, (x, y)):
+ Convert image coordinates to real word coordinates
+ Input : int x, int y
+ Output: float x, float y
+ try:
+ x = int(x)
+ y = int(y)
+ except:
+ return None
+ if self.Map.region["ewres"] > self.Map.region["nsres"]:
+ res = self.Map.region["ewres"]
+ else:
+ res = self.Map.region["nsres"]
+ w = self.Map.region["center_easting"] - (self.Map.width / 2) * res
+ n = self.Map.region["center_northing"] + (self.Map.height / 2) * res
+ east = w + x * res
+ north = n - y * res
+ # extent does not correspond with whole map canvas area...
+ # east = self.Map.region['w'] + x * self.Map.region["ewres"]
+ # north = self.Map.region['n'] - y * self.Map.region["nsres"]
+ return (east, north)
+ def Cell2Pixel(self, (east, north)):
+ Convert real word coordinates to image coordinates
+ try:
+ east = float(east)
+ north = float(north)
+ except:
+ return None
+ else:
+ # x = int((east - w) / res)
+ # y = int((n - north) / res)
+ x = (east - w) / res
+ y = (n - north) / res
+ return (x, y)
+ def Zoom(self, begin, end, zoomtype):
+ Calculates new region while (un)zoom/pan-ing
+ x1, y1 = begin
+ x2, y2 = end
+ newreg = {}
+ # threshold - too small squares do not make sense
+ # can only zoom to windows of > 5x5 screen pixels
+ if abs(x2-x1) > 5 and abs(y2-y1) > 5 and zoomtype != 0:
+ if x1 > x2:
+ x1, x2 = x2, x1
+ if y1 > y2:
+ y1, y2 = y2, y1
+ # zoom in
+ if zoomtype > 0:
+ newreg['w'], newreg['n'] = self.Pixel2Cell((x1, y1))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((x2, y2))
+ # zoom out
+ elif zoomtype < 0:
+ newreg['w'], newreg['n'] = self.Pixel2Cell((-x1 * 2, -y1 * 2))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + 2 * \
+ (self.Map.width - x2),
+ self.Map.height + 2 * \
+ (self.Map.height - y2)))
+ # pan
+ elif zoomtype == 0:
+ dx = x1 - x2
+ dy = y1 - y2
+ newreg['w'], newreg['n'] = self.Pixel2Cell((dx, dy))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + dx,
+ self.Map.height + dy))
+ # if new region has been calculated, set the values
+ if newreg != {}:
+ # LL locations
+ if self.parent.Map.projinfo['proj'] == 'll':
+ if newreg['n'] > 90.0:
+ newreg['n'] = 90.0
+ if newreg['s'] < -90.0:
+ newreg['s'] = -90.0
+ ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
+ cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
+ # xo = self.Cell2Pixel((self.Map.region['center_easting'], self.Map.region['center_northing']))
+ # xn = self.Cell2Pixel(ce, cn))
+ tmp = self.Pixel2Cell(self.mouse['end'])
+ # calculate new center point and display resolution
+ self.Map.region['center_easting'] = ce
+ self.Map.region['center_northing'] = cn
+ self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
+ self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
+ self.Map.AlignExtentFromDisplay()
+ tmp1 = self.mouse['end']
+ tmp2 = self.Cell2Pixel(self.vdigitMove['begin'])
+ dx = tmp1[0] - tmp2[0]
+ dy = tmp1[1] - tmp2[1]
+ self.vdigitMove['beginDiff'] = (dx, dy)
+ self.pdcTmp.RemoveId(id)
+ self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
+ self.Map.region['e'], self.Map.region['w'])
+ if self.redrawAll is False:
+ def ZoomBack(self):
+ Zoom to previous extents in zoomhistory list
+ zoom = []
+ if len(self.zoomhistory) > 1:
+ self.zoomhistory.pop()
+ zoom = self.zoomhistory[len(self.zoomhistory)-1]
+ # (n, s, e, w)
+ if zoom:
+ # zoom to selected region
+ self.Map.region['center_easting'] = zoom[3] + \
+ (zoom[2] - zoom[3]) / 2
+ self.Map.region['center_northing'] = zoom[1] + \
+ (zoom[0] - zoom[1]) / 2
+ self.Map.region["ewres"] = (zoom[2] - zoom[3]) / self.Map.width
+ self.Map.region["nsres"] = (zoom[0] - zoom[1]) / self.Map.height
+ # update map
+ self.UpdateMap()
+ def ZoomHistory(self, n, s, e, w):
+ Manages a list of last 10 zoom extents
+ Return removed history item if exists
+ removed = None
+ self.zoomhistory.append((n,s,e,w))
+ if len(self.zoomhistory) > 10:
+ removed = self.zoomhistory.pop(0)
+ if removed:
+ Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s, removed=%s" %
+ (self.zoomhistory, removed))
+ else:
+ Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s" %
+ (self.zoomhistory))
+ return removed
+ Set display extents to match selected raster (including NULLs)
+ or vector map.
+ self.ZoomToMap()
+ Set display extents to match selected raster map (ignore NULLs)
+ self.ZoomToMap(zoom=True)
+ def ZoomToMap(self, layer = None, zoom = False):
+ or vector map.
+ zoomreg = {}
+ if not layer:
+ layer = self.GetSelectedLayer(multi = True)
+ if not layer:
+ return
+ rast = []
+ vect = []
+ updated = False
+ for l in layer:
+ # only raster/vector layers are currently supported
+ if l.type == 'raster':
+ rast.append(l.name)
+ elif l.type == 'vector':
+ if self.parent.digit and l.name == self.parent.digit.map and \
+ self.parent.digit.type == 'vdigit':
+ w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
+ self.Map.GetRegion(n=n, s=s, w=w, e=e,
+ update=True)
+ updated = True
+ else:
+ vect.append(l.name)
+ if not updated:
+ self.Map.GetRegion(rast = rast,
+ vect = vect,
+ update = True)
+ self.UpdateMap()
+ def ZoomToWind(self, event):
+ Set display geometry to match computational
+ region settings (set with g.region)
+ self.Map.region = self.Map.GetRegion()
+ ### self.Map.SetRegion(windres=True)
+ self.UpdateMap()
+ def ZoomToDefault(self, event):
+ Set display geometry to match default region settings
+ self.Map.region = self.Map.GetRegion(default=True)
+ self.Map.AdjustRegion() # aling region extent to the display
+ self.UpdateMap()
+ def DisplayToWind(self, event):
+ Set computational region (WIND file) to
+ match display extents
+ tmpreg = os.getenv("GRASS_REGION")
+ if tmpreg:
+ del os.environ["GRASS_REGION"]
+ # We ONLY want to set extents here. Don't mess with resolution. Leave that
+ # for user to set explicitly with g.region
+ new = self.Map.AlignResolution()
+ cmdRegion = ["g.region", "--o",
+ "n=%f" % new['n'],
+ "s=%f" % new['s'],
+ "e=%f" % new['e'],
+ "w=%f" % new['w'],
+ "rows=%d" % int(new['rows']),
+ "cols=%d" % int(new['cols'])]
+ p = gcmd.Command(cmdRegion)
+ if tmpreg:
+ os.environ["GRASS_REGION"] = tmpreg
+ def ZoomToSaved(self, event):
+ """!Set display geometry to match extents in
+ saved region file
+ dlg = gdialogs.SavedRegion(parent = self, id = wx.ID_ANY,
+ title = _("Zoom to saved region extents"),
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_DIALOG_STYLE,
+ loadsave='load')
+ if dlg.ShowModal() == wx.ID_CANCEL:
+ dlg.Destroy()
+ return
+ wind = dlg.wind
+ self.Map.GetRegion(regionName = wind,
+ update = True)
+ dlg.Destroy()
+ self.Map.region['s'],
+ self.Map.region['w'])
+ self.UpdateMap()
+ def SaveDisplayRegion(self, event):
+ Save display extents to named region file.
+ title = _("Save display extents to region file"),
+ loadsave='save')
+ dlg.Destroy()
+ return
+ wind = dlg.wind
+ # test to see if it already exists and ask permission to overwrite
+ windpath = os.path.join(self.Map.env["GISDBASE"], self.Map.env["LOCATION_NAME"],
+ self.Map.env["MAPSET"], "windows", wind)
+ if windpath and not os.path.exists(windpath):
+ self.SaveRegion(wind)
+ elif windpath and os.path.exists(windpath):
+ overwrite = wx.MessageBox(_("Region file <%s> already exists. "
+ "Do you want to overwrite it?") % (wind),
+ _("Warning"), wx.YES_NO | wx.CENTRE)
+ if (overwrite == wx.YES):
+ else:
+ pass
+ dlg.Destroy()
+ def SaveRegion(self, wind):
+ Save region settings
+ ### new = self.Map.AlignResolution()
+ new = self.Map.GetCurrentRegion()
+ "-u",
+ "rows=%d" % new['rows'],
+ "cols=%d" % new['cols'],
+ "save=%s" % wind,
+ "--o"]
+ if tmpreg:
+ if tmpreg:
+ def Distance(self, beginpt, endpt, screen=True):
+ """Calculete distance
+ LL-locations not supported
+ @todo Use m.distance
+ @param beginpt first point
+ @param endpt second point
+ @param screen True for screen coordinates otherwise EN
+ x1, y1 = beginpt
+ x2, y2 = endpt
+ if screen:
+ dEast = (x2 - x1) * self.Map.region["ewres"]
+ dNorth = (y2 - y1) * self.Map.region["nsres"]
+ else:
+ dEast = (x2 - x1)
+ return (math.sqrt(math.pow((dEast),2) + math.pow((dNorth),2)), (dEast, dNorth))
+class MapFrame(wx.Frame):
+ Main frame for map display window. Drawing takes place in child double buffered
+ drawing window.
+ def __init__(self, parent=None, id=wx.ID_ANY, title=_("GRASS GIS - Map display"),
+ style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
+ tree=None, notebook=None, gismgr=None, page=None,
+ Map=None, auimgr=None):
+ Main map display window with toolbars, statusbar and
+ DrawWindow
+ @param toolbars array of activated toolbars, e.g. ['map', 'digit']
+ @param tree reference to layer tree
+ @param notebook control book ID in Layer Manager
+ @param gismgr Layer Manager panel
+ @param page notebook page with layer tree
+ @param Map instance of render.Map
+ self.gismanager = gismgr # GIS Manager object
+ self.Map = Map # instance of render.Map
+ self.tree = tree # GIS Manager layer tree object
+ self.page = page # Notebook page holding the layer tree
+ self.layerbook = notebook # GIS Manager layer tree notebook
+ # available cursors
+ self.cursors = {
+ # default: cross
+ # "default" : wx.StockCursor(wx.CURSOR_DEFAULT),
+ "default" : wx.StockCursor(wx.CURSOR_ARROW),
+ "cross" : wx.StockCursor(wx.CURSOR_CROSS),
+ "hand" : wx.StockCursor(wx.CURSOR_HAND),
+ "pencil" : wx.StockCursor(wx.CURSOR_PENCIL),
+ "sizenwse": wx.StockCursor(wx.CURSOR_SIZENWSE)
+ wx.Frame.__init__(self, parent, id, title, pos, size, style)
+ self.SetName("MapWindow")
+ # set the size & system icon
+ self.SetClientSize(size)
+ self.iconsize = (16, 16)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
+ # Fancy gui
+ # self._mgr = auimgr
+ self._mgr = wx.aui.AuiManager(self)
+ # Add toolbars
+ self.toolbars = { 'map' : None,
+ 'vdigit' : None,
+ 'georect' : None,
+ 'nviz' : None }
+ for toolb in toolbars:
+ self.AddToolbar(toolb)
+ # Add statusbar
+ self.statusbar = self.CreateStatusBar(number=4, style=0)
+ self.statusbar.SetStatusWidths([-5, -2, -1, -1])
+ self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
+ choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+ self.toggleStatus.SetSelection(UserSettings.Get(group='display', key='statusbarMode', subkey='selection'))
+ self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.toggleStatus)
+ # auto-rendering checkbox
+ self.autoRender = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Render"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.autoRender)
+ self.autoRender.SetValue(UserSettings.Get(group='display', key='autoRendering', subkey='enabled'))
+ self.autoRender.SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
+ # show region
+ self.showRegion = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Show computational extent"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.showRegion)
+ self.showRegion.SetValue(False)
+ self.showRegion.Hide()
+ self.showRegion.SetToolTip(wx.ToolTip (_("Show/hide computational "
+ "region extent (set with g.region). "
+ "Display region drawn as a blue box inside the "
+ "computational region, "
+ "computational region inside a display region "
+ "as a red box).")))
+ # set resolution
+ self.compResolution = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Constrain display resolution to computational settings"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.compResolution)
+ self.compResolution.SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+ self.compResolution.Hide()
+ self.compResolution.SetToolTip(wx.ToolTip (_("Constrain display resolution "
+ "to computational region settings. "
+ "Default value for new map displays can "
+ "be set up in 'User GUI settings' dialog.")))
+ # map scale
+ self.mapScale = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
+ value="", style=wx.TE_PROCESS_ENTER,
+ size=(150, -1))
+ self.mapScale.Hide()
+ self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.mapScale)
+ # mask
+ self.maskInfo = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
+ label = '')
+ self.maskInfo.SetForegroundColour(wx.Colour(255, 0, 0))
+ # on-render gauge
+ self.onRenderGauge = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
+ range=0, style=wx.GA_HORIZONTAL)
+ self.onRenderGauge.Hide()
+ self.StatusbarReposition() # reposition statusbar
+ # Init map display (buffered DC & set default cursor)
+ self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,
+ Map=self.Map, tree=self.tree, gismgr=self.gismanager)
+ # default is 2D display mode
+ self.MapWindow = self.MapWindow2D
+ self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.MapWindow.SetCursor(self.cursors["default"])
+ # used by Nviz (3D display mode)
+ self.MapWindow3D = None
+ # initialize region values
+ self.__InitDisplay()
+ # Bind various events
+ self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+ self.Bind(render.EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
+ # Update fancy gui style
+ self._mgr.AddPane(self.MapWindow, wx.aui.AuiPaneInfo().CentrePane().
+ Dockable(False).BestSize((-1,-1)).
+ CloseButton(False).DestroyOnClose(True).
+ Layer(0))
+ self._mgr.Update()
+ # Init print module and classes
+ self.printopt = disp_print.PrintOptions(self, self.MapWindow)
+ # Initialization of digitization tool
+ self.digit = None
+ # Init zoom history
+ self.MapWindow.ZoomHistory(self.Map.region['n'],
+ # Re-use dialogs
+ self.dialogs = {}
+ self.dialogs['attributes'] = None
+ self.dialogs['category'] = None
+ self.dialogs['barscale'] = None
+ self.dialogs['legend'] = None
+ self.decorationDialog = None # decoration/overlays
+ def AddToolbar(self, name):
+ Add defined toolbar to the window
+ Currently known toolbars are:
+ - map basic map toolbar
+ - digit vector digitizer
+ - georect georectifier
+ # default toolbar
+ if name == "map":
+ self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
+ self._mgr.AddPane(self.toolbars['map'].toolbar,
+ wx.aui.AuiPaneInfo().
+ Name("maptoolbar").Caption(_("Map Toolbar")).
+ ToolbarPane().Top().
+ LeftDockable(False).RightDockable(False).
+ BottomDockable(False).TopDockable(True).
+ CloseButton(False).Layer(2).
+ BestSize((self.toolbars['map'].GetToolbar().GetSize())))
+ # vector digitizer
+ elif name == "vdigit":
+ from vdigit import haveVDigit
+ if not haveVDigit:
+ from vdigit import errorMsg
+ msg = _("Unable to start vector digitizer.\nThe VDigit python extension "
+ "was not found or loaded properly.\n"
+ "Switching back to 2D display mode.\n\nDetails: %s" % errorMsg)
+ self.toolbars['map'].combo.SetValue (_("2D view"))
+ message=msg,
+ style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ return
+ self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, map=self.Map,
+ layerTree=self.tree,
+ log=self.gismanager.goutput)
+ for toolRow in range(0, self.toolbars['vdigit'].numOfRows):
+ self._mgr.AddPane(self.toolbars['vdigit'].toolbar[toolRow],
+ Name("vdigittoolbar" + str(toolRow)).Caption(_("Vector digitizer toolbar")).
+ ToolbarPane().Top().Row(toolRow + 1).
+ BestSize((self.toolbars['vdigit'].GetToolbar().GetSize())))
+ # change mouse to draw digitized line
+ self.MapWindow.mouse['box'] = "point"
+ self.MapWindow.zoomtype = 0
+ self.MapWindow.pen = wx.Pen(colour='red', width=2, style=wx.SOLID)
+ self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SOLID)
+ # georectifier
+ elif name == "georect":
+ self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
+ self._mgr.AddPane(self.toolbars['georect'].toolbar,
+ Name("georecttoolbar").Caption(_("Georectification toolbar")).
+ CloseButton(False).Layer(2))
+ # nviz
+ elif name == "nviz":
+ import nviz
+ # check for GLCanvas and OpenGL
+ msg = None
+ if not nviz.haveGLCanvas:
+ msg = _("Unable to switch to 3D display mode.\nThe GLCanvas class has not been "
+ "included with this build "
+ "of wxPython!\nSwitching back to "
+ "2D display mode.\n\nDetails: %s" % nviz.errorMsg)
+ if not nviz.haveNviz:
+ msg = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
+ "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg)
+ if msg:
+ message=msg,
+ return
+ # add Nviz toolbar and disable 2D display mode tools
+ self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
+ self.toolbars['map'].Enable2D(False)
+ # update layer tree (-> enable 3d-rasters)
+ self.tree.EnableItemType(type='3d-raster', enable=True)
+ # update status bar
+ self.toggleStatus.Enable(False)
+ # erase map window
+ self.MapWindow.EraseMap()
+ busy = wx.BusyInfo(message=_("Please wait, loading data..."),
+ parent=self)
+ wx.Yield()
+ # create GL window & NVIZ toolbar
+ if not self.MapWindow3D:
+ self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY,
+ self.nvizToolWin = nviz.NvizToolWindow(self, id=wx.ID_ANY,
+ mapWindow=self.MapWindow3D)
+ self.MapWindow3D.OnPaint(None) # -> LoadData
+ self.MapWindow3D.Show()
+ self.MapWindow3D.UpdateView(None)
+ busy.Destroy()
+ self.nvizToolWin.Show()
+ # switch from MapWindow to MapWindowGL
+ # add nviz toolbar
+ self._mgr.DetachPane(self.MapWindow2D)
+ self.MapWindow2D.Hide()
+ self._mgr.AddPane(self.MapWindow3D, wx.aui.AuiPaneInfo().CentrePane().
+ Layer(0))
+ self._mgr.AddPane(self.toolbars['nviz'].toolbar,
+ Name("nviztoolbar").Caption(_("Nviz toolbar")).
+ ToolbarPane().Top().Row(1).
+ self.MapWindow = self.MapWindow3D
+ self.SetStatusText("", 0)
+ def RemoveToolbar (self, name):
+ Removes toolbar from the window
+ TODO: Only hide, activate by calling AddToolbar()
+ # cannot hide main toolbar
+ if name == "map":
+ return
+ # TODO: not destroy only hide
+ self._mgr.DetachPane (self.toolbars['vdigit'].toolbar[toolRow])
+ self.toolbars['vdigit'].toolbar[toolRow].Destroy()
+ else:
+ self._mgr.DetachPane (self.toolbars[name].toolbar)
+ self.toolbars[name].toolbar.Destroy()
+ self.toolbars[name] = None
+ if name == 'nviz':
+ # hide nviz tools
+ self.nvizToolWin.Hide()
+ # unload data
+# self.MapWindow3D.Reset()
+ # switch from MapWindowGL to MapWindow
+ self._mgr.DetachPane(self.MapWindow3D)
+ self.MapWindow3D.Hide()
+ self.MapWindow2D.Show()
+ self._mgr.AddPane(self.MapWindow2D, wx.aui.AuiPaneInfo().CentrePane().
+ Layer(0))
+ # update layer tree (-> disable 3d-rasters)
+ self.tree.EnableItemType(type='3d-raster', enable=False)
+ self.MapWindow.UpdateMap()
+ self.toolbars['map'].Enable2D(True)
+ self.toggleStatus.Enable(True)
+ def __InitDisplay(self):
+ Initialize map display, set dimensions and map region
+ self.width, self.height = self.GetClientSize()
+ Debug.msg(2, "MapFrame.__InitDisplay():")
+ self.Map.region = self.Map.GetRegion() # g.region -upgc
+ # self.Map.SetRegion() # adjust region to match display window
+ def OnUpdateProgress(self, event):
+ Update progress bar info
+ self.onRenderGauge.SetValue(event.value)
+ event.Skip()
+ def OnFocus(self, event):
+ Change choicebook page to match display.
+ Or set display for georectifying
+ if self.gismanager.georectifying:
+ # in georectifying session; display used to get get geographic
+ # coordinates for GCPs
+ self.OnPointer(event)
+ else:
+ # change bookcontrol page to page associated with display
+ if self.page:
+ pgnum = self.layerbook.GetPageIndex(self.page)
+ if pgnum > -1:
+ self.layerbook.SetSelection(pgnum)
+ event.Skip()
+ def OnMotion(self, event):
+ Mouse moved
+ Track mouse motion and update status bar
+ # update statusbar if required
+ if self.toggleStatus.GetSelection() == 0: # Coordinates
+ e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
+ if self.toolbars['vdigit'] and \
+ self.toolbars['vdigit'].GetAction() == 'addLine' and \
+ self.toolbars['vdigit'].GetAction('type') in ('line', 'boundary') and \
+ len(self.MapWindow.polycoords) > 0:
+ # for linear feature show segment and total length
+ distance_seg = self.MapWindow.Distance(self.MapWindow.polycoords[-1],
+ (e, n), screen=False)[0]
+ distance_tot = distance_seg
+ for idx in range(1, len(self.MapWindow.polycoords)):
+ distance_tot += self.MapWindow.Distance(self.MapWindow.polycoords[idx-1],
+ self.MapWindow.polycoords[idx],
+ screen=False )[0]
+ self.statusbar.SetStatusText("%.2f, %.2f (seg: %.2f; tot: %.2f)" % \
+ (e, n, distance_seg, distance_tot), 0)
+ else:
+ if self.Map.projinfo['proj'] == 'll':
+ self.statusbar.SetStatusText("%s" % utils.Deg2DMS(e, n), 0)
+ else:
+ self.statusbar.SetStatusText("%.2f, %.2f" % (e, n), 0)
+ event.Skip()
+ def OnDraw(self, event):
+ Re-display current map composition
+ self.MapWindow.UpdateMap(render=False)
+ def OnRender(self, event):
+ Re-render map composition (each map layer)
+ # delete tmp map layers (queries)
+ qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
+ for layer in qlayer:
+ self.Map.DeleteLayer(layer)
+ # delete tmp lines
+ if self.MapWindow.mouse["use"] in ["measure", "profile"]:
+ self.MapWindow.polycoords = []
+ self.MapWindow.ClearLines()
+ # deselect features in vdigit
+ if self.toolbars['vdigit'] and self.digit:
+ self.digit.driver.SetSelected([])
+ self.MapWindow.UpdateMap(render=True, renderVector=True)
+ else:
+ self.MapWindow.UpdateMap(render=True)
+ self.StatusbarUpdate()
+ def OnPointer(self, event):
+ Pointer button clicked
+ if self.toolbars['map']:
+ if event:
+ self.toolbars['map'].OnTool(event)
+ self.toolbars['map'].action['desc'] = ''
+ self.MapWindow.mouse['use'] = "pointer"
+ # change the cursor
+ if self.toolbars['vdigit']:
+ # digitization tool activated
+ self.MapWindow.SetCursor(self.cursors["cross"])
+ # reset mouse['box'] if needed
+ if self.toolbars['vdigit'].GetAction() in ['addLine']:
+ if self.toolbars['vdigit'].GetAction('type') in ['point', 'centroid']:
+ self.MapWindow.mouse['box'] = 'point'
+ else: # line, boundary
+ self.MapWindow.mouse['box'] = 'line'
+ elif self.toolbars['vdigit'].GetAction() in ['addVertex', 'removeVertex', 'splitLine',
+ 'editLine', 'displayCats', 'displayAttrs',
+ 'copyCats']:
+ else: # moveLine, deleteLine
+ self.MapWindow.mouse['box'] = 'box'
+ elif self.gismanager.georectifying:
+ else:
+ def OnZoomIn(self, event):
+ Zoom in the map.
+ Set mouse cursor, zoombox attributes, and zoom direction
+ self.MapWindow.mouse['use'] = "zoom"
+ self.MapWindow.mouse['box'] = "box"
+ self.MapWindow.zoomtype = 1
+ self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+ def OnZoomOut(self, event):
+ Zoom out the map.
+ self.MapWindow.zoomtype = -1
+ def OnZoomBack(self, event):
+ Zoom last (previously stored position)
+ self.MapWindow.ZoomBack()
+ def OnPan(self, event):
+ Panning, set mouse to drag
+ self.MapWindow.mouse['use'] = "pan"
+ self.MapWindow.mouse['box'] = "pan"
+ self.MapWindow.SetCursor(self.cursors["hand"])
+ def OnErase(self, event):
+ Erase the canvas
+ def OnZoomRegion(self, event):
+ Zoom to region
+ self.Map.getRegion()
+ self.Map.getResolution()
+ self.UpdateMap()
+ # event.Skip()
+ def OnAlignRegion(self, event):
+ Align region
+ if not self.Map.alignRegion:
+ self.Map.alignRegion = True
+ else:
+ self.Map.alignRegion = False
+ # event.Skip()
+ def OnToggleRender(self, event):
+ Enable/disable auto-rendering
+ if self.autoRender.GetValue():
+ self.OnRender(None)
+ def OnToggleShowRegion(self, event):
+ Show/Hide extent in map canvas
+ if self.showRegion.GetValue():
+ # show extent
+ self.MapWindow.regionCoords = []
+ else:
+ del self.MapWindow.regionCoords
+ # redraw map if auto-rendering is enabled
+ def OnToggleResolution(self, event):
+ Use resolution of computation region settings
+ for redering image instead of display resolution
+ def OnToggleStatus(self, event):
+ Toggle status text
+ def OnChangeMapScale(self, event):
+ Map scale changed by user
+ scale = event.GetString()
+ try:
+ if scale[:2] != '1:':
+ raise ValueError
+ value = int(scale[2:])
+ except ValueError:
+ self.mapScale.SetValue('1:%ld' % int(self.mapScaleValue))
+ return
+ dEW = value * (self.Map.region['cols'] / self.ppm[0])
+ dNS = value * (self.Map.region['rows'] / self.ppm[1])
+ self.Map.region['n'] = self.Map.region['center_northing'] + dNS / 2.
+ self.Map.region['s'] = self.Map.region['center_northing'] - dNS / 2.
+ self.Map.region['w'] = self.Map.region['center_easting'] - dEW / 2.
+ self.Map.region['e'] = self.Map.region['center_easting'] + dEW / 2.
+ # add to zoom history
+ self.MapWindow.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
+ # redraw a map
+ self.mapScale.SetFocus()
+ def StatusbarUpdate(self):
+ """Update statusbar content"""
+ self.mapScaleValue = self.ppm = None
+ self.statusbar.SetStatusText("", 0)
+ # enable long help
+ self.StatusbarEnableLongHelp()
+ elif self.toggleStatus.GetSelection() == 1: # Extent
+ self.statusbar.SetStatusText("%.2f - %.2f, %.2f - %.2f" %
+ (self.Map.region["w"], self.Map.region["e"],
+ self.Map.region["s"], self.Map.region["n"]), 0)
+ elif self.toggleStatus.GetSelection() == 2: # Comp. region
+ compregion = self.Map.GetRegion()
+ self.statusbar.SetStatusText("%.2f - %.2f, %.2f - %.2f (%.2f, %.2f)" %
+ (compregion["w"], compregion["e"],
+ compregion["s"], compregion["n"],
+ compregion["ewres"], compregion["nsres"]), 0)
+ elif self.toggleStatus.GetSelection() == 3: # Show comp. extent
+ self.showRegion.Show()
+ # disable long help
+ self.StatusbarEnableLongHelp(False)
+ elif self.toggleStatus.GetSelection() == 4: # Display mode
+ self.compResolution.Show()
+ elif self.toggleStatus.GetSelection() == 5: # Display geometry
+ self.statusbar.SetStatusText("rows=%d; cols=%d; nsres=%.2f; ewres=%.2f" %
+ (self.Map.region["rows"], self.Map.region["cols"],
+ self.Map.region["nsres"], self.Map.region["ewres"]), 0)
+ elif self.toggleStatus.GetSelection() == 6: # Map scale
+ # TODO: need to be fixed...
+ ### screen X region problem
+ ### user should specify ppm
+ dc = wx.ScreenDC()
+ dpSizePx = wx.DisplaySize() # display size in pixels
+ dpSizeMM = wx.DisplaySizeMM() # display size in mm (system)
+ dpSizeIn = (dpSizeMM[0] / 25.4, dpSizeMM[1] / 25.4) # inches
+ sysPpi = dc.GetPPI()
+ comPpi = (dpSizePx[0] / dpSizeIn[0],
+ dpSizePx[1] / dpSizeIn[1])
+ ppi = comPpi # pixel per inch
+ self.ppm = ((ppi[0] / 2.54) * 100, # pixel per meter
+ (ppi[1] / 2.54) * 100)
+ Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): size: px=%d,%d mm=%f,%f "
+ "in=%f,%f ppi: sys=%d,%d com=%d,%d; ppm=%f,%f" % \
+ (dpSizePx[0], dpSizePx[1], dpSizeMM[0], dpSizeMM[1],
+ dpSizeIn[0], dpSizeIn[1],
+ sysPpi[0], sysPpi[1], comPpi[0], comPpi[1],
+ self.ppm[0], self.ppm[1]))
+ region = self.Map.region
+ heightCm = region['rows'] / self.ppm[1] * 100
+ widthCm = region['cols'] / self.ppm[0] * 100
+ Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): width_cm=%f, height_cm=%f" %
+ (widthCm, heightCm))
+ xscale = (region['e'] - region['w']) / (region['cols'] / self.ppm[0])
+ yscale = (region['n'] - region['s']) / (region['rows'] / self.ppm[1])
+ scale = (xscale + yscale) / 2.
+ Debug.msg(3, "MapFrame.StatusbarUpdate(mapscale): xscale=%f, yscale=%f -> scale=%f" % \
+ (xscale, yscale, scale))
+ self.statusbar.SetStatusText("")
+ try:
+ self.mapScale.SetValue("1:%ld" % (scale + 0.5))
+ except TypeError:
+ pass
+ self.mapScaleValue = scale
+ self.mapScale.Show()
+ else:
+ self.statusbar.SetStatusText("", 1)
+ def StatusbarEnableLongHelp(self, enable=True):
+ """Enable/disable toolbars long help"""
+ for toolbar in self.toolbars.itervalues():
+ if toolbar:
+ toolbar.EnableLongHelp(enable)
+ def StatusbarReposition(self):
+ """Reposition checkbox in statusbar"""
+ # reposition checkbox
+ widgets = [(0, self.showRegion),
+ (0, self.compResolution),
+ (0, self.mapScale),
+ (0, self.onRenderGauge),
+ (1, self.toggleStatus),
+ (2, self.maskInfo),
+ (3, self.autoRender)]
+ for idx, win in widgets:
+ rect = self.statusbar.GetFieldRect(idx)
+ if idx == 0: # show region / mapscale / process bar
+ # -> size
+ wWin, hWin = win.GetBestSize()
+ if win == self.onRenderGauge:
+ wWin = rect.width - 6
+ # -> position
+ # if win == self.showRegion:
+ # x, y = rect.x + rect.width - wWin, rect.y - 1
+ # align left
+ # else:
+ x, y = rect.x + 3, rect.y - 1
+ w, h = wWin, rect.height + 2
+ else: # choice || auto-rendering
+ x, y = rect.x, rect.y - 1
+ w, h = rect.width, rect.height + 2
+ if idx == 2: # mask
+ x += 5
+ y += 4
+ elif idx == 3: # render
+ x += 5
+ win.SetPosition((x, y))
+ win.SetSize((w, h))
+ def SaveToFile(self, event):
+ Save image to file
+ filetype = "PNG file (*.png)|*.png|"\
+ "TIF file (*.tif)|*.tif|"\
+ "GIF file (*.gif)|*.gif"
+ dlg = wx.FileDialog(self, "Choose a file name to save the image as a PNG to",
+ defaultDir = "",
+ defaultFile = "",
+ wildcard = filetype,
+ style=wx.SAVE|wx.FD_OVERWRITE_PROMPT)
+ base = os.path.splitext(dlg.GetPath())[0]
+ ext = os.path.splitext(dlg.GetPath())[1]
+ if dlg.GetFilterIndex() == 0:
+ type = wx.BITMAP_TYPE_PNG
+ path = dlg.GetPath()
+ if ext != '.png': path = base+'.png'
+ elif dlg.GetFilterIndex() == 1:
+ type = wx.BITMAP_TYPE_TIF
+ if ext != '.tif': path = base+'.tif'
+ elif dlg.GetFilterIndex() == 2:
+ if ext != '.gif': path = base+'.gif'
+ self.MapWindow.SaveToFile(path, type)
+ dlg.Destroy()
+ def PrintMenu(self, event):
+ Print options and output menu for map display
+ point = wx.GetMousePosition()
+ printmenu = wx.Menu()
+ # Add items to the menu
+ setup = wx.MenuItem(printmenu, wx.ID_ANY, _('Page setup'))
+ printmenu.AppendItem(setup)
+ self.Bind(wx.EVT_MENU, self.printopt.OnPageSetup, setup)
+ preview = wx.MenuItem(printmenu, wx.ID_ANY, _('Print preview'))
+ printmenu.AppendItem(preview)
+ self.Bind(wx.EVT_MENU, self.printopt.OnPrintPreview, preview)
+ doprint = wx.MenuItem(printmenu, wx.ID_ANY, _('Print display'))
+ printmenu.AppendItem(doprint)
+ self.Bind(wx.EVT_MENU, self.printopt.OnDoPrint, doprint)
+ # Popup the menu. If an item is selected then its handler
+ # will be called before PopupMenu returns.
+ self.PopupMenu(printmenu)
+ printmenu.Destroy()
+ def OnCloseWindow(self, event):
+ Window closed.
+ Also close associated layer tree page
+ pgnum = None
+ self.Map.Clean()
+ # close edited map and 3D tools properly
+ maplayer = self.toolbars['vdigit'].GetLayer()
+ if maplayer:
+ self.toolbars['vdigit'].OnExit()
+ self.imgVectorMap = None
+ if self.toolbars['nviz']:
+ self.toolbars['nviz'].OnExit()
+ if self.page:
+ if pgnum > -1:
+ self.layerbook.DeletePage(pgnum)
+ ### self.Destroy()
+ # if event:
+ # event.Skip() <- causes application crash
+ def GetRender(self):
+ Returns the current instance of render.Map()
+ return self.Map
+ def OnQueryDisplay(self, event):
+ Query currrent raster/vector map layers (display mode)
+ if self.toolbars['map'].GetAction() == 'displayAttrb': # select previous action
+ self.toolbars['map'].SelectDefault(event)
+ return
+ self.toolbars['map'].action['desc'] = 'displayAttrb'
+ # switch GIS Manager to output console to show query results
+ self.gismanager.notebook.SetSelection(1)
+ self.MapWindow.mouse['use'] = "query"
+ def OnQueryModify(self, event):
+ Query vector map layer (edit mode)
+ if self.toolbars['map'].GetAction() == 'modifyAttrb': # select previous action
+ return
+ self.toolbars['map'].action['desc'] = 'modifyAttrb'
+ self.MapWindow.mouse['use'] = "queryVector"
+ def QueryMap(self, x, y):
+ """!Query map layer features
+ Currently only raster and vector map layers are supported.
+ @param x,y coordinates
+ #set query snap distance for v.what at mapunit equivalent of 10 pixels
+ qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
+ east, north = self.MapWindow.Pixel2Cell((x, y))
+ num = 0
+ for layer in self.tree.GetSelections():
+ type = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
+ if type in ('raster', 'rgb', 'his',
+ 'vector', 'thememap', 'themechart'):
+ num += 1
+ if num < 1:
+ dlg = wx.MessageDialog(parent=self,
+ message=_('No raster or vector map layer selected for querying.'),
+ caption=_('No map layer selected'),
+ style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ dlg.ShowModal()
+ dlg.Destroy()
+ return
+ mapname = None
+ raststr = ''
+ vectstr = ''
+ rcmd = []
+ vcmd = []
+ dcmd = self.tree.GetPyData(layer)[0]['cmd']
+ name = utils.GetLayerNameFromCmd(dcmd)
+ if name == '':
+ continue
+ if type in ('raster', 'rgb', 'his'):
+ raststr += "%s," % name
+ elif type in ('vector', 'thememap', 'themechart'):
+ vectstr += "%s," % name
+ # use display region settings instead of computation region settings
+ self.tmpreg = os.getenv("GRASS_REGION")
+ os.environ["GRASS_REGION"] = self.Map.SetRegion(windres=False)
+ # build query commands for any selected rasters and vectors
+ if raststr != '':
+ rcmd = ['r.what', '--q',
+ '-f',
+ 'input=%s' % raststr.rstrip(','),
+ 'east_north=%f,%f' % (float(east), float(north))]
+ if vectstr != '':
+ # check for vector maps open to be edited
+ digitToolbar = self.toolbars['vdigit']
+ if digitToolbar:
+ vect = []
+ for vector in vectstr.split(','):
+ if map == vector:
+ self.gismanager.goutput.WriteWarning("Vector map <%s> "
+ "opened for editing - skipped." % map)
+ continue
+ vect.append(vector)
+ vectstr = ','.join(vect)
+ if len(vectstr) <= 1:
+ self.gismanager.goutput.WriteCmdLog("Nothing to query.")
+ return
+ vcmd = ['v.what', '--q',
+ '-a',
+ 'map=%s' % vectstr.rstrip(','),
+ 'east_north=%f,%f' % (float(east), float(north)),
+ 'distance=%f' % qdist]
+ # parse query command(s)
+ if self.gismanager:
+ if rcmd:
+ self.gismanager.goutput.RunCmd(rcmd, compReg=False,
+ onDone = self._QueryMapDone)
+ if vcmd:
+ self.gismanager.goutput.RunCmd(vcmd,
+ else:
+ if rcmd:
+ gcmd.Command(rcmd)
+ if vcmd:
+ gcmd.Command(vcmd)
+ def _QueryMapDone(self, returncode):
+ """!Restore settings after querying (restore GRASS_REGION)
+ @param returncode command return code
+ if hasattr(self, "tmpreg"):
+ if self.tmpreg:
+ os.environ["GRASS_REGION"] = self.tmpreg
+ elif os.environ.has_key('GRASS_REGION'):
+ del self.tmpreg
+ def QueryVector(self, x, y):
+ Query vector map layer features
+ Attribute data of selected vector object are displayed in GUI dialog.
+ Data can be modified (On Submit)
+ if not self.tree.layer_selected or \
+ self.tree.GetPyData(self.tree.layer_selected)[0]['type'] != 'vector':
+ message=_("No vector map selected for querying."),
+ caption=_("Vector querying"),
+ return
+ if self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetMapset() != \
+ grass.gisenv()['MAPSET']:
+ message=_("Only vector map from the current mapset can be modified."),
+ return
+ posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
+ y + self.MapWindow.dialogOffset))
+ qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / \
+ self.Map.width)
+ mapName = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name
+ if self.dialogs['attributes'] is None:
+ self.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self.MapWindow,
+ map=mapName,
+ query=((east, north), qdist),
+ pos=posWindow,
+ action="update")
+ else:
+ # selection changed?
+ if not self.dialogs['attributes'].mapDBInfo or \
+ self.dialogs['attributes'].mapDBInfo.map != mapName:
+ self.dialogs['attributes'].UpdateDialog(map=mapName, query=((east, north), qdist))
+ else:
+ self.dialogs['attributes'].UpdateDialog(query=((east, north), qdist))
+ cats = self.dialogs['attributes'].GetCats()
+ try:
+ qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)[0]
+ qlayer = None
+ if self.dialogs['attributes'].mapDBInfo and cats:
+ if qlayer:
+ qlayer.SetCmd(self.AddTmpVectorMapLayer(mapName, cats,
+ useId=False,
+ addLayer=False))
+ else:
+ qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId=False)
+ # set opacity based on queried layer
+ opacity = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetOpacity(float=True)
+ qlayer.SetOpacity(opacity)
+ self.MapWindow.UpdateMap(render=False, renderVector=False)
+ if not self.dialogs['attributes'].IsShown():
+ self.dialogs['attributes'].Show()
+ else:
+ if qlayer:
+ self.Map.DeleteLayer(qlayer)
+ if self.dialogs['attributes'].IsShown():
+ self.dialogs['attributes'].Hide()
+ def OnQuery(self, event):
+ """Query tools menu"""
+ action = self.toolbars['map'].GetAction()
+ toolsmenu = wx.Menu()
+ display = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
+ text=_("Query raster/vector map(s) (display mode)"),
+ kind=wx.ITEM_CHECK)
+ toolsmenu.AppendItem(display)
+ self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
+ numLayers = 0
+ numLayers += 1
+ if numLayers < 1:
+ display.Enable(False)
+ if action == "displayAttrb":
+ display.Check(True)
+ modify = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
+ text=_("Query vector map (edit mode)"),
+ toolsmenu.AppendItem(modify)
+ self.Bind(wx.EVT_MENU, self.OnQueryModify, modify)
+ if self.tree.layer_selected:
+ layer_selected = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer']
+ if layer_selected.GetType() != 'vector' or \
+ (digitToolbar and \
+ digitToolbar.GetLayer() == layer_selected):
+ modify.Enable(False)
+ else:
+ if action == "modifyAttrb":
+ modify.Check(True)
+ self.PopupMenu(toolsmenu)
+ toolsmenu.Destroy()
+ def AddTmpVectorMapLayer(self, name, cats, useId=False, addLayer=True):
+ Add temporal vector map layer to map composition
+ @param name name of map layer
+ @param useId use feature id instead of category
+ # color settings from ATM
+ color = UserSettings.Get(group='atm', key='highlight', subkey='color')
+ str(color[2])
+ pattern = ["d.vect",
+ "map=%s" % name,
+ "color=%s" % colorStr,
+ "fcolor=%s" % colorStr,
+ "width=%d" % UserSettings.Get(group='atm', key='highlight', subkey='width')]
+ if useId:
+ cmd = pattern
+ cmd.append('-i')
+ cmd.append('cats=%s' % str(cats))
+ else:
+ cmd = []
+ for layer in cats.keys():
+ cmd.append(copy.copy(pattern))
+ lcats = cats[layer]
+ cmd[-1].append("layer=%d" % layer)
+ cmd[-1].append("cats=%s" % utils.ListOfCatsToRange(lcats))
+ # if self.icon:
+ # cmd.append("icon=%s" % (self.icon))
+ # if self.pointsize:
+ # cmd.append("size=%s" % (self.pointsize))
+ if addLayer:
+ if useId:
+ return self.Map.AddLayer(type='vector', name=globalvar.QUERYLAYER, command=cmd,
+ l_active=True, l_hidden=True, l_opacity=1.0)
+ else:
+ return self.Map.AddLayer(type='command', name=globalvar.QUERYLAYER, command=cmd,
+ else:
+ return cmd
+ def OnAnalyze(self, event):
+ Analysis tools menu
+ measure = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["measure"].GetLabel())
+ measure.SetBitmap(Icons["measure"].GetBitmap(self.iconsize))
+ toolsmenu.AppendItem(measure)
+ self.Bind(wx.EVT_MENU, self.OnMeasure, measure)
+ profile = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["profile"].GetLabel())
+ profile.SetBitmap(Icons["profile"].GetBitmap(self.iconsize))
+ toolsmenu.AppendItem(profile)
+ self.Bind(wx.EVT_MENU, self.Profile, profile)
+ histogram = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["histogram"].GetLabel())
+ histogram.SetBitmap(Icons["histogram"].GetBitmap(self.iconsize))
+ toolsmenu.AppendItem(histogram)
+ self.Bind(wx.EVT_MENU, self.Histogram, histogram)
+ def OnMeasure(self, event):
+ Init measurement routine that calculates
+ map distance along transect drawn on
+ map display
+ self.totaldist = 0.0 # total measured distance
+ # switch GIS Manager to output console to show measure results
+ # change mouse to draw line for measurement
+ self.MapWindow.mouse['use'] = "measure"
+ self.MapWindow.mouse['box'] = "line"
+ self.MapWindow.pen = wx.Pen(colour='red', width=2, style=wx.SHORT_DASH)
+ self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SHORT_DASH)
+ self.MapWindow.SetCursor(self.cursors["pencil"])
+ # initiating output
+ style = self.gismanager.goutput.cmd_output.StyleWarning
+ self.gismanager.goutput.WriteLog(_('Click and drag with left mouse button '
+ 'to measure.%s'
+ 'Double click with left button to clear.') % \
+ (os.linesep), style)
+ if self.Map.projinfo['proj'] != 'xy':
+ units = self.Map.projinfo['units']
+ style = self.gismanager.goutput.cmd_output.StyleCommand
+ self.gismanager.goutput.WriteLog(_('Measuring distance') + ' ('
+ + units + '):',
+ style)
+ else:
+ self.gismanager.goutput.WriteLog(_('Measuring distance:'),
+ style)
+ def MeasureDist(self, beginpt, endpt):
+ Calculate map distance from screen distance
+ and print to output window
+ if self.gismanager.notebook.GetSelection() != 1:
+ dist, (north, east) = self.MapWindow.Distance(beginpt, endpt)
+ dist = round(dist, 3)
+ d, dunits = self.FormatDist(dist)
+ self.totaldist += dist
+ td, tdunits = self.FormatDist(self.totaldist)
+ strdist = str(d)
+ strtotdist = str(td)
+ if self.Map.projinfo['proj'] == 'xy' or 'degree' not in self.Map.projinfo['unit']:
+ angle = int(math.degrees(math.atan2(north,east)) + 0.5)
+ angle = 180 - angle
+ if angle < 0:
+ angle = 360+angle
+ mstring = 'segment = %s %s\ttotal distance = %s %s\tbearing = %d deg' \
+ % (strdist,dunits,strtotdist,tdunits,angle)
+ else:
+ mstring = 'segment = %s %s\ttotal distance = %s %s' \
+ % (strdist,dunits,strtotdist,tdunits)
+ self.gismanager.goutput.WriteLog(mstring)
+ return dist
+ def Profile(self, event):
+ Init profile canvas and tools
+ raster = []
+ if self.tree.layer_selected and \
+ self.tree.GetPyData(self.tree.layer_selected)[0]['type'] == 'raster':
+ raster.append(self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
+ self.profile = profile.ProfileFrame(self,
+ id=wx.ID_ANY, pos=wx.DefaultPosition, size=(700,300),
+ style=wx.DEFAULT_FRAME_STYLE, rasterList=raster)
+ self.profile.Show()
+ # Open raster select dialog to make sure that a raster (and the desired raster)
+ # is selected to be profiled
+ self.profile.OnSelectRaster(None)
+ def FormatDist(self, dist):
+ """Format length numbers and units in a nice way,
+ as a function of length. From code by Hamish Bowman
+ Grass Development Team 2006"""
+ mapunits = self.Map.projinfo['units']
+ if mapunits == 'metres': mapunits = 'meters'
+ outunits = mapunits
+ dist = float(dist)
+ divisor = 1.0
+ # figure out which units to use
+ if mapunits == 'meters':
+ if dist > 2500.0:
+ outunits = 'km'
+ divisor = 1000.0
+ else: outunits = 'm'
+ elif mapunits == 'feet':
+ # nano-bug: we match any "feet", but US Survey feet is really
+ # 5279.9894 per statute mile, or 10.6' per 1000 miles. As >1000
+ # miles the tick markers are rounded to the nearest 10th of a
+ # mile (528'), the difference in foot flavours is ignored.
+ if dist > 5280.0:
+ outunits = 'miles'
+ divisor = 5280.0
+ else:
+ outunits = 'ft'
+ elif 'degree' in mapunits:
+ if dist < 1:
+ outunits = 'min'
+ divisor = (1/60.0)
+ else:
+ outunits = 'deg'
+ # format numbers in a nice way
+ if (dist/divisor) >= 2500.0:
+ outdist = round(dist/divisor)
+ elif (dist/divisor) >= 1000.0:
+ outdist = round(dist/divisor,1)
+ elif (dist/divisor) > 0.0:
+ outdist = round(dist/divisor,int(math.ceil(3-math.log10(dist/divisor))))
+ else:
+ outdist = float(dist/divisor)
+ return (outdist, outunits)
+ def Histogram(self, event):
+ Init histogram display canvas and tools
+ self.histogram = histogram.HistFrame(self,
+ id=wx.ID_ANY, size=globalvar.HIST_WINDOW_SIZE,
+ style=wx.DEFAULT_FRAME_STYLE)
+ #show new display
+ self.histogram.Show()
+ self.histogram.Refresh()
+ self.histogram.Update()
+ def OnDecoration(self, event):
+ Decorations overlay menu
+ decmenu = wx.Menu()
+ AddScale = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addbarscale"].GetLabel())
+ AddScale.SetBitmap(Icons["addbarscale"].GetBitmap(self.iconsize))
+ decmenu.AppendItem(AddScale)
+ self.Bind(wx.EVT_MENU, self.OnAddBarscale, AddScale)
+ AddLegend = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addlegend"].GetLabel())
+ AddLegend.SetBitmap(Icons["addlegend"].GetBitmap(self.iconsize))
+ decmenu.AppendItem(AddLegend)
+ self.Bind(wx.EVT_MENU, self.OnAddLegend, AddLegend)
+ AddText = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addtext"].GetLabel())
+ AddText.SetBitmap(Icons["addtext"].GetBitmap(self.iconsize))
+ decmenu.AppendItem(AddText)
+ self.Bind(wx.EVT_MENU, self.OnAddText, AddText)
+ self.PopupMenu(decmenu)
+ decmenu.Destroy()
+ def OnAddBarscale(self, event):
+ Handler for scale/arrow map decoration menu selection.
+ if self.dialogs['barscale']:
+ return
+ id = 0 # unique index for overlay layer
+ # If location is latlon, only display north arrow (scale won't work)
+ # proj = self.Map.projinfo['proj']
+ # if proj == 'll':
+ # barcmd = 'd.barscale -n'
+ # else:
+ # barcmd = 'd.barscale'
+ # decoration overlay control dialog
+ self.dialogs['barscale'] = \
+ gdialogs.DecorationDialog(parent=self, title=_('Scale and North arrow'),
+ size=(350, 200),
+ style=wx.DEFAULT_DIALOG_STYLE | wx.CENTRE,
+ cmd=['d.barscale', 'at=0,5'],
+ ovlId=id,
+ name='barscale',
+ checktxt = _("Show/hide scale and North arrow"),
+ ctrltxt = _("scale object"))
+ self.dialogs['barscale'].CentreOnParent()
+ ### dialog cannot be show as modal - in the result d.barscale is not selectable
+ ### self.dialogs['barscale'].ShowModal()
+ self.dialogs['barscale'].Show()
+ self.MapWindow.mouse['use'] = 'pointer'
+ def OnAddLegend(self, event):
+ Handler for legend map decoration menu selection.
+ if self.dialogs['legend']:
+ return
+ id = 1 # index for overlay layer in render
+ cmd = ['d.legend', 'at=5,50,2,5']
+ cmd.append('map=%s' % self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
+ # Decoration overlay control dialog
+ self.dialogs['legend'] = \
+ gdialogs.DecorationDialog(parent=self, title=('Legend'),
+ size=(350, 200),
+ cmd=cmd,
+ ovlId=id,
+ name='legend',
+ checktxt = _("Show/hide legend"),
+ ctrltxt = _("legend object"))
+ self.dialogs['legend'].CentreOnParent()
+ ### dialog cannot be show as modal - in the result d.legend is not selectable
+ ### self.dialogs['legend'].ShowModal()
+ self.dialogs['legend'].Show()
+ def OnAddText(self, event):
+ Handler for text decoration menu selection.
+ if self.MapWindow.dragid > -1:
+ id = self.MapWindow.dragid
+ else:
+ # index for overlay layer in render
+ if len(self.MapWindow.textdict.keys()) > 0:
+ id = self.MapWindow.textdict.keys()[-1] + 1
+ else:
+ id = 101
+ self.dialogs['text'] = gdialogs.TextLayerDialog(parent=self, ovlId=id,
+ title=_('Add text layer'),
+ size=(400, 200))
+ self.dialogs['text'].CenterOnParent()
+ # If OK button pressed in decoration control dialog
+ if self.dialogs['text'].ShowModal() == wx.ID_OK:
+ text = self.dialogs['text'].GetValues()['text']
+ active = self.dialogs['text'].GetValues()['active']
+ coords, w, h = self.MapWindow.TextBounds(self.dialogs['text'].GetValues())
+ # delete object if it has no text or is not active
+ if text == '' or active == False:
+ try:
+ self.MapWindow.pdc.ClearId(id)
+ self.MapWindow.pdc.RemoveId(id)
+ del self.MapWindow.textdict[id]
+ except:
+ pass
+ return
+ self.MapWindow.pdc.SetId(id)
+ self.MapWindow.textdict[id] = self.dialogs['text'].GetValues()
+ self.MapWindow.Draw(self.MapWindow.pdcDec, img=self.MapWindow.textdict[id],
+ drawid=id, pdctype='text', coords=coords)
+ def GetOptData(self, dcmd, type, params, propwin):
+ Callback method for decoration overlay command generated by
+ dialog created in menuform.py
+ # Reset comand and rendering options in render.Map. Always render decoration.
+ # Showing/hiding handled by PseudoDC
+ self.Map.ChangeOverlay(ovltype=type, type='overlay', name='', command=dcmd,
+ l_active=True, l_render=False)
+ self.params[type] = params
+ self.propwin[type] = propwin
+ def OnZoomMenu(self, event):
+ Zoom menu
+ zoommenu = wx.Menu()
+ zoommap = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to selected map(s)'))
+ zoommenu.AppendItem(zoommap)
+ self.Bind(wx.EVT_MENU, self.MapWindow.OnZoomToMap, zoommap)
+ zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
+ zoommenu.AppendItem(zoomwind)
+ self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToWind, zoomwind)
+ zoomdefault = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to default region'))
+ zoommenu.AppendItem(zoomdefault)
+ self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToDefault, zoomdefault)
+ zoomsaved = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to saved region'))
+ zoommenu.AppendItem(zoomsaved)
+ self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToSaved, zoomsaved)
+ savewind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Set computational region from display'))
+ zoommenu.AppendItem(savewind)
+ self.Bind(wx.EVT_MENU, self.MapWindow.DisplayToWind, savewind)
+ savezoom = wx.MenuItem(zoommenu, wx.ID_ANY, _('Save display geometry to named region'))
+ zoommenu.AppendItem(savezoom)
+ self.Bind(wx.EVT_MENU, self.MapWindow.SaveDisplayRegion, savezoom)
+ self.PopupMenu(zoommenu)
+ zoommenu.Destroy()
+ def SetProperties(self, render=False, mode=0, showCompExtent=False,
+ constrainRes=False):
+ """Set properies of map display window"""
+ self.autoRender.SetValue(render)
+ self.toggleStatus.SetSelection(mode)
+ self.showRegion.SetValue(showCompExtent)
+ self.compResolution.SetValue(constrainRes)
+ if showCompExtent:
+ def IsStandalone(self):
+ """!Check if Map display is standalone"""
+ return False
+ return True
+ def GetLayerManager(self):
+ """!Get reference to Layer Manager
+ @return window reference
+ @return None (if standalone)
+ return self.gismanager
+# end of class MapFrame
+class MapApp(wx.App):
+ MapApp class
+ def OnInit(self):
+ wx.InitAllImageHandlers()
+ if __name__ == "__main__":
+ Map = render.Map() # instance of Map class to render GRASS display output to PPM file
+ else:
+ Map = None
+ self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map, size=(640,480))
+ #self.SetTopWindow(Map)
+ self.mapFrm.Show()
+ # redraw map, if new command appears
+ self.redraw = False
+ status = Command(self, Map)
+ status.start()
+ self.timer = wx.PyTimer(self.watcher)
+ # check each 0.1s
+ self.timer.Start(100)
+ return 1
+ def OnExit(self):
+ # stop the timer
+ self.timer.Stop()
+ # terminate thread (a bit ugly)
+ os.system("""echo "quit" >> %s""" % (cmdfilename))
+ def watcher(self):
+ """Redraw, if new layer appears"""
+ if self.redraw:
+ self.mapFrm.OnDraw(None)
+ return
+# end of class MapApp
+if __name__ == "__main__":
+ ###### SET command variable
+ if len(sys.argv) != 3:
+ print __doc__
+ sys.exit()
+ title = sys.argv[1]
+ cmdfilename = sys.argv[2]
+ import gettext
+ gettext.install("gm_map") # replace with the appropriate catalog name
+ print "Starting monitor <%s>" % (title)
+ gm_map = MapApp(0)
+ # set title
+ gm_map.mapFrm.SetTitle ("GRASS GIS - Map Display: " + title + " - Location: " + \
+ grass.gisenv()['LOCATION_NAME'])
+ gm_map.MainLoop()
+ if grass.gisenv().has_key("MONITOR"):
+ os.system("d.mon sel=%s" % grass.gisenv()["MONITOR"])
+ os.remove(cmdfilename)
+ os.system("""g.gisenv set="GRASS_PYCMDFILE" """)
+ print "Stoping monitor <%s>" % (title)
+ sys.exit()
