[GRASS-SVN] r40816 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Thu Feb 4 01:55:14 EST 2010
Author: rashadkm
Date: 2010-02-04 01:55:12 -0500 (Thu, 04 Feb 2010)
New Revision: 40816
Added:
grass-addons/gui/wxpython/data_catalog/toolbars1.py
grass-addons/gui/wxpython/data_catalog/catalog.py
grass-addons/gui/wxpython/data_catalog/mapdisplay.py
fixed problems on toolbars
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py 2010-02-04 06:30:13 UTC (rev 40815)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py 2010-02-04 06:55:12 UTC (rev 40816)
@@ -227,11 +227,7 @@
self.Map = self.GetMapDisplay()
- def OnRunScript(self)
- print "asdf"
- def OnQuit(self)
- print "asdf"
def GetMapDisplay(self):
self.winlist = self.GetChildren()
@@ -373,6 +369,12 @@
def OnXTerm(self):
print "asdf"
+ def OnRunScript(self):
+ print "asdf"
+ def OnQuit(self):
+ print "asdf"
def OnRunCmd(self, event):
"""Run command"""
cmdString = event.GetString()
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-02-04 06:30:13 UTC (rev 40815)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-02-04 06:55:12 UTC (rev 40816)
@@ -57,7 +57,7 @@
sys.path.append(grassPath)
import render
-import toolbars
+import toolbars1
import menuform
import gselect
import disp_print
@@ -378,7 +378,7 @@
# default toolbar
if name == "map":
- self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
+ self.toolbars['map'] = toolbars1.MapToolbar(self, self.Map)
self._mgr.AddPane(self.toolbars['map'].toolbar,
wx.aui.AuiPaneInfo().
Added: grass-addons/gui/wxpython/data_catalog/toolbars1.py
--- grass-addons/gui/wxpython/data_catalog/toolbars1.py (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/toolbars1.py 2010-02-04 06:55:12 UTC (rev 40816)
@@ -0,0 +1,1380 @@
+ at package toolbar
+ at brief Toolbars for Map Display window
+Classes:
+ - AbstractToolbar
+ - MapToolbar
+ - GRToolbar
+ - GCPToolbar
+ - VDigitToolbar
+ - ProfileToolbar
+ - NvizToolbar
+(C) 2007-2008 by the GRASS Development Team This program is free
+software under the GNU General Public License (>=v2). Read the file
+COPYING that comes with GRASS for details.
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
+import wx
+import os, sys
+import platform
+import globalvar
+import gcmd
+version = os.getenv("GRASS_VERSION")
+if version == "6.4.0svn":
+ import grassenv
+import gdialogs
+import vdigit
+from vdigit import VDigitSettingsDialog as VDigitSettingsDialog
+from debug import Debug as Debug
+from icon import Icons as Icons
+from preferences import globalSettings as UserSettings
+gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
+sys.path.append(gmpath)
+class AbstractToolbar(object):
+ """Abstract toolbar class"""
+ def __init__(self):
+ pass
+ def InitToolbar(self, parent, toolbar, toolData):
+ """Initialize toolbar, i.e. add tools to the toolbar
+ @return list of ids (of added tools)
+ for tool in toolData:
+ self.CreateTool(parent, toolbar, *tool)
+ self._toolbar = toolbar
+ self._data = toolData
+ self.parent = parent
+ def ToolbarData(self):
+ """Toolbar data"""
+ return None
+ def CreateTool(self, parent, toolbar, tool, label, bitmap, kind,
+ shortHelp, longHelp, handler):
+ """Add tool to the toolbar
+ @return id of tool
+ bmpDisabled=wx.NullBitmap
+ if label:
+ Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
+ (tool, label, bitmap))
+ toolWin = toolbar.AddLabelTool(tool, label, bitmap,
+ bmpDisabled, kind,
+ shortHelp, longHelp)
+ parent.Bind(wx.EVT_TOOL, handler, toolWin)
+ else: # add separator
+ toolbar.AddSeparator()
+ return tool
+ def GetToolbar(self):
+ """Get toolbar widget reference"""
+ return self._toolbar
+ def EnableLongHelp(self, enable=True):
+ """Enable/disable long help
+ @param enable True for enable otherwise disable
+ for tool in self._data:
+ if tool[0] == '': # separator
+ continue
+ if enable:
+ self._toolbar.SetToolLongHelp(tool[0], tool[5])
+ else:
+ self._toolbar.SetToolLongHelp(tool[0], "")
+ def OnTool(self, event):
+ """Tool selected"""
+ if self.parent.toolbars['vdigit']:
+ # update vdigit toolbar (unselect currently selected tool)
+ id = self.parent.toolbars['vdigit'].GetAction(type='id')
+ self.parent.toolbars['vdigit'].GetToolbar().ToggleTool(id, False)
+ if event:
+ # deselect previously selected tool
+ id = self.action.get('id', -1)
+ if id != event.GetId():
+ self._toolbar.ToggleTool(self.action['id'], False)
+ else:
+ self._toolbar.ToggleTool(self.action['id'], True)
+ self.action['id'] = event.GetId()
+ event.Skip()
+ else:
+ # initialize toolbar
+ def GetAction(self, type='desc'):
+ """Get current action info"""
+ return self.action.get(type, '')
+ def SelectDefault(self, event):
+ """Select default tool"""
+ self._toolbar.ToggleTool(self.defaultAction['id'], True)
+ self.defaultAction['bind'](event)
+ self.action = { 'id' : self.defaultAction['id'],
+ 'desc' : self.defaultAction.get('desc', '') }
+ def FixSize(self, width):
+ """Fix toolbar width on Windows
+ @todo Determine why combobox causes problems here
+ if platform.system() == 'Windows':
+ size = self._toolbar.GetBestSize()
+ self._toolbar.SetSize((size[0] + width, size[1]))
+class MapToolbar(AbstractToolbar):
+ Main Map Display toolbar
+ def __init__(self, mapdisplay, map):
+ AbstractToolbar.__init__(self)
+ self.mapcontent = map
+ self.mapdisplay = mapdisplay
+ self.toolbar = wx.ToolBar(parent=self.mapdisplay, id=wx.ID_ANY)
+ self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
+ self.InitToolbar(self.mapdisplay, self.toolbar, self.ToolbarData())
+ # optional tools
+ self.combo = wx.ComboBox(parent=self.toolbar, id=wx.ID_ANY, value=_('2D view'),
+ choices=[_('2D view'), _('3D view'), _('Digitize')],
+ style=wx.CB_READONLY, size=(90, -1))
+ self.comboid = self.toolbar.AddControl(self.combo)
+ self.mapdisplay.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
+ # realize the toolbar
+ self.toolbar.Realize()
+ # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
+ self.combo.Hide()
+ self.combo.Show()
+ # default action
+ self.action = { 'id' : self.pointer }
+ self.defaultAction = { 'id' : self.pointer,
+ 'bind' : self.mapdisplay.OnPointer }
+ self.OnTool(None)
+ self.FixSize(width = 90)
+ self.displaymap = wx.NewId()
+ self.rendermap = wx.NewId()
+ self.erase = wx.NewId()
+ self.pointer = wx.NewId()
+ self.query = wx.NewId()
+ self.pan = wx.NewId()
+ self.zoomin = wx.NewId()
+ self.zoomout = wx.NewId()
+ self.zoomback = wx.NewId()
+ self.zoommenu = wx.NewId()
+ self.analyze = wx.NewId()
+ self.dec = wx.NewId()
+ self.savefile = wx.NewId()
+ self.printmap = wx.NewId()
+ # tool, label, bitmap, kind, shortHelp, longHelp, handler
+ return (
+ (self.displaymap, "displaymap", Icons["displaymap"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["displaymap"].GetLabel(), Icons["displaymap"].GetDesc(),
+ self.mapdisplay.OnDraw),
+ (self.rendermap, "rendermap", Icons["rendermap"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["rendermap"].GetLabel(), Icons["rendermap"].GetDesc(),
+ self.mapdisplay.OnRender),
+ (self.erase, "erase", Icons["erase"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["erase"].GetLabel(), Icons["erase"].GetDesc(),
+ self.mapdisplay.OnErase),
+ (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
+ self.mapdisplay.OnPointer),
+ (self.query, "query", Icons["query"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["query"].GetLabel(), Icons["query"].GetDesc(),
+ self.mapdisplay.OnQuery),
+ (self.pan, "pan", Icons["pan"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+ self.mapdisplay.OnPan),
+ (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+ self.mapdisplay.OnZoomIn),
+ (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+ self.mapdisplay.OnZoomOut),
+ (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
+ self.mapdisplay.OnZoomBack),
+ (self.zoommenu, "zoommenu", Icons["zoommenu"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoommenu"].GetLabel(), Icons["zoommenu"].GetDesc(),
+ self.mapdisplay.OnZoomMenu),
+ (self.analyze, "analyze", Icons["analyze"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["analyze"].GetLabel(), Icons["analyze"].GetDesc(),
+ self.mapdisplay.OnAnalyze),
+ (self.dec, "overlay", Icons["overlay"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["overlay"].GetLabel(), Icons["overlay"].GetDesc(),
+ self.mapdisplay.OnDecoration),
+ (self.savefile, "savefile", Icons["savefile"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["savefile"].GetLabel(), Icons["savefile"].GetDesc(),
+ self.mapdisplay.SaveToFile),
+ (self.printmap, "printmap", Icons["printmap"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["printmap"].GetLabel(), Icons["printmap"].GetDesc(),
+ self.mapdisplay.PrintMenu),
+ def OnSelectTool(self, event):
+ Select / enable tool available in tools list
+ tool = event.GetSelection()
+ if tool == 0:
+ self.ExitToolbars()
+ self.Enable2D(True)
+ elif tool == 1 and not self.mapdisplay.toolbars['nviz']:
+ self.mapdisplay.AddToolbar("nviz")
+ elif tool == 2 and not self.mapdisplay.toolbars['vdigit']:
+ self.mapdisplay.AddToolbar("vdigit")
+ def ExitToolbars(self):
+ if self.mapdisplay.toolbars['vdigit']:
+ self.mapdisplay.toolbars['vdigit'].OnExit()
+ if self.mapdisplay.toolbars['nviz']:
+ self.mapdisplay.toolbars['nviz'].OnExit()
+ def Enable2D(self, enabled):
+ """Enable/Disable 2D display mode specific tools"""
+ for tool in (self.pointer,
+ self.query,
+ self.pan,
+ self.zoomin,
+ self.zoomout,
+ self.zoomback,
+ self.zoommenu,
+ self.analyze,
+ self.dec,
+ self.savefile,
+ self.printmap):
+ self.toolbar.EnableTool(tool, enabled)
+class GRToolbar(AbstractToolbar):
+ Georectification Display toolbar
+ # self.SetToolBar(self.toolbar)
+ self.gcpset = wx.NewId()
+ self.zoomtomap = wx.NewId()
+ return (
+ (self.gcpset, "grGcpSet", Icons["grGcpSet"].GetBitmap(),
+ wx.ITEM_RADIO, Icons["grGcpSet"].GetLabel(), Icons["grGcpSet"].GetDesc(),
+ wx.ITEM_RADIO, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+ wx.ITEM_RADIO, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+ wx.ITEM_RADIO, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+ (self.zoomtomap, "zoomtomap", Icons["zoommenu"].GetBitmap(),
+ wx.ITEM_NORMAL, _("Zoom to map"), _("Zoom to displayed map"),
+ self.OnZoomMap),
+ def OnZoomMap(self, event):
+ """Zoom to selected map"""
+ layer = self.mapcontent.GetListOfLayers()[0]
+ self.mapdisplay.MapWindow.ZoomToMap(layer=layer)
+ event.Skip()
+class GCPToolbar(AbstractToolbar):
+ Toolbar for managing ground control points during georectification
+ def __init__(self, parent, tbframe):
+ self.parent = parent # GCP
+ self.tbframe = tbframe
+ self.toolbar = wx.ToolBar(parent=self.tbframe, id=wx.ID_ANY)
+ self.InitToolbar(self.tbframe, self.toolbar, self.ToolbarData())
+ self.gcpSave = wx.NewId()
+ self.gcpAdd = wx.NewId()
+ self.gcpDelete = wx.NewId()
+ self.gcpClear = wx.NewId()
+ self.gcpReload = wx.NewId()
+ self.rms = wx.NewId()
+ self.georect = wx.NewId()
+ self.settings = wx.NewId()
+ self.quit = wx.NewId()
+ return (
+ (self.gcpSave, 'grGcpSave', Icons["grGcpSave"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGcpSave"].GetLabel(), Icons["grGcpSave"].GetDesc(),
+ self.parent.SaveGCPs),
+ (self.gcpAdd, 'grGrGcpAdd', Icons["grGcpAdd"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGcpAdd"].GetLabel(), Icons["grGcpAdd"].GetDesc(),
+ self.parent.AddGCP),
+ (self.gcpDelete, 'grGrGcpDelete', Icons["grGcpDelete"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGcpDelete"].GetLabel(), Icons["grGcpDelete"].GetDesc(),
+ self.parent.DeleteGCP),
+ (self.gcpClear, 'grGcpClear', Icons["grGcpClear"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGcpClear"].GetLabel(), Icons["grGcpClear"].GetDesc(),
+ self.parent.ClearGCP),
+ (self.gcpReload, 'grGcpReload', Icons["grGcpReload"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGcpReload"].GetLabel(), Icons["grGcpReload"].GetDesc(),
+ self.parent.ReloadGCPs),
+ (self.rms, 'grGcpRms', Icons["grGcpRms"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGcpRms"].GetLabel(), Icons["grGcpRms"].GetDesc(),
+ self.parent.OnRMS),
+ (self.georect, 'grGeorect', Icons["grGeorect"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGeorect"].GetLabel(), Icons["grGeorect"].GetDesc(),
+ self.parent.OnGeorect),
+ (self.settings, 'grSettings', Icons["grSettings"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grSettings"].GetLabel(), Icons["grSettings"].GetDesc(),
+ self.parent.OnSettings),
+ (self.quit, 'grGcpQuit', Icons["grGcpQuit"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["grGcpQuit"].GetLabel(), Icons["grGcpQuit"].GetDesc(),
+ self.parent.OnQuit)
+class VDigitToolbar(AbstractToolbar):
+ Toolbar for digitization
+ def __init__(self, parent, map, layerTree=None, log=None):
+ self.mapcontent = map # Map class instance
+ self.parent = parent # MapFrame
+ self.layerTree = layerTree # reference to layer tree associated to map display
+ self.log = log # log area
+ # currently selected map layer for editing (reference to MapLayer instance)
+ self.mapLayer = None
+ # list of vector layers from Layer Manager (only in the current mapset)
+ self.layers = []
+ self.comboid = None
+ # only one dialog can be open
+ self.settingsDialog = None
+ # create toolbars (two rows optionally)
+ self.toolbar = []
+ self.numOfRows = 1 # number of rows for toolbar
+ for row in range(0, self.numOfRows):
+ self.toolbar.append(wx.ToolBar(parent=self.parent, id=wx.ID_ANY))
+ self.toolbar[row].SetToolBitmapSize(globalvar.toolbarSize)
+ self.toolbar[row].Bind(wx.EVT_TOOL, self.OnTool)
+ # create toolbar
+ if self.numOfRows == 1:
+ rowdata=None
+ else:
+ rowdata = row
+ self.InitToolbar(self.parent, self.toolbar[row], self.ToolbarData(rowdata))
+ # default action (digitize new point, line, etc.)
+ self.action = { 'desc' : 'addLine',
+ 'type' : 'point',
+ 'id' : self.addPoint }
+ # list of available vector maps
+ self.UpdateListOfLayers(updateTool=True)
+ # realize toolbar
+ self.toolbar[row].Realize()
+ self.combo.Hide()
+ self.combo.Show()
+ # disable undo/redo
+ self.toolbar[0].EnableTool(self.undo, False)
+ # toogle to pointer by default
+ self.OnTool(None)
+ self.FixSize(width = 105)
+ def ToolbarData(self, row=None):
+ Toolbar data
+ data = []
+ if row is None or row == 0:
+ self.addPoint = wx.NewId()
+ self.addLine = wx.NewId()
+ self.addBoundary = wx.NewId()
+ self.addCentroid = wx.NewId()
+ self.moveVertex = wx.NewId()
+ self.addVertex = wx.NewId()
+ self.removeVertex = wx.NewId()
+ self.splitLine = wx.NewId()
+ self.editLine = wx.NewId()
+ self.moveLine = wx.NewId()
+ self.deleteLine = wx.NewId()
+ self.additionalTools = wx.NewId()
+ self.displayCats = wx.NewId()
+ self.displayAttr = wx.NewId()
+ self.copyCats = wx.NewId()
+ data = [("", "", "", "", "", "", ""),
+ (self.addPoint, "digAddPoint", Icons["digAddPoint"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddPoint"].GetLabel(), Icons["digAddPoint"].GetDesc(),
+ self.OnAddPoint),
+ (self.addLine, "digAddLine", Icons["digAddLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddLine"].GetLabel(), Icons["digAddLine"].GetDesc(),
+ self.OnAddLine),
+ (self.addBoundary, "digAddBoundary", Icons["digAddBoundary"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddBoundary"].GetLabel(), Icons["digAddBoundary"].GetDesc(),
+ self.OnAddBoundary),
+ (self.addCentroid, "digAddCentroid", Icons["digAddCentroid"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddCentroid"].GetLabel(), Icons["digAddCentroid"].GetDesc(),
+ self.OnAddCentroid),
+ (self.moveVertex, "digMoveVertex", Icons["digMoveVertex"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digMoveVertex"].GetLabel(), Icons["digMoveVertex"].GetDesc(),
+ self.OnMoveVertex),
+ (self.addVertex, "digAddVertex", Icons["digAddVertex"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddVertex"].GetLabel(), Icons["digAddVertex"].GetDesc(),
+ self.OnAddVertex),
+ (self.removeVertex, "digRemoveVertex", Icons["digRemoveVertex"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digRemoveVertex"].GetLabel(), Icons["digRemoveVertex"].GetDesc(),
+ self.OnRemoveVertex),
+ (self.splitLine, "digSplitLine", Icons["digSplitLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digSplitLine"].GetLabel(), Icons["digSplitLine"].GetDesc(),
+ self.OnSplitLine),
+ (self.editLine, "digEditLine", Icons["digEditLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digEditLine"].GetLabel(), Icons["digEditLine"].GetDesc(),
+ self.OnEditLine),
+ (self.moveLine, "digMoveLine", Icons["digMoveLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digMoveLine"].GetLabel(), Icons["digMoveLine"].GetDesc(),
+ self.OnMoveLine),
+ (self.deleteLine, "digDeleteLine", Icons["digDeleteLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digDeleteLine"].GetLabel(), Icons["digDeleteLine"].GetDesc(),
+ self.OnDeleteLine),
+ (self.displayCats, "digDispCats", Icons["digDispCats"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digDispCats"].GetLabel(), Icons["digDispCats"].GetDesc(),
+ self.OnDisplayCats),
+ (self.copyCats, "digCopyCats", Icons["digCopyCats"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digCopyCats"].GetLabel(), Icons["digCopyCats"].GetDesc(),
+ self.OnCopyCA),
+ (self.displayAttr, "digDispAttr", Icons["digDispAttr"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digDispAttr"].GetLabel(), Icons["digDispAttr"].GetDesc(),
+ self.OnDisplayAttr),
+ (self.additionalTools, "digAdditionalTools", Icons["digAdditionalTools"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAdditionalTools"].GetLabel(),
+ Icons["digAdditionalTools"].GetDesc(),
+ self.OnAdditionalToolMenu)]
+ if row is None or row == 1:
+ self.undo = wx.NewId()
+ self.exit = wx.NewId()
+ data.append(("", "", "", "", "", "", ""))
+ data.append((self.undo, "digUndo", Icons["digUndo"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["digUndo"].GetLabel(), Icons["digUndo"].GetDesc(),
+ self.OnUndo))
+ # data.append((self.undo, "digRedo", Icons["digRedo"].GetBitmap(),
+ # wx.ITEM_NORMAL, Icons["digRedo"].GetLabel(), Icons["digRedo"].GetDesc(),
+ # self.OnRedo))
+ data.append((self.settings, "digSettings", Icons["digSettings"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["digSettings"].GetLabel(), Icons["digSettings"].GetDesc(),
+ self.OnSettings))
+ data.append((self.exit, "digExit", Icons["quit"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["digExit"].GetLabel(), Icons["digExit"].GetDesc(),
+ self.OnExit))
+ return data
+ """Tool selected -> disable selected tool in map toolbar"""
+ # update map toolbar (unselect currently selected tool)
+ id = self.parent.toolbars['map'].GetAction(type='id')
+ self.parent.toolbars['map'].toolbar.ToggleTool(id, False)
+ # set cursor
+ cursor = self.parent.cursors["cross"]
+ self.parent.MapWindow.SetCursor(cursor)
+ # pointer
+ self.parent.OnPointer(None)
+ if event:
+ self.toolbar[0].ToggleTool(self.action['id'], False)
+ else:
+ self.toolbar[0].ToggleTool(self.action['id'], True)
+ event.Skip()
+ else:
+ # clear tmp canvas
+ if self.action['id'] != id:
+ self.parent.MapWindow.ClearLines(pdc=self.parent.MapWindow.pdcTmp)
+ if self.parent.digit and \
+ len(self.parent.digit.driver.GetSelected()) > 0:
+ # cancel action
+ self.parent.MapWindow.OnMiddleDown(None)
+ def OnAddPoint(self, event):
+ """Add point to the vector map Laier"""
+ Debug.msg (2, "VDigitToolbar.OnAddPoint()")
+ self.action = { 'desc' : "addLine",
+ 'type' : "point",
+ self.parent.MapWindow.mouse['box'] = 'point'
+ def OnAddLine(self, event):
+ """Add line to the vector map layer"""
+ Debug.msg (2, "VDigitToolbar.OnAddLine()")
+ 'type' : "line",
+ 'id' : self.addLine }
+ self.parent.MapWindow.mouse['box'] = 'line'
+ ### self.parent.MapWindow.polycoords = [] # reset temp line
+ def OnAddBoundary(self, event):
+ """Add boundary to the vector map layer"""
+ Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
+ if self.action['desc'] != 'addLine' or \
+ self.action['type'] != 'boundary':
+ self.parent.MapWindow.polycoords = [] # reset temp line
+ 'type' : "boundary",
+ 'id' : self.addBoundary }
+ def OnAddCentroid(self, event):
+ """Add centroid to the vector map layer"""
+ Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
+ 'type' : "centroid",
+ 'id' : self.addCentroid }
+ def OnExit (self, event=None):
+ """Quit digitization tool"""
+ # stop editing of the currently selected map layer
+ if self.mapLayer:
+ self.StopEditing()
+ # close dialogs if still open
+ if self.settingsDialog:
+ self.settingsDialog.OnCancel(None)
+ # disable the toolbar
+ self.parent.RemoveToolbar ("vdigit")
+ # set default mouse settings
+ self.parent.MapWindow.mouse['use'] = "pointer"
+ self.parent.MapWindow.mouse['box'] = "point"
+ def OnMoveVertex(self, event):
+ """Move line vertex"""
+ Debug.msg(2, "Digittoolbar.OnMoveVertex():")
+ self.action = { 'desc' : "moveVertex",
+ 'id' : self.moveVertex }
+ def OnAddVertex(self, event):
+ """Add line vertex"""
+ Debug.msg(2, "Digittoolbar.OnAddVertex():")
+ self.action = { 'desc' : "addVertex",
+ 'id' : self.addVertex }
+ def OnRemoveVertex(self, event):
+ """Remove line vertex"""
+ Debug.msg(2, "Digittoolbar.OnRemoveVertex():")
+ self.action = { 'desc' : "removeVertex",
+ 'id' : self.removeVertex }
+ def OnSplitLine(self, event):
+ """Split line"""
+ Debug.msg(2, "Digittoolbar.OnSplitLine():")
+ self.action = { 'desc' : "splitLine",
+ 'id' : self.splitLine }
+ def OnEditLine(self, event):
+ """Edit line"""
+ Debug.msg(2, "Digittoolbar.OnEditLine():")
+ self.action = { 'desc' : "editLine",
+ 'id' : self.editLine }
+ def OnMoveLine(self, event):
+ """Move line"""
+ Debug.msg(2, "Digittoolbar.OnMoveLine():")
+ self.action = { 'desc' : "moveLine",
+ 'id' : self.moveLine }
+ self.parent.MapWindow.mouse['box'] = 'box'
+ def OnDeleteLine(self, event):
+ """Delete line"""
+ Debug.msg(2, "Digittoolbar.OnDeleteLine():")
+ self.action = { 'desc' : "deleteLine",
+ 'id' : self.deleteLine }
+ def OnDisplayCats(self, event):
+ """Display/update categories"""
+ Debug.msg(2, "Digittoolbar.OnDisplayCats():")
+ self.action = { 'desc' : "displayCats",
+ 'id' : self.displayCats }
+ def OnDisplayAttr(self, event):
+ """Display/update attributes"""
+ Debug.msg(2, "Digittoolbar.OnDisplayAttr():")
+ self.action = { 'desc' : "displayAttrs",
+ 'id' : self.displayAttr }
+ def OnCopyCA(self, event):
+ """Copy categories/attributes menu"""
+ point = wx.GetMousePosition()
+ toolMenu = wx.Menu()
+ # Add items to the menu
+ cats = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Copy categories'),
+ kind=wx.ITEM_CHECK)
+ toolMenu.AppendItem(cats)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyCats, cats)
+ if self.action['desc'] == "copyCats":
+ cats.Check(True)
+ attrb = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Duplicate attributes'),
+ toolMenu.AppendItem(attrb)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyAttrb, attrb)
+ if self.action['desc'] == "copyAttrs":
+ attrb.Check(True)
+ # Popup the menu. If an item is selected then its handler
+ # will be called before PopupMenu returns.
+ self.parent.MapWindow.PopupMenu(toolMenu)
+ toolMenu.Destroy()
+ if self.action['desc'] == "addPoint":
+ self.toolbar[0].ToggleTool(self.copyCats, False)
+ def OnCopyCats(self, event):
+ """Copy categories"""
+ if self.action['desc'] == 'copyCats': # select previous action
+ self.toolbar[0].ToggleTool(self.addPoint, True)
+ self.OnAddPoint(event)
+ return
+ Debug.msg(2, "Digittoolbar.OnCopyCats():")
+ self.action = { 'desc' : "copyCats",
+ 'id' : self.copyCats }
+ def OnCopyAttrb(self, event):
+ if self.action['desc'] == 'copyAttrs': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnCopyAttrb():")
+ self.action = { 'desc' : "copyAttrs",
+ def OnUndo(self, event):
+ """Undo previous changes"""
+ self.parent.digit.Undo()
+ event.Skip()
+ def EnableUndo(self, enable=True):
+ """Enable 'Undo' in toolbar
+ @param enable False for disable
+ if enable:
+ if self.toolbar[0].GetToolEnabled(self.undo) is False:
+ self.toolbar[0].EnableTool(self.undo, True)
+ else:
+ if self.toolbar[0].GetToolEnabled(self.undo) is True:
+ def OnSettings(self, event):
+ """Show settings dialog"""
+ if self.parent.digit is None:
+ reload(vdigit)
+ from vdigit import Digit as Digit
+ self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
+ if not self.settingsDialog:
+ self.settingsDialog = VDigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
+ style=wx.DEFAULT_DIALOG_STYLE)
+ self.settingsDialog.Show()
+ def OnAdditionalToolMenu(self, event):
+ """Menu for additional tools"""
+ copy = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Copy features from (background) vector map'),
+ toolMenu.AppendItem(copy)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
+ if self.action['desc'] == "copyLine":
+ copy.Check(True)
+ flip = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Flip selected lines/boundaries'),
+ toolMenu.AppendItem(flip)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
+ if self.action['desc'] == "flipLine":
+ flip.Check(True)
+ merge = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Merge selected lines/boundaries'),
+ toolMenu.AppendItem(merge)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnMerge, merge)
+ if self.action['desc'] == "mergeLine":
+ merge.Check(True)
+ breakL = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Break selected lines/boundaries at intersection'),
+ toolMenu.AppendItem(breakL)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnBreak, breakL)
+ if self.action['desc'] == "breakLine":
+ breakL.Check(True)
+ snap = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Snap selected lines/boundaries (only to nodes)'),
+ toolMenu.AppendItem(snap)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnSnap, snap)
+ if self.action['desc'] == "snapLine":
+ snap.Check(True)
+ connect = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Connect selected lines/boundaries'),
+ toolMenu.AppendItem(connect)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnConnect, connect)
+ if self.action['desc'] == "connectLine":
+ connect.Check(True)
+ query = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Query features'),
+ toolMenu.AppendItem(query)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnQuery, query)
+ if self.action['desc'] == "queryLine":
+ query.Check(True)
+ zbulk = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Z bulk-labeling of 3D lines'),
+ toolMenu.AppendItem(zbulk)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
+ if self.action['desc'] == "zbulkLine":
+ zbulk.Check(True)
+ typeconv = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Feature type conversion'),
+ toolMenu.AppendItem(typeconv)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
+ if self.action['desc'] == "typeConv":
+ typeconv.Check(True)
+ if self.action['desc'] == 'addPoint':
+ self.toolbar[0].ToggleTool(self.additionalTools, False)
+ def OnCopy(self, event):
+ """Copy selected features from (background) vector map"""
+ if self.action['desc'] == 'copyLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnCopy():")
+ self.action = { 'desc' : "copyLine",
+ 'id' : self.additionalTools }
+ def OnFlip(self, event):
+ """Flip selected lines/boundaries"""
+ if self.action['desc'] == 'flipLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnFlip():")
+ self.action = { 'desc' : "flipLine",
+ def OnMerge(self, event):
+ """Merge selected lines/boundaries"""
+ if self.action['desc'] == 'mergeLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnMerge():")
+ self.action = { 'desc' : "mergeLine",
+ def OnBreak(self, event):
+ """Break selected lines/boundaries"""
+ if self.action['desc'] == 'breakLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnBreak():")
+ self.action = { 'desc' : "breakLine",
+ def OnSnap(self, event):
+ """Snap selected features"""
+ if self.action['desc'] == 'snapLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnSnap():")
+ self.action = { 'desc' : "snapLine",
+ def OnConnect(self, event):
+ """Connect selected lines/boundaries"""
+ if self.action['desc'] == 'connectLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnConnect():")
+ self.action = { 'desc' : "connectLine",
+ def OnQuery(self, event):
+ """Query selected lines/boundaries"""
+ if self.action['desc'] == 'queryLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnQuery(): %s" % \
+ UserSettings.Get(group='vdigit', key='query', subkey='selection'))
+ self.action = { 'desc' : "queryLine",
+ def OnZBulk(self, event):
+ """Z bulk-labeling selected lines/boundaries"""
+ if not self.parent.digit.driver.Is3D():
+ wx.MessageBox(parent=self.parent,
+ message=_("Vector map is not 3D. Operation canceled."),
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ return
+ if self.action['desc'] == 'zbulkLine': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnZBulk():")
+ self.action = { 'desc' : "zbulkLine",
+ def OnTypeConversion(self, event):
+ """Feature type conversion
+ Supported conversions:
+ - point <-> centroid
+ - line <-> boundary
+ if self.action['desc'] == 'typeConv': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnTypeConversion():")
+ self.action = { 'desc' : "typeConv",
+ def OnSelectMap (self, event):
+ Select vector map layer for editing
+ If there is a vector map layer already edited, this action is
+ firstly terminated. The map layer is closed. After this the
+ selected map layer activated for editing.
+ if event.GetSelection() == 0: # create new vector map layer
+ if self.mapLayer:
+ openVectorMap = self.mapLayer.GetName(fullyQualified=False)['name']
+ else:
+ openVectorMap = None
+ mapName = gdialogs.CreateNewVector(self.parent,
+ exceptMap=openVectorMap, log=self.log,
+ cmdDef=(['v.edit', 'tool=create'], "map"),
+ disableAdd=True)[0]
+ if mapName:
+ # add layer to map layer tree
+ if self.layerTree:
+ self.layerTree.AddLayer(ltype='vector',
+ lname=mapName,
+ lchecked=True,
+ lopacity=1.0,
+ lcmd=['d.vect', 'map=%s' % mapName])
+ vectLayers = self.UpdateListOfLayers(updateTool=True)
+ selection = vectLayers.index(mapName)
+ else:
+ pass # TODO (no Layer Manager)
+ else:
+ self.combo.SetValue(_('Select vector map'))
+ return
+ else:
+ selection = event.GetSelection() - 1 # first option is 'New vector map'
+ # skip currently selected map
+ if self.layers[selection] == self.mapLayer:
+ return False
+ if self.mapLayer:
+ # deactive map layer for editing
+ # select the given map layer for editing
+ self.StartEditing(self.layers[selection])
+ event.Skip()
+ return True
+ def StartEditing (self, mapLayer):
+ Start editing selected vector map layer.
+ @param mapLayer reference to MapLayer instance
+ # deactive layer
+ self.mapcontent.ChangeLayerActive(mapLayer, False)
+ # clean map canvas
+ ### self.parent.MapWindow.EraseMap()
+ # unset background map if needed
+ if UserSettings.Get(group='vdigit', key='bgmap',
+ subkey='value', internal=True) == mapLayer.GetName():
+ UserSettings.Set(group='vdigit', key='bgmap',
+ subkey='value', value='', internal=True)
+ self.parent.statusbar.SetStatusText(_("Please wait, "
+ "opening vector map <%s> for editing...") % \
+ mapLayer.GetName(),
+ 0)
+ # reload vdigit module
+ reload(vdigit)
+ self.mapLayer = mapLayer
+ # open vector map
+ try:
+ self.parent.digit.SetMapName(mapLayer.GetName())
+ except gcmd.DigitError, e:
+ print >> sys.stderr, e # wxMessageBox
+ return False
+ # update toolbar
+ self.combo.SetValue(mapLayer.GetName())
+ self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
+ Debug.msg (4, "VDigitToolbar.StartEditing(): layer=%s" % mapLayer.GetName())
+ # change cursor
+ if self.parent.MapWindow.mouse['use'] == 'pointer':
+ self.parent.MapWindow.SetCursor(self.parent.cursors["cross"])
+ # create pseudoDC for drawing the map
+ self.parent.MapWindow.pdcVector = vdigit.PseudoDC()
+ self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
+ if not self.parent.MapWindow.resize:
+ self.parent.MapWindow.UpdateMap(render=True)
+ opacity = mapLayer.GetOpacity(float=True)
+ if opacity < 1.0:
+ alpha = int(opacity * 255)
+ self.parent.digit.driver.UpdateSettings(alpha)
+ return True
+ def StopEditing (self):
+ """Stop editing of selected vector map layer.
+ @return True on success
+ @return False on failure
+ if not self.mapLayer:
+ return False
+ Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
+ self.combo.SetValue (_('Select vector map'))
+ # save changes
+ if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
+ if self.parent.digit.GetUndoLevel() > 0:
+ dlg = wx.MessageDialog(parent=self.parent,
+ message=_("Do you want to save changes "
+ "in vector map <%s>?") % self.mapLayer.GetName(),
+ caption=_("Save changes?"),
+ style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ if dlg.ShowModal() == wx.ID_NO:
+ # revert changes
+ self.parent.digit.Undo(0)
+ dlg.Destroy()
+ "closing and rebuilding topology of "
+ "vector map <%s>...") % self.mapLayer.GetName(),
+ 0)
+ self.parent.digit.SetMapName(None) # -> close map
+ # re-active layer
+ item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
+ if item and self.parent.tree.IsItemChecked(item):
+ self.mapcontent.ChangeLayerActive(self.mapLayer, True)
+ # change cursor
+ self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
+ # disable pseudodc for vector map layer
+ self.parent.MapWindow.pdcVector = None
+ self.parent.digit.driver.SetDevice(None)
+ # close dialogs
+ for dialog in ('attributes', 'category'):
+ if self.parent.dialogs[dialog]:
+ self.parent.dialogs[dialog].Close()
+ self.parent.dialogs[dialog] = None
+ self.parent.digit.__del__() # FIXME: destructor is not called here (del)
+ self.parent.digit = None
+ self.parent.MapWindow.redrawAll = True
+ return True
+ def UpdateListOfLayers (self, updateTool=False):
+ Update list of available vector map layers.
+ This list consists only editable layers (in the current mapset)
+ Optionally also update toolbar
+ Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
+ updateTool)
+ layerNameSelected = None
+ # name of currently selected layer
+ if self.mapLayer:
+ layerNameSelected = self.mapLayer.GetName()
+ # select vector map layer in the current mapset
+ layerNameList = []
+ self.layers = self.mapcontent.GetListOfLayers(l_type="vector",
+ l_mapset=grassenv.GetGRASSVariable('MAPSET'))
+ for layer in self.layers:
+ if not layer.name in layerNameList: # do not duplicate layer
+ layerNameList.append (layer.GetName())
+ if updateTool: # update toolbar
+ value = _('Select vector map')
+ else:
+ value = layerNameSelected
+ if not self.comboid:
+ self.combo = wx.ComboBox(self.toolbar[self.numOfRows-1], id=wx.ID_ANY, value=value,
+ choices=[_('New vector map'), ] + layerNameList, size=(85, -1),
+ style=wx.CB_READONLY)
+ self.comboid = self.toolbar[self.numOfRows-1].InsertControl(0, self.combo)
+ self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectMap, self.comboid)
+ else:
+ self.combo.SetItems([_('New vector map'), ] + layerNameList)
+ self.toolbar[self.numOfRows-1].Realize()
+ return layerNameList
+ def GetLayer(self):
+ """Get selected layer for editing -- MapLayer instance"""
+ return self.mapLayer
+class ProfileToolbar(AbstractToolbar):
+ Toolbar for profiling raster map
+ self.transect = wx.NewId()
+ self.addraster = wx.NewId()
+ self.draw = wx.NewId()
+ self.options = wx.NewId()
+ self.drag = wx.NewId()
+ self.zoom = wx.NewId()
+ self.unzoom = wx.NewId()
+ self.save = wx.NewId()
+ self.printer = wx.NewId()
+ return (
+ (self.addraster, 'raster', Icons["addrast"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
+ self.parent.OnSelectRaster),
+ (self.transect, 'transect', Icons["transect"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["transect"].GetLabel(), Icons["transect"].GetDesc(),
+ self.parent.OnDrawTransect),
+ (self.draw, 'profiledraw', Icons["profiledraw"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["profiledraw"].GetLabel(), Icons["profiledraw"].GetDesc(),
+ self.parent.OnCreateProfile),
+ (self.options, 'options', Icons["profileopt"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["profileopt"].GetLabel(), Icons["profileopt"].GetDesc(),
+ self.parent.ProfileOptionsMenu),
+ (self.drag, 'drag', Icons['pan'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+ self.parent.OnDrag),
+ (self.zoom, 'zoom', Icons['zoom_in'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+ self.parent.OnZoom),
+ (self.unzoom, 'unzoom', Icons['zoom_back'].GetBitmap(),
+ self.parent.OnRedraw),
+ (self.erase, 'erase', Icons["erase"].GetBitmap(),
+ self.parent.OnErase),
+ (self.save, 'save', Icons["savefile"].GetBitmap(),
+ self.parent.SaveToFile),
+ (self.printer, 'print', Icons["printmap"].GetBitmap(),
+ self.parent.PrintMenu),
+ (self.quit, 'quit', Icons["quit"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
+ self.parent.OnQuit),
+class NvizToolbar(AbstractToolbar):
+ Nviz toolbar
+ def __init__(self, parent, map):
+ self.toolbar = wx.ToolBar(parent=self.parent, id=wx.ID_ANY)
+ self.InitToolbar(self.parent, self.toolbar, self.ToolbarData())
+ return (
+ (self.settings, "settings", Icons["nvizSettings"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["nvizSettings"].GetLabel(), Icons["nvizSettings"].GetDesc(),
+ self.OnSettings),
+ self.OnExit),
+ win = self.parent.nvizToolWin
+ if not win.IsShown():
+ self.parent.nvizToolWin.Show()
+ else:
+ self.parent.nvizToolWin.Hide()
+ """Quit nviz tool (swith to 2D mode)"""
+ # hide dialogs if still open
+ if self.parent.nvizToolWin:
+ self.parent.RemoveToolbar ("nviz")
