[GRASS-SVN] r40824 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Fri Feb 5 03:31:53 EST 2010
Author: hamish
Date: 2010-02-05 03:31:50 -0500 (Fri, 05 Feb 2010)
New Revision: 40824
grass/trunk/gui/wxpython/xml/menudata.xml
fix v.label in menu (trac #907; merge from devbr6; text cosmetics)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2010-02-05 08:26:25 UTC (rev 40823)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2010-02-05 08:31:50 UTC (rev 40824)
@@ -1829,17 +1829,17 @@
<separator />
<menuitem>
<label>Create labels</label>
- <help>Creates optimally placed labels for vector map from associated attributes</help>
+ <help>Creates paint labels for a vector map from attached attributes.</help>
<keywords>vector,paint labels</keywords>
<handler>self.OnMenuCmd</handler>
- <command>v.label.sa</command>
+ <command>v.label</command>
</menuitem>
<menuitem>
<label>Create optimally placed labels</label>
- <help>Creates paint labels for a vector map from attached attributes.</help>
+ <help>Create optimally placed labels for a vector map from attached attributes.</help>
- <command>v.label</command>
+ <command>v.label.sa</command>
</menuitem>
<separator />
<menuitem>
