[GRASS-SVN] r40881 - in grass/trunk: gui/wxpython/nviz
	gui/wxpython/vdigit lib/gis visualization/wximgview
    svn_grass at osgeo.org
    Mon Feb  8 21:28:11 EST 2010
Author: glynn
Date: 2010-02-08 21:28:10 -0500 (Mon, 08 Feb 2010)
New Revision: 40881
   grass/trunk/gui/wxpython/nviz/Makefile
   grass/trunk/gui/wxpython/nviz/setup.py
   grass/trunk/gui/wxpython/vdigit/Makefile
   grass/trunk/gui/wxpython/vdigit/setup.py
   grass/trunk/lib/gis/popen.c
   grass/trunk/visualization/wximgview/main.cc
Windows fixes
Modified: grass/trunk/gui/wxpython/nviz/Makefile
--- grass/trunk/gui/wxpython/nviz/Makefile	2010-02-09 01:37:59 UTC (rev 40880)
+++ grass/trunk/gui/wxpython/nviz/Makefile	2010-02-09 02:28:10 UTC (rev 40881)
@@ -46,6 +46,7 @@
 	WXWIDGETSLIB="$(WXWIDGETSLIB)" \
 	OPENGL_X11="$(OPENGL_X11)" \
 	XCFLAGS="$(XCFLAGS)" \
+	CXXFLAGS="$(COMPILE_FLAGS_CXX)" \
 	$(PYTHON) setup.py build_ext --swig=$(SWIG) --swig-opts=-c++ --build-lib=$(OBJDIR) --build-temp=$(OBJDIR)
 .NOTPARALLEL: $(LIB_NAME).py $(LIB_NAME)_wrap.cpp
Modified: grass/trunk/gui/wxpython/nviz/setup.py
--- grass/trunk/gui/wxpython/nviz/setup.py	2010-02-09 01:37:59 UTC (rev 40880)
+++ grass/trunk/gui/wxpython/nviz/setup.py	2010-02-09 02:28:10 UTC (rev 40881)
@@ -26,7 +26,8 @@
         'grass_g3d']
 extras = []
-for flag in ['GDALCFLAGS',
+for flag in ['CXXFLAGS',
+	     'GDALCFLAGS',
              'GDALLIBS',
              'WXWIDGETSCXXFLAGS',
              'OPENGLINC',
Modified: grass/trunk/gui/wxpython/vdigit/Makefile
--- grass/trunk/gui/wxpython/vdigit/Makefile	2010-02-09 01:37:59 UTC (rev 40880)
+++ grass/trunk/gui/wxpython/vdigit/Makefile	2010-02-09 02:28:10 UTC (rev 40881)
@@ -41,6 +41,7 @@
 	GEOSCFLAGS="$(GEOSCFLAGS)" \
 	WXWIDGETSCXXFLAGS="$(WXWIDGETSCXXFLAGS)" \
Modified: grass/trunk/gui/wxpython/vdigit/setup.py
--- grass/trunk/gui/wxpython/vdigit/setup.py	2010-02-09 01:37:59 UTC (rev 40880)
+++ grass/trunk/gui/wxpython/vdigit/setup.py	2010-02-09 02:28:10 UTC (rev 40881)
@@ -27,7 +27,8 @@
         'grass_vedit']
 extras = []
+	     'GDALCFLAGS',
              'GDALLIBS',
              'GEOSCFLAGS',
              'WXWIDGETSLIB',
Modified: grass/trunk/lib/gis/popen.c
--- grass/trunk/lib/gis/popen.c	2010-02-09 01:37:59 UTC (rev 40880)
+++ grass/trunk/lib/gis/popen.c	2010-02-09 02:28:10 UTC (rev 40881)
@@ -6,6 +6,12 @@
 #include <grass/gis.h>
 #include <grass/spawn.h>
+#ifdef __MINGW32__
+#include <io.h>
+#include <fcntl.h>
+#define pipe(fds) _pipe(fds, 4096, O_BINARY)
+#endif
 static FILE *do_popen(struct Popen *state, int wr,
 		      const char *program, const char **args)
Modified: grass/trunk/visualization/wximgview/main.cc
--- grass/trunk/visualization/wximgview/main.cc	2010-02-09 01:37:59 UTC (rev 40880)
+++ grass/trunk/visualization/wximgview/main.cc	2010-02-09 02:28:10 UTC (rev 40881)
@@ -189,11 +189,13 @@
 #ifdef __MINGW32__
     ptr = MapViewOfFile((HANDLE) _get_osfhandle(fd),
 			FILE_MAP_READ, 0, 0, size);
+    if (!ptr)
+	G_fatal_error(_("Unable to map image file"));
 #else
     ptr = mmap(NULL, size, PROT_READ, MAP_SHARED, fd, (off_t) 0);
-#endif
     if (ptr == MAP_FAILED)
+#endif
     imgbuf = (unsigned char *)ptr + HEADER_SIZE;
@@ -208,13 +210,14 @@
 static void set_handler(void)
+#ifndef __MINGW32__
     struct sigaction act;
     act.sa_handler = &dummy_handler;
     sigemptyset(&act.sa_mask);
     act.sa_flags = 0;
     sigaction(SIGUSR1, &act, NULL);
+#endif
 bool MyApp::OnInit()
