[GRASS-SVN] r40893 - grass/branches/releasebranch_6_4/lib/gis
Tue Feb 9 05:44:35 EST 2010
Author: hamish
Date: 2010-02-09 05:44:34 -0500 (Tue, 09 Feb 2010)
New Revision: 40893
   grass/branches/releasebranch_6_4/lib/gis/datumtransform.table
reword to avoid confusion with mathematical 'add' (merge from devbr6 r40880)
Modified: grass/branches/releasebranch_6_4/lib/gis/datumtransform.table
--- grass/branches/releasebranch_6_4/lib/gis/datumtransform.table	2010-02-09 10:44:29 UTC (rev 40892)
+++ grass/branches/releasebranch_6_4/lib/gis/datumtransform.table	2010-02-09 10:44:34 UTC (rev 40893)
@@ -14,8 +14,9 @@
 # and will be presented to the user to select the most appropriate one for
 # his/her location. The "Where Used" and "Comment" fields should contain
 # information to aid in the user's decision.
-# If only the 7-parameter transformation is desired/known, add 99999 for
-# the 3 parameters in datum.table along with the correct ellipsoid.
+# If only the 7-parameter transformation is desired/known, set all 3 of
+# the 3-term parameters in datum.table to be 99999, along with the correct
+# ellipsoid.
 # Any supplementary files needed by the PROJ.4 library (e.g. gridshift tables)
 # should be placed in the directory $GISBASE/etc/nad/.
