[GRASS-SVN] r40912 - grass/branches/releasebranch_6_4/lib/segment
Wed Feb 10 09:29:32 EST 2010
Author: mmetz
Date: 2010-02-10 09:29:31 -0500 (Wed, 10 Feb 2010)
New Revision: 40912
   grass/branches/releasebranch_6_4/lib/segment/format.c
fix nonsense if statements, backport from trunk r40910
Modified: grass/branches/releasebranch_6_4/lib/segment/format.c
--- grass/branches/releasebranch_6_4/lib/segment/format.c	2010-02-10 14:28:56 UTC (rev 40911)
+++ grass/branches/releasebranch_6_4/lib/segment/format.c	2010-02-10 14:29:31 UTC (rev 40912)
@@ -119,20 +119,7 @@
 	return -3;
-    /* no LFS, file size within 2GB limit ? */
-    if (sizeof(off_t) == 4) {
-	double file_size;
-	file_size = (double) nrows * ncols * len;
-	if (file_size > INT_MAX) {
-	    G_warning("segment file size would be %.2fGB, but file size limit is 2GB", file_size / (1 << 30));
-	    G_warning("please recompile with LFS");
-	    G_fatal_error("can not create temporary segment file");
-    if (lseek(fd, 0L, SEEK_SET) == (off_t) - 1) {
+    if (lseek(fd, 0L, SEEK_SET) == (off_t) -1) {
 	G_warning("Segment_format: %s", strerror(errno));
 	return -1;
@@ -170,15 +157,12 @@
 static int write_int(int fd, int n)
-    int x;
-    int bytes_wrote;
-    x = n;
-    if ((bytes_wrote = write(fd, &x, sizeof(int)) == sizeof(int)) < 0)
+    if (write(fd, &n, sizeof(int)) != sizeof(int)) {
 	G_warning("%s", strerror(errno));
+	return 0;
-    return bytes_wrote;
+    return 1;
