[GRASS-SVN] r40916 -
grass/branches/releasebranch_6_4/raster/r.region
svn_grass at osgeo.org
Wed Feb 10 14:35:41 EST 2010
Author: neteler
Date: 2010-02-10 14:35:41 -0500 (Wed, 10 Feb 2010)
New Revision: 40916
grass/branches/releasebranch_6_4/raster/r.region/main.c
Use standard options, add ->gisprompt settings (backport)
Modified: grass/branches/releasebranch_6_4/raster/r.region/main.c
--- grass/branches/releasebranch_6_4/raster/r.region/main.c 2010-02-10 19:35:27 UTC (rev 40915)
+++ grass/branches/releasebranch_6_4/raster/r.region/main.c 2010-02-10 19:35:41 UTC (rev 40916)
@@ -87,21 +87,18 @@
parm.region->multiple = NO;
parm.region->type = TYPE_STRING;
parm.region->description = _("Set region from named region");
+ parm.region->gisprompt = "old,windows,region";
- parm.raster = G_define_option();
+ parm.raster = G_define_standard_option(G_OPT_R_MAP);
parm.raster->key = "raster";
- parm.raster->key_desc = "name";
parm.raster->required = NO;
parm.raster->multiple = NO;
- parm.raster->type = TYPE_STRING;
parm.raster->description = _("Set region to match this raster map");
- parm.vect = G_define_option();
+ parm.vect = G_define_standard_option(G_OPT_V_MAP);
parm.vect->key = "vector";
- parm.vect->key_desc = "name";
parm.vect->required = NO;
parm.vect->multiple = NO;
- parm.vect->type = TYPE_STRING;
parm.vect->description = _("Set region to match this vector map");
parm.view = G_define_option();
@@ -111,6 +108,7 @@
parm.view->multiple = NO;
parm.view->type = TYPE_STRING;
parm.view->description = _("Set region to match this 3dview file");
+ parm.view->gisprompt = "old,3d.view,3d view";
parm.north = G_define_option();
parm.north->key = "n";
@@ -152,12 +150,10 @@
llinfo(_("Value for the western edge"), G_lon_format_string(),
window.proj);
- parm.align = G_define_option();
+ parm.align = G_define_standard_option(G_OPT_R_MAP);
parm.align->key = "align";
- parm.align->key_desc = "name";
parm.align->required = NO;
parm.align->multiple = NO;
- parm.align->type = TYPE_STRING;
parm.align->description = _("Raster map to align to");
if (G_parser(argc, argv))
