[GRASS-SVN] r40934 - grass-addons/ossim_grass/r.planet
svn_grass at osgeo.org
Thu Feb 11 16:45:13 EST 2010
Author: epifanio
Date: 2010-02-11 16:45:12 -0500 (Thu, 11 Feb 2010)
New Revision: 40934
grass-addons/ossim_grass/r.planet/r.planet.py
add ossim-orthoigen export ability
Modified: grass-addons/ossim_grass/r.planet/r.planet.py
--- grass-addons/ossim_grass/r.planet/r.planet.py 2010-02-11 19:45:40 UTC (rev 40933)
+++ grass-addons/ossim_grass/r.planet/r.planet.py 2010-02-11 21:45:12 UTC (rev 40934)
@@ -64,9 +64,12 @@
#% key: r
#% description: Remove raster
#%END
+#%flag
+#% key: d
+#% description: Orthoigen
+#%END
import sys
import os
import socket
@@ -76,6 +79,7 @@
def main():
add = flags['a']
remove = flags['r']
+ orthoigen = flags['d']
host = options['host']
dport = options['dport']
pport = options['pport']
@@ -123,8 +127,23 @@
if remove :
removefile(output,host,dport)
print 'Removed raster file :', mappa[0]
+ if orthoigen :
+ path = os.path.dirname(output)
+ print path
+ elevdir = os.path.join(path,'elevation',mappa[0])
+ os.makedirs(elevdir)
+ print elevdir
+ elev = mappa[0]+'.tiff'
+ exportiff(output,elev)
+ instr = make3d(10801, elev, elevdir)
+ os.system(instr)
+def exportiff(infile,outfile):
+ gdal.GetDriverByName('GTiff').CreateCopy(outfile,gdal.Open(infile))
def addfile(output,host,dport):
ossim_data_xml = "<Add target=':idolbridge'><Image groupType='groundTexture'><filename>%s</filename> <id>%s</id><name>%s</name></Image></Add>" % (output,output,output)
ossimdata = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
@@ -231,6 +250,56 @@
return center
+def makedir(path):
+ d = os.path.dirname(path)
+ if not os.path.exists(d):
+ os.makedirs(d)
+def make3d(tile, elev, outdir):
+ makedir(outdir)
+ kwl = 'elev.kwl'
+ template = 'igen.slave_tile_buffers: 5 \n'
+ template += 'igen.tiling.type: ossimTiling \n'
+ template += 'igen.tiling.tiling_distance: 1 1 \n'
+ template += 'igen.tiling.tiling_distance_type: degrees \n'
+ template += 'igen.tiling.delta: %s %s \n' % (tile,tile)
+ template += 'igen.tiling.delta_type: total_pixels \n'
+ template += 'igen.tiling.padding_size_in_pixels: 0 0 \n'
+ template += 'object1.description: \n'
+ template += 'object1.enabled: 1 \n'
+ template += 'object1.id: 1 \n'
+ template += 'object1.object1.description: \n'
+ template += 'object1.object1.enabled: 1 \n'
+ template += 'object1.object1.id: 2 \n'
+ template += 'object1.object1.resampler.magnify_type: bilinear \n'
+ template += 'object1.object1.resampler.minify_type: bilinear \n'
+ template += 'object1.object1.type: ossimImageRenderer \n'
+ template += 'object1.object2.type: ossimCastTileSourceFilter \n'
+ template += 'object1.object2.scalar_type: ossim_sint16 \n'
+ template += 'object1.type: ossimImageChain \n'
+ template += 'object2.type: ossimGeneralRasterWriter \n'
+ template += 'object2.byte_order: big_endian \n'
+ template += 'object2.create_overview: false \n'
+ template += 'object2.create_histogram: false \n'
+ template += 'object2.create_external_geometry: false \n'
+ template += 'product.projection.type: ossimEquDistCylProjection \n'
+ open(kwl,'w').write(template)
+ instr = 'export DYLD_FRAMEWORK_PATH=/Users/sasha/OssimBuilds/Release/ ; '
+ instr += '/Users/sasha/OssimBuilds/Release/ossim-orthoigen'
+ instr += ' --tiling-template '
+ instr += kwl
+ instr +=' --view-template '
+ instr += kwl
+ instr +=' --writer-template '
+ instr += kwl
+ instr +=' --chain-template '
+ instr += kwl
+ instr += ' %s ' % elev
+ instr += '%s' % outdir
+ instr +='/%SRTM%'
+ return instr
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
