[GRASS-SVN] r40957 - in grass/trunk/general: . g.pnmcat
svn_grass at osgeo.org
Fri Feb 12 23:39:05 EST 2010
Author: glynn
Date: 2010-02-12 23:39:05 -0500 (Fri, 12 Feb 2010)
New Revision: 40957
Added:
grass/trunk/general/g.pnmcat/
grass/trunk/general/g.pnmcat/Makefile
grass/trunk/general/g.pnmcat/g.pnmcat.html
grass/trunk/general/g.pnmcat/main.c
Add g.pnmcat module (for use by NVIZ)
Property changes on: grass/trunk/general/g.pnmcat
___________________________________________________________________
Added: svn:ignore
+ OBJ.*
Added: grass/trunk/general/g.pnmcat/Makefile
--- grass/trunk/general/g.pnmcat/Makefile (rev 0)
+++ grass/trunk/general/g.pnmcat/Makefile 2010-02-13 04:39:05 UTC (rev 40957)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = g.pnmcat
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/general/g.pnmcat/g.pnmcat.html
--- grass/trunk/general/g.pnmcat/g.pnmcat.html (rev 0)
+++ grass/trunk/general/g.pnmcat/g.pnmcat.html 2010-02-13 04:39:05 UTC (rev 40957)
@@ -0,0 +1,24 @@
+<H2>DESCRIPTION</H2>
+<p>
+Concatenate PNM tiles into a single image.
+<p>
+This module is for use by NVIZ' "Maximum resolution PPM" option.
+<p>
+It concatenates a grid of <rows> x <cols> binary PPM
+images into a single image. The images must all be named
+<base>_<row>_<col>.ppm, where <row> and
+<col> start from one, with row one being the bottom row, and
+where <base> is the value of the <em>base=</em> option.
+<p>
+All images within a row must have the same height, and the widths must
+sum to the value of the <em>width=</em> option. The heights of the individual
+rows must sum to the value of the <em>height=</em> option. All images must be
+in "P6" (binary PPM) format.
+<h2>SEE ALSO</h2>
+<em><a href="nviz.html">NVIZ</a></em>
+<H2>AUTHOR</H2>
+Glynn Clements
+<p><i>Last changed: $Date: 2008-08-15 07:16:42 +0100 (Fri, 15 Aug 2008) $</i>
Added: grass/trunk/general/g.pnmcat/main.c
--- grass/trunk/general/g.pnmcat/main.c (rev 0)
+++ grass/trunk/general/g.pnmcat/main.c 2010-02-13 04:39:05 UTC (rev 40957)
@@ -0,0 +1,220 @@
+ * MODULE: g.pnmcat
+ * AUTHOR(S): Glynn Clements
+ * PURPOSE: Concatenate PNM tiles into a single image, for use by NVIZ'
+ * "Max. Resolution PPM" option.
+ * COPYRIGHT: (C) 2010 by Glynn Clements
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <stdarg.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+struct infile {
+ FILE *fp;
+ int width;
+static void read_line(char *buf, int size, FILE *fp)
+ for (;;) {
+ if (!fgets(buf, size, fp))
+ G_fatal_error(_("Error reading PPM file"));
+ if (buf[0] != '#')
+ return;
+static void read_header(FILE *fp, int *width, int *height)
+ char buf[80];
+ char magic;
+ int maxval;
+ read_line(buf, sizeof(buf), fp);
+ if (sscanf(buf, "P%c", &magic) != 1)
+ G_fatal_error(_("Invalid PPM file"));
+ if (magic != '6')
+ G_fatal_error(_("Unsupported PPM file (format = P6 required)"));
+ if (sscanf(buf, "%d %d", width, height) != 2)
+ if (sscanf(buf, "%d", &maxval) != 1)
+ if (maxval != 255)
+ G_fatal_error(_("Unsupported PPM file (maxval = 255 required)"));
+static void open_files(const char *base, struct infile *infiles,
+ int row, int cols,
+ int *p_width, int *p_height)
+ int r_width = 0;
+ int r_height;
+ int col;
+ for (col = 0; col < cols; col++) {
+ struct infile *infile = &infiles[col];
+ char path[GPATH_MAX];
+ int c_width, c_height;
+ FILE *fp;
+ sprintf(path, "%s_%d_%d.ppm", base, row + 1, col + 1);
+ fp = fopen(path, "rb");
+ if (!fp)
+ G_fatal_error(_("File <%s> not found"), path);
+ read_header(fp, &c_width, &c_height);
+ r_width += c_width;
+ if (col == 0)
+ r_height = c_height;
+ else
+ if (c_height != r_height)
+ G_fatal_error(_("File <%s> has wrong height (expected %d, got %d"),
+ path, r_height, c_height);
+ infile->fp = fp;
+ infile->width = c_width;
+ *p_width = r_width;
+ *p_height = r_height;
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct
+ struct Option *base, *out, *rows, *cols, *width, *height;
+ } opt;
+ int rows, cols, width, height;
+ int row, col;
+ int t_height = 0;
+ FILE *out_fp;
+ struct infile *infiles;
+ char *buf;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("general"));
+ module->description = "Concatenates multiple PPM image files";
+ opt.base = G_define_option();
+ opt.base->key = "base";
+ opt.base->type = TYPE_STRING;
+ opt.base->required = YES;
+ opt.base->description = _("Base name of input files");
+ opt.out = G_define_option();
+ opt.out->key = "output";
+ opt.out->type = TYPE_STRING;
+ opt.out->required = YES;
+ opt.out->description = _("Name of output file");
+ opt.out->gisprompt = "new_file,file,output";
+ opt.rows = G_define_option();
+ opt.rows->key = "rows";
+ opt.rows->type = TYPE_INTEGER;
+ opt.rows->required = YES;
+ opt.rows->description = _("Number of rows");
+ opt.cols = G_define_option();
+ opt.cols->key = "cols";
+ opt.cols->type = TYPE_INTEGER;
+ opt.cols->required = YES;
+ opt.cols->description = _("Number of columns");
+ opt.width = G_define_option();
+ opt.width->key = "width";
+ opt.width->type = TYPE_INTEGER;
+ opt.width->required = YES;
+ opt.width->description = _("Image width");
+ opt.height = G_define_option();
+ opt.height->key = "height";
+ opt.height->type = TYPE_INTEGER;
+ opt.height->required = YES;
+ opt.height->description = _("Image height");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ rows = atoi(opt.rows->answer);
+ cols = atoi(opt.cols->answer);
+ width = atoi(opt.width->answer);
+ height = atoi(opt.height->answer);
+ infiles = G_malloc(cols * sizeof(struct infile));
+ buf = G_malloc(width * 3);
+ out_fp = fopen(opt.out->answer, "wb");
+ if (!out_fp)
+ G_fatal_error(_("Unable to open output file <%s>"), opt.out->answer);
+ fprintf(out_fp, "P6\n%d %d\n255\n", width, height);
+ for (row = 0; row < rows; row++) {
+ int r_width = 0, r_height;
+ int i;
+ open_files(opt.base->answer, infiles, rows - 1 - row, cols, &r_width, &r_height);
+ if (r_width != width)
+ G_fatal_error(_("Row <%d> has wrong width (expected %d, got %d"),
+ row, width, r_width);
+ t_height += r_height;
+ if (t_height > height)
+ G_fatal_error(_("Invalid height (expected %d, got %d"),
+ height, t_height);
+ for (i = 0; i < r_height; i++) {
+ char *p = buf;
+ if (fread(p, 3, infile->width, infile->fp) != infile->width)
+ G_fatal_error(_("Error reading PPM file for tile <%d,%d> at row <%d>"),
+ row, col, i);
+ p += 3 * infile->width;
+ if (fwrite(buf, 3, width, out_fp) != width)
+ G_fatal_error(_("Error writing PPM file for tile row <%d> at row <%d>"),
+ row, i);
+ fclose(infiles[col].fp);
+ if (t_height != height)
+ G_fatal_error(_("Incorrect height (expected %d, got %d"),
+ fclose(out_fp);
+ return 0;
