[GRASS-SVN] r40961 - grass/trunk/raster/r.external
Fri Feb 12 23:44:48 EST 2010
Author: glynn
Date: 2010-02-12 23:44:47 -0500 (Fri, 12 Feb 2010)
New Revision: 40961
   grass/trunk/raster/r.external/main.c
Allow linking all bands (#914)
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c	2010-02-13 04:42:19 UTC (rev 40960)
+++ grass/trunk/raster/r.external/main.c	2010-02-13 04:44:47 UTC (rev 40961)
@@ -514,7 +514,7 @@
 	struct Option *input, *source, *output, *band, *title;
     } parm;
     struct Flag *flag_o, *flag_f, *flag_e, *flag_r, *flag_h, *flag_v;
-    int band;
+    int min_band, max_band, band;
     struct band_info info;
     int flip;
@@ -545,8 +545,7 @@
     parm.band->key = "band";
     parm.band->type = TYPE_INTEGER;
     parm.band->required = NO;
-    parm.band->description = _("Band to select");
-    parm.band->answer = "1";
+    parm.band->description = _("Band to select (default: all)");
     parm.title = G_define_option();
     parm.title->key = "title";
@@ -609,11 +608,6 @@
     else
 	title = NULL;
-    if (parm.band->answer)
-	band = atoi(parm.band->answer);
-    else
-	band = 1;
     if (!input && !source)
 	G_fatal_error(_("Name for input source not specified"));
@@ -642,18 +636,42 @@
     check_projection(&cellhd, hDS, flag_o->answer);
+    Rast_set_window(&cellhd);
+    if (parm.band->answer)
+	min_band = max_band = atoi(parm.band->answer);
+    else
+	min_band = 1, max_band = GDALGetRasterCount(hDS);
     G_verbose_message(_("Proceeding with import..."));
-    G_message("Importing band %d of %d...", band, GDALGetRasterCount( hDS ));
-    hBand = GDALGetRasterBand(hDS, band);
-    if (!hBand)
-	G_fatal_error(_("Selected band (%d) does not exist"), band);
+    for (band = min_band; band <= max_band; band++) {
+	char *output2, *title2 = NULL;
-    Rast_set_window(&cellhd);
+	G_message("Importing band %d of %d...", band, GDALGetRasterCount( hDS ));
-    query_band(hBand, output, flag_r->answer, &cellhd, &info);
-    create_map(input, band, output, &cellhd, &info, title, flip);
+	hBand = GDALGetRasterBand(hDS, band);
+	if (!hBand)
+	    G_fatal_error(_("Selected band (%d) does not exist"), band);
+	if (max_band > min_band) {
+	    G_asprintf(&output2, "%s.%d", output, band);
+	    if (title)
+		G_asprintf(&title2, "%s (band %d)", title, band);
+	else {
+	    output2 = G_store(output);
+	    if (title)
+		title2 = G_store(title);
+	query_band(hBand, output2, flag_r->answer, &cellhd, &info);
+	create_map(input, band, output2, &cellhd, &info, title, flip);
+	G_free(output2);
+	G_free(title2);
     if (flag_e->answer)
 	update_default_window(&cellhd);
