[GRASS-SVN] r40968 - grass/branches/develbranch_6/raster/r.external
svn_grass at osgeo.org
Sat Feb 13 04:36:21 EST 2010
Author: neteler
Date: 2010-02-13 04:36:21 -0500 (Sat, 13 Feb 2010)
New Revision: 40968
grass/branches/develbranch_6/raster/r.external/description.html
grass/branches/develbranch_6/raster/r.external/main.c
Link all bands by default (trac #914, backport of r40961)
Modified: grass/branches/develbranch_6/raster/r.external/description.html
--- grass/branches/develbranch_6/raster/r.external/description.html 2010-02-13 09:35:30 UTC (rev 40967)
+++ grass/branches/develbranch_6/raster/r.external/description.html 2010-02-13 09:36:21 UTC (rev 40968)
@@ -9,9 +9,8 @@
<h3>RGB Orthophoto from GeoTIFF</h3>
<div class="code"><pre>
-r.external /home/user/data/maps/059100.tif out=ortho.1 band=1
-r.external /home/user/data/maps/059100.tif out=ortho.2 band=2
-r.external /home/user/data/maps/059100.tif out=ortho.3 band=3
+# import of all channels:
+r.external /home/user/data/maps/059100.tif out=ortho
g.region rast=ortho.3 -p
d.rgb r=ortho.1 g=ortho.2 b=ortho.3
r.composite r=ortho.1 g=ortho.2 b=ortho.3 output=ortho.rgb
Modified: grass/branches/develbranch_6/raster/r.external/main.c
--- grass/branches/develbranch_6/raster/r.external/main.c 2010-02-13 09:35:30 UTC (rev 40967)
+++ grass/branches/develbranch_6/raster/r.external/main.c 2010-02-13 09:36:21 UTC (rev 40968)
@@ -498,7 +498,7 @@
struct Option *input, *source, *output, *band, *title;
} parm;
struct Flag *flag_o, *flag_f, *flag_e, *flag_r;
- int band;
+ int min_band, max_band, band;
struct band_info info;
G_gisinit(argv[0]);
@@ -527,8 +527,7 @@
parm.band->key = "band";
parm.band->type = TYPE_INTEGER;
parm.band->required = NO;
- parm.band->description = _("Band to select");
- parm.band->answer = "1";
+ parm.band->description = _("Band to select (default: all)");
parm.title = G_define_option();
parm.title->key = "title";
@@ -577,11 +576,6 @@
else
title = NULL;
- if (parm.band->answer)
- band = atoi(parm.band->answer);
- else
- band = 1;
if (!input && !source)
G_fatal_error(_("Name for input source not specified"));
@@ -610,19 +604,43 @@
check_projection(&cellhd, hDS, flag_o->answer);
+ if (G_set_window(&cellhd) < 0)
+ G_fatal_error(_("Unable to set window"));
+ if (parm.band->answer)
+ min_band = max_band = atoi(parm.band->answer);
+ else
+ min_band = 1, max_band = GDALGetRasterCount(hDS);
G_verbose_message(_("Proceeding with import..."));
- G_message("Importing band %d of %d...", band, GDALGetRasterCount( hDS ));
- hBand = GDALGetRasterBand(hDS, band);
- if (!hBand)
- G_fatal_error(_("Selected band (%d) does not exist"), band);
+ for (band = min_band; band <= max_band; band++) {
+ char *output2, *title2 = NULL;
- if (G_set_window(&cellhd) < 0)
- G_fatal_error(_("Unable to set window"));
+ G_message("Importing band %d of %d...", band, GDALGetRasterCount( hDS ));
- query_band(hBand, output, flag_r->answer, &cellhd, &info);
- create_map(input, band, output, &cellhd, &info, title);
+ hBand = GDALGetRasterBand(hDS, band);
+ if (!hBand)
+ G_fatal_error(_("Selected band (%d) does not exist"), band);
+ if (max_band > min_band) {
+ G_asprintf(&output2, "%s.%d", output, band);
+ if (title)
+ G_asprintf(&title2, "%s (band %d)", title, band);
+ else {
+ output2 = G_store(output);
+ if (title)
+ title2 = G_store(title);
+ query_band(hBand, output2, flag_r->answer, &cellhd, &info);
+ create_map(input, band, output2, &cellhd, &info, title);
+ G_free(output2);
+ G_free(title2);
if (flag_e->answer)
update_default_window(&cellhd);
