[GRASS-SVN] r40975 - grass-addons/raster/r.out.gmt2
svn_grass at osgeo.org
Sat Feb 13 05:23:12 EST 2010
Author: hamish
Date: 2010-02-13 05:23:12 -0500 (Sat, 13 Feb 2010)
New Revision: 40975
grass-addons/raster/r.out.gmt2/r.out.gmt2
merge fixes from r.out.gmt1
Modified: grass-addons/raster/r.out.gmt2/r.out.gmt2
--- grass-addons/raster/r.out.gmt2/r.out.gmt2 2010-02-13 10:18:27 UTC (rev 40974)
+++ grass-addons/raster/r.out.gmt2/r.out.gmt2 2010-02-13 10:23:12 UTC (rev 40975)
@@ -36,6 +36,7 @@
#%module
#% description: Exports a GRASS raster map into a GMT grd file and color table.
+#% keywords: raster, export, GMT
#%end
#%option
#% key: input
@@ -114,7 +115,7 @@
input_map="$map_name"
if [ -z "$GIS_OPT_OUTPUT" ]; then
- output_base="$GIS_OPT_INPUT"
+ output_base=`echo "$GIS_OPT_INPUT" | cut -f1 -d'@'`
else
output_base="$GIS_OPT_OUTPUT"
fi
@@ -148,7 +149,7 @@
cleanup()
if [ "$map_type" = "DCELL" ]; then
- g.remove tmp_gmt_$$ > /dev/null
+ g.remove tmp_gmt_$$ --quiet
fi
@@ -164,9 +165,9 @@
DCELL)
map_tag="=1"
echo "WARNING: Converting from double precision to floating point map" 1>&2
- r.mapcalc "tmp_gmt_$$=float($map_name)"
+ r.mapcalc "tmp_gmt_$$ = float($map_name)"
r.colors map="tmp_gmt_$$" raster="$map_name"
- map_name=tmp_gmt_$$
+ map_name="tmp_gmt_$$"
esac
