[GRASS-SVN] r40979 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Feb 13 09:26:16 EST 2010
Author: martinl
Date: 2010-02-13 09:26:15 -0500 (Sat, 13 Feb 2010)
New Revision: 40979
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
wxGUI/location wizard: fix proj parsing
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-02-13 12:53:57 UTC (rev 40978)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-02-13 14:26:15 UTC (rev 40979)
@@ -1539,35 +1539,39 @@
def OnPageChanging(self, event):
if event.GetDirection() and not self.customstring:
event.Veto()
- else:
- # check for datum tranforms
+ elif not event.GetDirection() and not self.customstring:
+ return
+ else: # check for datum tranforms
ret, out, err = gcmd.RunCommand('g.proj',
- read = True, getErrorMsg = True,
- proj4 = self.customstring,
- datumtrans = '-1')
+ read = True, getErrorMsg = True,
+ proj4 = self.customstring,
+ datumtrans = '-1')
if ret != 0:
- wx.MessageBox(err, 'g.proj error: check PROJ4 parameter string')
+ wx.MessageBox(parent = self,
+ message = err,
+ caption = _("Error"),
+ style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
event.Veto()
return
- if out != '':
+ if out:
dtrans = ''
# open a dialog to select datum transform number
dlg = SelectTransformDialog(self.parent.parent, transforms=out)
if dlg.ShowModal() == wx.ID_OK:
dtrans = dlg.GetTransform()
- if dtrans == '':
+ if len(dtrans) == 0:
dlg.Destroy()
event.Veto()
- return 'Datum transform is required.'
+ return _('Datum transform is required.')
else:
dlg.Destroy()
event.Veto()
self.parent.datumtrans = dtrans
self.GetNext().SetPrev(self)
def GetProjstring(self, event):
