[GRASS-SVN] r40982 - in grass-addons/ossim_grass: r.planet v.planet
svn_grass at osgeo.org
Sat Feb 13 18:39:00 EST 2010
Author: epifanio
Date: 2010-02-13 18:38:58 -0500 (Sat, 13 Feb 2010)
New Revision: 40982
grass-addons/ossim_grass/r.planet/r.planet.py
grass-addons/ossim_grass/v.planet/v.planet.py
adjusted output directory three
Modified: grass-addons/ossim_grass/r.planet/r.planet.py
--- grass-addons/ossim_grass/r.planet/r.planet.py 2010-02-13 16:38:40 UTC (rev 40981)
+++ grass-addons/ossim_grass/r.planet/r.planet.py 2010-02-13 23:38:58 UTC (rev 40982)
@@ -103,14 +103,17 @@
try :
rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'cellhd')
mapfile = os.path.join(rasterpath, mappa[0])
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt/raster/')
+ #print vrtdir
except :
rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'cellhd')
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt/raster/')
+ #print vrtdir
d = os.path.dirname(vrtdir)
if not os.path.exists(d):
os.makedirs(d)
+ #os.makedirs(d)
vrtfilename = mappa[0] + '.vrt'
output = os.path.join(vrtdir, vrtfilename)
if not os.path.exists(output):
@@ -142,8 +145,8 @@
if orthoigen :
if tile != '':
path = os.path.dirname(output)
- elevdir = os.path.join(path,'elevation',mappa[0])
- if not os.path.exists(d):
+ elevdir = os.path.join(path,'elevation',mappa[0]+'/')
+ if not os.path.exists(elevdir):
os.makedirs(elevdir)
elev = mappa[0]+'.tiff'
exportiff(output,elev)
@@ -164,6 +167,7 @@
ossimdata.connect((host, int(dport)))
ossimdata.send(ossim_data_xml)
ossimdata.close()
def zoomto(lon,lat,distance,host,pport):
ossim_zoom_xml = '<Set target=":navigator" vref="wgs84"><Camera><longitude>%s</longitude><latitude>%s</latitude><altitude>%s</altitude><heading>0</heading><pitch>0</pitch><roll>0</roll><altitudeMode>absolute</altitudeMode><range>%s</range></Camera></Set>' % (lon, lat, distance, distance)
Modified: grass-addons/ossim_grass/v.planet/v.planet.py
--- grass-addons/ossim_grass/v.planet/v.planet.py 2010-02-13 16:38:40 UTC (rev 40981)
+++ grass-addons/ossim_grass/v.planet/v.planet.py 2010-02-13 23:38:58 UTC (rev 40982)
@@ -131,11 +131,11 @@
try :
vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vector' , mappa[0] )
mapfile = os.path.join(vectorpath, 'head')
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt', 'vector')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt', 'vector/')
except :
vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], mappa[0] )
mapfile = os.path.join(vectorpath, 'head' )
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt', 'vector')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt', 'vector/')
os.makedirs(d)
