[GRASS-SVN] r40990 - grass/trunk/general/g.transform
Sun Feb 14 02:05:41 EST 2010
Author: hamish
Date: 2010-02-14 02:05:40 -0500 (Sun, 14 Feb 2010)
New Revision: 40990
   grass/trunk/general/g.transform/g.transform.html
   grass/trunk/general/g.transform/main.c
add new options to dump coeffs and transform arbitrary points, both fwd and reverse (trac #929; merge from devbr6)
Modified: grass/trunk/general/g.transform/g.transform.html
--- grass/trunk/general/g.transform/g.transform.html	2010-02-14 07:01:54 UTC (rev 40989)
+++ grass/trunk/general/g.transform/g.transform.html	2010-02-14 07:05:40 UTC (rev 40990)
@@ -3,13 +3,65 @@
 <EM>g.transform</EM> is an utility to compute transformation
 based upon GCPs and output error measurements.
+<H2>NOTES</H2>
+For coordnaites given with the <b>coords</b> file option or fed from
+<tt>stdin</tt>, the input format is "x y" with one coordinate pair per
+line.
+<p>
+The transformations are:
+<p>
+order=1:
+<div class="code"><pre>
+    e = [E0 E1][1].[1]
+        [E2  0][e] [n]
+    n = [N0 N1][1].[1]
+        [N2  0][e] [n]
+</pre></div>
+order=2:
+    e = [E0 E1 E3][1 ] [1 ]
+        [E2 E4  0][e ].[n ]
+        [E5  0  0][e&sup2;] [n&sup2;]
+    n = [N0 N1 N3][1 ] [1 ]
+        [N2 N4  0][e ].[n ]
+        [N5  0  0][e&sup2;] [n&sup2;]
+</pre></div>
+order=3:
+    e = [E0 E1 E3 E6][1 ] [1 ]
+        [E2 E4 E7  0][e ].[n ]
+        [E5 E8  0  0][e&sup2;] [n&sup2;]
+        [E9  0  0  0][e&sup3;] [n&sup3;]
+    n = [N0 N1 N3 N6][1 ] [1 ]
+        [N2 N4 N7  0][e ].[n ]
+        [N5 N8  0  0][e&sup2;] [n&sup2;]
+        [N9  0  0  0][e&sup3;] [n&sup3;]
+</pre></div>
+["." = dot-product, (AE).N = N'EA.]
+<p>
+In other words, order=1 and order=2 are equivalent to order=3 with
+the higher coefficients equal to zero.
 <H2>SEE ALSO</H2>
 <EM><A HREF="i.rectify.html">i.rectify</A></EM>
 <H2>AUTHORS</H2>
 Brian J. Buckley<br>
-Glynn Clements
+Glynn Clements<br>
+Hamish Bowman
-<p><i>Last changed: $Date$</i></p>
+<p>
+<i>Last changed: $Date$</i></p>
Modified: grass/trunk/general/g.transform/main.c
--- grass/trunk/general/g.transform/main.c	2010-02-14 07:01:54 UTC (rev 40989)
+++ grass/trunk/general/g.transform/main.c	2010-02-14 07:05:40 UTC (rev 40990)
@@ -2,11 +2,12 @@
  * MODULE:       g.transform
- * AUTHOR(S):    Brian J. Buckley<br>
+ * AUTHOR(S):    Brian J. Buckley
  *               Glynn Clements
+ *               Hamish Bowman
  * PURPOSE:      Utility to compute transformation based upon GCPs and
  *               output error measurements
- * COPYRIGHT:    (C) 2006-2008 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2006-2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -44,12 +45,16 @@
 static char *name;
 static int order;
 static int summary;
+static int forward;
 static char **columns;
 static int need_fwd;
 static int need_rev;
 static int need_fd;
 static int need_rd;
+static char *coord_file;
+static double E12[10], N12[10], E21[10], N21[10];
 static struct Control_Points points;
 static int equation_stat;
@@ -83,7 +88,6 @@
 static void compute_transformation(void)
     static const int order_pnts[3] = { 3, 6, 10 };
-    double E12[10], N12[10], E21[10], N21[10];
     int n, i;
     equation_stat =
@@ -94,7 +98,7 @@
 		      order_pnts[order - 1]);
     if (equation_stat <= 0)
-	return;
+	G_fatal_error(_("Error conducting transform (%d)"), equation_stat);
     count = 0;
@@ -134,7 +138,7 @@
 		update_stats(&rev, n, rx, ry, rd, rd2);
-	if (!columns)
+	if (!columns[0])
 	    continue;
 	for (i = 0;; i++) {
@@ -236,10 +240,74 @@
+static void dump_cooefs(void)
+    int i;
+    static const int order_pnts[3] = { 3, 6, 10 };
+    for (i = 0; i < order_pnts[order - 1]; i++)
+    	fprintf(stdout, "E%d=%.15g\n", i, forward ? E12[i] : E21[i]);
+    	fprintf(stdout, "N%d=%.15g\n", i, forward ? N12[i] : N21[i]);
+static void xform_value(double east, double north)
+    double xe, xn;
+    if(forward)
+	CRS_georef(east, north, &xe, &xn, E12, N12, order);
+    else
+	CRS_georef(east, north, &xe, &xn, E21, N21, order);
+    fprintf(stdout, "%.15g %.15g\n", xe, xn);
+static void do_pt_xforms(void)
+    double easting, northing;
+    int ret;
+    FILE *fp;
+    if (strcmp(coord_file, "-") == 0)
+    	fp = stdin;
+    else {
+    	fp = fopen(coord_file, "r");
+    	if (!fp)
+    	    G_fatal_error(_("Unable to open file <%s>"), coord_file);
+    for (;;) {
+    	char buf[64];
+    	if (!G_getl2(buf, sizeof(buf), fp))
+    	    break;
+    	if ((buf[0] == '#') || (buf[0] == '\0'))
+    	    continue;
+    	/* ? sscanf(buf, "%s %s", &east_str, &north_str)
+    	    ? G_scan_easting(,,-1)
+    	    ? G_scan_northing(,,-1) */
+    	/* ? muliple delims with sscanf(buf, "%[ ,|\t]", &dummy) ? */
+    	ret = sscanf(buf, "%lf %lf", &easting, &northing);
+    	if (ret != 2)
+    	    G_fatal_error(_("Invalid coordinates: [%s]"), buf);
+    	xform_value(easting, northing);
+    if (fp != stdin)
+    	fclose(fp);
 int main(int argc, char **argv)
-    struct Option *grp, *val, *fmt;
-    struct Flag *sum;
+    struct Option *grp, *val, *fmt, *xfm_pts;
+    struct Flag *sum, *rev_flag, *dump_flag;
     struct GModule *module;
     G_gisinit(argv[0]);
@@ -283,13 +351,32 @@
     sum->key = 's';
     sum->description = _("Display summary information");
+    xfm_pts = G_define_standard_option(G_OPT_F_INPUT);
+    xfm_pts->key = "coords";
+    xfm_pts->required = NO;
+    xfm_pts->label =
+	_("File containing coordinates to transform (\"-\" to read from stdin)");
+    xfm_pts->description = _("Local x,y coordinates to target east,north");
+    rev_flag = G_define_flag();
+    rev_flag->key = 'r';
+    rev_flag->label = _("Reverse transform of coords file or coeff. dump");
+    rev_flag->description = _("Target east,north coordinates to local x,y");
+    dump_flag = G_define_flag();
+    dump_flag->key = 'x';
+    dump_flag->description = _("Display transform matrix coefficients");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     name = grp->answer;
     order = atoi(val->answer);
     summary = !!sum->answer;
     columns = fmt->answers;
+    forward = !rev_flag->answer;
+    coord_file = xfm_pts->answer;
     I_get_control_points(name, &points);
@@ -301,5 +388,11 @@
     analyze();
+    if(dump_flag->answer)
+	dump_cooefs();
+    if(coord_file)
+	do_pt_xforms();
     return 0;
