[GRASS-SVN] r40997 - grass/trunk/vector/lidar/v.surf.bspline
Sun Feb 14 10:01:56 EST 2010
Author: neteler
Date: 2010-02-14 10:01:56 -0500 (Sun, 14 Feb 2010)
New Revision: 40997
   grass/trunk/vector/lidar/v.surf.bspline/main.c
   grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html
parm name more reasonable (standardization)
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c	2010-02-14 13:19:14 UTC (rev 40996)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c	2010-02-14 15:01:56 UTC (rev 40997)
@@ -131,7 +131,7 @@
     passoN_opt->guisection = _("Settings");
     type_opt = G_define_option();
-    type_opt->key = "type";
+    type_opt->key = "method";
     type_opt->type = TYPE_STRING;
     type_opt->required = NO;
     type_opt->description = _("Spline interpolation algorithm");
Modified: grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html
--- grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html	2010-02-14 13:19:14 UTC (rev 40996)
+++ grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html	2010-02-14 15:01:56 UTC (rev 40997)
@@ -91,7 +91,7 @@
 <h4>Basic interpolation</h4>
 <div class="code"><pre>
-v.surf.bspline input=point_vector output=interpolate_surface type=bicubic
+v.surf.bspline input=point_vector output=interpolate_surface method=bicubic
 </pre></div>
 A bicubic spline interpolation will be done and a vector points map with estimated
