[GRASS-SVN] r41008 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Mon Feb 15 01:22:52 EST 2010
Author: cmbarton
Date: 2010-02-15 01:22:52 -0500 (Mon, 15 Feb 2010)
New Revision: 41008
grass/branches/develbranch_6/lib/python/core.py
Added command_info method. Returns as dictionary all information output from <command> help. Backported from trunk r41007.
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2010-02-15 06:13:13 UTC (rev 41007)
+++ grass/branches/develbranch_6/lib/python/core.py 2010-02-15 06:22:52 UTC (rev 41008)
@@ -20,6 +20,7 @@
@author Glynn Clements
@author Martin Landa <landa.martin gmail.com>
+ at author Michael Barton <michael.barton at asu.edu>
import os
@@ -705,3 +706,64 @@
@return float value
return sum(float(x) / 60 ** n for (n, x) in enumerate(s.split(':')))
+def command_info(cmd):
+ """!Returns 'help' information for any command as dictionary with entries
+ for description, keywords, usage, flags, and parameters"""
+ cmdinfo = {}
+ s = start_command(cmd, 'help', stdout = subprocess.PIPE, stderr = subprocess.PIPE)
+ out, err = s.communicate()
+ # Parameters
+ first, params = err.split('Parameters:')
+ paramlines = params.splitlines()
+ dict = {}
+ for line in paramlines:
+ line = line.strip()
+ if line == '': continue
+ param = line.split(' ',1)[0].strip()
+ pval = line.split(' ',1)[1].strip()
+ dict[param] = pval
+ cmdinfo['parameters'] = dict
+ # Flags
+ first, flags = first.split('Flags:')
+ flaglines = flags.splitlines()
+ dict = {}
+ for line in flaglines:
+ flag = line.split(' ',1)[0].strip()
+ fval = line.split(' ',1)[1].strip()
+ dict[flag] = fval
+ cmdinfo['flags'] = dict
+ # Usage
+ first, usage = first.split('Usage:')
+ usagelines = usage.splitlines()
+ list = []
+ for line in usagelines:
+ line = line.strip()+' '
+ list.append(line)
+ cmdinfo['usage'] = ''.join(list).strip()
+ # Keywords
+ first, keywords = first.split('Keywords:')
+ list = []
+ list = keywords.strip().split(',')
+ cmdinfo['keywords'] = list
+ #Description
+ first, desc = first.split('Description:')
+ desclines = desc.splitlines()
+ for line in desclines:
+ cmdinfo['description'] = ''.join(desclines).strip()
+ return cmdinfo
