[GRASS-SVN] r41029 - in grass/trunk: lib/cairodriver lib/pngdriver scripts/wxpyimgview visualization/wximgview visualization/ximgview
Mon Feb 15 07:20:56 EST 2010
Author: glynn
Date: 2010-02-15 07:20:55 -0500 (Mon, 15 Feb 2010)
New Revision: 41029
   grass/trunk/lib/cairodriver/cairodriver.h
   grass/trunk/lib/cairodriver/write_bmp.c
   grass/trunk/lib/pngdriver/pngdriver.h
   grass/trunk/lib/pngdriver/write_bmp.c
   grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py
   grass/trunk/visualization/wximgview/main.cc
   grass/trunk/visualization/ximgview/main.c
Use 64-byte header to ensure frame buffer alignment
Modified: grass/trunk/lib/cairodriver/cairodriver.h
--- grass/trunk/lib/cairodriver/cairodriver.h	2010-02-15 11:58:59 UTC (rev 41028)
+++ grass/trunk/lib/cairodriver/cairodriver.h	2010-02-15 12:20:55 UTC (rev 41029)
@@ -42,7 +42,7 @@
 #define DEFAULT_FILE_NAME "map.png"
-#define HEADER_SIZE 54
+#define HEADER_SIZE 64
 /* Scale for converting colors from [0..255] to cairo's [0.0..1.0] */
 #define COLORSCALE (1.0/255.0)
Modified: grass/trunk/lib/cairodriver/write_bmp.c
--- grass/trunk/lib/cairodriver/write_bmp.c	2010-02-15 11:58:59 UTC (rev 41028)
+++ grass/trunk/lib/cairodriver/write_bmp.c	2010-02-15 12:20:55 UTC (rev 41029)
@@ -72,6 +72,7 @@
 	G_fatal_error(_("Cairo: unable to open output file <%s>"),
 		      ca.file_name);
+    memset(header, 0, sizeof(header));
     make_bmp_header(header);
     fwrite(header, sizeof(header), 1, output);
Modified: grass/trunk/lib/pngdriver/pngdriver.h
--- grass/trunk/lib/pngdriver/pngdriver.h	2010-02-15 11:58:59 UTC (rev 41028)
+++ grass/trunk/lib/pngdriver/pngdriver.h	2010-02-15 12:20:55 UTC (rev 41029)
@@ -9,7 +9,7 @@
 #define FILE_NAME  "map.png"
 struct png_state
Modified: grass/trunk/lib/pngdriver/write_bmp.c
--- grass/trunk/lib/pngdriver/write_bmp.c	2010-02-15 11:58:59 UTC (rev 41028)
+++ grass/trunk/lib/pngdriver/write_bmp.c	2010-02-15 12:20:55 UTC (rev 41029)
@@ -59,6 +59,7 @@
     if (!output)
 	G_fatal_error("PNG: couldn't open output file %s", png.file_name);
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py
--- grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py	2010-02-15 11:58:59 UTC (rev 41028)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py	2010-02-15 12:20:55 UTC (rev 41029)
@@ -107,11 +107,11 @@
     def __init__(self):
 	self.image = sys.argv[1]
 	self.fraction = int(sys.argv[2]) / 100.0
-	self.HEADER_SIZE = 54
+	self.HEADER_SIZE = 64
 	wx.App.__init__(self)
     def read_bmp_header(self, header):
-	magic, bmfh, bmih = struct.unpack("2s12s40s", header)
+	magic, bmfh, bmih = struct.unpack("2s12s40s10x", header)
 	if magic != 'BM':
 	    raise SyntaxError("Invalid magic number")
Modified: grass/trunk/visualization/wximgview/main.cc
--- grass/trunk/visualization/wximgview/main.cc	2010-02-15 11:58:59 UTC (rev 41028)
+++ grass/trunk/visualization/wximgview/main.cc	2010-02-15 12:20:55 UTC (rev 41029)
@@ -40,7 +40,7 @@
 #include "wximgview.h"
 IMPLEMENT_APP_NO_MAIN(MyApp)
Modified: grass/trunk/visualization/ximgview/main.c
--- grass/trunk/visualization/ximgview/main.c	2010-02-15 11:58:59 UTC (rev 41028)
+++ grass/trunk/visualization/ximgview/main.c	2010-02-15 12:20:55 UTC (rev 41029)
@@ -32,7 +32,7 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
 Display *dpy;
 int scrn;
