[GRASS-SVN] r41046 - grass/branches/releasebranch_6_4/lib/init
svn_grass at osgeo.org
Tue Feb 16 11:40:45 EST 2010
Author: neteler
Date: 2010-02-16 11:40:43 -0500 (Tue, 16 Feb 2010)
New Revision: 41046
Added:
grass/branches/releasebranch_6_4/lib/init/circle_1.png
grass/branches/releasebranch_6_4/lib/init/circle_2.png
grass/branches/releasebranch_6_4/lib/init/circle_3.png
grass/branches/releasebranch_6_4/lib/init/circle_4.png
grass/branches/releasebranch_6_4/lib/init/circle_5.png
grass/branches/releasebranch_6_4/lib/init/grass64_start.png
grass/branches/releasebranch_6_4/lib/init/grass64_start_small.jpg
grass/branches/releasebranch_6_4/lib/init/Makefile
grass/branches/releasebranch_6_4/lib/init/helptext.html
GRASS startup explained
Modified: grass/branches/releasebranch_6_4/lib/init/Makefile
--- grass/branches/releasebranch_6_4/lib/init/Makefile 2010-02-16 15:52:34 UTC (rev 41045)
+++ grass/branches/releasebranch_6_4/lib/init/Makefile 2010-02-16 16:40:43 UTC (rev 41046)
@@ -71,6 +71,8 @@
$(INSTALL_DATA) grass6.html $(GISBASE)/docs/html/grass6.html
$(INSTALL_DATA) helptext.html $(GISBASE)/docs/html/helptext.html
$(INSTALL_DATA) help_loc_struct.png $(GISBASE)/docs/html/help_loc_struct.png
+ $(INSTALL_DATA) circle_*.png $(GISBASE)/docs/html/
+ $(INSTALL_DATA) grass64_start.png grass64_start_small.jpg $(GISBASE)/docs/html/
$(ARCH_BINDIR)/$(START_UP): init.sh grass.src
@test -d $(ARCH_BINDIR) || (echo 'ARCH_DISTDIR($(ARCH_BINDIR))' not found; exit 1)
Added: grass/branches/releasebranch_6_4/lib/init/circle_1.png
(Binary files differ)
Property changes on: grass/branches/releasebranch_6_4/lib/init/circle_1.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Added: grass/branches/releasebranch_6_4/lib/init/circle_2.png
Property changes on: grass/branches/releasebranch_6_4/lib/init/circle_2.png
+ image/png
Added: grass/branches/releasebranch_6_4/lib/init/circle_3.png
Property changes on: grass/branches/releasebranch_6_4/lib/init/circle_3.png
+ image/png
Added: grass/branches/releasebranch_6_4/lib/init/circle_4.png
Property changes on: grass/branches/releasebranch_6_4/lib/init/circle_4.png
+ image/png
Added: grass/branches/releasebranch_6_4/lib/init/circle_5.png
Property changes on: grass/branches/releasebranch_6_4/lib/init/circle_5.png
+ image/png
Added: grass/branches/releasebranch_6_4/lib/init/grass64_start.png
Property changes on: grass/branches/releasebranch_6_4/lib/init/grass64_start.png
+ image/png
Added: grass/branches/releasebranch_6_4/lib/init/grass64_start_small.jpg
Property changes on: grass/branches/releasebranch_6_4/lib/init/grass64_start_small.jpg
+ image/jpeg
Modified: grass/branches/releasebranch_6_4/lib/init/helptext.html
--- grass/branches/releasebranch_6_4/lib/init/helptext.html 2010-02-16 15:52:34 UTC (rev 41045)
+++ grass/branches/releasebranch_6_4/lib/init/helptext.html 2010-02-16 16:40:43 UTC (rev 41046)
@@ -23,32 +23,69 @@
settings around the world, as well as by many governmental agencies
and environmental consulting companies.
-<h2>Introduction</h2>
+<h2>1. Startup of GRASS GIS</h2>
+<p>
+ <IMG SRC="grass64_start_small.jpg" ALT="[GRASS start screen]">
+<h3><IMG SRC="circle_1.png" ALT="[(1)]"> Selecting the GIS Database directory</h3>
GRASS data are stored in a directory referred to as DATABASE
(also called "GISDBASE"). This directory has to be created
-with <tt>mkdir</tt> or a file manager, before starting to work
+with a file manager or the <tt>mkdir</tt> command, before starting to work
with GRASS. Within this DATABASE, the projects are organized
by project areas stored in subdirectories called LOCATIONs.
-<p>
+<h3><IMG SRC="circle_2.png" ALT="[(2)]"> Selecting the LOCATION (a project)</h3>
A LOCATION is defined by its coordinate system, map projection and
geographical boundaries. The subdirectories and files defining a
LOCATION are created automatically when GRASS is started the first
-time with a new LOCATION.
+time with a new LOCATION. It is important to understand that each
+projection stays in its own LOCATION.
<p>
+See <IMG SRC="circle_4.png" ALT="[(4)]"> the "Location Wizard" to
+easily create a new LOCATION from scratch from a geocoded file, by
+defining the parameters or by selecting the corresponding EPSG projection
+code.
+<h3><IMG SRC="circle_3.png" ALT="[(3)]"> Selecting the MAPSET (a subproject)</h3>
Each LOCATION can have many MAPSETs. Each MAPSET is a LOCATION's
-subdirectory. New MAPSET can be added at GRASS startup. To remove a
-MAPSET, remove it's directory using your file manager or by <br>
-<tt>rm -rf
-/path/to/the/mapset_to_delete</tt>. The <a href="wxGUI.html">wxGUI</a>
-graphical user interface provides options to rename/remove LOCATIONs
-and MAPSETs.
+subdirectory. New MAPSET can be added at GRASS startup (see related
+button).
+<h3><IMG SRC="circle_4.png" ALT="[(4)]"> Location Wizard</h3>
+The "Location Wizard" let's you easily create a new LOCATION. You
+will be guided through a series of dialogues to browse and select
+predefined projections (also via EPSG code) or to define individual
+projections. Find below some rules to define the default raster
+resolution for a new LOCATION.
+<h3><IMG SRC="circle_5.png" ALT="[(5)]"> Start GRASS</h3>
+Once you have selected an existing LOCATION/MAPSET or defined a new
+one, you can enter GRASS. The graphical user interface
+<a href="wxGUI.html">wxGUI</a> will open and provide you with a
+menu system, map visualization tool, digitizer, and more.
+<h2>2. Background GRASS Location structure</h2>
<p>
-<IMG SRC="help_loc_struct.png" ALT="[GRASS Location structure]">
+ <IMG SRC="help_loc_struct.png" ALT="[GRASS Location structure]">
<BR>
<i>Fig. 1: GRASS Location structure</i>
+<p>
-<p>
+A LOCATION is simply a set of directories which contains the GRASS
+data of a project. Within each LOCATION, a mandatory "PERMANENT"
+MAPSET exists which contains projection information and some
+more definitions. It can be used to store the base cartography
+in it as "PERMANENT" is visible to all users accessing a LOCATION.
+<h3>Creating and maintaining MAPSETs</h3>
One motivation to maintain different MAPSETs is to store maps
related to project issues or subregions. Another motivation is to
support simultaneous access of several users to the map layers
@@ -62,7 +99,8 @@
You can learn more about mapsets and how to seamlessly access maps
found in another MAPSET of the same LOCATION in the
<a href="g.mapsets.html">g.mapsets</a> documentation.
-<p>
+<h3>The role of the "PERMANENT" LOCATION</h3>
When creating a new LOCATION, GRASS automatically creates a special
MAPSET called PERMANENT where the core data for the project can be
stored. Data in the PERMANENT MAPSET can only be added, modified or
@@ -80,26 +118,36 @@
coordinate values and the currently selected raster resolution. Users
have the option of switching back to the default region at any time.
-<h2>Creating a GRASS database</h2>
+<h2>3. Creating a GRASS database with sample data</h2>
To create the GRASS database:
<OL>
<LI> Find a place on your disk where you have write access and that
- has enough diskspace to hold your decompressed data.</LI>
+ has enough diskspace to hold your spatial data.</LI>
<LI> Create a subdirectory that will hold the general GRASS database
- (e.g. <tt>mkdir /data/grassdata</tt> or
+ (e.g. using a file manager or with <tt>mkdir /data/grassdata</tt> or
<tt>mkdir /home/yourlogin/grassdata</tt>).</LI>
</OL>
<P>
-Sample data such as the Spearfish or the North Carolina sample datasets
+Sample data such as the "Spearfish" or the "North Carolina" sample datasets
may be downloaded from
<A HREF="http://grass.osgeo.org/download/data.php">http://grass.osgeo.org/download/data.php</A>
and placed in this new database directory.
<P>
-<h3>A) Create New Location with text screen</h3>
+<h3>A) Create New Location with wxGUI</h3>
+The <a href="wxGUI.html">wxGUI</a> graphical user interface provides a
+graphical "Location Wizard" instead which let's you easily create a
+new LOCATION. You will be guided through a series of dialogues to
+browse and select predefined projections (also via EPSG code) or to
+define individual projections. The rules to define the resolution as
+described above also apply here.
+<h3>B) Create New Location with text screen</h3>
Click on the "Create New Location" button, which will take you to a
text screen on which you can enter a new location name, and then
continue by pressing "ESC"-"RETURN" - i.e. press (NOT hold) the ESC key,
@@ -160,29 +208,20 @@
created. You have "arrived" in the GRASS system and can start working
within this new location.
-<h3>B) Create New Location with wxGUI</h3>
-The <a href="wxGUI.html">wxGUI</a> graphical user interface provides a
-graphical "Location Wizard" instead which let's you easily create a
-new LOCATION. You will be guided through a series of dialogues to
-browse and select predefined projections (also via EPSG code) or to
-define individual projections. The rules to define the resolution as
-described above also apply here.
<H2>Further Reading</H2>
Please have a look at the GRASS web site for tutorials and books:
<A HREF="http://grass.osgeo.org/gdp/index.php">http://grass.osgeo.org/gdp/index.php</A>.
<H2>See also</H2>
-<a href="grass6.html">GRASS 6 launch manual page</a>
+<a href="index.html">GRASS 6 Reference Manual</a>
<br>
-<a href="index.html">GRASS 6 Reference Manual</a>
+<a href="grass6.html">Manual page of GRASS 6 launch program</a>
<p><i>Last changed: $Date$</i>
<HR>
<P><a href=index.html>Help Index</a>
-<P>© 2005-2009 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
+<P>© 2005-2010 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
</BODY>
</HTML>
