[GRASS-SVN] r41057 -
grass/branches/releasebranch_6_4/vector/v.out.ascii
svn_grass at osgeo.org
Wed Feb 17 02:56:18 EST 2010
Author: neteler
Date: 2010-02-17 02:56:18 -0500 (Wed, 17 Feb 2010)
New Revision: 41057
grass/branches/releasebranch_6_4/vector/v.out.ascii/description.html
info transfer from v.in.ascii; link to SQL docs
Modified: grass/branches/releasebranch_6_4/vector/v.out.ascii/description.html
--- grass/branches/releasebranch_6_4/vector/v.out.ascii/description.html 2010-02-17 07:55:21 UTC (rev 41056)
+++ grass/branches/releasebranch_6_4/vector/v.out.ascii/description.html 2010-02-17 07:56:18 UTC (rev 41057)
@@ -27,6 +27,45 @@
such metadata exists. An example of the <b>standard</b> format is
given below.
+<p>The header is similar as the head file of vector binary format but
+contains bounding box also. Key words are:
+<pre>
+ORGANIZATION
+DIGIT DATE
+DIGIT NAME
+MAP NAME
+MAP DATE
+MAP SCALE
+OTHER INFO
+ZONE
+WEST EDGE
+EAST EDGE
+SOUTH EDGE
+NORTH EDGE
+MAP THRESH
+</pre>
+<p>The body begins with the row:
+<pre>
+VERTI:
+</pre>
+followed by records of primitives:
+<pre>
+TYPE NUMBER_OF_COORDINATES [NUMBER_OF_CATEGORIES]
+ X Y [Z]
+ X Y [Z]
+[ LAYER CATEGORY]
+[ LAYER CATEGORY]
+</pre>
+Everything above in <tt>[ ]</tt> is optional.
<p>
The primitive codes are as follows:
<ul>
@@ -40,22 +79,22 @@
</ul>
The coordinates are listed following the initial line containing the
-primitive code, the total number of vectors in the series, and the
-number of categories (1 for a single layer, higher for multiple
-layers). Below that 1 or several lines follow to indicate the layer
-number and the category number.
-<p>
-The order of coordinates for new (standard) version of ASCII file is
+primitive code, the total number of vectors in the series, and (optionally)
+the number of categories (1 for a single layer, higher for multiple layers).
+Below that 1 or several lines follow to indicate the layer number and
+the category number (ID).
+<br>
+The order of coordinates is
<div class="code"><pre>
-X Y [Z]
+ X Y [Z]
</pre></div>
-the order of coordinates for old version of ASCII file is
+In pre-GRASS 6 versions of the ASCII file, the order of coordinates is:
Y X
</pre></div>
-If old version is requested, the <b>output</b> files from <em>v.out.ascii</em> will be placed
+If old version is requested, the <b>output</b> files from <em>v.out.ascii</em> is placed
in the <tt>$LOCATION/$MAPSET/dig_ascii/</tt> and <tt>$LOCATION/$MAPSET/dig_att</tt> directory.
<p>
@@ -136,12 +175,10 @@
<em>
<a href="v.category.html">v.category</a>,
<a href="v.in.ascii.html">v.in.ascii</a>,
-<a href="v.to.points.html">v.to.points</a></em>
+<a href="v.to.points.html">v.to.points</a><br>
+<a HREF="sql.html">GRASS SQL interface</a>
+</em>
-<br><br>
-<a HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass6/doc/vector/vector.html#ascii">Vector
-ASCII Format Specification</a>
<h2>AUTHORS</h2>
Michael Higgins,
