[GRASS-SVN] r41079 - grass/trunk/lib/gis
svn_grass at osgeo.org
Thu Feb 18 07:38:58 EST 2010
Author: glynn
Date: 2010-02-18 07:38:56 -0500 (Thu, 18 Feb 2010)
New Revision: 41079
grass/trunk/lib/gis/parser.c
grass/trunk/lib/gis/parser_help.c
grass/trunk/lib/gis/parser_local_proto.h
Add --help-text option
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2010-02-18 10:43:52 UTC (rev 41078)
+++ grass/trunk/lib/gis/parser.c 2010-02-18 12:38:56 UTC (rev 41079)
@@ -435,6 +435,13 @@
exit(EXIT_SUCCESS);
+ /* If first arg is "--help-text" give a usage/syntax message
+ * with machine-readable sentinels */
+ if (strcmp(argv[1], "--help-text") == 0) {
+ G__usage_text();
+ exit(EXIT_SUCCESS);
/* If first arg is "--interface-description" then print out
* a xml description of the task */
if (strcmp(argv[1], "--interface-description") == 0) {
Modified: grass/trunk/lib/gis/parser_help.c
--- grass/trunk/lib/gis/parser_help.c 2010-02-18 10:43:52 UTC (rev 41078)
+++ grass/trunk/lib/gis/parser_help.c 2010-02-18 12:38:56 UTC (rev 41079)
@@ -20,8 +20,9 @@
#include "parser_local_proto.h"
-static void show_options(int, const char *);
-static int show(const char *, int );
+static void usage(FILE *fp, int markers);
+static void show_options(FILE *fp, int maxlen, const char *str);
+static int show(FILE *fp, const char *item, int len);
* \brief Command line help/usage message.
@@ -45,6 +46,16 @@
void G_usage(void)
+ usage(stderr, 0);
+void G__usage_text(void)
+ usage(stdout, 1);
struct Option *opt;
struct Flag *flag;
char item[256];
@@ -61,21 +72,30 @@
st->pgm_name = "??";
if (st->module_info.label || st->module_info.description) {
- fprintf(stderr, _("\nDescription:\n"));
+ fprintf(fp, "\n");
+ if (markers)
+ fprintf(fp, "{{{DESCRIPTION}}}\n");
+ fprintf(fp, "%s\n", _("Description:"));
if (st->module_info.label)
- fprintf(stderr, " %s\n", st->module_info.label);
+ fprintf(fp, " %s\n", st->module_info.label);
if (st->module_info.description)
- fprintf(stderr, " %s\n", st->module_info.description);
+ fprintf(fp, " %s\n", st->module_info.description);
if (st->module_info.keywords) {
- fprintf(stderr, _("\nKeywords:\n "));
- G__print_keywords(stderr, NULL);
- fprintf(stderr, "\n");
+ if (markers)
+ fprintf(fp, "{{{KEYWORDS}}}\n");
+ fprintf(fp, "%s\n ", _("Keywords:"));
+ G__print_keywords(fp, NULL);
- fprintf(stderr, _("\nUsage:\n "));
+ if (markers)
+ fprintf(fp, "{{{USAGE}}}\n");
+ fprintf(fp, "%s\n ", _("Usage:"));
- len = show(st->pgm_name, 1);
+ len = show(fp, st->pgm_name, 1);
/* Print flags */
@@ -88,7 +108,7 @@
item[n] = flag->key;
item[n++] = ']';
item[n] = 0;
- len = show(item, len);
+ len = show(fp, item, len);
maxlen = 0;
@@ -120,42 +140,44 @@
if (!opt->required)
strcat(item, "]");
opt = opt->next_opt;
if (new_prompt) {
strcpy(item, " [--overwrite]");
strcpy(item, " [--verbose]");
strcpy(item, " [--quiet]");
/* Print help info for flags */
- fprintf(stderr, _("\nFlags:\n"));
+ if (markers)
+ fprintf(fp, "{{{FLAGS}}}\n");
+ fprintf(fp, "%s\n", _("Flags:"));
if (st->n_flags) {
flag = &st->first_flag;
while (flag != NULL) {
- fprintf(stderr, " -%c ", flag->key);
+ fprintf(fp, " -%c ", flag->key);
if (flag->label) {
- fprintf(stderr, "%s\n", flag->label);
+ fprintf(fp, "%s\n", flag->label);
if (flag->description)
- fprintf(stderr, " %s\n", flag->description);
+ fprintf(fp, " %s\n", flag->description);
else if (flag->description) {
- fprintf(stderr, "%s\n", flag->description);
+ fprintf(fp, "%s\n", flag->description);
flag = flag->next_flag;
@@ -163,39 +185,42 @@
if (new_prompt)
- fprintf(stderr, " --o %s\n",
+ fprintf(fp, " --o %s\n",
_("Allow output files to overwrite existing files"));
- fprintf(stderr, " --v %s\n", _("Verbose module output"));
- fprintf(stderr, " --q %s\n", _("Quiet module output"));
+ fprintf(fp, " --v %s\n", _("Verbose module output"));
+ fprintf(fp, " --q %s\n", _("Quiet module output"));
/* Print help info for options */
if (st->n_opts) {
- fprintf(stderr, _("\nParameters:\n"));
+ if (markers)
+ fprintf(fp, "{{{PARAMETERS}}}\n");
+ fprintf(fp, "%s\n", _("Parameters:"));
opt = &st->first_option;
while (opt != NULL) {
- fprintf(stderr, " %*s ", maxlen, opt->key);
+ fprintf(fp, " %*s ", maxlen, opt->key);
if (opt->label) {
- fprintf(stderr, "%s\n", opt->label);
+ fprintf(fp, "%s\n", opt->label);
if (opt->description) {
- fprintf(stderr, " %*s %s\n",
+ fprintf(fp, " %*s %s\n",
maxlen, " ", opt->description);
else if (opt->description) {
- fprintf(stderr, "%s\n", opt->description);
+ fprintf(fp, "%s\n", opt->description);
if (opt->options)
- show_options(maxlen, opt->options);
+ show_options(fp, maxlen, opt->options);
- fprintf (stderr, " %*s options: %s\n", maxlen, " ",
+ fprintf (fp, " %*s options: %s\n", maxlen, " ",
_(opt->options)) ;
if (opt->def)
- fprintf(stderr, _(" %*s default: %s\n"), maxlen, " ",
+ fprintf(fp, _(" %*s default: %s\n"), maxlen, " ",
opt->def);
if (opt->descs) {
@@ -203,7 +228,7 @@
while (opt->opts[i]) {
if (opt->descs[i])
- fprintf(stderr, " %*s %s: %s\n",
+ fprintf(fp, " %*s %s: %s\n",
maxlen, " ", opt->opts[i], opt->descs[i]);
i++;
@@ -215,13 +240,13 @@
-static void show_options(int maxlen, const char *str)
char *buff = G_store(str);
char *p1, *p2;
int totlen, len;
- fprintf(stderr, _(" %*s options: "), maxlen, " ");
+ fprintf(fp, _(" %*s options: "), maxlen, " ");
totlen = maxlen + 13;
p1 = buff;
while ((p2 = strchr(p1, ','))) {
@@ -229,30 +254,30 @@
len = strlen(p1) + 1;
if ((len + totlen) > 76) {
- fprintf(stderr, "\n %*s", maxlen + 13, " ");
+ fprintf(fp, "\n %*s", maxlen + 13, " ");
- fprintf(stderr, "%s,", p1);
+ fprintf(fp, "%s,", p1);
totlen += len;
p1 = p2 + 1;
len = strlen(p1);
- fprintf(stderr, "%s\n", p1);
+ fprintf(fp, "%s\n", p1);
G_free(buff);
-static int show(const char *item, int len)
int n;
n = strlen(item) + (len > 0);
if (n + len > 76) {
if (len)
- fprintf(stderr, "\n ");
+ fprintf(fp, "\n ");
len = 0;
- fprintf(stderr, "%s", item);
+ fprintf(fp, "%s", item);
return n + len;
Modified: grass/trunk/lib/gis/parser_local_proto.h
--- grass/trunk/lib/gis/parser_local_proto.h 2010-02-18 10:43:52 UTC (rev 41078)
+++ grass/trunk/lib/gis/parser_local_proto.h 2010-02-18 12:38:56 UTC (rev 41079)
@@ -43,6 +43,7 @@
void G__usage_xml(void);
void G__usage_html(void);
+void G__usage_text(void);
void G__script(void);
void G__wps_print_process_description(void);
int G__uses_new_gisprompt(void);
