[GRASS-SVN] r41093 - grass/trunk/locale/po
svn_grass at osgeo.org
Thu Feb 18 08:34:00 EST 2010
Author: neteler
Date: 2010-02-18 08:34:00 -0500 (Thu, 18 Feb 2010)
New Revision: 41093
grass/trunk/locale/po/grasslibs_de.po
grass/trunk/locale/po/grassmods_de.po
cont'ed
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po 2010-02-18 13:33:41 UTC (rev 41092)
+++ grass/trunk/locale/po/grasslibs_de.po 2010-02-18 13:34:00 UTC (rev 41093)
@@ -12,7 +12,7 @@
"Project-Id-Version: grasslibs_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-02-06 20:42+0100\n"
-"PO-Revision-Date: 2010-02-12 08:45+0100\n"
+"PO-Revision-Date: 2010-02-18 14:33+0100\n"
"Last-Translator: Markus Neteler <neteler osgeo.org>\n"
"Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -685,7 +685,7 @@
#: ../lib/raster/color_rules.c:114
msgid "R/G/B not in range 0-255"
-msgstr ""
+msgstr "R/G/B nicht im Bereich 0-255"
#: ../lib/raster/color_rules.c:116
msgid "invalid color name"
@@ -693,7 +693,7 @@
#: ../lib/raster/color_rules.c:118
msgid "percentage not in range 0-100"
-msgstr ""
+msgstr "Prozent nicht im Bereich 0-100"
#: ../lib/raster/color_rules.c:120
msgid "invalid value"
@@ -721,9 +721,8 @@
msgstr "Raster Karte Raster Karte"
#: ../lib/raster/get_cellhd.c:70
-#, fuzzy
msgid "which is missing."
-msgstr "welche fehlt"
+msgstr "welches fehlt."
#: ../lib/raster/get_cellhd.c:71
#, fuzzy
@@ -1008,9 +1007,9 @@
msgstr ""
#: ../lib/proj/get_proj.c:148
-#, fuzzy, c-format
+#, c-format
msgid "Invalid zone %s specified"
-msgstr "ungültiger Ellipsoid %s in Datei."
+msgstr "Ungültige Zone %s angegeben"
#: ../lib/proj/get_proj.c:228
msgid "Unable to initialise PROJ.4 with the following parameter list:"
@@ -1019,35 +1018,32 @@
#: ../lib/proj/get_proj.c:236
#, c-format
msgid "The error message: %s"
-msgstr ""
+msgstr "Die Fehlermeldung: %s"
#: ../lib/proj/get_proj.c:294
msgid "Option input overflowed option table"
msgstr ""
#: ../lib/proj/get_proj.c:325
-#, fuzzy, c-format
+#, c-format
msgid "Unable to initialize pj cause: %s"
-msgstr "Kann Datei %s in %s nicht öffnen"
+msgstr "Kann pj nicht initialisieren: %s"
#: ../lib/proj/get_proj.c:401
-#, fuzzy
msgid "Input Projection Parameters"
-msgstr "Parameter"
+msgstr "Eingabeparameter der Projektion"
#: ../lib/proj/get_proj.c:404
msgid "Input Unit Factor"
-msgstr ""
+msgstr "Einheitenfaktor der Eingabe"
#: ../lib/proj/get_proj.c:414
-#, fuzzy
msgid "Output Projection Parameters"
-msgstr "Ergebnis Parameter"
+msgstr "Ausgabeparameter der Projektion"
#: ../lib/proj/get_proj.c:417
-#, fuzzy
msgid "Output Unit Factor"
-msgstr "Ergebnis"
+msgstr "Einheitfaktor der Ausgabe"
#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
#, fuzzy, c-format
@@ -1145,9 +1141,9 @@
msgstr ""
#: ../lib/gis/find_file.c:88
-#, fuzzy, c-format
+#, c-format
msgid "Using <%s@%s>"
-msgstr "Kann [%s] nicht finden."
+msgstr "Benutze <%s@%s>"
#: ../lib/gis/view.c:176
#, c-format
@@ -1544,7 +1540,7 @@
#: ../lib/gis/parser_standard_options.c:90
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "WHERE Bedingungen des SQL-Ausdrucksohne das Schlüsselwort 'where'."
+msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
#: ../lib/gis/parser_standard_options.c:91
msgid "Example: income < 1000 and inhab >= 10000"
@@ -1754,15 +1750,15 @@
#: ../lib/gis/parser_html.c:40
msgid "NAME"
-msgstr ""
+msgstr "NAME"
#: ../lib/gis/parser_html.c:53
msgid "KEYWORDS"
-msgstr ""
+msgstr "SCHLÜSSELWÖRTER"
#: ../lib/gis/parser_html.c:58
msgid "SYNOPSIS"
-msgstr ""
+msgstr "SYNOPSIS"
#: ../lib/gis/parser_html.c:126
msgid "Flags"
@@ -2544,9 +2540,8 @@
msgstr "Kann Header-Datei für [%s in %s] nicht erstellen."
#: ../lib/vector/Vlib/geos.c:53 ../lib/vector/Vlib/read.c:105
-#, fuzzy
msgid "vector map is not opened"
-msgstr "Vektor Karte"
+msgstr "Vektorkarte ist nicht geöffnet"
#: ../lib/vector/Vlib/geos.c:56
#, fuzzy, c-format
@@ -2644,9 +2639,8 @@
msgstr "Erstelle Topologie für die Vektorkarte <%s>..."
#: ../lib/vector/Vlib/build.c:147
-#, fuzzy
msgid "Topology was built"
-msgstr "Die Topologie wurde erstellt\n"
+msgstr "Die Topologie wurde erstellt"
#: ../lib/vector/Vlib/build.c:159
#, c-format
@@ -2930,9 +2924,8 @@
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:523
-#, fuzzy
msgid "Registering primitives..."
-msgstr "Registriere Linien..."
+msgstr "Registriere Primitive..."
#: ../lib/vector/Vlib/build_nat.c:532
msgid "Unable to read vector map"
@@ -3247,7 +3240,7 @@
#: ../lib/vector/Vlib/write.c:145 ../lib/vector/Vlib/write.c:179
#, c-format
msgid "%s: Area %d does not exist"
-msgstr ""
+msgstr "%s: Fläche %d existiert nicht"
#: ../lib/vector/Vlib/write.c:226
#, fuzzy
@@ -5791,9 +5784,8 @@
#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
#~ msgstr "Raster Karte."
-#, fuzzy
#~ msgid " Invalid format."
-#~ msgstr "Ungültiges Format\n"
+#~ msgstr " Ungültiges Format."
#, fuzzy
#~ msgid "Unable to spawn the 'wish' program"
@@ -5839,7 +5831,7 @@
#~ msgstr "Socket wird bereits benutzt oder akzeptiert keine Verbindungen."
#~ msgid "Use d.mon to select a monitor"
-#~ msgstr "Bitte verwenden Sie \"d.mon\", um ein Grafikfenster auszuwählen."
+#~ msgstr "Bitte verwenden Sie d.mon, um ein Grafikfenster auszuwählen"
#~ msgid "Trying to connect to something not a socket."
#~ msgstr ""
@@ -6117,7 +6109,7 @@
#~ msgstr "Kann Datei %s nicht öffnen."
#~ msgid "Unable to allocate memory\n"
-#~ msgstr "Kann keinen Speicher belegen.\n"
+#~ msgstr "Kann keinen Speicher belegen\n"
#~ msgid "Unable to open temporary file"
#~ msgstr "Kann temporäre Datei nicht öffnen."
@@ -6351,3 +6343,15 @@
#~ msgid "Table has no columns"
#~ msgstr "Tabelle hat keine Spalten"
+#~ msgid "Allow overwrite"
+#~ msgstr "Erlaube Überschreiben"
+#~ msgid "Run with minimal output messages"
+#~ msgstr "Lasse mit minimalen Ausgabemeldungen laufen"
+#~ msgid "not implemented"
+#~ msgstr "nicht implementiert"
+#~ msgid "OGR format cannot be updated"
+#~ msgstr "OGR Format kann nicht aktualisiert werden"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2010-02-18 13:33:41 UTC (rev 41092)
+++ grass/trunk/locale/po/grassmods_de.po 2010-02-18 13:34:00 UTC (rev 41093)
@@ -27302,7 +27302,7 @@
#: ../locale/scriptstrings/v.out.gps_to_translate.c:15
#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
#: ../locale/scriptstrings/v.out.gps_to_translate.c:16
