[GRASS-SVN] r41097 - grass-addons/grass7/raster/r.univar.zonal
Thu Feb 18 10:56:48 EST 2010
Author: mmetz
Date: 2010-02-18 10:56:48 -0500 (Thu, 18 Feb 2010)
New Revision: 41097
   grass-addons/grass7/raster/r.univar.zonal/Makefile
   grass-addons/grass7/raster/r.univar.zonal/globals.h
   grass-addons/grass7/raster/r.univar.zonal/r.univar_main.c
   grass-addons/grass7/raster/r.univar.zonal/r3.univar_main.c
   grass-addons/grass7/raster/r.univar.zonal/stats.c
r.univar.zonal for grass7
Modified: grass-addons/grass7/raster/r.univar.zonal/Makefile
--- grass-addons/grass7/raster/r.univar.zonal/Makefile	2010-02-18 15:50:11 UTC (rev 41096)
+++ grass-addons/grass7/raster/r.univar.zonal/Makefile	2010-02-18 15:56:48 UTC (rev 41097)
@@ -1,23 +1,18 @@
 MODULE_TOPDIR = ../..
-LIBES = $(G3DLIB) $(GISLIB)
-DEPENDENCIES = $(G3DDEP) $(GISDEP)
+LIBES2 = $(RASTERLIB) $(GISLIB) $(MATHLIB)
+LIBES3 = $(G3DLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(G3DDEP) $(GISDEP) $(RASTERDEP)
-#needed for htmlmulti
 PROGRAMS = r.univar.zonal r3.univar.zonal
+r_univar_zonal_OBJS = r.univar_main.o sort.o stats.o
+r3_univar_zonal_OBJS = r3.univar_main.o sort.o stats.o
 include $(MODULE_TOPDIR)/include/Make/Multi.make
-R3UNIVAR = $(BIN)/r3.univar.zonal$(EXE)
-RUNIVAR = $(BIN)/r.univar.zonal$(EXE)
+default: multi
-default: $(RUNIVAR) $(R3UNIVAR)
-	$(MAKE) htmlmulti
-$(RUNIVAR): $(OBJDIR)/r.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
-	$(CC) $(LDFLAGS) -o $@ $^ $(FMODE_OBJ) $(LIBES) $(XDRLIB) $(MATHLIB)
-$(R3UNIVAR): $(OBJDIR)/r3.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
+$(BIN)/r.univar.zonal$(EXE): LIBES = $(LIBES2)
+$(BIN)/r3.univar.zonal$(EXE): LIBES = $(LIBES3)
Modified: grass-addons/grass7/raster/r.univar.zonal/globals.h
--- grass-addons/grass7/raster/r.univar.zonal/globals.h	2010-02-18 15:50:11 UTC (rev 41096)
+++ grass-addons/grass7/raster/r.univar.zonal/globals.h	2010-02-18 15:56:48 UTC (rev 41097)
@@ -1,10 +1,11 @@
  *  Calculates univariate statistics from the non-null cells
- *   Copyright (C) 2004-2007 by the GRASS Development Team
+ *   Copyright (C) 2004-2010 by the GRASS Development Team
  *   Author(s): Soeren Gebbert
  *              Based on r.univar from Hamish Bowman, University of Otago, New Zealand
  *              and Martin Landa
+ *              zonal loop by Markus Metz
  *      This program is free software under the GNU General Public
  *      License (>=v2). Read the file COPYING that comes with GRASS
@@ -20,6 +21,7 @@
 #include <math.h>
 #include <grass/gis.h>
 #include <grass/G3d.h>
+#include <grass/raster.h>
 #include <grass/glocale.h>
 /*- Parameters and global variables -----------------------------------------*/
@@ -30,7 +32,7 @@
     double min;
     double max;
     unsigned int n_perc;
-    int *perc;
+    double *perc;
     double sum_abs;
     int n;
     int size;
@@ -57,13 +59,8 @@
     struct Flag *shell_style, *extended, *table;
 } param_type;
-#ifdef MAIN
-param_type param;
-zone_type zone_info;
-#else
 extern param_type param;
 extern zone_type zone_info;
-#endif
 /* fn prototypes */
 void heapsort_double(double *data, int n);
Modified: grass-addons/grass7/raster/r.univar.zonal/r.univar_main.c
--- grass-addons/grass7/raster/r.univar.zonal/r.univar_main.c	2010-02-18 15:50:11 UTC (rev 41096)
+++ grass-addons/grass7/raster/r.univar.zonal/r.univar_main.c	2010-02-18 15:56:48 UTC (rev 41097)
@@ -16,11 +16,10 @@
 #include <assert.h>
 #include <string.h>
-#define MAIN
 #include "globals.h"
-/* local proto */
-void set_params();
+param_type param;
+zone_type zone_info;
 /* Set up the arguments we are expecting ********************************** */
@@ -42,7 +41,7 @@
     param.percentile = G_define_option();
     param.percentile->key = "percentile";
-    param.percentile->type = TYPE_INTEGER;
+    param.percentile->type = TYPE_DOUBLE;
     param.percentile->required = NO;
     param.percentile->multiple = YES;
     param.percentile->options = "0-100";
@@ -85,13 +84,14 @@
     char **p, *z;
     int fd, fdz, cell_type, min, max;
     struct Range zone_range;
-    char *mapset, *name;
+    const char *mapset, *name;
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("raster, statistics");
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("statistics"));
     module->description =
 	_("Calculates univariate statistics from the non-null cells of a raster map.");
@@ -123,19 +123,18 @@
     /* open zoning raster */
     if ((z = param.zonefile->answer)) {
-	mapset = G_find_cell2(z, "");
+	mapset = G_find_raster2(z, "");
 	fdz = open_raster(z);
-	cell_type = G_get_raster_map_type(fdz);
+	cell_type = Rast_get_map_type(fdz);
 	if (cell_type != CELL_TYPE)
 	    G_fatal_error("Zoning raster must be of type CELL");
-	if (G_read_range(z, mapset, &zone_range) == -1)
+	if (Rast_read_range(z, mapset, &zone_range) == -1)
 	    G_fatal_error("Can not read range for zoning raster");
-	if (G_get_range_min_max(&zone_range, &min, &max))
-	    G_fatal_error("Can not read range for zoning raster");
-	if (G_read_raster_cats(z, mapset, &(zone_info.cats)))
+	Rast_get_range_min_max(&zone_range, &min, &max);
+	if (Rast_read_cats(z, mapset, &(zone_info.cats)))
 	    G_warning("no category support for zoning raster");
 	zone_info.min = min;
@@ -159,7 +158,7 @@
 	if (map_type != -1) {
 	    /* NB: map_type must match when doing extended stats */
-	    int this_type = G_get_raster_map_type(fd);
+	    int this_type = Rast_get_map_type(fd);
 	    assert(this_type > -1);
 	    if (map_type < -1) {
@@ -176,12 +175,12 @@
 	process_raster(stats, fd, fdz, &region);
 	/* close input raster */
-	G_close_cell(fd);
+	Rast_close(fd);
     /* close zoning raster */
     if (z)
-	G_close_cell(fdz);
+	Rast_close(fdz);
     /* create the output */
     if (param.table->answer)
@@ -197,19 +196,16 @@
 static int open_raster(const char *infile)
-    char *mapset;
+    const char *mapset;
     int fd;
-    mapset = G_find_cell2(infile, "");
+    mapset = G_find_raster2(infile, "");
     if (mapset == NULL) {
 	G_fatal_error(_("Raster map <%s> not found"), infile);
-    fd = G_open_cell_old(infile, mapset);
-    if (fd < 0)
-	G_fatal_error(_("Unable to open raster map <%s>"), infile);
+    fd = Rast_open_old(infile, mapset);
     return fd;
@@ -228,7 +224,7 @@
     stats = create_univar_stat_struct(map_type, i);
     for (i = 0; i < n_zones; i++) {
 	for (j = 0; j < stats[i].n_perc; j++) {
-	    sscanf(param.percentile->answers[j], "%i", &(stats[i].perc[j]));
+	    sscanf(param.percentile->answers[j], "%lf", &(stats[i].perc[j]));
@@ -243,27 +239,25 @@
     const int rows = region->rows;
     const int cols = region->cols;
-    const RASTER_MAP_TYPE map_type = G_get_raster_map_type(fd);
-    const size_t value_sz = G_raster_size(map_type);
+    const RASTER_MAP_TYPE map_type = Rast_get_map_type(fd);
+    const size_t value_sz = Rast_cell_size(map_type);
     unsigned int row;
     void *raster_row;
     CELL *zoneraster_row;
     int n_zones = zone_info.n_zones;
-    raster_row = G_allocate_raster_buf(map_type);
+    raster_row = Rast_allocate_buf(map_type);
     if (n_zones)
-	zoneraster_row = G_allocate_c_raster_buf();
+	zoneraster_row = Rast_allocate_c_buf();
     for (row = 0; row < rows; row++) {
 	void *ptr;
 	CELL *zptr;
 	unsigned int col;
-	if (G_get_raster_row(fd, raster_row, row, map_type) < 0)
-	    G_fatal_error(_("Reading row %d"), row);
+	Rast_get_row(fd, raster_row, row, map_type);
 	if (n_zones) {
-	    if (G_get_c_raster_row(fdz, zoneraster_row, row) < 0)
+	    Rast_get_c_row(fdz, zoneraster_row, row);
 	    zptr = zoneraster_row;
@@ -275,7 +269,7 @@
 	    if (n_zones) {
 		/* skip NULL cells in zone map */
-		if (G_is_c_null_value(zptr)) {
+		if (Rast_is_c_null_value(zptr)) {
 		    ptr = G_incr_void_ptr(ptr, value_sz);
 		    zptr++;
 		    continue;
@@ -287,7 +281,7 @@
 	    stats[zone].size++;
 	    /* can't do stats with NULL cells in input map */
-	    if (G_is_null_value(ptr, map_type)) {
+	    if (Rast_is_null_value(ptr, map_type)) {
 		if (n_zones)
 		    zptr++;
Modified: grass-addons/grass7/raster/r.univar.zonal/r3.univar_main.c
--- grass-addons/grass7/raster/r.univar.zonal/r3.univar_main.c	2010-02-18 15:50:11 UTC (rev 41096)
+++ grass-addons/grass7/raster/r.univar.zonal/r3.univar_main.c	2010-02-18 15:56:48 UTC (rev 41097)
@@ -16,12 +16,11 @@
 #include <string.h>
-#define MAIN
 #include "grass/G3d.h"
-/* local proto */
-void set_params();
+param_type param;
@@ -43,7 +42,7 @@
@@ -82,7 +81,7 @@
     univar_stat *stats;
     char *infile, *zonemap;
-    void *map, *zmap;
+    void *map, *zmap = NULL;
     G3D_Region region;
     unsigned int i;
     unsigned int rows, cols, depths;
@@ -97,7 +96,8 @@
     G_gisinit(argv[0]);
-    module->keywords = _("raster3d, statistics");
+    G_add_keyword(_("raster3d"));
 	_("Calculates univariate statistics from the non-null 3d cells of a raster3d map.");
@@ -134,7 +134,7 @@
     zone_info.n_zones = 0;
     /* open 3D zoning raster with default region */
-    if ((zonemap = param.zonefile->answer)) {
+    if ((zonemap = param.zonefile->answer) != NULL) {
 	if (NULL == (mapset = G_find_grid3(zonemap, "")))
 	    G3d_fatalError(_("Requested g3d map <%s> not found"), zonemap);
@@ -156,7 +156,7 @@
 	if (G3d_readRange(zonemap, mapset, &zone_range) == -1)
 	G3d_range_min_max(zmap, &dmin, &dmax);
-	if (G_read_raster_cats(zonemap, mapset, &(zone_info.cats)))
+	if (Rast_read_cats(zonemap, mapset, &(zone_info.cats)))
 	/* properly round dmin and dmax */
@@ -193,11 +193,13 @@
     while (param.percentile->answers[i])
 	i++;
-    for (i = 0; i < stats->n_perc; i++) {
-	sscanf(param.percentile->answers[i], "%i", &stats->perc[i]);
+    for (i = 0; i < zone_info.n_zones; i++) {
+	unsigned int j;
+	for (j = 0; j < stats[i].n_perc; j++) {
-    stats->n = 0;
     for (z = 0; z < depths; z++) {	/*From the bottom to the top */
 	if (!(param.shell_style->answer))
 	    G_percent(z, depths - 1, 10);
Modified: grass-addons/grass7/raster/r.univar.zonal/stats.c
--- grass-addons/grass7/raster/r.univar.zonal/stats.c	2010-02-18 15:50:11 UTC (rev 41096)
+++ grass-addons/grass7/raster/r.univar.zonal/stats.c	2010-02-18 15:56:48 UTC (rev 41097)
@@ -34,7 +34,7 @@
 	stats[i].max = 0.0 / 0.0;	/*set to nan as default */
 	stats[i].n_perc = n_perc;
 	if (n_perc > 0)
-	    stats[i].perc = (int *)G_malloc(n_perc * sizeof(int));
+	    stats[i].perc = (double *)G_malloc(n_perc * sizeof(double));
 	else
 	    stats[i].perc = NULL;
 	stats[i].sum_abs = 0.0;
@@ -135,8 +135,11 @@
 	sprintf(sum_str, "%.10f", stats[z].sum);
 	G_trim_decimal(sum_str);
-	if (zone_info.n_zones)
-	    fprintf(stdout, "\nzone %d %s\n\n", z + zone_info.min, G_get_cat(z + zone_info.min, &(zone_info.cats)));
+	if (zone_info.n_zones) {
+	    int z_cat = z + zone_info.min;
+	    fprintf(stdout, "\nzone %d %s\n\n", z_cat, Rast_get_c_cat(&z_cat, &(zone_info.cats)));
 	if (!param.shell_style->answer) {
 	    fprintf(stdout, "total null and non-null cells: %d\n", stats[z].size);
@@ -240,7 +243,10 @@
 		fprintf(stdout, "median=%g\n", median);
 		fprintf(stdout, "third_quartile=%g\n", quartile_75);
 		for (i = 0; i < stats[z].n_perc; i++) {
-		    fprintf(stdout, "percentile_%d=%g\n", stats[z].perc[i],
+		    char buf[24];
+		    sprintf(buf, "%.15g", stats[z].perc[i]);
+		    G_strchg(buf, '.', '_');
+		    fprintf(stdout, "percentile_%s=%g\n", buf,
 			    quartile_perc[i]);
@@ -255,18 +261,26 @@
-		    if (stats[z].perc[i] % 10 == 1 && stats[z].perc[i] != 11)
-			fprintf(stdout, "%dst percentile: %g\n", stats[z].perc[i],
+		    if (stats[z].perc[i] == (int)stats[z].perc[i]) {
+			/* percentile is an exact integer */
+			if ((int)stats[z].perc[i] % 10 == 1 && (int)stats[z].perc[i] != 11)
+			    fprintf(stdout, "%dst percentile: %g\n", (int)stats[z].perc[i],
+				    quartile_perc[i]);
+			else if ((int)stats[z].perc[i] % 10 == 2 && (int)stats[z].perc[i] != 12)
+			    fprintf(stdout, "%dnd percentile: %g\n", (int)stats[z].perc[i],
+			else if ((int)stats[z].perc[i] % 10 == 3 && (int)stats[z].perc[i] != 13)
+			    fprintf(stdout, "%drd percentile: %g\n", (int)stats[z].perc[i],
+			else
+			    fprintf(stdout, "%dth percentile: %g\n", (int)stats[z].perc[i],
+		    else {
+			/* percentile is not an exact integer */
+			fprintf(stdout, "%.15g percentile: %g\n", stats[z].perc[i],
 				quartile_perc[i]);
-		    else if (stats[z].perc[i] % 10 == 2 && stats[z].perc[i] != 12)
-			fprintf(stdout, "%dnd percentile: %g\n", stats[z].perc[i],
-				quartile_perc[i]);
-		    else if (stats[z].perc[i] % 10 == 3 && stats[z].perc[i] != 13)
-			fprintf(stdout, "%drd percentile: %g\n", stats[z].perc[i],
-		    else
-			fprintf(stdout, "%dth percentile: %g\n", stats[z].perc[i],
 	    G_free((void *)quartile_perc);
@@ -313,7 +327,18 @@
 	fprintf(stdout, "%smedian", zone_info.sep);
 	fprintf(stdout, "%sthird_quart", zone_info.sep);
 	for (i = 0; i < stats[0].n_perc; i++) {
-	    fprintf(stdout, "%sperc_%d", zone_info.sep, stats[0].perc[i]);
+	    if (stats[0].perc[i] == (int)stats[0].perc[i]) {
+		fprintf(stdout, "%sperc_%d", zone_info.sep, (int)stats[0].perc[i]);
+	    else {
+		char buf[24];
+		sprintf(buf, "%.15g", stats[0].perc[i]);
+		fprintf(stdout, "%sperc_%s", zone_info.sep, buf);
     fprintf(stdout, "\n");
@@ -344,10 +369,11 @@
 	var_coef = (stdev / mean) * 100.;	/* perhaps stdev/fabs(mean) ? */
 	    /* zone number */
 	    fprintf(stdout, "%d%s", z + zone_info.min, zone_info.sep);
 	    /* zone label */
-	    fprintf(stdout,"%s%s", G_get_cat(z + zone_info.min, &(zone_info.cats)), zone_info.sep);
+	    fprintf(stdout,"%s%s", Rast_get_c_cat(&z_cat, &(zone_info.cats)), zone_info.sep);
 	/* total cells */
