[GRASS-SVN] r41107 - grass/branches/develbranch_6/vector/lidar/v.surf.bspline
Fri Feb 19 02:57:56 EST 2010
Author: mmetz
Date: 2010-02-19 02:57:55 -0500 (Fri, 19 Feb 2010)
New Revision: 41107
   grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c
make wxGUI happy (backport from relbr r41106)
Modified: grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c
--- grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c	2010-02-19 07:52:40 UTC (rev 41106)
+++ grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c	2010-02-19 07:57:55 UTC (rev 41107)
@@ -147,8 +147,9 @@
     dfield_opt = G_define_standard_option(G_OPT_V_FIELD);
     dfield_opt->description =
-	_("If set to -1, z coordinates are used. (3D vector only)");
-    dfield_opt->answer = "-1";
+	_("If set to 0, z coordinates are used. (3D vector only)");
+    dfield_opt->answer = "0";
+    dfield_opt->gisprompt = "old_layer,layer,layer_zero";
     dfield_opt->guisection = _("Settings");
     col_opt = G_define_option();
