[GRASS-SVN] r41110 - grass/trunk/vector/lidar/v.surf.bspline
svn_grass at osgeo.org
Fri Feb 19 03:30:15 EST 2010
Author: mmetz
Date: 2010-02-19 03:30:13 -0500 (Fri, 19 Feb 2010)
New Revision: 41110
grass/trunk/vector/lidar/v.surf.bspline/main.c
sync to v.surf.* modules in trunk
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-02-19 08:12:51 UTC (rev 41109)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-02-19 08:30:13 UTC (rev 41110)
@@ -63,7 +63,7 @@
struct GModule *module;
struct Option *in_opt, *in_ext_opt, *out_opt, *out_map_opt, *passoE_opt,
*passoN_opt, *lambda_f_opt, *type_opt, *dfield_opt, *col_opt;
- struct Flag *cross_corr_flag, *spline_step_flag;
+ struct Flag *cross_corr_flag, *spline_step_flag, *withz_flag;
struct Reg_dimens dims;
struct Cell_head elaboration_reg, original_reg;
@@ -97,6 +97,11 @@
spline_step_flag->description =
_("Estimate point density and distance for the input vector points within the current region extends and quit");
+ withz_flag = G_define_flag();
+ withz_flag->key = 'z';
+ withz_flag->description = _("Use z coordinates for approximation (3D vector maps only)");
+ withz_flag->guisection = _("Settings");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
in_ext_opt = G_define_standard_option(G_OPT_V_INPUT);
@@ -148,10 +153,7 @@
lambda_f_opt->guisection = _("Settings");
dfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- dfield_opt->description =
- _("If set to 0, z coordinates are used. (3D vector only)");
- dfield_opt->answer = "0";
- dfield_opt->gisprompt = "old_layer,layer,layer_zero";
+ dfield_opt->answer = "1";
dfield_opt->guisection = _("Settings");
col_opt = G_define_option();
@@ -227,13 +229,16 @@
bspline_field = Vect_get_field_number(&In, dfield_opt->answer);
bspline_column = col_opt->answer;
- /* check availability of z values
- * column option overrrides 3D z coordinates */
- if (!Vect_is_3d(&In) && (bspline_field <= 0 || bspline_column == NULL))
- G_fatal_error(_("Need either 3D vector or layer and column with z values"));
- if (bspline_field > 0 && bspline_column == NULL)
- G_fatal_error(_("Layer but not column with z values given"));
+ /* check availability of z values */
+ if (withz_flag->answer && !Vect_is_3d(&In)) {
+ G_fatal_error(_("Input vector is not 3D, can not use z coordinates"));
+ else if (!withz_flag->answer && (bspline_field <= 0 || bspline_column == NULL))
+ G_fatal_error(_("Both layer and column with z values must be given"));
+ if (withz_flag->answer)
+ bspline_field = 0;
/* Estimate point density and mean distance for current region */
if (spline_step_flag->answer) {
double dens, dist;
