Author: hamish
Date: 2010-02-21 01:41:18 -0500 (Sun, 21 Feb 2010)
New Revision: 41141
grass/trunk/lib/init/functions.sh
minor clean
Modified: grass/trunk/lib/init/functions.sh
--- grass/trunk/lib/init/functions.sh 2010-02-21 04:37:13 UTC (rev 41140)
+++ grass/trunk/lib/init/functions.sh 2010-02-21 06:41:18 UTC (rev 41141)
@@ -428,7 +428,7 @@
gui_startup()
if [ "$GRASS_GUI" = "wxpython" ] ; then
- # eval `foo` will return subshell return code and not app foo return code!!!
+ # eval `foo` will return subshell return code and not app foo return code!!!?
eval '"$GRASS_PYTHON" "$WXPYTHONGRASSBASE/gis_set.py"'
thetest=$?
fi
@@ -587,19 +587,15 @@
start_gui()
- # Start the chosen GUI but ignore text
+ # Start the chosen GUI, or if in text-mode, don't.
if [ "$GRASS_DEBUG" -ne 0 ] ; then
- echo "GRASS GUI should be $GRASS_GUI"
+ echo "GRASS GUI is <$GRASS_GUI>"
fi
case "$GRASS_GUI" in
- # Check for gui interface
wxpython)
- eval '"$GRASS_PYTHON" "$GISBASE/etc/wxpython/wxgui.py" &'
-# "$GISBASE/etc/wxpython/wxgui.py"
+ "$GRASS_PYTHON" "$GISBASE/etc/wxpython/wxgui.py" &
# Ignore others
